moab::MeshSet Class Reference
Class to implement entity set functionality. More...
#include <MeshSet.hpp>
+ Collaboration diagram for moab::MeshSet:
Classes
union  CompactList
struct  dim_test
struct  hdl_iter
struct  not_dim_test
struct  not_type_test
struct  type_test
Public Types
enum  Count { ZERO = 0, ONE = 1, TWO = 2, MANY = 3 }
 Possible values of mParentCount and mChildCount. More...
Public Member Functions
 MeshSet ()
 create an empty meshset
 MeshSet (unsigned flags)
 ~MeshSet ()
 destructor
ErrorCode set_flags (unsigned flags, EntityHandle my_handle, AEntityFactory *adjacencies)
const EntityHandleget_children (int &count_out) const
 get all children pointed to by this meshset
const EntityHandleget_parents (int &count_out) const
 get all parents pointed to by this meshset
int num_children () const
 return the number of children pointed to by this meshset
int num_parents () const
 return the number of parents pointed to by this meshset
int add_parent (EntityHandle parent)
int add_child (EntityHandle child)
int remove_parent (EntityHandle parent)
int remove_child (EntityHandle child)
unsigned flags () const
int tracking () const
 returns whether entities of meshsets know this meshset
int set () const
int ordered () const
int vector_based () const
ErrorCode replace_entities (EntityHandle my_handle, const EntityHandle *old_entities, const EntityHandle *new_entities, size_t num_entities, AEntityFactory *mAdjFact)
ErrorCode clear (EntityHandle myhandle, AEntityFactory *adjacencies)
ErrorCode clear_all (EntityHandle myhandle, AEntityFactory *adjacencies)
const EntityHandleget_contents (size_t &count_out) const
ErrorCode get_entities (std::vector< EntityHandle > &entities) const
ErrorCode get_entities (Range &entities) const
ErrorCode get_entities_by_type (EntityType entity_type, std::vector< EntityHandle > &entity_list) const
 get all entities in this MeshSet with the specified type
ErrorCode get_entities_by_type (EntityType type, Range &entity_list) const
unsigned int num_entities_by_type (EntityType type) const
 return the number of entities with the given type contained in this meshset
ErrorCode get_entities_by_dimension (int dimension, std::vector< EntityHandle > &entity_list) const
ErrorCode get_entities_by_dimension (int dimension, Range &entity_list) const
unsigned int num_entities_by_dimension (int dimension) const
ErrorCode get_non_set_entities (Range &range) const
bool contains_entities (const EntityHandle *entities, int num_entities, const int op) const
ErrorCode subtract (const MeshSet *meshset_2, EntityHandle my_handle, AEntityFactory *adjacencies)
 subtract/intersect/unite meshset_2 from/with/into meshset_1; modifies meshset_1
ErrorCode intersect (const MeshSet *meshset_2, EntityHandle my_handle, AEntityFactory *adjacencies)
ErrorCode unite (const MeshSet *meshset_2, EntityHandle my_handle, AEntityFactory *adjacencies)
ErrorCode add_entities (const EntityHandle *entity_handles, const int num_entities, EntityHandle my_handle, AEntityFactory *adjacencies)
 add these entities to this meshset
ErrorCode add_entities (const Range &entities, EntityHandle my_handle, AEntityFactory *adjacencies)
ErrorCode remove_entities (const Range &entities, EntityHandle my_handle, AEntityFactory *adjacencies)
ErrorCode remove_entities (const EntityHandle *entities, const int num_entities, EntityHandle my_handle, AEntityFactory *adjacencies)
 remove these entities from this meshset
unsigned int num_entities () const
 return the number of entities contained in this meshset
bool empty () const
unsigned long get_memory_use () const
Static Public Member Functions
static int DIM_FROM_HANDLE (EntityHandle h)
static EntityHandle FIRST_OF_DIM (int dim)
static EntityHandle LAST_OF_DIM (int dim)
Protected Member Functions
ErrorCode convert (unsigned flags, EntityHandle my_handle, AEntityFactory *adj)
ErrorCode create_adjacencies (EntityHandle myhandle, AEntityFactory *adjacencies)
ErrorCode remove_adjacencies (EntityHandle myhandle, AEntityFactory *adjacencies)
ErrorCode insert_entity_vector (const EntityHandle *vect, size_t len, EntityHandle my_h, AEntityFactory *adj)
ErrorCode insert_entity_ranges (const EntityHandle *range_vect, size_t len, EntityHandle my_h, AEntityFactory *adj)
ErrorCode insert_entity_ranges (const Range &range, EntityHandle my_h, AEntityFactory *adj)
ErrorCode remove_entity_vector (const EntityHandle *vect, size_t len, EntityHandle my_h, AEntityFactory *adj)
ErrorCode remove_entity_ranges (const EntityHandle *range_vect, size_t len, EntityHandle my_h, AEntityFactory *adj)
ErrorCode remove_entity_ranges (const Range &range, EntityHandle my_h, AEntityFactory *adj)
Private Attributes
unsigned char mFlags
 Meshset propery flags.
unsigned mParentCount: 2
unsigned mChildCount: 2
unsigned mContentCount: 2
CompactList parentMeshSets
 Storage for data lists.
CompactList childMeshSets
CompactList contentList
Detailed Description
Author:
Jason Kraftcheck <[email protected]>
Definition at line 26 of file MeshSet.hpp.
Member Enumeration Documentation
Enumerator:
ZERO
ONE
TWO
MANY
Definition at line 211 of file MeshSet.hpp.
        ZERO = 0,
        ONE  = 1,
        TWO  = 2,
        MANY = 3
moab::MeshSet::MeshSet ( ) [inline]
Definition at line 393 of file MeshSet.hpp.
moab::MeshSet::MeshSet ( unsigned  flags) [inline]
Definition at line 396 of file MeshSet.hpp.
    : mFlags( (unsigned char)flg ), mParentCount( ZERO ), mChildCount( ZERO ), mContentCount( ZERO )
Member Function Documentation
add a child to this meshset; returns true if child was added, 0 if it was already a child of this meshset
Definition at line 244 of file MeshSet.cpp.
References childMeshSets, moab::insert_in_vector(), and mChildCount.
Referenced by moab::Core::add_child_meshset(), moab::Core::add_child_meshsets(), and moab::Core::add_parent_child().
    int result  = 0;
    mChildCount = insert_in_vector( (Count)mChildCount, childMeshSets, child, result );
    return result;
ErrorCode moab::MeshSet::add_entities ( const EntityHandle entity_handles,
AEntityFactory adjacencies
) [inline]
Definition at line 858 of file MeshSet.hpp.
References insert_entity_vector().
Referenced by replace_entities().
    return insert_entity_vector( entity_handles, num_ents, my_handle, adjacencies );
ErrorCode moab::MeshSet::add_entities ( const Range entities,
) [inline]
Definition at line 867 of file MeshSet.hpp.
References insert_entity_ranges().
    return insert_entity_ranges( entities, my_handle, adjacencies );
add a parent to this meshset; returns true if parent was added, 0 if it was already a parent of this meshset
Definition at line 238 of file MeshSet.cpp.
References moab::insert_in_vector(), mParentCount, and parentMeshSets.
Referenced by moab::Core::add_parent_child(), moab::Core::add_parent_meshset(), and moab::Core::add_parent_meshsets().
    int result   = 0;
    mParentCount = insert_in_vector( (Count)mParentCount, parentMeshSets, parent, result );
    return result;
ErrorCode moab::MeshSet::clear ( EntityHandle  myhandle,
) [inline]
Clear *contents* of set (not parents or children)
Definition at line 459 of file MeshSet.hpp.
References contentList, MANY, MB_SUCCESS, mContentCount, moab::MeshSet::CompactList::ptr, remove_adjacencies(), tracking(), and ZERO.
Referenced by clear_all(), and intersect().
    if( tracking() ) remove_adjacencies( myhandle, adjacencies );
    if( mContentCount == MANY ) free( contentList.ptr[0] );
    mContentCount = ZERO;
    return MB_SUCCESS;
ErrorCode moab::MeshSet::clear_all ( EntityHandle  myhandle,
) [inline]
Clear all set lists (contents, parents, and children)
Definition at line 467 of file MeshSet.hpp.
References childMeshSets, clear(), ErrorCode, MANY, mChildCount, mParentCount, parentMeshSets, moab::MeshSet::CompactList::ptr, and ZERO.
    ErrorCode rval = clear( myhandle, adjacencies );
    if( mChildCount == MANY ) free( childMeshSets.ptr[0] );
    mChildCount = ZERO;
    if( mParentCount == MANY ) free( parentMeshSets.ptr[0] );
    mParentCount = ZERO;
    return rval;
bool moab::MeshSet::contains_entities ( const EntityHandle entities,
int  num_entities,
const int  op
) const [inline]
Test of meshset contains some or all of passed entities
Parameters:
entitiesArray of entities
num_entitiesLength of array of entities.
op- Interface::UNION : Test if set contains any of the input entities
Definition at line 812 of file MeshSet.hpp.
References get_contents(), moab::Interface::INTERSECT, and vector_based().
    size_t count;
    const EntityHandle* const ptr = get_contents( count );
    const EntityHandle* const end = ptr + count;
    size_t found_count            = 0;
    if( vector_based() )
        for( int i = 0; i < num_ents; ++i )
            if( std::find( ptr, end, entities[i] ) < end ) ++found_count;
    else
        assert( 0 == count % 2 );
            const unsigned long idx = std::lower_bound( ptr, end, entities[i] ) - ptr;
            if( idx < count && ( idx % 2 != 0 || ptr[idx] == entities[i] ) ) ++found_count;
    return found_count >= ( ( Interface::INTERSECT == op ) ? (unsigned)num_ents : 1u );
ErrorCode moab::MeshSet::convert ( unsigned  flags,
AEntityFactory adj
) [protected]
Convert for changing flag values
Definition at line 268 of file MeshSet.cpp.
References contentList, moab::convert_to_ranges(), create_adjacencies(), ErrorCode, get_contents(), MB_SUCCESS, mContentCount, MESHSET_TRACK_OWNER, mFlags, num_entities(), remove_adjacencies(), and moab::resize_compact_list().
Referenced by set_flags().
    ErrorCode rval = MB_SUCCESS;
    if( ( mFlags & MESHSET_TRACK_OWNER ) && !( flg & MESHSET_TRACK_OWNER ) )
        rval = remove_adjacencies( my_handle, adj );
    else if( !( mFlags & MESHSET_TRACK_OWNER ) && ( flg & MESHSET_TRACK_OWNER ) )
        rval = create_adjacencies( my_handle, adj );
    if( MB_SUCCESS != rval ) return rval;
    if( !( mFlags & MESHSET_ORDERED ) && ( flg & MESHSET_ORDERED ) )
        size_t datalen;
        EntityHandle* data = get_contents( datalen );
        if( datalen )
            std::vector< EntityHandle > list( datalen );
            memcpy( &list[0], data, datalen * sizeof( EntityHandle ) );
            int num_ents  = num_entities();
            Count count   = (Count)mContentCount;
            data          = resize_compact_list( count, contentList, num_ents );
            mContentCount = count;
            assert( list.size() % 2 == 0 );
            std::vector< EntityHandle >::iterator i = list.begin();
            while( i != list.end() )
                EntityHandle h = *i;
                ++i;
                EntityHandle e = *i;
                ++i;
                for( ; h <= e; ++h )
                    *data = h;
                    ++data;
    else if( ( mFlags & MESHSET_ORDERED ) && !( flg & MESHSET_ORDERED ) )
        size_t datalen;
        if( datalen )
            std::vector< EntityHandle > ranges;
            convert_to_ranges( data, datalen, ranges );
            data          = resize_compact_list( count, contentList, ranges.size() );
            memcpy( data, &ranges[0], ranges.size() * sizeof( EntityHandle ) );
    return MB_SUCCESS;
ErrorCode moab::MeshSet::create_adjacencies ( EntityHandle  myhandle,
) [protected]
Add explicit adjacencies from all contained entities to this (i.e. convert to tracking)
Definition at line 323 of file MeshSet.cpp.
References moab::AEntityFactory::add_adjacency(), ErrorCode, get_contents(), MB_SUCCESS, moab::AEntityFactory::remove_adjacency(), and vector_based().
Referenced by convert().
    size_t count;
        for( const EntityHandle* i = ptr; i != end; ++i )
            rval = adj->add_adjacency( *i, my_handle, false );
                for( const EntityHandle* j = ptr; j != i; ++j )
                    adj->remove_adjacency( *j, my_handle );
                return rval;
    else
        for( const EntityHandle* i = ptr; i != end; i += 2 )
            for( EntityHandle h = i[0]; h <= i[1]; ++h )
                rval = adj->add_adjacency( h, my_handle, false );
                    for( EntityHandle j = i[0]; j < h; ++j )
                        adj->remove_adjacency( j, my_handle );
                    for( const EntityHandle* j = ptr; j != i; j += 2 )
                        for( EntityHandle k = j[0]; k <= j[1]; ++k )
                            adj->remove_adjacency( k, my_handle );
                    return rval;
    return MB_SUCCESS;
bool moab::MeshSet::empty ( ) const [inline]
Definition at line 167 of file MeshSet.hpp.
References mContentCount, and ZERO.
        return mContentCount == ZERO;
static EntityHandle moab::MeshSet::FIRST_OF_DIM ( int  dim) [inline, static]
Get smallest possible handle with specified dimension (first handle for first type of dimension)
Definition at line 257 of file MeshSet.hpp.
References moab::GeomUtil::first(), moab::FIRST_HANDLE(), and moab::CN::TypeDimensionMap.
Referenced by get_entities_by_dimension(), and num_entities_by_dimension().
unsigned moab::MeshSet::flags ( ) const [inline]
Definition at line 66 of file MeshSet.hpp.
References mFlags.
        return mFlags;
const EntityHandle * moab::MeshSet::get_children ( int &  count_out) const [inline]
Definition at line 422 of file MeshSet.hpp.
References childMeshSets, moab::MeshSet::CompactList::hnd, MANY, mChildCount, and moab::MeshSet::CompactList::ptr.
Referenced by moab::MeshSetSequence::get_children(), and moab::MeshSetSequence::get_parent_child_meshsets().
    count_out = mChildCount;
    if( count_out < MANY ) return childMeshSets.hnd;
    count_out = childMeshSets.ptr[1] - childMeshSets.ptr[0];
    return childMeshSets.ptr[0];
EntityHandle * moab::MeshSet::get_contents ( size_t &  count_out) [inline]
Get contents data array. NOTE: this may not contain what you expect if not vector_based
Definition at line 491 of file MeshSet.hpp.
References contentList, moab::MeshSet::CompactList::hnd, MANY, mContentCount, and moab::MeshSet::CompactList::ptr.
        count_out = contentList.ptr[1] - contentList.ptr[0];
        return contentList.ptr[0];
    else
        count_out = mContentCount;
        return contentList.hnd;
ErrorCode moab::MeshSet::get_entities ( std::vector< EntityHandle > &  entities) const [inline]
Get entities contained in set
Definition at line 505 of file MeshSet.hpp.
References get_contents(), MB_SUCCESS, and vector_based().
Referenced by moab::MeshSetSequence::get_entities(), get_entities_by_type(), and intersect().
    size_t count;
    const EntityHandle* ptr = get_contents( count );
        size_t old_size = entities.size();
        entities.resize( count + old_size );
        std::copy( ptr, ptr + count, entities.begin() + old_size );
    else
        assert( count % 2 == 0 );
        for( size_t i = 0; i < count; i += 2 )
            std::copy( hdl_iter( ptr[i] ), hdl_iter( ptr[i + 1] + 1 ), std::back_inserter( entities ) );
    return MB_SUCCESS;
ErrorCode moab::MeshSet::get_entities ( Range entities) const [inline]
Definition at line 524 of file MeshSet.hpp.
References moab::Range::begin(), get_contents(), moab::Range::insert(), MB_SUCCESS, and vector_based().
    size_t count;
        std::copy( ptr, ptr + count, range_inserter( entities ) );
    else
        Range::iterator in = entities.begin();
            in = entities.insert( in, ptr[i], ptr[i + 1] );
    return MB_SUCCESS;
ErrorCode moab::MeshSet::get_entities_by_dimension ( int  dimension,
std::vector< EntityHandle > &  entity_list
) const [inline]
Definition at line 670 of file MeshSet.hpp.
References DIM_FROM_HANDLE(), FIRST_OF_DIM(), get_contents(), LAST_OF_DIM(), MB_SUCCESS, and vector_based().
Referenced by moab::MeshSetSequence::get_dimension().
    size_t count;
        std::remove_copy_if( ptr, ptr + count, std::back_inserter( entity_list ), not_dim_test( dimension ) );
    else
        size_t idx = std::lower_bound( ptr, ptr + count, FIRST_OF_DIM( dimension ) ) - ptr;
        if( idx < count && DIM_FROM_HANDLE( ptr[idx] ) == dimension )
            if( idx % 2 )
            {  // only part of first block is of type
                std::copy( hdl_iter( FIRST_OF_DIM( dimension ) ), hdl_iter( ptr[idx] + 1 ),
                           std::back_inserter( entity_list ) );
                ++idx;
            for( ; idx < count; idx += 2 )
                if( DIM_FROM_HANDLE( ptr[idx + 1] ) == dimension )  // whole block is of type
                    std::copy( hdl_iter( ptr[idx] ), hdl_iter( ptr[idx + 1] + 1 ), std::back_inserter( entity_list ) );
                else
                    if( DIM_FROM_HANDLE( ptr[idx] ) == dimension )  // part of last block is of type
                        std::copy( hdl_iter( ptr[idx] ), hdl_iter( LAST_OF_DIM( dimension ) ),
                    break;
    return MB_SUCCESS;
Range entity_list
) const [inline]
Definition at line 707 of file MeshSet.hpp.
References moab::Range::begin(), DIM_FROM_HANDLE(), FIRST_OF_DIM(), get_contents(), moab::Range::insert(), LAST_OF_DIM(), MB_SUCCESS, and vector_based().
    size_t count;
        std::remove_copy_if( ptr, ptr + count, range_inserter( entity_list ), not_dim_test( dimension ) );
    else
        Range::iterator in = entity_list.begin();
            if( idx % 2 )
                in = entity_list.insert( in, FIRST_OF_DIM( dimension ), ptr[idx] );
                ++idx;
                    in = entity_list.insert( in, ptr[idx], ptr[idx + 1] );
                else
                        entity_list.insert( in, ptr[idx], LAST_OF_DIM( dimension ) );
                    break;
    return MB_SUCCESS;
ErrorCode moab::MeshSet::get_entities_by_type ( EntityType  entity_type,
) const [inline]
Definition at line 543 of file MeshSet.hpp.
References moab::FIRST_HANDLE(), get_contents(), get_entities(), moab::LAST_HANDLE(), MB_SUCCESS, MBMAXTYPE, moab::TYPE_FROM_HANDLE(), and vector_based().
Referenced by moab::MeshSetSequence::get_contained_sets(), moab::MeshSetSequence::get_type(), and moab::MeshSetSequence::recursive_get_sets().
    size_t count;
    if( MBMAXTYPE == type )
        return get_entities( entity_list );
    else if( vector_based() )
        std::remove_copy_if( ptr, ptr + count, std::back_inserter( entity_list ), not_type_test( type ) );
    else
        size_t idx = std::lower_bound( ptr, ptr + count, FIRST_HANDLE( type ) ) - ptr;
        if( idx < count && TYPE_FROM_HANDLE( ptr[idx] ) == type )
            if( idx % 2 )
                std::copy( hdl_iter( FIRST_HANDLE( type ) ), hdl_iter( ptr[idx] + 1 ),
                ++idx;
                if( TYPE_FROM_HANDLE( ptr[idx + 1] ) == type )  // whole block is of type
                else
                    if( TYPE_FROM_HANDLE( ptr[idx] ) == type )  // part of last block is of type
                        std::copy( hdl_iter( ptr[idx] ), hdl_iter( LAST_HANDLE( type ) ),
                    break;
    return MB_SUCCESS;
ErrorCode moab::MeshSet::get_entities_by_type ( EntityType  type,
Range entity_list
) const [inline]
Definition at line 584 of file MeshSet.hpp.
References moab::Range::begin(), moab::FIRST_HANDLE(), get_contents(), get_entities(), moab::Range::insert(), moab::LAST_HANDLE(), MB_SUCCESS, MBMAXTYPE, moab::TYPE_FROM_HANDLE(), and vector_based().
    size_t count;
        std::remove_copy_if( ptr, ptr + count, range_inserter( entity_list ), not_type_test( type ) );
    else
            if( idx % 2 )
                in = entity_list.insert( in, FIRST_HANDLE( type ), ptr[idx] );
                ++idx;
                else
                        entity_list.insert( in, ptr[idx], LAST_HANDLE( type ) );
                    break;
    return MB_SUCCESS;
unsigned long moab::MeshSet::get_memory_use ( ) const
Definition at line 1279 of file MeshSet.cpp.
References childMeshSets, contentList, MANY, mChildCount, mContentCount, mParentCount, parentMeshSets, and moab::MeshSet::CompactList::ptr.
Referenced by moab::MeshSetSequence::get_per_entity_memory_use().
    unsigned long result = 0;
    if( mParentCount == MANY ) result += parentMeshSets.ptr[1] - parentMeshSets.ptr[0];
    if( mChildCount == MANY ) result += childMeshSets.ptr[1] - childMeshSets.ptr[0];
    if( mContentCount == MANY ) result += contentList.ptr[1] - contentList.ptr[0];
    return sizeof( EntityHandle ) * result;
Definition at line 785 of file MeshSet.hpp.
References moab::Range::begin(), get_contents(), moab::Range::insert(), moab::LAST_HANDLE(), MB_SUCCESS, MBENTITYSET, moab::TYPE_FROM_HANDLE(), and vector_based().
    size_t count;
        std::remove_copy_if( ptr, ptr + count, range_inserter( range ), type_test( MBENTITYSET ) );
    else
        Range::iterator in = range.begin();
        for( size_t idx = 0; idx < count; idx += 2 )
            if( TYPE_FROM_HANDLE( ptr[idx + 1] ) != MBENTITYSET )
                in = range.insert( in, ptr[idx], ptr[idx + 1] );
            else
                if( TYPE_FROM_HANDLE( ptr[idx] ) != MBENTITYSET )
                    in = range.insert( in, ptr[idx], LAST_HANDLE( MBENTITYSET - 1 ) );
                break;
    return MB_SUCCESS;
const EntityHandle * moab::MeshSet::get_parents ( int &  count_out) const [inline]
Definition at line 432 of file MeshSet.hpp.
References moab::MeshSet::CompactList::hnd, MANY, mParentCount, parentMeshSets, and moab::MeshSet::CompactList::ptr.
Referenced by moab::MeshSetSequence::get_parent_child_meshsets(), and moab::MeshSetSequence::get_parents().
    count_out = mParentCount;
    if( count_out < MANY ) return parentMeshSets.hnd;
    count_out = parentMeshSets.ptr[1] - parentMeshSets.ptr[0];
    return parentMeshSets.ptr[0];
ErrorCode moab::MeshSet::insert_entity_ranges ( const EntityHandle range_vect,
size_t  len,
EntityHandle  my_h,
AEntityFactory adj
) [protected]
Insert vector of handle range pairs into MeshSet
Definition at line 1052 of file MeshSet.cpp.
References contentList, ErrorCode, mContentCount, tracking(), and vector_based().
Referenced by add_entities(), and unite().
    typedef const std::pair< EntityHandle, EntityHandle >* pair_vect_t;
    pair_vect_t pair_vect = reinterpret_cast< pair_vect_t >( range_vect );
    MeshSet::Count count  = static_cast< MeshSet::Count >( mContentCount );
    ErrorCode rval;
    if( !vector_based() )
        rval = range_tool< pair_vect_t >::ranged_insert_entities( count, contentList, pair_vect, pair_vect + len / 2,
        my_h, tracking() ? adj : 0 );
    else
        rval = range_tool< pair_vect_t >::vector_insert_entities( count, contentList, pair_vect, pair_vect + len / 2,
    return rval;
ErrorCode moab::MeshSet::insert_entity_ranges ( const Range range,
EntityHandle  my_h,
AEntityFactory adj
) [protected]
Insert Range of handles into MeshSet
Definition at line 1071 of file MeshSet.cpp.
References moab::Range::const_pair_begin(), moab::Range::const_pair_end(), contentList, ErrorCode, mContentCount, tracking(), and vector_based().
    ErrorCode rval;
        rval = range_tool< Range::const_pair_iterator >::ranged_insert_entities(
            count, contentList, range.const_pair_begin(), range.const_pair_end(), my_h, tracking() ? adj : 0 );
    else
        rval = range_tool< Range::const_pair_iterator >::vector_insert_entities(
    return rval;
ErrorCode moab::MeshSet::insert_entity_vector ( const EntityHandle vect,
size_t  len,
EntityHandle  my_h,
AEntityFactory adj
) [protected]
Insert vector of handles into MeshSet
Definition at line 1196 of file MeshSet.cpp.
References contentList, moab::convert_to_ranges(), ErrorCode, mContentCount, tracking(), vector_based(), and moab::vector_insert_vector().
    ErrorCode rval;
        rval = vector_insert_vector( count, contentList, vect, len, my_h, tracking() ? adj : 0 );
    else
        std::vector< EntityHandle > rangevect;
        convert_to_ranges( vect, len, rangevect );
        pair_vect_t pair_vect = ( rangevect.empty() ) ? NULL : reinterpret_cast< pair_vect_t >( &rangevect[0] );
                             count, contentList, pair_vect, pair_vect + rangevect.size() / 2, my_h, tracking() ? adj : 0 );
    return rval;
ErrorCode moab::MeshSet::intersect ( const MeshSet meshset_2,
Definition at line 1118 of file MeshSet.cpp.
References clear(), ErrorCode, get_contents(), get_entities(), MB_SUCCESS, remove_entities(), remove_entity_ranges(), moab::subtract(), and vector_based().
Referenced by moab::Core::intersect_meshset().
    ErrorCode rval;
    if( !vector_based() && !other->vector_based() )
        size_t other_count             = 0;
        const EntityHandle* other_vect = other->get_contents( other_count );
        if( !other_count ) return clear( my_handle, adj );
        assert( 0 == other_count % 2 );
        std::vector< EntityHandle > compliment;
        compliment.reserve( other_count + 4 );
        if( *other_vect > 0 )
            compliment.push_back( 0 );
            compliment.push_back( *other_vect - 1 );
        ++other_vect;
        const EntityHandle* const other_end = other_vect + other_count - 2;
        for( ; other_vect < other_end; other_vect += 2 )
            compliment.push_back( other_vect[0] + 1 );
            compliment.push_back( other_vect[1] - 1 );
        if( *other_vect < ~(EntityHandle)0 )
            compliment.push_back( *other_vect + 1 );
            compliment.push_back( ~(EntityHandle)0 );
        return remove_entity_ranges( &compliment[0], compliment.size(), my_handle, adj );
    else
        Range my_ents, other_ents;
        rval = get_entities( my_ents );
        rval = other->get_entities( other_ents );
        return remove_entities( moab::subtract( my_ents, other_ents ), my_handle, adj );
static EntityHandle moab::MeshSet::LAST_OF_DIM ( int  dim) [inline, static]
Get largest possible handle with specified dimension (largest handle for last type of dimension)
Definition at line 264 of file MeshSet.hpp.
References moab::LAST_HANDLE(), and moab::CN::TypeDimensionMap.
        return LAST_HANDLE( CN::TypeDimensionMap[dim].second );
int moab::MeshSet::num_children ( ) const [inline]
Definition at line 442 of file MeshSet.hpp.
References childMeshSets, MANY, mChildCount, and moab::MeshSet::CompactList::ptr.
Referenced by moab::MeshSetSequence::num_children().
    if( mChildCount < MANY )
        return mChildCount;
    else
        return childMeshSets.ptr[1] - childMeshSets.ptr[0];
unsigned int moab::MeshSet::num_entities ( ) const [inline]
Definition at line 888 of file MeshSet.hpp.
References get_contents(), and vector_based().
Referenced by convert(), moab::MeshSetSequence::num_entities(), and num_entities_by_type().
    size_t count;
    const EntityHandle* list = get_contents( count );
    if( vector_based() ) return count;
    int result                    = 0;
    const EntityHandle* const end = list + count;
    for( ; list < end; list += 2 )
        result += list[1] - list[0] + 1;
    return result;
unsigned int moab::MeshSet::num_entities_by_dimension ( int  dimension) const [inline]
Definition at line 744 of file MeshSet.hpp.
References DIM_FROM_HANDLE(), FIRST_OF_DIM(), get_contents(), LAST_OF_DIM(), and vector_based().
Referenced by moab::MeshSetSequence::num_dimension().
    unsigned int result;
    size_t count;
#ifndef __SUNPRO_CC
        result = std::count_if( ptr, ptr + count, dim_test( dimension ) );
#else
        std::count_if( ptr, ptr + count, dim_test( dimension ), result );
#endif
    else
        result     = 0;
            if( idx % 2 )
                result += ptr[idx] - FIRST_OF_DIM( dimension ) + 1;
                ++idx;
                    result += ptr[idx + 1] - ptr[idx] + 1;
                else
                        result += LAST_OF_DIM( dimension ) - ptr[idx] + 1;
                    break;
    return result;
unsigned int moab::MeshSet::num_entities_by_type ( EntityType  type) const [inline]
Definition at line 625 of file MeshSet.hpp.
References moab::FIRST_HANDLE(), get_contents(), moab::LAST_HANDLE(), MBMAXTYPE, num_entities(), moab::TYPE_FROM_HANDLE(), and vector_based().
Referenced by moab::MeshSetSequence::num_contained_sets(), and moab::MeshSetSequence::num_type().
    size_t count;
        return num_entities();
#ifndef __SUNPRO_CC
        result = std::count_if( ptr, ptr + count, type_test( type ) );
#else
        std::count_if( ptr, ptr + count, type_test( type ), result );
#endif
    else
        result     = 0;
            if( idx % 2 )
                result += ptr[idx] - FIRST_HANDLE( type ) + 1;
                ++idx;
                else
                        result += LAST_HANDLE( type ) - ptr[idx] + 1;
                    break;
    return result;
int moab::MeshSet::num_parents ( ) const [inline]
Definition at line 451 of file MeshSet.hpp.
References MANY, mParentCount, parentMeshSets, and moab::MeshSet::CompactList::ptr.
Referenced by moab::MeshSetSequence::num_parents().
    if( mParentCount < MANY )
        return mParentCount;
    else
        return parentMeshSets.ptr[1] - parentMeshSets.ptr[0];
int moab::MeshSet::ordered ( ) const [inline]
Definition at line 79 of file MeshSet.hpp.
References mFlags.
Referenced by vector_based().
        return mFlags & MESHSET_ORDERED;
ErrorCode moab::MeshSet::remove_adjacencies ( EntityHandle  myhandle,
) [protected]
Remvoe explicit adjacencies from all contained entities to this (i.e. convert from tracking)
Definition at line 366 of file MeshSet.cpp.
References get_contents(), MB_SUCCESS, moab::AEntityFactory::remove_adjacency(), and vector_based().
Referenced by clear(), and convert().
    size_t count;
            adj->remove_adjacency( *i, my_handle );
    else
                adj->remove_adjacency( h, my_handle );
    return MB_SUCCESS;
remove a child from this meshset; returns true if child was removed, 0 if it was not a child of this meshset
Definition at line 257 of file MeshSet.cpp.
References childMeshSets, mChildCount, and moab::remove_from_vector().
Referenced by moab::Core::remove_child_meshset(), and moab::Core::remove_parent_child().
    int result  = 0;
    mChildCount = remove_from_vector( (Count)mChildCount, childMeshSets, child, result );
    return result;
ErrorCode moab::MeshSet::remove_entities ( const Range entities,
) [inline]
Definition at line 873 of file MeshSet.hpp.
References remove_entity_ranges().
Referenced by intersect(), and replace_entities().
    return remove_entity_ranges( entities, my_handle, adjacencies );
ErrorCode moab::MeshSet::remove_entities ( const EntityHandle entities,
) [inline]
Definition at line 879 of file MeshSet.hpp.
References remove_entity_vector().
    return remove_entity_vector( entities, num_ents, my_handle, adjacencies );
ErrorCode moab::MeshSet::remove_entity_ranges ( const EntityHandle range_vect,
size_t  len,
EntityHandle  my_h,
AEntityFactory adj
) [protected]
Remove vector of handle range pairs from MeshSet
Definition at line 1085 of file MeshSet.cpp.
References contentList, ErrorCode, mContentCount, tracking(), vector_based(), and moab::vector_remove_ranges().
Referenced by intersect(), remove_entities(), and subtract().
    ErrorCode rval;
        rval = vector_remove_ranges( count, contentList, range_vect, len / 2, my_h, tracking() ? adj : 0 );
    else
        rval = range_tool< pair_vect_t >::ranged_remove_entities( count, contentList, pair_vect, pair_vect + len / 2,
    return rval;
ErrorCode moab::MeshSet::remove_entity_ranges ( const Range range,
EntityHandle  my_h,
AEntityFactory adj
) [protected]
Remove Range of handles from MeshSet
Definition at line 1105 of file MeshSet.cpp.
References moab::Range::const_pair_begin(), moab::Range::const_pair_end(), contentList, ErrorCode, mContentCount, tracking(), vector_based(), and moab::vector_remove_range().
    ErrorCode rval;
        rval = vector_remove_range( count, contentList, range, my_h, tracking() ? adj : 0 );
    else
        rval = range_tool< Range::const_pair_iterator >::ranged_remove_entities(
    return rval;
ErrorCode moab::MeshSet::remove_entity_vector ( const EntityHandle vect,
size_t  len,
EntityHandle  my_h,
AEntityFactory adj
) [protected]
Remove vector of handles from MeshSet
Definition at line 1215 of file MeshSet.cpp.
References contentList, moab::convert_to_ranges(), ErrorCode, mContentCount, tracking(), vector_based(), and moab::vector_remove_vector().
Referenced by remove_entities(), and subtract().
    ErrorCode rval;
        rval = vector_remove_vector( count, contentList, vect, len, my_h, tracking() ? adj : 0 );
    else
    return rval;
remove a parent from this meshset; returns true if parent was removed, 0 if it was not a parent of this meshset
Definition at line 251 of file MeshSet.cpp.
References mParentCount, parentMeshSets, and moab::remove_from_vector().
Referenced by moab::Core::remove_parent_child(), and moab::Core::remove_parent_meshset().
    int result   = 0;
    mParentCount = remove_from_vector( (Count)mParentCount, parentMeshSets, parent, result );
    return result;
ErrorCode moab::MeshSet::replace_entities ( EntityHandle  my_handle,
const EntityHandle old_entities,
const EntityHandle new_entities,
AEntityFactory mAdjFact
replace one entity with another in the set (contents and parent/child lists); returns whether it was replaced or not
Definition at line 1234 of file MeshSet.cpp.
References moab::AEntityFactory::add_adjacency(), add_entities(), ErrorCode, get_contents(), MB_ENTITY_NOT_FOUND, MB_SUCCESS, moab::AEntityFactory::remove_adjacency(), remove_entities(), tracking(), and vector_based().
        ErrorCode result = MB_SUCCESS;
        size_t count;
        EntityHandle* vect           = get_contents( count );
        EntityHandle* const vect_end = vect + count;
        for( size_t i = 0; i < num_ents; ++i )
            EntityHandle* p = std::find( vect, vect_end, old_entities[i] );
            if( p == vect_end )
                result = MB_ENTITY_NOT_FOUND;
            else
                do
                    if( tracking() )
                        adjfact->remove_adjacency( *p, my_handle );
                        adjfact->add_adjacency( new_entities[i], my_handle, false );
                    *p = new_entities[i];
                    p  = std::find( p + 1, vect_end, old_entities[i] );
                } while( p != vect_end );
        return result;
    else
        ErrorCode r1 = remove_entities( old_entities, num_ents, my_handle, adjfact );
        ErrorCode r2 = add_entities( new_entities, num_ents, my_handle, adjfact );
        return ( MB_SUCCESS == r2 ) ? r1 : r2;
int moab::MeshSet::set ( ) const [inline]
Definition at line 75 of file MeshSet.hpp.
References MESHSET_SET, and mFlags.
        return mFlags & MESHSET_SET;
ErrorCode moab::MeshSet::set_flags ( unsigned  flags,
) [inline]
Definition at line 410 of file MeshSet.hpp.
References convert(), ErrorCode, MB_SUCCESS, mContentCount, mFlags, and ZERO.
    if( ZERO != mContentCount )
        ErrorCode result = convert( flg, my_handle, adjacencies );
        if( MB_SUCCESS != result ) return result;
    mFlags = (unsigned char)flg;
    return MB_SUCCESS;
ErrorCode moab::MeshSet::subtract ( const MeshSet meshset_2,
) [inline]
Definition at line 837 of file MeshSet.hpp.
References get_contents(), remove_entity_ranges(), remove_entity_vector(), and vector_based().
Referenced by moab::Core::subtract_meshset().
    size_t count;
    const EntityHandle* const ptr = meshset_2->get_contents( count );
    if( meshset_2->vector_based() )
        return remove_entity_vector( ptr, count, my_handle, adjacencies );
    else
        return remove_entity_ranges( ptr, count, my_handle, adjacencies );
int moab::MeshSet::tracking ( ) const [inline]
Definition at line 71 of file MeshSet.hpp.
References MESHSET_TRACK_OWNER, and mFlags.
Referenced by clear(), insert_entity_ranges(), insert_entity_vector(), remove_entity_ranges(), remove_entity_vector(), and replace_entities().
        return mFlags & MESHSET_TRACK_OWNER;
ErrorCode moab::MeshSet::unite ( const MeshSet meshset_2,
) [inline]
Definition at line 847 of file MeshSet.hpp.
References get_contents(), insert_entity_ranges(), insert_entity_vector(), and vector_based().
Referenced by moab::Core::unite_meshset().
    size_t count;
        return insert_entity_vector( ptr, count, my_handle, adjacencies );
    else
        return insert_entity_ranges( ptr, count, my_handle, adjacencies );
Member Data Documentation
unsigned moab::MeshSet::mChildCount [private]
If less than MANY, the number of children stored inline in childMeshSets.hnd. If MANY, then childMeshSets.ptr contains array begin and end pointers for a dynamically allocated array of child handles.
Definition at line 240 of file MeshSet.hpp.
Referenced by add_child(), clear_all(), get_children(), get_memory_use(), num_children(), remove_child(), and ~MeshSet().
unsigned moab::MeshSet::mContentCount [private]
If less than MANY, the number of children stored inline in contentList.hnd. If MANY, then contentList.ptr contains array begin and end pointers for a dynamically allocated array..
Definition at line 244 of file MeshSet.hpp.
Referenced by clear(), convert(), empty(), get_contents(), get_memory_use(), insert_entity_ranges(), insert_entity_vector(), remove_entity_ranges(), remove_entity_vector(), set_flags(), and ~MeshSet().
unsigned char moab::MeshSet::mFlags [private]
Definition at line 230 of file MeshSet.hpp.
Referenced by convert(), flags(), ordered(), set(), set_flags(), and tracking().
unsigned moab::MeshSet::mParentCount [private]
If less than MANY, the number of parents stored inline in parentMeshSets.hnd. If MANY, then parentMeshSets.ptr contains array begin and end pointers for a dynamically allocated array of parent handles.
Definition at line 235 of file MeshSet.hpp.
Referenced by add_parent(), clear_all(), get_memory_use(), get_parents(), num_parents(), remove_parent(), and ~MeshSet().
Definition at line 246 of file MeshSet.hpp.
List of all members.
