moab::MergeMesh Class Reference
#include <MergeMesh.hpp>
+ Collaboration diagram for moab::MergeMesh:
Public Member Functions
 MergeMesh (Interface *mbImpl, bool printErrorIn=true)
virtual ~MergeMesh ()
ErrorCode merge_entities (EntityHandle *elems, int elems_size, const double merge_tol, const int do_merge=true, const int update_sets=false, Tag merge_tag=0, bool do_higher_dim=true)
ErrorCode merge_entities (Range &elems, const double merge_tol, const int do_merge=true, const int update_sets=false, Tag merge_tag=0, bool do_higher_dim=true)
ErrorCode merge_higher_dimensions (Range &elems)
ErrorCode merge_using_integer_tag (Range &verts, Tag user_tag, Tag merge_tag=0)
ErrorCode perform_merge (Tag merged_to)
ErrorCode merge_all (EntityHandle meshset, const double merge_tol)
Private Member Functions
ErrorCode find_merged_to (EntityHandle &tree_root, AdaptiveKDTree &tree, Tag merged_to)
Private Attributes
InterfacembImpl
Tag mbMergeTag
double mergeTol
double mergeTolSq
std::set< EntityHandledeadEnts
std::set< EntityHandlemergedToVertices
bool printError
Detailed Description
Definition at line 13 of file MergeMesh.hpp.
moab::MergeMesh::MergeMesh ( Interface mbImpl,
bool  printErrorIn = true
Definition at line 22 of file MergeMesh.cpp.
    : mbImpl( impl ), mbMergeTag( 0 ), mergeTol( 0.001 ), mergeTolSq( 0.000001 ), printError( printErrorIn )
Definition at line 27 of file MergeMesh.cpp.
References mbImpl, mbMergeTag, and moab::Interface::tag_delete().
Member Function Documentation
ErrorCode moab::MergeMesh::find_merged_to ( EntityHandle tree_root,
AdaptiveKDTree tree,
Tag  merged_to
) [private]
Definition at line 265 of file MergeMesh.cpp.
References moab::CartVect::array(), moab::Range::begin(), moab::Range::clear(), deadEnts, moab::AdaptiveKDTree::distance_search(), moab::Range::empty(), ErrorCode, moab::Interface::get_coords(), moab::Interface::get_entities_by_handle(), moab::AdaptiveKDTree::get_tree_iterator(), moab::AdaptiveKDTreeIter::handle(), MB_ENTITY_NOT_FOUND, MB_SUCCESS, mbImpl, mergeTol, mergeTolSq, moab::Range::size(), moab::AdaptiveKDTreeIter::step(), moab::Interface::tag_get_data(), moab::Interface::tag_set_data(), and moab::Interface::UNION.
Referenced by merge_all(), and merge_entities().
    AdaptiveKDTreeIter iter;
    // evaluate vertices in this leaf
    Range leaf_range, leaf_range2;
    std::vector< EntityHandle > sorted_leaves;
    std::vector< double > coords;
    std::vector< EntityHandle > merge_tag_val, leaves_out;
    ErrorCode result = tree.get_tree_iterator( tree_root, iter );
    if( MB_SUCCESS != result ) return result;
    while( result == MB_SUCCESS )
        sorted_leaves.push_back( iter.handle() );
        result = iter.step();
    if( result != MB_ENTITY_NOT_FOUND ) return result;
    std::sort( sorted_leaves.begin(), sorted_leaves.end() );
    std::vector< EntityHandle >::iterator it;
    for( it = sorted_leaves.begin(); it != sorted_leaves.end(); ++it )
        leaf_range.clear();
        result = mbImpl->get_entities_by_handle( *it, leaf_range );
        coords.resize( 3 * leaf_range.size() );
        merge_tag_val.resize( leaf_range.size() );
        result = mbImpl->get_coords( leaf_range, &coords[0] );
        result = mbImpl->tag_get_data( merge_tag, leaf_range, &merge_tag_val[0] );
        Range::iterator rit;
        unsigned int i;
        bool inleaf_merged, outleaf_merged = false;
        unsigned int lr_size = leaf_range.size();
        for( i = 0, rit = leaf_range.begin(); i != lr_size; ++rit, i++ )
            if( 0 != merge_tag_val[i] ) continue;
            CartVect from( &coords[3 * i] );
            inleaf_merged = false;
            // check close-by leaves too
            leaves_out.clear();
            result =
                tree.distance_search( from.array(), mergeTol, leaves_out, mergeTol, 1.0e-6, NULL, NULL, &tree_root );
            leaf_range2.clear();
            for( std::vector< EntityHandle >::iterator vit = leaves_out.begin(); vit != leaves_out.end(); ++vit )
                if( *vit > *it )
                {  // if we haven't visited this leaf yet in the outer loop
                    result = mbImpl->get_entities_by_handle( *vit, leaf_range2, Interface::UNION );
            if( !leaf_range2.empty() )
                coords.resize( 3 * ( lr_size + leaf_range2.size() ) );
                merge_tag_val.resize( lr_size + leaf_range2.size() );
                result = mbImpl->get_coords( leaf_range2, &coords[3 * lr_size] );
                result = mbImpl->tag_get_data( merge_tag, leaf_range2, &merge_tag_val[lr_size] );
            // check other verts in this leaf
            for( unsigned int j = i + 1; j < merge_tag_val.size(); j++ )
                EntityHandle to_ent = j >= lr_size ? leaf_range2[j - lr_size] : leaf_range[j];
                if( *rit == to_ent ) continue;
                if( ( from - CartVect( &coords[3 * j] ) ).length_squared() < mergeTolSq )
                    merge_tag_val[j] = *rit;
                    if( j < lr_size )
                        inleaf_merged = true;
                    else
                        outleaf_merged = true;
                    deadEnts.insert( to_ent );
            if( outleaf_merged )
                result = mbImpl->tag_set_data( merge_tag, leaf_range2, &merge_tag_val[leaf_range.size()] );
            if( inleaf_merged )
                result = mbImpl->tag_set_data( merge_tag, leaf_range, &merge_tag_val[0] );
    return MB_SUCCESS;
ErrorCode moab::MergeMesh::merge_all ( EntityHandle  meshset,
Definition at line 118 of file MergeMesh.cpp.
References moab::AdaptiveKDTree::build_tree(), deadEnts, entities, ErrorCode, find_merged_to(), moab::Interface::get_connectivity(), moab::Interface::get_entities_by_handle(), MB_CHK_ERR, MB_SUCCESS, MB_TAG_DENSE, MB_TAG_EXCL, MB_TYPE_HANDLE, MBENTITYSET, mbImpl, mbMergeTag, merge_higher_dimensions(), mergeTol, mergeTolSq, perform_merge(), moab::Range::subset_by_type(), moab::subtract(), and moab::Interface::tag_get_handle().
Referenced by main(), merge_all_test(), and moab::IntxUtils::remove_duplicate_vertices().
    ErrorCode rval;
    if( 0 == mbMergeTag )
        EntityHandle def_val = 0;
        rval = mbImpl->tag_get_handle( "__merge_tag", 1, MB_TYPE_HANDLE, mbMergeTag, MB_TAG_DENSE | MB_TAG_EXCL,
                                       &def_val );MB_CHK_ERR( rval );
    // get all entities;
    // get all vertices connected
    // build a kdtree
    // find merged to
    mergeTol   = merge_tol;
    mergeTolSq = merge_tol * merge_tol;
    // get all vertices
    Range entities;
    rval = mbImpl->get_entities_by_handle( meshset, entities, /*recursive*/ true );MB_CHK_ERR( rval );
    Range sets = entities.subset_by_type( MBENTITYSET );
    entities   = subtract( entities, sets );
    Range verts;
    rval = mbImpl->get_connectivity( entities, verts );MB_CHK_ERR( rval );
    // build a kd tree with the vertices
    AdaptiveKDTree kd( mbImpl );
    EntityHandle tree_root;
    rval = kd.build_tree( verts, &tree_root );MB_CHK_ERR( rval );
    // find matching vertices, mark them
    rval = find_merged_to( tree_root, kd, mbMergeTag );MB_CHK_ERR( rval );
    rval = perform_merge( mbMergeTag );MB_CHK_ERR( rval );
    if( deadEnts.size() != 0 )
        rval = merge_higher_dimensions( entities );MB_CHK_ERR( rval );
    return MB_SUCCESS;
ErrorCode moab::MergeMesh::merge_entities ( EntityHandle elems,
int  elems_size,
const int  do_merge = true,
const int  update_sets = false,
Tag  merge_tag = 0,
bool  do_higher_dim = true
Definition at line 33 of file MergeMesh.cpp.
References ErrorCode, moab::Range::insert(), mergeTol, and mergeTolSq.
Referenced by moab::MeshGeneration::BrickInstance(), main(), mergesimple_test(), and moab::ParallelMergeMesh::PopulateMySkinEnts().
    Range tmp_elems;
    tmp_elems.insert( elems, elems + elems_size );
    ErrorCode result = merge_entities( tmp_elems, merge_tol, do_merge, update_sets, (Tag)merge_tag, do_higher_dim );
    return result;
ErrorCode moab::MergeMesh::merge_entities ( Range elems,
Tag  merge_tag = 0,
Definition at line 60 of file MergeMesh.cpp.
References moab::AdaptiveKDTree::build_tree(), deadEnts, ErrorCode, find_merged_to(), moab::Skinner::find_skin(), MB_SUCCESS, MB_TAG_DENSE, MB_TAG_EXCL, MB_TYPE_HANDLE, mbImpl, mbMergeTag, merge_higher_dimensions(), mergeTol, mergeTolSq, perform_merge(), and moab::Interface::tag_get_handle().
    // If merge_higher_dim is true, do_merge must also be true
    if( merge_higher_dim && !do_merge )
        return MB_FAILURE;
    // get the skin of the entities
    Skinner skinner( mbImpl );
    Range skin_range;
    ErrorCode result = skinner.find_skin( 0, elems, 0, skin_range, false, false );
    // create a tag to mark merged-to entity; reuse tree_root
    EntityHandle tree_root = 0;
    if( 0 == merge_tag )
        result = mbImpl->tag_get_handle( "__merge_tag", 1, MB_TYPE_HANDLE, mbMergeTag, MB_TAG_DENSE | MB_TAG_EXCL,
                                         &tree_root );
    else
        mbMergeTag = merge_tag;
    result = kd.build_tree( skin_range, &tree_root );
    result = find_merged_to( tree_root, kd, mbMergeTag );
    // merge them if requested
    if( do_merge )
        result = perform_merge( mbMergeTag );
    if( merge_higher_dim && deadEnts.size() != 0 )
        result = merge_higher_dimensions( elems );
    return MB_SUCCESS;
Definition at line 371 of file MergeMesh.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::Interface::delete_entities(), dim, moab::Range::end(), moab::Range::erase(), ErrorCode, moab::Skinner::find_skin(), moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), moab::Range::insert(), moab::Interface::INTERSECT, moab::intersect(), MB_SUCCESS, mbImpl, moab::Interface::merge_entities(), mergedToVertices, moab::Range::size(), and moab::Interface::UNION.
    // apply a different strategy
    // look at the vertices that were merged to, earlier, and find all entities adjacent to them
    // elems (input) are used just for initial connectivity
    ErrorCode result;
    Range verts;
    result = mbImpl->get_connectivity( elems, verts );
    // all higher dim entities that will be merged will be connected to the vertices that were
    // merged earlier; we will look at these vertices only
    Range mergedToVertsRange;
    std::copy( mergedToVertices.rbegin(), mergedToVertices.rend(), range_inserter( mergedToVertsRange ) );
    Range vertsOfInterest = intersect( mergedToVertsRange, verts );
    // Go through each dimension
    Range possibleEntsToMerge, conn, matches, moreDeadEnts;
    for( int dim = 1; dim < 3; dim++ )
        moreDeadEnts.clear();
        possibleEntsToMerge.clear();
        result = mbImpl->get_adjacencies( vertsOfInterest, dim, false, possibleEntsToMerge, Interface::UNION );
        // Go through each possible entity and see if it shares vertices with another entity of same
        // dimension
        for( Range::iterator pit = possibleEntsToMerge.begin(); pit != possibleEntsToMerge.end(); ++pit )
            EntityHandle eh = *pit;  // possible entity to be matched
            conn.clear();
            // Get the vertices connected to it in a range
            result = mbImpl->get_connectivity( &eh, 1, conn );
            matches.clear();
            // now retrieve all entities connected to all conn vertices
            result = mbImpl->get_adjacencies( conn, dim, false, matches, Interface::INTERSECT );
            if( matches.size() > 1 )
                for( Range::iterator matchIt = matches.begin(); matchIt != matches.end(); ++matchIt )
                    EntityHandle to_remove = *matchIt;
                    if( to_remove != eh )
                        moreDeadEnts.insert( to_remove );
                        result = mbImpl->merge_entities( eh, to_remove, false, false );
                        if( result != MB_SUCCESS ) return result;
                        possibleEntsToMerge.erase( to_remove );
        // Delete the entities of dimension dim
        result = mbImpl->delete_entities( moreDeadEnts );
    return MB_SUCCESS;
#if 0
  Range skinEnts, adj, matches, moreDeadEnts;
  ErrorCode result;
  Skinner skinner(mbImpl);
  //Go through each dimension
  for (int dim = 1; dim < 3; dim++)
    skinEnts.clear();
    result = skinner.find_skin(0, elems, dim, skinEnts, false, false);
    //Go through each skin entity and see if it shares adjacancies with another entity
    for (Range::iterator skinIt = skinEnts.begin();
        skinIt != skinEnts.end(); ++skinIt)
      adj.clear();
      //Get the adjacencies 1 dimension lower
      result = mbImpl->get_adjacencies(&(*skinIt), 1, dim - 1, false, adj);
      if (result != MB_SUCCESS)
        return result;
      //See what other entities share these adjacencies
      matches.clear();
      result = mbImpl->get_adjacencies(adj, dim, false, matches,
          Interface::INTERSECT);
        return result;
      //If there is more than one entity, then we have some to merge and erase
      if (matches.size() > 1)
        for (Range::iterator matchIt = matches.begin();
            matchIt != matches.end(); ++matchIt)
          if (*matchIt != *skinIt)
            moreDeadEnts.insert(*matchIt);
            result = mbImpl->merge_entities(*skinIt, *matchIt, false, false);
              return result;
            skinEnts.erase(*matchIt);
    //Delete the entities
    result = mbImpl->delete_entities(moreDeadEnts);
      return result;
  return MB_SUCCESS;
#endif
ErrorCode moab::MergeMesh::merge_using_integer_tag ( Range verts,
Tag  user_tag,
Tag  merge_tag = 0
Definition at line 215 of file MergeMesh.cpp.
References moab::Range::begin(), moab::compare_handle_id(), deadEnts, moab::handle_id::eh, moab::Range::end(), ErrorCode, moab::GeomUtil::first(), MB_SUCCESS, MB_TAG_DENSE, MB_TAG_EXCL, MB_TYPE_HANDLE, MB_TYPE_INTEGER, mbImpl, mbMergeTag, perform_merge(), moab::Range::size(), moab::Interface::tag_get_data(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), and moab::handle_id::val.
Referenced by moab::MeshGeneration::BrickInstance(), main(), and merge_with_tag_test().
    ErrorCode rval;
    DataType tag_type;
    rval = mbImpl->tag_get_data_type( user_tag, tag_type );
    if( rval != MB_SUCCESS || tag_type != MB_TYPE_INTEGER ) return MB_FAILURE;
    std::vector< int > vals( verts.size() );
    rval = mbImpl->tag_get_data( user_tag, verts, &vals[0] );
    if( rval != MB_SUCCESS ) return rval;
                                       &def_val );
        if( MB_SUCCESS != rval ) return rval;
    else
    std::vector< handle_id > handles( verts.size() );
    int i = 0;
    for( Range::iterator vit = verts.begin(); vit != verts.end(); ++vit )
        handles[i].eh  = *vit;
        handles[i].val = vals[i];
        i++;
    // std::sort(handles.begin(), handles.end(), compare_handle_id);
    qsort( &handles[0], handles.size(), sizeof( handle_id ), compare_handle_id );
    i = 0;
    while( i < (int)verts.size() - 1 )
        handle_id first = handles[i];
        int j           = i + 1;
        while( j < (int)verts.size() && handles[j].val == first.val )
            rval = mbImpl->tag_set_data( mbMergeTag, &( handles[j].eh ), 1, &( first.eh ) );
            deadEnts.insert( handles[j].eh );
            j++;
        i = j;
    return rval;
Definition at line 157 of file MergeMesh.cpp.
References deadEnts, moab::Interface::delete_entities(), ErrorCode, MB_SUCCESS, mbImpl, MBVERTEX, moab::Interface::merge_entities(), mergedToVertices, printError, moab::Interface::tag_get_data(), moab::TYPE_FROM_HANDLE(), and moab::Interface::type_from_handle().
Referenced by merge_all(), merge_entities(), and merge_using_integer_tag().
    // we start with an empty range of vertices that are "merged to"
    // they are used (eventually) for higher dim entities
    mergedToVertices.clear();
    ErrorCode result;
    if( deadEnts.size() == 0 )
        if( printError ) std::cout << "\nWarning: Geometries don't have a common face; Nothing to merge" << std::endl;
        return MB_SUCCESS;  // nothing to merge carry on with the program
    if( mbImpl->type_from_handle( *deadEnts.begin() ) != MBVERTEX ) return MB_FAILURE;
    std::vector< EntityHandle > merge_tag_val( deadEnts.size() );
    Range deadEntsRange;
    std::copy( deadEnts.rbegin(), deadEnts.rend(), range_inserter( deadEntsRange ) );
    result = mbImpl->tag_get_data( merge_tag, deadEntsRange, &merge_tag_val[0] );
    std::set< EntityHandle >::iterator rit;
    unsigned int i;
    for( rit = deadEnts.begin(), i = 0; rit != deadEnts.end(); ++rit, i++ )
        assert( merge_tag_val[i] );
        if( MBVERTEX == TYPE_FROM_HANDLE( merge_tag_val[i] ) ) mergedToVertices.insert( merge_tag_val[i] );
        result = mbImpl->merge_entities( merge_tag_val[i], *rit, false, false );
            return result;
    result = mbImpl->delete_entities( deadEntsRange );
    return result;
Member Data Documentation
Definition at line 72 of file MergeMesh.hpp.
Referenced by merge_higher_dimensions(), and perform_merge().
double moab::MergeMesh::mergeTol [private]
Definition at line 66 of file MergeMesh.hpp.
Referenced by find_merged_to(), merge_all(), and merge_entities().
double moab::MergeMesh::mergeTolSq [private]
Definition at line 75 of file MergeMesh.hpp.
Referenced by perform_merge().
List of all members.
