moab::BSPTreeIter Class Reference
Iterate over leaves of a BSPTree. More...
#include <BSPTree.hpp>
+ Inheritance diagram for moab::BSPTreeIter:
+ Collaboration diagram for moab::BSPTreeIter:
Public Types
enum  Direction { LEFT = 0, RIGHT = 1 }
Public Member Functions
 BSPTreeIter ()
virtual ~BSPTreeIter ()
BSPTreetool () const
EntityHandle handle () const
 Get handle for current leaf.
unsigned depth () const
 Get depth in tree. root is at depth of 1.
virtual ErrorCode step (Direction direction)
ErrorCode step ()
ErrorCode back ()
ErrorCode get_parent_split_plane (BSPTree::Plane &plane) const
 Get split plane that separates this node from its immediate sibling.
virtual double volume () const
 Get volume of leaf polyhedron.
virtual bool intersect_ray (const double ray_point[3], const double ray_vect[3], double &t_enter, double &t_exit) const
bool is_sibling (const BSPTreeIter &other_leaf) const
bool is_sibling (EntityHandle other_leaf) const
bool sibling_is_forward () const
virtual ErrorCode calculate_polyhedron (BSPTreePoly &polyhedron_out) const
 Calculate the convex polyhedron bounding this leaf.
Protected Member Functions
virtual ErrorCode step_to_first_leaf (Direction direction)
virtual ErrorCode up ()
virtual ErrorCode down (const BSPTree::Plane &plane, Direction direction)
virtual ErrorCode initialize (BSPTree *tool, EntityHandle root, const double *point=0)
Protected Attributes
std::vector< EntityHandlemStack
std::vector< EntityHandlechildVect
Private Attributes
BSPTreetreeTool
Friends
class BSPTree
Detailed Description
Definition at line 252 of file BSPTree.hpp.
Member Enumeration Documentation
Enumerator:
LEFT
RIGHT
Definition at line 255 of file BSPTree.hpp.
        LEFT  = 0,
        RIGHT = 1
Definition at line 278 of file BSPTree.hpp.
: treeTool( 0 ), childVect( 2 ) {}
virtual moab::BSPTreeIter::~BSPTreeIter ( ) [inline, virtual]
Definition at line 279 of file BSPTree.hpp.
Member Function Documentation
Move back to previous leaf Returns MB_ENTITY_NOT_FOUND if at beginning. Note: stepping past the start of the tree will invalidate the iterator. Calling step() will not work.
Reimplemented in moab::BSPTreeBoxIter.
Definition at line 317 of file BSPTree.hpp.
References LEFT, and step().
Referenced by test_iterator().
        return step( LEFT );
ErrorCode moab::BSPTreeIter::calculate_polyhedron ( BSPTreePoly polyhedron_out) const [virtual]
Definition at line 512 of file BSPTree.cpp.
References moab::CartVect::array(), childVect, moab::BSPTree::Plane::coeff, moab::BSPTreePoly::cut_polyhedron(), ErrorCode, moab::BSPTree::Plane::flip(), moab::Interface::get_child_meshsets(), moab::BSPTree::get_split_plane(), moab::BSPTree::get_tree_box(), MB_SUCCESS, moab::BSPTree::moab(), mStack, moab::BSPTree::Plane::norm, moab::BSPTreePoly::set(), and treeTool.
Referenced by test_leaf_polyhedron(), and volume().
    ErrorCode rval;
    assert( sizeof( CartVect ) == 3 * sizeof( double ) );
    CartVect corners[8];
    rval = treeTool->get_tree_box( mStack.front(), corners[0].array() );
    if( MB_SUCCESS != rval ) return rval;
    rval = poly_out.set( corners );
    BSPTree::Plane plane;
    std::vector< EntityHandle >::const_iterator i    = mStack.begin();
    std::vector< EntityHandle >::const_iterator here = mStack.end() - 1;
    while( i != here )
        rval = treeTool->get_split_plane( *i, plane );
        childVect.clear();
        rval = treeTool->moab()->get_child_meshsets( *i, childVect );
        if( childVect.size() != 2 ) return MB_FAILURE;
        ++i;
        if( childVect[1] == *i ) plane.flip();
        CartVect norm( plane.norm );
        poly_out.cut_polyhedron( norm, plane.coeff );
    return MB_SUCCESS;
unsigned moab::BSPTreeIter::depth ( ) const [inline]
Definition at line 293 of file BSPTree.hpp.
References mStack.
Referenced by moab::BSPTree::merge_leaf(), test_box_iterator(), test_box_tree_create(), test_iterator(), test_merge_leaf(), and test_tree_create().
        return mStack.size();
ErrorCode moab::BSPTreeIter::down ( const BSPTree::Plane plane,
Direction  direction
) [protected, virtual]
Definition at line 449 of file BSPTree.cpp.
References childVect, ErrorCode, moab::Interface::get_child_meshsets(), MB_ENTITY_NOT_FOUND, MB_SUCCESS, moab::BSPTree::moab(), mStack, and tool().
Referenced by moab::BSPTree::leaf_containing_point().
    childVect.clear();
    ErrorCode rval = tool()->moab()->get_child_meshsets( mStack.back(), childVect );
    if( childVect.empty() ) return MB_ENTITY_NOT_FOUND;
    mStack.push_back( childVect[dir] );
    return MB_SUCCESS;
Definition at line 460 of file BSPTree.cpp.
References moab::BSPTree::get_split_plane(), MB_ENTITY_NOT_FOUND, mStack, and tool().
Referenced by test_box_iterator(), test_box_tree_create(), test_iterator(), test_leaf_containing_point_bounded_tree(), test_leaf_containing_point_unbounded_tree(), test_merge_leaf(), and test_tree_create().
    if( mStack.size() < 2 )  // at tree root
    EntityHandle parent = mStack[mStack.size() - 2];
    return tool()->get_split_plane( parent, plane );
ErrorCode moab::BSPTreeIter::initialize ( BSPTree tool,
EntityHandle  root,
const double *  point = 0
Definition at line 374 of file BSPTree.cpp.
References MB_SUCCESS, mStack, and treeTool.
Referenced by moab::BSPTree::get_tree_end_iterator(), moab::BSPTree::get_tree_iterator(), and moab::BSPTree::leaf_containing_point().
    treeTool = btool;
    mStack.clear();
    mStack.push_back( root );
    return MB_SUCCESS;
bool moab::BSPTreeIter::intersect_ray ( const double  ray_point[3],
double &  t_enter,
double &  t_exit
) const [virtual]
Find range of overlap between ray and leaf.
Parameters:
ray_pointCoordinates of start point of ray
ray_vectDirectionion vector for ray such that the ray is defined by r(t) = ray_point + t * ray_vect for t > 0.
t_enterOutput: if return value is true, this value is the parameter location along the ray at which the ray entered the leaf. If return value is false, then this value is undefined.
t_exitOutput: if return value is true, this value is the parameter location along the ray at which the ray exited the leaf. If return value is false, then this value is undefined.
Returns:
true if ray intersects leaf, false otherwise.
Definition at line 1338 of file BSPTree.cpp.
References ErrorCode, moab::BSPTree::get_tree_box(), MB_SUCCESS, mStack, moab::ray_intersect_halfspaces(), and tool().
Referenced by test_leaf_intersects_ray_common().
    // intersect with half-spaces defining tree
    BSPTreePlaneIter iter1( tool(), &mStack[0], mStack.size() ), end1;
    if( !ray_intersect_halfspaces( CartVect( ray_point ), CartVect( ray_vect ), iter1, end1, t_enter, t_exit ) )
        return false;
    // itersect with box bounding entire tree
    double corners[8][3];
    ErrorCode rval = tool()->get_tree_box( mStack.front(), corners );
        assert( false );
        return false;
    BoxPlaneIter iter2( corners ), end2;
    double t2_enter, t2_exit;
    if( !ray_intersect_halfspaces( CartVect( ray_point ), CartVect( ray_vect ), iter2, end2, t2_enter, t2_exit ) )
        return false;
    // if intersect both box and halfspaces, check that
    // two intersections overlap
    if( t_enter < t2_enter ) t_enter = t2_enter;
    if( t_exit > t2_exit ) t_exit = t2_exit;
    return t_enter <= t_exit;
bool moab::BSPTreeIter::is_sibling ( const BSPTreeIter other_leaf) const
Return true if thos node and the passed node share the same immediate parent.
Definition at line 476 of file BSPTree.cpp.
References handle(), and mStack.
    const size_t s = mStack.size();
    return ( s > 1 ) && ( s == other_leaf.mStack.size() ) && ( other_leaf.mStack[s - 2] == mStack[s - 2] ) &&
           other_leaf.handle() != handle();
bool moab::BSPTreeIter::is_sibling ( EntityHandle  other_leaf) const
Definition at line 483 of file BSPTree.cpp.
References childVect, ErrorCode, moab::Interface::get_child_meshsets(), handle(), MB_SUCCESS, moab::BSPTree::moab(), mStack, and tool().
    if( mStack.size() < 2 || other_leaf == handle() ) return false;
    childVect.clear();
    ErrorCode rval = tool()->moab()->get_child_meshsets( parent, childVect );
    if( MB_SUCCESS != rval || childVect.size() != 2 )
        assert( false );
        return false;
    return childVect[0] == other_leaf || childVect[1] == other_leaf;
Returns true if calling step() will advance to the immediate sibling of the current node. Returns false if current node is root or back() will move to the immediate sibling.
Definition at line 497 of file BSPTree.cpp.
    if( mStack.size() < 2 )  // if root
        return false;
    childVect.clear();
        assert( false );
        return false;
    return childVect[0] == handle();
ErrorCode moab::BSPTreeIter::step ( Direction  direction) [virtual]
Advance the iterator either left or right in the tree Note: stepping past the end of the tree will invalidate the iterator. It will *not* be work step the other direction.
Definition at line 398 of file BSPTree.cpp.
References childVect, ErrorCode, moab::Interface::get_child_meshsets(), MB_ENTITY_NOT_FOUND, MB_SUCCESS, moab::BSPTree::moab(), mStack, step_to_first_leaf(), and tool().
Referenced by build_tree(), test_iterator(), test_leaf_containing_point_bounded_tree(), test_leaf_containing_point_unbounded_tree(), test_leaf_intersects_ray_common(), test_leaf_polyhedron(), test_leaf_volume(), and test_tree_create().
    EntityHandle node, parent;
    ErrorCode rval;
    const Direction opposite = static_cast< Direction >( 1 - direction );
    // If stack is empty, then either this iterator is uninitialized
    // or we reached the end of the iteration (and return
    // MB_ENTITY_NOT_FOUND) already.
    if( mStack.empty() ) return MB_FAILURE;
    // Pop the current node from the stack.
    // The stack should then contain the parent of the current node.
    // If the stack is empty after this pop, then we've reached the end.
    node = mStack.back();
    mStack.pop_back();
    while( !mStack.empty() )
        // Get data for parent entity
        parent = mStack.back();
        childVect.clear();
        // If we're at the left child
        if( childVect[opposite] == node )
            // push right child on stack
            mStack.push_back( childVect[direction] );
            // descend to left-most leaf of the right child
            return step_to_first_leaf( opposite );
        // The current node is the right child of the parent,
        // continue up the tree.
        assert( childVect[direction] == node );
        node = parent;
        mStack.pop_back();
Advance to next leaf Returns MB_ENTITY_NOT_FOUND if at end. Note: stepping past the end of the tree will invalidate the iterator. Calling back() will not work.
Definition at line 308 of file BSPTree.hpp.
References RIGHT.
Referenced by back().
        return step( RIGHT );
ErrorCode moab::BSPTreeIter::step_to_first_leaf ( Direction  direction) [protected, virtual]
Definition at line 382 of file BSPTree.cpp.
References childVect, ErrorCode, moab::Interface::get_child_meshsets(), MB_SUCCESS, moab::BSPTree::moab(), mStack, and tool().
Referenced by moab::BSPTree::get_tree_end_iterator(), moab::BSPTree::get_tree_iterator(), moab::BSPTree::split_leaf(), and step().
    ErrorCode rval;
    for( ;; )
        childVect.clear();
        if( childVect.empty() )  // leaf
            break;
    return MB_SUCCESS;
ErrorCode moab::BSPTreeIter::up ( ) [protected, virtual]
Definition at line 442 of file BSPTree.cpp.
References MB_ENTITY_NOT_FOUND, MB_SUCCESS, and mStack.
Referenced by moab::BSPTree::merge_leaf().
    if( mStack.size() < 2 ) return MB_ENTITY_NOT_FOUND;
    mStack.pop_back();
    return MB_SUCCESS;
double moab::BSPTreeIter::volume ( ) const [virtual]
Definition at line 469 of file BSPTree.cpp.
References calculate_polyhedron(), ErrorCode, MB_SUCCESS, and moab::BSPTreePoly::volume().
Referenced by test_leaf_volume().
    BSPTreePoly polyhedron;
    ErrorCode rval = calculate_polyhedron( polyhedron );
    return MB_SUCCESS == rval ? polyhedron.volume() : -1.0;
Friends And Related Function Documentation
friend class BSPTree [friend]
Definition at line 262 of file BSPTree.hpp.
Member Data Documentation
Definition at line 264 of file BSPTree.hpp.
Referenced by calculate_polyhedron(), initialize(), and tool().
List of all members.
