moab::ReadDamsel Class Reference
#include <ReadDamsel.hpp>
+ Inheritance diagram for moab::ReadDamsel:
+ Collaboration diagram for moab::ReadDamsel:
Classes
class  subrange
Public Member Functions
ErrorCode load_file (const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0)
 Load an NC file.
 ReadDamsel (Interface *impl=NULL)
 Constructor.
virtual ~ReadDamsel ()
 Destructor.
virtual ErrorCode read_tag_values (const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0)
 Read tag values from a file.
Static Public Member Functions
static ReaderIfacefactory (Interface *)
Private Member Functions
ErrorCode get_contents (damsel_model m, damsel_container c, Range &ents)
ErrorCode get_contents (damsel_model m, damsel_container c, EntityHandle *ents)
ErrorCode init ()
ErrorCode parse_options (const FileOptions &opts, bool &parallel)
ErrorCode process_tags (std::vector< damsel_tag_buf_type > &tag_infos)
ErrorCode process_ent_info (const damsel_entity_buf_type &einfo)
ErrorCode process_entity_tags (int count, damsel_container tag_container, damsel_container app_cont, Range &these_ents)
ErrorCode process_coll_infos (std::vector< damsel_collection_buf_type > &coll_infos)
ErrorCode container_to_handle_pairs (damsel_container &cont, std::vector< damsel_handle > &handle_pairs)
ErrorCode insert_into_map (std::vector< damsel_handle > &handle_pairs, EntityHandle start_handle)
Private Attributes
InterfacembImpl
 Interface instance.
ReadUtilIfacereadMeshIface
 UtilIface.
std::string fileName
 File name.
bool nativeParallel
 Whether this reader natively supports parallel semantics.
ParallelCommmyPcomm
 Parallel info.
Tag mGlobalIdTag
 Used to track file handles.
RangeMap< damsel_handle,
EntityHandle, 0 >
dmHandleRMap
 map from damsel to moab handles
DamselUtil dU
 Keep various damsel data.
Detailed Description
Definition at line 36 of file ReadDamsel.hpp.
Constructor.
Definition at line 30 of file ReadDamsel.cpp.
References init().
Referenced by factory().
    : mbImpl( impl ), readMeshIface( NULL ), nativeParallel( false ), myPcomm( NULL ), mGlobalIdTag( 0 ), dU()
    init();
Destructor.
Definition at line 36 of file ReadDamsel.cpp.
References moab::DamselUtil::dmslLib, dU, mbImpl, readMeshIface, and moab::Interface::release_interface().
    if( readMeshIface ) mbImpl->release_interface( readMeshIface );
    DMSLlib_finalize( dU.dmslLib );
Member Function Documentation
ErrorCode moab::ReadDamsel::container_to_handle_pairs ( damsel_container &  cont,
std::vector< damsel_handle > &  handle_pairs
) [private]
Convert handles in a container into handle pairs, one pair per contiguous sequence of handles in the container
Definition at line 25 of file ReadDamsel.cpp.
References ReadDamsel().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
    return new ReadDamsel( iface );
ErrorCode moab::ReadDamsel::get_contents ( damsel_model  m,
damsel_container  c,
Range ents
) [private]
Get contents of the container (containing file-side handles) and translate to moab-side handles
Definition at line 433 of file ReadDamsel.cpp.
References CHK_DMSL_ERR, dmHandleRMap, moab::RangeMap< KeyType, ValType, NullVal >::end(), ErrorCode, moab::RangeMap< KeyType, ValType, NullVal >::find(), moab::Range::insert(), moab::RangeMap< KeyType, ValType, NullVal >::lower_bound(), and MB_SUCCESS.
Referenced by get_contents(), and process_ent_info().
    EntityHandle eh;
    if( DMSLcontainer_get_type( c ) == DAMSEL_HANDLE_CONTAINER_TYPE_SEQUENCE )
        damsel_handle start;
        size_t count, stride;
        damsel_err_t err = DMSLcontainer_sequence_get_contents( m, c, &start, &count, &stride );
        CHK_DMSL_ERR( err, "DMSLcontainer_sequence_get_contents" );
        if( stride == 1 )
            while( count )
                // Get start in rangemap
                RangeMap< damsel_handle, EntityHandle, 0 >::iterator beg = dmHandleRMap.lower_bound( start );
                if( beg == dmHandleRMap.end() ) return MB_SUCCESS;
                unsigned long diff = std::max( ( *beg ).begin - start, (damsel_handle)0 );
                unsigned long num  = std::min( count - diff, (size_t)( *beg ).count );
                ents.insert( ( *beg ).begin + diff, ( *beg ).begin + diff + num - 1 );
                count -= ( diff + num );
                ++beg;
        else
            for( int i = count - 1; i >= 0; i-- )
                if( dmHandleRMap.find( start + i, eh ) ) ents.insert( eh );
    else if( DMSLcontainer_get_type( c ) == DAMSEL_HANDLE_CONTAINER_TYPE_VECTOR )
        damsel_handle* handle_ptr;
        size_t count;
        damsel_err_t err = DMSLcontainer_vector_get_contents( m, c, &handle_ptr, &count );
        CHK_DMSL_ERR( err, "Trouble getting vector contents" );
            if( dmHandleRMap.find( handle_ptr[i], eh ) ) ents.insert( eh );
    else if( DMSLcontainer_get_type( c ) == DAMSEL_HANDLE_CONTAINER_TYPE_TREE )
        damsel_handle_ptr node_ptr = NULL;
        damsel_container cont      = NULL;
        while( DMSLcontainer_tree_get_contents( m, c, &node_ptr, &cont ) == DMSL_OK && cont )
            ErrorCode rval = get_contents( m, c, ents );
            if( MB_SUCCESS != rval ) return rval;
    return MB_SUCCESS;
damsel_container  c,
EntityHandle ents
) [private]
Get contents of the container (containing file-side handles) and translate to moab-side handles ents argument should point to already-allocated space
Definition at line 489 of file ReadDamsel.cpp.
References CHK_DMSL_ERR, dmHandleRMap, moab::RangeMap< KeyType, ValType, NullVal >::end(), ErrorCode, moab::RangeMap< KeyType, ValType, NullVal >::find(), get_contents(), moab::RangeMap< KeyType, ValType, NullVal >::lower_bound(), and MB_SUCCESS.
    EntityHandle eh;
    int ind = 0;
        CHK_DMSL_ERR( err, "Problem calling DMSLcontainer_sequence_get_contents" );
        if( stride == 1 )
            while( count )
                unsigned int diff = std::max( ( *beg ).begin - start, (damsel_handle)0 );
                unsigned int num  = std::min( count - diff, (size_t)( *beg ).count );
                for( EntityHandle hdl = ( *beg ).begin + diff; hdl <= (int)( *beg ).begin + diff + num - 1; hdl++ )
                    ents[ind++] = hdl;
                ++beg;
        else
                if( dmHandleRMap.find( start + i, eh ) ) ents[i] = eh;
        damsel_handle_ptr handle_ptr;
        size_t count;
        CHK_DMSL_ERR( err, "Failed to get vector contents" );
            if( dmHandleRMap.find( handle_ptr[i], eh ) ) ents[i] = eh;
            ErrorCode rval = get_contents( m, cont, ents );
            unsigned int num = DMSLcontainer_count( cont );
            ents += num;
    return MB_SUCCESS;
ErrorCode moab::ReadDamsel::insert_into_map ( std::vector< damsel_handle > &  handle_pairs,
) [private]
Store MOAB handles starting from start_handle, corresponding to store handles in handle_pairs, into the entity map
ErrorCode moab::ReadDamsel::load_file ( const char *  file_name,
const EntityHandle file_set,
const FileOptions opts,
const SubsetList subset_list = 0,
const Tag file_id_tag = 0
) [virtual]
Load an NC file.
Implements moab::ReaderIface.
Definition at line 70 of file ReadDamsel.cpp.
References CHK_DMSL_ERR, moab::DamselUtil::dmslLib, moab::DamselUtil::dmslModel, dU, ErrorCode, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MPI_COMM_WORLD, myPcomm, nativeParallel, parse_options(), moab::ProcConfig::proc_comm(), moab::ParallelComm::proc_config(), process_ent_info(), and process_tags().
    ErrorCode rval;
    rval = parse_options( opts, nativeParallel );
    // Initialize damsel
    dU.dmslLib = DMSLlib_init();
    // Create a damsel model
    dU.dmslModel =
        DMSLmodel_create( sizeof( EntityHandle ) == 8 ? DAMSEL_HANDLE_TYPE_HANDLE64 : DAMSEL_HANDLE_TYPE_HANDLE32 );
    // Model attach - need model id from make model, filename
#ifdef MOAB_HAVE_MPI
    MPI_Comm comm = MPI_COMM_WORLD;
    if( nativeParallel )
        comm = myPcomm->proc_config().proc_comm();
#endif
    damsel_err_t err;
    err = DMSLmodel_attach( dU.dmslModel, filename, comm, NULL );
    CHK_DMSL_ERR( err, "DMSLmodel_attach failed" );
    err = DMSLmodel_populate( dU.dmslModel );
    CHK_DMSL_ERR( err, "DMSLmodel_populate failed" );
    // STEP 0: GET COLLECTION, TAG, ENTITY INFOS FOR GLOBAL MODEL
    int num_containers = 0, num_tag_infos = 0, num_ent_infos = 0;
    DMSLmodel_get_tuple_count( dU.dmslModel, &num_containers, &num_tag_infos );
    num_ent_infos      = DMSLmodel_get_entity_count( dU.dmslModel );
    int num_coll_infos = DMSLmodel_get_collection_count( dU.dmslModel );
    CHK_DMSL_ERR( err, "DMSLmodel_get_collection_count failed" );
    if( -1 == num_containers || -1 == num_tag_infos || -1 == num_ent_infos )
        MB_SET_ERR( MB_FAILURE, "Bad count for containers/tags/ents" );
    std::vector< damsel_entity_buf_type > ent_infos( num_ent_infos );
    std::vector< damsel_collection_buf_type > coll_infos( num_coll_infos );
    std::vector< damsel_tag_buf_type > tag_infos( num_tag_infos );
    std::vector< damsel_container_buf_type > cont_infos( num_containers );
    err = DMSLmodel_get_entity_infos( dU.dmslModel, &ent_infos[0] );
    CHK_DMSL_ERR( err, "Failure getting entity infos" );
    err = DMSLmodel_get_collection_infos( dU.dmslModel, &coll_infos[0] );
    CHK_DMSL_ERR( err, "Failure getting collection infos" );
    err = DMSLmodel_get_tag_infos( dU.dmslModel, &tag_infos[0] );
    CHK_DMSL_ERR( err, "Failure getting tag infos" );
    err = DMSLmodel_get_container_infos( dU.dmslModel, &cont_infos[0] );
    CHK_DMSL_ERR( err, "Failure getting container infos" );
    // Create MOAB-side tags for all damsel tags except pre-defined ones
    rval = process_tags( tag_infos );MB_CHK_SET_ERR( rval, "Error processing tags" );
      if (nativeParallel) {
        // STEP 1: GET COLLECTION(S) REPRESENTING PARTITION:
        // Input: tag name, optionally value;
        // Output: container with file-side handles of collections satisfying those criteria
        // - Get all handles/values for tag
        // - Select handles matching criteria for tag value (will be collection handles)
        std::string partn_tag_name("PARALLEL_PARTITION");
        damsel_handle partn_tag = DMSLselect_tag_by_name(dU.dmslModel, partn_tag_name.c_str());
        // Get all the parts with that tag regardless of value
        damsel_container part_handles = DMSLselect_handles_with_values(dU.dmslModel, partn_tag);
        // STEP 2: GET HANDLES FOR TAGS WE NEED FOR THIS READER:
        // - "SET_CHARACTERISTIC"
        damsel_handle setchar_tag = DMSLselect_tag_by_name(dU.dmslModel, "SET_CHARACTERISTIC");
        // - "PARENT_LIST"
        //damsel_handle plist_tag = DMSLselect_tag_by_name(dU.dmslModel, "PARENT_LIST");
        // - "CHILD_LIST"
        //damsel_handle clist_tag = DMSLselect_tag_by_name(dU.dmslModel, "CHILD_LIST");
        // STEP 3: GET VALUES FOR "SET_CHARACTERISTIC" TAG ON PARTITION COLLECTIONS,
        //         GET VECTOR- OR SET-TYPE FLAGS FOR PARTITION COLLECTIONS
        // (gives tracking flag for moab)
        int num_handles = DMSLcontainer_count(part_handles);
        std::vector<unsigned> char_tagvals(num_handles);
        // Map the set chars
        err = DMSLmodel_map_tag(&char_tagvals[0], part_handles, &setchar_tag);CHK_DMSL_ERR(err,
      "Problem calling DMSLmodel_map_tag");
        // Execute the transfer
        err = DMSLmodel_transfer_sync(dU.dmslModel, DAMSEL_TRANSFER_TYPE_READ);CHK_DMSL_ERR(err,
      "Problem calling DMSLmodel_transfer_sync");
        // STEP 4: READ/PROCESS PARTITION COLLECTION(S)
        // Decide the handles I am responsible using round-robin for now
        // - GET TYPE, CONTENTS OF COLLECTION CONTENTS CONTAINER
        // - Allocate moab-side container (using count from container)
        // - MAP storage TO CONTAINER
        // - EXECUTE
        // ==> have list of all handles (entities + collections) represented on this proc
        int tmp_num = num_handles / proc_size, extra = num_handles % proc_size;
        if (extra) tmp_num++;
        int my_num_handles = tmp_num;
        if (proc_rank >= extra) my_num_handles--;
        int first_ind = std::min(proc_rank, extra) * tmp_num +
            std::max(proc_rank - extra, 0) * (tmp_num - 1);
        // - Create moab entity sets for partition collection(s)
        EntityHandle start_handle;
        rval = readMeshIface->create_entity_sets(my_num_handles, &char_tagvals[first_ind], 0,
      start_handle);MB_CHK_SET_ERR(rval, "Problem creating entity sets");
      else {
    // Initialize just by entity; each call to process_ent_info will:
    // a. Create moab-side representation to read into
    // b. Map those handles to damsel handles
    // c. Map coords / connectivity storage to damsel equivalent
    // d. For each tag, map moab storage to damsel storage
    std::vector< damsel_entity_buf_type >::iterator eiit;
    // Process verts info first
    for( eiit = ent_infos.begin(); eiit != ent_infos.end(); ++eiit )
        if( ( *eiit ).entity_type == DAMSEL_ENTITY_TYPE_VERTEX )
            rval = process_ent_info( *eiit );MB_CHK_ERR( rval );
        if( ( *eiit ).entity_type != DAMSEL_ENTITY_TYPE_VERTEX )
      // Process collections
      rval = process_coll_infos(coll_infos);MB_CHK_ERR(rval);
      // STEP 5: Process into list of local info structs, each represents file-side struct and
      // portion of that struct
      // ASSUMPTION: Each local info struct represents single entity type & # vertices or collection
      // STEP 6: For each local info struct:
      // STEP 6b: READ CONTAINER INTO LOCAL BUFFER
      // STEP 6c: Create app representation of entities/vertices/collection, and damsel container
      for them,
      //    and MAP APP HANDLE CONTAINER TO DAMSEL CONTAINER
      // STEP 6d: Process vertices/entities/collection
      //    6d1: If vertices, continue
      //    6d2: If entities:
      //    - MAP LOCAL CONNECTIVITY REP'N TO DAMSEL (might be tag, don't know yet)
      //    6d3: If collection:
      //    - (everything in STEP 4 for this collection except for EXECUTE)
      //    - might need to filter out things not represented on this rank
      //    6d4: If sparse tag:
      //    - Create app-side representation of sparse tag
      //    - READ CONTAINER OF MODEL HANDLES INTO LOCAL BUFFER
      //    - Allocate app-side storage for tag values
      //    - MAP APP STORAGE TO MODEL TAG + (implicit?) CONTAINER
      // STEP 6e: Process dense tags for the local info struct; for each dense tag:
      //   - Get app tag handle for model tag handle
      //   - Get app storage for app tag handle + container
      //   - MAP APP STORAGE TO MODEL TAG + CONTAINER
      // STEP 7: EXECUTE
      //   - Assign all mapped data
      //   - Translate all damsel handles to app handles
      // uninit damsel
    return MB_SUCCESS;
ErrorCode moab::ReadDamsel::parse_options ( const FileOptions opts,
bool &  parallel
) [private]
Definition at line 51 of file ReadDamsel.cpp.
References ErrorCode, moab::FileOptions::get_null_option(), moab::FileOptions::match_option(), MB_ENTITY_NOT_FOUND, MB_NOT_IMPLEMENTED, MB_SET_ERR, MB_SUCCESS, and nativeParallel.
Referenced by load_file().
    // Handle parallel options
    bool use_mpio  = ( MB_SUCCESS == opts.get_null_option( "USE_MPIO" ) );
    ErrorCode rval = opts.match_option( "PARALLEL", "READ_PART" );
    parallel       = ( rval != MB_ENTITY_NOT_FOUND );
    nativeParallel = ( rval == MB_SUCCESS );
    if( use_mpio && !parallel )
        MB_SET_ERR( MB_NOT_IMPLEMENTED, "'USE_MPIO' option specified w/out 'PARALLEL' option" );
    return MB_SUCCESS;
ErrorCode moab::ReadDamsel::process_coll_infos ( std::vector< damsel_collection_buf_type > &  coll_infos) [private]
ErrorCode moab::ReadDamsel::process_ent_info ( const damsel_entity_buf_type &  einfo) [private]
Definition at line 317 of file ReadDamsel.cpp.
References CHK_DMSL_ERR, moab::DamselUtil::container_to_range(), dmHandleRMap, moab::DamselUtil::dmslModel, moab::DamselUtil::dtom_entity_type, dU, ErrorCode, get_contents(), moab::ReadUtilIface::get_element_connect(), moab::ReadUtilIface::get_node_coords(), moab::RangeMap< KeyType, ValType, NullVal >::insert(), moab::Range::insert(), MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, moab::DamselUtil::tinfo::mTagh, process_entity_tags(), moab::Range::psize(), readMeshIface, moab::Range::size(), moab::DamselUtil::xcoordsTag, moab::DamselUtil::ycoordsTag, and moab::DamselUtil::zcoordsTag.
    // Create this chunk of entities
    EntityHandle *connect, start_handle;
    ErrorCode rval;
    damsel_err_t err;
    damsel_container app_cont;
    Range these_ents;
    // Check that there's only one contiguous run of file-side handles, fail if there isn't
#ifndef NDEBUG
    Range fside_handles;
    rval = DamselUtil::container_to_range( dU.dmslModel, const_cast< damsel_container& >( einfo.entity_container ),
                                           fside_handles );
    if( MB_SUCCESS != rval || fside_handles.size() != einfo.count || fside_handles.psize() != 1 ) return MB_FAILURE;
#endif
    if( einfo.entity_type != DAMSEL_ENTITY_TYPE_VERTEX )
        // Create the moab entities
        rval = readMeshIface->get_element_connect( einfo.count, einfo.vertices_per_entity,
                                                   DamselUtil::dtom_entity_type[einfo.entity_type], 0, start_handle,
                                                   connect );MB_CHK_ERR( rval );
        these_ents.insert( start_handle, start_handle + einfo.count - 1 );
        // Create an app-side sequence and map to file-side container
        app_cont = DMSLcontainer_create_sequence( dU.dmslModel, einfo.count, start_handle, 1 );
        err      = DMSLmodel_map_handles( app_cont, einfo.entity_container );
        CHK_DMSL_ERR( err, "Error returned mapping entity handles" );
        // Map connectivity
        assert( DMSLcontainer_count( einfo.vertex_container ) == (int)( einfo.vertices_per_entity * einfo.count ) );
        rval = get_contents( dU.dmslModel, einfo.vertex_container, connect );MB_CHK_SET_ERR( rval, "Error returned mapping connectivity" );
    else
        // Get the number of coordinate arrays
        int num_ctags             = 0;
        damsel_handle xcoord_dtag = DMSLselect_tag_by_name( dU.dmslModel, "mbdmsl_XCOORDS" );
        if( xcoord_dtag ) num_ctags++;
        damsel_handle ycoord_dtag = DMSLselect_tag_by_name( dU.dmslModel, "mbdmsl_YCOORDS" );
        if( ycoord_dtag ) num_ctags++;
        damsel_handle zcoord_dtag = DMSLselect_tag_by_name( dU.dmslModel, "mbdmsl_ZCOORDS" );
        if( zcoord_dtag ) num_ctags++;
        // Should have one vertex per entity
        assert( einfo.vertices_per_entity == 1 );
        std::vector< double* > coord_arrays;
        rval = readMeshIface->get_node_coords( num_ctags, einfo.count, 0, start_handle, coord_arrays );MB_CHK_ERR( rval );
        app_cont = DMSLcontainer_create_sequence( dU.dmslModel, start_handle, einfo.count, 1 );
        CHK_DMSL_ERR( err, "Trouble mapping entity handles" );
        // Map the coords storage
        if( xcoord_dtag != 0 )
            err = DMSLmodel_map_tag( coord_arrays[0], app_cont, (damsel_handle_ptr)&dU.xcoordsTag.mTagh );
            CHK_DMSL_ERR( err, "Trouble mapping x coordinate tag" );
        if( ycoord_dtag != 0 )
            err = DMSLmodel_map_tag( coord_arrays[1], app_cont, (damsel_handle_ptr)&dU.ycoordsTag.mTagh );
            CHK_DMSL_ERR( err, "Trouble mapping y coordinate tag" );
        if( zcoord_dtag != 0 )
            err = DMSLmodel_map_tag( coord_arrays[2], app_cont, (damsel_handle_ptr)&dU.zcoordsTag.mTagh );
            CHK_DMSL_ERR( err, "Trouble mapping z coordinate tag" );
    // Save mapping from moab entity to einfo
    dmHandleRMap.insert( DMSLcontainer_handle_at_position( einfo.entity_container, 0 ), start_handle, einfo.count );
    rval = process_entity_tags( einfo.tag_count, einfo.tag_handle_container, app_cont, these_ents );
    return rval;
ErrorCode moab::ReadDamsel::process_entity_tags ( int  count,
Range these_ents
) [private]
Definition at line 400 of file ReadDamsel.cpp.
References moab::Range::begin(), CHK_DMSL_ERR, dU, moab::Range::end(), ErrorCode, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TAG_ANY, mbImpl, moab::Range::size(), moab::Interface::tag_iterate(), and moab::DamselUtil::tagMap.
Referenced by process_ent_info().
    // Process tags on these entities
    ErrorCode rval = MB_SUCCESS;
    for( int i = 0; i < count; i++ )
        damsel_handle dtagh = DMSLcontainer_handle_at_position( tag_container, i );
        // Don't do conventional tags here
        std::vector< DamselUtil::tinfo >::iterator vit =
            std::find_if( dU.tagMap.begin(), dU.tagMap.end(), DamselUtil::DtagP< DamselUtil::tinfo >( dtagh ) );
        if( ( *vit ).tagType == MB_TAG_ANY )
            continue;
        else if( vit == dU.tagMap.end() )
            MB_SET_ERR( MB_FAILURE, "Failed to find tag" );
        Tag tagh = ( *vit ).mTagh;
        assert( tagh );
        void* tag_data;
        int ecount = these_ents.size();
        rval       = mbImpl->tag_iterate( tagh, these_ents.begin(), these_ents.end(), ecount, tag_data );MB_CHK_SET_ERR( rval, "Problem getting tag iterator" );
        assert( ecount == (int)these_ents.size() );
        damsel_err_t err = DMSLmodel_map_tag( tag_data, app_cont, (damsel_handle_ptr)&tagh );
        CHK_DMSL_ERR( err, "Problem calling DMSLmodel_map_tag" );
    return rval;
ErrorCode moab::ReadDamsel::process_tags ( std::vector< damsel_tag_buf_type > &  tag_infos) [private]
Definition at line 260 of file ReadDamsel.cpp.
References moab::DamselUtil::childrenTag, moab::DamselUtil::collFlagsTag, moab::DamselUtil::dtom_data_type, dU, ErrorCode, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_OPAQUE, mbImpl, moab::DamselUtil::parentsTag, moab::Interface::tag_get_handle(), moab::DamselUtil::tagMap, moab::DamselUtil::xcoordsTag, moab::DamselUtil::ycoordsTag, and moab::DamselUtil::zcoordsTag.
    Tag tagh;
    ErrorCode rval = MB_SUCCESS, tmp_rval;
    for( std::vector< damsel_tag_buf_type >::iterator tit = tag_infos.begin(); tit != tag_infos.end(); ++tit )
        if( DamselUtil::dtom_data_type[( *tit ).tag_datatype] == MB_TYPE_OPAQUE )
            std::cout << "Damsel reader encountered opaque tag." << std::endl;
            continue;
        tmp_rval = mbImpl->tag_get_handle( ( *tit ).name, 1, DamselUtil::dtom_data_type[( *tit ).tag_datatype], tagh,
                                           MB_TAG_CREAT | MB_TAG_DENSE );
        if( MB_SUCCESS != tmp_rval )
            rval = tmp_rval;
        else
            dU.tagMap.push_back( DamselUtil::tinfo( tagh, 0, MB_TAG_DENSE ) );
            // Also store predefined tags specially...
            if( !strncmp( ( *tit ).name, "mbdmsl_", 7 ) )
                // Predefined tag name, store the handle
                if( !strcmp( ( *tit ).name, "mbdmsl_XCOORDS" ) )
                    dU.xcoordsTag = dU.tagMap.back();
                else if( !strcmp( ( *tit ).name, "mbdmsl_YCOORDS" ) )
                    dU.ycoordsTag = dU.tagMap.back();
                else if( !strcmp( ( *tit ).name, "mbdmsl_ZCOORDS" ) )
                    dU.zcoordsTag = dU.tagMap.back();
                else if( !strcmp( ( *tit ).name, "mbdmsl_COLL_FLAGS" ) )
                    dU.collFlagsTag = dU.tagMap.back();
                else if( !strcmp( ( *tit ).name, "mbdmsl_PARENTS" ) )
                    dU.parentsTag = dU.tagMap.back();
                else if( !strcmp( ( *tit ).name, "mbdmsl_CHILDREN" ) )
                    dU.childrenTag = dU.tagMap.back();
                else
                    rval = MB_FAILURE;
                    continue;
    return rval;
ErrorCode moab::ReadDamsel::read_tag_values ( const char *  file_name,
const char *  tag_name,
std::vector< int > &  tag_values_out,
) [virtual]
Read the list if all integer tag values from the file for a tag that is a single integer value per entity.
Parameters:
file_nameThe file to read.
tag_nameThe tag for which to read values
tag_values_outOutput: The list of tag values.
subset_listAn array of tag name and value sets specifying the subset of the file to read. If multiple tags are specified, the sets that match all tags (intersection) should be read.
subset_list_lengthThe length of the 'subset_list' array.
Definition at line 251 of file ReadDamsel.cpp.
    return MB_FAILURE;
Member Data Documentation
RangeMap< damsel_handle, EntityHandle, 0 > moab::ReadDamsel::dmHandleRMap [private]
Definition at line 122 of file ReadDamsel.hpp.
Definition at line 125 of file ReadDamsel.hpp.
Referenced by load_file(), process_ent_info(), process_entity_tags(), process_tags(), and ~ReadDamsel().
std::string moab::ReadDamsel::fileName [private]
File name.
Definition at line 110 of file ReadDamsel.hpp.
Interface instance.
Definition at line 104 of file ReadDamsel.hpp.
Referenced by init(), process_entity_tags(), process_tags(), and ~ReadDamsel().
Definition at line 119 of file ReadDamsel.hpp.
Parallel info.
Definition at line 116 of file ReadDamsel.hpp.
Definition at line 113 of file ReadDamsel.hpp.
Referenced by load_file(), and parse_options().
UtilIface.
Definition at line 107 of file ReadDamsel.hpp.
Referenced by init(), process_ent_info(), and ~ReadDamsel().
List of all members.
