moab::EdgeSizeSimpleImplicit Class Reference
#include <EdgeSizeSimpleImplicit.hpp>
+ Inheritance diagram for moab::EdgeSizeSimpleImplicit:
+ Collaboration diagram for moab::EdgeSizeSimpleImplicit:
Public Member Functions
 EdgeSizeSimpleImplicit ()
 Construct an evaluator.
virtual ~EdgeSizeSimpleImplicit ()
 Destruction is virtual so subclasses may clean up after refinement.
virtual bool evaluate_edge (const double *p0, const void *t0, double *p1, void *t1, const double *p2, const void *t2)
 Given an edge of length L, true when edge midpoint is within $^2$ of $({2f(x,y,z)}{L})^2$.
virtual void set_implicit_function (double *coeffs)
void get_implicit_function (double *&coeffs)
virtual void set_ratio (double r)
 Set the threshold ratio of function value to half-edge length that triggers subdivision.
double get_ratio ()
 Get the threshold ratio of function value to half-edge length that triggers subdivision.
Protected Attributes
double coeffA [6]
double coeffB [3]
double coeffC
double ratio
Detailed Description
This is an simple example edge evaluator tha subdivides edges based on their midpoint's distance to a simple, fixed-form implicit surface written as \( x^T A x + B x + C \) where \(x\) is a column vector of holding the edge midpoint coordinates, \(A\) is a symmetric 3x3 matrix, \(B\) is a 1x3 row vector, and \(C\) is a scalar. Whenever the implicit function divided by half of the edge length is smaller than some minimum ratio (which defaults to 1), the edge is marked for subdivision.
Author:
David Thompson
Date:
19 November 2007
Definition at line 38 of file EdgeSizeSimpleImplicit.hpp.
Definition at line 6 of file EdgeSizeSimpleImplicit.cpp.
References coeffA, coeffB, coeffC, and ratio.
    int i;
    // Default to the plane: x = 0.
    this->coeffC = 0.;
    for( i = 0; i < 3; ++i )
        this->coeffB[i] = this->coeffA[i] = this->coeffA[i + 3] = 0.;
    this->coeffB[0] = 1.;
    // Default to a scaling ratio of 1.
    this->ratio = 1.;
Definition at line 20 of file EdgeSizeSimpleImplicit.cpp.
Member Function Documentation
bool moab::EdgeSizeSimpleImplicit::evaluate_edge ( const double *  p0,
const void *  t0,
double *  p1,
void *  t1,
const double *  p2,
const void *  t2
) [virtual]
Implements moab::EdgeSizeEvaluator.
Definition at line 22 of file EdgeSizeSimpleImplicit.cpp.
    (void)t0;
    (void)t1;
    (void)t2;
    double L2 = 0.;
    double delta;
    int i;
        delta = p2[i + 3] - p0[i + 3];
        L2 += delta * delta;
    // parametric coords in p1[{0,1,2}]
    double x  = p1[3];
    double y  = p1[4];
    double z  = p1[5];
    double F2 = this->coeffA[0] * x * x + 2. * this->coeffA[1] * x * y + 2. * this->coeffA[2] * x * z +
                this->coeffA[3] * y * y + 2. * this->coeffA[4] * y * z + this->coeffA[5] * z * z + this->coeffB[0] * x +
                this->coeffB[1] * y + this->coeffB[2] * z + this->coeffC;
    F2        = F2 * F2;  // square it
    double r2 = this->ratio * this->ratio;
    if( 4. * F2 / L2 < r2 ) return true;  // Midpoint is close to surface => split edge
    return false;  // Don't split edge
Get the 10 coefficients of the implicit function. The vector contains the entries of A, followed by B, followed by C.
Definition at line 67 of file EdgeSizeSimpleImplicit.cpp.
References coeffA, coeffB, and coeffC.
    int i;
        coeffs[i]     = this->coeffA[i];
        coeffs[i + 3] = this->coeffA[i + 3];
        coeffs[i + 6] = this->coeffB[i];
    coeffs[9] = this->coeffC;
Definition at line 69 of file EdgeSizeSimpleImplicit.hpp.
References ratio.
        return this->ratio;
void moab::EdgeSizeSimpleImplicit::set_implicit_function ( double *  coeffs) [virtual]
Set the 10 coefficients of the implicit function. The vector contains the entries of A, followed by B, followed by C.
Definition at line 54 of file EdgeSizeSimpleImplicit.cpp.
    int i;
        this->coeffA[i]     = coeffs[i];
        this->coeffA[i + 3] = coeffs[i + 3];
        this->coeffB[i]     = coeffs[i + 6];
    this->coeffC = coeffs[9];
virtual void moab::EdgeSizeSimpleImplicit::set_ratio ( double  r) [inline, virtual]
Definition at line 64 of file EdgeSizeSimpleImplicit.hpp.
References ratio.
Referenced by TestMeshRefiner().
        this->ratio = r;
Member Data Documentation
List of all members.
