moab::GeomTopoTool Class Reference
Tool for interpreting geometric topology sets in MOAB database Tool for interpreting geometric topology sets in MOAB database; see MOAB metadata_info document for information on how geometric topology sets are read and represented. More...
#include <GeomTopoTool.hpp>
+ Collaboration diagram for moab::GeomTopoTool:
Public Member Functions
 GeomTopoTool (Interface *impl, bool find_geoments=false, EntityHandle modelRootSet=0, bool p_rootSets_vector=true, bool restore_rootSets=true)
 Constructor (creates a GTT object) \ Construct a GeomTopoTool object and search for geometric EntitySets if they exist in the provided moab instance.
 ~GeomTopoTool ()
ErrorCode restore_topology_from_adjacency ()
 Restore parent/child links between GEOM_TOPO mesh sets.
ErrorCode set_sense (EntityHandle entity, EntityHandle wrt_entity, int sense)
ErrorCode get_sense (EntityHandle entity, EntityHandle wrt_entity, int &sense)
ErrorCode get_surface_senses (EntityHandle volume, int num_surfs, const EntityHandle *surfs, int *senses_out)
 Get the sense of the surface(s) with respect to the volume.
ErrorCode get_surface_senses (EntityHandle surface_ent, EntityHandle &forward_vol, EntityHandle &reverse_vol)
 Get the senses of a surface with respect to its volumes.
ErrorCode set_surface_senses (EntityHandle surface_ent, EntityHandle forward_vol, EntityHandle reverse_vol)
 Set the senses of a surface with respect to its volumes.
ErrorCode get_senses (EntityHandle entity, std::vector< EntityHandle > &wrt_entities, std::vector< int > &senses)
 Get the senses of the lower dimension entity handle wrt the higher dimension entities.
ErrorCode set_senses (EntityHandle entity, std::vector< EntityHandle > &wrt_entities, std::vector< int > &senses)
 Set the senses of the entity wrt multiple higher dimension entities.
ErrorCode next_vol (EntityHandle surface, EntityHandle old_volume, EntityHandle &new_volume)
 Get the volume on the other side of a surface.
ErrorCode get_gsets_by_dimension (int dim, Range &gset)
 Retrieve geometry sets of desired dimension from model set.
ErrorCode construct_obb_tree (EntityHandle eh)
 Build obb tree for the entity set given; entity can be surface or volume.
ErrorCode get_bounding_coords (EntityHandle volume, double minPt[3], double maxPt[3])
 Get the bouding points from a bounding box.
ErrorCode get_obb (EntityHandle volume, double center[3], double axis1[3], double axis2[3], double axis3[3])
 Get the center point and three vectors for the OBB of a given volume.
ErrorCode other_entity (EntityHandle bounded, EntityHandle not_this, EntityHandle across, EntityHandle &other)
 Get the other (d-1)-dimensional entity bounding a set across a (d-2)-dimensional entity.
int dimension (EntityHandle this_set)
 Return the dimension of the set, or -1 if it's not a geom_dimension set.
int global_id (EntityHandle this_set)
 Return the global ID of a given entity set.
EntityHandle entity_by_id (int dimension, int id)
 Map from dimension & global ID to EntityHandle.
ErrorCode find_geomsets (Range *ranges=NULL)
ErrorCode restore_obb_index ()
 Restore the internal cross-referencing of geometry sets and OBB roots.
ErrorCode construct_obb_trees (bool make_one_vol=false)
 Build obb trees for all surfaces and volumes in model set.
ErrorCode delete_obb_tree (EntityHandle gset, bool vol_only=false)
 Delete the OBB tree of a volume or surface.
ErrorCode delete_all_obb_trees ()
ErrorCode remove_root (EntityHandle vol_or_surf)
 Delete the root of the obb tree from the set of all roots.
ErrorCode get_root (EntityHandle vol_or_surf, EntityHandle &root)
 Get the root of the obbtree for a given entity.
EntityHandle get_one_vol_root ()
 If constructing one volume obb tree by joining all surface trees,.
OrientedBoxTreeToolobb_tree ()
 Pointer to Oriented Box Tree Tool class.
ErrorCode add_geo_set (EntityHandle set, int dimension, int global_id=0)
 Adds a geometry set to the range of all geometry sets, the model set, and root set.
ErrorCode geometrize_surface_set (EntityHandle surface, EntityHandle &output)
 Will assume no geo sets are defined for this surface.
ErrorCode is_owned_set (EntityHandle eh)
 Checks to see if the entity is part of the model set.
ErrorCode duplicate_model (GeomTopoTool *&duplicate, std::vector< EntityHandle > *pvGEnts=NULL)
 This would be a deep copy, into a new geom topo tool.
EntityHandle get_root_model_set ()
 Return the model set handle (this is the full geometry)
bool check_model ()
 Checks that all geometric entities were created properly.
const RangegeoRanges ()
 Should be used instead of keeping multiple ranges, for example in FBEngine.
Interfaceget_moab_instance ()
 Return pointer to moab instance.
Tag get_sense_tag ()
 Returns the sense tag (sense2Tag) from check_face_sense_tag.
Tag get_gid_tag ()
 Returns the global ID tag (gidTag) from check_gid_tag.
Tag get_geom_tag ()
 Returns the geometry dimension tag (geomTag) from check_geom_tag.
bool have_obb_tree ()
 Returns true if obb trees have been added to the rootset.
int num_ents_of_dim (int dim)
 returns the number of entities in the modelSet with specified geometric dimension
ErrorCode setup_implicit_complement ()
 sets the implicit complement handle for this tool
ErrorCode get_implicit_complement (EntityHandle &implicit_complement)
 Get (or optionally, create) the implicit complement handle.
bool is_implicit_complement (EntityHandle volume)
 detection method for the implicit complement
ErrorCode restore_topology_from_geometric_inclusion (const Range &flat_volumes)
 Discover and store the topological relationships among a set of volumes This method may be used to discover the hierarchy that exists in a range of volumes, that have no previous sense of hierarchy, and store it according to the conventions of GeomTopoTool. The following requirements about the range of flat_volumes must be met: 1. Each volume must be represented by a single, closed surface a. The surface meshsets have triangles and vertices as members. b. For each "flat volume", there must be two meshsets: one for the volume and another for the surface that encloses it. These must be linked by a parent-child relationship. c. The SENSE_FORWARD tag on the surface meshset must be set to be the volume meshset it encloses. 2. The surfaces must not touch or overlap.
Private Member Functions
ErrorCode generate_implicit_complement (EntityHandle &implicit_complement_set)
 Creates a volume for undefined space in the model.
ErrorCode construct_vertex_ranges (const Range &geom_sets, const Tag verts_tag)
 Compute vertices inclusive and put on tag on sets in geom_sets.
ErrorCode separate_by_dimension (const Range &geom_sets)
 Given a range of geom topology sets, separate by dimension.
ErrorCode check_gid_tag (bool create=false)
 Verify global id tag.
ErrorCode check_geom_tag (bool create=false)
 Verify geometry tag.
ErrorCode check_face_sense_tag (bool create=false)
 Verify sense face tag.
ErrorCode check_edge_sense_tags (bool create=false)
 Verify sense edge tags.
ErrorCode resize_rootSets ()
ErrorCode set_root_set (EntityHandle vol_or_surf, EntityHandle root)
Range get_ct_children_by_dimension (const EntityHandle parent, const int desired_dimension)
 Return a range of children of a desired geometric dimension.
bool A_is_in_B (const EntityHandle volume_A, const EntityHandle volume_B, GeomQueryTool *GQT)
 Test if volume A is enclosed by volume B.
ErrorCode insert_in_tree (const EntityHandle ct_root, const EntityHandle volume, GeomQueryTool *GQT)
 Used by restore_topology_from_geometric_inclusion to generate the.
Private Attributes
InterfacemdbImpl
Tag sense2Tag
Tag senseNEntsTag
Tag senseNSensesTag
Tag geomTag
Tag gidTag
Tag nameTag
Tag obbRootTag
Tag obbGsetTag
EntityHandle modelSet
EntityHandle impl_compl_handle
Range geomRanges [5]
int maxGlobalId [5]
bool updated
OrientedBoxTreeToolobbTree
EntityHandle setOffset
std::vector< EntityHandlerootSets
bool m_rootSets_vector
std::map< EntityHandle,
EntityHandle
mapRootSets
EntityHandle oneVolRootSet
Detailed Description
Definition at line 37 of file GeomTopoTool.hpp.
moab::GeomTopoTool::GeomTopoTool ( Interface impl,
bool  find_geoments = false,
EntityHandle  modelRootSet = 0,
bool  p_rootSets_vector = true,
bool  restore_rootSets = true
Parameters:
implMOAB instance the GeomTopoTool will operate on.
find_geomentsif specified as True, geometric objects in the provided MOAB instance will be searched for and added to the GTT.
modelRootSetthe GTT will operate only on geometric EntitySets contained by this EntitySet. If unprovided, the default value for the modelRootSet is the MOAB instance's root set, which contains everything in the instance.
p_rootSets_vectordetermines the storage datastructure used to relate geometric EntitySets to their OrientedBoundingBox (OBB) Tree roots. If set to true (default) a vector will be used to store the root sets along with an EntityHandle offset for fast lookup of the root sets. If set to false, then a map will be used to link geometric EntitySets (keys) to the OBB Tree root sets (values).
restore_rootSetsdetermines whether or not to restore the internal index that links geomSets to their corresponding OBB Root. Only relevant if find_geoments is true. (default = true)
Definition at line 46 of file GeomTopoTool.cpp.
References construct_obb_trees(), delete_all_obb_trees(), ErrorCode, find_geomsets(), GEOM_DIMENSION_TAG_NAME, geomTag, gidTag, moab::Interface::globalId_tag(), impl_compl_handle, maxGlobalId, MB_CHK_SET_ERR_CONT, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, mdbImpl, NAME_TAG_NAME, NAME_TAG_SIZE, nameTag, moab::OBB_GSET_TAG_NAME, moab::OBB_ROOT_TAG_NAME, obbGsetTag, obbRootTag, obbTree, restore_obb_index(), and moab::Interface::tag_get_handle().
Referenced by duplicate_model().
    : mdbImpl( impl ), sense2Tag( 0 ), senseNEntsTag( 0 ), senseNSensesTag( 0 ), geomTag( 0 ), gidTag( 0 ),
      obbRootTag( 0 ), obbGsetTag( 0 ), modelSet( modelRootSet ), updated( false ), setOffset( 0 ),
      m_rootSets_vector( p_rootSets_vector ), oneVolRootSet( 0 )
    obbTree = new OrientedBoxTreeTool( impl, NULL, true );
    ErrorCode rval =
        mdbImpl->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geomTag, MB_TAG_CREAT | MB_TAG_SPARSE );MB_CHK_SET_ERR_CONT( rval, "Error: Failed to create geometry dimension tag" );
    // global id tag is not really needed, but mbsize complains if we do not set it for
    // geometry entities
    gidTag = mdbImpl->globalId_tag();
    rval =
        mdbImpl->tag_get_handle( NAME_TAG_NAME, NAME_TAG_SIZE, MB_TYPE_OPAQUE, nameTag, MB_TAG_CREAT | MB_TAG_SPARSE );MB_CHK_SET_ERR_CONT( rval, "Error: Failed to create name tag" );
    rval = mdbImpl->tag_get_handle( OBB_ROOT_TAG_NAME, 1, MB_TYPE_HANDLE, obbRootTag, MB_TAG_CREAT | MB_TAG_SPARSE );MB_CHK_SET_ERR_CONT( rval, "Error: Failed to create obb root tag" );
    rval = mdbImpl->tag_get_handle( OBB_GSET_TAG_NAME, 1, MB_TYPE_HANDLE, obbGsetTag, MB_TAG_CREAT | MB_TAG_SPARSE );MB_CHK_SET_ERR_CONT( rval, "Error: Failed to create obb gset tag" );
    // set this value to zero for comparisons
    impl_compl_handle = 0;
    maxGlobalId[0] = maxGlobalId[1] = maxGlobalId[2] = maxGlobalId[3] = maxGlobalId[4] = 0;
    if( find_geoments )
        find_geomsets();
        if( restore_rootSets )
            rval = restore_obb_index();
            if( MB_SUCCESS != rval )
                rval = delete_all_obb_trees();MB_CHK_SET_ERR_CONT( rval, "Error: Failed to delete existing obb trees" );
                rval = construct_obb_trees();MB_CHK_SET_ERR_CONT( rval, "Error: Failed to rebuild obb trees" );
Definition at line 91 of file GeomTopoTool.cpp.
References obbTree.
    delete obbTree;
Member Function Documentation
bool moab::GeomTopoTool::A_is_in_B ( const EntityHandle  volume_A,
GeomQueryTool GQT
) [private]
Definition at line 1944 of file GeomTopoTool.cpp.
References moab::Range::begin(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), get_ct_children_by_dimension(), moab::Interface::get_entities_by_type(), MB_CHK_ERR, MB_CHK_SET_ERR, MBTRI, mdbImpl, and moab::GeomQueryTool::point_in_volume().
Referenced by insert_in_tree().
    ErrorCode rval;
    Range child_surfaces, triangles, vertices;
    double coord[3];  // coord[0] = x, etc.
    int result;       // point in vol result; 0=F, 1=T
    // find coordinates of any point on surface of A
    // get surface corresponding to volume, then get the triangles
    child_surfaces = get_ct_children_by_dimension( volume_A, 2 );
    rval           = mdbImpl->get_entities_by_type( *child_surfaces.begin(), MBTRI, triangles );MB_CHK_ERR( rval );
    // now get 1st triangle vertices
    rval = mdbImpl->get_connectivity( &( *triangles.begin() ), 1, vertices );MB_CHK_ERR( rval );
    // now get coordinates of first vertex
    rval = mdbImpl->get_coords( &( *vertices.begin() ), 1, &( coord[0] ) );MB_CHK_ERR( rval );
    // if point on A is inside vol B, return T; o.w. return F
    rval = GQT->point_in_volume( volume_B, coord, result );MB_CHK_SET_ERR( rval, "Failed to complete point in volume query." );
    return ( result != 0 );
ErrorCode moab::GeomTopoTool::add_geo_set ( EntityHandle  set,
int  dimension,
int  global_id = 0
Definition at line 1174 of file GeomTopoTool.cpp.
References moab::Interface::add_entities(), dim, ErrorCode, GEOM_DIMENSION_TAG_NAME, geomRanges, geomTag, gidTag, moab::Interface::globalId_tag(), moab::Range::insert(), maxGlobalId, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TYPE_INTEGER, mdbImpl, modelSet, moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), and updated.
Referenced by moab::FBEngine::create_new_gedge(), create_shell_test(), moab::FBEngine::create_volume_with_direction(), geometrize_surface_set(), setup_implicit_complement(), moab::FBEngine::split_bedge_at_new_mesh_node(), moab::FBEngine::split_edge_at_mesh_node(), moab::FBEngine::split_surface(), test_root_sets_resize(), and moab::FBEngine::weave_lateral_face_from_edges().
    if( dim < 0 || dim > 4 ) MB_SET_ERR( MB_FAILURE, "Invalid geometric dimension provided" );
    // see if it is not already set
    if( geomRanges[dim].find( set ) != geomRanges[dim].end() )
        return MB_SUCCESS;  // nothing to do, we already have it as a geo set of proper dimension
    updated = false;  // this should trigger at least an obb recomputation
    // get the geom topology tag
    ErrorCode result;
    if( 0 == geomTag )
        result = mdbImpl->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geomTag );MB_CHK_SET_ERR( result, "Failed to get the geometry dimension tag handle" );
    if( 0 == gidTag )
    // make sure the added set has the geom tag properly set
    result = mdbImpl->tag_set_data( geomTag, &set, 1, &dim );MB_CHK_SET_ERR( result, "Failed set the geometry dimension tag value" );
    geomRanges[dim].insert( set );
    // not only that, but also add it to the root model set
    if( modelSet )
        result = mdbImpl->add_entities( modelSet, &set, 1 );MB_CHK_SET_ERR( result, "Failed to add new geometry set to the tool's modelSet" );
    // set the global ID value
    // if passed 0, just increase the max id for the dimension
    if( 0 == gid )
        gid = ++maxGlobalId[dim];
    result = mdbImpl->tag_set_data( gidTag, &set, 1, &gid );MB_CHK_SET_ERR( result, "Failed to get the global id tag value for the geom entity" );
    return MB_SUCCESS;
ErrorCode moab::GeomTopoTool::check_edge_sense_tags ( bool  create = false) [private]
Definition at line 1161 of file GeomTopoTool.cpp.
References ErrorCode, moab::GEOM_SENSE_N_ENTS_TAG_NAME, moab::GEOM_SENSE_N_SENSES_TAG_NAME, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TAG_VARLEN, MB_TYPE_HANDLE, MB_TYPE_INTEGER, mdbImpl, senseNEntsTag, senseNSensesTag, and moab::Interface::tag_get_handle().
Referenced by duplicate_model(), get_sense(), get_senses(), and set_sense().
    ErrorCode rval;
    unsigned flags = MB_TAG_VARLEN | MB_TAG_SPARSE;
    if( create ) flags |= MB_TAG_CREAT;
    if( !senseNEntsTag )
        rval = mdbImpl->tag_get_handle( GEOM_SENSE_N_ENTS_TAG_NAME, 0, MB_TYPE_HANDLE, senseNEntsTag, flags );MB_CHK_SET_ERR( rval, "Failed to get the curve to surface entity tag handle" );
        rval = mdbImpl->tag_get_handle( GEOM_SENSE_N_SENSES_TAG_NAME, 0, MB_TYPE_INTEGER, senseNSensesTag, flags );MB_CHK_SET_ERR( rval, "Failed to get the curve to surface sense tag handle" );
    return MB_SUCCESS;
ErrorCode moab::GeomTopoTool::check_geom_tag ( bool  create = false) [private]
Definition at line 1122 of file GeomTopoTool.cpp.
References ErrorCode, GEOM_DIMENSION_TAG_NAME, geomTag, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_INTEGER, mdbImpl, and moab::Interface::tag_get_handle().
Referenced by get_geom_tag(), and separate_by_dimension().
    ErrorCode rval;
    unsigned flags = create ? MB_TAG_DENSE | MB_TAG_CREAT : MB_TAG_DENSE;
    if( !geomTag )
        // get any kind of tag that already exists
        rval = mdbImpl->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geomTag, flags );MB_CHK_SET_ERR( rval, "Could not get/create the geometry dimension tag" );
    return MB_SUCCESS;
ErrorCode moab::GeomTopoTool::check_gid_tag ( bool  create = false) [private]
Definition at line 1134 of file GeomTopoTool.cpp.
References ErrorCode, gidTag, GLOBAL_ID_TAG_NAME, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_INTEGER, mdbImpl, and moab::Interface::tag_get_handle().
Referenced by get_gid_tag().
    ErrorCode rval;
    if( !gidTag )
        rval = mdbImpl->tag_get_handle( GLOBAL_ID_TAG_NAME, 1, MB_TYPE_INTEGER, gidTag, flags );MB_CHK_SET_ERR( rval, "Could not get/create the global id tag" );
    return MB_SUCCESS;
Definition at line 1727 of file GeomTopoTool.cpp.
References moab::Range::begin(), moab::Interface::contains_entities(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Skinner::find_skin(), geomRanges, moab::Interface::get_adjacencies(), moab::Interface::get_child_meshsets(), moab::Interface::get_connectivity(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type(), moab::Interface::get_parent_meshsets(), get_sense(), moab::Interface::list_entity(), MB_SUCCESS, MBEDGE, MBVERTEX, mdbImpl, RETFALSE, moab::Interface::side_number(), moab::Range::size(), moab::subtract(), and moab::Interface::type_from_handle().
Referenced by check_model_test(), and verify_split().
    // vertex sets should have one node
    Range::iterator rit;
    ErrorCode rval;
    for( rit = geomRanges[0].begin(); rit != geomRanges[0].end(); ++rit )
        EntityHandle vSet = *rit;
        Range nodes;
        rval = mdbImpl->get_entities_by_handle( vSet, nodes );
        if( MB_SUCCESS != rval ) RETFALSE( " failed to get nodes from vertex set ", vSet );
        if( nodes.size() != 1 ) RETFALSE( " number of nodes is different from 1 ", vSet )
        EntityType type = mdbImpl->type_from_handle( nodes[0] );
        if( type != MBVERTEX ) RETFALSE( " entity in vertex set is not a node ", nodes[0] )
        // get all parents, and see if they belong to geomRanges[1]
        Range edges;
        rval = mdbImpl->get_parent_meshsets( vSet, edges );
        if( MB_SUCCESS != rval ) RETFALSE( " can't get parent edges for a node set ", vSet )
        Range notEdges = subtract( edges, geomRanges[1] );
        if( !notEdges.empty() ) RETFALSE( " some parents of a node set are not geo edges ", notEdges[0] )
    // edges to be formed by continuous chain of mesh edges, oriented correctly
    for( rit = geomRanges[1].begin(); rit != geomRanges[1].end(); ++rit )
        EntityHandle edge = *rit;
        std::vector< EntityHandle > mesh_edges;
        rval = mdbImpl->get_entities_by_type( edge, MBEDGE, mesh_edges );
        if( MB_SUCCESS != rval ) RETFALSE( " can't get mesh edges from edge set", edge )
        int num_edges = (int)mesh_edges.size();
        if( num_edges == 0 ) RETFALSE( " no mesh edges in edge set ", edge )
        EntityHandle firstNode;
        EntityHandle currentNode;  // will also hold the last node in chain of edges
        const EntityHandle* conn2;
        int nnodes2;
        for( int i = 0; i < num_edges; i++ )
            rval = mdbImpl->get_connectivity( mesh_edges[i], conn2, nnodes2 );
            if( MB_SUCCESS != rval || nnodes2 != 2 ) RETFALSE( " mesh edge connectivity is wrong ", mesh_edges[i] )
            if( i == 0 )
                firstNode   = conn2[0];
                currentNode = conn2[1];
            else  // if ( (i>0) )
                // check the current node is conn[0]
                if( conn2[0] != currentNode )
                    std::cout << "i=" << i << " conn2:" << conn2[0] << " " << conn2[1] << " currentNode:" << currentNode
                              << "\n";
                    mdbImpl->list_entity( mesh_edges[i] );
                    RETFALSE( " edges are not contiguous in edge set ", edge )
        // check the children of the edge set; do they have the first and last node?
        Range vertSets;
        rval = mdbImpl->get_child_meshsets( edge, vertSets );
        if( MB_SUCCESS != rval ) RETFALSE( " can't get vertex children ", edge )
        Range notVertices = subtract( vertSets, geomRanges[0] );
        if( !notVertices.empty() ) RETFALSE( " children sets that are not vertices ", notVertices[0] )
        for( Range::iterator it = vertSets.begin(); it != vertSets.end(); ++it )
            if( !mdbImpl->contains_entities( *it, &firstNode, 1 ) &&
                !mdbImpl->contains_entities( *it, &currentNode, 1 ) )
                RETFALSE( " a vertex set is not containing the first and last nodes ", *it )
        // check now the faces / parents
        Range faceSets;
        rval = mdbImpl->get_parent_meshsets( edge, faceSets );
        if( MB_SUCCESS != rval ) RETFALSE( " can't get edge parents ", edge )
        Range notFaces = subtract( faceSets, geomRanges[2] );
        if( !notFaces.empty() ) RETFALSE( " parent sets that are not faces ", notFaces[0] )
        // for a geo edge, check the sense tags with respect to the adjacent faces
        // in general, it is sufficient to check one mesh edge (the first one)
        // edge/face  senses
        EntityHandle firstMeshEdge = mesh_edges[0];
        // get all entities/elements adjacent to it
        Range adjElem;
        rval = mdbImpl->get_adjacencies( &firstMeshEdge, 1, 2, false, adjElem );
        if( MB_SUCCESS != rval ) RETFALSE( " can't get adjacent elements to the edge ", firstMeshEdge )
        for( Range::iterator it2 = adjElem.begin(); it2 != adjElem.end(); ++it2 )
            EntityHandle elem = *it2;
            // find the geo face it belongs to
            EntityHandle gFace = 0;
            for( Range::iterator fit = faceSets.begin(); fit != faceSets.end(); ++fit )
                EntityHandle possibleFace = *fit;
                if( mdbImpl->contains_entities( possibleFace, &elem, 1 ) )
                    gFace = possibleFace;
                    break;
            if( 0 == gFace )
                RETFALSE( " can't find adjacent surface that contains the adjacent element to the edge ",
                          firstMeshEdge )
            // now, check the sense of mesh_edge in element, and the sense of gedge in gface
            // side_number
            int side_n, sense, offset;
            rval = mdbImpl->side_number( elem, firstMeshEdge, side_n, sense, offset );
            if( MB_SUCCESS != rval ) RETFALSE( " can't get sense and side number of an element ", elem )
            // now get the sense
            int topoSense;
            rval = this->get_sense( edge, gFace, topoSense );
            if( topoSense != sense ) RETFALSE( " geometric topo sense and element sense do not agree ", edge )
    // surfaces to be true meshes
    // for surfaces, check that the skinner will find the correct boundary
    // use the skinner for boundary check
    Skinner tool( mdbImpl );
    for( rit = geomRanges[2].begin(); rit != geomRanges[2].end(); ++rit )
        EntityHandle faceSet = *rit;
        // get all boundary edges (adjacent edges)
        Range edges;
        rval = mdbImpl->get_child_meshsets( faceSet, edges );
        if( MB_SUCCESS != rval ) RETFALSE( " can't get children edges for a face set ", faceSet )
        if( !notEdges.empty() ) RETFALSE( " some children of a face set are not geo edges ", notEdges[0] )
        Range boundary_mesh_edges;
        for( Range::iterator it = edges.begin(); it != edges.end(); ++it )
            rval = mdbImpl->get_entities_by_type( *it, MBEDGE, boundary_mesh_edges );
            if( MB_SUCCESS != rval ) RETFALSE( " can't get edge elements from the edge set ", *it )
        // skin the elements of the surface
        // most of these should be triangles and quads
        Range surface_ents, edge_ents;
        rval = mdbImpl->get_entities_by_dimension( faceSet, 2, surface_ents );
        if( MB_SUCCESS != rval ) RETFALSE( " can't get surface elements from the face set ", faceSet )
        rval = tool.find_skin( 0, surface_ents, 1, edge_ents );
        if( MB_SUCCESS != rval ) RETFALSE( "can't skin a surface ", surface_ents[0] )
        // those 2 ranges for boundary edges now must be equal
        if( boundary_mesh_edges != edge_ents ) RETFALSE( "boundary ranges are different", boundary_mesh_edges[0] )
    // solids to be filled correctly, maybe a skin procedure too.
    // (maybe the solids are empty)
    return true;
Parameters:
ehEntityHandle of the volume or surface to construct the OBB tree around
Definition at line 407 of file GeomTopoTool.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), moab::OrientedBoxTreeTool::build(), dim, moab::Range::empty(), moab::Range::end(), ErrorCode, geomTag, moab::Interface::get_child_meshsets(), moab::Interface::get_entities_by_dimension(), get_root(), moab::Range::insert(), is_owned_set(), moab::OrientedBoxTreeTool::join_trees(), m_rootSets_vector, MB_CHK_SET_ERR, MB_INDEX_OUT_OF_RANGE, MB_SET_ERR, MB_SUCCESS, MBENTITYSET, mdbImpl, obbTree, resize_rootSets(), rootSets, set_root_set(), setOffset, moab::Interface::tag_get_data(), and moab::Interface::type_from_handle().
Referenced by construct_obb_trees(), test_delete_obb_tree(), and test_root_sets_resize().
    ErrorCode rval;
    int dim;
    rval = is_owned_set( eh );MB_CHK_SET_ERR( rval, "Entity set is not part of this model" );
    // get the type
    EntityType type = mdbImpl->type_from_handle( eh );
    // find the dimension of the entity
    rval = mdbImpl->tag_get_data( geomTag, &eh, 1, &dim );MB_CHK_SET_ERR( rval, "Failed to get dimension" );
    // ensure that the rootSets vector is of the correct size
    if( m_rootSets_vector && ( eh < setOffset || eh >= setOffset + rootSets.size() ) )
        rval = resize_rootSets();MB_CHK_SET_ERR( rval, "Error setting offset and sizing rootSets vector." );
    EntityHandle root;
    // if it's a surface
    if( dim == 2 && type == MBENTITYSET )
        rval = get_root( eh, root );
        if( MB_SUCCESS == rval )
            std::cerr << "Surface obb tree already exists" << std::endl;
            return MB_SUCCESS;
        else if( MB_INDEX_OUT_OF_RANGE != rval )
            MB_CHK_SET_ERR( rval, "Failed to get surface obb tree root" );
        Range tris;
        rval = mdbImpl->get_entities_by_dimension( eh, 2, tris );MB_CHK_SET_ERR( rval, "Failed to get entities by dimension" );
        if( tris.empty() )
            std::cerr << "WARNING: Surface has no facets" << std::endl;
        rval = obbTree->build( tris, root );MB_CHK_SET_ERR( rval, "Failed to build obb Tree for surface" );
        rval = mdbImpl->add_entities( root, &eh, 1 );MB_CHK_SET_ERR( rval, "Failed to add entities to root set" );
        // add this root to the GeomTopoTool tree root indexing
        set_root_set( eh, root );
        // if just building tree for surface, return here
        return MB_SUCCESS;
    // if it's a volume
    else if( dim == 3 && type == MBENTITYSET )
        // get its surfaces
        Range tmp_surfs, surf_trees;
        rval = mdbImpl->get_child_meshsets( eh, tmp_surfs );MB_CHK_SET_ERR( rval, "Failed to get surface meshsets" );
        // get OBB trees or create for each surface
        for( Range::iterator j = tmp_surfs.begin(); j != tmp_surfs.end(); ++j )
            rval = get_root( *j, root );
            // if root doesn't exist, create obb tree
            if( MB_INDEX_OUT_OF_RANGE == rval )
                rval = construct_obb_tree( *j );MB_CHK_SET_ERR( rval, "Failed to get create surface obb tree" );
                rval = get_root( *j, root );MB_CHK_SET_ERR( rval, "Failed to get surface obb tree root" );
            else
            surf_trees.insert( root );
        // build OBB tree for volume
        rval = obbTree->join_trees( surf_trees, root );MB_CHK_SET_ERR( rval, "Failed to join the obb trees" );
        return MB_SUCCESS;
    else
        MB_SET_ERR( MB_FAILURE, "Improper dimension or type for constructing obb tree" );
ErrorCode moab::GeomTopoTool::construct_obb_trees ( bool  make_one_vol = false)
Definition at line 560 of file GeomTopoTool.cpp.
References moab::Range::begin(), construct_obb_tree(), moab::Range::end(), ErrorCode, get_gsets_by_dimension(), get_root(), moab::Range::insert(), moab::OrientedBoxTreeTool::join_trees(), MB_CHK_SET_ERR, obbTree, and oneVolRootSet.
Referenced by GeomTopoTool(), gqt_build_obb(), gqt_load_file_dagmc_internal_build_obb(), gqt_load_file_dagmc_via_moab_build_obb(), heappermute(), moab::FBEngine::Init(), moab::GeomQueryTool::initialize(), main(), and test_restore_obb_trees().
    ErrorCode rval;
    EntityHandle root;
    // get all surfaces and volumes
    Range surfs, vols, vol_trees;
    rval = get_gsets_by_dimension( 2, surfs );MB_CHK_SET_ERR( rval, "Could not get surface sets" );
    rval = get_gsets_by_dimension( 3, vols );MB_CHK_SET_ERR( rval, "Could not get volume sets" );
    // for surface
    Range one_vol_trees;
    for( Range::iterator i = surfs.begin(); i != surfs.end(); ++i )
        rval = construct_obb_tree( *i );MB_CHK_SET_ERR( rval, "Failed to construct obb tree for surface" );
        // get the root set of this volume
        rval = get_root( *i, root );MB_CHK_SET_ERR( rval, "Failed to get obb tree root for surface" );
        // add to the Range of volume root sets
        one_vol_trees.insert( root );
    // for volumes
    for( Range::iterator i = vols.begin(); i != vols.end(); ++i )
        // create tree for this volume
        rval = construct_obb_tree( *i );MB_CHK_SET_ERR( rval, "Failed to construct obb tree for volume" );
    if( make_one_vol )
        rval = obbTree->join_trees( one_vol_trees, root );MB_CHK_SET_ERR( rval, "Failed to join surface trees into one volume" );
        oneVolRootSet = root;
    return rval;
ErrorCode moab::GeomTopoTool::construct_vertex_ranges ( const Range geom_sets,
const Tag  verts_tag
) [private]
Definition at line 758 of file GeomTopoTool.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::Range::end(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_handle(), MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, mdbImpl, moab::Interface::tag_set_data(), and moab::Interface::UNION.
    // construct the vertex range for each entity and put on that tag
    Range *temp_verts, temp_elems;
    ErrorCode result = MB_SUCCESS;
    for( Range::const_iterator it = geom_sets.begin(); it != geom_sets.end(); ++it )
        temp_elems.clear();
        // get all the elements in the set, recursively
        result = mdbImpl->get_entities_by_handle( *it, temp_elems, true );MB_CHK_SET_ERR( result, "Failed to get the geometry set entities" );
        // make the new range
        temp_verts = new( std::nothrow ) Range();
        if( NULL == temp_verts )
            MB_SET_ERR( MB_FAILURE, "Could not construct Range object" );
        // get all the verts of those elements; use get_adjacencies 'cuz it handles ranges better
        result = mdbImpl->get_adjacencies( temp_elems, 0, false, *temp_verts, Interface::UNION );
        if( MB_SUCCESS != result )
            delete temp_verts;
        MB_CHK_SET_ERR( result, "Failed to get the element's adjacent vertices" );
        // store this range as a tag on the entity
        result = mdbImpl->tag_set_data( verts_tag, &( *it ), 1, &temp_verts );
            delete temp_verts;
        MB_CHK_SET_ERR( result, "Failed to get the adjacent vertex data" );
        delete temp_verts;
        temp_verts = NULL;
    return result;
Definition at line 389 of file GeomTopoTool.cpp.
References delete_obb_tree(), moab::Range::end(), ErrorCode, geomRanges, MB_CHK_SET_ERR, MB_SUCCESS, mdbImpl, obbRootTag, and moab::Interface::tag_get_data().
Referenced by GeomTopoTool().
    ErrorCode rval;
    for( Range::iterator rit = geomRanges[3].begin(); rit != geomRanges[3].end(); ++rit )
        EntityHandle root;
        rval = mdbImpl->tag_get_data( obbRootTag, &( *rit ), 1, &root );
            rval = delete_obb_tree( *rit, false );MB_CHK_SET_ERR( rval, "Failed to delete obb tree" );
    return MB_SUCCESS;
ErrorCode moab::GeomTopoTool::delete_obb_tree ( EntityHandle  gset,
bool  vol_only = false
Definition at line 312 of file GeomTopoTool.cpp.
References moab::Range::begin(), child, moab::Interface::delete_entities(), dim, moab::Range::end(), moab::Range::erase(), ErrorCode, geomTag, moab::Interface::get_child_meshsets(), get_root(), moab::Range::insert(), moab::Range::insert_list(), is_owned_set(), MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_NOT_FOUND, mdbImpl, obbGsetTag, remove_root(), moab::Range::size(), and moab::Interface::tag_get_data().
Referenced by delete_all_obb_trees(), test_delete_obb_tree(), and test_restore_obb_trees().
    ErrorCode rval;
    // Make sure this set is part of the model
    rval = is_owned_set( gset );MB_CHK_SET_ERR( rval, "Entity set is not part of this model" );
    // Find the dimension of the entity
    int dim;
    rval = mdbImpl->tag_get_data( geomTag, &gset, 1, &dim );MB_CHK_SET_ERR( rval, "Failed to get dimension" );
    // Attempt to find a root for this set
    EntityHandle root;
    rval = get_root( gset, root );MB_CHK_SET_ERR( rval, "Failed to find an obb tree root for the entity set" );
    // Create range of tree nodes to delete
    Range nodes_to_delete;
    nodes_to_delete.insert( root );
    // If passed ent is a vol and 'vol_only' is true, delete vol root and all nodes between vol and
    // surf root
    if( dim == 3 && vol_only )
        // Range of child nodes to check before adding to delete list
        Range child_tree_nodes;
        rval = mdbImpl->get_child_meshsets( root, child_tree_nodes );MB_CHK_SET_ERR( rval, "Problem getting child tree nodes" );
        // Traverse the tree, checking each child node until
        // a surface root node is reached
        while( child_tree_nodes.size() != 0 )
            EntityHandle child = *child_tree_nodes.begin();
            EntityHandle surf;
            rval = mdbImpl->tag_get_data( obbGsetTag, &child, 1, &surf );
            // If the node has a gset tag, it is a surf root. Stop here.
            // If not, it is a tree node that needs to 1) have its children checked and
            //  2) be added to delete range
            if( MB_TAG_NOT_FOUND == rval )
                Range new_child_tree_nodes;
                rval = mdbImpl->get_child_meshsets( child, new_child_tree_nodes );MB_CHK_SET_ERR( rval, "Problem getting child nodes" );
                child_tree_nodes.insert_list( new_child_tree_nodes.begin(), new_child_tree_nodes.end() );
                nodes_to_delete.insert( child );
            // We're done checking this node, so can erase from child list
            child_tree_nodes.erase( child );
    // If passed ent is a surf or a vol and 'vol_only' is false, recursively gather all child nodes
    // and add them to delete list
    else
        Range all_tree_nodes;
        rval = mdbImpl->get_child_meshsets( root, all_tree_nodes, 0 );MB_CHK_SET_ERR( rval, "Failed to get child tree node sets" );
        nodes_to_delete.insert_list( all_tree_nodes.begin(), all_tree_nodes.end() );
    // Remove the root nodes from the GTT data structures
    for( Range::iterator it = nodes_to_delete.begin(); it != nodes_to_delete.end(); ++it )
        // Check to see if node is a root
        EntityHandle vol_or_surf;
        rval = mdbImpl->tag_get_data( obbGsetTag, &( *it ), 1, &vol_or_surf );
            // Remove from set of all roots
            rval = remove_root( vol_or_surf );MB_CHK_SET_ERR( rval, "Failed to remove node from GTT data structure" );
    // Delete the tree nodes from the database
    rval = mdbImpl->delete_entities( nodes_to_delete );MB_CHK_SET_ERR( rval, "Failed to delete node set" );
    return MB_SUCCESS;
Definition at line 96 of file GeomTopoTool.cpp.
References moab::Interface::contains_entities(), dim, ErrorCode, GEOM_DIMENSION_TAG_NAME, geomTag, MB_CHK_SET_ERR, MB_SUCCESS, MB_TYPE_INTEGER, mdbImpl, modelSet, moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
Referenced by get_sense(), get_senses(), get_surface_senses(), moab::FBEngine::redistribute_boundary_edges_to_faces(), set_sense(), set_surface_senses(), moab::FBEngine::split_bedge_at_new_mesh_node(), moab::FBEngine::split_edge_at_mesh_node(), and moab::FBEngine::split_edge_at_point().
    ErrorCode result;
    if( 0 == geomTag )
        result = mdbImpl->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geomTag );MB_CHK_SET_ERR( result, "Failed to get the geometry dimension tag" );
    // check if the geo set belongs to this model
    if( modelSet )
        if( !mdbImpl->contains_entities( modelSet, &this_set, 1 ) )
            // this g set does not belong to the current model
            return -1;
    // get the data for those tags
    int dim;
    result = mdbImpl->tag_get_data( geomTag, &this_set, 1, &dim );
    if( MB_SUCCESS != result ) return -1;
    else return dim;
ErrorCode moab::GeomTopoTool::duplicate_model ( GeomTopoTool *&  duplicate,
std::vector< EntityHandle > *  pvGEnts = NULL
Definition at line 1454 of file GeomTopoTool.cpp.
References moab::Interface::add_entities(), moab::Interface::add_parent_child(), moab::Range::begin(), check_edge_sense_tags(), check_face_sense_tag(), children, moab::Interface::create_meshset(), dim, moab::Range::end(), ErrorCode, moab::Range::find(), GEOM_DIMENSION_TAG_NAME, geomRanges, geomTag, GeomTopoTool(), moab::Interface::get_child_meshsets(), moab::Interface::get_entities_by_handle(), get_senses(), gidTag, moab::Interface::globalId_tag(), moab::Range::insert(), MB_CHK_SET_ERR, MB_SUCCESS, MB_TYPE_INTEGER, mdbImpl, MESHSET_SET, modelSet, set_senses(), moab::Range::size(), moab::Interface::tag_get_handle(), and moab::Interface::tag_set_data().
Referenced by duplicate_model_test(), moab::FBEngine::split_quads(), split_test(), and volume_test().
    // will
    EntityHandle rootModelSet;
    ErrorCode rval = mdbImpl->create_meshset( MESHSET_SET, rootModelSet );MB_CHK_SET_ERR( rval, "Failed to create the rootModelSet" );
    if( 0 == geomTag )
        rval = mdbImpl->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geomTag );MB_CHK_SET_ERR( rval, "Failed to get the geometry dimension tag handle" );
    if( 0 == gidTag )
    // extract from the geomSet the dimension, children, and grand-children
    Range depSets;  // dependents of the geomSet, including the geomSet
    // add in this range all the dependents of this, to filter the ones that need to be deep copied
    if( pvGEnts != NULL )
        unsigned int numGents = pvGEnts->size();
        for( unsigned int k = 0; k < numGents; k++ )
            EntityHandle geomSet = ( *pvGEnts )[k];
            // will keep accumulating to the depSets range
            rval = mdbImpl->get_child_meshsets( geomSet, depSets, 0 );  // 0 for numHops means that all
            // dependents are returned, not only the direct children.
            MB_CHK_SET_ERR( rval, "Failed to get the geometry set's child meshsets" );
            depSets.insert( geomSet );
    // add to the root model set copies of the gsets, with correct sets
    // keep a map between sets to help in copying parent/child relations
    std::map< EntityHandle, EntityHandle > relate;
    // each set will get the same entities as the original
    for( int dim = 0; dim < 5; dim++ )
        int gid                  = 0;
        unsigned int set_options = ( ( 1 != dim ) ? MESHSET_SET : MESHSET_ORDERED );
        for( Range::iterator it = geomRanges[dim].begin(); it != geomRanges[dim].end(); ++it )
            EntityHandle set = *it;
            if( pvGEnts != NULL && depSets.find( set ) == depSets.end() )
                continue;  // this means that this set is not of interest, skip it
            EntityHandle newSet;
            rval = mdbImpl->create_meshset( set_options, newSet );MB_CHK_SET_ERR( rval, "Failed to create new meshset" );
            relate[set] = newSet;
            rval        = mdbImpl->add_entities( rootModelSet, &newSet, 1 );MB_CHK_SET_ERR( rval, "Failed to add the new meshset to the tool's modelSet" );
            // make it a geo set, and give also global id in order
            rval = mdbImpl->tag_set_data( geomTag, &newSet, 1, &dim );MB_CHK_SET_ERR( rval, "Failed to set the new meshset's geometry dimension data" );
            gid++;  // increment global id, everything starts with 1 in the new model!
            rval = mdbImpl->tag_set_data( gidTag, &newSet, 1, &gid );MB_CHK_SET_ERR( rval, "Failed to get the new meshset's global id data" );
            if( dim == 1 )
                // the entities are ordered, we need to retrieve them ordered, and set them ordered
                rval = mdbImpl->get_entities_by_handle( set, mesh_edges );MB_CHK_SET_ERR( rval, "Failed to get the meshset entities by handle" );
                rval = mdbImpl->add_entities( newSet, &( mesh_edges[0] ), (int)mesh_edges.size() );MB_CHK_SET_ERR( rval, "Failed to add the new entities to the new meshset" );
            else
                Range ents;
                rval = mdbImpl->get_entities_by_handle( set, ents );MB_CHK_SET_ERR( rval, "Failed to add the entities to the existing meshset" );
                rval = mdbImpl->add_entities( newSet, ents );MB_CHK_SET_ERR( rval, "Failed to add the entities to the new meshset" );
            // set parent/child relations if dim>=1
            if( dim >= 1 )
                Range children;
                // the children of geo sets are only g sets
                rval = mdbImpl->get_child_meshsets( set, children );  // num_hops = 1 by default
                MB_CHK_SET_ERR( rval, "Failed to get the child meshsets of the existing set" );
                for( Range::iterator it2 = children.begin(); it2 != children.end(); ++it2 )
                    EntityHandle newChildSet = relate[*it2];
                    rval                     = mdbImpl->add_parent_child( newSet, newChildSet );MB_CHK_SET_ERR( rval, "Failed to create parent child relationship to the new meshset" );
    duplicate = new GeomTopoTool( mdbImpl, true, rootModelSet );  // will retrieve the
    // sets and put them in ranges
    // this is the lazy way to it:
    // newgtt->restore_topology_from_adjacency(); // will reset the sense entities, and with this,
    // the model represented by this new gtt will be complete set senses by peeking at the old model
    // make sure we have the sense tags defined
    rval = check_face_sense_tag( true );MB_CHK_SET_ERR( rval, "Failed to check the face to volume sense tag handle" );
    rval = check_edge_sense_tags( true );MB_CHK_SET_ERR( rval, "Failed to check the curve to surface sense tag handles" );
    for( int dd = 1; dd <= 2; dd++ )  // do it for surfaces and edges
        for( Range::iterator it = geomRanges[dd].begin(); it != geomRanges[dd].end(); ++it )
            EntityHandle surf = *it;
            if( pvGEnts != NULL && depSets.find( surf ) == depSets.end() )
            EntityHandle newSurf = relate[surf];
            // we can actually look at the tag data, to be more efficient
            // or use the
            std::vector< EntityHandle > solids;
            std::vector< int > senses;
            rval = this->get_senses( surf, solids, senses );MB_CHK_SET_ERR( rval, "Failed to get the sense data for the surface with respect to its volumes" );
            std::vector< EntityHandle > newSolids;
            std::vector< int > newSenses;
            for( unsigned int i = 0; i < solids.size(); i++ )
                if( pvGEnts != NULL && depSets.find( solids[i] ) == depSets.end() )
                EntityHandle newSolid = relate[solids[i]];
                // see which "solids" are in the new model
                newSolids.push_back( newSolid );
                newSenses.push_back( senses[i] );
            rval = duplicate->set_senses( newSurf, newSolids, newSenses );MB_CHK_SET_ERR( rval, "Failed to set the sense data for the surface with respect to the new volumes" );
    // if the original root model set for this model is 0 (root set), then create
    // a new set and put all the old sets in the new model set
    // in this way, the existing gtt remains valid (otherwise, the modelSet would contain all the
    // gsets, the old ones and the new ones; the root set contains everything)
    if( modelSet == 0 )
        rval = mdbImpl->create_meshset( MESHSET_SET, modelSet );MB_CHK_SET_ERR( rval, "Failed to create the modelSet meshset" );
        // add to this new set all previous sets (which are still in ranges)
            rval = mdbImpl->add_entities( modelSet, geomRanges[dim] );MB_CHK_SET_ERR( rval, "Failed to add the geometric meshsets to the tool's modelSet" );
    return MB_SUCCESS;
Definition at line 224 of file GeomTopoTool.cpp.
References ErrorCode, GEOM_DIMENSION_TAG_NAME, geomRanges, geomTag, moab::Interface::get_entities_by_type_and_tag(), MB_CHK_SET_ERR, MB_SUCCESS, MB_TYPE_INTEGER, MBENTITYSET, mdbImpl, modelSet, separate_by_dimension(), and moab::Interface::tag_get_handle().
Referenced by moab::FBEngine::chain_edges(), create_shell_test(), duplicate_model_test(), FBiGeom_load(), GeomTopoTool(), moab::FBEngine::Init(), moab::GeomQueryTool::initialize(), main(), moab::FBEngine::set_default_neumann_tags(), moab::FBEngine::split_quads(), and test_cubit14().
    ErrorCode rval;
    // get all sets with this tag
    Range geom_sets;
    if( 0 == geomTag )
        rval = mdbImpl->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geomTag );MB_CHK_SET_ERR( rval, "Failed to get geom dimension tag handle" );
    rval = mdbImpl->get_entities_by_type_and_tag( modelSet, MBENTITYSET, &geomTag, NULL, 1, geom_sets );MB_CHK_SET_ERR( rval, "Failed to get the geometry entities" );
    rval = separate_by_dimension( geom_sets );MB_CHK_SET_ERR( rval, "Failed to separate geometry sets by dimension" );
    if( ranges )
        for( int i = 0; i < 5; i++ )
            ranges[i] = geomRanges[i];
    return MB_SUCCESS;
Definition at line 1667 of file GeomTopoTool.cpp.
References moab::Interface::add_parent_child(), moab::Range::begin(), check_face_sense_tag(), moab::Interface::create_meshset(), moab::Range::end(), ErrorCode, get_gsets_by_dimension(), moab::Interface::get_parent_meshsets(), get_surface_senses(), MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, mdbImpl, MESHSET_SET, sense2Tag, and set_surface_senses().
Referenced by setup_implicit_complement().
    ErrorCode rval;
    rval = mdbImpl->create_meshset( MESHSET_SET, implicit_complement_set );MB_CHK_SET_ERR( rval, "Failed to create mesh set for implicit complement" );
    // make sure the sense2Tag is set
    if( !sense2Tag )
    // get all geometric surface sets
    Range surfs;
    // search through all surfaces
    std::vector< EntityHandle > parent_vols;
    for( Range::iterator surf_i = surfs.begin(); surf_i != surfs.end(); ++surf_i )
        parent_vols.clear();
        // get parents of each surface
        rval = mdbImpl->get_parent_meshsets( *surf_i, parent_vols );MB_CHK_SET_ERR( rval, "Failed to get volume meshsets" );
        // if only one parent, get the OBB root for this surface
        if( parent_vols.size() == 1 )
            // add this surf to the topology of the implicit complement volume
            rval = mdbImpl->add_parent_child( implicit_complement_set, *surf_i );MB_CHK_SET_ERR( rval, "Could not add surface to implicit complement set" );
            // get the surface sense wrt original volume
            EntityHandle sense_data[2] = { 0, 0 };
            rval                       = get_surface_senses( *surf_i, sense_data[0], sense_data[1] );MB_CHK_SET_ERR( rval, "Could not get surface sense data" );
            // set the surface sense wrt implicit complement volume
            if( 0 == sense_data[0] && 0 == sense_data[1] )
                MB_SET_ERR( MB_FAILURE, "No sense data for current surface" );
            if( 0 == sense_data[0] )
                sense_data[0] = implicit_complement_set;
            else if( 0 == sense_data[1] )
                sense_data[1] = implicit_complement_set;
            else
                MB_SET_ERR( MB_FAILURE, "Could not insert implicit complement into surface sense data" );
            // set the new sense data for this surface
            rval = set_surface_senses( *surf_i, sense_data[0], sense_data[1] );MB_CHK_SET_ERR( rval, "Failed to set sense tag data" );
    }  // end surface loop
    return MB_SUCCESS;
Definition at line 1220 of file GeomTopoTool.cpp.
References moab::Interface::add_entities(), add_geo_set(), moab::Interface::add_parent_child(), moab::Range::begin(), moab::Interface::create_meshset(), moab::Range::empty(), moab::Range::end(), moab::Range::erase(), ErrorCode, moab::Range::find(), moab::Skinner::find_skin(), moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), moab::Interface::get_entities_by_dimension(), moab::Interface::id_from_handle(), moab::Range::insert(), moab::Interface::list_entity(), MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, mdbImpl, MESHSET_SET, moab::Interface::set_connectivity(), set_sense(), moab::Interface::side_number(), moab::Range::size(), and moab::Interface::type_from_handle().
Referenced by geometrize_test().
    // usual scenario is to read a surface smf file, and "geometrize" it, and output it as a
    //  h5m file with proper sets, tags defined for mesh-based geometry
    // get all triangles/quads from the surface, then build loops
    // we may even have to
    // proper care has to be given to the orientation, material to the left!!!
    // at some point we may have to reorient triangles, not only edges, for proper definition
    bool debugFlag = false;
    Range surface_ents, edge_ents, loop_range;
    ErrorCode rval = mdbImpl->get_entities_by_dimension( surface, 2, surface_ents );MB_CHK_SET_ERR( rval, "Failed to get the surface entities" );
    EntityHandle face = surface;
    if( !surface )  // in the case it is root set, create another set
        rval = mdbImpl->create_meshset( MESHSET_SET, face );MB_CHK_SET_ERR( rval, "Failed to create a the new surface meshset" );
    // set the geo tag
    rval = add_geo_set( face, 2 );MB_CHK_SET_ERR( rval, "Failed to add the geometry set to the tool" );
    // this will be our output set, will contain all our new geo sets
    rval = mdbImpl->create_meshset( MESHSET_SET, output );MB_CHK_SET_ERR( rval, "Failed to create the output meshset" );
    // add first geo set (face) to the output set
    rval = mdbImpl->add_entities( output, &face, 1 );MB_CHK_SET_ERR( rval, "Failed to add the new meshset to the output meshset" );
    // how many edges do we need to create?
    // depends on how many loops we have
    // also, we should avoid non-manifold topology
    if( !surface )
    {  // in this case, surface is root, so we have to add entities
        rval = mdbImpl->add_entities( face, surface_ents );MB_CHK_SET_ERR( rval, "Failed to add surface entities to the surface meshset" );
    rval = tool.find_skin( 0, surface_ents, 1, edge_ents );MB_CHK_SET_ERR( rval, "Failed to skin the surface entities" );
    if( debugFlag )
        std::cout << "skinning edges: " << edge_ents.size() << "\n";
        for( Range::iterator it = edge_ents.begin(); it != edge_ents.end(); ++it )
            EntityHandle ed = *it;
            std::cout << "edge: " << mdbImpl->id_from_handle( ed ) << " type:" << mdbImpl->type_from_handle( ed )
                      << "\n";
            std::cout << mdbImpl->list_entity( ed );
    std::vector< EntityHandle > edges_loop;
    Range pool_of_edges = edge_ents;
    Range used_edges;  // these edges are already used for some loops
    // get a new one
    while( !pool_of_edges.empty() )
        // get the first edge, and start a loop with it
        EntityHandle current_edge = pool_of_edges[0];
        if( debugFlag )
            std::cout << "Start current edge: " << mdbImpl->id_from_handle( current_edge ) << "\n ";
            std::cout << mdbImpl->list_entity( current_edge );
        // get its triangle / quad and see its orientation
        std::vector< EntityHandle > tris;
        rval = mdbImpl->get_adjacencies( &current_edge, 1, 2, false, tris );MB_CHK_SET_ERR( rval, "Failed to get the adjacent triangles to the current edge" );
        if( tris.size() != 1 ) MB_SET_ERR( MB_FAILURE, "Edge not on boundary" );
        rval = mdbImpl->side_number( tris[0], current_edge, side_n, sense, offset );MB_CHK_SET_ERR( rval, "Failed to get the current edge's side number" );
        int nnodes2;
        rval = mdbImpl->get_connectivity( current_edge, conn2, nnodes2 );MB_CHK_SET_ERR( rval, "Failed to get the current edge's connectivity" );
        if( nnodes2 != 2 ) MB_SET_ERR( MB_FAILURE, "Incorrect number of nodes found." );
        EntityHandle start_node = conn2[0];
        EntityHandle next_node  = conn2[1];
        if( sense == -1 )
            // revert the edge, and start well
            EntityHandle nn2[2] = { conn2[1], conn2[0] };
            rval                = mdbImpl->set_connectivity( current_edge, nn2, 2 );MB_CHK_SET_ERR( rval, "Failed to set the connectivity of the current edge" );
            start_node = nn2[0];  // or conn2[0] !!! beware: conn2 is modified
            next_node  = nn2[1];  // or conn2[1]   !!!
            // reset connectivity of edge
            if( debugFlag ) std::cout << " current edge needs reversed\n";
        // start a new loop of edges
        edges_loop.clear();  // every edge loop starts fresh
        edges_loop.push_back( current_edge );
        used_edges.insert( current_edge );
        pool_of_edges.erase( current_edge );
        if( debugFlag )
            std::cout << " start node: " << start_node << "\n";
            std::cout << mdbImpl->list_entity( start_node );
            std::cout << " next node: " << next_node << "\n";
            std::cout << mdbImpl->list_entity( next_node );
        while( next_node != start_node )
            // find the next edge in the skin
            std::vector< EntityHandle > candidate_edges;
            rval = mdbImpl->get_adjacencies( &next_node, 1, 1, false, candidate_edges );MB_CHK_SET_ERR( rval, "Failed to get the adjacent edges to the next node" );
            // filter the edges that are used, or the edges not in the skin
            std::vector< EntityHandle > good_edges;
            for( int k = 0; k < (int)candidate_edges.size(); k++ )
                EntityHandle edg = candidate_edges[k];
                if( used_edges.find( edg ) != used_edges.end() ) continue;
                if( pool_of_edges.find( edg ) != pool_of_edges.end() ) good_edges.push_back( edg );
            if( good_edges.size() != 1 )
                std::cout << " good_edges.size()=" << good_edges.size() << " STOP\n";
                MB_SET_ERR( MB_FAILURE, "Number of good edges is not one. Could not complete the loop" );
            // see if the orientation is good; if not, revert it
            current_edge = good_edges[0];
            rval         = mdbImpl->get_connectivity( current_edge, conn2, nnodes2 );MB_CHK_SET_ERR( rval, "Failed to get the connectivity of the current edge" );
            if( nnodes2 != 2 ) MB_SET_ERR( MB_FAILURE, "Incorrect number of nodes found" );
            if( conn2[0] != next_node )
                if( conn2[1] != next_node )
                    // the edge is not connected then to current edge
                    // bail out
                    std::cout << "edge " << mdbImpl->id_from_handle( current_edge ) << " not connected to node "
                    MB_SET_ERR( MB_FAILURE, "Current edge is not connected to node" );
                if( debugFlag )
                    std::cout << " revert edge " << mdbImpl->id_from_handle( current_edge ) << "\n";
                // orientation should be reversed
                    std::cout << "after revert edge " << mdbImpl->id_from_handle( current_edge ) << "\n";
                    std::cout << " conn2: " << conn2[0] << " " << conn2[1] << "\n";
            // before reversion, conn2 was something { n1, next_node}
            // after reversion, conn2 became {next_node, n1}, so the
            // new next node will be still conn2[1]; big surprise, as
            //  I didn't expect the conn2 to change.
            // it seems that const EntityHandle * conn2 means conn2 cannot be
            // changed, but what is pointed to by it will change when we reset connectivity for edge
            if( debugFlag )
                std::cout << " current edge: " << mdbImpl->id_from_handle( current_edge ) << "\n ";
                std::cout << "next node: " << next_node << "\n ";
        // at this point, we have a loop formed;
        // create a geo edge, a vertex set, and add it to our sets
        EntityHandle edge;
        rval = mdbImpl->create_meshset( MESHSET_ORDERED, edge );MB_CHK_SET_ERR( rval, "Failed to create the edge meshset" );
        rval = add_geo_set( edge, 1 );MB_CHK_SET_ERR( rval, "Failed to add the edge meshset to the tool's model set" );
        // add the mesh edges:
        // add loops edges to the edge set
        rval = mdbImpl->add_entities( edge, &edges_loop[0], edges_loop.size() );  //
        MB_CHK_SET_ERR( rval, "Failed to add entities to the edge meshset" );
        // create a vertex set
        EntityHandle vertex;
        rval = mdbImpl->create_meshset( MESHSET_SET, vertex );MB_CHK_SET_ERR( rval, "Failed to create the vertex meshset" );
        rval = add_geo_set( vertex, 0 );MB_CHK_SET_ERR( rval, "Failed to add the vertex meshset to the tool's model set" );
        // add one node to the vertex set
        rval = mdbImpl->add_entities( vertex, &start_node, 1 );  //
        MB_CHK_SET_ERR( rval, "Failed to add entities to the vertex meshset" );
        rval = mdbImpl->add_parent_child( face, edge );MB_CHK_SET_ERR( rval, "Failed to create the edge to face parent child relationship" );
        rval = mdbImpl->add_parent_child( edge, vertex );MB_CHK_SET_ERR( rval, "Failed to create the vertex to edge parent child relationship" );
        // the sense of the edge in face is for sure positive (forward)
        rval = set_sense( edge, face, 1 );  //
        MB_CHK_SET_ERR( rval, "Failed to set the edge to face sense" );
        // also add our sets to the output set, to be sure to be exported
        rval = mdbImpl->add_entities( output, &edge, 1 );MB_CHK_SET_ERR( rval, "Failed to add the edge meshset to the output set" );
        rval = mdbImpl->add_entities( output, &vertex, 1 );MB_CHK_SET_ERR( rval, "Failed to add the vertex meshset to the output set" );
        if( debugFlag )
            std::cout << "add edge with start node " << start_node << " with " << edges_loop.size() << " edges\n";
    return MB_SUCCESS;
const Range* moab::GeomTopoTool::geoRanges ( ) [inline]
Definition at line 224 of file GeomTopoTool.hpp.
References geomRanges.
Referenced by FBiGeom_getEntSets(), FBiGeom_getNumEntSets(), moab::FBEngine::getAdjacentEntities(), moab::FBEngine::getEntities(), moab::FBEngine::getEntType(), and moab::FBEngine::getNumOfType().
        return geomRanges;
ErrorCode moab::GeomTopoTool::get_bounding_coords ( EntityHandle  volume,
double  minPt[3],
double  maxPt[3]
Parameters:
volumeThe volume for which the bounding coordinates are requested
minPtLocation of the min xyz corner of the volume's axis-aligned bounding box
maxPtLocation of the max xyz corner of the volume's axis-aligned bounding box
Definition at line 1892 of file GeomTopoTool.cpp.
References center(), ErrorCode, get_obb(), MB_CHK_SET_ERR, MB_SUCCESS, and moab::sum().
Referenced by moab::GeomQueryTool::point_in_box().
    double center[3], axis1[3], axis2[3], axis3[3];
    // get center point and vectors to OBB faces
    ErrorCode rval = get_obb( volume, center, axis1, axis2, axis3 );MB_CHK_SET_ERR( rval, "Failed to get the oriented bounding box of the volume" );
    // compute min and max vertices
    for( int i = 0; i < 3; i++ )
        double sum = fabs( axis1[i] ) + fabs( axis2[i] ) + fabs( axis3[i] );
        minPt[i]   = center[i] - sum;
        maxPt[i]   = center[i] + sum;
    return MB_SUCCESS;
Range moab::GeomTopoTool::get_ct_children_by_dimension ( const EntityHandle  parent,
) [private]
Definition at line 1923 of file GeomTopoTool.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::Range::end(), geomTag, moab::Interface::get_child_meshsets(), moab::Range::insert(), mdbImpl, and moab::Interface::tag_get_data().
Referenced by A_is_in_B(), insert_in_tree(), and restore_topology_from_geometric_inclusion().
    Range all_children, desired_children;
    Range::iterator it;
    int actual_dimension;
    desired_children.clear();
    all_children.clear();
    mdbImpl->get_child_meshsets( parent, all_children );
    for( it = all_children.begin(); it != all_children.end(); ++it )
        mdbImpl->tag_get_data( geomTag, &( *it ), 1, &actual_dimension );
        if( actual_dimension == desired_dimension ) desired_children.insert( *it );
    return desired_children;
Definition at line 382 of file GeomTopoTool.hpp.
References check_gid_tag(), and gidTag.
Referenced by overlap_test_measure_area(), overlap_test_ray_fire(), test_measure_area(), and test_ray_fire().
    check_gid_tag( true );
    return gidTag;
Definition at line 250 of file GeomTopoTool.cpp.
References dim, ErrorCode, geomTag, moab::Interface::get_entities_by_type_and_tag(), MB_CHK_SET_ERR, MB_SUCCESS, MBENTITYSET, mdbImpl, and modelSet.
Referenced by check_tree(), construct_obb_trees(), moab::GeomQueryTool::find_volume_slow(), generate_implicit_complement(), resize_rootSets(), test_delete_obb_tree(), and test_restore_obb_trees().
    ErrorCode rval;
    const int val               = dim;
    const void* const dim_val[] = { &val };
    rval = mdbImpl->get_entities_by_type_and_tag( modelSet, MBENTITYSET, &geomTag, dim_val, 1, gset );MB_CHK_SET_ERR( rval, "Failed to get entity set by type and tag" );
    return MB_SUCCESS;
Definition at line 1600 of file GeomTopoTool.cpp.
References impl_compl_handle, MB_ENTITY_NOT_FOUND, and MB_SUCCESS.
Referenced by moab::GeomQueryTool::find_volume().
    if( impl_compl_handle )
        implicit_complement = impl_compl_handle;
        return MB_SUCCESS;
    else
        return MB_ENTITY_NOT_FOUND;
Definition at line 230 of file GeomTopoTool.hpp.
References mdbImpl.
Referenced by chkerr(), moab::GeomQueryTool::GeomQueryTool(), obbstat_write(), and obbvis_create().
        return mdbImpl;
ErrorCode moab::GeomTopoTool::get_obb ( EntityHandle  volume,
double  center[3],
double  axis1[3],
double  axis2[3],
double  axis3[3]
Parameters:
volumeThe volume for which the OBB axes will be returned
centercoordinates of the oriented bounding box's center point
axis1scaled axis one of the oriented bounding box
axis2scaled axis two of the oriented bounding box
axis3scaled axis three of the oriented bounding box
Definition at line 1909 of file GeomTopoTool.cpp.
References moab::OrientedBoxTreeTool::box(), ErrorCode, get_root(), MB_CHK_SET_ERR, and obbTree.
Referenced by get_bounding_coords(), and obbvis_create().
    // find EntityHandle node_set for use in box
    EntityHandle root;
    ErrorCode rval = get_root( volume, root );MB_CHK_SET_ERR( rval, "Failed to get volume's obb tree root" );
    // call box to get center and vectors to faces
    return obbTree->box( root, center, axis1, axis2, axis3 );
Definition at line 371 of file GeomTopoTool.hpp.
References oneVolRootSet.
Referenced by moab::GeomQueryTool::find_volume(), and find_volume_tests().
    return oneVolRootSet;
Definition at line 215 of file GeomTopoTool.hpp.
References modelSet.
Referenced by duplicate_model_test(), moab::FBEngine::getRootSet(), split_test(), and volume_test().
        return modelSet;
ErrorCode moab::GeomTopoTool::get_sense ( EntityHandle  entity,
int &  sense
Get the sense of entity with respect to wrt_entity Returns MB_ENTITY_NOT_FOUND if no relationship found
Definition at line 899 of file GeomTopoTool.cpp.
References check_edge_sense_tags(), check_face_sense_tag(), dimension(), ErrorCode, get_senses(), MB_CHK_SET_ERR, MB_ENTITY_NOT_FOUND, MB_SET_ERR, MB_SUCCESS, MB_TAG_NOT_FOUND, mdbImpl, sense2Tag, and moab::Interface::tag_get_data().
Referenced by moab::GeomQueryTool::boundary_case(), check_model(), get_surface_senses(), main(), overlap_test_surface_sense(), moab::FBEngine::split_bedge_at_new_mesh_node(), moab::FBEngine::split_edge_at_mesh_node(), and test_surface_sense().
    // entity is lower dim (edge or face), wrt_entity is face or volume
    int edim   = dimension( entity );
    int wrtdim = dimension( wrt_entity );
    if( -1 == edim || -1 == wrtdim ) MB_SET_ERR( MB_FAILURE, "Non-geometric entity provided" );
    if( wrtdim - edim != 1 ) MB_SET_ERR( MB_FAILURE, "Entity dimension mismatch" );
    ErrorCode rval;
    if( 1 == edim )
        // edge in face
        rval = check_edge_sense_tags( false );MB_CHK_SET_ERR( rval, "Failed to check the curve to surface sense tag handles" );
        std::vector< EntityHandle > faces;
        rval = get_senses( entity, faces, senses );  // the tags should be defined here
        MB_CHK_SET_ERR( rval, "Failed to get the curve to surface sense data" );
        std::vector< EntityHandle >::iterator it = std::find( faces.begin(), faces.end(), wrt_entity );
        if( it == faces.end() ) return MB_ENTITY_NOT_FOUND;
        unsigned int index = it - faces.begin();
        sense              = senses[index];
    else
        // face in volume
        rval = check_face_sense_tag( false );MB_CHK_SET_ERR( rval, "Failed to check the surface to volume sense tag handle" );
        rval                       = mdbImpl->tag_get_data( sense2Tag, &entity, 1, sense_data );
        if( MB_TAG_NOT_FOUND != rval && MB_SUCCESS != rval )
            MB_CHK_SET_ERR( rval, "Failed to get the surface to volume sense data" );
        if( ( wrt_entity == sense_data[0] ) && ( wrt_entity == sense_data[1] ) )
            sense = 0;
        else if( wrt_entity == sense_data[0] )
            sense = 1;
        else if( wrt_entity == sense_data[1] )
            sense = -1;
        else
    return MB_SUCCESS;
Definition at line 376 of file GeomTopoTool.hpp.
References check_face_sense_tag(), and sense2Tag.
Referenced by moab::GeomQueryTool::GeomQueryTool().
    return sense2Tag;
ErrorCode moab::GeomTopoTool::get_senses ( EntityHandle  entity,
std::vector< EntityHandle > &  wrt_entities,
std::vector< int > &  senses
Get the senses of the lower dimension entity handle wrt the higher dimension entities.
Definition at line 1011 of file GeomTopoTool.cpp.
References check_edge_sense_tags(), check_face_sense_tag(), moab::Interface::contains_entities(), dimension(), ErrorCode, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, mdbImpl, modelSet, sense2Tag, senseNEntsTag, senseNSensesTag, moab::Interface::tag_get_by_ptr(), and moab::Interface::tag_get_data().
Referenced by moab::SmoothCurve::compute_control_points_on_boundary_edges(), duplicate_model(), get_sense(), moab::FBEngine::getEgFcSense(), main(), read_cylcube_curve_senses_test(), read_cylcube_surf_senses_test(), and set_sense().
    // the question here is: the wrt_entities is supplied or not?
    // I assume not, we will obtain it !!
    if( -1 == edim ) MB_SET_ERR( MB_FAILURE, "Non-geometric entity provided" );
    ErrorCode rval;
    wrt_entities.clear();
    senses.clear();
    if( 1 == edim )  // edge
        const void* dum_ptr;
        int num_ents;
        rval = mdbImpl->tag_get_by_ptr( senseNEntsTag, &entity, 1, &dum_ptr, &num_ents );MB_CHK_ERR( rval );
        const EntityHandle* ents_data = static_cast< const EntityHandle* >( dum_ptr );
        std::copy( ents_data, ents_data + num_ents, std::back_inserter( wrt_entities ) );
        rval = mdbImpl->tag_get_by_ptr( senseNSensesTag, &entity, 1, &dum_ptr, &num_ents );MB_CHK_ERR( rval );
        const int* senses_data = static_cast< const int* >( dum_ptr );
        std::copy( senses_data, senses_data + num_ents, std::back_inserter( senses ) );
    else  // face in volume, edim == 2
        rval                       = mdbImpl->tag_get_data( sense2Tag, &entity, 1, sense_data );MB_CHK_SET_ERR( rval, "Failed to get the surface to volume sense data" );
        if( sense_data[0] != 0 && sense_data[1] == sense_data[0] )
            wrt_entities.push_back( sense_data[0] );
            senses.push_back( 0 );  // both
        else
            if( sense_data[0] != 0 )
                senses.push_back( 1 );
            if( sense_data[1] != 0 )
                wrt_entities.push_back( sense_data[1] );
                senses.push_back( -1 );
    // filter the results with the sets that are in the model at this time
    // this was introduced because extracting some sets (e.g. neumann set, with mbconvert)
    //   from a model would leave some sense tags not defined correctly
    // also, the geom ent set really needs to be part of the current model set
    unsigned int currentSize = 0;
    for( unsigned int index = 0; index < wrt_entities.size(); index++ )
        EntityHandle wrt_ent = wrt_entities[index];
        if( wrt_ent )
            if( mdbImpl->contains_entities( modelSet, &wrt_ent, 1 ) )
                wrt_entities[currentSize] = wrt_entities[index];
                senses[currentSize]       = senses[index];
                currentSize++;
    wrt_entities.resize( currentSize );
    senses.resize( currentSize );
    return MB_SUCCESS;
ErrorCode moab::GeomTopoTool::get_surface_senses ( EntityHandle  volume,
int  num_surfs,
const EntityHandle surfs,
int *  senses_out
Get the sense of the surface(s) with respect to the volume.
Definition at line 991 of file GeomTopoTool.cpp.
References get_sense(), and MB_SUCCESS.
Referenced by moab::GeomQueryTool::find_volume(), generate_implicit_complement(), moab::GeomQueryTool::measure_volume(), and moab::GeomQueryTool::point_in_volume_slow().
    /* The sense tags do not reference the implicit complement handle.
       All surfaces that interact with the implicit complement should have
       a null handle in the direction of the implicit complement. */
    // if (volume == impl_compl_handle)
    //  volume = (EntityHandle) 0;
    for( int surf_num = 0; surf_num < num_surfaces; surf_num++ )
        get_sense( surfaces[surf_num], volume, senses_out[surf_num] );
    return MB_SUCCESS;
ErrorCode moab::GeomTopoTool::get_surface_senses ( EntityHandle  surface_ent,
EntityHandle forward_vol,
EntityHandle reverse_vol
Get the senses of a surface with respect to its volumes.
Definition at line 944 of file GeomTopoTool.cpp.
References dimension(), ErrorCode, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, mdbImpl, sense2Tag, and moab::Interface::tag_get_data().
    ErrorCode rval;
    // this method should only be called to retrieve surface to volume
    // sense relationships
    int ent_dim = dimension( surface_ent );
    // verify the incoming entity dimensions for this call
    if( ent_dim != 2 )
        MB_SET_ERR( MB_FAILURE, "Entity dimension is incorrect for surface meshset" );
    // get the sense information for this surface
    EntityHandle parent_vols[2] = { 0, 0 };
    rval                        = mdbImpl->tag_get_data( sense2Tag, &surface_ent, 1, parent_vols );MB_CHK_SET_ERR( rval, "Failed to get surface sense data" );
    // set the outgoing values
    forward_vol = parent_vols[0];
    reverse_vol = parent_vols[1];
    return MB_SUCCESS;
Return the global ID of a given entity set.
Parameters:
this_setEntitySet for which the global ID will be returned
Definition at line 120 of file GeomTopoTool.cpp.
References moab::Interface::contains_entities(), ErrorCode, gidTag, moab::Interface::globalId_tag(), MB_SUCCESS, mdbImpl, modelSet, and moab::Interface::tag_get_data().
Referenced by moab::FBEngine::create_new_gedge(), obbstat_write(), moab::FBEngine::split_bedge_at_new_mesh_node(), and moab::FBEngine::split_edge_at_mesh_node().
    ErrorCode result;
    if( 0 == gidTag )
    if( modelSet )
            return -1;
    int id;
    result = mdbImpl->tag_get_data( gidTag, &this_set, 1, &id );
    else return id;
Returns true if obb trees have been added to the rootset.
Definition at line 1884 of file GeomTopoTool.cpp.
References mapRootSets, and rootSets.
    return rootSets.size() != 0 || mapRootSets.size() != 0;
ErrorCode moab::GeomTopoTool::insert_in_tree ( const EntityHandle  ct_root,
GeomQueryTool GQT
) [private]
Definition at line 1969 of file GeomTopoTool.cpp.
References A_is_in_B(), moab::Interface::add_parent_child(), ErrorCode, get_ct_children_by_dimension(), MB_CHK_SET_ERR, MB_SUCCESS, mdbImpl, moab::Range::pop_front(), moab::Interface::remove_parent_child(), and moab::Range::size().
Referenced by restore_topology_from_geometric_inclusion().
    ErrorCode rval;
    bool inserted               = false;
    EntityHandle current_volume = volume;   // volume to be inserted
    EntityHandle tree_volume    = ct_root;  // volume already existing in the tree
    EntityHandle parent         = ct_root;
    Range child_volumes;
    // while not inserted in tree
    while( !inserted )
        // if current volume is insde of tree volume-- always true if tree volume
        // is the root of the tree
        if( tree_volume == ct_root || ( tree_volume != ct_root && A_is_in_B( current_volume, tree_volume, GQT ) ) )
            parent = tree_volume;
            // if tree_volume has children then we must test them,
            // (tree_volume will change)
            child_volumes = get_ct_children_by_dimension( tree_volume, 3 );
            if( child_volumes.size() > 0 ) tree_volume = child_volumes.pop_front();
            // otherwise current_volume is the only child of the tree volume
            else
                rval = mdbImpl->add_parent_child( parent, current_volume );MB_CHK_SET_ERR( rval, "Failed to add parent-child relationship." );
                inserted = true;
            // if current volume is not in the tree volume, the converse may be true
        else
            // if the tree volume is inside the current volume
            if( A_is_in_B( tree_volume, current_volume, GQT ) )
                // reverse their parentage
                rval = mdbImpl->remove_parent_child( parent, tree_volume );MB_CHK_SET_ERR( rval, "Failed to remove parent-child relationship." );
                rval = mdbImpl->add_parent_child( current_volume, tree_volume );MB_CHK_SET_ERR( rval, "Failed to add parent-child relationship." );
            if( child_volumes.size() == 0 )
                inserted = true;
            else
    return MB_SUCCESS;
detection method for the implicit complement
Definition at line 394 of file GeomTopoTool.hpp.
References impl_compl_handle.
Referenced by moab::GeomQueryTool::measure_volume(), obbstat_write(), and moab::GeomQueryTool::point_in_volume().
    return volume == impl_compl_handle;
Checks to see if the entity is part of the model set.
Definition at line 300 of file GeomTopoTool.cpp.
References moab::Range::end(), ErrorCode, moab::Range::find(), moab::Interface::get_entities_by_handle(), MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, mdbImpl, and modelSet.
Referenced by construct_obb_tree(), and delete_obb_tree().
    // make sure entity set is part of the model
    Range model_ents;
    ErrorCode rval = mdbImpl->get_entities_by_handle( modelSet, model_ents );MB_CHK_SET_ERR( rval, "Failed to get entities" );
    if( model_ents.find( eh ) == model_ents.end() )
        MB_SET_ERR( MB_FAILURE, "Entity handle not in model set" );
    return MB_SUCCESS;
ErrorCode moab::GeomTopoTool::next_vol ( EntityHandle  surface,
EntityHandle  old_volume,
EntityHandle new_volume
Get the volume on the other side of a surface.
Parameters:
Asurface to query
old_volumeA volume on one side of surface
new_volumeOutput parameter for volume on the other side of surface
Returns:
MB_SUCCESS if new_volume was set successfully, error if not.
Definition at line 1102 of file GeomTopoTool.cpp.
References ErrorCode, moab::Interface::get_parent_meshsets(), MB_SUCCESS, and mdbImpl.
Referenced by overlap_test_tracking().
    std::vector< EntityHandle > parents;
    ErrorCode rval = mdbImpl->get_parent_meshsets( surface, parents );
        if( parents.size() != 2 )
            rval = MB_FAILURE;
        else if( parents.front() == old_volume )
            new_volume = parents.back();
        else if( parents.back() == old_volume )
            new_volume = parents.front();
        else
            rval = MB_FAILURE;
    return rval;
int moab::GeomTopoTool::num_ents_of_dim ( int  dim) [inline]
returns the number of entities in the modelSet with specified geometric dimension
Definition at line 352 of file GeomTopoTool.hpp.
References dim, geomRanges, and moab::Range::size().
Referenced by gqt_num_vols().
    assert( 0 <= dim && 3 >= dim );
    return geomRanges[dim].size();
Get the other (d-1)-dimensional entity bounding a set across a (d-2)-dimensional entity.
Given a d-dimensional entity and one (d-1)-dimensional entity, return the (d-1) dimensional entity across a specified (d-2)-dimensional entity. For example, given a surface, edge, and vertex, returns the other edge bounding the surface sharing the vertex. In the case of degenerate results, e.g. two loops bounding a surface and sharing a vertex, tries to step in positively-oriented direction. This won't always work; in those cases, will return MB_MULTIPLE_ENTITIES_FOUND.
In the special case where bounded is a curve, then not_this can be a vertex and across zero. This function returns the other vertex on the curve.
Definition at line 162 of file GeomTopoTool.cpp.
References moab::Range::begin(), ErrorCode, moab::Interface::get_child_meshsets(), moab::Interface::get_parent_meshsets(), moab::intersect(), MB_CHK_SET_ERR, MB_SUCCESS, mdbImpl, moab::Range::rbegin(), and moab::Range::size().
    other = 0;
    // get all children of bounded
    Range bdy, tmpr;
    ErrorCode rval = mdbImpl->get_child_meshsets( bounded, bdy );MB_CHK_SET_ERR( rval, "Failed to get the bounded entity's child meshsets" );
    // get all the parents of across
    rval = mdbImpl->get_parent_meshsets( across, tmpr );
    // possible candidates is the intersection
    bdy = intersect( bdy, tmpr );
    // if only two, choose the other
    if( 1 == bdy.size() && *bdy.begin() == not_this )
        return MB_SUCCESS;
    else if( 2 == bdy.size() )
        if( *bdy.begin() == not_this ) other = *bdy.rbegin();
        if( *bdy.rbegin() == not_this )
            other = *bdy.begin();
        else
            return MB_FAILURE;
    else
        return MB_FAILURE;
    return MB_SUCCESS;
Delete the root of the obb tree from the set of all roots.
Definition at line 517 of file GeomTopoTool.cpp.
References dim, ErrorCode, geomTag, m_rootSets_vector, mapRootSets, MB_CHK_SET_ERR, MB_INDEX_OUT_OF_RANGE, MB_SUCCESS, mdbImpl, obbGsetTag, obbRootTag, obbTree, moab::OrientedBoxTreeTool::remove_root(), rootSets, setOffset, moab::Interface::tag_delete_data(), and moab::Interface::tag_get_data().
Referenced by delete_obb_tree().
    // Find the root of the vol or surf
    ErrorCode rval;
    EntityHandle root;
    rval = mdbImpl->tag_get_data( obbRootTag, &( vol_or_surf ), 1, &root );MB_CHK_SET_ERR( rval, "Failed to get obb root tag" );
    // If the ent is a vol, remove its root from obbtreetool
    int dim;
    rval = mdbImpl->tag_get_data( geomTag, &vol_or_surf, 1, &dim );MB_CHK_SET_ERR( rval, "Failed to get dimension" );
    if( dim == 3 )
        rval = obbTree->remove_root( root );MB_CHK_SET_ERR( rval, "Failed to remove root from obbTreeTool" );
    // Delete the obbGsetTag data from the root
    rval = mdbImpl->tag_delete_data( obbGsetTag, &root, 1 );MB_CHK_SET_ERR( rval, "Failed to delete obb root tag" );
    // Delete the obbRootTag data from the vol or surf
    rval = mdbImpl->tag_delete_data( obbRootTag, &vol_or_surf, 1 );MB_CHK_SET_ERR( rval, "Failed to delete obb root tag" );
    // Remove the root from set of all roots
    if( m_rootSets_vector )
        unsigned int index = vol_or_surf - setOffset;
        if( index < rootSets.size() )
            rootSets[index] = 0;
        else
            return MB_INDEX_OUT_OF_RANGE;
    else
        mapRootSets[vol_or_surf] = 0;
    return MB_SUCCESS;
Definition at line 261 of file GeomTopoTool.cpp.
References moab::Range::back(), ErrorCode, moab::Range::front(), get_gsets_by_dimension(), MB_CHK_SET_ERR, MB_SUCCESS, moab::Range::merge(), rootSets, and setOffset.
Referenced by construct_obb_tree(), and restore_obb_index().
    ErrorCode rval;
    // store original offset for later
    EntityHandle orig_offset = setOffset;
    Range surfs, vols;
    // check the vector size
    Range surfs_and_vols;
    surfs_and_vols = vols;
    surfs_and_vols.merge( surfs );
    // update the setOffset
    setOffset = surfs_and_vols.front();
    EntityHandle exp_size = surfs_and_vols.back() - setOffset + 1;
    // if new EnitytHandle(s) are lower than the original offset
    if( setOffset < orig_offset )
        // insert empty values at the beginning of the vector
        rootSets.insert( rootSets.begin(), orig_offset - setOffset, 0 );
    if( exp_size != rootSets.size() )
        // resize rootSets vector if necessary (new space will be added at the back)
        rootSets.resize( exp_size );
    return MB_SUCCESS;
Restore the internal cross-referencing of geometry sets and OBB roots.
Definition at line 200 of file GeomTopoTool.cpp.
References dim, moab::Range::end(), ErrorCode, geomRanges, m_rootSets_vector, MB_SUCCESS, MB_TAG_NOT_FOUND, mdbImpl, obbRootTag, resize_rootSets(), set_root_set(), and moab::Interface::tag_get_data().
    if( m_rootSets_vector ) resize_rootSets();
    ErrorCode rval;
    EntityHandle root;
    for( int dim = 2; dim <= 3; dim++ )
        for( Range::iterator rit = geomRanges[dim].begin(); rit != geomRanges[dim].end(); ++rit )
                set_root_set( *rit, root );
            else
                return MB_TAG_NOT_FOUND;
    return MB_SUCCESS;
Restore parent/child links between GEOM_TOPO mesh sets.
Definition at line 599 of file GeomTopoTool.cpp.
References moab::Interface::add_parent_child(), moab::Range::begin(), moab::Range::clear(), dim, moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Range::front(), geomRanges, moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), moab::Interface::get_entities_by_dimension(), MB_CHK_SET_ERR, MB_MULTIPLE_ENTITIES_FOUND, MB_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TAG_NOT_FOUND, MB_TYPE_HANDLE, mdbImpl, set_sense(), moab::CN::SideNumber(), moab::Range::size(), moab::Interface::tag_delete(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), and moab::TYPE_FROM_HANDLE().
Referenced by moab::Tqdcfr::load_file().
    // look for geometric topology sets and restore parent/child links between them
    // algorithm:
    // - for each entity of dimension d=D-1..0:
    //   . get d-dimensional entity in entity
    //   . get all (d+1)-dim adjs to that entity
    //   . for each geom entity if dim d+1, if it contains any of the ents,
    //     add it to list of parents
    //   . make parent/child links with parents
    // the  geomRanges are already known, separated by dimension
    Range tmp_parents;
    ErrorCode result;
    // loop over dimensions
    for( int dim = 2; dim >= 0; dim-- )
        // mark entities of next higher dimension with their owners; regenerate tag
        // each dimension so prev dim's tag data goes away
        Tag owner_tag;
        EntityHandle dum_val = 0;
        result = mdbImpl->tag_get_handle( "__owner_tag", 1, MB_TYPE_HANDLE, owner_tag, MB_TAG_DENSE | MB_TAG_CREAT,
                                          &dum_val );
        if( MB_SUCCESS != result ) continue;
        Range dp1ents;
        std::vector< EntityHandle > owners;
        for( Range::iterator rit = geomRanges[dim + 1].begin(); rit != geomRanges[dim + 1].end(); ++rit )
            dp1ents.clear();
            result = mdbImpl->get_entities_by_dimension( *rit, dim + 1, dp1ents );
            owners.resize( dp1ents.size() );
            std::fill( owners.begin(), owners.end(), *rit );
            result = mdbImpl->tag_set_data( owner_tag, dp1ents, &owners[0] );
        for( Range::iterator d_it = geomRanges[dim].begin(); d_it != geomRanges[dim].end(); ++d_it )
            Range dents;
            result = mdbImpl->get_entities_by_dimension( *d_it, dim, dents );
            if( dents.empty() ) continue;
            // get (d+1)-dimensional adjs
            dp1ents.clear();
            result = mdbImpl->get_adjacencies( &( *dents.begin() ), 1, dim + 1, false, dp1ents );
            if( MB_SUCCESS != result || dp1ents.empty() ) continue;
            // get owner tags
            parents.resize( dp1ents.size() );
            result = mdbImpl->tag_get_data( owner_tag, dp1ents, &parents[0] );
            if( MB_TAG_NOT_FOUND == result )
                MB_CHK_SET_ERR( result, "Could not find owner tag" );
            // compress to a range to remove duplicates
            tmp_parents.clear();
            std::copy( parents.begin(), parents.end(), range_inserter( tmp_parents ) );
            for( Range::iterator pit = tmp_parents.begin(); pit != tmp_parents.end(); ++pit )
                result = mdbImpl->add_parent_child( *pit, *d_it );MB_CHK_SET_ERR( result, "Failed to create parent child relationship" );
            // store surface senses within regions, and edge senses within surfaces
            if( dim == 0 ) continue;
            const EntityHandle *conn3 = NULL, *conn2 = NULL;
            int len3 = 0, len2 = 0, err = 0, num = 0, sense = 0, offset = 0;
            for( size_t i = 0; i < parents.size(); ++i )
                result = mdbImpl->get_connectivity( dp1ents[i], conn3, len3, true );MB_CHK_SET_ERR( result, "Failed to get the connectivity of the element" );
                result = mdbImpl->get_connectivity( dents.front(), conn2, len2, true );MB_CHK_SET_ERR( result, "Failed to get the connectivity of the first element" );
                if( len2 > 4 )
                    MB_SET_ERR( MB_FAILURE, "Connectivity of incorrect length" );
                err = CN::SideNumber( TYPE_FROM_HANDLE( dp1ents[i] ), conn3, conn2, len2, dim, num, sense, offset );
                if( err ) return MB_FAILURE;
                result = set_sense( *d_it, parents[i], sense );
                if( MB_MULTIPLE_ENTITIES_FOUND == result )
                    if( 2 == dim )
                        std::cerr << "Warning: Multiple volumes use surface with same sense." << std::endl
                                  << "         Some geometric sense data lost." << std::endl;
                else if( MB_SUCCESS != result )
                    return result;
        // now delete owner tag on this dimension, automatically removes tag data
        result = mdbImpl->tag_delete( owner_tag );MB_CHK_SET_ERR( result, "Failed to delete the owner tag" );
    }  // dim
    return result;
Discover and store the topological relationships among a set of volumes This method may be used to discover the hierarchy that exists in a range of volumes, that have no previous sense of hierarchy, and store it according to the conventions of GeomTopoTool. The following requirements about the range of flat_volumes must be met: 1. Each volume must be represented by a single, closed surface a. The surface meshsets have triangles and vertices as members. b. For each "flat volume", there must be two meshsets: one for the volume and another for the surface that encloses it. These must be linked by a parent-child relationship. c. The SENSE_FORWARD tag on the surface meshset must be set to be the volume meshset it encloses. 2. The surfaces must not touch or overlap.
After the hierarchy is established, the topological relationships between surfaces and the volumes that enclose them are set. This involves: 1. Setting parent-child relationship between surfaces and the volumes that enclose them. 2. Setting the SENSE_REVERSE tag on the surfaces to be the volume that encloses them.
Definition at line 2024 of file GeomTopoTool.cpp.
References moab::Interface::add_parent_child(), moab::Range::begin(), moab::Interface::create_meshset(), moab::Range::end(), ErrorCode, get_ct_children_by_dimension(), GQT, insert_in_tree(), MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, mdbImpl, MESHSET_SET, nameTag, moab::Interface::remove_parent_child(), SENSE_REVERSE, set_sense(), moab::Range::size(), and moab::Interface::tag_set_data().
Referenced by heappermute().
    ErrorCode rval;
    // local var will go out of scope if errors appear, no need to free it also
    GeomQueryTool GQT( this );
    std::map< EntityHandle, EntityHandle > volume_surface;  // map of volume
                                                            // to its surface
    EntityHandle ct_root;
    // create root meshset-- this will be top of tree
    std::string meshset_name = "build_hierarchy_root";
    rval                     = mdbImpl->create_meshset( MESHSET_SET, ct_root );MB_CHK_ERR( rval );
    rval = mdbImpl->tag_set_data( nameTag, &ct_root, 1, meshset_name.c_str() );MB_CHK_ERR( rval );
    for( Range::iterator vol = flat_volumes.begin(); vol != flat_volumes.end(); vol++ )
        // get the surface corresponding to each volume
        // at this point, each volume meshset only has one 'child' surface
        // which exactly corresponds to that volume
        Range child_surfaces = get_ct_children_by_dimension( *vol, 2 );
        volume_surface[*vol] = *child_surfaces.begin();
        rval = insert_in_tree( ct_root, *vol, &GQT );MB_CHK_SET_ERR( rval, "Failed to insert volume into tree." );
    // for each original volume, get its child volumes
    for( Range::iterator parent_it = flat_volumes.begin(); parent_it != flat_volumes.end(); parent_it++ )
        Range volume_children = get_ct_children_by_dimension( *parent_it, 3 );
        if( volume_children.size() != 0 )
            // loop over all of original volume's child volumes
            for( Range::iterator child_it = volume_children.begin(); child_it != volume_children.end(); ++child_it )
                // set the sense of the surface mapped to the child volume to REVERSE
                // wrt the parent volume
                rval = set_sense( volume_surface[*child_it], *parent_it, SENSE_REVERSE );MB_CHK_SET_ERR( rval, "Failed to set sense." );
                // add the child volume's surface as a child of the original volume
                // and delete the child volume as a child of original volume
                rval = mdbImpl->add_parent_child( *parent_it, volume_surface[*child_it] );MB_CHK_SET_ERR( rval, "Failed to add parent-child relationship." );
                rval = mdbImpl->remove_parent_child( *parent_it, *child_it );MB_CHK_SET_ERR( rval, "Failed to remove parent-child relationship." );
    return MB_SUCCESS;
ErrorCode moab::GeomTopoTool::separate_by_dimension ( const Range geom_sets) [private]
Given a range of geom topology sets, separate by dimension.
Definition at line 706 of file GeomTopoTool.cpp.
References moab::Range::begin(), check_geom_tag(), moab::Range::end(), ErrorCode, geomRanges, geomTag, gidTag, moab::Interface::globalId_tag(), moab::Range::insert(), maxGlobalId, MB_CHK_SET_ERR, MB_SUCCESS, mdbImpl, moab::Range::size(), and moab::Interface::tag_get_data().
Referenced by find_geomsets().
    ErrorCode result;
    result = check_geom_tag();MB_CHK_SET_ERR( result, "Could not verify geometry dimension tag" );
    std::vector< int > tag_vals( geom_sets.size() );
    result = mdbImpl->tag_get_data( geomTag, geom_sets, &tag_vals[0] );MB_CHK_SET_ERR( result, "Failed to get the geometry dimension tag" );
    Range::const_iterator git;
    std::vector< int >::iterator iit;
        this->geomRanges[i].clear();
    for( git = geom_sets.begin(), iit = tag_vals.begin(); git != geom_sets.end(); ++git, ++iit )
        if( 0 <= *iit && 4 >= *iit )
            geomRanges[*iit].insert( *git );
        else
            // assert(false);
            // do nothing for now
    // establish the max global ids so far, per dimension
    if( 0 == gidTag )
        gidTag = mdbImpl->globalId_tag();
    for( int i = 0; i <= 4; i++ )
        maxGlobalId[i] = 0;
        for( Range::iterator it = geomRanges[i].begin(); it != geomRanges[i].end(); ++it )
            int gid;
            result = mdbImpl->tag_get_data( gidTag, &set, 1, &gid );
            if( MB_SUCCESS == result )
                if( gid > maxGlobalId[i] ) maxGlobalId[i] = gid;
    return MB_SUCCESS;
Definition at line 498 of file GeomTopoTool.cpp.
References ErrorCode, m_rootSets_vector, mapRootSets, MB_CHK_SET_ERR, MB_SUCCESS, mdbImpl, obbGsetTag, obbRootTag, rootSets, setOffset, and moab::Interface::tag_set_data().
    // Tag the vol or surf with its obb root (obbRootTag)
    ErrorCode rval;
    rval = mdbImpl->tag_set_data( obbRootTag, &vol_or_surf, 1, &root );MB_CHK_SET_ERR( rval, "Failed to set the obb root tag" );
    // Tag obb root with corresponding gset (obbGsetTag)
    rval = mdbImpl->tag_set_data( obbGsetTag, &root, 1, &vol_or_surf );MB_CHK_SET_ERR( rval, "Failed to set the obb gset tag" );
    // Add to the set of all roots
        rootSets[vol_or_surf - setOffset] = root;
    else
        mapRootSets[vol_or_surf] = root;
    return MB_SUCCESS;
ErrorCode moab::GeomTopoTool::set_sense ( EntityHandle  entity,
EntityHandle  wrt_entity,
int  sense
Store sense of entity relative to wrt_entity.
Returns:
MB_MULTIPLE_ENTITIES_FOUND if surface already has a forward volume. MB_SUCCESS if successful otherwise whatever internal error code occured.
Returns:
MB_MULTIPLE_ENTITIES_FOUND if surface already has a forward volume. MB_SUCCESS if successful otherwise whatever internal error code occurred.
Definition at line 804 of file GeomTopoTool.cpp.
References check_edge_sense_tags(), check_face_sense_tag(), dimension(), ErrorCode, get_senses(), MB_CHK_SET_ERR, MB_MULTIPLE_ENTITIES_FOUND, MB_SET_ERR, MB_SUCCESS, MB_TAG_NOT_FOUND, mdbImpl, sense2Tag, SENSE_BOTH, senseNEntsTag, senseNSensesTag, moab::Interface::tag_get_data(), moab::Interface::tag_set_by_ptr(), and moab::Interface::tag_set_data().
Referenced by build_cube(), moab::ReadOBJ::create_new_object(), moab::FBEngine::create_volume_with_direction(), geometrize_surface_set(), moab::FBEngine::redistribute_boundary_edges_to_faces(), restore_topology_from_adjacency(), restore_topology_from_geometric_inclusion(), set_senses(), moab::ReadRTT::set_surface_senses(), moab::FBEngine::split_bedge_at_new_mesh_node(), moab::FBEngine::split_edge_at_mesh_node(), moab::FBEngine::split_surface(), moab::ReadCGM::store_surface_senses(), and moab::FBEngine::weave_lateral_face_from_edges().
    if( sense < -1 || sense > 1 ) MB_SET_ERR( MB_FAILURE, "Invalid sense data provided" );
    ErrorCode rval;
    if( 1 == edim )
        // this case is about setting the sense of an edge in a face
        // it could be -1, 0 (rare, non manifold), or 1
        std::vector< EntityHandle > higher_ents;
        rval = get_senses( entity, higher_ents, senses );  // the tags should be defined here
        // if there are no higher_ents, we are fine, we will just set them
        // if wrt_entity is not among higher_ents, we will add it to the list
        // it is possible the entity (edge set) has no prior faces adjancent; in that case, the
        // tag would not be set, and rval could be MB_TAG_NOT_FOUND; it is not a fatal error
        if( MB_SUCCESS != rval && MB_TAG_NOT_FOUND != rval )
            MB_CHK_SET_ERR( rval, "cannot determine sense tags for edge" );
        bool append = true;
        if( !higher_ents.empty() )
            std::vector< EntityHandle >::iterator it = std::find( higher_ents.begin(), higher_ents.end(), wrt_entity );
            if( it != higher_ents.end() )
                // we should not reset the sense, if the sense is the same
                // if the sense is different, put BOTH
                unsigned int idx = it - higher_ents.begin();
                int oldSense     = senses[idx];
                if( oldSense == sense ) return MB_SUCCESS;  // sense already set fine, do not reset
                if( 0 != oldSense && oldSense + sense != 0 ) return MB_MULTIPLE_ENTITIES_FOUND;
                senses[idx] = SENSE_BOTH;  // allow double senses
                // do not need to add a new sense, but still need to reset the tag
                // because of a new value
                append = false;
        if( append )
            // what happens if a var tag data was already set before, and now it is
            // reset with a different size??
            higher_ents.push_back( wrt_entity );
            senses.push_back( sense );
        // finally, set the senses :
        int dum_size  = higher_ents.size();
        void* dum_ptr = &higher_ents[0];
        rval          = mdbImpl->tag_set_by_ptr( senseNEntsTag, &entity, 1, &dum_ptr, &dum_size );MB_CHK_SET_ERR( rval, "Failed to set the sense data" );
        dum_ptr  = &senses[0];
        rval     = mdbImpl->tag_set_by_ptr( senseNSensesTag, &entity, 1, &dum_ptr, &dum_size );MB_CHK_SET_ERR( rval, "Failed to set the sense data by pointer" );
    else
        // this case is about a face in the volume
        // there could be only 2 volumes
        rval = check_face_sense_tag( true );MB_CHK_SET_ERR( rval, "Failed to verify the face sense tag" );
        if( MB_TAG_NOT_FOUND != rval && MB_SUCCESS != rval ) MB_CHK_SET_ERR( rval, "Failed to get the sense2Tag data" );
        if( 0 == sense )
            if( 0 != sense_data[0] && wrt_entity != sense_data[0] ) return MB_MULTIPLE_ENTITIES_FOUND;
            if( 0 != sense_data[1] && wrt_entity != sense_data[1] ) return MB_MULTIPLE_ENTITIES_FOUND;
            sense_data[0] = sense_data[1] = wrt_entity;
        else if( -1 == sense )
            if( sense_data[1] == wrt_entity ) return MB_SUCCESS;  // already set as we want
        else if( 1 == sense )
            if( sense_data[0] == wrt_entity ) return MB_SUCCESS;  // already set as we want
            sense_data[0] = wrt_entity;
        return mdbImpl->tag_set_data( sense2Tag, &entity, 1, sense_data );
    return MB_SUCCESS;
ErrorCode moab::GeomTopoTool::set_senses ( EntityHandle  entity,
Set the senses of the entity wrt multiple higher dimension entities.
Definition at line 1089 of file GeomTopoTool.cpp.
References ErrorCode, MB_CHK_SET_ERR, MB_SUCCESS, and set_sense().
Referenced by create_shell_test(), duplicate_model(), and moab::ReadCGM::store_curve_senses().
    // not efficient, and maybe wrong
    for( unsigned int i = 0; i < wrt_entities.size(); i++ )
        ErrorCode rval = set_sense( entity, wrt_entities[i], senses[i] );MB_CHK_SET_ERR( rval, "Failed to set the sense" );
    return MB_SUCCESS;
ErrorCode moab::GeomTopoTool::set_surface_senses ( EntityHandle  surface_ent,
Set the senses of a surface with respect to its volumes.
Definition at line 969 of file GeomTopoTool.cpp.
References dimension(), ErrorCode, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, mdbImpl, sense2Tag, and moab::Interface::tag_set_data().
Referenced by generate_implicit_complement().
    ErrorCode rval;
    // this mthod should only be called to retrieve surface to volume
    if( ent_dim != 2 )
    // set the sense information for this surface
    EntityHandle parent_vols[2] = { forward_vol, reverse_vol };
    rval                        = mdbImpl->tag_set_data( sense2Tag, &surface_ent, 1, parent_vols );MB_CHK_SET_ERR( rval, "Failed to set surface sense data" );
    return MB_SUCCESS;
sets the implicit complement handle for this tool
Definition at line 1613 of file GeomTopoTool.cpp.
References add_geo_set(), category_tag, CATEGORY_TAG_NAME, CATEGORY_TAG_SIZE, moab::Range::empty(), entities, ErrorCode, moab::Range::front(), generate_implicit_complement(), moab::Interface::get_entities_by_type_and_tag(), impl_compl_handle, moab::IMPLICIT_COMPLEMENT_NAME, MB_CHK_SET_ERR, MB_MULTIPLE_ENTITIES_FOUND, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_OPAQUE, MBENTITYSET, mdbImpl, modelSet, nameTag, moab::Range::size(), moab::Interface::tag_get_handle(), and moab::Interface::tag_set_data().
Referenced by gqt_create_impl_compl(), gqt_load_file_dagmc_internal_build_obb(), gqt_load_file_dagmc_via_moab_build_obb(), and moab::GeomQueryTool::initialize().
    // if the implicit complement is already setup,
    // we're done
    if( impl_compl_handle != 0 )
        std::cout << "IPC already exists!" << std::endl;
        return MB_SUCCESS;
    // if not, then query for a set with it's name
    Range entities;
    const void* const tagdata[] = { IMPLICIT_COMPLEMENT_NAME };
    ErrorCode rval = mdbImpl->get_entities_by_type_and_tag( modelSet, MBENTITYSET, &nameTag, tagdata, 1, entities );
    // query error
    MB_CHK_SET_ERR( rval, "Unable to query for implicit complement" );
    // if we found exactly one, set it as the implicit complement
    if( entities.size() == 1 )
        impl_compl_handle = entities.front();
        return MB_SUCCESS;
    // found too many
    if( entities.size() > 1 ) MB_CHK_SET_ERR( MB_MULTIPLE_ENTITIES_FOUND, "Too many implicit complement sets" );
    // found none
    if( entities.empty() )
        // create implicit complement if requested
        rval = generate_implicit_complement( impl_compl_handle );MB_CHK_SET_ERR( rval, "Could not create implicit complement" );
        rval = mdbImpl->tag_set_data( nameTag, &impl_compl_handle, 1, &IMPLICIT_COMPLEMENT_NAME );MB_CHK_SET_ERR( rval, "Could not set the name tag for the implicit complement" );
        rval = add_geo_set( impl_compl_handle, 3 );MB_CHK_SET_ERR( rval, "Failed to add implicit complement to model" );
        // assign category tag - this is presumably for consistency so that the
        // implicit complement has all the appearance of being the same as any
        // other volume
        Tag category_tag;
        rval = mdbImpl->tag_get_handle( CATEGORY_TAG_NAME, CATEGORY_TAG_SIZE, MB_TYPE_OPAQUE, category_tag,
                                        MB_TAG_SPARSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Could not get the category tag" );
        static const char volume_category[CATEGORY_TAG_SIZE] = "Volume\0";
        rval = mdbImpl->tag_set_data( category_tag, &impl_compl_handle, 1, volume_category );MB_CHK_SET_ERR( rval, "Could not set the category tag for the implicit complement" );
        return MB_SUCCESS;
    return MB_FAILURE;
Member Data Documentation
Definition at line 299 of file GeomTopoTool.hpp.
Referenced by add_geo_set(), GeomTopoTool(), and separate_by_dimension().
Definition at line 300 of file GeomTopoTool.hpp.
Referenced by add_geo_set().
List of all members.
