moab::NestedRefine Member List
This is the complete list of members for moab::NestedRefine, including all inherited members.
_incellsmoab::NestedRefine [protected]
_inedgesmoab::NestedRefine [protected]
_infacesmoab::NestedRefine [protected]
_invertsmoab::NestedRefine [protected]
_rsetmoab::NestedRefine [protected]
ahfmoab::NestedRefine [protected]
child_to_parent(EntityHandle child, int child_level, int parent_level, EntityHandle *parent)moab::NestedRefine
compute_coordinates(int cur_level, int deg, EntityType type, EntityHandle *vbuffer, int vtotal, double *corner_coords, std::vector< int > &vflag, int nverts_prev)moab::NestedRefine [protected]
construct_hm_1D(int cur_level, int deg)moab::NestedRefine [protected]
construct_hm_1D(int cur_level, int deg, EntityType type, std::vector< EntityHandle > &trackverts)moab::NestedRefine [protected]
construct_hm_2D(int cur_level, int deg)moab::NestedRefine [protected]
construct_hm_2D(int cur_level, int deg, EntityType type, std::vector< EntityHandle > &trackvertsC_edg, std::vector< EntityHandle > &trackvertsF)moab::NestedRefine [protected]
construct_hm_3D(int cur_level, int deg)moab::NestedRefine [protected]
construct_hm_entities(int cur_level, int deg)moab::NestedRefine [protected]
copy_vertices_from_prev_level(int cur_level)moab::NestedRefine [protected]
count_subentities(EntityHandle set, int cur_level, int *nedges, int *nfaces)moab::NestedRefine [protected]
create_hm_storage_single_level(EntityHandle *set, int cur_level, int estL[4])moab::NestedRefine [protected]
deg_indexmoab::NestedRefine [protected]
elementypemoab::NestedRefine [protected]
estimate_hm_storage(EntityHandle set, int level_degree, int cur_level, int hmest[4])moab::NestedRefine [protected]
exchange_ghosts(std::vector< EntityHandle > &lsets, int num_glayers)moab::NestedRefine
find_shortest_diagonal_octahedron(int cur_level, int deg, EntityHandle *vbuffer)moab::NestedRefine [protected]
generate_hm(int *level_degrees, int num_level, EntityHandle *hm_set, bool optimize)moab::NestedRefine [protected]
generate_mesh_hierarchy(int num_level, int *level_degrees, std::vector< EntityHandle > &level_sets, bool optimize=false)moab::NestedRefine
get_adjacencies(const EntityHandle source_entity, const unsigned int target_dimension, std::vector< EntityHandle > &target_entities)moab::NestedRefine
get_connectivity(EntityHandle ent, int level, std::vector< EntityHandle > &conn)moab::NestedRefine
get_coordinates(EntityHandle *verts, int num_verts, int level, double *coords)moab::NestedRefine
get_index_from_degree(int degree)moab::NestedRefine [protected]
get_lid_inci_child(EntityType type, int deg, int lfid, int leid, std::vector< int > &child_ids, std::vector< int > &child_lvids)moab::NestedRefine [protected]
get_local_vid(EntityHandle vid, EntityHandle ent, int level)moab::NestedRefine [protected]
get_octahedron_corner_coords(int cur_level, int deg, EntityHandle *vbuffer, double *ocoords)moab::NestedRefine [protected]
get_vertex_duplicates(EntityHandle vertex, int level, EntityHandle &dupvertex)moab::NestedRefine
hasghostmoab::NestedRefine [protected]
initialize()moab::NestedRefine
intFacEdgmoab::NestedRefine [protected, static]
is_cell_on_boundary(const EntityHandle &entity)moab::NestedRefine [protected]
is_edge_on_boundary(const EntityHandle &entity)moab::NestedRefine [protected]
is_entity_on_boundary(const EntityHandle &entity)moab::NestedRefine
is_face_on_boundary(const EntityHandle &entity)moab::NestedRefine [protected]
is_vertex_on_boundary(const EntityHandle &entity)moab::NestedRefine [protected]
level_dsequencemoab::NestedRefine [protected]
level_meshmoab::NestedRefine [protected]
mbImplmoab::NestedRefine [protected]
meshdimmoab::NestedRefine [protected]
NestedRefine(Core *impl, ParallelComm *comm=0, EntityHandle rset=0)moab::NestedRefine
nlevelsmoab::NestedRefine [protected]
parent_to_child(EntityHandle parent, int parent_level, int child_level, std::vector< EntityHandle > &children)moab::NestedRefine
pcommmoab::NestedRefine [protected]
permutationmoab::NestedRefine [protected, static]
print_maps_1D(int level)moab::NestedRefine [protected]
print_maps_2D(int level, EntityType type)moab::NestedRefine [protected]
print_maps_3D(int level, EntityType type)moab::NestedRefine [protected]
refTemplatesmoab::NestedRefine [protected, static]
reorder_indices(int cur_level, int deg, EntityHandle cell, int lfid, EntityHandle sib_cell, int sib_lfid, int index, int *id_sib)moab::NestedRefine [protected]
reorder_indices(int deg, EntityHandle *face1_conn, EntityHandle *face2_conn, int nvF, std::vector< int > &lemap, std::vector< int > &vidx, int *leorient=NULL)moab::NestedRefine [protected]
reorder_indices(int deg, int nvF, int comb, int *childfid_map)moab::NestedRefine [protected]
reorder_indices(EntityHandle *face1_conn, EntityHandle *face2_conn, int nvF, int *conn_map, int &comb, int *orient=NULL)moab::NestedRefine [protected]
subdivide_cells(EntityType type, int cur_level, int deg)moab::NestedRefine [protected]
subdivide_tets(int cur_level, int deg)moab::NestedRefine [protected]
timeallmoab::NestedRefine
tmmoab::NestedRefine [protected]
update_ahf_1D(int cur_level)moab::NestedRefine [protected]
update_global_ahf(EntityType type, int cur_level, int deg, std::vector< int > *pattern_ids=NULL)moab::NestedRefine [protected]
update_global_ahf_1D(int cur_level, int deg)moab::NestedRefine [protected]
update_global_ahf_1D_sub(int cur_level, int deg)moab::NestedRefine [protected]
update_global_ahf_2D(int cur_level, int deg)moab::NestedRefine [protected]
update_global_ahf_2D_sub(int cur_level, int deg)moab::NestedRefine [protected]
update_global_ahf_3D(int cur_level, int deg, std::vector< int > *pattern_ids=NULL)moab::NestedRefine [protected]
update_local_ahf(int deg, EntityType type, EntityHandle *vbuffer, EntityHandle *ent_buffer, int etotal)moab::NestedRefine [protected]
update_local_ahf(int deg, EntityType type, int pat_id, EntityHandle *vbuffer, EntityHandle *ent_buffer, int etotal)moab::NestedRefine [protected]
update_special_tags(int level, EntityHandle &lset)moab::NestedRefine
update_tracking_verts(EntityHandle cid, int cur_level, int deg, std::vector< EntityHandle > &trackvertsC_edg, std::vector< EntityHandle > &trackvertsC_face, EntityHandle *vbuffer)moab::NestedRefine [protected]
vertex_to_entities_down(EntityHandle vertex, int vert_level, int child_level, std::vector< EntityHandle > &incident_entities)moab::NestedRefine
vertex_to_entities_up(EntityHandle vertex, int vert_level, int parent_level, std::vector< EntityHandle > &incident_entities)moab::NestedRefine
~NestedRefine()moab::NestedRefine
