moab::CN Class Reference
Canonical numbering data and functions This class represents canonical ordering of finite-element meshes. Elements in the finite element "zoo" are represented. Canonical numbering denotes the vertex, edge, and face numbers making up each kind of element, and the vertex numbers defining those entities. Functions for evaluating adjacencies and other things based on vertex numbering are also provided. By default, this class defines a zero-based numbering system. For a complete description of this class, see the document "MOAB Canonical Numbering Conventions", Timothy J. Tautges, Sandia National Laboratories Report #SAND2004-xxxx. More...
#include <CN.hpp>
+ Collaboration diagram for moab::CN:
Classes
struct  ConnMap
struct  UpConnMap
Public Types
enum  { MAX_NODES_PER_ELEMENT = 27 }
enum  { MID_EDGE_BIT = 1 << 1, MID_FACE_BIT = 1 << 2, MID_REGION_BIT = 1 << 3 }
enum  { INTERSECT = 0, UNION }
 enum used to specify operation type More...
Static Public Member Functions
static DimensionPair getDimPair (int entity_type)
 Get the dimension pair corresponding to a dimension.
static short int GetBasis ()
 get the basis of the numbering system
static void SetBasis (const int in_basis)
 set the basis of the numbering system
static const char * EntityTypeName (const EntityType this_type)
 return the string type name for this type
static EntityType EntityTypeFromName (const char *name)
 given a name, find the corresponding entity type
static short int Dimension (const EntityType t)
 return the topological entity dimension
static short int VerticesPerEntity (const EntityType t)
 return the number of (corner) vertices contained in the specified type.
static short int NumSubEntities (const EntityType t, const int d)
 return the number of sub-entities bounding the entity.
static EntityType SubEntityType (const EntityType this_type, const int sub_dimension, const int index)
 return the type of a particular sub-entity.
static void SubEntityVertexIndices (const EntityType this_type, const int sub_dimension, const int sub_index, int sub_entity_conn[])
 return the connectivity of the specified sub-entity.
static const short * SubEntityVertexIndices (const EntityType this_type, const int sub_dimension, const int sub_index, EntityType &sub_type, int &num_sub_ent_vertices)
static void SubEntityNodeIndices (const EntityType this_topo, const int num_nodes, const int sub_dimension, const int sub_index, EntityType &sub_entity_topo, int &num_sub_entity_nodes, int sub_entity_conn[])
static void SubEntityConn (const void *parent_conn, const EntityType parent_type, const int sub_dimension, const int sub_index, void *sub_entity_conn, int &num_sub_vertices)
static short int AdjacentSubEntities (const EntityType this_type, const int *source_indices, const int num_source_indices, const int source_dim, const int target_dim, std::vector< int > &index_list, const int operation_type=CN::INTERSECT)
 given an entity and a target dimension & side number, get that entity
static short int SideNumber (const EntityType parent_type, const int *parent_conn, const int *child_conn, const int child_num_verts, const int child_dim, int &side_number, int &sense, int &offset)
static short int SideNumber (const EntityType parent_type, const unsigned int *parent_conn, const unsigned int *child_conn, const int child_num_verts, const int child_dim, int &side_number, int &sense, int &offset)
static short int SideNumber (const EntityType parent_type, const long *parent_conn, const long *child_conn, const int child_num_verts, const int child_dim, int &side_number, int &sense, int &offset)
static short int SideNumber (const EntityType parent_type, const unsigned long *parent_conn, const unsigned long *child_conn, const int child_num_verts, const int child_dim, int &side_number, int &sense, int &offset)
static short int SideNumber (const EntityType parent_type, const unsigned long long *parent_conn, const unsigned long long *child_conn, const int child_num_verts, const int child_dim, int &side_number, int &sense, int &offset)
static short int SideNumber (const EntityType parent_type, void *const *parent_conn, void *const *child_conn, const int child_num_verts, const int child_dim, int &side_number, int &sense, int &offset)
static short int SideNumber (const EntityType parent_type, const int *child_conn_indices, const int child_num_verts, const int child_dim, int &side_number, int &sense, int &offset)
static short int OppositeSide (const EntityType parent_type, const int child_index, const int child_dim, int &opposite_index, int &opposite_dim)
static bool ConnectivityMatch (const int *conn1, const int *conn2, const int num_vertices, int &direct, int &offset)
static bool ConnectivityMatch (const unsigned int *conn1, const unsigned int *conn2, const int num_vertices, int &direct, int &offset)
static bool ConnectivityMatch (const long *conn1, const long *conn2, const int num_vertices, int &direct, int &offset)
static bool ConnectivityMatch (const unsigned long *conn1, const unsigned long *conn2, const int num_vertices, int &direct, int &offset)
static bool ConnectivityMatch (const unsigned long long *conn1, const unsigned long long *conn2, const int num_vertices, int &direct, int &offset)
static bool ConnectivityMatch (void *const *conn1, void *const *conn2, const int num_vertices, int &direct, int &offset)
static void setPermutation (const EntityType t, const int dim, short int *pvec, const int num_entries, const bool is_reverse=false)
 Set permutation or reverse permutation vector.
static void resetPermutation (const EntityType t, const int dim)
 Reset permutation or reverse permutation vector.
static int permuteThis (const EntityType t, const int dim, int *pvec, const int indices_per_ent, const int num_entries)
 Permute this vector.
static int permuteThis (const EntityType t, const int dim, unsigned int *pvec, const int indices_per_ent, const int num_entries)
static int permuteThis (const EntityType t, const int dim, long *pvec, const int indices_per_ent, const int num_entries)
static int permuteThis (const EntityType t, const int dim, void **pvec, const int indices_per_ent, const int num_entries)
static int revPermuteThis (const EntityType t, const int dim, int *pvec, const int indices_per_ent, const int num_entries)
 Reverse permute this vector.
static int revPermuteThis (const EntityType t, const int dim, unsigned int *pvec, const int indices_per_ent, const int num_entries)
static int revPermuteThis (const EntityType t, const int dim, long *pvec, const int indices_per_ent, const int num_entries)
static int revPermuteThis (const EntityType t, const int dim, void **pvec, const int indices_per_ent, const int num_entries)
static bool HasMidEdgeNodes (const EntityType this_type, const int num_verts)
static bool HasMidFaceNodes (const EntityType this_type, const int num_verts)
static bool HasMidRegionNodes (const EntityType this_type, const int num_verts)
static void HasMidNodes (const EntityType this_type, const int num_verts, int mid_nodes[4])
static int HasMidNodes (const EntityType this_type, const int num_verts)
static void HONodeParent (EntityType elem_type, int num_nodes, int ho_node_index, int &parent_dim, int &parent_index)
static short int HONodeIndex (const EntityType this_type, const int num_verts, const int subfacet_dim, const int subfacet_index)
Static Public Attributes
static MOAB_EXPORT const ConnMap mConnectivityMap [MBMAXTYPE][3]
static const UpConnMap mUpConnMap [MBMAXTYPE][4][4]
unsigned char
midNodesPerType [MBMAXTYPE][MAX_NODES_PER_ELEMENT+1]
static short int permuteVec [MBMAXTYPE][3][MAX_SUB_ENTITIES+1]
 Permutation and reverse permutation vectors.
static short int revPermuteVec [MBMAXTYPE][3][MAX_SUB_ENTITIES+1]
DimensionPair
TypeDimensionMap []
Private Member Functions
 CN ()
 declare private constructor, since we don't want to create any of these
Static Private Member Functions
static void SwitchBasis (const int old_basis, const int new_basis)
 switch the basis
Static Private Attributes
static MOAB_EXPORT const char * entityTypeNames []
 entity names
static MOAB_EXPORT short int numberBasis = 0
 the basis of the numbering system (normally 0 or 1, 0 by default)
static MOAB_EXPORT short increasingInts []
Detailed Description
MOAB, a Mesh-Oriented datABase, is a software component for creating, storing and accessing finite element mesh data.
Copyright 2004 Sandia Corporation. Under the terms of Contract DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government retains certain rights in this software.
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version.
Author:
Tim Tautges
Date:
April 2004
Definition at line 56 of file CN.hpp.
Member Enumeration Documentation
anonymous enum
Enumerator:
Definition at line 74 of file CN.hpp.
anonymous enum
Enumerator:
MID_EDGE_BIT
MID_FACE_BIT
MID_REGION_BIT
Definition at line 78 of file CN.hpp.
anonymous enum
Enumerator:
INTERSECT
UNION
Definition at line 86 of file CN.hpp.
        INTERSECT = 0,
        UNION
moab::CN::CN ( ) [private]
Member Function Documentation
short int moab::CN::AdjacentSubEntities ( const EntityType  this_type,
const int *  source_indices,
std::vector< int > &  index_list,
const int  operation_type = CN::INTERSECT
) [static]
For a specified set of sides of given dimension, return the intersection or union of all sides of specified target dimension adjacent to those sides.
Parameters:
this_typeType of entity for which sub-entity connectivity is being queried
source_indicesIndices of sides being queried
num_source_indicesNumber of entries in source_indices
source_dimDimension of source entity
target_dimDimension of target entity
index_listIndices of target entities (returned)
operation_typeSpecify either CN::INTERSECT or CN::UNION to get intersection or union of target entity lists over source entities
Definition at line 138 of file CN.cpp.
References moab::CN::ConnMap::conn, Dimension(), mConnectivityMap, MUC, moab::CN::ConnMap::num_corners_per_sub_element, and UNION.
Referenced by moab::AEntityFactory::get_down_adjacency_elements(), and moab::Core::side_element().
    // first get all the vertex indices
    std::vector< int > tmp_indices;
    const int* it1 = source_indices;
    assert( source_dim <= 3 && target_dim >= 0 && target_dim <= 3 &&
            // make sure we're not stepping off the end of the array;
            ( ( source_dim > 0 && *it1 < mConnectivityMap[this_type][source_dim - 1].num_sub_elements ) ||
              ( source_dim == 0 &&
                *it1 < mConnectivityMap[this_type][Dimension( this_type ) - 1].num_corners_per_sub_element[0] ) ) &&
            *it1 >= 0 );
#define MUC CN::mUpConnMap[this_type][source_dim][target_dim]
    // if we're looking for the vertices of a single side, return them in
    // the canonical ordering; otherwise, return them in sorted order
    if( num_source_indices == 1 && 0 == target_dim && source_dim != target_dim )
        // element of mConnectivityMap should be for this type and for one
        // less than source_dim, which should give the connectivity of that sub element
        const ConnMap& cm = mConnectivityMap[this_type][source_dim - 1];
        std::copy( cm.conn[source_indices[0]],
                   cm.conn[source_indices[0]] + cm.num_corners_per_sub_element[source_indices[0]],
                   std::back_inserter( index_list ) );
        return 0;
    // now go through source indices, folding adjacencies into target list
    for( it1 = source_indices; it1 != source_indices + num_source_indices; it1++ )
        // *it1 is the side index
        // at start of iteration, index_list has the target list
        // if a union, or first iteration and index list was empty, copy the list
        if( operation_type == CN::UNION || ( it1 == source_indices && index_list.empty() ) )
            std::copy( MUC.targets_per_source_element[*it1],
                       MUC.targets_per_source_element[*it1] + MUC.num_targets_per_source_element[*it1],
        else
            // else we're intersecting, and have a non-empty list; intersect with this target list
            tmp_indices.clear();
            for( int i = MUC.num_targets_per_source_element[*it1] - 1; i >= 0; i-- )
                if( std::find( index_list.begin(), index_list.end(), MUC.targets_per_source_element[*it1][i] ) !=
                    index_list.end() )
                    tmp_indices.push_back( MUC.targets_per_source_element[*it1][i] );
            //      std::set_intersection(MUC.targets_per_source_element[*it1],
            //                            MUC.targets_per_source_element[*it1]+
            //                            MUC.num_targets_per_source_element[*it1],
            //                            index_list.begin(), index_list.end(),
            //                            std::back_inserter(tmp_indices));
            index_list.swap( tmp_indices );
            // if we're at this point and the list is empty, the intersection will be NULL;
            // return if so
            if( index_list.empty() ) return 0;
    if( operation_type == CN::UNION && num_source_indices != 1 )
        // need to sort then unique the list
        std::sort( index_list.begin(), index_list.end() );
        index_list.erase( std::unique( index_list.begin(), index_list.end() ), index_list.end() );
    return 0;
bool moab::CN::ConnectivityMatch ( const int *  conn1,
const int *  conn2,
int &  direct,
int &  offset
) [static]
given two connectivity arrays, determine whether or not they represent the same entity.
Parameters:
conn1Connectivity array of first entity
conn2Connectivity array of second entity
num_verticesNumber of entries in conn1 and conn2
directIf positive, entities have the same sense (returned)
offsetOffset of conn2's first vertex in conn1
Returns:
bool Returns true if conn1 and conn2 match
Definition at line 540 of file CN.cpp.
Referenced by moab::HalfFacetRep::get_down_adjacencies_face_3d(), moab::Core::merge_entities(), moab::Core::side_number(), and SideNumber().
    return connectivity_match< int >( conn1_i, conn2_i, num_vertices, direct, offset );
bool moab::CN::ConnectivityMatch ( const unsigned int *  conn1,
const unsigned int *  conn2,
int &  direct,
int &  offset
) [static]
Definition at line 545 of file CN.cpp.
    return connectivity_match< unsigned int >( conn1_i, conn2_i, num_vertices, direct, offset );
bool moab::CN::ConnectivityMatch ( const long *  conn1,
const long *  conn2,
int &  direct,
int &  offset
) [static]
Definition at line 554 of file CN.cpp.
    return connectivity_match< long >( conn1_i, conn2_i, num_vertices, direct, offset );
bool moab::CN::ConnectivityMatch ( const unsigned long *  conn1,
const unsigned long *  conn2,
int &  direct,
int &  offset
) [static]
Definition at line 559 of file CN.cpp.
    return connectivity_match< unsigned long >( conn1_i, conn2_i, num_vertices, direct, offset );
bool moab::CN::ConnectivityMatch ( const unsigned long long *  conn1,
const unsigned long long *  conn2,
int &  direct,
int &  offset
) [static]
Definition at line 568 of file CN.cpp.
    return connectivity_match< unsigned long long >( conn1_i, conn2_i, num_vertices, direct, offset );
bool moab::CN::ConnectivityMatch ( void *const *  conn1,
void *const *  conn2,
int &  direct,
int &  offset
) [static]
Definition at line 577 of file CN.cpp.
    return connectivity_match< void* >( conn1_i, conn2_i, num_vertices, direct, offset );
short int moab::CN::Dimension ( const EntityType  t) [static]
Definition at line 1066 of file CN.cpp.
References mConnectivityMap, t, and moab::CN::ConnMap::topo_dimension.
Referenced by AdjacentSubEntities(), moab::Range::all_of_dimension(), moab::SweptElementData::calc_num_entities(), moab::ScdElementData::calc_num_entities(), check_adj_ho_nodes(), check_ho_element(), check_parallel_read(), check_set_contents(), check_type(), moab::Skinner::classify_2d_boundary(), moab::DualTool::construct_dual_cells(), moab::DualTool::construct_dual_edges(), moab::DualTool::construct_dual_faces(), moab::DualTool::construct_dual_vertices(), moab::HigherOrderFactory::convert_sequence(), moab::SpectralMeshTool::convert_to_coarse(), moab::HigherOrderFactory::copy_mid_face_nodes(), moab::SequenceManager::create_scd_sequence(), moab::ReadGmsh::create_sets(), moab::Skinner::create_side(), moab::ReadNCDF::create_sideset_element(), moab::SequenceManager::create_sweep_sequence(), moab::MeshSet::DIM_FROM_HANDLE(), moab::Core::dimension_from_handle(), moab::Skinner::face_reversed(), moab::ParallelComm::find_existing_entity(), moab::Skinner::find_skin_noadj(), moab::Skinner::find_skin_vertices(), moab::WriteTemplate::gather_mesh_information(), moab::WriteSLAC::gather_mesh_information(), moab::WriteNCDF::gather_mesh_information(), moab::AEntityFactory::get_adjacencies(), moab::get_adjacencies_intersection(), moab::get_adjacencies_union(), moab::MeshTopoUtil::get_bridge_adjacencies(), moab::AEntityFactory::get_element(), moab::AEntityFactory::get_elements(), moab::WriteTemplate::get_neuset_elems(), moab::WriteSLAC::get_neuset_elems(), moab::WriteCCMIO::get_neuset_elems(), moab::VectorSetIterator::get_next_arr(), moab::RangeSetIterator::get_next_by_dimension(), moab::ReadUtil::get_ordered_vertices(), moab::SweptElementData::get_params_connectivity(), moab::ScdElementData::get_params_connectivity(), moab::WriteNCDF::get_sideset_elems(), moab::AEntityFactory::get_up_adjacency_elements(), moab::WriteTemplate::get_valid_sides(), moab::WriteSLAC::get_valid_sides(), moab::WriteNCDF::get_valid_sides(), moab::Core::high_order_node(), HONodeParent(), moab::WriteHDF5::initialize_mesh(), moab::Core::list_entity(), moab::ReadHDF5::load_file_partial(), moab::AEntityFactory::merge_adjust_adjacencies(), moab::Core::merge_entities(), moab::Range::num_of_dimension(), orient_faces_outward(), moab::Tqdcfr::read_block(), moab::Tqdcfr::read_elements(), moab::Tqdcfr::GeomHeader::read_info_header(), moab::AEntityFactory::remove_all_adjacencies(), moab::HigherOrderFactory::remove_mid_face_nodes(), moab::Core::side_number(), SideNumber(), moab::MeshTopoUtil::split_entities_manifold(), moab::ExoIIUtil::static_get_element_type(), SubEntityType(), test_dimension(), test_has_mid_nodes(), test_ho_node_index(), test_ho_node_parent(), test_read_side(), test_sub_entity_nodes(), moab::ReadNCDF::update(), TreeValidator::visit(), and moab::HigherOrderFactory::zero_mid_face_nodes().
EntityType moab::CN::EntityTypeFromName ( const char *  name) [static]
return a type for the given name
Definition at line 56 of file CN.cpp.
References entityTypeNames, MBMAXTYPE, and MBVERTEX.
Referenced by moab::ReadHDF5::load_file_impl(), moab::ReadHDF5::load_file_partial(), moab::ReadHDF5::read_elems(), moab::ReadHDF5::read_node_adj_elems(), moab::ReadHDF5::read_poly(), and test_type_names().
    for( EntityType i = MBVERTEX; i < MBMAXTYPE; i++ )
        if( 0 == strcmp( name, entityTypeNames[i] ) ) return i;
    return MBMAXTYPE;
const char * moab::CN::EntityTypeName ( const EntityType  this_type) [static]
Examples:
GetEntities.cpp, and StructuredMeshSimple.cpp.
Definition at line 666 of file CN.cpp.
References entityTypeNames.
Referenced by moab::WriteHDF5::assign_ids(), moab::Core::check_adjacencies(), check_sets_sizes(), compare_sets(), moab::ReadCCMIO::create_cell_from_faces(), moab::ParallelComm::create_interface_sets(), moab::ent_not_found(), moab::WriteHDF5Parallel::exchange_file_ids(), moab::WriteSLAC::gather_interior_exterior(), moab::Tqdcfr::get_mesh_entities(), moab::DualTool::list_entities(), moab::Core::list_entities(), moab::Core::list_entity(), moab::DebugOutput::list_range_real(), main(), moab::WriteHDF5::ExportSet::name(), moab::WriteHDF5Parallel::negotiate_type_list(), moab::not_found(), moab::not_root_set(), moab::operator<<(), moab::ParallelComm::pack_entities(), moab::ParallelComm::pack_entity_seq(), moab::WriteHDF5Parallel::parallel_create_file(), moab::ParallelComm::print_buffer(), moab::TreeNodePrinter::print_contents(), moab::TreeNodePrinter::print_counts(), moab::Core::print_database(), print_handles(), moab::WriteHDF5::print_id_map(), print_memory_stats(), print_stats(), print_tag_counts(), moab::Tqdcfr::read_elements(), moab::WriteHDF5::serial_create_file(), moab::Range::str_rep(), test_type_names(), test_write_elements(), moab::ParallelComm::unpack_entities(), moab::ParallelComm::update_remote_data(), moab::ParallelComm::update_remote_data_old(), moab::WriteVtk::write_elems(), moab::WriteHDF5::write_elems(), and moab::WriteGmsh::write_file().
    return entityTypeNames[this_type];
short int moab::CN::GetBasis ( ) [inline, static]
Definition at line 532 of file CN.hpp.
References numberBasis.
    return numberBasis;
DimensionPair moab::CN::getDimPair ( int  entity_type) [static]
Definition at line 50 of file CN.cpp.
References TypeDimensionMap.
Referenced by iMeshP_pushTags().
    return TypeDimensionMap[entity_type];
bool moab::CN::HasMidEdgeNodes ( const EntityType  this_type,
const int  num_verts
) [inline, static]
true if entities of a given type and number of nodes indicates mid edge nodes are present.
Parameters:
num_vertsNumber of nodes defining entity
Returns:
bool Returns true if this_type combined with num_nodes indicates mid-edge nodes are likely
Definition at line 549 of file CN.hpp.
References HasMidNodes().
Referenced by moab::HigherOrderFactory::center_node_exist(), moab::Skinner::find_skin_vertices_2D(), moab::ElementSequence::has_mid_edge_nodes(), and test_has_mid_nodes().
    const int bits = HasMidNodes( this_type, num_nodes );
    return static_cast< bool >( ( bits & ( 1 << 1 ) ) >> 1 );
bool moab::CN::HasMidFaceNodes ( const EntityType  this_type,
const int  num_verts
) [inline, static]
true if entities of a given type and number of nodes indicates mid face nodes are present.
Parameters:
Returns:
bool Returns true if this_type combined with num_nodes indicates mid-face nodes are likely
Definition at line 555 of file CN.hpp.
Referenced by moab::HigherOrderFactory::center_node_exist(), moab::ElementSequence::has_mid_face_nodes(), and test_has_mid_nodes().
    return static_cast< bool >( ( bits & ( 1 << 2 ) ) >> 2 );
void moab::CN::HasMidNodes ( const EntityType  this_type,
int  mid_nodes[4]
) [inline, static]
true if entities of a given type and number of nodes indicates mid edge/face/region nodes are present.
Parameters:
mid_nodesIf mid_nodes[i], i=1..2 is non-zero, indicates that mid-edge (i=1), mid-face (i=2), and/or mid-region (i=3) nodes are likely
Definition at line 573 of file CN.hpp.
Referenced by check_adj_ho_nodes(), check_type(), moab::Skinner::find_skin_vertices_3D(), moab::AEntityFactory::get_down_adjacency_elements(), HasMidEdgeNodes(), HasMidFaceNodes(), HasMidRegionNodes(), moab::Core::high_order_node(), HONodeIndex(), HONodeParent(), moab::ReadNCDF::read_elements(), moab::Tqdcfr::BlockHeader::read_info_header(), SubEntityNodeIndices(), test_has_mid_nodes(), test_ho_elements(), test_read_side(), test_sub_entity_nodes(), and moab::WriteCCMIO::write_cells_and_faces().
    mid_nodes[0]   = 0;
    mid_nodes[1]   = ( bits & ( 1 << 1 ) ) >> 1;
    mid_nodes[2]   = ( bits & ( 1 << 2 ) ) >> 2;
    mid_nodes[3]   = ( bits & ( 1 << 3 ) ) >> 3;
int moab::CN::HasMidNodes ( const EntityType  this_type,
const int  num_verts
) [inline, static]
Same as above, except returns a single integer with the bits, from least significant to most significant set to one if the corresponding mid nodes on sub entities of the least dimension (0) to the highest dimension (3) are present in the elment type.
Definition at line 567 of file CN.hpp.
References MAX_NODES_PER_ELEMENT, and midNodesPerType.
    assert( (unsigned)num_nodes <= (unsigned)MAX_NODES_PER_ELEMENT );
    return midNodesPerType[this_type][num_nodes];
bool moab::CN::HasMidRegionNodes ( const EntityType  this_type,
const int  num_verts
) [inline, static]
true if entities of a given type and number of nodes indicates mid region nodes are present.
Parameters:
Returns:
bool Returns true if this_type combined with num_nodes indicates mid-region nodes are likely
Definition at line 561 of file CN.hpp.
Referenced by moab::ElementSequence::has_mid_volume_nodes(), and test_has_mid_nodes().
    return static_cast< bool >( ( bits & ( 1 << 3 ) ) >> 3 );
short int moab::CN::HONodeIndex ( const EntityType  this_type,
) [static]
for an entity of this type with num_verts vertices, and a specified subfacet (dimension and index), return the index of the higher order node for that entity in this entity's connectivity array
Parameters:
this_typeType of entity being queried
num_vertsNumber of vertices for the entity being queried
subfacet_dimDimension of sub-entity being queried
subfacet_indexIndex of sub-entity being queried
Returns:
index Index of sub-entity's higher-order node
for an entity of this type and a specified subfacet (dimension and index), return the index of the higher order node for that entity in this entity's connectivity array
Definition at line 588 of file CN.cpp.
References HasMidNodes(), numberBasis, NumSubEntities(), and VerticesPerEntity().
Referenced by check_adj_ho_nodes(), moab::Skinner::find_skin_vertices_2D(), moab::AEntityFactory::get_down_adjacency_elements(), SubEntityNodeIndices(), test_ho_node_index(), and test_sub_entity_nodes().
    int i;
    int has_mids[4];
    HasMidNodes( this_type, num_verts, has_mids );
    // if we have no mid nodes on the subfacet_dim, we have no index
    if( subfacet_index != -1 && !has_mids[subfacet_dim] ) return -1;
    // put start index at last index (one less than the number of vertices
    // plus the index basis)
    int index = VerticesPerEntity( this_type ) - 1 + numberBasis;
    // for each subfacet dimension less than the target subfacet dim which has mid nodes,
    // add the number of subfacets of that dimension to the index
    for( i = 1; i < subfacet_dim; i++ )
        if( has_mids[i] ) index += NumSubEntities( this_type, i );
    // now add the index of this subfacet, or one if we're asking about the entity as a whole
    if( subfacet_index == -1 && has_mids[subfacet_dim] )
        // want the index of the last ho node on this subfacet
        index += NumSubEntities( this_type, subfacet_dim );
    else if( subfacet_index != -1 && has_mids[subfacet_dim] )
        index += subfacet_index + 1 - numberBasis;
    // that's it
    return index;
void moab::CN::HONodeParent ( EntityType  elem_type,
int  num_verts,
int  ho_index,
int &  parent_dim,
int &  parent_index
) [static]
given data about an element and a vertex in that element, return the dimension and index of the sub-entity that the vertex resolves. If it does not resolve a sub-entity, either because it's a corner node or it's not in the element, -1 is returned in both return values.
Parameters:
elem_typeType of entity being queried
num_nodesThe number of nodes in the element connectivity
ho_node_indexThe position of the HO node in the connectivity list (zero based)
parent_dimDimension of sub-entity high-order node resolves (returned)
parent_indexIndex of sub-entity high-order node resolves (returned)
Definition at line 625 of file CN.cpp.
References dim, Dimension(), HasMidNodes(), NumSubEntities(), and VerticesPerEntity().
Referenced by check_ho_element(), moab::HigherOrderFactory::tag_for_deletion(), and test_ho_node_parent().
    // begin with error values
    parent_dim = parent_index = -1;
    // given the number of verts and the element type, get the hasmidnodes solution
    int has_mids[4];
    HasMidNodes( elem_type, num_verts, has_mids );
    int index     = VerticesPerEntity( elem_type ) - 1;
    const int dim = Dimension( elem_type );
    // keep a running sum of the ho node indices for this type of element, and stop
    // when you get to the dimension which has the ho node
    for( int i = 1; i < dim; i++ )
        if( has_mids[i] )
            if( ho_index <= index + NumSubEntities( elem_type, i ) )
                // the ho_index resolves an entity of dimension i, so set the return values
                // and break out of the loop
                parent_dim   = i;
                parent_index = ho_index - index - 1;
                return;
            else
                index += NumSubEntities( elem_type, i );
    // mid region node case
    if( has_mids[dim] && ho_index == index + 1 )
        parent_dim   = dim;
        parent_index = 0;
short int moab::CN::NumSubEntities ( const EntityType  t,
const int  d
) [static]
short int moab::CN::OppositeSide ( const EntityType  parent_type,
int &  opposite_index,
int &  opposite_dim
) [static]
return the dimension and index of the opposite side, given parent entity type and child dimension and index. This function is only defined for certain types of parent/child types: (Parent, Child dim->Opposite dim): (Tri, 1->0), (Tri, 0->1), (Quad, 1->1), (Quad, 0->0), (Tet, 2->0), (Tet, 1->1), (Tet, 0->2), (Hex, 2->2), (Hex, 1->1)(diagonally across element), (Hex, 0->0) (diagonally across element) All other parent types and child dimensions return an error.
Parameters:
parent_typeThe type of parent element
child_typeThe type of child element
child_indexThe index of the child element
opposite_indexThe index of the opposite element
Returns:
status Returns 0 if successful, -1 if not
Definition at line 379 of file CN.cpp.
References MBEDGE, MBHEX, MBQUAD, MBTET, and MBTRI.
Referenced by moab::MeshTopoUtil::opposite_entity(), test_opposite_side_hex(), test_opposite_side_quad(), test_opposite_side_tet(), and test_opposite_side_tri().
    switch( parent_type )
        case MBEDGE:
            if( 0 != child_dim )
                return -1;
            else
                opposite_index = 1 - child_index;
            opposite_dim = 0;
            break;
        case MBTRI:
            switch( child_dim )
                case 0:
                    opposite_dim   = 1;
                    opposite_index = ( child_index + 1 ) % 3;
                    break;
                case 1:
                    opposite_dim   = 0;
                    opposite_index = ( child_index + 2 ) % 3;
                    break;
                default:
                    return -1;
            break;
        case MBQUAD:
            switch( child_dim )
                case 0:
                case 1:
                    opposite_dim   = child_dim;
                    opposite_index = ( child_index + 2 ) % 4;
                    break;
                default:
                    return -1;
            break;
        case MBTET:
            switch( child_dim )
                case 0:
                    opposite_dim   = 2;
                    opposite_index = ( child_index + 1 ) % 3 + 2 * ( child_index / 3 );
                    break;
                case 1:
                    opposite_dim   = 1;
                    opposite_index = child_index < 3 ? 3 + ( child_index + 2 ) % 3 : ( child_index + 1 ) % 3;
                    break;
                case 2:
                    opposite_dim   = 0;
                    opposite_index = ( child_index + 2 ) % 3 + child_index / 3;
                    break;
                default:
                    return -1;
            break;
        case MBHEX:
            switch( child_dim )
                case 0:
                    opposite_index = child_index < 4 ? 4 + ( child_index + 2 ) % 4 : ( child_index - 2 ) % 4;
                    break;
                case 1:
                    opposite_index = 4 * ( 2 - child_index / 4 ) + ( child_index + 2 ) % 4;
                    break;
                case 2:
                    opposite_index = child_index < 4 ? ( child_index + 2 ) % 4 : 9 - child_index;
                    break;
                default:
                    return -1;
            break;
        default:
            return -1;
    return 0;
int moab::CN::permuteThis ( const EntityType  t,
const int  dim,
int *  pvec,
) [inline, static]
Permute a handle array according to permutation vector set with setPermute; permutation is done in-place
Parameters:
tEntityType of handles in pvec
dimDimension of handles in pvec
pvecHandle array being permuted
indices_per_entNumber of indices per entity
num_entriesNumber of entities in pvec
Definition at line 1115 of file CN.cpp.
References moab::permute_this().
    return permute_this( t, dim, pvec, num_indices, num_entries );
const int  dim,
unsigned int *  pvec,
) [inline, static]
Definition at line 1119 of file CN.cpp.
const int  dim,
long *  pvec,
) [inline, static]
Definition at line 1127 of file CN.cpp.
const int  dim,
void **  pvec,
) [inline, static]
Definition at line 1135 of file CN.cpp.
void moab::CN::resetPermutation ( const EntityType  t,
const int  dim
) [inline, static]
Parameters:
tEntityType whose permutation vector is being reset
dimDimension of facets being reset; if -1 is input, all dimensions are reset
Definition at line 606 of file CN.hpp.
References dim, moab::MAX_SUB_ENTITIES, permuteVec, revPermuteVec, and t.
    if( -1 == dim )
        for( unsigned int i = 0; i < 3; i++ )
            resetPermutation( t, i );
        return;
    for( short unsigned int i = 0; i < MAX_SUB_ENTITIES; i++ )
        revPermuteVec[t][dim][i] = permuteVec[t][dim][i] = i;
    revPermuteVec[t][dim][MAX_SUB_ENTITIES] = permuteVec[t][dim][MAX_SUB_ENTITIES] = MAX_SUB_ENTITIES + 1;
int moab::CN::revPermuteThis ( const EntityType  t,
const int  dim,
int *  pvec,
) [inline, static]
Reverse permute a handle array according to reverse permutation vector set with setPermute; reverse permutation is done in-place
Parameters:
pvecHandle array being reverse permuted
Definition at line 1145 of file CN.cpp.
References moab::rev_permute_this().
    return rev_permute_this( t, dim, pvec, num_indices, num_entries );
const int  dim,
) [inline, static]
Definition at line 1153 of file CN.cpp.
const int  dim,
long *  pvec,
) [inline, static]
Definition at line 1161 of file CN.cpp.
const int  dim,
void **  pvec,
) [inline, static]
Definition at line 1169 of file CN.cpp.
void moab::CN::SetBasis ( const int  in_basis) [static]
set the basis of the numbering system; may or may not do things besides setting the member variable
Definition at line 44 of file CN.cpp.
    numberBasis = in_basis;
void moab::CN::setPermutation ( const EntityType  t,
const int  dim,
short int *  pvec,
const bool  is_reverse = false
) [inline, static]
Set permutation or reverse permutation vector Forward permutation is from CN's numbering into application's ordering; that is, if i is CN's index, pvec[i] is application's index. This function stores the permutation vector for this type and facet dimension, which then is used in calls to permuteThis or revPermuteThis.
Parameters:
tEntityType for which to set permutation
dimDimension of facets whose permutation array is being set
pvecPermutation array
num_entriesNumber of indicies in permutation array
is_reverseArray is reverse permutation
Definition at line 583 of file CN.hpp.
    short int *this_vec = permuteVec[t][dim], *that_vec = revPermuteVec[t][dim];
    if( is_reverse )
        this_vec = revPermuteVec[t][dim];
        that_vec = permuteVec[t][dim];
    for( short int i = 0; i < num_entries; i++ )
        this_vec[i]       = pvec[i];
        that_vec[pvec[i]] = i;
    this_vec[MAX_SUB_ENTITIES] = that_vec[MAX_SUB_ENTITIES] = (short)num_entries;
short int moab::CN::SideNumber ( const EntityType  parent_type,
const int *  parent_conn,
const int *  child_conn,
int &  side_number,
int &  sense,
int &  offset
) [static]
return the side index represented in the input sub-entity connectivity in the input parent entity connectivity array.
Parameters:
parent_connConnectivity of parent entity being queried
parent_typeEntity type of parent entity
child_connConnectivity of child whose index is being queried
child_num_vertsNumber of vertices in child_conn
child_dimDimension of child entity being queried
side_numberSide number of child entity (returned)
senseSense of child entity with respect to order in child_conn (returned)
offsetOffset of child_conn with respect to canonical ordering data (returned)
Returns:
status Returns zero if successful, -1 if not
Definition at line 240 of file CN.cpp.
References moab::side_number().
Referenced by moab::Skinner::create_side(), do_test_side_number_1d(), do_test_side_number_2d(), moab::Skinner::face_reversed(), moab::Skinner::find_skin_vertices_2D(), moab::Skinner::find_skin_vertices_3D(), moab::Core::high_order_node(), orient_faces_outward(), moab::GeomTopoTool::restore_topology_from_adjacency(), SphereDecomp::retrieve_subdiv_verts(), moab::side_number(), moab::Core::side_number(), SubEntityNodeIndices(), test_sub_entity_nodes(), and moab::WriteCCMIO::write_cells_and_faces().
    return side_number( parent_conn, parent_type, child_conn, child_num_verts, child_dim, side_no, sense, offset );
const unsigned int *  parent_conn,
const unsigned int *  child_conn,
int &  side_number,
int &  sense,
int &  offset
) [static]
Definition at line 252 of file CN.cpp.
const long *  parent_conn,
const long *  child_conn,
int &  side_number,
int &  sense,
int &  offset
) [static]
Definition at line 263 of file CN.cpp.
const unsigned long *  parent_conn,
const unsigned long *  child_conn,
int &  side_number,
int &  sense,
int &  offset
) [static]
Definition at line 274 of file CN.cpp.
const unsigned long long *  parent_conn,
const unsigned long long *  child_conn,
int &  side_number,
int &  sense,
int &  offset
) [static]
Definition at line 286 of file CN.cpp.
void *const *  parent_conn,
void *const *  child_conn,
int &  side_number,
int &  sense,
int &  offset
) [static]
Definition at line 299 of file CN.cpp.
const int *  child_conn_indices,
int &  side_number,
int &  sense,
int &  offset
) [static]
Parameters:
child_conn_indicesChild connectivity to query, specified as indices into the connectivity list of the parent.
child_num_vertsNumber of values in child_conn_indices
Returns:
Definition at line 311 of file CN.cpp.
References ConnectivityMatch(), Dimension(), NumSubEntities(), SubEntityType(), SubEntityVertexIndices(), and VerticesPerEntity().
    int parent_dim       = Dimension( parent_type );
    int parent_num_verts = VerticesPerEntity( parent_type );
    // degenerate case (vertex), output == input
    if( child_dim == 0 )
        if( child_num_verts != 1 ) return -1;
        side_no = *child_conn_indices;
        sense = offset = 0;
    // given a parent and child element, find the corresponding side number
    // dim_diff should be -1, 0 or 1 (same dimension, one less dimension, two less, resp.)
    if( child_dim > parent_dim || child_dim < 0 ) return -1;
    // different types of same dimension won't be the same
    if( parent_dim == child_dim && parent_num_verts != child_num_verts )
        side_no = -1;
        sense   = 0;
        return 0;
    // loop over the sub-elements, comparing to child connectivity
    int sub_conn_indices[10];
    for( int i = 0; i < NumSubEntities( parent_type, child_dim ); i++ )
        int sub_size = VerticesPerEntity( SubEntityType( parent_type, child_dim, i ) );
        if( sub_size != child_num_verts ) continue;
        SubEntityVertexIndices( parent_type, child_dim, i, sub_conn_indices );
        bool they_match = ConnectivityMatch( child_conn_indices, sub_conn_indices, sub_size, sense, offset );
        if( they_match )
            side_no = i;
            return 0;
    // if we've gotten here, we don't match
    side_no = -1;
    // return value is no success
    return 1;
void moab::CN::SubEntityConn ( const void *  parent_conn,
void *  sub_entity_conn,
int &  num_sub_vertices
) [static]
return the vertices of the specified sub entity
Parameters:
sub_dimensionDimension of sub-entity being queried
sub_indexIndex of sub-entity being queried
sub_entity_connConnectivity of sub-entity, based on parent_conn and canonical ordering for parent_type
num_sub_verticesNumber of vertices in sub-entity
Definition at line 119 of file CN.cpp.
References moab::MAX_SUB_ENTITY_VERTICES, SubEntityType(), SubEntityVertexIndices(), and VerticesPerEntity().
Referenced by moab::WriteCCMIO::write_cells_and_faces().
    static int sub_indices[MAX_SUB_ENTITY_VERTICES];
    SubEntityVertexIndices( parent_type, sub_dimension, sub_index, sub_indices );
    num_sub_vertices       = VerticesPerEntity( SubEntityType( parent_type, sub_dimension, sub_index ) );
    void** parent_conn_ptr = static_cast< void** >( const_cast< void* >( parent_conn ) );
    void** sub_conn_ptr    = static_cast< void** >( sub_entity_conn );
    for( int i = 0; i < num_sub_vertices; i++ )
        sub_conn_ptr[i] = parent_conn_ptr[sub_indices[i]];
void moab::CN::SubEntityNodeIndices ( const EntityType  this_topo,
EntityType &  sub_entity_topo,
int &  num_sub_entity_nodes,
) [static]
return the node indices of the specified sub-entity.
Parameters:
this_topoThe topology of the queried element type
num_nodesThe number of nodes in the queried element type.
sub_entity_topo(Output) Topology of requested sub-entity.
num_sub_entity_nodes(Output) Number of nodes in the requested sub-entity.
sub_entity_conn(Output) Connectivity of sub-entity
Definition at line 66 of file CN.cpp.
References moab::CN::ConnMap::conn, dim, HasMidNodes(), HONodeIndex(), moab::MAX_SUB_ENTITY_VERTICES, MBVERTEX, mConnectivityMap, NumSubEntities(), SideNumber(), SubEntityType(), SubEntityVertexIndices(), and VerticesPerEntity().
Referenced by moab::Skinner::classify_2d_boundary(), moab::Skinner::create_side(), moab::ReadNCDF::create_ss_elements(), moab::Skinner::find_skin_noadj(), moab::Skinner::find_skin_vertices_3D(), and test_sub_entity_nodes().
    // If asked for a node, the special case...
    if( sub_dimension == 0 )
        assert( sub_index < num_nodes );
        subentity_topo       = MBVERTEX;
        num_sub_entity_nodes = 1;
        sub_entity_conn[0]   = sub_index;
        return;
    const int ho_bits    = HasMidNodes( this_topo, num_nodes );
    subentity_topo       = SubEntityType( this_topo, sub_dimension, sub_index );
    num_sub_entity_nodes = VerticesPerEntity( subentity_topo );
    const short* corners = mConnectivityMap[this_topo][sub_dimension - 1].conn[sub_index];
    std::copy( corners, corners + num_sub_entity_nodes, sub_entity_conn );
    int sub_sub_corners[MAX_SUB_ENTITY_VERTICES];
    int side, sense, offset;
    for( int dim = 1; dim <= sub_dimension; ++dim )
        if( !( ho_bits & ( 1 << dim ) ) ) continue;
        const short num_mid = NumSubEntities( subentity_topo, dim );
        for( int i = 0; i < num_mid; ++i )
            const EntityType sub_sub_topo = SubEntityType( subentity_topo, dim, i );
            const int sub_sub_num_vert    = VerticesPerEntity( sub_sub_topo );
            SubEntityVertexIndices( subentity_topo, dim, i, sub_sub_corners );
            for( int j = 0; j < sub_sub_num_vert; ++j )
                sub_sub_corners[j] = corners[sub_sub_corners[j]];
            SideNumber( this_topo, sub_sub_corners, sub_sub_num_vert, dim, side, sense, offset );
            sub_entity_conn[num_sub_entity_nodes++] = HONodeIndex( this_topo, num_nodes, dim, side );
EntityType moab::CN::SubEntityType ( const EntityType  this_type,
const int  index
) [static]
Parameters:
this_typeType of entity for which sub-entity type is being queried
sub_dimensionTopological dimension of sub-entity whose type is being queried
indexIndex of sub-entity whose type is being queried
Returns:
type Entity type of sub-entity with specified dimension and index
Definition at line 1085 of file CN.cpp.
References Dimension(), MBVERTEX, and mConnectivityMap.
Referenced by moab::GeomUtil::box_linear_elem_overlap(), check_ho_element(), do_test_side_number_2d(), do_test_sub_entity_type_2d(), do_test_sub_entity_type_3d(), find_side(), moab::MeshTopoUtil::get_bridge_adjacencies(), SideNumber(), SubEntityConn(), SubEntityNodeIndices(), test_sub_entity_nodes(), test_sub_entity_type_edge(), and test_sub_entity_type_vtx().
    return ( !sub_dimension ? MBVERTEX
                            : ( Dimension( this_type ) == sub_dimension && 0 == index
                                    ? this_type
                                    : mConnectivityMap[this_type][sub_dimension - 1].target_type[index] ) );
void moab::CN::SubEntityVertexIndices ( const EntityType  this_type,
) [inline, static]
return the vertex indices of the specified sub-entity.
Parameters:
sub_entity_connConnectivity of sub-entity (returned to calling function)
Definition at line 538 of file CN.hpp.
Referenced by moab::GeomUtil::box_linear_elem_overlap(), check_ho_element(), moab::Skinner::classify_2d_boundary(), do_test_side_number_1d(), do_test_side_number_2d(), find_side(), moab::Skinner::find_skin_vertices_3D(), gather_set_stats(), moab::MeshTopoUtil::get_bridge_adjacencies(), moab::ReadUtil::get_ordered_vertices(), min_edge_length(), SideNumber(), SubEntityConn(), SubEntityNodeIndices(), test_0d_sub_entity_indices(), test_1d_sub_entity_indices(), test_2d_sub_entity_indices(), test_elem_as_sub_entity(), and test_sub_entity_nodes().
    EntityType type;
    int n;
    const short* indices = SubEntityVertexIndices( this_type, sub_dimension, index, type, n );
    std::copy( indices, indices + n, sub_entity_conn );
const short * moab::CN::SubEntityVertexIndices ( const EntityType  this_type,
EntityType &  sub_type,
int &  num_sub_ent_vertices
) [static]
Parameters:
num_sub_ent_verticesthe number of vertices in the sub-entity
Definition at line 1093 of file CN.cpp.
References moab::CN::ConnMap::conn, increasingInts, MBVERTEX, mConnectivityMap, moab::CN::ConnMap::num_corners_per_sub_element, and moab::CN::ConnMap::target_type.
        n        = 1;
        sub_type = MBVERTEX;
        return increasingInts + index;
    else
        const CN::ConnMap& map = mConnectivityMap[this_type][sub_dimension - 1];
        sub_type               = map.target_type[index];
        n                      = map.num_corners_per_sub_element[index];
        return map.conn[index];
static void moab::CN::SwitchBasis ( const int  old_basis,
const int  new_basis
) [static, private]
switch the basis
short int moab::CN::VerticesPerEntity ( const EntityType  t) [static]
Definition at line 1071 of file CN.cpp.
References MBVERTEX, and mConnectivityMap.
Referenced by moab::Skinner::add_adjacency(), moab::HigherOrderFactory::add_mid_edge_nodes(), moab::HigherOrderFactory::add_mid_face_nodes(), moab::HigherOrderFactory::add_mid_volume_nodes(), moab::GeomUtil::box_linear_elem_overlap(), moab::HigherOrderFactory::center_node_exist(), moab::AEntityFactory::check_equiv_entities(), check_ho_element(), moab::Skinner::classify_2d_boundary(), SphereDecomp::compute_nodes(), moab::HigherOrderFactory::convert_sequence(), moab::HigherOrderFactory::copy_corner_nodes(), moab::HigherOrderFactory::copy_mid_edge_nodes(), moab::HigherOrderFactory::copy_mid_face_nodes(), moab::HigherOrderFactory::copy_mid_volume_nodes(), moab::Core::create_element(), moab::ReadIDEAS::create_elements(), moab::Skinner::create_side(), moab::ReadNCDF::create_sideset_element(), do_test_side_number_2d(), do_test_sub_entity_type_2d(), do_test_sub_entity_type_3d(), moab::AEntityFactory::entities_equivalent(), moab::Skinner::face_reversed(), moab::Skinner::find_match(), find_side(), moab::Skinner::find_skin_noadj(), moab::Skinner::find_skin_vertices_3D(), moab::WriteVtk::gather_mesh(), moab::MeshTopoUtil::get_bridge_adjacencies(), moab::UnstructuredElemSeq::get_connectivity(), moab::Core::get_connectivity_by_type(), moab::ReadUtil::get_ordered_vertices(), moab::WriteNCDF::get_valid_sides(), moab::Core::high_order_node(), HONodeIndex(), HONodeParent(), moab::HigherOrderFactory::initialize_map(), moab::ReadSms::load_file_impl(), moab::WriteGMV::local_write_mesh(), NumSubEntities(), moab::Tqdcfr::read_block(), moab::ReadNASTRAN::read_element(), moab::Tqdcfr::BlockHeader::read_info_header(), moab::HigherOrderFactory::remove_mid_edge_nodes(), moab::HigherOrderFactory::remove_mid_face_nodes(), moab::HigherOrderFactory::remove_mid_volume_nodes(), moab::side_number(), SideNumber(), moab::ExoIIUtil::static_get_element_type(), SubEntityConn(), SubEntityNodeIndices(), test_has_mid_nodes(), test_ho_node_index(), test_ho_node_parent(), test_sub_entity_nodes(), test_vertices_per_entity(), moab::WriteVtk::write_elems(), moab::HigherOrderFactory::zero_mid_edge_nodes(), moab::HigherOrderFactory::zero_mid_face_nodes(), and moab::HigherOrderFactory::zero_mid_volume_nodes().
    return ( MBVERTEX == t
                 ? (short int)1
                 : mConnectivityMap[t][mConnectivityMap[t][0].topo_dimension - 1].num_corners_per_sub_element[0] );
Member Data Documentation
const char * moab::CN::entityTypeNames [static, private]
Initial value:
 { "Vertex", "Edge",  "Tri", "Quad",       "Polygon",   "Tet",    "Pyramid",
                                      "Prism",  "Knife", "Hex", "Polyhedron", "EntitySet", "MaxType" }
entity names
Definition at line 60 of file CN.hpp.
Referenced by EntityTypeFromName(), and EntityTypeName().
short moab::CN::increasingInts [static, private]
Initial value:
 { 0,  1,  2,  3,  4,  5,  6,  7,  8,  9,  10, 11, 12, 13, 14, 15, 16, 17, 18, 19,
                               20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39 }
Definition at line 71 of file CN.hpp.
Referenced by SubEntityVertexIndices().
const unsigned char moab::CN::midNodesPerType [static]
Initial value:
    { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
    { 0, 0, 0, E, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
    { 0, 0, 0, 0, F, 0, E, E | F, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
    { 0, 0, 0, 0, 0, F, 0, 0, E, E | F, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
    { 0, 0, 0, 0, 0, R, 0, 0, F, F | R, E, E | R, 0, 0, E | F, E | F | R, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
    { 0, 0, 0, 0, 0, 0, R, 0, 0, 0, F, F | R, 0, E, E | R, 0, 0, 0, E | F, E | F | R, 0, 0, 0, 0, 0, 0, 0, 0 },
    { 0, 0, 0, 0, 0, 0, 0, R, 0, 0, 0, F, F | R, 0, 0, E, E | R, 0, 0, 0, E | F, E | F | R, 0, 0, 0, 0, 0, 0 },
    { 0, 0, 0, 0, 0, 0, 0, 0, R, 0, 0, 0, F, F | R, 0, 0, 0, E, E | R, 0, 0, 0, E | F, E | F | R, 0, 0, 0, 0 },
    { 0, 0, 0, 0, 0, 0, 0, 0, 0, R, 0, 0, 0, 0, F, F | R, 0, 0, 0, 0, E, E | R, 0, 0, 0, 0, E | F, E | F | R },
Definition at line 142 of file CN.hpp.
Referenced by HasMidNodes().
Definition at line 139 of file CN.hpp.
short int moab::CN::numberBasis = 0 [static, private]
Definition at line 66 of file CN.hpp.
Referenced by GetBasis(), HONodeIndex(), and SetBasis().
short int moab::CN::permuteVec [static]
Definition at line 145 of file CN.hpp.
Referenced by moab::permute_this(), resetPermutation(), and setPermutation().
short int moab::CN::revPermuteVec [static]
Definition at line 146 of file CN.hpp.
Referenced by resetPermutation(), moab::rev_permute_this(), and setPermutation().
List of all members.
