moab::RangeSetIterator Class Reference
#include <SetIterator.hpp>
+ Inheritance diagram for moab::RangeSetIterator:
+ Collaboration diagram for moab::RangeSetIterator:
Public Member Functions
virtual ~RangeSetIterator ()
 Destructor.
virtual ErrorCode get_next_arr (std::vector< EntityHandle > &arr, bool &atend)
 get the next chunkSize entities Return the next chunkSize entities.
virtual ErrorCode reset ()
 reset the iterator to the beginning of the set
Protected Member Functions
 RangeSetIterator (Core *core, EntityHandle ent_set, int chunk_size, EntityType ent_type, int ent_dimension, bool check_valid=false)
 Constructor.
Private Member Functions
ErrorCode get_next_by_type (const EntityHandle *&ptr, int count, std::vector< EntityHandle > &arr, bool &atend)
ErrorCode get_next_by_dimension (const EntityHandle *&ptr, int count, std::vector< EntityHandle > &arr, bool &atend)
ErrorCode build_pair_vec ()
 Build the special pair vector for the root set.
Private Attributes
EntityHandle iterPos
 Current iterator position, 0 if at beginning.
EntityHandlepairPtr
 Special range pair ptr for root set.
int numPairs
 Number of range pairs.
Friends
class Core
Detailed Description
Definition at line 95 of file SetIterator.hpp.
Destructor.
Definition at line 40 of file SetIterator.cpp.
References numPairs, and pairPtr.
    if( pairPtr ) delete[] pairPtr;
    numPairs = 0;
moab::RangeSetIterator::RangeSetIterator ( Core core,
int  chunk_size,
int  ent_dimension,
bool  check_valid = false
) [protected]
Constructor.
Parameters:
coreMOAB Core instance
ent_setEntitySet to which this iterator corresponds
chunk_sizeChunk size of this iterator
ent_typeEntity type for this iterator
ent_dimEntity dimension for this iterator
Definition at line 21 of file SetIterator.cpp.
References build_pair_vec(), ErrorCode, and MB_SUCCESS.
    : SetIterator( core, eset, chunk_sz, ent_tp, ent_dim, check_valid ), iterPos( 0 ), pairPtr( NULL ), numPairs( 0 )
    if( !eset )
        // special case for the root set, have to keep a local array
        ErrorCode rval = build_pair_vec();
        assert( MB_SUCCESS == rval );
        // empty statement to avoid warning
        (void)( rval );
Member Function Documentation
Definition at line 46 of file SetIterator.cpp.
References moab::Range::const_pair_begin(), moab::Range::const_pair_end(), moab::SetIterator::entSet, ErrorCode, moab::Core::get_entities_by_handle(), MB_SUCCESS, moab::SetIterator::myCore, numPairs, pairPtr, and moab::Range::psize().
Referenced by get_next_arr(), and RangeSetIterator().
    // shouldn't be here unless we're iterating the root set
    assert( !entSet );
    Range all_ents;
    ErrorCode rval = myCore->get_entities_by_handle( 0, all_ents );
    if( MB_SUCCESS != rval ) return rval;
    pairPtr = new EntityHandle[2 * all_ents.psize()];
    Range::const_pair_iterator pi;
    int i;
    for( pi = all_ents.const_pair_begin(), i = 0; pi != all_ents.const_pair_end(); ++pi, i += 2 )
        pairPtr[i]     = ( *pi ).first;
        pairPtr[i + 1] = ( *pi ).second;
    numPairs = all_ents.psize();
    return MB_SUCCESS;
ErrorCode moab::RangeSetIterator::get_next_arr ( std::vector< EntityHandle > &  arr,
bool &  atend
) [virtual]
Parameters:
arrArray of entities returned.
atendReturns true if iterator is at the end of iterable values, otherwise false
Implements moab::SetIterator.
Definition at line 69 of file SetIterator.cpp.
References build_pair_vec(), moab::SetIterator::checkValid, moab::WriteUtilIface::CONTENTS, moab::SetIterator::entDimension, moab::SetIterator::entSet, ErrorCode, moab::WriteUtilIface::get_entity_list_pointers(), get_next_by_dimension(), get_next_by_type(), iface, moab::Core::is_valid(), MB_SUCCESS, moab::SetIterator::myCore, numPairs, pairPtr, moab::Interface::query_interface(), and moab::Interface::release_interface().
    atend = false;
    int count;
    const EntityHandle* ptr;
    WriteUtilIface* iface;
    std::vector< EntityHandle > tmp_arr;
    std::vector< EntityHandle >* tmp_ptr = &arr;
    if( checkValid ) tmp_ptr = &tmp_arr;
    ErrorCode rval;
    if( !pairPtr )
        Interface* mbImpl = dynamic_cast< Interface* >( myCore );
        rval              = mbImpl->query_interface( iface );
        rval = iface->get_entity_list_pointers( &entSet, 1, &ptr, WriteUtilIface::CONTENTS, &count );
        mbImpl->release_interface( iface );
    else
        if( checkValid )
        ptr   = pairPtr;
        count = 2 * numPairs;
    assert( !( count % 2 ) );
    if( !count )
        atend = true;
        return MB_SUCCESS;
    if( -1 == entDimension )
        rval = get_next_by_type( ptr, count, *tmp_ptr, atend );
    else
        rval = get_next_by_dimension( ptr, count, *tmp_ptr, atend );
    if( checkValid )
        for( std::vector< EntityHandle >::iterator vit = tmp_ptr->begin(); vit != tmp_ptr->end(); ++vit )
            if( myCore->is_valid( *vit ) ) arr.push_back( *vit );
    return MB_SUCCESS;
ErrorCode moab::RangeSetIterator::get_next_by_dimension ( const EntityHandle *&  ptr,
int  count,
bool &  atend
) [private]
Definition at line 175 of file SetIterator.cpp.
References moab::SetIterator::chunkSize, moab::CREATE_HANDLE(), moab::CN::Dimension(), moab::SetIterator::entDimension, moab::SetIterator::entType, moab::GeomUtil::first(), iterPos, moab::LAST_HANDLE(), MB_SET_ERR, MB_SUCCESS, MBMAXTYPE, moab::TYPE_FROM_HANDLE(), and moab::CN::TypeDimensionMap.
Referenced by get_next_arr().
    // iterating by dimension - type should be maxtype
    if( entType != MBMAXTYPE )
        MB_SET_ERR( MB_FAILURE, "Both dimension and type should not be set on an iterator" );
    unsigned int num_ret = 0;
    size_t idx           = 0;
    // initialize to first relevant handle
    while( (int)idx < count && ( iterPos > ptr[idx + 1] ||
                                 ( !iterPos && entDimension > CN::Dimension( TYPE_FROM_HANDLE( ptr[idx + 1] ) ) ) ) )
        idx += 2;
    if( (int)idx == count || CN::Dimension( TYPE_FROM_HANDLE( ptr[idx] ) ) > entDimension )
        atend = true;
        return MB_SUCCESS;
    if( !iterPos )
        iterPos = ptr[idx];
    else if( CN::Dimension( TYPE_FROM_HANDLE( ptr[idx] ) ) < entDimension )
        iterPos = CREATE_HANDLE( CN::TypeDimensionMap[entDimension].first, 1 );
    // idx points to start of subrange, iterPos in that subrange
    do
        EntityHandle next = ptr[idx + 1];
        if( CN::Dimension( TYPE_FROM_HANDLE( next ) ) != entDimension )
            next = LAST_HANDLE( CN::TypeDimensionMap[entDimension].second );
        unsigned int this_ret = chunkSize - num_ret;
        unsigned int to_end   = next - iterPos + 1;
        if( to_end < this_ret ) this_ret = to_end;
        std::copy( MeshSet::hdl_iter( iterPos ), MeshSet::hdl_iter( iterPos + this_ret ), std::back_inserter( arr ) );
        if( this_ret == to_end )
            idx += 2;
            iterPos = ( (int)idx < count ? ptr[idx] : 0 );
        else
            iterPos += this_ret;
        num_ret += this_ret;
    } while( (int)idx < count && num_ret < chunkSize && iterPos &&
             CN::Dimension( TYPE_FROM_HANDLE( iterPos ) ) == entDimension );
    if( !iterPos || CN::Dimension( TYPE_FROM_HANDLE( iterPos ) ) != entDimension ) atend = true;
    return MB_SUCCESS;
ErrorCode moab::RangeSetIterator::get_next_by_type ( const EntityHandle *&  ptr,
int  count,
bool &  atend
) [private]
Definition at line 124 of file SetIterator.cpp.
References moab::SetIterator::chunkSize, moab::CREATE_HANDLE(), moab::SetIterator::entType, moab::ID_FROM_HANDLE(), iterPos, moab::LAST_HANDLE(), MB_SUCCESS, MBMAXTYPE, and moab::TYPE_FROM_HANDLE().
    bool max_type        = ( entType == MBMAXTYPE );
    size_t idx           = 0;
             ( !max_type && !iterPos && CREATE_HANDLE( entType, ID_FROM_HANDLE( iterPos ) ) > ptr[idx + 1] ) ) )
        idx += 2;
    if( (int)idx == count || TYPE_FROM_HANDLE( ptr[idx] ) > entType )
        atend = true;
        return MB_SUCCESS;
    if( !iterPos && max_type )
        iterPos = ptr[idx];
    else if( !iterPos && TYPE_FROM_HANDLE( ptr[idx] ) <= entType && TYPE_FROM_HANDLE( ptr[idx + 1] ) >= entType )
        iterPos = std::max( CREATE_HANDLE( entType, 1 ), ptr[idx] );
    do
        if( TYPE_FROM_HANDLE( next ) != entType && !max_type ) next = LAST_HANDLE( entType );
            idx += 2;
        else
             ( max_type || TYPE_FROM_HANDLE( iterPos ) == entType ) );
    if( !iterPos || ( !max_type && TYPE_FROM_HANDLE( iterPos ) != entType ) ) atend = true;
    return MB_SUCCESS;
Definition at line 229 of file SetIterator.cpp.
References iterPos, and MB_SUCCESS.
    iterPos = 0;
    return MB_SUCCESS;
Friends And Related Function Documentation
friend class Core [friend]
Reimplemented from moab::SetIterator.
Definition at line 98 of file SetIterator.hpp.
Member Data Documentation
Definition at line 141 of file SetIterator.hpp.
Referenced by get_next_by_dimension(), get_next_by_type(), and reset().
Definition at line 147 of file SetIterator.hpp.
Referenced by build_pair_vec(), get_next_arr(), and ~RangeSetIterator().
Definition at line 144 of file SetIterator.hpp.
List of all members.
