moab::Interface::HONodeAddedRemoved Class Reference
function object for recieving events from MB of higher order nodes added to entities More...
#include <Interface.hpp>
+ Inheritance diagram for moab::Interface::HONodeAddedRemoved:
Public Member Functions
 HONodeAddedRemoved ()
 Constructor.
virtual ~HONodeAddedRemoved ()
 Destructor.
virtual void node_added (EntityHandle node, EntityHandle element)=0
virtual void node_removed (EntityHandle node)=0
Detailed Description
Definition at line 1134 of file Interface.hpp.
Constructor.
Definition at line 1138 of file Interface.hpp.
Destructor.
Definition at line 1141 of file Interface.hpp.
Member Function Documentation
virtual void moab::Interface::HONodeAddedRemoved::node_added ( EntityHandle  node,
) [pure virtual]
node_added called when a node was added to an element's connectivity array note: connectivity array of element may be incomplete (corner nodes will exist always)
Parameters:
nodeNode being added
elementElement node is being added to
Implemented in OffsetHexCenterNodes.
Referenced by moab::HigherOrderFactory::add_mid_edge_nodes(), moab::HigherOrderFactory::add_mid_face_nodes(), and moab::HigherOrderFactory::add_mid_volume_nodes().
virtual void moab::Interface::HONodeAddedRemoved::node_removed ( EntityHandle  node) [pure virtual]
Parameters:
nodeNode being removed.
Referenced by moab::HigherOrderFactory::convert_sequence().
List of all members.
