SphericalGeometryTest Class Reference
+ Inheritance diagram for SphericalGeometryTest:
+ Collaboration diagram for SphericalGeometryTest:
Public Member Functions
void setUp ()
void tearDown ()
 SphericalGeometryTest ()
void test_cg_mesh_cond_sphere ()
void test_smart_lapl_sphere ()
void test_lapl_geo_sphere ()
Private Member Functions
 CPPUNIT_TEST_SUITE (SphericalGeometryTest)
 CPPUNIT_TEST (test_cg_mesh_cond_sphere)
 CPPUNIT_TEST (test_smart_lapl_sphere)
 CPPUNIT_TEST (test_lapl_geo_sphere)
 CPPUNIT_TEST_SUITE_END ()
Private Attributes
double qualTol
int pF
Detailed Description
Definition at line 85 of file SphericalGeometryTest.cpp.
Definition at line 113 of file SphericalGeometryTest.cpp.
Member Function Documentation
void SphericalGeometryTest::setUp ( ) [inline]
Definition at line 102 of file SphericalGeometryTest.cpp.
References MBMesquite::MSQ_MIN.
        // pF=1;//PRINT_FLAG IS ON
        pF = 0;  // PRINT_FLAG IS OFF
                 // tolerance double
        qualTol = MSQ_MIN;
Definition at line 110 of file SphericalGeometryTest.cpp.
Definition at line 115 of file SphericalGeometryTest.cpp.
References MBMesquite::TerminationCriterion::add_iteration_limit(), center(), CPPUNIT_ASSERT, MBMesquite::QualityAssessor::loop_over_mesh(), mesh, MBMesquite::MeshImpl::read_vtk(), MBMesquite::IQInterface::run_instructions(), MBMesquite::ConjugateGradient::set_debugging_level(), MBMesquite::QualityImprover::set_inner_termination_criterion(), MBMesquite::InstructionQueue::set_master_quality_improver(), and MBMesquite::PatchSetUser::use_global_patch().
        MBMesquite::MeshImpl mesh;
        MBMesquite::MsqPrintError err( cout );
        mesh.read_vtk( MESH_FILES_DIR "2D/vtk/quads/untangled/quads_on_sphere_529.vtk", err );
        CPPUNIT_ASSERT( !err );
        // create geometry: sphere, center (2,2,0), radius 3
        Vector3D center( 2, 2, 0 );
        SphericalDomain msq_geom( center, 3.0 );
        // creates an intruction queue
        InstructionQueue queue1;
        // creates a mean ratio quality metric ...
        ConditionNumberQualityMetric shape;
        UntangleBetaQualityMetric untan;
        // ... and builds an objective function with it
        LPtoPTemplate obj_func( &shape, 2, err );
        // Make sure no errors
        // creates the steepest descent optimization procedures
        ConjugateGradient pass1( &obj_func, err );
        // SteepestDescent* pass2 = new SteepestDescent( obj_func );
        pass1.use_global_patch();
        QualityAssessor qa = QualityAssessor( &shape );
        //**********Set stopping criterion  5 iterates ****************
        // StoppingCriterion sc5(StoppingCriterion::NUMBER_OF_PASSES,5);
        // pass1->set_stopping_criterion(&sc5);
        TerminationCriterion sc5;
        sc5.add_iteration_limit( 5 );
        pass1.set_inner_termination_criterion( &sc5 );
        // CG's debugging print, increase integer to get more print info
        pass1.set_debugging_level( 0 );
        //  queue1.add_preconditioner(pass2, err); CPPUNIT_ASSERT(!err);
        queue1.set_master_quality_improver( &pass1, err );
        // launches optimization on mesh_set1
        MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &msq_geom );
        double orig_qa_val              = qa.loop_over_mesh( &mesh_and_domain, 0, err );
        queue1.run_instructions( &mesh_and_domain, err );
        double fin_qa_val = qa.loop_over_mesh( &mesh_and_domain, 0, err );
        // make sure 'quality' improved
        CPPUNIT_ASSERT( fin_qa_val <= orig_qa_val );
Definition at line 225 of file SphericalGeometryTest.cpp.
References MBMesquite::TerminationCriterion::add_iteration_limit(), center(), CPPUNIT_ASSERT, MBMesquite::QualityAssessor::loop_over_mesh(), mesh, MBMesquite::MeshImpl::read_vtk(), MBMesquite::IQInterface::run_instructions(), MBMesquite::InstructionQueue::set_master_quality_improver(), and MBMesquite::QualityImprover::set_outer_termination_criterion().
        mesh.read_vtk( MESH_FILES_DIR "2D/vtk/tris/untangled/Mesquite_geo_10242.vtk", err );
        // create geometry sphere:  ratius 1, centered at (0,0,0)
        Vector3D center( 0, 0, 0 );
        MBMesquite::SphericalDomain msq_geom( center, 1.0 );
        // creates an edge length metric ...
        EdgeLengthQualityMetric edg_len;
        // create the laplacian smoother
        LaplacianSmoother lapl;
        // create a quality assessor
        QualityAssessor qa = QualityAssessor( &edg_len );
        //*******Set stopping criterion 10 iterates  ***********
        // StoppingCriterion sc10(StoppingCriterion::NUMBER_OF_PASSES,10);
        // lapl->set_stopping_criterion(&sc10);
        TerminationCriterion sc10;
        sc10.add_iteration_limit( 10 );
        lapl.set_outer_termination_criterion( &sc10 );
        // qa, qi, qa
        queue1.set_master_quality_improver( &lapl, err );
Definition at line 174 of file SphericalGeometryTest.cpp.
        IdealWeightInverseMeanRatio shape_metric( err );
        LInfTemplate shape_func( &shape_metric );
        // create the smart laplacian smoother
        SmartLaplacianSmoother s_lapl( &shape_func );
        //*******Set stopping criterion 5 iterates  ***********
        s_lapl.set_outer_termination_criterion( &sc5 );
        // qa, qi, qa
        queue1.set_master_quality_improver( &s_lapl, err );
        QualityAssessor qa              = QualityAssessor( &shape_metric );
        double orig_val                 = qa.loop_over_mesh( &mesh_and_domain, 0, err );
        double final_val = qa.loop_over_mesh( &mesh_and_domain, 0, err );
        CPPUNIT_ASSERT( final_val < orig_val );
Member Data Documentation
Definition at line 100 of file SphericalGeometryTest.cpp.
Definition at line 99 of file SphericalGeometryTest.cpp.
List of all members.
