moab::ErrorOutput Class Reference
Utility class for printing error output. More...
#include <ErrorOutput.hpp>
+ Collaboration diagram for moab::ErrorOutput:
Public Member Functions
 ErrorOutput (FILE *str)
 ErrorOutput (std::ostream &str)
 ~ErrorOutput ()
bool have_rank () const
 Check if MPI rank has been set.
int get_rank () const
 Get MPI rank.
void set_rank (int rank)
 Set MPI rank.
void use_world_rank ()
 Set MPI rank to the rank of this process in MPI_COMM_WORLD, if MOAB is built with MPI and MPI_Init has been called.
void print (const char *str)
 Output the specified string.
void print (const std::string &str)
void printf (const char *fmt,...) MB_PRINTF(1)
 Output the specified printf-formatted output.
Private Member Functions
void print_real (const char *buffer)
void print_real (const std::string &str)
void print_real (const char *buffer, va_list args1, va_list args2)
void process_line_buffer ()
Private Attributes
ErrorOutputStreamoutputImpl
int mpiRank
std::vector< char > lineBuffer
Detailed Description
This class implements line-oriented output. That is, it buffers output data until a newline is encountered, at which point it sends the output to the output stream followed by an explicit flush, and optionally prefixed with the MPI rank.
Any output not terminated with an newline character or followed by later output containing a newline character will not be flushed until the destructor is invoked.
Definition at line 28 of file ErrorOutput.hpp.
Parameters:
strOutput stream to which to flush output
Definition at line 62 of file ErrorOutput.cpp.
References lineBuffer.
                                     : outputImpl( new FILEErrorStream( impl ) ), mpiRank( -1 )
    lineBuffer.reserve( 1024 );
moab::ErrorOutput::ErrorOutput ( std::ostream &  str)
Parameters:
Definition at line 67 of file ErrorOutput.cpp.
                                          : outputImpl( new CxxErrorStream( str ) ), mpiRank( -1 )
Destructor flushes any remaining output that wasn't followed by a newline character.
Definition at line 72 of file ErrorOutput.cpp.
References lineBuffer, outputImpl, and process_line_buffer().
    if( !lineBuffer.empty() )
        lineBuffer.push_back( '\n' );
        process_line_buffer();
    if( NULL != outputImpl )
        delete outputImpl;
        outputImpl = NULL;
Member Function Documentation
int moab::ErrorOutput::get_rank ( ) const [inline]
Get MPI rank.
Definition at line 53 of file ErrorOutput.hpp.
References mpiRank.
Referenced by moab::MBTraceBackErrorHandler(), and process_line_buffer().
        return mpiRank;
bool moab::ErrorOutput::have_rank ( ) const [inline]
Definition at line 48 of file ErrorOutput.hpp.
References mpiRank.
        return mpiRank >= 0;
void moab::ErrorOutput::print ( const char *  str) [inline]
Definition at line 67 of file ErrorOutput.hpp.
References print_real().
Referenced by moab::MBTraceBackErrorHandler().
        print_real( str );
void moab::ErrorOutput::print ( const std::string &  str) [inline]
Definition at line 73 of file ErrorOutput.hpp.
        print_real( str );
void moab::ErrorOutput::print_real ( const char *  buffer) [private]
Definition at line 98 of file ErrorOutput.cpp.
References buffer, lineBuffer, and process_line_buffer().
Referenced by print(), and printf().
    lineBuffer.insert( lineBuffer.end(), buffer, buffer + strlen( buffer ) );
void moab::ErrorOutput::print_real ( const std::string &  str) [private]
Definition at line 104 of file ErrorOutput.cpp.
References lineBuffer, and process_line_buffer().
    lineBuffer.insert( lineBuffer.end(), str.begin(), str.end() );
void moab::ErrorOutput::print_real ( const char *  buffer,
va_list  args1,
va_list  args2
) [private]
Definition at line 110 of file ErrorOutput.cpp.
References lineBuffer, process_line_buffer(), and size.
    size_t idx = lineBuffer.size();
#ifdef MOAB_HAVE_VSNPRINTF
    // try once with remaining space in buffer
    lineBuffer.resize( lineBuffer.capacity() );
    unsigned size = vsnprintf( &lineBuffer[idx], lineBuffer.size() - idx, fmt, args1 );
    ++size;  // trailing null
    // if necessary, increase buffer size and retry
    if( size > ( lineBuffer.size() - idx ) )
        lineBuffer.resize( idx + size );
        size = vsnprintf( &lineBuffer[idx], lineBuffer.size() - idx, fmt, args2 );
#else
    // Guess how much space might be required.
    // If every character is a format code then there are len/3 format codes.
    // Guess a random large value of num_chars characters per formatted argument.
    const unsigned num_chars = 180;
    unsigned exp_size        = ( num_chars / 3 ) * strlen( fmt );
    lineBuffer.resize( idx + exp_size );
    unsigned size = vsprintf( &lineBuffer[idx], fmt, args1 );
    // check if we overflowed the buffer
    if( size > exp_size )
        // crap!
        fprintf( stderr, "ERROR: Buffer overflow at %s:%d\n", __FILE__, __LINE__ );
        size = vsprintf( &lineBuffer[idx], fmt, args2 );
#endif
    // less one because we don't want the trailing '\0'
    lineBuffer.resize( idx + size - 1 );
void moab::ErrorOutput::printf ( const char *  fmt,
) [inline]
Definition at line 98 of file ErrorOutput.hpp.
    va_list args1, args2;
    va_start( args1, fmt );
    va_start( args2, fmt );
    print_real( fmt, args1, args2 );
    va_end( args2 );
    va_end( args1 );
Definition at line 150 of file ErrorOutput.cpp.
References get_rank(), have_rank(), lineBuffer, outputImpl, and moab::ErrorOutputStream::println().
Referenced by print_real(), and ~ErrorOutput().
    size_t last_idx = 0;
    std::vector< char >::iterator i;
    for( i = std::find( lineBuffer.begin(), lineBuffer.end(), '\n' ); i != lineBuffer.end();
         i = std::find( i, lineBuffer.end(), '\n' ) )
        *i = '\0';
        if( have_rank() )
            outputImpl->println( get_rank(), &lineBuffer[last_idx] );
        else
            outputImpl->println( &lineBuffer[last_idx] );
        ++i;
        last_idx = i - lineBuffer.begin();
    if( last_idx )
        i = std::copy( lineBuffer.begin() + last_idx, lineBuffer.end(), lineBuffer.begin() );
        lineBuffer.erase( i, lineBuffer.end() );
void moab::ErrorOutput::set_rank ( int  rank) [inline]
Set MPI rank.
Definition at line 58 of file ErrorOutput.hpp.
References mpiRank, and rank.
        mpiRank = rank;
Definition at line 87 of file ErrorOutput.cpp.
References MPI_COMM_WORLD, and mpiRank.
Referenced by moab::MBErrorHandler_Init().
#ifdef MOAB_HAVE_MPI
    int flag1;
    MPI_Initialized( &flag1 );
    int flag2;
    MPI_Finalized( &flag2 );
    if( flag1 && !flag2 ) MPI_Comm_rank( MPI_COMM_WORLD, &mpiRank );
#endif
Member Data Documentation
std::vector< char > moab::ErrorOutput::lineBuffer [private]
Definition at line 95 of file ErrorOutput.hpp.
Referenced by ErrorOutput(), print_real(), process_line_buffer(), and ~ErrorOutput().
Definition at line 83 of file ErrorOutput.hpp.
Referenced by get_rank(), have_rank(), set_rank(), and use_world_rank().
Definition at line 82 of file ErrorOutput.hpp.
Referenced by process_line_buffer(), and ~ErrorOutput().
List of all members.
