moab::AdjSides< CORNERS > Class Template Reference
Classes
struct  Side
Public Types
typedef std::vector< Side >
::iterator
iterator
::const_iterator
const_iterator
Public Member Functions
const_iterator begin () const
const_iterator end () const
void clear ()
bool empty () const
 AdjSides ()
size_t num_skin () const
void insert (const EntityHandle *handles, int skip_idx, EntityHandle adj_elem, unsigned short elem_side)
 insert side, specifying side connectivity
void insert (const EntityHandle *handles, int skip_idx, EntityHandle adj_elem, unsigned short elem_side, const short *indices)
 insert side, specifying list of indices into parent element connectivity.
bool find_and_unmark (const EntityHandle *other, int skip_index, EntityHandle &elem_out)
 Search list for a given side, and if found, mark as not skin.
Private Attributes
std::vector< Sidedata
 List of sides.
size_t skin_count
 Cached count of sides that are skin.
Detailed Description
template<unsigned CORNERS>
class moab::AdjSides< CORNERS >
Definition at line 1144 of file Skinner.cpp.
Member Typedef Documentation
typedef std::vector< Side >::const_iterator moab::AdjSides< CORNERS >::const_iterator
Definition at line 1252 of file Skinner.cpp.
typedef std::vector< Side >::iterator moab::AdjSides< CORNERS >::iterator
Definition at line 1251 of file Skinner.cpp.
moab::AdjSides< CORNERS >::AdjSides ( ) [inline]
Definition at line 1272 of file Skinner.cpp.
: skin_count( 0 ) {}
Member Function Documentation
const_iterator moab::AdjSides< CORNERS >::begin ( ) const [inline]
Definition at line 1253 of file Skinner.cpp.
References moab::AdjSides< CORNERS >::data.
Referenced by moab::Skinner::find_skin_vertices_2D(), and moab::Skinner::find_skin_vertices_3D().
        return data.begin();
void moab::AdjSides< CORNERS >::clear ( ) [inline]
bool moab::AdjSides< CORNERS >::empty ( ) const [inline]
Definition at line 1267 of file Skinner.cpp.
        return data.empty();
const_iterator moab::AdjSides< CORNERS >::end ( ) const [inline]
Definition at line 1257 of file Skinner.cpp.
        return data.end();
bool moab::AdjSides< CORNERS >::find_and_unmark ( const EntityHandle other,
int  skip_index,
EntityHandle elem_out
) [inline]
Parameters:
otherConnectivity of side
skip_indexIndex in 'other' at which implicit vertex occurs.
elem_outIf return value is true, the element that the side is a side of. If return value is false, not set.
Returns:
true if found and marked not-skin, false if not found.
Given the connectivity of some existing element, check if it occurs in the list. If it does, clear the "is skin" state of the side so that we know that we don't need to later create the side element.
Definition at line 1355 of file Skinner.cpp.
References moab::AdjSides< CORNERS >::data, and moab::AdjSides< CORNERS >::skin_count.
        Side s( other, skip_index, 0, 0 );
        iterator p = std::find( data.begin(), data.end(), s );
        if( p == data.end() || !p->adj_elem )
            return false;
        else
            elem_out    = p->adj_elem;
            p->adj_elem = 0;  // clear "is skin" state for side
            --skin_count;     // decrement cached count of skin sides
            return true;
void moab::AdjSides< CORNERS >::insert ( const EntityHandle handles,
int  skip_idx,
) [inline]
Either insert a new side, or if the side is already in the list, mark it as not on the skin.
Parameters:
handlesThe connectivity of the element side.
skip_idxThe index of the implicit vertex (contained in all sides in the list.)
adj_elemThe element that this is a side of.
elem_sideWhich side of adj_elem are we storing (CN side number.)
Definition at line 1291 of file Skinner.cpp.
        Side side( handles, skip_idx, adj_elem, elem_side );
        iterator p = std::find( data.begin(), data.end(), side );
        if( p == data.end() )
            data.push_back( side );
            ++skin_count;  // not in list yet, so skin side (so far)
        else if( p->adj_elem )
            p->adj_elem = 0;  // mark as not on skin
            --skin_count;     // decrement cached count of skin elements
int  skip_idx,
const short *  indices
) [inline]
Parameters:
handlesThe connectivity of the parent element
skip_idxThe index of the implicit vertex (contained in all sides in the list.) This is an index into 'indices', not 'handles'.
adj_elemThe element that this is a side of (parent handle).
indicesThe indices into 'handles' at which the vertices representing the side occur.
Definition at line 1323 of file Skinner.cpp.
        Side side( handles, skip_idx, adj_elem, elem_side, indices );
size_t moab::AdjSides< CORNERS >::num_skin ( ) const [inline]
Member Data Documentation
size_t moab::AdjSides< CORNERS >::skin_count [private]
List of all members.
