moab::AdaptiveKDTree Class Reference
Adaptive KD tree, for sorting and searching entities spatially. More...
#include <AdaptiveKDTree.hpp>
+ Inheritance diagram for moab::AdaptiveKDTree:
+ Collaboration diagram for moab::AdaptiveKDTree:
Classes
struct  Plane
 Split plane. More...
Public Types
enum  Axis { X = 0, Y = 1, Z = 2 }
 Enumeriate split plane directions. More...
enum  CandidatePlaneSet { SUBDIVISION = 0, SUBDIVISION_SNAP, VERTEX_MEDIAN, VERTEX_SAMPLE }
 methods for selecting candidate split planes More...
Public Member Functions
 AdaptiveKDTree (Interface *iface)
 AdaptiveKDTree (Interface *iface, const Range &entities, EntityHandle *tree_root_set=NULL, FileOptions *opts=NULL)
 Constructor (build the tree on construction) Construct a tree object, and build the tree with entities input. See comments for build_tree() for detailed description of arguments.
 ~AdaptiveKDTree ()
ErrorCode parse_options (FileOptions &options)
 Parse options for tree creation.
virtual ErrorCode build_tree (const Range &entities, EntityHandle *tree_root_set=NULL, FileOptions *options=NULL)
virtual ErrorCode reset_tree ()
 Reset the tree, optionally checking we have the right root.
virtual ErrorCode point_search (const double *point, EntityHandle &leaf_out, const double iter_tol=1.0e-10, const double inside_tol=1.0e-6, bool *multiple_leaves=NULL, EntityHandle *start_node=NULL, CartVect *params=NULL)
 Get leaf containing input position.
ErrorCode point_search (const double *point, AdaptiveKDTreeIter &leaf_it, const double iter_tol=1.0e-10, const double inside_tol=1.0e-6, bool *multiple_leaves=NULL, EntityHandle *start_node=NULL)
virtual ErrorCode distance_search (const double *point, const double distance, std::vector< EntityHandle > &leaves_out, const double iter_tol=1.0e-10, const double inside_tol=1.0e-6, std::vector< double > *dists_out=NULL, std::vector< CartVect > *params_out=NULL, EntityHandle *start_node=NULL)
 Find all leaves within a given distance from point If dists_out input non-NULL, also returns distances from each leaf; if point i is inside leaf, 0 is given as dists_out[i]. If params_out is non-NULL and myEval is non-NULL, will evaluate individual entities in tree nodes and return containing entities in leaves_out. In those cases, if params_out is also non-NULL, will return parameters in those elements in that vector.
ErrorCode get_info (EntityHandle root, double min[3], double max[3], unsigned int &dep)
 Return some basic information about the tree Stats are returned for tree starting from input node or tree root (root = 0)
ErrorCode get_split_plane (EntityHandle node, Plane &plane)
 Get split plane for tree node.
ErrorCode set_split_plane (EntityHandle node, const Plane &plane)
 Set split plane for tree node.
ErrorCode get_tree_iterator (EntityHandle tree_root, AdaptiveKDTreeIter &result)
 Get iterator for tree.
ErrorCode get_last_iterator (EntityHandle tree_root, AdaptiveKDTreeIter &result)
 Get iterator at right-most ('last') leaf.
ErrorCode get_sub_tree_iterator (EntityHandle tree_root, const double box_min[3], const double box_max[3], AdaptiveKDTreeIter &result)
 Get iterator for tree or subtree.
ErrorCode split_leaf (AdaptiveKDTreeIter &leaf, Plane plane)
ErrorCode split_leaf (AdaptiveKDTreeIter &leaf, Plane plane, EntityHandle &left_child, EntityHandle &right_child)
ErrorCode split_leaf (AdaptiveKDTreeIter &leaf, Plane plane, const Range &left_entities, const Range &right_entities)
ErrorCode split_leaf (AdaptiveKDTreeIter &leaf, Plane plane, const std::vector< EntityHandle > &left_entities, const std::vector< EntityHandle > &right_entities)
ErrorCode merge_leaf (AdaptiveKDTreeIter &iter)
ErrorCode closest_triangle (EntityHandle tree_root, const double from_coords[3], double closest_point_out[3], EntityHandle &triangle_out)
ErrorCode sphere_intersect_triangles (EntityHandle tree_root, const double center[3], double radius, std::vector< EntityHandle > &triangles)
ErrorCode ray_intersect_triangles (EntityHandle tree_root, const double tolerance, const double ray_unit_dir[3], const double ray_base_pt[3], std::vector< EntityHandle > &triangles_out, std::vector< double > &distance_out, int result_count_limit=0, double distance_limit=-1.0)
ErrorCode compute_depth (EntityHandle root, unsigned int &min_depth, unsigned int &max_depth)
virtual ErrorCode print ()
 print various things about this tree
Private Member Functions
ErrorCode init ()
ErrorCode find_close_triangle (EntityHandle root, const double from_point[3], double pt[3], EntityHandle &triangle)
 find a triangle near the input point
ErrorCode make_tag (Interface *iface, std::string name, TagType storage, DataType type, int count, void *default_val, Tag &tag_handle, std::vector< Tag > &created_tags)
ErrorCode intersect_children_with_elems (const Range &elems, AdaptiveKDTree::Plane plane, double eps, CartVect box_min, CartVect box_max, Range &left_tris, Range &right_tris, Range &both_tris, double &metric_value)
ErrorCode best_subdivision_snap_plane (int num_planes, const AdaptiveKDTreeIter &iter, Range &best_left, Range &best_right, Range &best_both, AdaptiveKDTree::Plane &best_plane, std::vector< double > &tmp_data, double eps)
ErrorCode best_subdivision_plane (int num_planes, const AdaptiveKDTreeIter &iter, Range &best_left, Range &best_right, Range &best_both, AdaptiveKDTree::Plane &best_plane, double eps)
ErrorCode best_vertex_median_plane (int num_planes, const AdaptiveKDTreeIter &iter, Range &best_left, Range &best_right, Range &best_both, AdaptiveKDTree::Plane &best_plane, std::vector< double > &coords, double eps)
ErrorCode best_vertex_sample_plane (int num_planes, const AdaptiveKDTreeIter &iter, Range &best_left, Range &best_right, Range &best_both, AdaptiveKDTree::Plane &best_plane, std::vector< double > &coords, std::vector< EntityHandle > &indices, double eps)
Private Attributes
Tag planeTag
Tag axisTag
unsigned splitsPerDir
CandidatePlaneSet planeSet
bool spherical
double radius
Static Private Attributes
static const char * treeName = "AKDTree"
Friends
class AdaptiveKDTreeIter
Detailed Description
Definition at line 23 of file AdaptiveKDTree.hpp.
Member Enumeration Documentation
Enumerator:
X
Y
Z
Definition at line 148 of file AdaptiveKDTree.hpp.
        X = 0,
        Y = 1,
        Z = 2
Enumerator:
SUBDIVISION
Candidiate planes at evenly spaced intervals.
SUBDIVISION_SNAP
Like SUBDIVISION, except snap to closest vertex coordinate.
VERTEX_MEDIAN
Median vertex coodinate values.
VERTEX_SAMPLE
Random sampling of vertex coordinate values.
Definition at line 248 of file AdaptiveKDTree.hpp.
        //! Candidiate planes at evenly spaced intervals
        SUBDIVISION = 0,
        //! Like SUBDIVISION, except snap to closest vertex coordinate
        SUBDIVISION_SNAP,  // = 1
                           //! Median vertex coodinate values
        VERTEX_MEDIAN,     // = 2
                           //! Random sampling of vertex coordinate values
        VERTEX_SAMPLE      // = 3
Definition at line 36 of file AdaptiveKDTree.cpp.
References moab::Tree::boxTagName, ErrorCode, init(), MB_SUCCESS, and treeName.
    : Tree( iface ), planeTag( 0 ), axisTag( 0 ), splitsPerDir( 3 ), planeSet( SUBDIVISION_SNAP ), spherical( false ),
      radius( 1.0 )
    boxTagName = treeName;
    ErrorCode rval = init();
    if( MB_SUCCESS != rval ) throw rval;
moab::AdaptiveKDTree::AdaptiveKDTree ( Interface iface,
const Range entities,
EntityHandle tree_root_set = NULL,
FileOptions opts = NULL
Parameters:
ifaceMOAB instance
entitiesEntities to build tree around
tree_rootRoot set for tree (see function description)
optsOptions for tree (see function description)
Definition at line 46 of file AdaptiveKDTree.cpp.
References moab::Tree::boxTagName, build_tree(), ErrorCode, init(), MB_SUCCESS, parse_options(), and treeName.
      radius( 1.0 )
    ErrorCode rval;
    if( opts )
        rval = parse_options( *opts );
    rval = init();
    rval = build_tree( entities, tree_root_set, opts );
Definition at line 69 of file AdaptiveKDTree.cpp.
References moab::Tree::cleanUp, moab::Tree::myRoot, and reset_tree().
    if( !cleanUp ) return;
    if( myRoot )
        reset_tree();
        myRoot = 0;
Member Function Documentation
ErrorCode moab::AdaptiveKDTree::best_subdivision_plane ( int  num_planes,
const AdaptiveKDTreeIter iter,
Range best_left,
Range best_right,
Range best_both,
AdaptiveKDTree::Plane best_plane,
double  eps
) [private]
Definition at line 942 of file AdaptiveKDTree.cpp.
References box_max(), moab::AdaptiveKDTreeIter::box_max(), box_min(), moab::AdaptiveKDTreeIter::box_min(), entities, ErrorCode, moab::Interface::get_entities_by_handle(), moab::AdaptiveKDTreeIter::handle(), intersect_children_with_elems(), MB_SUCCESS, moab::Tree::moab(), moab::Range::size(), moab::Range::swap(), and moab::AdaptiveKDTreeIter::tool().
Referenced by build_tree().
    double metric_val = std::numeric_limits< unsigned >::max();
    ErrorCode r;
    const CartVect box_min( iter.box_min() );
    const CartVect box_max( iter.box_max() );
    const CartVect diff( box_max - box_min );
    Range entities;
    r = iter.tool()->moab()->get_entities_by_handle( iter.handle(), entities );
    if( MB_SUCCESS != r ) return r;
    const size_t p_count = entities.size();
    for( int axis = 0; axis < 3; ++axis )
        int plane_count = num_planes;
        if( ( num_planes + 1 ) * eps >= diff[axis] ) plane_count = (int)( diff[axis] / eps ) - 1;
        for( int p = 1; p <= plane_count; ++p )
            AdaptiveKDTree::Plane plane = { box_min[axis] + ( p / ( 1.0 + plane_count ) ) * diff[axis], axis };
            Range left, right, both;
            double val;
            r = intersect_children_with_elems( entities, plane, eps, box_min, box_max, left, right, both, val );
            const size_t sdiff = p_count - both.size();
            if( left.size() == sdiff || right.size() == sdiff ) continue;
            if( val >= metric_val ) continue;
            metric_val = val;
            best_plane = plane;
            best_left.swap( left );
            best_right.swap( right );
            best_both.swap( both );
    return MB_SUCCESS;
ErrorCode moab::AdaptiveKDTree::best_subdivision_snap_plane ( int  num_planes,
Range best_left,
Range best_right,
Range best_both,
std::vector< double > &  tmp_data,
double  eps
) [private]
Definition at line 990 of file AdaptiveKDTree.cpp.
References box_max(), box_min(), entities, ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_coords(), moab::Interface::get_entities_by_handle(), moab::AdaptiveKDTreeIter::handle(), intersect_children_with_elems(), MB_SUCCESS, moab::Tree::moab(), moab::Range::size(), moab::Range::swap(), moab::AdaptiveKDTreeIter::tool(), and moab::Interface::UNION.
    ErrorCode r;
    // const CartVect tol(eps*diff);
    Range entities, vertices;
    r                    = iter.tool()->moab()->get_adjacencies( entities, 0, false, vertices, Interface::UNION );
    unsigned int nverts = vertices.size();
    tmp_data.resize( 3 * nverts );
    r = iter.tool()->moab()->get_coords( vertices, &tmp_data[0], &tmp_data[nverts], &tmp_data[2 * nverts] );
    // calculate bounding box of vertices
    // decide based on the actual box the splitting plane
    // do not decide based on iterator box.
    // it could be too big
    // BoundBox box;
    // r = box.update(*moab(), vertices);
    CartVect box_min;
    CartVect box_max;
    for( int dir = 0; dir < 3; dir++ )
        double amin = tmp_data[dir * nverts];
        double amax = amin;
        double* p   = &tmp_data[dir * nverts + 1];
        for( unsigned int i = 1; i < nverts; i++ )
            if( *p < amin ) amin = *p;
            if( *p > amax ) amax = *p;
            p++;
        box_min[dir] = amin;
        box_max[dir] = amax;
        // if num_planes results in width < eps, reset the plane count
            // coord of this plane on axis
            double coord = box_min[axis] + ( p / ( 1.0 + plane_count ) ) * diff[axis];
            // find closest vertex coordinate to this plane position
            unsigned int istrt   = axis * nverts;
            double closest_coord = tmp_data[istrt];
            for( unsigned i = 1; i < nverts; ++i )
                if( fabs( coord - tmp_data[istrt + i] ) < fabs( coord - closest_coord ) )
                    closest_coord = tmp_data[istrt + i];
            if( closest_coord - box_min[axis] <= eps || box_max[axis] - closest_coord <= eps ) continue;
            // seprate elems into left/right/both, and compute separating metric
            AdaptiveKDTree::Plane plane = { closest_coord, axis };
            double val;
            const size_t d = p_count - both.size();
            if( left.size() == d || right.size() == d ) continue;
            metric_val = val;
            best_plane = plane;
    return MB_SUCCESS;
ErrorCode moab::AdaptiveKDTree::best_vertex_median_plane ( int  num_planes,
Range best_left,
Range best_right,
Range best_both,
std::vector< double > &  coords,
double  eps
) [private]
Definition at line 1083 of file AdaptiveKDTree.cpp.
References box_max(), moab::AdaptiveKDTreeIter::box_max(), box_min(), moab::AdaptiveKDTreeIter::box_min(), entities, eps, ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_coords(), moab::Interface::get_entities_by_handle(), moab::AdaptiveKDTreeIter::handle(), intersect_children_with_elems(), MB_SUCCESS, moab::Tree::moab(), np, moab::Range::size(), moab::Range::swap(), moab::AdaptiveKDTreeIter::tool(), and moab::Interface::UNION.
    ErrorCode r;
    coords.resize( vertices.size() );
        if( box_max[axis] - box_min[axis] <= 2 * eps ) continue;
        double* ptrs[] = { 0, 0, 0 };
        ptrs[axis]     = &coords[0];
        r              = iter.tool()->moab()->get_coords( vertices, ptrs[0], ptrs[1], ptrs[2] );
        std::sort( coords.begin(), coords.end() );
        std::vector< double >::iterator citer;
        citer              = std::upper_bound( coords.begin(), coords.end(), box_min[axis] + eps );
        const size_t count = std::upper_bound( citer, coords.end(), box_max[axis] - eps ) - citer;
        size_t step;
        int np = num_planes;
        if( count < 2 * (size_t)num_planes )
            step = 1;
            np   = count - 1;
        else
            step = count / ( num_planes + 1 );
        for( int p = 1; p <= np; ++p )
            citer += step;
            AdaptiveKDTree::Plane plane = { *citer, axis };
            double val;
            const size_t diff = p_count - both.size();
            if( left.size() == diff || right.size() == diff ) continue;
            metric_val = val;
            best_plane = plane;
    return MB_SUCCESS;
ErrorCode moab::AdaptiveKDTree::best_vertex_sample_plane ( int  num_planes,
Range best_left,
Range best_right,
Range best_both,
std::vector< EntityHandle > &  indices,
double  eps
) [private]
Definition at line 1156 of file AdaptiveKDTree.cpp.
References box_max(), moab::AdaptiveKDTreeIter::box_max(), box_min(), moab::AdaptiveKDTreeIter::box_min(), entities, ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_coords(), moab::Interface::get_entities_by_handle(), moab::AdaptiveKDTreeIter::handle(), intersect_children_with_elems(), MB_SUCCESS, moab::Tree::moab(), moab::Range::size(), moab::Range::swap(), moab::AdaptiveKDTreeIter::tool(), and moab::Interface::UNION.
    const size_t random_elem_threshold = 20 * num_planes;
    ErrorCode r;
    // We are selecting random vertex coordinates to use for candidate split
    // planes.  So if element list is large, begin by selecting random elements.
    coords.resize( 3 * num_planes );
    if( p_count < random_elem_threshold )
    else
        indices.resize( random_elem_threshold );
        const int num_rand = p_count / RAND_MAX + 1;
        for( size_t j = 0; j < random_elem_threshold; ++j )
            size_t rnd = rand();
            for( int i = num_rand; i > 1; --i )
                rnd *= rand();
            rnd %= p_count;
            indices[j] = entities[rnd];
        r = iter.tool()->moab()->get_adjacencies( &indices[0], random_elem_threshold, 0, false, vertices,
                                                  Interface::UNION );
        size_t num_valid_coords = 0;
        for( size_t i = 0; i < coords.size(); ++i )
            if( coords[i] > box_min[axis] + eps && coords[i] < box_max[axis] - eps ) ++num_valid_coords;
        if( 2 * (size_t)num_planes > num_valid_coords )
            indices.clear();
                if( coords[i] > box_min[axis] + eps && coords[i] < box_max[axis] - eps ) indices.push_back( i );
        else
            indices.resize( num_planes );
            // make sure random indices are sufficient to cover entire range
            const int num_rand = coords.size() / RAND_MAX + 1;
            for( int j = 0; j < num_planes; ++j )
                size_t rnd;
                do
                    rnd = rand();
                        rnd *= rand();
                    rnd %= coords.size();
                } while( coords[rnd] <= box_min[axis] + eps || coords[rnd] >= box_max[axis] - eps );
                indices[j] = rnd;
        for( unsigned p = 0; p < indices.size(); ++p )
            AdaptiveKDTree::Plane plane = { coords[indices[p]], axis };
            double val;
            metric_val = val;
            best_plane = plane;
    return MB_SUCCESS;
ErrorCode moab::AdaptiveKDTree::build_tree ( const Range entities,
FileOptions options = NULL
) [virtual]
Build the tree Build a tree with the entities input. If a non-NULL tree_root_set pointer is input, use the pointed-to set as the root of this tree (*tree_root_set!=0) otherwise construct a new root set and pass its handle back in *tree_root_set. Options vary by tree type; see Tree.hpp for common options; options specific to AdaptiveKDTree: SPLITS_PER_DIR: number of candidate splits considered per direction; default = 3 PLANE_SET: method used to decide split planes; see CandidatePlaneSet enum (below) for possible values; default = 1 (SUBDIVISION_SNAP)
Parameters:
entitiesEntities with which to build the tree
Returns:
Error is returned only on build failure
Implements moab::Tree.
Definition at line 80 of file AdaptiveKDTree.cpp.
References moab::Interface::add_entities(), moab::FileOptions::all_seen(), moab::CartVect::array(), best_subdivision_plane(), best_subdivision_snap_plane(), best_vertex_median_plane(), best_vertex_sample_plane(), moab::BoundBox::bMax, moab::BoundBox::bMin, box(), moab::TreeStats::compute_stats(), moab::Tree::create_root(), moab::AdaptiveKDTreeIter::depth(), ErrorCode, moab::Interface::get_number_entities_by_handle(), moab::AdaptiveKDTreeIter::handle(), moab::AdaptiveKDTreeIter::initialize(), moab::TreeStats::initTime, moab::AdaptiveKDTreeIter::LEFT, moab::Tree::maxDepth, moab::Tree::maxPerLeaf, MB_ENTITY_NOT_FOUND, MB_SUCCESS, moab::Tree::mbImpl, moab::Range::merge(), moab::Tree::minWidth, moab::Tree::moab(), moab::Tree::myRoot, moab::AdaptiveKDTree::Plane::norm, parse_options(), planeSet, radius, moab::TreeStats::reset(), reset_tree(), spherical, split_leaf(), splitsPerDir, moab::AdaptiveKDTreeIter::step(), SUBDIVISION, SUBDIVISION_SNAP, moab::CpuTimer::time_elapsed(), moab::Tree::treeStats, moab::BoundBox::update(), VERTEX_MEDIAN, and VERTEX_SAMPLE.
Referenced by AdaptiveKDTree(), moab::TempestRemapper::ConstructCoveringSet(), do_kdtree_test(), moab::Intx2Mesh::intersect_meshes(), moab::Intx2Mesh::intersect_meshes_kdtree(), main(), moab::MergeMesh::merge_all(), merge_duplicate_vertices(), moab::MergeMesh::merge_entities(), test_build_tree_bisect_triangles(), test_closest_triangle(), test_ray_intersect_triangles(), test_sphere_intersect_triangles(), and moab::ReadNCDF::update().
    ErrorCode rval;
    CpuTimer cp;
    if( options )
        rval = parse_options( *options );
        if( MB_SUCCESS != rval ) return rval;
        if( !options->all_seen() ) return MB_FAILURE;
    // calculate bounding box of elements
    BoundBox box;
    rval = box.update( *moab(), entities, spherical, radius );
    // create tree root
    EntityHandle tmp_root;
    if( !tree_root_set ) tree_root_set = &tmp_root;
    rval = create_root( box.bMin.array(), box.bMax.array(), *tree_root_set );
    rval = moab()->add_entities( *tree_root_set, entities );
    AdaptiveKDTreeIter iter;
    iter.initialize( this, *tree_root_set, box.bMin.array(), box.bMax.array(), AdaptiveKDTreeIter::LEFT );
    std::vector< double > tmp_data;
    std::vector< EntityHandle > tmp_data2;
    for( ;; )
        int pcount;
        rval = moab()->get_number_entities_by_handle( iter.handle(), pcount );
        if( MB_SUCCESS != rval ) break;
        const size_t p_count = pcount;
        Range best_left, best_right, best_both;
        Plane best_plane = { HUGE_VAL, -1 };
        if( (int)p_count > maxPerLeaf && (int)iter.depth() < maxDepth )
            switch( planeSet )
                case AdaptiveKDTree::SUBDIVISION:
                    rval = best_subdivision_plane( splitsPerDir, iter, best_left, best_right, best_both, best_plane,
                                                   minWidth );
                    break;
                case AdaptiveKDTree::SUBDIVISION_SNAP:
                    rval = best_subdivision_snap_plane( splitsPerDir, iter, best_left, best_right, best_both,
                                                        best_plane, tmp_data, minWidth );
                    break;
                case AdaptiveKDTree::VERTEX_MEDIAN:
                    rval = best_vertex_median_plane( splitsPerDir, iter, best_left, best_right, best_both, best_plane,
                    break;
                case AdaptiveKDTree::VERTEX_SAMPLE:
                    rval = best_vertex_sample_plane( splitsPerDir, iter, best_left, best_right, best_both, best_plane,
                                                     tmp_data, tmp_data2, minWidth );
                    break;
                default:
                    rval = MB_FAILURE;
        if( best_plane.norm >= 0 )
            best_left.merge( best_both );
            best_right.merge( best_both );
            rval = split_leaf( iter, best_plane, best_left, best_right );
        else
            rval = iter.step();
            if( MB_ENTITY_NOT_FOUND == rval )
                rval               = treeStats.compute_stats( mbImpl, myRoot );
                treeStats.initTime = cp.time_elapsed();
                return rval;  // at end
            else if( MB_SUCCESS != rval )
                break;
    reset_tree();
    treeStats.reset();
    return rval;
ErrorCode moab::AdaptiveKDTree::closest_triangle ( EntityHandle  tree_root,
EntityHandle triangle_out
Find triangle closest to input position.
Parameters:
from_coordsThe input position to test against
closest_point_outThe closest point on the set of triangles in the tree
triangle_outThe triangle closest to the input position
Find the triangles in a set that are closer to the input position than any triangles in the 'closest_tris' list.
closest_tris is assumed to contain a list of triangles for which the first is the closest known triangle to the input position and the first entry in 'closest_pts' is the closest location on that triangle. Any other values in the lists must be other triangles for which the closest point is within the input tolerance of the closest closest point. This function will update the lists as appropriate if any closer triangles or triangles within the tolerance of the current closest location are found. The first entry is maintained as the closest of the list of triangles.
Definition at line 1763 of file AdaptiveKDTree.cpp.
References moab::CartVect::array(), moab::closest_to_triangles(), distance_search(), ErrorCode, find_close_triangle(), moab::CartVect::get(), MB_SUCCESS, and moab::Tree::moab().
Referenced by main(), and test_closest_triangle().
    ErrorCode rval;
    double shortest_dist_sqr = HUGE_VAL;
    std::vector< EntityHandle > leaves;
    const CartVect from( from_coords );
    CartVect closest_pt;
    // Find the leaf containing the input point
    // This search does not take into account any bounding box for the
    // tree, so it always returns one leaf.
    assert( tree_root );
    rval = find_close_triangle( tree_root, from_coords, closest_pt.array(), triangle_out );
    // Find any other leaves for which the bounding box is within
    // the same distance from the input point as the current closest
    // point is.
    CartVect diff = closest_pt - from;
    rval = distance_search( from_coords, sqrt( diff % diff ), leaves, 1.0e-10, 1.0e-6, NULL, NULL, &tree_root );
    // Check any close leaves to see if they contain triangles that
    // are as close to or closer than the current closest triangle(s).
    for( unsigned i = 0; i < leaves.size(); ++i )
        rval = closest_to_triangles( moab(), leaves[i], from, shortest_dist_sqr, closest_pt, triangle_out );
    // pass back resulting position
    closest_pt.get( closest_point_out );
    return MB_SUCCESS;
ErrorCode moab::AdaptiveKDTree::compute_depth ( EntityHandle  root,
unsigned int &  min_depth,
unsigned int &  max_depth
Definition at line 2031 of file AdaptiveKDTree.cpp.
References moab::AdaptiveKDTreeIter::depth(), moab::Interface::get_number_entities_by_handle(), get_tree_iterator(), moab::AdaptiveKDTreeIter::handle(), moab::AdaptiveKDTreeIter::LEFT, max_depth, MB_SUCCESS, moab::Tree::moab(), moab::AdaptiveKDTreeIter::step(), and moab::AdaptiveKDTreeIter::step_to_first_leaf().
Referenced by get_info().
    get_tree_iterator( root, iter );
    iter.step_to_first_leaf( AdaptiveKDTreeIter::LEFT );
    min_depth = max_depth = iter.depth();
    int num_of_elements = 0, max, min;
    moab()->get_number_entities_by_handle( iter.handle(), num_of_elements );
    max = min = num_of_elements;
    int k     = 0;
    while( MB_SUCCESS == iter.step() )
        int temp = 0;
        moab()->get_number_entities_by_handle( iter.handle(), temp );
        max = std::max( max, temp );
        min = std::min( min, temp );
        if( iter.depth() > max_depth )
        else if( iter.depth() < min_depth )
            min_depth = iter.depth();
        ++k;
    return MB_SUCCESS;
ErrorCode moab::AdaptiveKDTree::distance_search ( const double *  point,
std::vector< EntityHandle > &  leaves_out,
const double  iter_tol = 1.0e-10,
const double  inside_tol = 1.0e-6,
std::vector< double > *  dists_out = NULL,
std::vector< CartVect > *  params_out = NULL,
EntityHandle start_node = NULL
) [virtual]
Parameters:
pointPoint to be located in tree
distanceDistance within which to query
leaves_outLeaves within distance or containing point
iter_tolTolerance for convergence of point search
inside_tolTolerance for inside element calculation
dists_outIf non-NULL, will contain distsances to leaves
params_outIf non-NULL, will contain parameters of the point in the ents in leaves_out
start_nodeStart from this tree node (non-NULL) instead of tree root (NULL)
when we pop it from the list.)
Definition at line 1388 of file AdaptiveKDTree.cpp.
References moab::CartVect::array(), moab::BoundBox::bMax, moab::BoundBox::bMin, box(), children, moab::BoundBox::contains_point(), moab::AdaptiveKDTree::Plane::coord, moab::NodeDistance::dist, ErrorCode, moab::ElemEvaluator::find_containing_entity(), moab::Tree::get_bounding_box(), moab::Interface::get_child_meshsets(), get_split_plane(), moab::NodeDistance::handle, moab::TreeStats::leavesVisited, moab::Tree::maxDepth, MB_SUCCESS, moab::Tree::moab(), moab::Tree::myEval, moab::Tree::myRoot, moab::TreeStats::nodesVisited, moab::AdaptiveKDTree::Plane::norm, moab::TreeStats::numTraversals, moab::TreeStats::traversalLeafObjectTests, and moab::Tree::treeStats.
Referenced by closest_triangle(), moab::MergeMesh::find_merged_to(), moab::Intx2Mesh::intersect_meshes(), moab::Intx2Mesh::intersect_meshes_kdtree(), merge_duplicate_vertices(), moab::Coupler::nat_param(), sphere_intersect_triangles(), and moab::ReadNCDF::update().
    treeStats.numTraversals++;
    const double dist_sqr = distance * distance;
    const CartVect from( from_point );
    std::vector< NodeDistance > list,
        result_list_nodes;  // list of subtrees to traverse, and results
                            // pre-allocate space for default max tree depth
    list.reserve( maxDepth );
    // misc temporary values
    Plane plane;
    NodeDistance node;
    ErrorCode rval;
    std::vector< EntityHandle > children;
    // Get distance from input position to bounding box of tree
    // (zero if inside box)
    BoundBox box;
    rval = get_bounding_box( box );
    if( MB_SUCCESS == rval && !box.contains_point( from_point, iter_tol ) )
        treeStats.nodesVisited++;
        return MB_SUCCESS;
    // if bounding box is not available (e.g. not starting from true root)
    // just start with zero.  Less efficient, but will work.
    node.dist = CartVect( 0.0 );
    if( MB_SUCCESS == rval )
        for( int i = 0; i < 3; ++i )
            if( from_point[i] < box.bMin[i] )
                node.dist[i] = box.bMin[i] - from_point[i];
            else if( from_point[i] > box.bMax[i] )
                node.dist[i] = from_point[i] - box.bMax[i];
        if( node.dist % node.dist > dist_sqr )
            return MB_SUCCESS;
    // begin with root in list
    node.handle = ( tree_root ? *tree_root : myRoot );
    list.push_back( node );
    while( !list.empty() )
        node = list.back();
        list.pop_back();
        // If leaf node, test contained triangles
        children.clear();
        rval = moab()->get_child_meshsets( node.handle, children );
        if( children.empty() )
            treeStats.leavesVisited++;
            if( myEval && result_params )
                EntityHandle ent;
                CartVect params;
                rval = myEval->find_containing_entity( node.handle, from_point, iter_tol, inside_tol, ent,
                                                       params.array(), &treeStats.traversalLeafObjectTests );
                    return rval;
                else if( ent )
                    result_list.push_back( ent );
                    result_params->push_back( params );
                    if( result_dists ) result_dists->push_back( 0.0 );
            else
                result_list_nodes.push_back( node );
                continue;
        // If not leaf node, add children to working list
        rval = get_split_plane( node.handle, plane );
        const double d = from[plane.norm] - plane.coord;
        // right of plane?
        if( d > 0 )
            node.handle = children[1];
            // if the split plane is close to the input point, add
            // the left child also (we'll check the exact distance
            /// when we pop it from the list.)
            if( d <= distance )
                node.dist[plane.norm] = d;
                if( node.dist % node.dist <= dist_sqr )
                    node.handle = children[0];
        // left of plane
        else
            // the right child also (we'll check the exact distance
            if( -d <= distance )
                node.dist[plane.norm] = -d;
    if( myEval && result_params ) return MB_SUCCESS;
    // separate loops to avoid if test inside loop
    result_list.reserve( result_list_nodes.size() );
    for( std::vector< NodeDistance >::iterator vit = result_list_nodes.begin(); vit != result_list_nodes.end(); ++vit )
        result_list.push_back( ( *vit ).handle );
    if( result_dists && distance > 0.0 )
        result_dists->reserve( result_list_nodes.size() );
             ++vit )
            result_dists->push_back( ( *vit ).dist.length() );
    return MB_SUCCESS;
ErrorCode moab::AdaptiveKDTree::find_close_triangle ( EntityHandle  root,
double  pt[3],
) [private]
Definition at line 1593 of file AdaptiveKDTree.cpp.
References children, moab::Range::clear(), moab::closest_to_triangles(), moab::Range::empty(), ErrorCode, moab::CartVect::get(), moab::Interface::get_child_meshsets(), moab::Interface::get_entities_by_type(), get_split_plane(), MB_ENTITY_NOT_FOUND, MB_SUCCESS, MBTRI, moab::Tree::moab(), moab::AdaptiveKDTree::Plane::right_side(), and split.
Referenced by closest_triangle().
    ErrorCode rval;
    Range tris;
    Plane split;
    std::vector< EntityHandle > stack;
    std::vector< EntityHandle > children( 2 );
    stack.reserve( 30 );
    assert( root );
    stack.push_back( root );
    while( !stack.empty() )
        EntityHandle node = stack.back();
        stack.pop_back();
        for( ;; )
        {  // loop until we find a leaf
            children.clear();
            rval = moab()->get_child_meshsets( node, children );
            // loop termination criterion
            if( children.empty() ) break;
            // if not a leaf, get split plane
            rval = get_split_plane( node, split );
            // continue down the side that contains the point,
            // and push the other side onto the stack in case
            // we need to check it later.
            int rs = split.right_side( from );
            node   = children[rs];
            stack.push_back( children[1 - rs] );
        // We should now be at a leaf.
        // If it has some triangles, we're done.
        // If not, continue searching for another leaf.
        tris.clear();
        rval = moab()->get_entities_by_type( node, MBTRI, tris );
        if( !tris.empty() )
            double dist_sqr = HUGE_VAL;
            CartVect point( pt );
            rval = closest_to_triangles( moab(), tris, CartVect( from ), dist_sqr, point, triangle );
            point.get( pt );
            return rval;
    // If we got here, then we traversed the entire tree
    // and all the leaves were empty.
    return MB_ENTITY_NOT_FOUND;
ErrorCode moab::AdaptiveKDTree::get_info ( EntityHandle  root,
double  min[3],
double  max[3],
) [virtual]
Parameters:
rootIf non-0, give stats below and including root
minMinimum corner of bounding box
maxMaximum corner of bounding box
max_depMaximum depth of tree below root
Reimplemented from moab::Tree.
Definition at line 2057 of file AdaptiveKDTree.cpp.
References moab::BoundBox::bMax, moab::BoundBox::bMin, box(), compute_depth(), ErrorCode, moab::CartVect::get(), moab::Tree::get_bounding_box(), and MB_SUCCESS.
Referenced by do_kdtree_test(), and moab::Coupler::initialize_tree().
    BoundBox box;
    ErrorCode result = get_bounding_box( box, &root );
    if( MB_SUCCESS != result ) return result;
    box.bMin.get( bmin );
    box.bMax.get( bmax );
    unsigned min_depth;
    return compute_depth( root, min_depth, dep );
Definition at line 327 of file AdaptiveKDTree.cpp.
References box(), moab::Tree::boxTag, ErrorCode, moab::AdaptiveKDTreeIter::initialize(), MB_SUCCESS, moab::Tree::moab(), moab::AdaptiveKDTreeIter::RIGHT, and moab::Interface::tag_get_data().
Referenced by test_point_search().
    double box[6];
    ErrorCode rval = moab()->tag_get_data( boxTag, &root, 1, box );
    return iter.initialize( this, root, box, box + 3, AdaptiveKDTreeIter::RIGHT );
Definition at line 285 of file AdaptiveKDTree.cpp.
References axisTag, moab::AdaptiveKDTree::Plane::coord, ErrorCode, MB_SUCCESS, moab::Tree::moab(), moab::AdaptiveKDTree::Plane::norm, planeTag, and moab::Interface::tag_get_data().
Referenced by distance_search(), find_close_triangle(), merge_leaf(), point_search(), and ray_intersect_triangles().
#ifndef MB_AD_KD_TREE_USE_SINGLE_TAG
    ErrorCode r1, r2;
    r1 = moab()->tag_get_data( planeTag, &entity, 1, &plane.coord );
    r2 = moab()->tag_get_data( axisTag, &entity, 1, &plane.norm );
    return MB_SUCCESS == r1 ? r2 : r1;
#elif defined( MB_AD_KD_TREE_USE_TWO_DOUBLE_TAG )
    double values[2];
    ErrorCode rval = moab()->tag_get_data( planeTag, &entity, 1, values );
    plane.coord    = values[0];
    plane.norm     = (int)values[1];
    return rval;
#else
    return moab()->tag_get_data( planeTag, &entity, 1, &plane );
#endif
ErrorCode moab::AdaptiveKDTree::get_sub_tree_iterator ( EntityHandle  tree_root,
AdaptiveKDTreeIter result
Definition at line 336 of file AdaptiveKDTree.cpp.
References moab::AdaptiveKDTreeIter::initialize(), and moab::AdaptiveKDTreeIter::LEFT.
Referenced by get_tree_iterator().
    return result.initialize( this, root, min, max, AdaptiveKDTreeIter::LEFT );
Definition at line 240 of file AdaptiveKDTree.cpp.
References axisTag, moab::Tree::boxTagName, moab::AdaptiveKDTree::Plane::coord, ErrorCode, make_tag(), MB_SUCCESS, MB_TAG_DENSE, MB_TAG_MESH, MB_TYPE_DOUBLE, MB_TYPE_OPAQUE, moab::Tree::mbImpl, moab::Tree::moab(), planeTag, moab::Interface::tag_set_data(), tagname, and treeName.
Referenced by AdaptiveKDTree().
    std::vector< Tag > ctl;
    // create two tags, one for axis direction and one for axis coordinate
    std::string n1( treeName ), n2( treeName );
    n1 += "_coord";
    n2 += "_norm";
    ErrorCode rval = make_tag( moab(), n1, MB_TAG_DENSE, MB_TYPE_DOUBLE, 1, 0, planeTag, ctl );
    rval = make_tag( moab(), n2, MB_TAG_DENSE, MB_TYPE_INT, 1, 0, axisTag, ctl );
    // create tag to hold two doubles, one for location and one for axis
    std::string double_tag_name = std::string( treeName ) + std::string( "_coord_norm" );
    ErrorCode rval = make_tag( moab(), double_tag_name, MB_TAG_DENSE, MB_TYPE_DOUBLE, 2, 0, planeTag, ctl );
#else
    // create opaque tag to hold struct Plane
    ErrorCode rval = make_tag( moab(), tagname, MB_TAG_DENSE, MB_TYPE_OPAQUE, sizeof( Plane ), 0, planeTag, ctl );
#ifdef MOAB_HAVE_HDF5
    // create a mesh tag holding the HDF5 type for a struct Plane
    Tag type_tag;
    std::string type_tag_name = "__hdf5_tag_type_";
    type_tag_name += boxTagName;
    rval = make_tag( moab(), type_tag_name, MB_TAG_MESH, MB_TYPE_OPAQUE, sizeof( hid_t ), 0, type_tag, ctl );
    // create HDF5 type object describing struct Plane
    Plane p;
    hid_t handle = H5Tcreate( H5T_COMPOUND, sizeof( Plane ) );
    H5Tinsert( handle, "coord", &( p.coord ) - &p, H5T_NATIVE_DOUBLE );
    H5Tinsert( handle, "norm", &( p.axis ) - &p, H5T_NATIVE_INT );
    EntityHandle root = 0;
    rval              = mbImpl->tag_set_data( type_tag, &root, 1, &handle );
#endif
#endif
    return rval;
ErrorCode moab::AdaptiveKDTree::intersect_children_with_elems ( const Range elems,
double  eps,
CartVect  box_min,
CartVect  box_max,
Range left_tris,
Range right_tris,
Range both_tris,
double &  metric_value
) [private]
Definition at line 777 of file AdaptiveKDTree.cpp.
References moab::Range::begin(), moab::BoundBox::bMax, moab::BoundBox::bMin, moab::GeomUtil::box_elem_overlap(), box_max(), box_min(), moab::TreeStats::boxElemTests, moab::Range::clear(), moab::TreeStats::constructLeafObjectTests, moab::AdaptiveKDTree::Plane::coord, dim, moab::Range::end(), eps, ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Range::insert(), left_box, moab::Range::lower_bound(), MB_SUCCESS, MBEDGE, MBENTITYSET, MBPOLYHEDRON, moab::Tree::moab(), moab::AdaptiveKDTree::Plane::norm, radius, right_box, moab::Range::size(), spherical, moab::Tree::tree_stats(), moab::TYPE_FROM_HANDLE(), and moab::BoundBox::update().
Referenced by best_subdivision_plane(), best_subdivision_snap_plane(), best_vertex_median_plane(), and best_vertex_sample_plane().
    left_tris.clear();
    right_tris.clear();
    both_tris.clear();
    CartVect coords[16];
    // get extents of boxes for left and right sides
    BoundBox left_box( box_min, box_max ), right_box( box_min, box_max );
    right_box.bMin             = box_min;
    left_box.bMax              = box_max;
    right_box.bMin[plane.norm] = left_box.bMax[plane.norm] = plane.coord;
    const CartVect left_cen                                = 0.5 * ( left_box.bMax + box_min );
    const CartVect left_dim                                = 0.5 * ( left_box.bMax - box_min );
    const CartVect right_cen                               = 0.5 * ( box_max + right_box.bMin );
    const CartVect right_dim                               = 0.5 * ( box_max - right_box.bMin );
    const CartVect dim                                     = box_max - box_min;
    const double max_tol                                   = std::max( dim[0], std::max( dim[1], dim[2] ) ) / 10;
    // test each entity
    ErrorCode rval;
    int count, count2;
    const EntityHandle *conn, *conn2;
    const Range::const_iterator elem_begin = elems.lower_bound( MBEDGE );
    const Range::const_iterator poly_begin = elems.lower_bound( MBPOLYHEDRON, elem_begin );
    const Range::const_iterator set_begin  = elems.lower_bound( MBENTITYSET, poly_begin );
    Range::iterator left_ins               = left_tris.begin();
    Range::iterator right_ins              = right_tris.begin();
    Range::iterator both_ins               = both_tris.begin();
    Range::const_iterator i;
    // vertices
    for( i = elems.begin(); i != elem_begin; ++i )
        tree_stats().constructLeafObjectTests++;
        rval = moab()->get_coords( &*i, 1, coords[0].array() );
        bool lo = false, ro = false;
        if( coords[0][plane.norm] <= plane.coord ) lo = true;
        if( coords[0][plane.norm] >= plane.coord ) ro = true;
        if( lo && ro )
            both_ins = both_tris.insert( both_ins, *i, *i );
        else if( lo )
            left_ins = left_tris.insert( left_ins, *i, *i );
        else  // if (ro)
            right_ins = right_tris.insert( right_ins, *i, *i );
    // non-polyhedron elements
    std::vector< EntityHandle > dum_vector;
    for( i = elem_begin; i != poly_begin; ++i )
        rval = moab()->get_connectivity( *i, conn, count, true, &dum_vector );
        if( count > (int)( sizeof( coords ) / sizeof( coords[0] ) ) ) return MB_FAILURE;
        rval = moab()->get_coords( &conn[0], count, coords[0].array() );
        for( int j = 0; j < count; ++j )
            if( coords[j][plane.norm] <= plane.coord ) lo = true;
            if( coords[j][plane.norm] >= plane.coord ) ro = true;
        // Triangle must be in at least one leaf.  If test against plane
        // identified that leaf, then we're done.  If triangle is on both
        // sides of plane, do more precise test to ensure that it is really
        // in both.
        //        BoundBox box;
        //        box.update(*moab(), *i);
        if( lo && ro )
            double tol = eps;
            lo = ro = false;
            while( !lo && !ro && tol <= max_tol )
                tree_stats().boxElemTests += 2;
                lo = GeomUtil::box_elem_overlap( coords, TYPE_FROM_HANDLE( *i ), left_cen, left_dim + CartVect( tol ),
                                                 count );
                ro = GeomUtil::box_elem_overlap( coords, TYPE_FROM_HANDLE( *i ), right_cen, right_dim + CartVect( tol ),
                                                 count );
                tol *= 10.0;
        if( lo && ro )
        else if( lo )
        else if( ro )
    // polyhedra
    for( i = poly_begin; i != set_begin; ++i )
        rval = moab()->get_connectivity( *i, conn, count, true );
        // just check the bounding box of the polyhedron
            rval = moab()->get_connectivity( conn[j], conn2, count2, true );
            for( int k = 0; k < count2; ++k )
                rval = moab()->get_coords( conn2 + k, 1, coords[0].array() );
        if( lo && ro )
        else if( lo )
        else if( ro )
    // sets
    BoundBox tbox;
    for( i = set_begin; i != elems.end(); ++i )
        rval = tbox.update( *moab(), *i, spherical, radius );
        if( tbox.bMin[plane.norm] <= plane.coord ) lo = true;
        if( tbox.bMax[plane.norm] >= plane.coord ) ro = true;
        if( lo && ro )
        else if( lo )
        else  // if (ro)
    CartVect box_dim  = box_max - box_min;
    double area_left  = left_dim[0] * left_dim[1] + left_dim[1] * left_dim[2] + left_dim[2] * left_dim[0];
    double area_right = right_dim[0] * right_dim[1] + right_dim[1] * right_dim[2] + right_dim[2] * right_dim[0];
    double area_both  = box_dim[0] * box_dim[1] + box_dim[1] * box_dim[2] + box_dim[2] * box_dim[0];
    metric_value = ( area_left * left_tris.size() + area_right * right_tris.size() ) / area_both + both_tris.size();
    return MB_SUCCESS;
ErrorCode moab::AdaptiveKDTree::make_tag ( Interface iface,
std::string  name,
TagType  storage,
DataType  type,
int  count,
void *  default_val,
Tag tag_handle,
std::vector< Tag > &  created_tags
) [private]
Definition at line 209 of file AdaptiveKDTree.cpp.
References axisTag, ErrorCode, MB_SUCCESS, MB_TAG_CREAT, planeTag, moab::Interface::tag_delete(), and moab::Interface::tag_get_handle().
Referenced by init().
    ErrorCode rval =
        iface->tag_get_handle( name.c_str(), count, type, tag_handle, MB_TAG_CREAT | storage, default_val );
        if( std::find( created_tags.begin(), created_tags.end(), tag_handle ) == created_tags.end() )
            created_tags.push_back( tag_handle );
    else
        while( !created_tags.empty() )
            iface->tag_delete( created_tags.back() );
            created_tags.pop_back();
        planeTag = axisTag = (Tag)-1;
    return rval;
Merge the leaf pointed to by the current iterator with it's sibling. If the sibling is not a leaf, multiple merges may be done.
Definition at line 419 of file AdaptiveKDTree.cpp.
References moab::Interface::add_entities(), moab::Range::back(), moab::AdaptiveKDTreeIter::childVect, moab::Range::clear(), moab::AdaptiveKDTreeIter::StackObj::coord, moab::Interface::delete_entities(), moab::AdaptiveKDTreeIter::depth(), moab::AdaptiveKDTreeIter::StackObj::entity, ErrorCode, moab::Interface::get_child_meshsets(), moab::Interface::get_entities_by_handle(), get_split_plane(), moab::AdaptiveKDTreeIter::handle(), MB_CHK_ERR, MB_SUCCESS, moab::AdaptiveKDTreeIter::mBox, moab::Tree::moab(), moab::AdaptiveKDTreeIter::mStack, moab::AdaptiveKDTree::Plane::norm, and moab::Interface::remove_child_meshset().
Referenced by test_leaf_merge(), and test_tree_merge_nodes().
    ErrorCode rval;
    if( iter.depth() == 1 )  // at root
        return MB_FAILURE;
    // Move iter to parent
    AdaptiveKDTreeIter::StackObj node = iter.mStack.back();
    iter.mStack.pop_back();
    iter.childVect.clear();
    rval = moab()->get_child_meshsets( iter.mStack.back().entity, iter.childVect );
    Plane plane;
    rval = get_split_plane( iter.mStack.back().entity, plane );
    int child_idx = iter.childVect[0] == node.entity ? 0 : 1;
    assert( iter.childVect[child_idx] == node.entity );
    iter.mBox[1 - child_idx][plane.norm] = node.coord;
    // Get all entities from children and put them in parent
    EntityHandle parent = iter.handle();
    moab()->remove_child_meshset( parent, iter.childVect[0] );
    moab()->remove_child_meshset( parent, iter.childVect[1] );
    std::vector< EntityHandle > stack( iter.childVect );
    Range range;
        EntityHandle h = stack.back();
        stack.pop_back();
        range.clear();
        rval = moab()->get_entities_by_handle( h, range );
        rval = moab()->add_entities( parent, range );
        rval = moab()->get_child_meshsets( h, iter.childVect );MB_CHK_ERR( rval );
        if( !iter.childVect.empty() )
            moab()->remove_child_meshset( h, iter.childVect[0] );
            moab()->remove_child_meshset( h, iter.childVect[1] );
            stack.push_back( iter.childVect[0] );
            stack.push_back( iter.childVect[1] );
        rval = moab()->delete_entities( &h, 1 );
    return MB_SUCCESS;
Parameters:
optionsOptions passed in by application
Returns:
Failure is returned if any options were passed in and not interpreted; could mean inappropriate options for a particular tree type
Definition at line 176 of file AdaptiveKDTree.cpp.
References ErrorCode, moab::FileOptions::get_int_option(), moab::FileOptions::get_real_option(), moab::FileOptions::get_toggle_option(), MB_ENTITY_NOT_FOUND, MB_SUCCESS, moab::Tree::parse_common_options(), planeSet, radius, spherical, splitsPerDir, SUBDIVISION, and VERTEX_SAMPLE.
Referenced by AdaptiveKDTree(), and build_tree().
    ErrorCode rval = parse_common_options( opts );
    //  SPLITS_PER_DIR: number of candidate splits considered per direction; default = 3
    int tmp_int;
    rval = opts.get_int_option( "SPLITS_PER_DIR", tmp_int );
    if( MB_SUCCESS == rval ) splitsPerDir = tmp_int;
    //  PLANE_SET: method used to decide split planes; see CandidatePlaneSet enum (below)
    //           for possible values; default = 1 (SUBDIVISION_SNAP)
    rval = opts.get_int_option( "PLANE_SET", tmp_int );
    if( MB_SUCCESS == rval && ( tmp_int < SUBDIVISION || tmp_int > VERTEX_SAMPLE ) )
        return MB_FAILURE;
    else if( MB_ENTITY_NOT_FOUND == rval )
        planeSet = SUBDIVISION;
    else
        planeSet = (CandidatePlaneSet)( tmp_int );
    rval = opts.get_toggle_option( "SPHERICAL", false, spherical );
    if( MB_SUCCESS != rval ) spherical = false;
    double tmp = 1.0;
    rval       = opts.get_real_option( "RADIUS", tmp );
        radius = 1.0;
    else
        radius = tmp;
    return MB_SUCCESS;
ErrorCode moab::AdaptiveKDTree::point_search ( const double *  point,
EntityHandle leaf_out,
bool *  multiple_leaves = NULL,
EntityHandle start_node = NULL,
CartVect params = NULL
) [virtual]
Does not take into account global bounding box of tree.
  • Therefore there is always one leaf containing the point.
  • If caller wants to account for global bounding box, then caller can test against that box and not call this method at all if the point is outside the box, as there is no leaf containing the point in that case.
    Parameters:
    leaf_outLeaf containing point
    multiple_leavesSome tree types can have multiple leaves containing a point; if non-NULL, this parameter is returned true if multiple leaves contain the input point
    Returns:
    Non-success returned only in case of failure; not-found indicated by leaf_out=0
Definition at line 1266 of file AdaptiveKDTree.cpp.
References moab::CartVect::array(), box(), children, moab::BoundBox::contains_point(), moab::AdaptiveKDTree::Plane::coord, ErrorCode, moab::ElemEvaluator::find_containing_entity(), moab::Tree::get_bounding_box(), moab::Interface::get_child_meshsets(), get_split_plane(), moab::TreeStats::leavesVisited, MB_SUCCESS, moab::Tree::moab(), moab::Tree::myEval, moab::Tree::myRoot, moab::TreeStats::nodesVisited, moab::AdaptiveKDTree::Plane::norm, moab::TreeStats::numTraversals, moab::TreeStats::traversalLeafObjectTests, and moab::Tree::treeStats.
Referenced by moab::TempestRemapper::ConstructCoveringSet(), do_kdtree_test(), main(), moab::Coupler::nat_param(), and test_point_search().
    Plane plane;
    leaf_out = 0;
    BoundBox box;
    // kdtrees never have multiple leaves containing a pt
    if( multiple_leaves ) *multiple_leaves = false;
    EntityHandle node = ( start_node ? *start_node : myRoot );
    ErrorCode rval = get_bounding_box( box, &node );
    if( !box.contains_point( point, iter_tol ) ) return MB_SUCCESS;
    while( !children.empty() )
        rval = get_split_plane( node, plane );
        const double d = point[plane.norm] - plane.coord;
        node           = children[( d > 0.0 )];
        children.clear();
    if( myEval && params )
        rval = myEval->find_containing_entity( node, point, iter_tol, inside_tol, leaf_out, params->array(),
    else
        leaf_out = node;
    return MB_SUCCESS;
AdaptiveKDTreeIter leaf_it,
    Parameters:
    leaf_itIterator to leaf containing point
    Returns:
Definition at line 1321 of file AdaptiveKDTree.cpp.
References moab::BoundBox::bMax, moab::BoundBox::bMin, moab::Tree::boundBox, moab::AdaptiveKDTreeIter::childVect, moab::BoundBox::contains_point(), moab::AdaptiveKDTree::Plane::coord, ErrorCode, moab::Interface::get_child_meshsets(), get_split_plane(), moab::AdaptiveKDTreeIter::handle(), moab::TreeStats::leavesVisited, MB_ENTITY_NOT_FOUND, MB_SUCCESS, moab::AdaptiveKDTreeIter::mBox, moab::Tree::moab(), moab::AdaptiveKDTreeIter::mStack, moab::Tree::myRoot, moab::TreeStats::nodesVisited, moab::AdaptiveKDTree::Plane::norm, moab::TreeStats::numTraversals, moab::Tree::treeStats, and moab::AdaptiveKDTreeIter::treeTool.
    ErrorCode rval;
    leaf_it.mBox[0] = boundBox.bMin;
    leaf_it.mBox[1] = boundBox.bMax;
    // test that point is inside tree
    if( !boundBox.contains_point( point, iter_tol ) )
    // initialize iterator at tree root
    leaf_it.treeTool = this;
    leaf_it.mStack.clear();
    leaf_it.mStack.push_back( AdaptiveKDTreeIter::StackObj( ( start_node ? *start_node : myRoot ), 0 ) );
    // loop until we reach a leaf
    AdaptiveKDTree::Plane plane;
    for( ;; )
        // get children
        leaf_it.childVect.clear();
        rval = moab()->get_child_meshsets( leaf_it.handle(), leaf_it.childVect );
        // if no children, then at leaf (done)
        if( leaf_it.childVect.empty() )
            break;
        // get split plane
        rval = get_split_plane( leaf_it.handle(), plane );
        // step iterator to appropriate child
        // idx: 0->left, 1->right
        const int idx = ( point[plane.norm] > plane.coord );
            AdaptiveKDTreeIter::StackObj( leaf_it.childVect[idx], leaf_it.mBox[1 - idx][plane.norm] ) );
        leaf_it.mBox[1 - idx][plane.norm] = plane.coord;
    return MB_SUCCESS;
Definition at line 2131 of file AdaptiveKDTree.cpp.
References moab::SimpleStat< T >::add(), moab::SimpleStat< T >::avg(), moab::Range::begin(), moab::BoundBox::bMax, moab::BoundBox::bMin, box(), moab::AdaptiveKDTreeIter::box_max(), moab::AdaptiveKDTreeIter::box_min(), moab::SimpleStat< T >::count, moab::AdaptiveKDTreeIter::depth(), moab::SimpleStat< T >::dev(), moab::Range::end(), ErrorCode, moab::Interface::estimated_memory_use(), moab::Tree::get_bounding_box(), moab::Interface::get_child_meshsets(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_type(), moab::Interface::get_number_entities_by_dimension(), moab::Interface::get_number_entities_by_handle(), get_tree_iterator(), moab::AdaptiveKDTreeIter::handle(), moab::Range::insert(), moab::SimpleStat< T >::max, MB_SUCCESS, MBVERTEX, moab::mem_to_string(), moab::Range::merge(), moab::SimpleStat< T >::min, moab::Tree::moab(), moab::Tree::myRoot, moab::SimpleStat< T >::rms(), size, moab::Range::size(), moab::AdaptiveKDTreeIter::step(), and moab::SimpleStat< T >::sum.
Referenced by main().
    Range range;
    Range tree_sets, elem2d, elem3d, verts, all;
    moab()->get_child_meshsets( myRoot, tree_sets, 0 );
    for( Range::iterator rit = tree_sets.begin(); rit != tree_sets.end(); ++rit )
        moab()->get_entities_by_dimension( *rit, 2, elem2d );
        moab()->get_entities_by_dimension( *rit, 3, elem3d );
        moab()->get_entities_by_type( *rit, MBVERTEX, verts );
    all.merge( verts );
    all.merge( elem2d );
    all.merge( elem3d );
    tree_sets.insert( myRoot );
    unsigned long long set_used, set_amortized, set_store_used, set_store_amortized, set_tag_used, set_tag_amortized,
        elem_used, elem_amortized;
    moab()->estimated_memory_use( tree_sets, &set_used, &set_amortized, &set_store_used, &set_store_amortized, 0, 0, 0,
                                  0, &set_tag_used, &set_tag_amortized );
    moab()->estimated_memory_use( all, &elem_used, &elem_amortized );
    int num_2d = 0, num_3d = 0;
    moab()->get_number_entities_by_dimension( 0, 2, num_2d );
    moab()->get_number_entities_by_dimension( 0, 3, num_3d );
    BoundBox box;
    ErrorCode rval = get_bounding_box( box, &myRoot );
    if( MB_SUCCESS != rval || box == BoundBox() ) throw rval;
    double diff[3]        = { box.bMax[0] - box.bMin[0], box.bMax[1] - box.bMin[1], box.bMax[2] - box.bMin[2] };
    double tree_vol       = diff[0] * diff[1] * diff[2];
    double tree_surf_area = 2 * ( diff[0] * diff[1] + diff[1] * diff[2] + diff[2] * diff[0] );
    SimpleStat< unsigned > depth, size;
    SimpleStat< double > vol, surf;
    get_tree_iterator( myRoot, iter );
    do
        depth.add( iter.depth() );
        int num_leaf_elem;
        moab()->get_number_entities_by_handle( iter.handle(), num_leaf_elem );
        size.add( num_leaf_elem );
        const double* n = iter.box_min();
        const double* x = iter.box_max();
        double dims[3]  = { x[0] - n[0], x[1] - n[1], x[2] - n[2] };
        double leaf_vol = dims[0] * dims[1] * dims[2];
        vol.add( leaf_vol );
        double area = 2.0 * ( dims[0] * dims[1] + dims[1] * dims[2] + dims[2] * dims[0] );
        surf.add( area );
    } while( MB_SUCCESS == iter.step() );
    printf( "------------------------------------------------------------------\n" );
    printf( "tree volume:      %f\n", tree_vol );
    printf( "total elements:   %d\n", num_2d + num_3d );
    printf( "number of leaves: %lu\n", (unsigned long)depth.count );
    printf( "number of nodes:  %lu\n", (unsigned long)tree_sets.size() );
    printf( "volume ratio:     %0.2f%%\n", 100 * ( vol.sum / tree_vol ) );
    printf( "surface ratio:    %0.2f%%\n", 100 * ( surf.sum / tree_surf_area ) );
    printf( "\nmemory:           used  amortized\n" );
    printf( "            ---------- ----------\n" );
    printf( "elements    %10s %10s\n", mem_to_string( elem_used ).c_str(), mem_to_string( elem_amortized ).c_str() );
    printf( "sets (total)%10s %10s\n", mem_to_string( set_used ).c_str(), mem_to_string( set_amortized ).c_str() );
    printf( "sets        %10s %10s\n", mem_to_string( set_store_used ).c_str(),
            mem_to_string( set_store_amortized ).c_str() );
    printf( "set tags    %10s %10s\n", mem_to_string( set_tag_used ).c_str(),
            mem_to_string( set_tag_amortized ).c_str() );
    printf( "\nleaf stats:        min        avg        rms        max    std.dev\n" );
    printf( "            ---------- ---------- ---------- ---------- ----------\n" );
    printf( "depth       %10u %10.1f %10.1f %10u %10.2f\n", depth.min, depth.avg(), depth.rms(), depth.max,
            depth.dev() );
    printf( "triangles   %10u %10.1f %10.1f %10u %10.2f\n", size.min, size.avg(), size.rms(), size.max, size.dev() );
    printf( "volume      %10.2g %10.2g %10.2g %10.2g %10.2g\n", vol.min, vol.avg(), vol.rms(), vol.max, vol.dev() );
    printf( "surf. area  %10.2g %10.2g %10.2g %10.2g %10.2g\n", surf.min, surf.avg(), surf.rms(), surf.max,
            surf.dev() );
    return MB_SUCCESS;
ErrorCode moab::AdaptiveKDTree::ray_intersect_triangles ( EntityHandle  tree_root,
std::vector< EntityHandle > &  triangles_out,
std::vector< double > &  distance_out,
int  result_count_limit = 0,
double  distance_limit = -1.0
Definition at line 1851 of file AdaptiveKDTree.cpp.
References moab::NodeSeg::beg, moab::Range::begin(), moab::BoundBox::bMax, moab::BoundBox::bMin, box(), children, moab::Range::clear(), moab::AdaptiveKDTree::Plane::coord, moab::Range::end(), moab::NodeSeg::end, ErrorCode, moab::Tree::get_bounding_box(), moab::Interface::get_child_meshsets(), moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), get_split_plane(), moab::NodeSeg::handle, moab::Util::is_finite(), MB_SUCCESS, MBTRI, moab::Tree::moab(), moab::AdaptiveKDTree::Plane::norm, moab::GeomUtil::ray_tri_intersect(), moab::GeomUtil::segment_box_intersect(), t, and tri_coords().
Referenced by test_ray_intersect_triangles().
    ErrorCode rval;
    double ray_beg = 0.0;
    if( ray_end < 0.0 ) ray_end = HUGE_VAL;
    // if root has bounding box, trim ray to that box
    CartVect tvec( tol );
    BoundBox box;
    const CartVect ray_pt( ray_pt_in ), ray_dir( ray_dir_in );
        if( !GeomUtil::segment_box_intersect( box.bMin - tvec, box.bMax + tvec, ray_pt, ray_dir, ray_beg, ray_end ) )
            return MB_SUCCESS;  // ray misses entire tree.
    Range tris;
    Range::iterator iter;
    CartVect tri_coords[3];
    const EntityHandle* tri_conn;
    int conn_len;
    double tri_t;
    Plane plane;
    std::vector< NodeSeg > list;
    NodeSeg seg( root, ray_beg, ray_end );
    list.push_back( seg );
        seg = list.back();
        list.pop_back();
        // If we are limited to a certain number of intersections
        // (max_ints != 0), then ray_end will contain the distance
        // to the furthest intersection we have so far.  If the
        // tree node is further than that, skip it.
        if( seg.beg > ray_end ) continue;
        // Check if at a leaf
        children.clear();
        rval = moab()->get_child_meshsets( seg.handle, children );
        {  // leaf
            tris.clear();
            rval = moab()->get_entities_by_type( seg.handle, MBTRI, tris );
            for( iter = tris.begin(); iter != tris.end(); ++iter )
                rval = moab()->get_connectivity( *iter, tri_conn, conn_len );
                rval = moab()->get_coords( tri_conn, 3, tri_coords[0].array() );
                if( GeomUtil::ray_tri_intersect( tri_coords, ray_pt, ray_dir, tri_t, &ray_end ) )
                    if( !max_ints )
                        if( std::find( tris_out.begin(), tris_out.end(), *iter ) == tris_out.end() )
                            tris_out.push_back( *iter );
                            dists_out.push_back( tri_t );
                    else if( tri_t < ray_end )
                            if( tris_out.size() < (unsigned)max_ints )
                                tris_out.resize( tris_out.size() + 1 );
                                dists_out.resize( dists_out.size() + 1 );
                            int w = tris_out.size() - 1;
                            for( ; w > 0 && tri_t < dists_out[w - 1]; --w )
                                tris_out[w]  = tris_out[w - 1];
                                dists_out[w] = dists_out[w - 1];
                            tris_out[w]  = *iter;
                            dists_out[w] = tri_t;
                            if( tris_out.size() >= (unsigned)max_ints )
                                // when we have already reached the max intx points, we cans safely
                                // reset ray_end, because we will accept new points only "closer"
                                // than the last one
                                ray_end = dists_out.back();
            continue;
        rval = get_split_plane( seg.handle, plane );
        // Consider two planes that are the split plane +/- the tolerance.
        // Calculate the segment parameter at which the line segment intersects
        // the true plane, and also the difference between that value and the
        // intersection with either of the +/- tol planes.
        const double inv_dir = 1.0 / ray_dir[plane.norm];                       // only do division once
        const double t       = ( plane.coord - ray_pt[plane.norm] ) * inv_dir;  // intersection with plane
        const double diff    = tol * inv_dir;                                   // t adjustment for +tol plane
            // const double t0 = t - diff; // intersection with -tol plane
            // const double t1 = t + diff; // intersection with +tol plane
        // The index of the child tree node (0 or 1) that is on the
        // side of the plane to which the ray direction points.  That is,
        // if the ray direction is opposite the plane normal, the index
        // of the child corresponding to the side beneath the plane.  If
        // the ray direction is the same as the plane normal, the index
        // of the child corresponding to the side above the plane.
        const int fwd_child = ( ray_dir[plane.norm] > 0.0 );
        // Note: we maintain seg.beg <= seg.end at all times, so assume that here.
        // If segment is parallel to plane
        if( !Util::is_finite( t ) )
            if( ray_pt[plane.norm] - tol <= plane.coord ) list.push_back( NodeSeg( children[0], seg.beg, seg.end ) );
            if( ray_pt[plane.norm] + tol >= plane.coord ) list.push_back( NodeSeg( children[1], seg.beg, seg.end ) );
        // If segment is entirely to one side of plane such that the
        // intersection with the split plane is past the end of the segment
        else if( seg.end + diff < t )
            // If segment direction is opposite that of plane normal, then
            // being past the end of the segment means that we are to the
            // right (or above) the plane and what the right child (index == 1).
            // Otherwise we want the left child (index == 0);
            list.push_back( NodeSeg( children[1 - fwd_child], seg.beg, seg.end ) );
        // If the segment is entirely to one side of the plane such that
        // the intersection with the split plane is before the start of the
        // segment
        else if( seg.beg - diff > t )
            // being before the start of the segment means that we are to the
            // left (or below) the plane and what the left child (index == 0).
            // Otherwise we want the right child (index == 1);
            list.push_back( NodeSeg( children[fwd_child], seg.beg, seg.end ) );
        // Otherwise we must intersect the plane.
        // Note: be careful not to grow the segment if t is slightly
        // outside the current segment, as doing so would effectively
        // increase the tolerance as we descend the tree.
        else if( t <= seg.beg )
            list.push_back( NodeSeg( children[1 - fwd_child], seg.beg, seg.beg ) );
        else if( t >= seg.end )
            list.push_back( NodeSeg( children[fwd_child], seg.end, seg.end ) );
        else
            list.push_back( NodeSeg( children[1 - fwd_child], seg.beg, t ) );
            list.push_back( NodeSeg( children[fwd_child], t, seg.end ) );
    return MB_SUCCESS;
Definition at line 303 of file AdaptiveKDTree.cpp.
References axisTag, moab::AdaptiveKDTree::Plane::coord, ErrorCode, MB_SUCCESS, moab::Tree::moab(), moab::AdaptiveKDTree::Plane::norm, planeTag, and moab::Interface::tag_set_data().
Referenced by split_leaf().
    ErrorCode r1, r2;
    r1 = moab()->tag_set_data( planeTag, &entity, 1, &plane.coord );
    r2 = moab()->tag_set_data( axisTag, &entity, 1, &plane.norm );
    double values[2] = { plane.coord, static_cast< double >( plane.norm ) };
    return moab()->tag_set_data( planeTag, &entity, 1, values );
#else
    return moab()->tag_set_data( planeTag, &entity, 1, &plane );
#endif
ErrorCode moab::AdaptiveKDTree::sphere_intersect_triangles ( EntityHandle  tree_root,
double  radius,
Definition at line 1801 of file AdaptiveKDTree.cpp.
References moab::Range::begin(), moab::GeomUtil::closest_location_on_tri(), distance_search(), moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), MB_SUCCESS, MBTRI, and moab::Tree::moab().
Referenced by test_sphere_intersect_triangles().
    ErrorCode rval;
    const CartVect from( center );
    const EntityHandle* conn;
    CartVect coords[3];
    int conn_len;
    // get leaves of tree that intersect sphere
    rval = distance_search( center, rad, leaves, 1.0e-10, 1.0e-6, NULL, NULL, &tree_root );
    // search each leaf for triangles intersecting sphere
        Range tris;
        rval = moab()->get_entities_by_type( leaves[i], MBTRI, tris );
        for( Range::iterator j = tris.begin(); j != tris.end(); ++j )
            rval = moab()->get_connectivity( *j, conn, conn_len );
            rval = moab()->get_coords( conn, 3, coords[0].array() );
            GeomUtil::closest_location_on_tri( from, coords, closest_pt );
            closest_pt -= from;
            if( ( closest_pt % closest_pt ) <= ( rad * rad ) ) triangles.push_back( *j );
    // remove duplicates from triangle list
    std::sort( triangles.begin(), triangles.end() );
    triangles.erase( std::unique( triangles.begin(), triangles.end() ), triangles.end() );
    return MB_SUCCESS;
Split leaf of tree Updates iterator location to point to first new leaf node.
Definition at line 371 of file AdaptiveKDTree.cpp.
Referenced by build_grid(), build_tree(), create_simple_2d_tree(), create_tree(), and split_leaf().
    EntityHandle left, right;
    return split_leaf( leaf, plane, left, right );
ErrorCode moab::AdaptiveKDTree::split_leaf ( AdaptiveKDTreeIter leaf,
Plane  plane,
EntityHandle left_child,
EntityHandle right_child
Definition at line 344 of file AdaptiveKDTree.cpp.
References moab::Interface::add_child_meshset(), children, moab::Interface::create_meshset(), moab::Interface::delete_entities(), ErrorCode, moab::AdaptiveKDTreeIter::handle(), moab::AdaptiveKDTreeIter::LEFT, MB_SUCCESS, moab::Tree::meshsetFlags, moab::Tree::moab(), set_split_plane(), and moab::AdaptiveKDTreeIter::step_to_first_leaf().
    ErrorCode rval;
    rval = moab()->create_meshset( meshsetFlags, left );
    rval = moab()->create_meshset( meshsetFlags, right );
        moab()->delete_entities( &left, 1 );
        return rval;
    if( MB_SUCCESS != set_split_plane( leaf.handle(), plane ) ||
        MB_SUCCESS != moab()->add_child_meshset( leaf.handle(), left ) ||
        MB_SUCCESS != moab()->add_child_meshset( leaf.handle(), right ) ||
        MB_SUCCESS != leaf.step_to_first_leaf( AdaptiveKDTreeIter::LEFT ) )
        EntityHandle children[] = { left, right };
        moab()->delete_entities( children, 2 );
        return MB_FAILURE;
    return MB_SUCCESS;
Plane  plane,
const Range left_entities,
const Range right_entities
Definition at line 377 of file AdaptiveKDTree.cpp.
References children, moab::Interface::delete_entities(), ErrorCode, moab::AdaptiveKDTreeIter::handle(), MB_SUCCESS, moab::Tree::moab(), moab::Interface::remove_child_meshset(), and split_leaf().
    EntityHandle left, right, parent = leaf.handle();
    ErrorCode rval = split_leaf( leaf, plane, left, right );
    if( MB_SUCCESS == moab()->add_entities( left, left_entities ) &&
        MB_SUCCESS == moab()->add_entities( right, right_entities ) &&
        MB_SUCCESS == moab()->clear_meshset( &parent, 1 ) )
        return MB_SUCCESS;
    moab()->remove_child_meshset( parent, left );
    moab()->remove_child_meshset( parent, right );
    return MB_FAILURE;
Plane  plane,
const std::vector< EntityHandle > &  left_entities,
const std::vector< EntityHandle > &  right_entities
Definition at line 398 of file AdaptiveKDTree.cpp.
References moab::Interface::add_entities(), children, moab::Interface::clear_meshset(), moab::Interface::delete_entities(), ErrorCode, moab::AdaptiveKDTreeIter::handle(), MB_SUCCESS, moab::Tree::moab(), moab::Interface::remove_child_meshset(), and split_leaf().
    if( MB_SUCCESS == moab()->add_entities( left, &left_entities[0], left_entities.size() ) &&
        MB_SUCCESS == moab()->add_entities( right, &right_entities[0], right_entities.size() ) &&
        return MB_SUCCESS;
    return MB_FAILURE;
Friends And Related Function Documentation
friend class AdaptiveKDTreeIter [friend]
Definition at line 264 of file AdaptiveKDTree.hpp.
Member Data Documentation
Definition at line 331 of file AdaptiveKDTree.hpp.
Referenced by get_split_plane(), init(), make_tag(), and set_split_plane().
Definition at line 335 of file AdaptiveKDTree.hpp.
Referenced by build_tree(), and parse_options().
double moab::AdaptiveKDTree::radius [private]
Definition at line 338 of file AdaptiveKDTree.hpp.
Referenced by build_tree(), intersect_children_with_elems(), and parse_options().
Definition at line 333 of file AdaptiveKDTree.hpp.
const char * moab::AdaptiveKDTree::treeName = "AKDTree" [static, private]
Definition at line 329 of file AdaptiveKDTree.hpp.
Referenced by AdaptiveKDTree(), and init().
List of all members.
