moab::OrientedBox Member List
This is the complete list of members for moab::OrientedBox, including all inherited members.
area() const moab::OrientedBox [inline]
axesmoab::OrientedBox
axis(int index) const moab::OrientedBox [inline]
centermoab::OrientedBox
closest_location_in_box(const CartVect &input_position, CartVect &output_position) const moab::OrientedBox
compute_from_2d_cells(OrientedBox &result, Interface *instance, const Range &elements)moab::OrientedBox [static]
compute_from_covariance_data(OrientedBox &result, Interface *moab_instance, const CovarienceData *orient_array, unsigned orient_array_length, const Range &vertices)moab::OrientedBox [static]
compute_from_covariance_data(OrientedBox &result, Interface *moab_instance, CovarienceData &orientation_data, const Range &vertices)moab::OrientedBox [static]
compute_from_vertices(OrientedBox &result, Interface *instance, const Range &vertices)moab::OrientedBox [static]
contained(const CartVect &point, double tolerance) const moab::OrientedBox
covariance_data_from_tris(CovarienceData &result, Interface *moab_instance, const Range &elements)moab::OrientedBox [static]
dimensions() const moab::OrientedBox [inline]
inner_radius() const moab::OrientedBox [inline]
inner_radius_squared(const double reps) const moab::OrientedBox [inline]
intersect_ray(const CartVect &ray_start_point, const CartVect &ray_unit_direction, const double distance_tolerance, const double *nonnegatve_ray_len=0, const double *negative_ray_len=0) const moab::OrientedBox
lengthmoab::OrientedBox
make_hex(EntityHandle &hex, Interface *instance)moab::OrientedBox
order_axes_by_length(double ax1_len, double ax2_len, double ax3_len)moab::OrientedBox [private]
OrientedBox()moab::OrientedBox [inline]
OrientedBox(const Matrix3 &axes_mat, const CartVect &center)moab::OrientedBox
OrientedBox(const CartVect axes_in[3], const CartVect &center)moab::OrientedBox
outer_radius() const moab::OrientedBox [inline]
outer_radius_squared(const double reps) const moab::OrientedBox [inline]
radiusmoab::OrientedBox
scaled_axis(int index) const moab::OrientedBox [inline]
tag_handle(Tag &handle_out, Interface *instance, const char *name)moab::OrientedBox [static]
volume() const moab::OrientedBox [inline]
