SlaveBoundaryVerticesTest Class Reference
+ Inheritance diagram for SlaveBoundaryVerticesTest:
+ Collaboration diagram for SlaveBoundaryVerticesTest:
Public Member Functions
void test_fail_if_slaves_not_calculated ()
void test_one_depth_from_fixed ()
void test_two_depth_from_fixed ()
void test_zero_depth_from_surface ()
void test_one_depth_from_surface ()
void test_two_depth_from_surface ()
void test_zero_depth_from_curve ()
void test_one_depth_from_curve ()
void test_two_depth_from_curve ()
Private Member Functions
 CPPUNIT_TEST_SUITE (SlaveBoundaryVerticesTest)
 CPPUNIT_TEST (test_fail_if_slaves_not_calculated)
 CPPUNIT_TEST (test_one_depth_from_fixed)
 CPPUNIT_TEST (test_two_depth_from_fixed)
 CPPUNIT_TEST (test_zero_depth_from_surface)
 CPPUNIT_TEST (test_one_depth_from_surface)
 CPPUNIT_TEST (test_two_depth_from_surface)
 CPPUNIT_TEST (test_zero_depth_from_curve)
 CPPUNIT_TEST (test_one_depth_from_curve)
 CPPUNIT_TEST (test_two_depth_from_curve)
 CPPUNIT_TEST_SUITE_END ()
void test_slaved_common (unsigned depth, unsigned boundary)
void make_mesh (MeshImpl &mesh, DomainClassifier &domain, const int intervals)
Detailed Description
Definition at line 53 of file SlaveBoundaryVerticesTest.cpp.
Member Function Documentation
void SlaveBoundaryVerticesTest::make_mesh ( MeshImpl mesh,
DomainClassifier domain,
const int  intervals
) [private]
Definition at line 129 of file SlaveBoundaryVerticesTest.cpp.
References ASSERT_NO_ERROR, MBMesquite::DomainClassifier::classify_skin_geometrically(), MBMesquite::MeshImpl::clear(), corners, MBMesquite::DomainClassifier::delete_sub_domains(), input_file, MBMesquite::MeshImpl::read_vtk(), MBMesquite::PlanarDomain::XY, MBMesquite::PlanarDomain::XZ, and MBMesquite::PlanarDomain::YZ.
    MsqPrintError err( std::cerr );
    const char input_file[] = MESH_FILES_DIR "3D/vtk/quadratic/6x6x6-hex20.vtk";
    const Vector3D min( -3, -3, -3 );
    const Vector3D max( 3, 3, 3 );
    const Vector3D space = ( max - min ) * 1.0 / ( intervals );
    mesh.clear();
    mesh.read_vtk( input_file, err );
    ASSERT_NO_ERROR( err );
    const Vector3D corners[8] = { Vector3D( min[0], min[1], min[2] ), Vector3D( max[0], min[1], min[2] ),
                                  Vector3D( max[0], max[1], min[2] ), Vector3D( min[0], max[1], min[2] ),
                                  Vector3D( min[0], min[1], max[2] ), Vector3D( max[0], min[1], max[2] ),
                                  Vector3D( max[0], max[1], max[2] ), Vector3D( min[0], max[1], max[2] ) };
    MeshDomain* subdomains[26] = { new PlanarDomain( PlanarDomain::XZ, min[1] ),
                                   new PlanarDomain( PlanarDomain::YZ, max[0] ),
                                   new PlanarDomain( PlanarDomain::XZ, max[1] ),
                                   new PlanarDomain( PlanarDomain::YZ, min[0] ),
                                   new PlanarDomain( PlanarDomain::XY, min[2] ),
                                   new PlanarDomain( PlanarDomain::XY, max[2] ),
                                   new LineDomain( corners[0], corners[1] - corners[0] ),
                                   new LineDomain( corners[1], corners[2] - corners[1] ),
                                   new LineDomain( corners[2], corners[3] - corners[2] ),
                                   new LineDomain( corners[3], corners[0] - corners[3] ),
                                   new LineDomain( corners[0], corners[4] - corners[0] ),
                                   new LineDomain( corners[1], corners[5] - corners[1] ),
                                   new LineDomain( corners[2], corners[6] - corners[0] ),
                                   new LineDomain( corners[3], corners[7] - corners[1] ),
                                   new LineDomain( corners[4], corners[5] - corners[4] ),
                                   new LineDomain( corners[5], corners[6] - corners[5] ),
                                   new LineDomain( corners[6], corners[7] - corners[6] ),
                                   new LineDomain( corners[7], corners[4] - corners[7] ),
                                   new PointDomain( corners[0] ),
                                   new PointDomain( corners[1] ),
                                   new PointDomain( corners[2] ),
                                   new PointDomain( corners[3] ),
                                   new PointDomain( corners[4] ),
                                   new PointDomain( corners[5] ),
                                   new PointDomain( corners[6] ),
                                   new PointDomain( corners[7] ) };
    const int subdims[26]      = { 2, 2, 2, 2, 2, 2, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0 };
    DomainClassifier::classify_skin_geometrically( domain, &mesh, 1e-6, subdomains, subdims, 26, err );
    domain.delete_sub_domains( true );
void SlaveBoundaryVerticesTest::test_slaved_common ( unsigned  depth,
unsigned  boundary
) [private]
Definition at line 179 of file SlaveBoundaryVerticesTest.cpp.
References MBMesquite::adj(), MBMesquite::arrptr(), ASSERT_NO_ERROR, conn, corners, CPPUNIT_ASSERT, dim, MBMesquite::DomainClassifier::domain_DoF(), MBMesquite::MeshImpl::elements_get_attached_vertices(), MBMesquite::MeshImpl::elements_get_topologies(), fixed, MBMesquite::MeshImpl::get_all_elements(), MBMesquite::MeshImpl::get_all_vertices(), MBMesquite::SlaveBoundaryVertices::loop_over_mesh(), make_mesh(), mesh, MBMesquite::MsqVertex::MSQ_DEPENDENT, MBMesquite::Settings::set_slaved_ho_node_mode(), settings, MBMesquite::Settings::SLAVE_CALCULATED, MBMesquite::MeshImpl::vertices_get_attached_elements(), MBMesquite::MeshImpl::vertices_get_byte(), and MBMesquite::MeshImpl::vertices_get_fixed_flag().
    MeshImpl mesh;
    DomainClassifier domain;
    make_mesh( mesh, domain, 2 * depth + 2 );
    std::vector< std::vector< Mesh::VertexHandle > > depths( depth + 1 );
    std::set< Mesh::VertexHandle > non_slave;
    std::set< Mesh::VertexHandle >::iterator p;
    // find boundary vertices
    std::vector< Mesh::VertexHandle > verts;
    mesh.get_all_vertices( verts, err );
    CPPUNIT_ASSERT( !verts.empty() );
    if( boundary >= 4 )
        std::vector< bool > flags;
        mesh.vertices_get_fixed_flag( arrptr( verts ), flags, verts.size(), err );
        for( size_t i = 0; i < verts.size(); ++i )
            if( flags[i] )
                depths[0].push_back( verts[i] );
                non_slave.insert( verts[i] );
    else
        std::vector< unsigned short > dim( verts.size() );
        domain.domain_DoF( arrptr( verts ), arrptr( dim ), verts.size(), err );
            if( dim[i] <= boundary )
    // check that our input is usable for this test
    // find all vertices up to specified depth
    for( unsigned d = 0; d < depth; ++d )
        for( size_t i = 0; i < depths[d].size(); ++i )
            std::vector< Mesh::ElementHandle > adj;
            std::vector< size_t > junk;
            mesh.vertices_get_attached_elements( &depths[d][i], 1, adj, junk, err );
            for( size_t j = 0; j < adj.size(); ++j )
                junk.clear();
                std::vector< Mesh::VertexHandle > conn;
                mesh.elements_get_attached_vertices( &adj[j], 1, conn, junk, err );
                for( size_t k = 0; k < conn.size(); ++k )
                    p = non_slave.find( conn[k] );
                    if( p == non_slave.end() )
                        non_slave.insert( p, conn[k] );
                        depths[d + 1].push_back( conn[k] );
    // Check that our input is usable for this test:
    // Should have some vertices that are not within the specified depth of
    // the boundary.
    CPPUNIT_ASSERT( non_slave.size() < verts.size() );
    // Now build a map of all higher-order nodes in the mesh
    std::set< Mesh::VertexHandle > higher_order;
    std::vector< Mesh::ElementHandle > elems;
    mesh.get_all_elements( elems, err );
    CPPUNIT_ASSERT( !elems.empty() );
    std::vector< EntityTopology > types( elems.size() );
    mesh.elements_get_topologies( arrptr( elems ), arrptr( types ), elems.size(), err );
    for( size_t i = 0; i < elems.size(); ++i )
        mesh.elements_get_attached_vertices( &elems[i], 1, conn, junk, err );
        for( size_t j = TopologyInfo::corners( types[i] ); j < conn.size(); ++j )
            higher_order.insert( conn[j] );
    // Should have some higher-order vertices
    CPPUNIT_ASSERT( !higher_order.empty() );
    // Now build a map of all fixed vertices
    std::set< Mesh::VertexHandle > fixed_vertices;
    std::vector< bool > fixed;
    mesh.vertices_get_fixed_flag( arrptr( verts ), fixed, verts.size(), err );
        if( fixed[i] ) fixed_vertices.insert( verts[i] );
    // Now actually run the tool
    Settings settings;
    settings.set_slaved_ho_node_mode( Settings::SLAVE_CALCULATED );
    SlaveBoundaryVertices tool( depth, boundary );
    MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &domain );
    tool.loop_over_mesh( &mesh_and_domain, &settings, err );
    // Now verify the results
    std::vector< unsigned char > bytes( verts.size() );
    mesh.vertices_get_byte( arrptr( verts ), arrptr( bytes ), verts.size(), err );
        bool in_non_slave    = ( non_slave.find( verts[i] ) != non_slave.end() );
        bool in_fixed        = ( fixed_vertices.find( verts[i] ) != fixed_vertices.end() );
        bool in_higher_order = ( higher_order.find( verts[i] ) != higher_order.end() );
        if( bytes[i] & MsqVertex::MSQ_DEPENDENT )
        {  // if slave node
            // must not be within 'depth' of boundary
            CPPUNIT_ASSERT( !in_non_slave );
            // must be a higher-order vertex
            CPPUNIT_ASSERT( in_higher_order );
            // must not be fixed
            CPPUNIT_ASSERT( !in_fixed );
        else
            // there are three reasons that a vertex isn't slaved
            CPPUNIT_ASSERT( in_fixed || !in_higher_order || in_non_slave );
List of all members.
