moab::Intx2Mesh Class Reference
#include <Intx2Mesh.hpp>
+ Inheritance diagram for moab::Intx2Mesh:
+ Collaboration diagram for moab::Intx2Mesh:
Public Member Functions
 Intx2Mesh (Interface *mbimpl)
virtual ~Intx2Mesh ()
ErrorCode intersect_meshes (EntityHandle mbs1, EntityHandle mbs2, EntityHandle &outputSet)
ErrorCode intersect_meshes_kdtree (EntityHandle mbset1, EntityHandle mbset2, EntityHandle &outputSet)
virtual ErrorCode computeIntersectionBetweenTgtAndSrc (EntityHandle tgt, EntityHandle src, double *P, int &nP, double &area, int markb[MAXEDGES], int markr[MAXEDGES], int &nsidesSrc, int &nsidesTgt, bool check_boxes_first=false)=0
virtual ErrorCode findNodes (EntityHandle tgt, int nsTgt, EntityHandle src, int nsSrc, double *iP, int nP)=0
virtual double setup_tgt_cell (EntityHandle tgt, int &nsTgt)=0
virtual ErrorCode FindMaxEdgesInSet (EntityHandle eset, int &max_edges)
virtual ErrorCode FindMaxEdges (EntityHandle set1, EntityHandle set2)
virtual ErrorCode createTags ()
ErrorCode DetermineOrderedNeighbors (EntityHandle inputSet, int max_edges, Tag &neighTag)
void set_error_tolerance (double eps)
void clean ()
void set_box_error (double berror)
ErrorCode create_departure_mesh_2nd_alg (EntityHandle &euler_set, EntityHandle &covering_lagr_set)
ErrorCode create_departure_mesh_3rd_alg (EntityHandle &lagr_set, EntityHandle &covering_set)
void correct_polygon (EntityHandle *foundIds, int &nP)
Protected Attributes
Interfacemb
EntityHandle mbs1
EntityHandle mbs2
Range rs1
Range rs2
EntityHandle outSet
Tag gid
Tag TgtFlagTag
Range TgtEdges
Tag tgtParentTag
Tag srcParentTag
Tag countTag
Tag srcNeighTag
Tag tgtNeighTag
Tag neighTgtEdgeTag
Tag orgSendProcTag
const EntityHandletgtConn
 for coverage mesh, will store the original sender
const EntityHandlesrcConn
CartVect tgtCoords [MAXEDGES]
CartVect srcCoords [MAXEDGES]
double tgtCoords2D [MAXEDGES2]
double srcCoords2D [MAXEDGES2]
std::vector< std::vector
< EntityHandle > * >
extraNodesVec
double epsilon_1
double epsilon_area
std::vector< double > allBoxes
double box_error
EntityHandle localRoot
Range localEnts
unsigned int my_rank
int max_edges_1
int max_edges_2
int counting
Detailed Description
Definition at line 55 of file Intx2Mesh.hpp.
Definition at line 28 of file Intx2Mesh.cpp.
References gid, and moab::Interface::globalId_tag().
    : mb( mbimpl ), mbs1( 0 ), mbs2( 0 ), outSet( 0 ), gid( 0 ), TgtFlagTag( 0 ), tgtParentTag( 0 ), srcParentTag( 0 ),
      countTag( 0 ), srcNeighTag( 0 ), tgtNeighTag( 0 ), neighTgtEdgeTag( 0 ), orgSendProcTag( 0 ), tgtConn( NULL ),
      srcConn( NULL ), epsilon_1( 0.0 ), epsilon_area( 0.0 ), box_error( 0.0 ), localRoot( 0 ), my_rank( 0 )
#ifdef MOAB_HAVE_MPI
      parcomm( NULL ), remote_cells( NULL ), remote_cells_with_tracers( NULL )
#endif
      max_edges_1( 0 ), max_edges_2( 0 ), counting( 0 )
    gid = mbimpl->globalId_tag();
Definition at line 42 of file Intx2Mesh.cpp.
    // TODO Auto-generated destructor stub
    if( remote_cells )
        delete remote_cells;
        remote_cells = NULL;
#endif
Member Function Documentation
Definition at line 796 of file Intx2Mesh.cpp.
References moab::Range::begin(), counting, moab::Range::end(), extraNodesVec, mb, moab::Interface::tag_delete(), TgtEdges, and TgtFlagTag.
Referenced by intersect_meshes(), and intersect_meshes_kdtree().
    int indx = 0;
    for( Range::iterator eit = TgtEdges.begin(); eit != TgtEdges.end(); ++eit, indx++ )
        delete extraNodesVec[indx];
    // extraNodesMap.clear();
    extraNodesVec.clear();
    // also, delete some bit tags, used to mark processed tgts and srcs
    mb->tag_delete( TgtFlagTag );
    counting = 0;  // reset counting to original value
virtual ErrorCode moab::Intx2Mesh::computeIntersectionBetweenTgtAndSrc ( EntityHandle  tgt,
EntityHandle  src,
double *  P,
int &  nP,
double &  area,
int &  nsidesSrc,
int &  nsidesTgt,
bool  check_boxes_first = false
) [pure virtual]
void moab::Intx2Mesh::correct_polygon ( EntityHandle foundIds,
int &  nP
Definition at line 813 of file Intx2Mesh.cpp.
Referenced by moab::Intx2MeshInPlane::findNodes(), moab::IntxRllCssphere::findNodes(), and moab::Intx2MeshOnSphere::findNodes().
    int i = 0;
    while( i < nP )
        int nextIndex = ( i + 1 ) % nP;
        if( nodes[i] == nodes[nextIndex] )
#ifdef ENABLE_DEBUG
            // we need to reduce nP, and collapse nodes
            if( dbg_1 )
                std::cout << " nodes duplicated in list: ";
                for( int j = 0; j < nP; j++ )
                    std::cout << nodes[j] << " ";
                std::cout << "\n";
                std::cout << " node " << nodes[i] << " at index " << i << " is duplicated"
                          << "\n";
#endif
            // this will work even if we start from 1 2 3 1; when i is 3, we find nextIndex is 0,
            // then next thing does nothing
            //  (nP-1 is 3, so k is already >= nP-1); it will result in nodes -> 1, 2, 3
            for( int k = i; k < nP - 1; k++ )
                nodes[k] = nodes[k + 1];
            nP--;  // decrease the number of nodes; also, decrease i, just if we may need to check
                   // again
            i--;
        i++;
    return;
Definition at line 90 of file Intx2Mesh.cpp.
References moab::Range::begin(), countTag, DetermineOrderedNeighbors(), moab::Range::end(), ErrorCode, extraNodesVec, moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), moab::Interface::INTERSECT, max_edges_1, max_edges_2, mb, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_BIT, MB_TYPE_HANDLE, MB_TYPE_INTEGER, mbs1, mbs2, neighTgtEdgeTag, rs2, moab::Range::size(), srcNeighTag, srcParentTag, moab::Interface::tag_delete(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), tgtConn, TgtEdges, TgtFlagTag, tgtNeighTag, tgtParentTag, and moab::Interface::UNION.
Referenced by intersect_meshes().
    if( tgtParentTag ) mb->tag_delete( tgtParentTag );
    if( srcParentTag ) mb->tag_delete( srcParentTag );
    if( countTag ) mb->tag_delete( countTag );
    unsigned char def_data_bit = 0;  // unused by default
    // maybe the tgt tag is better to be deleted every time, and recreated;
    // or is it easy to set all values to something again? like 0?
    ErrorCode rval = mb->tag_get_handle( "tgtFlag", 1, MB_TYPE_BIT, TgtFlagTag, MB_TAG_CREAT, &def_data_bit );MB_CHK_SET_ERR( rval, "can't get tgt flag tag" );
    // create tgt edges if they do not exist yet; so when they are looked upon, they are found
    // this is the only call that is potentially NlogN, in the whole method
    rval = mb->get_adjacencies( rs2, 1, true, TgtEdges, Interface::UNION );MB_CHK_SET_ERR( rval, "can't get adjacent tgt edges" );
    // now, create a map from each edge to a list of potential new nodes on a tgt edge
    // this memory has to be cleaned up
    // change it to a vector, and use the index in range of tgt edges
    int indx = 0;
    extraNodesVec.resize( TgtEdges.size() );
        std::vector< EntityHandle >* nv = new std::vector< EntityHandle >;
        extraNodesVec[indx]             = nv;
    int defaultInt = -1;
    rval = mb->tag_get_handle( "TargetParent", 1, MB_TYPE_INTEGER, tgtParentTag, MB_TAG_DENSE | MB_TAG_CREAT,
                               &defaultInt );MB_CHK_SET_ERR( rval, "can't create positive tag" );
    rval = mb->tag_get_handle( "SourceParent", 1, MB_TYPE_INTEGER, srcParentTag, MB_TAG_DENSE | MB_TAG_CREAT,
                               &defaultInt );MB_CHK_SET_ERR( rval, "can't create negative tag" );
    rval = mb->tag_get_handle( "Counting", 1, MB_TYPE_INTEGER, countTag, MB_TAG_DENSE | MB_TAG_CREAT, &defaultInt );MB_CHK_SET_ERR( rval, "can't create Counting tag" );
    // for each cell in set 1, determine its neigh in set 1 (could be null too)
    // for each cell in set 2, determine its neigh in set 2 (if on boundary, could be 0)
    rval = DetermineOrderedNeighbors( mbs1, max_edges_1, srcNeighTag );MB_CHK_SET_ERR( rval, "can't determine neighbors for set 1" );
    rval = DetermineOrderedNeighbors( mbs2, max_edges_2, tgtNeighTag );MB_CHK_SET_ERR( rval, "can't determine neighbors for set 2" );
    // for tgt cells, save a dense tag with the bordering edges, so we do not have to search for
    // them each time edges were for sure created before (tgtEdges)
    std::vector< EntityHandle > zeroh( max_edges_2, 0 );
    // if we have a tag with this name, it could be of a different size, so delete it
    rval = mb->tag_get_handle( "__tgtEdgeNeighbors", neighTgtEdgeTag );
    if( rval == MB_SUCCESS && neighTgtEdgeTag ) mb->tag_delete( neighTgtEdgeTag );
    rval = mb->tag_get_handle( "__tgtEdgeNeighbors", max_edges_2, MB_TYPE_HANDLE, neighTgtEdgeTag,
                               MB_TAG_DENSE | MB_TAG_CREAT, &zeroh[0] );MB_CHK_SET_ERR( rval, "can't create tgt edge neighbors tag" );
    for( Range::iterator rit = rs2.begin(); rit != rs2.end(); rit++ )
        EntityHandle tgtCell = *rit;
        int num_nodes        = 0;
        rval                 = mb->get_connectivity( tgtCell, tgtConn, num_nodes );MB_CHK_SET_ERR( rval, "can't get  tgt conn" );
        // account for padded polygons
        while( tgtConn[num_nodes - 2] == tgtConn[num_nodes - 1] && num_nodes > 3 )
            num_nodes--;
        int i = 0;
        for( i = 0; i < num_nodes; i++ )
            EntityHandle v[2] = { tgtConn[i],
                                  tgtConn[( i + 1 ) % num_nodes] };  // this is fine even for padded polygons
            std::vector< EntityHandle > adj_entities;
            rval = mb->get_adjacencies( v, 2, 1, false, adj_entities, Interface::INTERSECT );
            if( rval != MB_SUCCESS || adj_entities.size() < 1 ) return rval;  // get out , big error
            zeroh[i] = adj_entities[0];                                       // should be only one edge between 2 nodes
            // also, even if number of edges is less than max_edges_2, they will be ignored, even if
            // the tag is dense
        // now set the value of the tag
        rval = mb->tag_set_data( neighTgtEdgeTag, &tgtCell, 1, &( zeroh[0] ) );MB_CHK_SET_ERR( rval, "can't set edge tgt tag" );
    return MB_SUCCESS;
ErrorCode moab::Intx2Mesh::DetermineOrderedNeighbors ( EntityHandle  inputSet,
int  max_edges,
Tag neighTag
Definition at line 166 of file Intx2Mesh.cpp.
References moab::Range::begin(), moab::Interface::contains_entities(), moab::Range::end(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), moab::Interface::get_entities_by_dimension(), moab::Interface::INTERSECT, moab::Interface::list_entities(), mb, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_HANDLE, neighbors(), moab::Interface::tag_get_handle(), and moab::Interface::tag_set_data().
Referenced by createTags().
    Range cells;
    ErrorCode rval = mb->get_entities_by_dimension( inputSet, 2, cells );MB_CHK_SET_ERR( rval, "can't get cells in set" );
    std::vector< EntityHandle > neighbors( max_edges );
    std::vector< EntityHandle > zeroh( max_edges, 0 );
    // nameless tag, as the name is not important; we will have 2 related tags, but one on tgt mesh,
    // one on src mesh
    rval = mb->tag_get_handle( "", max_edges, MB_TYPE_HANDLE, neighTag, MB_TAG_DENSE | MB_TAG_CREAT, &zeroh[0] );MB_CHK_SET_ERR( rval, "can't create neighbors tag" );
    for( Range::iterator cit = cells.begin(); cit != cells.end(); cit++ )
        EntityHandle cell = *cit;
        int nnodes        = 3;
        // will get the nnodes ordered neighbors;
        // first cell is for nodes 0, 1, second to 1, 2, third to 2, 3, last to nnodes-1,
        const EntityHandle* conn4;
        rval = mb->get_connectivity( cell, conn4, nnodes );MB_CHK_SET_ERR( rval, "can't get connectivity of a cell" );
        int nsides = nnodes;
        // account for possible padded polygons
        while( conn4[nsides - 2] == conn4[nsides - 1] && nsides > 3 )
            nsides--;
        for( int i = 0; i < nsides; i++ )
            EntityHandle v[2];
            v[0] = conn4[i];
            v[1] = conn4[( i + 1 ) % nsides];
            // get all cells adjacent to these 2 vertices on the edge
            std::vector< EntityHandle > adjcells;
            std::vector< EntityHandle > cellsInSet;
            rval = mb->get_adjacencies( v, 2, 2, false, adjcells, Interface::INTERSECT );MB_CHK_SET_ERR( rval, "can't adjacency to 2 verts" );
            // now look for the cells contained in the input set;
            // the input set should be a correct mesh, not overlapping cells, and manifold
            size_t siz = adjcells.size();
            for( size_t j = 0; j < siz; j++ )
                if( mb->contains_entities( inputSet, &( adjcells[j] ), 1 ) ) cellsInSet.push_back( adjcells[j] );
            siz = cellsInSet.size();
            if( siz > 2 )
                std::cout << "non manifold mesh, error" << mb->list_entities( &( cellsInSet[0] ), cellsInSet.size() )
                          << "\n";MB_CHK_SET_ERR( MB_FAILURE, "non-manifold input mesh set" );  // non-manifold
            if( siz == 1 )
                // it must be the border of the input mesh;
                neighbors[i] = 0;  // we are guaranteed that ids are !=0; this is marking a border
                // borders do not appear for a sphere in serial, but they do appear for
                // parallel processing anyway
                continue;
            // here siz ==2, it is either the first or second
            if( cell == cellsInSet[0] )
                neighbors[i] = cellsInSet[1];
            else
                neighbors[i] = cellsInSet[0];
        // fill the rest with 0
        for( int i = nsides; i < max_edges; i++ )
            neighbors[i] = 0;
        // now simply set the neighbors tag; the last few positions will not be used, but for
        // simplicity will keep them all (MAXEDGES)
        rval = mb->tag_set_data( neighTag, &cell, 1, &neighbors[0] );MB_CHK_SET_ERR( rval, "can't set neigh tag" );
    return MB_SUCCESS;
Definition at line 82 of file Intx2Mesh.cpp.
References ErrorCode, FindMaxEdgesInSet(), max_edges_1, max_edges_2, MB_CHK_SET_ERR, and MB_SUCCESS.
Referenced by moab::TempestRemapper::ConstructCoveringSet(), main(), test_intx_in_parallel_elem_based(), and test_intx_mpas().
    ErrorCode rval = FindMaxEdgesInSet( set1, max_edges_1 );MB_CHK_SET_ERR( rval, "can't determine max_edges in set 1" );
    rval = FindMaxEdgesInSet( set2, max_edges_2 );MB_CHK_SET_ERR( rval, "can't determine max_edges in set 2" );
    return MB_SUCCESS;
ErrorCode moab::Intx2Mesh::FindMaxEdgesInSet ( EntityHandle  eset,
int &  max_edges
) [virtual]
Definition at line 53 of file Intx2Mesh.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_dimension(), mb, MB_CHK_ERR, MB_CHK_SET_ERR, and MB_SUCCESS.
Referenced by FindMaxEdges().
    Range cells;
    ErrorCode rval = mb->get_entities_by_dimension( eset, 2, cells );MB_CHK_ERR( rval );
    max_edges = 0;  // can be 0 for point clouds
        int nnodes = 3;
        if( nnodes > max_edges ) max_edges = nnodes;
    // if in parallel, communicate the actual max_edges; it is not needed for tgt mesh (to be
    // global) but it is better to be consistent
    if( parcomm )
        int local_max_edges = max_edges;
        // now reduce max_edges over all processors
        int mpi_err =
            MPI_Allreduce( &local_max_edges, &max_edges, 1, MPI_INT, MPI_MAX, parcomm->proc_config().proc_comm() );
        if( MPI_SUCCESS != mpi_err ) return MB_FAILURE;
#endif
    return MB_SUCCESS;
virtual ErrorCode moab::Intx2Mesh::findNodes ( EntityHandle  tgt,
int  nsTgt,
EntityHandle  src,
int  nsSrc,
double *  iP,
int  nP
) [pure virtual]
Definition at line 439 of file Intx2Mesh.cpp.
References moab::Range::begin(), moab::AdaptiveKDTree::build_tree(), clean(), moab::Range::clear(), computeIntersectionBetweenTgtAndSrc(), counting, createTags(), moab::AdaptiveKDTree::distance_search(), moab::Range::empty(), moab::Range::end(), epsilon_1, moab::Range::erase(), ErrorCode, moab::Range::find(), findNodes(), moab::Range::front(), moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_dimension(), moab::ID_FROM_HANDLE(), moab::Interface::id_from_handle(), moab::Range::insert(), moab::Interface::list_entities(), MAXEDGES, mb, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, mbs1, mbs2, moab::Range::merge(), my_rank, neighbors(), nr, outSet, P, rs1, rs2, setup_tgt_cell(), size, moab::Range::size(), srcNeighTag, moab::Interface::tag_get_data(), moab::Interface::tag_set_data(), TgtFlagTag, tgtNeighTag, and moab::Interface::write_mesh().
Referenced by compute_tracer_case1(), moab::TempestRemapper::ComputeOverlapMesh(), intersection_at_level(), main(), test_intx_in_parallel_elem_based(), test_intx_mpas(), and update_tracer().
    ErrorCode rval;
    mbs1   = mbset1;  // set 1 is departure, and it is completely covering the euler set on proc
    mbs2   = mbset2;
    outSet = outputSet;
#ifdef VERBOSE
    std::stringstream ffs, fft;
    ffs << "source_rank0" << my_rank << ".vtk";
    rval = mb->write_mesh( ffs.str().c_str(), &mbset1, 1 );MB_CHK_ERR( rval );
    fft << "target_rank0" << my_rank << ".vtk";
    rval = mb->write_mesh( fft.str().c_str(), &mbset2, 1 );MB_CHK_ERR( rval );
#endif
    // really, should be something from t1 and t2; src is 1 (lagrange), tgt is 2 (euler)
    EntityHandle startSrc = 0, startTgt = 0;
    rval = mb->get_entities_by_dimension( mbs1, 2, rs1 );MB_CHK_ERR( rval );
    rval = mb->get_entities_by_dimension( mbs2, 2, rs2 );MB_CHK_ERR( rval );
    // std::cout << "rs1.size() = " << rs1.size() << " and rs2.size() = "  << rs2.size() << "\n";
    // std::cout.flush();
    createTags();  // will also determine max_edges_1, max_edges_2 (for src and tgt meshes)
    Range rs22 = rs2;  // a copy of the initial range; we will remove from it elements as we
                       // advance ; rs2 is needed for marking the polygon to the tgt parent
    // create the local kdd tree with source elements; will use it to search
    // more efficiently for the seeds in advancing front;
    // some of the target cells will not be covered by source cells, and they need to be eliminated
    // early from contention
    // build a kd tree with the rs1 (source) cells
    AdaptiveKDTree kd( mb );
    EntityHandle tree_root = 0;
    rval                   = kd.build_tree( rs1, &tree_root );MB_CHK_ERR( rval );
    while( !rs22.empty() )
#if defined( ENABLE_DEBUG ) || defined( VERBOSE )
        if( rs22.size() < rs2.size() )
            std::cout << " possible not connected arrival mesh; my_rank: " << my_rank << " counting: " << counting
                      << "\n";
            std::stringstream ffo;
            ffo << "file0" << counting << "rank0" << my_rank << ".vtk";
            rval = mb->write_mesh( ffo.str().c_str(), &outSet, 1 );MB_CHK_ERR( rval );
#endif
        bool seedFound = false;
        for( Range::iterator it = rs22.begin(); it != rs22.end(); ++it )
            startTgt  = *it;
            int found = 0;
            // find vertex positions
            const EntityHandle* conn = NULL;
            int nnodes               = 0;
            rval                     = mb->get_connectivity( startTgt, conn, nnodes );MB_CHK_ERR( rval );
            // find leaves close to those positions
            std::vector< double > positions;
            positions.resize( nnodes * 3 );
            rval = mb->get_coords( conn, nnodes, &positions[0] );MB_CHK_ERR( rval );
            // find leaves within a distance from each vertex of target
            // in those leaves, collect all cells; we will try for an intx in there, instead of
            // looping over all rs1 cells, as before
            Range close_source_cells;
            std::vector< EntityHandle > leaves;
            for( int i = 0; i < nnodes; i++ )
                leaves.clear();
                rval = kd.distance_search( &positions[3 * i], epsilon_1, leaves, epsilon_1, epsilon_1 );MB_CHK_ERR( rval );
                for( std::vector< EntityHandle >::iterator j = leaves.begin(); j != leaves.end(); ++j )
                    Range tmp;
                    rval = mb->get_entities_by_dimension( *j, 2, tmp );MB_CHK_ERR( rval );
                    close_source_cells.merge( tmp.begin(), tmp.end() );
            for( Range::iterator it2 = close_source_cells.begin(); it2 != close_source_cells.end() && !found; ++it2 )
                startSrc    = *it2;
                double area = 0;
                // if area is > 0 , we have intersections
                double P[10 * MAXEDGES];  // max 8 intx points + 8 more in the polygon
                int nP = 0;
                int nb[MAXEDGES], nr[MAXEDGES];  // sides 3 or 4? also, check boxes first
                int nsTgt, nsSrc;
                rval =
                    computeIntersectionBetweenTgtAndSrc( startTgt, startSrc, P, nP, area, nb, nr, nsSrc, nsTgt, true );MB_CHK_ERR( rval );
                if( area > 0 )
                    found     = 1;
                    seedFound = true;
                    break;  // found 2 elements that intersect; these will be the seeds
            if( found )
                break;
            else
#if defined( VERBOSE )
                std::cout << " on rank " << my_rank << " target cell " << ID_FROM_HANDLE( startTgt )
                          << " not intx with any source\n";
#endif
                rs22.erase( startTgt );
        if( !seedFound ) continue;  // continue while(!rs22.empty())
        std::queue< EntityHandle > srcQueue;  // these are corresponding to Ta,
        srcQueue.push( startSrc );
        std::queue< EntityHandle > tgtQueue;
        tgtQueue.push( startTgt );
        Range toResetSrcs;  // will be used to reset src flags for every tgt quad
        // processed
        /*if (my_rank==0)
          dbg_1 = 1;*/
        unsigned char used = 1;
        // mark the start tgt quad as used, so it will not come back again
        rval = mb->tag_set_data( TgtFlagTag, &startTgt, 1, &used );MB_CHK_ERR( rval );
        while( !tgtQueue.empty() )
            // flags for the side : 0 means a src cell not found on side
            // a paired src not found yet for the neighbors of tgt
            Range nextSrc[MAXEDGES];  // there are new ranges of possible next src cells for
                                      // seeding the side j of tgt cell
            EntityHandle currentTgt = tgtQueue.front();
            tgtQueue.pop();
            int nsidesTgt;                                                   // will be initialized now
            double areaTgtCell   = setup_tgt_cell( currentTgt, nsidesTgt );  // this is the area in the gnomonic plane
            double recoveredArea = 0;
            // get the neighbors of tgt, and if they are solved already, do not bother with that
            // side of tgt
            EntityHandle tgtNeighbors[MAXEDGES] = { 0 };
            rval                                = mb->tag_get_data( tgtNeighTag, &currentTgt, 1, tgtNeighbors );MB_CHK_SET_ERR( rval, "can't get neighbors of current tgt" );
#ifdef ENABLE_DEBUG
            if( dbg_1 )
                std::cout << "Next: neighbors for current tgt ";
                for( int kk = 0; kk < nsidesTgt; kk++ )
                    if( tgtNeighbors[kk] > 0 )
                        std::cout << mb->id_from_handle( tgtNeighbors[kk] ) << " ";
                    else
                        std::cout << 0 << " ";
                std::cout << std::endl;
#endif
            // now get the status of neighbors; if already solved, make them 0, so not to bother
            // anymore on that side of tgt
            for( int j = 0; j < nsidesTgt; j++ )
                EntityHandle tgtNeigh = tgtNeighbors[j];
                unsigned char status  = 1;
                if( tgtNeigh == 0 ) continue;
                rval = mb->tag_get_data( TgtFlagTag, &tgtNeigh, 1, &status );MB_CHK_ERR( rval );                     // status 0 is unused
                if( 1 == status ) tgtNeighbors[j] = 0;  // so will not look anymore on this side of tgt
#ifdef ENABLE_DEBUG
            if( dbg_1 )
                std::cout << "reset sources: ";
                for( Range::iterator itr = toResetSrcs.begin(); itr != toResetSrcs.end(); ++itr )
                    std::cout << mb->id_from_handle( *itr ) << " ";
#endif
            EntityHandle currentSrc = srcQueue.front();
            // tgt and src queues are parallel; for clarity we should have kept in the queue pairs
            // of entity handle std::pair<EntityHandle, EntityHandle>; so just one queue, with
            // pairs;
            //  at every moment, the queue contains pairs of cells that intersect, and they form the
            //  "advancing front"
            srcQueue.pop();
            toResetSrcs.clear();  // empty the range of used srcs, will have to be set unused again,
            // at the end of tgt element processing
            toResetSrcs.insert( currentSrc );
            // mb2->set_tag_data
            std::queue< EntityHandle > localSrc;
            localSrc.push( currentSrc );
#ifdef VERBOSE
            int countingStart = counting;
#endif
            // will advance-front search in the neighborhood of tgt cell, until we finish processing
            // all
            //   possible src cells; localSrc queue will contain all possible src cells that cover
            //   the current tgt cell
            while( !localSrc.empty() )
                EntityHandle srcT = localSrc.front();
                localSrc.pop();
                double P[10 * MAXEDGES], area;  //
                int nP           = 0;
                int nb[MAXEDGES] = { 0 };
                int nr[MAXEDGES] = { 0 };
                int nsidesSrc;  ///
                // area is in 2d, points are in 3d (on a sphere), back-projected, or in a plane
                // intersection points could include the vertices of initial elements
                // nb [j] = 0 means no intersection on the side j for element src (markers)
                // nb [j] = 1 means that the side j (from j to j+1) of src poly intersects the
                // tgt poly.  A potential next poly in the tgt queue is the tgt poly that is
                // adjacent to this side
                rval = computeIntersectionBetweenTgtAndSrc( /* tgt */ currentTgt, srcT, P, nP, area, nb, nr, nsidesSrc,
                                                            nsidesTgt );MB_CHK_ERR( rval );
                if( nP > 0 )
#ifdef ENABLE_DEBUG
                    if( dbg_1 )
                        for( int k = 0; k < 3; k++ )
                            std::cout << " nb, nr: " << k << " " << nb[k] << " " << nr[k] << "\n";
#endif
                    // intersection found: output P and original triangles if nP > 2
                    EntityHandle neighbors[MAXEDGES] = { 0 };
                    rval                             = mb->tag_get_data( srcNeighTag, &srcT, 1, neighbors );
                    if( rval != MB_SUCCESS )
                        std::cout << " can't get the neighbors for src element " << mb->id_from_handle( srcT );
                        return MB_FAILURE;
                    // add neighbors to the localSrc queue, if they are not marked
                    for( int nn = 0; nn < nsidesSrc; nn++ )
                        EntityHandle neighbor = neighbors[nn];
                        if( neighbor > 0 && nb[nn] > 0 )  // advance across src boundary nn
                            if( toResetSrcs.find( neighbor ) == toResetSrcs.end() )
                                localSrc.push( neighbor );
#ifdef ENABLE_DEBUG
                                if( dbg_1 )
                                    std::cout << " local src elem " << mb->id_from_handle( neighbor )
                                              << " for tgt:" << mb->id_from_handle( currentTgt ) << "\n";
                                    mb->list_entities( &neighbor, 1 );
#endif
                                toResetSrcs.insert( neighbor );
                    // n(find(nc>0))=ac;        % ac is starting candidate for neighbor
                    for( int nn = 0; nn < nsidesTgt; nn++ )
                        if( nr[nn] > 0 && tgtNeighbors[nn] > 0 )
                            nextSrc[nn].insert( srcT );  // potential src cell that can intersect
                                                         // the tgt neighbor nn
                    if( nP > 1 )
                    {  // this will also construct triangles/polygons in the new mesh, if needed
                        rval = findNodes( currentTgt, nsidesTgt, srcT, nsidesSrc, P, nP );MB_CHK_ERR( rval );
                    recoveredArea += area;
#ifdef ENABLE_DEBUG
                else if( dbg_1 )
                    std::cout << " tgt, src, do not intersect: " << mb->id_from_handle( currentTgt ) << " "
                              << mb->id_from_handle( srcT ) << "\n";
#endif
            }                                                               // end while (!localSrc.empty())
            recoveredArea = ( recoveredArea - areaTgtCell ) / areaTgtCell;  // replace now with recovery fraction
            if( fabs( recoveredArea ) > epsilon_1 )
#ifdef VERBOSE
                std::cout << " tgt area: " << areaTgtCell << " recovered :" << recoveredArea * ( 1 + areaTgtCell )
                          << " fraction error recovery:" << recoveredArea
                          << " tgtID: " << mb->id_from_handle( currentTgt ) << " countingStart:" << countingStart
                          << "\n";
#endif
#endif
            // here, we are finished with tgtCurrent, take it out of the rs22 range (tgt, arrival
            // mesh)
            rs22.erase( currentTgt );
            // also, look at its neighbors, and add to the seeds a next one
                if( tgtNeigh == 0 || nextSrc[j].size() == 0 )  // if tgt is bigger than src, there could be no src
                                                               // to advance on that side
                    continue;
                int nsidesTgt2 = 0;
                setup_tgt_cell( tgtNeigh,
                                nsidesTgt2 );  // find possible intersection with src cell from nextSrc
                for( Range::iterator nit = nextSrc[j].begin(); nit != nextSrc[j].end(); ++nit )
                    EntityHandle nextB = *nit;
                    // we identified tgt quad n[j] as possibly intersecting with neighbor j of the
                    // src quad
                    int nP           = 0;
                    int nsidesSrc;  ///
                        /* tgt */ tgtNeigh, nextB, P, nP, area, nb, nr, nsidesSrc, nsidesTgt2 );MB_CHK_ERR( rval );
                    if( area > 0 )
                        tgtQueue.push( tgtNeigh );
                        srcQueue.push( nextB );
#ifdef ENABLE_DEBUG
                        if( dbg_1 )
                            std::cout << "new polys pushed: src, tgt:" << mb->id_from_handle( tgtNeigh ) << " "
                                      << mb->id_from_handle( nextB ) << std::endl;
#endif
                        rval = mb->tag_set_data( TgtFlagTag, &tgtNeigh, 1, &used );MB_CHK_ERR( rval );
                        break;  // so we are done with this side of tgt, we have found a proper next
                                // seed
        }  // end while (!tgtQueue.empty())
#ifdef ENABLE_DEBUG
    if( dbg_1 )
        for( int k = 0; k < 6; k++ )
            mout_1[k].close();
#endif
    // before cleaning up , we need to settle the position of the intersection points
    // on the boundary edges
    // this needs to be collective, so we should maybe wait something
    rval = resolve_intersection_sharing();MB_CHK_SET_ERR( rval, "can't correct position, Intx2Mesh.cpp \n" );
#endif
    this->clean();
    return MB_SUCCESS;
Definition at line 237 of file Intx2Mesh.cpp.
References moab::Range::begin(), box_error, moab::AdaptiveKDTree::build_tree(), clean(), moab::Range::clear(), computeIntersectionBetweenTgtAndSrc(), countTag, moab::AdaptiveKDTree::distance_search(), moab::Range::empty(), moab::Range::end(), epsilon_1, ErrorCode, extraNodesVec, findNodes(), moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_dimension(), moab::Interface::id_from_handle(), moab::Interface::INTERSECT, max_edges_1, max_edges_2, MAXEDGES, mb, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, mbs1, mbs2, moab::Range::merge(), my_rank, neighTgtEdgeTag, nr, outSet, P, rs1, rs2, setup_tgt_cell(), moab::Range::size(), srcParentTag, moab::Interface::tag_delete(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), tgtConn, TgtEdges, tgtParentTag, moab::tolerance, and moab::Interface::UNION.
Referenced by moab::TempestRemapper::ComputeOverlapMesh(), and main().
    ErrorCode rval;
    mbs2   = mbset2;
    outSet = outputSet;
    // from create tags, copy relevant ones
    int indx = 0;
        int num_nodes        = 0;
            num_nodes--;
        int i = 0;
            // the tag is dense
    // create the kd tree on source cells, and intersect all targets in an expensive loop
    // find out max edge on source mesh;
    double max_length = 0;
        std::vector< double > coords;
        coords.resize( 3 * max_edges_1 );
        for( Range::iterator it = rs1.begin(); it != rs1.end(); it++ )
            int nnodes;
            rval = mb->get_connectivity( *it, conn, nnodes );MB_CHK_SET_ERR( rval, "can't get connectivity" );
            while( conn[nnodes - 2] == conn[nnodes - 1] && nnodes > 3 )
                nnodes--;
            rval = mb->get_coords( conn, nnodes, &coords[0] );MB_CHK_SET_ERR( rval, "can't get coordinates" );
            for( int j = 0; j < nnodes; j++ )
                int next = ( j + 1 ) % nnodes;
                double leng;
                leng = ( coords[3 * j] - coords[3 * next] ) * ( coords[3 * j] - coords[3 * next] ) +
                       ( coords[3 * j + 1] - coords[3 * next + 1] ) * ( coords[3 * j + 1] - coords[3 * next + 1] ) +
                       ( coords[3 * j + 2] - coords[3 * next + 2] ) * ( coords[3 * j + 2] - coords[3 * next + 2] );
                leng = sqrt( leng );
                if( leng > max_length ) max_length = leng;
    // maximum sag on a spherical mesh make sense only for intx on a sphere, with radius 1 :(
    double tolerance = 1.e-15;
    if( max_length < 1. )
        // basically, the sag for an arc of length max_length on a circle of radius 1
        tolerance = 1. - sqrt( 1 - max_length * max_length / 4 );
        if( box_error < tolerance ) box_error = tolerance;
        tolerance = 3 * tolerance;  // we use it for gnomonic plane too, projected sag could be =* sqrt(2.)
        // be more generous, use 1.5 ~= sqrt(2.)
        if( !my_rank )
            std::cout << " max edge length: " << max_length << "  tolerance for kd tree: " << tolerance << "\n";
            std::cout << " box overlap tolerance: " << box_error << "\n";
    for( Range::iterator it = rs2.begin(); it != rs2.end(); ++it )
        EntityHandle tcell = *it;
        int nnodes               = 0;
        rval                     = mb->get_connectivity( tcell, conn, nnodes );MB_CHK_ERR( rval );
        double areaTgtCell   = setup_tgt_cell( tcell, nnodes );  // this is the area in the gnomonic plane
        // distance to search will be based on average edge length
        double av_len = 0;
        for( int k = 0; k < nnodes; k++ )
            int ik      = ( k + 1 ) % nnodes;
            double len1 = 0;
            for( int j = 0; j < 3; j++ )
                double len2 = positions[3 * k + j] - positions[3 * ik + j];
                len1 += len2 * len2;
            av_len += sqrt( len1 );
        if( nnodes > 0 ) av_len /= nnodes;
            leaves.clear();
            rval = kd.distance_search( &positions[3 * i], av_len, leaves, tolerance, epsilon_1 );MB_CHK_ERR( rval );
                Range tmp;
#ifdef VERBOSE
        if( close_source_cells.empty() )
            std::cout << " there are no close source cells to target cell " << tcell << " id from handle "
                      << mb->id_from_handle( tcell ) << "\n";
#endif
        for( Range::iterator it2 = close_source_cells.begin(); it2 != close_source_cells.end(); ++it2 )
            EntityHandle startSrc = *it2;
            double area           = 0;
            int nP = 0;
            int nsTgt, nsSrc;
            rval = computeIntersectionBetweenTgtAndSrc( tcell, startSrc, P, nP, area, nb, nr, nsSrc, nsTgt, true );MB_CHK_ERR( rval );
            if( area > 0 )
                if( nP > 1 )
                    rval = findNodes( tcell, nnodes, startSrc, nsSrc, P, nP );MB_CHK_ERR( rval );
#endif
    this->clean();
    return MB_SUCCESS;
void moab::Intx2Mesh::set_box_error ( double  berror) [inline]
virtual double moab::Intx2Mesh::setup_tgt_cell ( EntityHandle  tgt,
int &  nsTgt
) [pure virtual]
Member Data Documentation
std::vector< double > moab::Intx2Mesh::allBoxes [protected]
Definition at line 250 of file Intx2Mesh.hpp.
Definition at line 254 of file Intx2Mesh.hpp.
Definition at line 253 of file Intx2Mesh.hpp.
Definition at line 223 of file Intx2Mesh.hpp.
Referenced by moab::Intx2MeshOnSphere::findNodes().
Definition at line 216 of file Intx2Mesh.hpp.
Referenced by createTags(), and intersect_meshes().
Definition at line 206 of file Intx2Mesh.hpp.
Referenced by clean(), createTags(), and intersect_meshes().
Definition at line 218 of file Intx2Mesh.hpp.
List of all members.
