moab::MeshTag Class Reference
Tag with only a global/mesh value. More...
#include <MeshTag.hpp>
+ Inheritance diagram for moab::MeshTag:
+ Collaboration diagram for moab::MeshTag:
Public Member Functions
 MeshTag (const char *name, int size, DataType type, const void *default_value, int default_value_size)
 constructor that takes all parameters
virtual ~MeshTag ()
virtual TagType get_storage_type () const
virtual ErrorCode release_all_data (SequenceManager *seqman, Error *error_handler, bool delete_pending)
 Remove/clear tag data for all entities.
virtual ErrorCode get_data (const SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities, void *data) const
 Get tag value for passed entities.
virtual ErrorCode get_data (const SequenceManager *seqman, Error *error_handler, const Range &entities, void *data) const
virtual ErrorCode get_data (const SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities, const void **data_ptrs, int *data_lengths) const
virtual ErrorCode get_data (const SequenceManager *seqman, Error *error_handler, const Range &entities, const void **data_ptrs, int *data_lengths) const
virtual ErrorCode set_data (SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities, const void *data)
 Set tag value for passed entities.
virtual ErrorCode set_data (SequenceManager *seqman, Error *error_handler, const Range &entities, const void *data)
virtual ErrorCode set_data (SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities, void const *const *data_ptrs, const int *data_lengths)
virtual ErrorCode set_data (SequenceManager *seqman, Error *error_handler, const Range &entities, void const *const *data_ptrs, const int *data_lengths)
virtual ErrorCode clear_data (SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities, const void *value_ptr, int value_len=0)
virtual ErrorCode clear_data (SequenceManager *seqman, Error *error_handler, const Range &entities, const void *value_ptr, int value_len=0)
virtual ErrorCode remove_data (SequenceManager *seqman, Error *error_handler, const EntityHandle *entities, size_t num_entities)
 Remove/clear tag data for entities.
virtual ErrorCode remove_data (SequenceManager *seqman, Error *error_handler, const Range &entities)
virtual ErrorCode tag_iterate (SequenceManager *seqman, Error *error_handler, Range::iterator &iter, const Range::iterator &end, void *&data_ptr, bool allocate=true)
 Access tag data via direct pointer into contiguous blocks.
virtual ErrorCode get_tagged_entities (const SequenceManager *seqman, Range &output_entities, EntityType type=MBMAXTYPE, const Range *intersect=0) const
 Get all tagged entities.
virtual ErrorCode num_tagged_entities (const SequenceManager *seqman, size_t &output_count, EntityType type=MBMAXTYPE, const Range *intersect=0) const
 Count all tagged entities.
virtual ErrorCode find_entities_with_value (const SequenceManager *seqman, Error *error_handler, Range &output_entities, const void *value, int value_bytes=0, EntityType type=MBMAXTYPE, const Range *intersect_entities=0) const
 Get all tagged entities with tag value.
virtual bool is_tagged (const SequenceManager *, EntityHandle h) const
 Check if entity is tagged.
virtual ErrorCode get_memory_use (const SequenceManager *seqman, unsigned long &total, unsigned long &per_entity) const
 Get memory use for tag data.
Private Member Functions
 MeshTag (const MeshTag &)
MeshTagoperator= (const MeshTag &)
Private Attributes
std::vector< unsigned char > mValue
Detailed Description
Trivial tag implementation. No per-entity values. Only the global mesh value which is handled by the TagInfo base class.
Definition at line 20 of file MeshTag.hpp.
moab::MeshTag::MeshTag ( const char *  name,
int  size,
DataType  type,
const void *  default_value,
Definition at line 51 of file MeshTag.cpp.
    : TagInfo( name, size, type, default_value, default_value_size )
moab::MeshTag::~MeshTag ( ) [virtual]
Definition at line 56 of file MeshTag.cpp.
moab::MeshTag::MeshTag ( const MeshTag ) [private]
Member Function Documentation
ErrorCode moab::MeshTag::clear_data ( SequenceManager seqman,
Error error_handler,
const EntityHandle entities,
const void *  value_ptr,
int  value_len = 0
) [virtual]
Store tag data or update stored tag values.
Parameters:
seqmanPointer to mesh entity database
entitiesEntity handles for which to store tag data
num_entitiesLength of entities array
value_ptrPointer to a single tag value which is to be stored for each of the passed entities.
value_lenLength of tag value in bytes. Ignored for fixed-length tags. Required for variable- length tags.
Implements moab::TagInfo.
Definition at line 215 of file MeshTag.cpp.
References moab::all_root_set(), ErrorCode, moab::TagInfo::get_name(), MB_CHK_ERR, MB_SUCCESS, MB_TAG_NOT_FOUND, mValue, and moab::TagInfo::validate_lengths().
    if( !all_root_set( get_name(), entities, num_entities ) ) return MB_TAG_NOT_FOUND;
    ErrorCode valid = validate_lengths( NULL, value_len ? &value_len : 0, 1 );MB_CHK_ERR( valid );
    if( num_entities > 0 )
        mValue.resize( value_len );
        memcpy( &mValue[0], value_ptr, value_len );
    return MB_SUCCESS;
const Range entities,
int  value_len = 0
) [virtual]
Parameters:
Definition at line 235 of file MeshTag.cpp.
References moab::Range::empty(), moab::Range::front(), moab::TagInfo::get_name(), MB_SUCCESS, and moab::not_root_set().
    if( range.empty() )
        return MB_SUCCESS;
    else
        return not_root_set( get_name(), range.front() );
ErrorCode moab::MeshTag::find_entities_with_value ( const SequenceManager seqman,
Range output_entities,
const void *  value,
int  value_bytes = 0,
EntityType  type = MBMAXTYPE,
const Range intersect_entities = 0
) const [virtual]
Get the list of entities which have the specified tag value.
Parameters:
seqmanPointer to entity storage database
output_entitiesResults *appended* to this range
valuePointer to tag value
value_bytesSize of tag value in bytes.
typeOptional entity type. If specified, search is limited to entities of specified type.
intersect_entitiesOptional intersect list. If specified, search is restricted to entities in this list.
Definition at line 286 of file MeshTag.cpp.
References MB_SUCCESS.
    return MB_SUCCESS;
ErrorCode moab::MeshTag::get_data ( const SequenceManager seqman,
void *  data
) const [virtual]
Get tag values for specified entities.
Will fail for variable-length data.
Parameters:
entitiesEntity handles for which to retrieve tag data
dataPointer to memory in which to store consecutive tag values, one for each passed entity.
Definition at line 68 of file MeshTag.cpp.
References moab::all_root_set(), moab::TagInfo::get_default_value(), moab::TagInfo::get_default_value_size(), moab::TagInfo::get_name(), MB_SUCCESS, MB_TAG_NOT_FOUND, mValue, moab::not_found(), and moab::SysUtil::setmem().
    const void* ptr;
    int len;
    if( !mValue.empty() )
        ptr = &mValue[0];
        len = mValue.size();
    else if( get_default_value() )
        ptr = get_default_value();
        len = get_default_value_size();
    else
        return not_found( get_name() );
    SysUtil::setmem( data, ptr, len, num_entities );
    return MB_SUCCESS;
void *  data
) const [virtual]
Parameters:
Definition at line 98 of file MeshTag.cpp.
References moab::Range::empty(), moab::Range::front(), moab::TagInfo::get_name(), MB_SET_ERR, MB_SUCCESS, MB_VARIABLE_DATA_LENGTH, moab::not_root_set(), and moab::TagInfo::variable_length().
    if( variable_length() )
        MB_SET_ERR( MB_VARIABLE_DATA_LENGTH, "No length specified for variable-length tag " << get_name() << " value" );
    else if( r.empty() )
        return MB_SUCCESS;
    else
        return not_root_set( get_name(), r.front() );
const void **  data_ptrs,
int *  data_lengths
) const [virtual]
Parameters:
data_ptrsArray of pointers to tag values, one pointer for each passed entity.
data_lengthsOne value for each entity specifying the length of the tag value for the corresponding entity.
Definition at line 110 of file MeshTag.cpp.
References moab::TagInfo::get_default_value(), moab::TagInfo::get_default_value_size(), moab::TagInfo::get_name(), MB_SUCCESS, mValue, moab::not_found(), and moab::not_root_set().
    const void* ptr;
    int len;
        ptr = &mValue[0];
    else
    for( size_t i = 0; i < num_entities; ++i )
        if( entities[i] ) return not_root_set( get_name(), entities[i] );  // Not root set
        data_ptrs[i] = ptr;
        if( data_lengths ) data_lengths[i] = len;
    return MB_SUCCESS;
int *  data_lengths
) const [virtual]
Parameters:
Definition at line 145 of file MeshTag.cpp.
    if( range.empty() )
        return MB_SUCCESS;
    else
ErrorCode moab::MeshTag::get_memory_use ( const SequenceManager seqman,
unsigned long &  total,
unsigned long &  per_entity
) const [virtual]
Definition at line 302 of file MeshTag.cpp.
References moab::TagInfo::get_memory_use(), MB_SUCCESS, and mValue.
    total      = TagInfo::get_memory_use() + sizeof( *this ) + mValue.size();
    per_entity = 0;
    return MB_SUCCESS;
Definition at line 58 of file MeshTag.cpp.
References MB_TAG_MESH.
    return MB_TAG_MESH;
ErrorCode moab::MeshTag::get_tagged_entities ( const SequenceManager seqman,
const Range intersect = 0
) const [virtual]
Get the list of entities for which the a tag value has been set, or a close approximation if the tag storage scheme cannot accurately determine exactly which entities have explicit values.
Parameters:
intersectOptional intersect list. If specified, search is restricted to entities in this list.
Definition at line 276 of file MeshTag.cpp.
    return MB_SUCCESS;
bool moab::MeshTag::is_tagged ( const SequenceManager ,
EntityHandle  h
) const [virtual]
Definition at line 297 of file MeshTag.cpp.
References mValue.
    return ( 0 == h ) && ( !mValue.empty() );
ErrorCode moab::MeshTag::num_tagged_entities ( const SequenceManager seqman,
size_t &  output_count,
) const [virtual]
Count the entities for which the a tag value has been set, or a close approximation if the tag storage scheme cannot accurately determine exactly which entities have explicit values.
Parameters:
output_countThis is *incremented* for each detected entity.
Definition at line 281 of file MeshTag.cpp.
    return MB_SUCCESS;
MeshTag& moab::MeshTag::operator= ( const MeshTag ) [private]
ErrorCode moab::MeshTag::release_all_data ( SequenceManager seqman,
bool  delete_pending
) [virtual]
Remove tag values from entities.
Parameters:
delete_pendingIf true, then release any global data associated with the tag in preparation for deleting the tag itself.
Invalidates tag if tag_delete_pending is true. The only valid method that can be invoked that is is the destructor.
Parameters:
Definition at line 63 of file MeshTag.cpp.
    return MB_SUCCESS;
ErrorCode moab::MeshTag::remove_data ( SequenceManager seqman,
size_t  num_entities
) [virtual]
Parameters:
Definition at line 243 of file MeshTag.cpp.
References moab::all_root_set(), moab::TagInfo::get_name(), MB_SUCCESS, MB_TAG_NOT_FOUND, and mValue.
    if( num_entities ) mValue.clear();
    return MB_SUCCESS;
) [virtual]
Parameters:
Definition at line 255 of file MeshTag.cpp.
    if( range.empty() )
        return MB_SUCCESS;
    else
ErrorCode moab::MeshTag::set_data ( SequenceManager seqman,
const void *  data
) [virtual]
Store tag data or update stored tag values Will fail for variable-length data.
Parameters:
dataPointer to memory holding consecutive tag values, one for each passed entity.
Definition at line 153 of file MeshTag.cpp.
References moab::all_root_set(), moab::TagInfo::get_name(), moab::TagInfo::get_size(), MB_SET_ERR, MB_SUCCESS, MB_TAG_NOT_FOUND, MB_VARIABLE_DATA_LENGTH, mValue, and moab::TagInfo::variable_length().
        mValue.resize( get_size() );
        const unsigned char* bytes = reinterpret_cast< const unsigned char* >( data );
        memcpy( &mValue[0], bytes + get_size() * ( num_entities - 1 ), get_size() );
    return MB_SUCCESS;
const void *  data
) [virtual]
Parameters:
Definition at line 175 of file MeshTag.cpp.
    else if( range.empty() )
        return MB_SUCCESS;
    else
void const *const *  data_ptrs,
const int *  data_lengths
) [virtual]
Parameters:
data_lengthsOne value for each entity specifying the length of the tag value for the corresponding entity. Array is required for variable-length tags and is ignored for fixed-length tags.
Definition at line 187 of file MeshTag.cpp.
    ErrorCode valid = validate_lengths( NULL, data_lengths, num_entities );MB_CHK_ERR( valid );
        mValue.resize( data_lengths[num_entities - 1] );
        memcpy( &mValue[0], data_ptrs[num_entities - 1], mValue.size() );
    return MB_SUCCESS;
) [virtual]
Parameters:
Definition at line 207 of file MeshTag.cpp.
    if( range.empty() )
        return MB_SUCCESS;
    else
ErrorCode moab::MeshTag::tag_iterate ( SequenceManager seqman,
Range::iterator iter,
const Range::iterator end,
void *&  data_ptr,
bool  allocate = true
) [virtual]
Iteratively obtain direct access to contiguous blocks of tag storage. This function cannot be used with bit tags because of the compressed bit storage. This function cannot be used with variable length tags because it does not provide a mechanism to determine the length of the value for each entity. This function may be used with sparse tags, but if it is used, it will return data for a single entity at a time.
Parameters:
iterAs input, the first entity for which to return data. As output, one past the last entity for which data was returned.
endOne past the last entity for which data is desired
data_ptrOutput: pointer to tag storage.
allocateIf true, allocate space for this tag as part of this call, else don't
If this function is called for entities for which no tag value has been set, but for which a default value exists, it will force the allocation of explicit storage for each such entity even though MOAB would normally not explicitly store tag values for such entities.
Definition at line 263 of file MeshTag.cpp.
References moab::TagInfo::get_name(), MB_SUCCESS, and moab::not_root_set().
    if( beg == end )
        return MB_SUCCESS;
    else
        return not_root_set( get_name(), *beg );
Member Data Documentation
std::vector< unsigned char > moab::MeshTag::mValue [private]
Definition at line 345 of file MeshTag.hpp.
Referenced by clear_data(), get_data(), get_memory_use(), is_tagged(), remove_data(), and set_data().
List of all members.
