moab::OrientedBoxTreeTool::TrvStats Class Reference
Traversal statistics structure. More...
#include <OrientedBoxTreeTool.hpp>
Public Member Functions
const std::vector< unsigned > & nodes_visited () const
const std::vector< unsigned > & leaves_visited () const
 return counts of tree leaves visited, indexed by tree depth
const std::vector< unsigned > & traversals_ended () const
 return counts of traversals ended, indexed by tree depth
unsigned int ray_tri_tests () const
void reset ()
 reset all counters on this structure
void print (std::ostream &str) const
 print the contents of this structure to given stream
 TrvStats ()
Private Member Functions
void increment (unsigned depth)
void increment_leaf (unsigned depth)
void end_traversal (unsigned depth)
Private Attributes
std::vector< unsigned > nodes_visited_count
std::vector< unsigned > leaves_visited_count
std::vector< unsigned > traversals_ended_count
unsigned int ray_tri_tests_count
Friends
class OrientedBoxTreeTool
Detailed Description
Structure to accumulate statistics on traversal performance. Passed optionally to query functions, this structure contains the count of nodes visited at each level in a tree, and the count of traversals that ended at each level. One TrvStats structure can be used with multiple OBB trees or multiple queries, or used on only a single tree or a single query.
Note that these traversal statistics are not related to the stats() query below, which calculates static information about a tree. These statistics relate to a tree's dynamic behavior on particular operations.
Definition at line 151 of file OrientedBoxTreeTool.hpp.
Member Function Documentation
void moab::OrientedBoxTreeTool::TrvStats::end_traversal ( unsigned  depth) [private]
Definition at line 1695 of file OrientedBoxTreeTool.cpp.
Referenced by moab::OrientedBoxTreeTool::closest_to_location(), moab::OrientedBoxTreeTool::preorder_traverse(), and moab::OrientedBoxTreeTool::sphere_intersect_triangles().
    // assume safe depth, because increment is always called on a given
    // tree level first
    traversals_ended_count[depth] += 1;
void moab::OrientedBoxTreeTool::TrvStats::increment_leaf ( unsigned  depth) [private]
const std::vector< unsigned >& moab::OrientedBoxTreeTool::TrvStats::leaves_visited ( ) const [inline]
Definition at line 161 of file OrientedBoxTreeTool.hpp.
References leaves_visited_count.
            return leaves_visited_count;
const std::vector< unsigned >& moab::OrientedBoxTreeTool::TrvStats::nodes_visited ( ) const [inline]
return counts of nodes visited, indexed by tree depth. the counts include both leaves and interior nodes
Definition at line 156 of file OrientedBoxTreeTool.hpp.
References nodes_visited_count.
            return nodes_visited_count;
void moab::OrientedBoxTreeTool::TrvStats::print ( std::ostream &  str) const
Definition at line 1702 of file OrientedBoxTreeTool.cpp.
References h1, and h4.
Referenced by do_closest_point_test(), do_ray_fire_test(), and main().
    const std::string h1 = "OBBTree Depth";
    const std::string h2 = " - NodesVisited";
    const std::string h3 = " - LeavesVisited";
    const std::string h4 = " - TraversalsEnded";
    str << h1 << h2 << h3 << h4 << std::endl;
    unsigned num_visited = 0, num_leaves = 0, num_traversals = 0;
    for( unsigned i = 0; i < traversals_ended_count.size(); ++i )
        num_visited += nodes_visited_count[i];
        num_leaves += leaves_visited_count[i];
        num_traversals += traversals_ended_count[i];
        str << std::setw( h1.length() ) << i << std::setw( h2.length() ) << nodes_visited_count[i]
            << std::setw( h3.length() ) << leaves_visited_count[i] << std::setw( h4.length() )
            << traversals_ended_count[i] << std::endl;
    str << std::setw( h1.length() ) << "---- Totals:" << std::setw( h2.length() ) << num_visited
        << std::setw( h3.length() ) << num_leaves << std::setw( h4.length() ) << num_traversals << std::endl;
    if( ray_tri_tests_count )
        str << std::setw( h1.length() ) << "---- Total ray-tri tests: " << ray_tri_tests_count << std::endl;
unsigned int moab::OrientedBoxTreeTool::TrvStats::ray_tri_tests ( ) const [inline]
return total number of ray-triangle intersection tests performed in calls made with this TrvStats
Definition at line 172 of file OrientedBoxTreeTool.hpp.
References ray_tri_tests_count.
            return ray_tri_tests_count;
const std::vector< unsigned >& moab::OrientedBoxTreeTool::TrvStats::traversals_ended ( ) const [inline]
Definition at line 166 of file OrientedBoxTreeTool.hpp.
References traversals_ended_count.
Friends And Related Function Documentation
friend class OrientedBoxTreeTool [friend]
Definition at line 193 of file OrientedBoxTreeTool.hpp.
Member Data Documentation
Definition at line 185 of file OrientedBoxTreeTool.hpp.
Referenced by leaves_visited(), and reset().
Definition at line 184 of file OrientedBoxTreeTool.hpp.
Referenced by nodes_visited(), and reset().
Definition at line 186 of file OrientedBoxTreeTool.hpp.
Referenced by reset(), and traversals_ended().
List of all members.
