moab::GQT_IntRegCtxt Class Reference
An implementation of an Intersection Registration Context for use GQT ray-firing. More...
+ Inheritance diagram for moab::GQT_IntRegCtxt:
+ Collaboration diagram for moab::GQT_IntRegCtxt:
Public Member Functions
 GQT_IntRegCtxt (OrientedBoxTreeTool *obbtool, const double ray_point[3], const double ray_dir[3], double tolerance, int min_tolerance_intersections, const EntityHandle *root_set, const EntityHandle *geom_volume, const Tag *sense_tag, const int *desired_orient, const std::vector< EntityHandle > *prev_facets)
virtual ErrorCode register_intersection (EntityHandle set, EntityHandle triangle, double distance, OrientedBoxTreeTool::IntersectSearchWindow &, GeomUtil::intersection_type int_type)
virtual ErrorCode update_orient (EntityHandle set, int *surfTriOrient)
virtual const int * getDesiredOrient ()
Private Member Functions
void add_intersection (EntityHandle set, EntityHandle tri, double dist, OrientedBoxTreeTool::IntersectSearchWindow &search_win)
void append_intersection (EntityHandle set, EntityHandle facet, double dist)
void set_intersection (int len_idx, EntityHandle set, EntityHandle facet, double dist)
void add_mode1_intersection (EntityHandle set, EntityHandle facet, double dist, OrientedBoxTreeTool::IntersectSearchWindow &search_win)
bool edge_node_piercing_intersect (const EntityHandle tri, const CartVect &ray_direction, const GeomUtil::intersection_type int_type, const std::vector< EntityHandle > &close_tris, const std::vector< int > &close_senses, const Interface *MBI, std::vector< EntityHandle > *neighborhood_tris=0)
 Determine if a ray-edge/node intersection is glancing or piercing. This function avoids asking for upward adjacencies to prevent their creation.
bool in_prevFacets (const EntityHandle tri)
bool in_neighborhoods (const EntityHandle tri)
Private Attributes
OrientedBoxTreeTooltool
const CartVect ray_origin
const CartVect ray_direction
const double tol
const int minTolInt
const EntityHandlerootSet
const EntityHandlegeomVol
const TagsenseTag
const int * desiredOrient
const std::vector< EntityHandle > * prevFacets
std::vector< std::vector
< EntityHandle > >
neighborhoods
std::vector< EntityHandleneighborhood
Detailed Description
This context uses a variety of tests and conditions to confirm whether or not to accumulate an intersection, to ensure robustness for ray firing.
This context only accumulates intersections that are oriented parallel to the 'desiredOrient', if provided, with respect to 'geomVol', using information in the in 'senseTag'.
This context only accumulates a single intersection out of a set of multiple intersections that fall in the same 'neighborhood', where a 'neighborhood' is defined as facets that share edges or vertices.
This context only accumulates piercing intersections. This is relevant for intersections that are found to be on an edge or vertex by the Plucker test. Such intersections are piercing if the ray has the same orientation w.r.t. to all fecets that share that edge or vertex.
This context tests intersections against a list of 'prevFacets' to prevent a ray from crossing the same facet more than once. The user is responsible for ensuring that this list is reset when appropriate.
This context accumulates all intersections within 'tol' of the start of the ray and if the number of intersections within the 'tol' of the ray start point is less than 'minTolInt', the next closest intersection. If the desired result is only the closest intersection, 'minTolInt' should be 0. This function will return all intersections, regardless of distance from the start of the ray, if 'minTolInt' is negative.
Definition at line 123 of file GeomQueryTool.cpp.
moab::GQT_IntRegCtxt::GQT_IntRegCtxt ( OrientedBoxTreeTool obbtool,
double  tolerance,
const EntityHandle root_set,
const EntityHandle geom_volume,
const Tag sense_tag,
const int *  desired_orient,
const std::vector< EntityHandle > *  prev_facets
) [inline]
Definition at line 176 of file GeomQueryTool.cpp.
        : tool( obbtool ), ray_origin( ray_point ), ray_direction( ray_dir ), tol( tolerance ),
          minTolInt( min_tolerance_intersections ), rootSet( root_set ), geomVol( geom_volume ), senseTag( sense_tag ),
          desiredOrient( desired_orient ), prevFacets( prev_facets ){
Member Function Documentation
void moab::GQT_IntRegCtxt::add_intersection ( EntityHandle  set,
EntityHandle  tri,
double  dist,
OrientedBoxTreeTool::IntersectSearchWindow search_win
) [private]
Definition at line 532 of file GeomQueryTool.cpp.
References add_mode1_intersection(), append_intersection(), moab::OrientedBoxTreeTool::IntRegCtxt::intersections, minTolInt, neighborhood, neighborhoods, set_intersection(), and tol.
Referenced by register_intersection().
    // Mode 1, detected by non-null neg_ray_len pointer
    // keep the closest nonneg intersection and one negative intersection, if closer
    if( search_win.second && search_win.first )
        return add_mode1_intersection( set, facet, dist, search_win );
    /*   Mode 2: Used if neg_ray_len is not specified
         variables used:     min_tol_int, tol, search_win.first
         variables not used: neg_ray_len
         1) if(min_tol_int<0) return all intersections
         2) otherwise return all inside tolerance and unless there are >min_tol_int
         inside of tolerance, return the closest outside of tolerance */
    // Mode 2
    // If minTolInt is less than zero, return all intersections
    if( minTolInt < 0 && dist > -tol )
        append_intersection( set, facet, dist );
        neighborhoods.push_back( neighborhood );
        return;
    // Check if the 'len' pointer is pointing into the intersection
    // list.  If this is the case, then the list contains, at that
    // location, an intersection greater than the tolerance away from
    // the base point of the ray.
    int len_idx = -1;
    if( search_win.first && search_win.first >= &intersections[0] &&
        search_win.first < &intersections[0] + intersections.size() )
        len_idx = search_win.first - &intersections[0];
    // If the intersection is within tol of the ray base point, we
    // always add it to the list.
    if( dist <= tol )
        // If the list contains an intersection outside the tolerance...
        if( len_idx >= 0 )
            // If we no longer want an intersection outside the tolerance,
            // remove it.
            if( (int)intersections.size() >= minTolInt )
                set_intersection( len_idx, set, facet, dist );
                // From now on, we want only intersections within the tolerance,
                // so update length accordingly
                search_win.first = &tol;
            // Otherwise appended to the list and update pointer
            else
                search_win.first = &intersections[len_idx];
        // Otherwise just append it
        else
            // If we have all the intersections we want, set
            // length such that we will only find further intersections
            // within the tolerance
            if( (int)intersections.size() >= minTolInt ) search_win.first = &tol;
    // Otherwise the intersection is outside the tolerance
    // If we already have an intersection outside the tolerance and
    // this one is closer, replace the existing one with this one.
    else if( len_idx >= 0 )
        if( dist <= *search_win.first )
    // Otherwise if we want an intersection outside the tolerance
    // and don'thave one yet, add it.
    else if( (int)intersections.size() < minTolInt )
        // update length.  this is currently the closest intersection, so
        // only want further intersections that are closer than this one.
        search_win.first = &intersections.back();
Definition at line 494 of file GeomQueryTool.cpp.
References moab::OrientedBoxTreeTool::IntRegCtxt::facets, moab::OrientedBoxTreeTool::IntRegCtxt::intersections, set_intersection(), and moab::OrientedBoxTreeTool::IntRegCtxt::sets.
Referenced by add_intersection().
    if( 2 != intersections.size() )
        intersections.resize( 2, 0 );
        sets.resize( 2, 0 );
        facets.resize( 2, 0 );
        // must initialize this for comparison below
        intersections[0] = -std::numeric_limits< double >::max();
    // negative case
    if( 0.0 > dist )
        set_intersection( 0, set, facet, dist );
        search_win.second = &intersections[0];
        // nonnegative case
    else
        set_intersection( 1, set, facet, dist );
        search_win.first = &intersections[1];
        // if the intersection is closer than the negative one, remove the negative one
        if( dist < -*( search_win.second ) )
            set_intersection( 0, 0, 0, -intersections[1] );
    //    std::cout << "add_intersection: dist = " << dist << " search_win.second=" <<
    //    *search_win.second
    //          << " search_win.first=" << *search_win.first << std::endl;
    return;
void moab::GQT_IntRegCtxt::append_intersection ( EntityHandle  set,
EntityHandle  facet,
double  dist
) [private]
bool moab::GQT_IntRegCtxt::edge_node_piercing_intersect ( const EntityHandle  tri,
const CartVect ray_dir,
const std::vector< EntityHandle > &  close_tris,
const std::vector< int > &  close_senses,
const Interface MBI,
std::vector< EntityHandle > *  neighborhood_tris = 0
) [private]
Parameters:
triThe intersected triangle
ray_dirThe direction of the ray
int_typeThe type of intersection (EDGE0, EDGE1, NODE2, ...)
close_trisVector of triangles in the proximity of the intersection
close_sensesVector of surface senses for tris in the proximity of the intersection
neighborhoodVector of triangles in the topological neighborhood of the intersection
Returns:
True if piercing, false otherwise.
Definition at line 278 of file GeomQueryTool.cpp.
References moab::GeomUtil::EDGE0, moab::GeomUtil::EDGE1, moab::GeomUtil::EDGE2, ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::list_entities(), MB_CHK_ERR_RET_VAL, moab::GeomUtil::NODE0, moab::GeomUtil::NODE1, and moab::GeomUtil::NODE2.
    // get the node of the triangle
    const EntityHandle* conn = NULL;
    int len                  = 0;
    ErrorCode rval           = MBI->get_connectivity( tri, conn, len );MB_CHK_ERR_RET_VAL( rval, false );
    // NOTE: original code is next line, but return type was wrong; returning true to get same net effect
    if( 3 != len ) return false;
    // get adjacent tris (and keep their corresponding senses)
    std::vector< EntityHandle > adj_tris;
    std::vector< int > adj_senses;
    // node intersection
    if( GeomUtil::NODE0 == int_type || GeomUtil::NODE1 == int_type || GeomUtil::NODE2 == int_type )
        // get the intersected node
        EntityHandle node;
        if( GeomUtil::NODE0 == int_type )
            node = conn[0];
        else if( GeomUtil::NODE1 == int_type )
            node = conn[1];
        else
            node = conn[2];
        // get tris adjacent to node
        for( unsigned i = 0; i < close_tris.size(); ++i )
            const EntityHandle* con = NULL;
            rval                    = MBI->get_connectivity( close_tris[i], con, len );MB_CHK_ERR_RET_VAL( rval, false );
            if( node == con[0] || node == con[1] || node == con[2] )
                adj_tris.push_back( close_tris[i] );
                adj_senses.push_back( close_senses[i] );
        if( adj_tris.empty() )
            std::cerr << "error: no tris are adjacent to the node" << std::endl;
            return false;
        // edge intersection
    else if( GeomUtil::EDGE0 == int_type || GeomUtil::EDGE1 == int_type || GeomUtil::EDGE2 == int_type )
        // get the endpoints of the edge
        EntityHandle endpts[2];
        if( GeomUtil::EDGE0 == int_type )
            endpts[0] = conn[0];
            endpts[1] = conn[1];
        else if( GeomUtil::EDGE1 == int_type )
            endpts[0] = conn[1];
            endpts[1] = conn[2];
        else
            endpts[0] = conn[2];
            endpts[1] = conn[0];
        // get tris adjacent to edge
            // check both orientations in case close_tris are not on the same surface
            if( ( endpts[0] == con[0] && endpts[1] == con[1] ) || ( endpts[0] == con[1] && endpts[1] == con[0] ) ||
                ( endpts[0] == con[1] && endpts[1] == con[2] ) || ( endpts[0] == con[2] && endpts[1] == con[1] ) ||
                ( endpts[0] == con[2] && endpts[1] == con[0] ) || ( endpts[0] == con[0] && endpts[1] == con[2] ) )
        // In a 2-manifold each edge is adjacent to exactly 2 tris
        if( 2 != adj_tris.size() )
            std::cerr << "error: edge of a manifold must be topologically adjacent to exactly 2 tris" << std::endl;
            MBI->list_entities( endpts, 2 );
            return true;
    else
        std::cerr << "error: special case not an node/edge intersection" << std::endl;
        return false;
    // The close tris were in proximity to the intersection. The adj_tris are
    // topologically adjacent to the intersection (the neighborhood).
    if( neighborhood_tris ) ( *neighborhood_tris ).assign( adj_tris.begin(), adj_tris.end() );
    // determine glancing/piercing
    // If a desired_orientation was used in this call to ray_intersect_sets,
    // the plucker_ray_tri_intersect will have already used it. For a piercing
    // intersection, the normal of all tris must have the same orientation.
    int sign = 0;
    for( unsigned i = 0; i < adj_tris.size(); ++i )
        rval                    = MBI->get_connectivity( adj_tris[i], con, len );MB_CHK_ERR_RET_VAL( rval, false );
        CartVect coords[3];
        rval = MBI->get_coords( con, len, coords[0].array() );MB_CHK_ERR_RET_VAL( rval, false );
        // get normal of triangle
        CartVect v0     = coords[1] - coords[0];
        CartVect v1     = coords[2] - coords[0];
        CartVect norm   = adj_senses[i] * ( v0 * v1 );
        double dot_prod = norm % ray_dir;
        // if the sign has not yet been decided, choose it
        if( 0 == sign && 0 != dot_prod )
            if( 0 < dot_prod )
                sign = 1;
            else
                sign = -1;
        // intersection is glancing if tri and ray do not point in same direction
        // for every triangle
        if( 0 != sign && 0 > sign * dot_prod ) return false;
    return true;
virtual const int* moab::GQT_IntRegCtxt::getDesiredOrient ( ) [inline, virtual]
Reimplemented from moab::OrientedBoxTreeTool::IntRegCtxt.
Definition at line 199 of file GeomQueryTool.cpp.
References desiredOrient.
        return desiredOrient;
Definition at line 252 of file GeomQueryTool.cpp.
References neighborhoods.
    bool same_neighborhood = false;
    for( unsigned i = 0; i < neighborhoods.size(); ++i )
        if( neighborhoods[i].end() != find( neighborhoods[i].begin(), neighborhoods[i].end(), tri ) )
            same_neighborhood = true;
            continue;
    return same_neighborhood;
bool moab::GQT_IntRegCtxt::in_prevFacets ( const EntityHandle  tri) [private]
Definition at line 247 of file GeomQueryTool.cpp.
References prevFacets.
    return ( prevFacets && ( ( *prevFacets ).end() != find( ( *prevFacets ).begin(), ( *prevFacets ).end(), tri ) ) );
Definition at line 422 of file GeomQueryTool.cpp.
References add_intersection(), edge_node_piercing_intersect(), ErrorCode, geomVol, moab::OrientedBoxTreeTool::get_close_tris(), moab::OrientedBoxTreeTool::get_moab_instance(), in_neighborhoods(), in_prevFacets(), moab::GeomUtil::INTERIOR, MB_SUCCESS, neighborhood, ray_direction, ray_origin, rootSet, senseTag, tol, and tool.
    ErrorCode rval;
    // Do not accept intersections if they are in the vector of previously intersected
    // facets.
    if( in_prevFacets( t ) ) return MB_SUCCESS;
    // Do not accept intersections if they are in the neighborhood of previous
    // intersections.
    if( in_neighborhoods( t ) ) return MB_SUCCESS;
    neighborhood.clear();
    // Handle special case of edge/node intersection. Accept piercing
    // intersections and reject glancing intersections.
    // The edge_node_intersection function needs to know surface sense wrt volume.
    // A less-robust implementation could work without sense information.
    // Would it ever be useful to accept a glancing intersection?
    if( GeomUtil::INTERIOR != int_type && rootSet && geomVol && senseTag )
        // get triangles in the proximity of the intersection
        std::vector< EntityHandle > close_tris;
        std::vector< int > close_senses;
        rval = tool->get_close_tris( ray_origin + int_dist * ray_direction, tol, rootSet, geomVol, senseTag, close_tris,
                                     close_senses );
        if( MB_SUCCESS != rval ) return rval;
        if( !edge_node_piercing_intersect( t, ray_direction, int_type, close_tris, close_senses,
                                           tool->get_moab_instance(), &neighborhood ) )
            return MB_SUCCESS;
    else
        neighborhood.push_back( t );
    // NOTE: add_intersection may modify the 'neg_ray_len' and 'nonneg_ray_len'
    //       members, which will affect subsequent calls to ray_tri_intersect
    //       in this loop.
    add_intersection( set, t, int_dist, search_win );
    return MB_SUCCESS;
void moab::GQT_IntRegCtxt::set_intersection ( int  len_idx,
EntityHandle  set,
EntityHandle  facet,
double  dist
) [private]
ErrorCode moab::GQT_IntRegCtxt::update_orient ( EntityHandle  set,
int *  surfTriOrient
) [virtual]
Definition at line 205 of file GeomQueryTool.cpp.
References desiredOrient, ErrorCode, geomVol, moab::OrientedBoxTreeTool::get_moab_instance(), MB_SUCCESS, senseTag, moab::Interface::tag_get_data(), and tool.
    ErrorCode rval;
    // Get desired orientation of surface wrt volume. Use this to return only
    // exit or entrance intersections.
    if( geomVol && senseTag && desiredOrient && surfTriOrient )
        if( 1 != *desiredOrient && -1 != *desiredOrient )
            std::cerr << "error: desired orientation must be 1 (forward) or -1 (reverse)" << std::endl;
        EntityHandle vols[2];
        rval = tool->get_moab_instance()->tag_get_data( *senseTag, &set, 1, vols );
        assert( MB_SUCCESS == rval );
        if( vols[0] == vols[1] )
            std::cerr << "error: surface has positive and negative sense wrt same volume" << std::endl;
            return MB_FAILURE;
        // surfTriOrient will be used by plucker_ray_tri_intersect to avoid
        // intersections with wrong orientation.
        if( *geomVol == vols[0] )
            *surfTriOrient = *desiredOrient * 1;
        else if( *geomVol == vols[1] )
            *surfTriOrient = *desiredOrient * ( -1 );
        else
            assert( false );
            return MB_FAILURE;
    return MB_SUCCESS;
Member Data Documentation
Definition at line 141 of file GeomQueryTool.cpp.
Referenced by getDesiredOrient(), and update_orient().
Definition at line 138 of file GeomQueryTool.cpp.
Referenced by register_intersection(), and update_orient().
const int moab::GQT_IntRegCtxt::minTolInt [private]
Definition at line 134 of file GeomQueryTool.cpp.
std::vector< std::vector< EntityHandle > > moab::GQT_IntRegCtxt::neighborhoods [private]
Definition at line 151 of file GeomQueryTool.cpp.
Referenced by add_intersection(), append_intersection(), and in_neighborhoods().
const std::vector< EntityHandle >* moab::GQT_IntRegCtxt::prevFacets [private]
Definition at line 147 of file GeomQueryTool.cpp.
Referenced by in_prevFacets().
Definition at line 130 of file GeomQueryTool.cpp.
Definition at line 129 of file GeomQueryTool.cpp.
Definition at line 137 of file GeomQueryTool.cpp.
Definition at line 139 of file GeomQueryTool.cpp.
const double moab::GQT_IntRegCtxt::tol [private]
Definition at line 131 of file GeomQueryTool.cpp.
Referenced by add_intersection(), and register_intersection().
List of all members.
