moab::DGMSolver Class Reference
#include <DGMSolver.hpp>
Static Public Member Functions
static unsigned int nchoosek (unsigned int n, unsigned int k)
 compute combinational number, n choose k, maximum output is std::numeric_limits<unsigned int>::max();
static unsigned int compute_numcols_vander_multivar (unsigned int kvars, unsigned int degree)
 compute the number of columns for a multivariate vandermonde matrix, given certen degree
static void gen_multivar_monomial_basis (const int kvars, const double *vars, const int degree, std::vector< double > &basis)
 compute the monomial basis of mutiple variables, up to input degree, lexicographically ordered
static void gen_vander_multivar (const int mrows, const int kvars, const double *us, const int degree, std::vector< double > &V)
 compute multivariate vandermonde matrix, monomial basis ordered in the same way as gen_multivar_monomial_basis
static void rescale_matrix (int mrows, int ncols, double *V, double *ts)
static void compute_qtransposeB (int mrows, int ncols, const double *Q, int bncols, double *bs)
static void qr_polyfit_safeguarded (const int mrows, const int ncols, double *V, double *D, int *rank)
static void backsolve (int mrows, int ncols, double *R, int bncols, double *bs, double *ws)
static void backsolve_polyfit_safeguarded (int dim, int degree, const bool interp, int mrows, int ncols, double *R, int bncols, double *bs, const double *ws, int *degree_out)
static void vec_dotprod (const int len, const double *a, const double *b, double *c)
static void vec_scalarprod (const int len, const double *a, const double c, double *b)
static void vec_crossprod (const double a[3], const double b[3], double(&c)[3])
static double vec_innerprod (const int len, const double *a, const double *b)
static double vec_2norm (const int len, const double *a)
static double vec_normalize (const int len, const double *a, double *b)
static double vec_distance (const int len, const double *a, const double *b)
static void vec_projoff (const int len, const double *a, const double *b, double *c)
static void vec_linear_operation (const int len, const double mu, const double *a, const double psi, const double *b, double *c)
static void get_tri_natural_coords (const int dim, const double *cornercoords, const int npts, const double *currcoords, double *naturalcoords)
Private Member Functions
 DGMSolver ()
 ~DGMSolver ()
Detailed Description
Definition at line 8 of file DGMSolver.hpp.
moab::DGMSolver::DGMSolver ( ) [inline, private]
Definition at line 10 of file DGMSolver.hpp.
moab::DGMSolver::~DGMSolver ( ) [inline, private]
Definition at line 11 of file DGMSolver.hpp.
Member Function Documentation
void moab::DGMSolver::backsolve ( int  mrows,
int  ncols,
double *  R,
int  bncols,
double *  bs,
double *  ws
) [static]
Definition at line 256 of file DGMSolver.cpp.
Referenced by moab::HiReconstruction::eval_vander_bivar_cmf(), and moab::HiReconstruction::eval_vander_univar_cmf().
#if 0
    std::cout.precision(16);
    std::cout<<"Before backsolve  "<<std::endl;
    std::cout<<" V = "<<std::endl;
    for (int k=0; k< ncols; k++){
        for (int j=0; j<mrows; ++j){
            std::cout<<R[mrows*k+j]<<std::endl;
        std::cout<<std::endl;
    //std::cout<<"#pnts = "<<mrows<<std::endl;
    std::cout<<"bs = "<<std::endl;
    for (int k=0; k< bncols; k++){
            std::cout<<"  "<<bs[mrows*k+j]<<std::endl;
#endif
    for( int k = 0; k < bncols; k++ )
        for( int j = ncols - 1; j >= 0; j-- )
            for( int i = j + 1; i < ncols; ++i )
                bs[mrows * k + j] = bs[mrows * k + j] - R[mrows * i + j] * bs[mrows * k + i];
            assert( R[mrows * j + j] != 0 );
            bs[mrows * k + j] = bs[mrows * k + j] / R[mrows * j + j];
        for( int j = 0; j < ncols; ++j )
            bs[mrows * k + j] = bs[mrows * k + j] / ws[j];
void moab::DGMSolver::backsolve_polyfit_safeguarded ( int  dim,
int  degree,
const bool  interp,
int  mrows,
int  ncols,
double *  R,
int  bncols,
double *  bs,
const double *  ws,
int *  degree_out
) [static]
Definition at line 300 of file DGMSolver.cpp.
    if( ncols < 1 ) std::cout << "ERROR: Invalid input to safeguarded polyfit backsolve routine.\n";
#if 0
    std::cout.precision(12);
    //std::cout<<" ] "<<std::endl;
    std::cout<<"Input ws = [ ";
            std::cout<<ws[k]<<", ";
    std::cout << "R: " << R << "size: [" << mrows << "," << ncols << "]" << std::endl;
    std::cout << "bs: " << bs << "size: [" << mrows << "," << bncols << "]" << std::endl;
    std::cout << "ws: " << ws << "size: [" << ncols << "," << 1 << "]" << std::endl;
    std::cout << "degree_out: " << degree_out << std::endl;
#endif
    int deg, numcols = 0;
        deg = degree;
        /* I think we should consider interp = true/false -Xinglin*/
        if( dim == 1 )
            numcols = deg + 1 - interp;
        else if( dim == 2 )
            numcols = ( deg + 2 ) * ( deg + 1 ) / 2 - interp;
        assert( numcols <= ncols );
        std::vector< double > bs_bak( numcols );
        if( deg >= 2 )
            for( int i = 0; i < numcols; i++ )
                assert( mrows * k + i < mrows * bncols );
                bs_bak.at( i ) = bs[mrows * k + i];
        while( deg >= 1 )
            int cend       = numcols - 1;
            bool downgrade = false;
            // The reconstruction can be applied only on edges (2-d) or faces (3-d)
            assert( cend >= 0 );
            assert( dim > 0 && dim < 3 );
            for( int d = deg; d >= 0; d-- )
                int cstart = 0;
                if( dim == 1 )
                    cstart = d;
                else if( dim == 2 )
                    cstart = ( ( d + 1 ) * d ) / 2;
                    // cstart = ((d*(d+1))>>1)-interp;
                // Solve for  bs
                for( int j = cend; j >= cstart; j-- )
                    assert( mrows * k + j < mrows * bncols );
                    for( int i = j + 1; i < numcols; ++i )
                        assert( mrows * i + j < mrows * ncols );  // check R
                    assert( mrows * j + j < mrows * ncols );  // check R
                // Checking for change in the coefficient
                if( d >= 2 && d < deg )
                    double tol;
                    if( dim == 1 )
                        tol = 1e-06;
                        assert( mrows * cstart + cstart < mrows * ncols );  // check R
                        double tb = bs_bak.at( cstart ) / R[mrows * cstart + cstart];
                        assert( mrows * k + cstart < mrows * bncols );
                        if( fabs( bs[mrows * k + cstart] - tb ) > ( 1 + tol ) * fabs( tb ) )
                            downgrade = true;
                            break;
                    else if( dim == 2 )
                        tol = 0.05;
                        std::vector< double > tb( cend - cstart + 1 );
                        for( int j = 0; j <= ( cend - cstart ); j++ )
                            tb.at( j ) = bs_bak.at( cstart + j );
                            int jind = j - cstart;
                            for( int i = j + 1; i <= cend; ++i )
                                tb.at( jind ) = tb.at( jind ) - R[mrows * i + j] * tb.at( i - cstart );
                            tb.at( jind ) = tb.at( jind ) / R[mrows * j + j];
                            double err = fabs( bs[mrows * k + j] - tb.at( jind ) );
                            if( ( err > tol ) && ( err >= ( 1 + tol ) * fabs( tb.at( jind ) ) ) )
                                downgrade = true;
                                break;
                        if( downgrade ) break;
                cend = cstart - 1;
            if( !downgrade )
                break;
            else
                deg = deg - 1;
                if( dim == 1 )
                    numcols = deg + 1;
                else if( dim == 2 )
                    numcols = ( deg + 2 ) * ( deg + 1 ) / 2;
                    bs[mrows * k + i] = bs_bak.at( i );
        assert( k < bncols );
        degree_out[k] = deg;
            // assert(mrows*k+i < mrows*bncols);
            // assert(i < ncols);
            bs[mrows * k + i] = bs[mrows * k + i] / ws[i];
        for( int i = numcols; i < mrows; i++ )
            bs[mrows * k + i] = 0;
unsigned int moab::DGMSolver::compute_numcols_vander_multivar ( unsigned int  kvars,
unsigned int  degree
) [static]
If degree = 0, out put is 1; If kvars = 1, degree = k, output is k+1; If kvars = 2, degree = k, output is (k+2)*(k+1)/2;
Definition at line 42 of file DGMSolver.cpp.
References nchoosek().
Referenced by gen_multivar_monomial_basis(), and gen_vander_multivar().
    unsigned int mcols = 0;
    for( unsigned int i = 0; i <= degree; ++i )
        unsigned int temp = nchoosek( kvars - 1 + i, kvars - 1 );
        if( !temp )
            std::cout << "overflow to compute nchoosek n= " << kvars - 1 + i << " k= " << kvars - 1 << std::endl;
            return 0;
        mcols += temp;
    return mcols;
void moab::DGMSolver::compute_qtransposeB ( int  mrows,
int  ncols,
const double *  Q,
int  bncols,
double *  bs
) [static]
Definition at line 174 of file DGMSolver.cpp.
    for( int k = 0; k < ncols; k++ )
        for( int j = 0; j < bncols; j++ )
            double t2 = 0;
            for( int i = k; i < mrows; i++ )
                t2 += Q[mrows * k + i] * bs[mrows * j + i];
            t2 = t2 + t2;
                bs[mrows * j + i] -= t2 * Q[mrows * k + i];
void moab::DGMSolver::gen_multivar_monomial_basis ( const int  kvars,
const double *  vars,
const int  degree,
std::vector< double > &  basis
) [static]
if degree = 0, output basis = {1} If kvars = 1, vars = {u}, degree = k, basis = {1,u,...,u^k} If kvars = 2, vars = {u,v}, degree = k, basis = {1,u,v,u^2,uv,v^2,u^3,u^2*v,uv^2,v^3,...,u^k,u^k-1*v,...,uv^k-1,v^k} If kvars = 3, vars = {u,v,w}, degree = k, basis = {1,u,v,w,u^2,uv,uw,v^2,v*w,w^2,...,u^k,u^k-1v,u^k-1w,...,v^k,v^k-1w,...,vw^k-1,w^k}
Parameters:
kvarsInteger, number of variables
varsPointer to array of doubles, size = kvars, variable values
degreeInteger, maximum degree
basisReference to vector, user input container to hold output which is appended to existing data; users don't have to preallocate for basis, this function will allocate interally
Definition at line 58 of file DGMSolver.cpp.
References compute_numcols_vander_multivar().
    unsigned int len = compute_numcols_vander_multivar( kvars, degree );
    basis.reserve( len - basis.capacity() + basis.size() );
    size_t iend = basis.size();
#ifndef NDEBUG
    size_t istr = basis.size();
#endif
    basis.push_back( 1 );
    ++iend;
    if( !degree )
        return;
    std::vector< size_t > varspos( kvars );
    // degree 1
    for( int ivar = 0; ivar < kvars; ++ivar )
        basis.push_back( vars[ivar] );
        varspos[ivar] = iend++;
    // degree 2 to degree
    for( int ideg = 2; ideg <= degree; ++ideg )
        size_t preend = iend;
            size_t varpreend = iend;
            for( size_t ilast = varspos[ivar]; ilast < preend; ++ilast )
                basis.push_back( vars[ivar] * basis[ilast] );
                ++iend;
            varspos[ivar] = varpreend;
    assert( len == iend - istr );
void moab::DGMSolver::gen_vander_multivar ( const int  mrows,
const int  kvars,
const double *  us,
const int  degree,
std::vector< double > &  V
) [static]
if degree = 0, V = {1,...,1}'; If kvars = 1, us = {u1;u2;..,;um}, degree = k, V = {1 u1 u1^2 ... u1^k;1 u2 u2^2 ... u2^k;...;1 um um^2 ... um^k}; *If kvars = 2, us = {u1 v1;u2 v2;...;um vm}, degree = k, V = {1 u1 v1 u1^2 u1v1 v1^2;...;1 um vm um^2 umvm vm^2};
Parameters:
mrowsInteger, number of points to evaluate Vandermonde matrix
usPointer to array of doubles, size = mrow*kvars, variable values for all points. Stored in row-wise, like {u1 v1 u2 v2 ...}
basisReference to vector, user input container to hold Vandermonde matrix which is appended to existing data; users don't have to preallocate for basis, this function will allocate interally; the Vandermonde matrix is stored in an array, columnwise, like {1 ... 1 u1 ...um u1^2 ... um^2 ...}
Definition at line 100 of file DGMSolver.cpp.
    unsigned int ncols = compute_numcols_vander_multivar( kvars, degree );
    V.reserve( mrows * ncols - V.capacity() + V.size() );
    size_t istr = V.size(), icol = 0;
    // add ones, V is stored in an single array, elements placed in columnwise order
    for( int irow = 0; irow < mrows; ++irow )
        V.push_back( 1 );
    ++icol;
    if( !degree )
        return;
    // degree 1
            V.push_back( us[irow * kvars + ivar] );  // us stored in row-wise
        varspos[ivar] = icol++;
    // from 2 to degree
        size_t preendcol = icol;
            size_t varpreend = icol;
            for( size_t ilast = varspos[ivar]; ilast < preendcol; ++ilast )
                    V.push_back( us[irow * kvars + ivar] * V[istr + irow + ilast * mrows] );
                ++icol;
    assert( icol == ncols );
void moab::DGMSolver::get_tri_natural_coords ( const int  dim,
const double *  cornercoords,
const int  npts,
const double *  currcoords,
double *  naturalcoords
) [static]
Definition at line 667 of file DGMSolver.cpp.
References dim.
Referenced by test_closedsurface_mesh().
    assert( dim == 2 || dim == 3 );
    double a = 0, b = 0, d = 0, tol = 1e-12;
    for( int i = 0; i < dim; ++i )
        a += ( cornercoords[dim + i] - cornercoords[i] ) * ( cornercoords[dim + i] - cornercoords[i] );
        b += ( cornercoords[dim + i] - cornercoords[i] ) * ( cornercoords[2 * dim + i] - cornercoords[i] );
        d += ( cornercoords[2 * dim + i] - cornercoords[i] ) * ( cornercoords[2 * dim + i] - cornercoords[i] );
    double det = a * d - b * b;
    assert( det > 0 );
    for( int ipt = 0; ipt < npts; ++ipt )
        double e = 0, f = 0;
            e += ( cornercoords[dim + i] - cornercoords[i] ) * ( currcoords[ipt * dim + i] - cornercoords[i] );
            f += ( cornercoords[2 * dim + i] - cornercoords[i] ) * ( currcoords[ipt * dim + i] - cornercoords[i] );
        naturalcoords[ipt * 3 + 1] = ( e * d - b * f ) / det;
        naturalcoords[ipt * 3 + 2] = ( a * f - b * e ) / det;
        naturalcoords[ipt * 3]     = 1 - naturalcoords[ipt * 3 + 1] - naturalcoords[ipt * 3 + 2];
        if( naturalcoords[ipt * 3] < -tol || naturalcoords[ipt * 3 + 1] < -tol || naturalcoords[ipt * 3 + 2] < -tol )
            std::cout << "Corners: \n";
            std::cout << cornercoords[0] << "\t" << cornercoords[1] << "\t" << cornercoords[3] << std::endl;
            std::cout << cornercoords[3] << "\t" << cornercoords[4] << "\t" << cornercoords[5] << std::endl;
            std::cout << cornercoords[6] << "\t" << cornercoords[7] << "\t" << cornercoords[8] << std::endl;
            std::cout << "Candidate: \n";
            std::cout << currcoords[ipt * dim] << "\t" << currcoords[ipt * dim + 1] << "\t" << currcoords[ipt * dim + 2]
                      << std::endl;
            exit( 0 );
        assert( fabs( naturalcoords[ipt * 3] + naturalcoords[ipt * 3 + 1] + naturalcoords[ipt * 3 + 2] - 1 ) < tol );
            assert( fabs( naturalcoords[ipt * 3] * cornercoords[i] +
                          naturalcoords[ipt * 3 + 1] * cornercoords[dim + i] +
                          naturalcoords[ipt * 3 + 2] * cornercoords[2 * dim + i] - currcoords[ipt * dim + i] ) < tol );
unsigned int moab::DGMSolver::nchoosek ( unsigned int  n,
unsigned int  k
) [static]
Definition at line 19 of file DGMSolver.cpp.
Referenced by compute_numcols_vander_multivar().
    if( k > n )
        return 0;
    unsigned long long ans = 1;
    if( k > ( n >> 1 ) )
        k = n - k;
    for( unsigned int i = 1; i <= k; ++i )
        ans *= n--;
        ans /= i;
        if( ans > std::numeric_limits< unsigned int >::max() )
            return 0;
    return ans;
void moab::DGMSolver::qr_polyfit_safeguarded ( const int  mrows,
const int  ncols,
double *  V,
double *  D,
int *  rank
) [static]
Definition at line 191 of file DGMSolver.cpp.
References t.
    double tol = 1e-8;
    *rank      = ncols;
    double* v  = new double[mrows];
        int nv = mrows - k;
        for( int j = 0; j < nv; j++ )
            v[j] = V[mrows * k + ( j + k )];
        double t2 = 0;
            t2 = t2 + v[j] * v[j];
        double t    = sqrt( t2 );
        double vnrm = 0;
        if( v[0] >= 0 )
            vnrm = sqrt( 2 * ( t2 + v[0] * t ) );
            v[0] = v[0] + t;
        else
            vnrm = sqrt( 2 * ( t2 - v[0] * t ) );
            v[0] = v[0] - t;
        if( vnrm > 0 )
                v[j] = v[j] / vnrm;
        for( int j = k; j < ncols; j++ )
            t2 = 0;
            for( int i = 0; i < nv; i++ )
                t2 = t2 + v[i] * V[mrows * j + ( i + k )];
            t2 = t2 + t2;
                V[mrows * j + ( i + k )] = V[mrows * j + ( i + k )] - t2 * v[i];
        D[k] = V[mrows * k + k];
            V[mrows * k + ( i + k )] = v[i];
        if( ( fabs( D[k] ) ) < tol && ( *rank == ncols ) )
            *rank = k;
            break;
    delete[] v;
void moab::DGMSolver::rescale_matrix ( int  mrows,
int  ncols,
double *  V,
double *  ts
) [static]
Definition at line 150 of file DGMSolver.cpp.
References vec_2norm().
    // This function rescales the input matrix using the norm of each column.
    for( int i = 0; i < ncols; i++ )
        for( int j = 0; j < mrows; j++ )
            v[j] = V[mrows * i + j];
        // Compute norm of the column vector
        double w = vec_2norm( mrows, v );
        if( fabs( w ) == 0 )
            ts[i] = 1;
        else
            ts[i] = w;
                V[mrows * i + j] = V[mrows * i + j] / ts[i];
    delete[] v;
double moab::DGMSolver::vec_2norm ( const int  len,
const double *  a
) [static]
Definition at line 544 of file DGMSolver.cpp.
References MB_SET_ERR_RET_VAL.
Referenced by rescale_matrix(), test_unitcircle(), test_unitsphere(), and vec_projoff().
    if( !a )
        MB_SET_ERR_RET_VAL( "NULL Pointer", 0.0 );
    double w = 0, s = 0;
    for( int k = 0; k < len; k++ )
        w = std::max( w, fabs( a[k] ) );
    if( w == 0 )
        return 0;
    else
            s += ( a[k] / w ) * ( a[k] / w );
        s = w * sqrt( s );
    return s;
void moab::DGMSolver::vec_crossprod ( const double  a[3],
const double  b[3],
double(&)  c[3]
) [static]
Definition at line 523 of file DGMSolver.cpp.
Referenced by moab::HiReconstruction::average_vertex_normal(), and moab::HiReconstruction::polyfit3d_surf_get_coeff().
    c[0] = a[1] * b[2] - a[2] * b[1];
    c[1] = a[2] * b[0] - a[0] * b[2];
    c[2] = a[0] * b[1] - a[1] * b[0];
double moab::DGMSolver::vec_distance ( const int  len,
const double *  a,
const double *  b
) [static]
Definition at line 604 of file DGMSolver.cpp.
Referenced by test_mesh(), test_unitcircle(), test_unitsphere(), test_unitsq_quads(), and test_unitsq_tris().
    double res = 0;
    for( int i = 0; i < len; ++i )
        res += ( a[i] - b[i] ) * ( a[i] - b[i] );
    return sqrt( res );
void moab::DGMSolver::vec_dotprod ( const int  len,
const double *  a,
const double *  b,
double *  c
) [static]
Definition at line 499 of file DGMSolver.cpp.
References MB_SET_ERR_RET.
    if( !a || !b || !c )
        MB_SET_ERR_RET( "NULL Pointer" );
        c[i] = a[i] * b[i];
double moab::DGMSolver::vec_innerprod ( const int  len,
const double *  a,
const double *  b
) [static]
Definition at line 530 of file DGMSolver.cpp.
Referenced by moab::HiReconstruction::compute_weights(), moab::HiReconstruction::polyfit3d_curve_get_coeff(), moab::HiReconstruction::polyfit3d_surf_get_coeff(), vec_projoff(), moab::HiReconstruction::walf3d_curve_vertex_eval(), and moab::HiReconstruction::walf3d_surf_vertex_eval().
    if( !a || !b )
    double ans = 0;
        ans += a[i] * b[i];
    return ans;
void moab::DGMSolver::vec_linear_operation ( const int  len,
const double  mu,
const double *  a,
const double  psi,
const double *  b,
double *  c
) [static]
double moab::DGMSolver::vec_normalize ( const int  len,
const double *  a,
double *  b
) [static]
Definition at line 569 of file DGMSolver.cpp.
Referenced by moab::HiReconstruction::average_vertex_normal(), moab::HiReconstruction::average_vertex_tangent(), and moab::HiReconstruction::polyfit3d_surf_get_coeff().
    if( !a || !b )
    double nrm = 0, mx = 0;
        mx = std::max( fabs( a[i] ), mx );
    if( mx == 0 )
            b[i] = 0;
        return 0;
        nrm += ( a[i] / mx ) * ( a[i] / mx );
    nrm = mx * sqrt( nrm );
    if( nrm == 0 )
        return nrm;
        b[i] = a[i] / nrm;
    return nrm;
void moab::DGMSolver::vec_projoff ( const int  len,
const double *  a,
const double *  b,
double *  c
) [static]
Definition at line 614 of file DGMSolver.cpp.
References MB_SET_ERR_RET, vec_2norm(), and vec_innerprod().
Referenced by moab::HiReconstruction::polyfit3d_surf_get_coeff().
    // c = a-<a,b>b/<b,b>;
    double bnrm = vec_2norm( len, b );
    if( bnrm == 0 )
            c[i] = a[i];
        return;
    double innerp = vec_innerprod( len, a, b ) / bnrm;
    if( innerp == 0 )
        if( c != a )
                c[i] = a[i];
        return;
        c[i] = a[i] - innerp * b[i] / bnrm;
void moab::DGMSolver::vec_scalarprod ( const int  len,
const double *  a,
const double  c,
double *  b
) [static]
Definition at line 511 of file DGMSolver.cpp.
    if( !a || !b )
        b[i] = c * a[i];
List of all members.
