moab::DamselUtil Class Reference
#include <DamselUtil.hpp>
+ Collaboration diagram for moab::DamselUtil:
Classes
struct  DtagP
struct  MtagP
class  tinfo
 struct to hold information on damsel/moab tags More...
Public Member Functions
 DamselUtil ()
 Needs to be a constructor to initialize dtom_data_type.
Static Public Member Functions
static ErrorCode container_to_range (damsel_model m, damsel_container &cont, Range &range)
Static Public Attributes
static damsel_data_type mtod_data_type [MB_MAX_DATA_TYPE+1]
static enum DataType dtom_data_type [DAMSEL_DATA_TYPE_PREDEFINED_WATERMARK+1]
static enum damsel_entity_type mtod_entity_type [MBMAXTYPE+1]
static enum EntityType dtom_entity_type [DAMSEL_ENTITY_TYPE_ALL_TYPES+1]
Private Attributes
damsel_library dmslLib
 Damsel library id.
damsel_model dmslModel
 Damsel model id.
tinfo xcoordsTag
 Other conventional tags.
tinfo ycoordsTag
tinfo zcoordsTag
tinfo collFlagsTag
tinfo parentsTag
tinfo childrenTag
std::vector< tinfotagMap
 MOAB/damsel handles for dense [0], sparse [1], and conventional [2] tags.
damsel_handle_type moabHandleType
 Damsel handle type used in (this build of) MOAB.
Friends
class WriteDamsel
class ReadDamsel
Detailed Description
Definition at line 37 of file DamselUtil.hpp.
Definition at line 60 of file DamselUtil.cpp.
    : dmslLib( DAMSEL_LIBRARY_INVALID ), dmslModel( DAMSEL_MODEL_INVALID ), moabHandleType( DAMSEL_HANDLE_TYPE_INVALID )
Member Function Documentation
ErrorCode moab::DamselUtil::container_to_range ( damsel_model  m,
damsel_container &  c,
Range r
) [static]
Convert handles in a container to a range; assumes EntityHandle and Damsel entity handles are the same size
Definition at line 67 of file DamselUtil.cpp.
References CHK_DMSL_ERR_NM, ErrorCode, moab::Range::insert(), and MB_SUCCESS.
Referenced by moab::ReadDamsel::process_ent_info().
    if( DMSLcontainer_get_type( c ) == DAMSEL_HANDLE_CONTAINER_TYPE_SEQUENCE )
        damsel_handle start;
        size_t count, stride;
        damsel_err_t err = DMSLcontainer_sequence_get_contents( m, c, &start, &count, &stride );
        CHK_DMSL_ERR_NM( err );
        for( damsel_handle i = start + ( count - 1 ) * stride; i >= start; i -= stride )
            r.insert( i );
    else if( DMSLcontainer_get_type( c ) == DAMSEL_HANDLE_CONTAINER_TYPE_VECTOR )
        damsel_handle* handle_ptr;
        size_t count;
        damsel_err_t err = DMSLcontainer_vector_get_contents( m, c, &handle_ptr, &count );
        for( int i = count - 1; i >= 0; i-- )
            r.insert( handle_ptr[i] );
    else if( DMSLcontainer_get_type( c ) == DAMSEL_HANDLE_CONTAINER_TYPE_TREE )
        damsel_handle_ptr node_ptr = NULL;
        damsel_container cont      = NULL;
        damsel_err_t err           = DMSLcontainer_tree_get_contents( m, c, &node_ptr, &cont );
        while( err.id == DMSL_OK.id && cont )
            ErrorCode rval = container_to_range( m, c, r );
            if( MB_SUCCESS != rval ) return rval;
    return MB_SUCCESS;
Friends And Related Function Documentation
friend class ReadDamsel [friend]
Definition at line 41 of file DamselUtil.hpp.
friend class WriteDamsel [friend]
Definition at line 40 of file DamselUtil.hpp.
Member Data Documentation
Definition at line 116 of file DamselUtil.hpp.
Referenced by moab::ReadDamsel::process_tags().
damsel_library moab::DamselUtil::dmslLib [private]
Damsel library id.
Definition at line 110 of file DamselUtil.hpp.
Referenced by moab::ReadDamsel::load_file(), moab::WriteDamsel::write_file(), and moab::ReadDamsel::~ReadDamsel().
Initial value:
Definition at line 52 of file DamselUtil.hpp.
damsel_handle_type moab::DamselUtil::moabHandleType [private]
Definition at line 122 of file DamselUtil.hpp.
Referenced by moab::WriteDamsel::WriteDamsel().
damsel_data_type moab::DamselUtil::mtod_data_type [static]
Initial value:
    DAMSEL_DATA_TYPE_BYTES,
    DAMSEL_DATA_TYPE_INTEGER,
    DAMSEL_DATA_TYPE_DOUBLE,
    DAMSEL_DATA_TYPE_INVALID,
    DAMSEL_DATA_TYPE_HANDLE
Definition at line 46 of file DamselUtil.hpp.
Referenced by moab::WriteDamsel::init_tag_info().
damsel_entity_type moab::DamselUtil::mtod_entity_type [static]
Initial value:
    DAMSEL_ENTITY_TYPE_VERTEX,
    DAMSEL_ENTITY_TYPE_EDGE,
    DAMSEL_ENTITY_TYPE_TRI,
    DAMSEL_ENTITY_TYPE_QUAD,
    DAMSEL_ENTITY_TYPE_POLYGON,
    DAMSEL_ENTITY_TYPE_TET,
    DAMSEL_ENTITY_TYPE_PYRAMID,
    DAMSEL_ENTITY_TYPE_PRISM,
    DAMSEL_ENTITY_TYPE_UNDEFINED,
    DAMSEL_ENTITY_TYPE_HEX,
    DAMSEL_ENTITY_TYPE_POLYHEDRON,
Definition at line 50 of file DamselUtil.hpp.
Referenced by moab::WriteDamsel::write_entities().
List of all members.
