moab::PolyElementSeq Member List
This is the complete list of members for moab::PolyElementSeq, including all inherited members.
append_entities(EntityID count)moab::EntitySequence [protected]
create_data_subset(EntityHandle start, EntityHandle end) const moab::UnstructuredElemSeq [virtual]
moab::ElementSequence::create_data_subset(EntityHandle start_handle, EntityHandle end_handle, int num_sequence_arrays, unsigned const *bytes_per_element) const moab::EntitySequence [protected]
data() const moab::EntitySequence [inline]
data(SequenceData *ptr)moab::EntitySequence [inline]
ElementSequence(EntityHandle start, EntityID count, unsigned int nodes_per_elem, SequenceData *dat)moab::ElementSequence [inline]
ElementSequence(ElementSequence &split_from, EntityHandle here)moab::ElementSequence [inline, protected]
end_handle() const moab::EntitySequence [inline]
EntitySequence(EntityHandle h)moab::EntitySequence [inline, protected]
EntitySequence(EntitySequence &split_from, EntityHandle here)moab::EntitySequence [inline, protected]
EntitySequence(EntityHandle start, EntityID count, SequenceData *dat)moab::EntitySequence [inline]
get_array() const moab::UnstructuredElemSeq [inline, protected]
get_array()moab::UnstructuredElemSeq [inline, protected]
get_connectivity(EntityHandle handle, std::vector< EntityHandle > &connect, bool topological=false) const moab::PolyElementSeq [virtual]
get_connectivity(EntityHandle handle, EntityHandle const *&connect, int &connect_length, bool topological=false, std::vector< EntityHandle > *storage=0) const moab::PolyElementSeq [virtual]
get_connectivity_array()moab::UnstructuredElemSeq [virtual]
moab::ElementSequence::get_connectivity_array() const moab::ElementSequence [inline]
get_const_memory_use(unsigned long &bytes_per_entity, unsigned long &size_of_sequence) const moab::UnstructuredElemSeq [virtual]
get_per_entity_memory_use(EntityHandle first, EntityHandle last) const moab::EntitySequence [virtual]
has_mid_edge_nodes() const moab::ElementSequence [inline]
has_mid_face_nodes() const moab::ElementSequence [inline]
has_mid_volume_nodes() const moab::ElementSequence [inline]
merge(EntitySequence &other)moab::EntitySequence [virtual]
nodes_per_element() const moab::ElementSequence [inline]
PolyElementSeq(EntityHandle shandle, EntityID entity_count, unsigned nodes_per_entity, SequenceData *dat)moab::PolyElementSeq [inline]
PolyElementSeq(EntityHandle shandle, EntityID entity_count, unsigned nodes_per_entity, EntityID sequence_data_size)moab::PolyElementSeq [inline]
PolyElementSeq(PolyElementSeq &split_from, EntityHandle here)moab::PolyElementSeq [inline, protected]
pop_back(EntityID count)moab::EntitySequence [virtual]
pop_front(EntityID count)moab::EntitySequence [virtual]
prepend_entities(EntityID count)moab::EntitySequence [protected]
push_back(EntityID count)moab::UnstructuredElemSeq
push_front(EntityID count)moab::UnstructuredElemSeq
set_connectivity(EntityHandle handle, EntityHandle const *connect, int connect_length)moab::UnstructuredElemSeq [virtual]
size() const moab::EntitySequence [inline]
split(EntityHandle here)moab::PolyElementSeq [virtual]
start_handle() const moab::EntitySequence [inline]
type() const moab::EntitySequence [inline]
UnstructuredElemSeq(EntityHandle start_handle, EntityID entity_count, unsigned nodes_per_entity, SequenceData *data)moab::UnstructuredElemSeq
UnstructuredElemSeq(EntityHandle start_handle, EntityID entity_count, unsigned nodes_per_entity, EntityID sequence_data_size)moab::UnstructuredElemSeq
UnstructuredElemSeq(UnstructuredElemSeq &split_from, EntityHandle here)moab::UnstructuredElemSeq [inline, protected]
using_entire_data() const moab::EntitySequence
values_per_entity() const moab::UnstructuredElemSeq [virtual]
~ElementSequence()moab::ElementSequence [inline, virtual]
~EntitySequence()moab::EntitySequence [inline, virtual]
~PolyElementSeq()moab::PolyElementSeq [virtual]
~UnstructuredElemSeq()moab::UnstructuredElemSeq [virtual]
