SetIntersectIter< Container > Class Template Reference
+ Inheritance diagram for SetIntersectIter< Container >:
+ Collaboration diagram for SetIntersectIter< Container >:
Public Member Functions
 SetIntersectIter (iBase_EntityType type, iMesh_EntityTopology topology, EntityHandle set, EntityHandle other_set, int array_sz)
virtual ~SetIntersectIter ()
ErrorCode intersect_with_set (Interface *mb, Range &range)
ErrorCode intersect_with_set (Interface *mb, std::vector< EntityHandle > &list)
virtual ErrorCode reset (Interface *mb)
Private Attributes
EntityHandle otherSet
Detailed Description
template<class Container>
class SetIntersectIter< Container >
Definition at line 301 of file iMeshP_MOAB.cpp.
SetIntersectIter< Container >::SetIntersectIter ( iBase_EntityType  type,
EntityHandle  set,
int  array_sz
) [inline]
Definition at line 307 of file iMeshP_MOAB.cpp.
        : MBIter< Container >( type, topology, set, array_sz ), otherSet( other_set )
virtual SetIntersectIter< Container >::~SetIntersectIter ( ) [inline, virtual]
Definition at line 315 of file iMeshP_MOAB.cpp.
Member Function Documentation
ErrorCode SetIntersectIter< Container >::intersect_with_set ( Interface mb,
Range range
) [inline]
Definition at line 317 of file iMeshP_MOAB.cpp.
References ErrorCode, moab::Interface::get_entities_by_handle(), and moab::intersect().
        Range tmp;
        ErrorCode result;
        result = mb->get_entities_by_handle( otherSet, tmp );
        range  = intersect( range, tmp );
        return result;
std::vector< EntityHandle > &  list
) [inline]
Definition at line 326 of file iMeshP_MOAB.cpp.
References moab::Interface::contains_entities(), and MB_SUCCESS.
        size_t w = 0;
        for( size_t r = 0; r < list.size(); ++r )
            if( mb->contains_entities( otherSet, &list[r], 1 ) ) list[w++] = list[r];
        list.resize( w );
        return MB_SUCCESS;
virtual ErrorCode SetIntersectIter< Container >::reset ( Interface mb) [inline, virtual]
Definition at line 337 of file iMeshP_MOAB.cpp.
References ErrorCode, and MB_SUCCESS.
Referenced by iMeshP_initEntArrIter().
        ErrorCode result = MBIter< Container >::reset( mb );
        if( MB_SUCCESS != result ) return result;
        result                       = intersect_with_set( mb, MBIter< Container >::iterData );
        MBIter< Container >::iterPos = MBIter< Container >::iterData.begin();
        return result;
Member Data Documentation
EntityHandle SetIntersectIter< Container >::otherSet [private]
Definition at line 304 of file iMeshP_MOAB.cpp.
List of all members.
