moab::ReadIDEAS Class Reference
#include <ReadIDEAS.hpp>
+ Inheritance diagram for moab::ReadIDEAS:
+ Collaboration diagram for moab::ReadIDEAS:
Public Member Functions
ErrorCode load_file (const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0)
 Load mesh from a file.
ErrorCode read_tag_values (const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0)
 Read tag values from a file.
 ReadIDEAS (Interface *impl=NULL)
 Constructor.
virtual ~ReadIDEAS ()
 Destructor.
Static Public Member Functions
static ReaderIfacefactory (Interface *)
Protected Member Functions
ErrorCode skip_header ()
ErrorCode create_vertices (EntityHandle &first_vertex, const Tag *file_id_tag)
ErrorCode create_elements (EntityHandle first_vertex, const Tag *file_id_tag)
Private Attributes
std::ifstream file
RangeMap< int, EntityHandlenodeIdMap
ReadUtilIfacereadMeshIface
InterfaceMBI
Static Private Attributes
static const unsigned SINGLE_PRECISION_NODES = 15
static const unsigned DOUBLE_PRECISION_NODES0 = 781
static const unsigned DOUBLE_PRECISION_NODES1 = 2411
static const unsigned ELEMENTS0 = 71
static const unsigned ELEMENTS1 = 780
static const unsigned ELEMENTS2 = 2412
static const int ROD0 = 11
static const int ROD1 = 171
static const int TRI0 = 41
static const int TRI1 = 91
static const int QUAD0 = 44
static const int QUAD1 = 94
static const int TET = 111
static const int WEDGE = 112
static const int HEX = 115
Detailed Description
Definition at line 24 of file ReadIDEAS.hpp.
Constructor.
Definition at line 25 of file ReadIDEAS.cpp.
References moab::Interface::query_interface(), and readMeshIface.
Referenced by factory().
                                      : MBI( impl )
    impl->query_interface( readMeshIface );
virtual moab::ReadIDEAS::~ReadIDEAS ( ) [inline, virtual]
Destructor.
Definition at line 46 of file ReadIDEAS.hpp.
Member Function Documentation
ErrorCode moab::ReadIDEAS::create_elements ( EntityHandle  first_vertex,
const Tag file_id_tag
) [protected]
Definition at line 209 of file ReadIDEAS.cpp.
References moab::Interface::add_entities(), moab::Interface::create_element(), moab::Interface::create_meshset(), moab::Range::empty(), ErrorCode, file, moab::Range::front(), moab::Interface::get_entities_by_type_and_tag(), moab::Interface::globalId_tag(), HEX, id_tag, MAT_PROP_TABLE_TAG, MAX_NODES_PER_ELEMENT, MB_ALREADY_ALLOCATED, MB_CHK_SET_ERR, MB_MULTIPLE_ENTITIES_FOUND, MB_NOT_IMPLEMENTED, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_INTEGER, MBENTITYSET, MBHEX, MBI, MBPRISM, MBQUAD, MBTET, MBTRI, MESHSET_SET, PHYS_PROP_TABLE_TAG, QUAD0, QUAD1, moab::Range::size(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), TET, TRI0, TRI1, moab::CN::VerticesPerEntity(), and WEDGE.
Referenced by load_file().
    char line1[10000], line2[10000];
    int il1, il2;
    char *ctmp1, *ctmp2;
    std::string s1, s2;
    ErrorCode rval;
    EntityHandle handle;
    Tag mat_tag, phys_tag, id_tag;
    rval = MBI->tag_get_handle( MAT_PROP_TABLE_TAG, 1, MB_TYPE_INTEGER, mat_tag, MB_TAG_DENSE | MB_TAG_CREAT );
    if( MB_SUCCESS != rval && MB_ALREADY_ALLOCATED != rval ) return rval;
    rval = MBI->tag_get_handle( PHYS_PROP_TABLE_TAG, 1, MB_TYPE_INTEGER, phys_tag, MB_TAG_DENSE | MB_TAG_CREAT );
    id_tag = MBI->globalId_tag();
    for( ;; )
        if( !file.getline( line1, 10000 ) || !file.getline( line2, 10000 ) ) return MB_FAILURE;
        // Check if we are at the end of the block
        il1 = std::strtol( line1, &ctmp1, 10 );
        il2 = std::strtol( line2, &ctmp2, 10 );
        if( ( il1 == -1 ) && ( il2 == -1 ) )
            s1 = ctmp1;
            s2 = ctmp2;
            if( ( s1.empty() ) && ( s2.empty() ) ) return MB_SUCCESS;
        // The first line describes attributes of the element other than connectivity.
        const int element_id = strtol( line1 + 1, &ctmp1, 10 );
        const int ideas_type = strtol( line1 + 11, &ctmp1, 10 );
        const int phys_table = strtol( line1 + 21, &ctmp1, 10 );
        const int mat_table  = strtol( line1 + 31, &ctmp1, 10 );
        // Determine the element type.
        EntityType mb_type;
        if( TRI0 == ideas_type || TRI1 == ideas_type )
            mb_type = MBTRI;
        else if( QUAD0 == ideas_type || QUAD1 == ideas_type )
            mb_type = MBQUAD;
        else if( TET == ideas_type )
            mb_type = MBTET;
        else if( HEX == ideas_type )
            mb_type = MBHEX;
        else if( WEDGE == ideas_type )
            mb_type = MBPRISM;
        else
            std::cout << "IDEAS element type not yet added to MOAB reader." << std::endl;
            return MB_NOT_IMPLEMENTED;
        // Get the connectivity out of the 2nd line
        std::stringstream ss( line2 );
        const int n_conn = CN::VerticesPerEntity( mb_type );
        EntityHandle conn[CN::MAX_NODES_PER_ELEMENT];
        EntityHandle vert;
        for( int i = 0; i < n_conn; ++i )
            ss >> vert;
            conn[i] = vstart + vert - 1;
        // Make the element. According to the Gmsh 2.2.3 source code, the IDEAS
        // canonical numbering is the same as MBCN.
        rval = MBI->create_element( mb_type, conn, n_conn, handle );MB_CHK_SET_ERR( rval, "can't create elements of type " << mb_type );
        // If the phys set does not already exist, create it.
        Range phys_sets;
        EntityHandle phys_set;
        const void* const phys_set_id_val[] = { &phys_table };
        rval = MBI->get_entities_by_type_and_tag( 0, MBENTITYSET, &phys_tag, phys_set_id_val, 1, phys_sets );MB_CHK_SET_ERR( rval, "can't get phys sets" );
        if( phys_sets.empty() )
            rval = MBI->create_meshset( MESHSET_SET, phys_set );MB_CHK_SET_ERR( rval, "can't create phys set" );
            rval = MBI->tag_set_data( phys_tag, &phys_set, 1, &phys_table );MB_CHK_SET_ERR( rval, "can't set tag to phys set" );
        else if( 1 == phys_sets.size() )
            phys_set = phys_sets.front();
        else
            return MB_MULTIPLE_ENTITIES_FOUND;
        rval = MBI->add_entities( phys_set, &handle, 1 );MB_CHK_SET_ERR( rval, "can't add entities to phys set" );
        // If the material set does not already exist, create it.
        Range mat_sets;
        EntityHandle mat_set;
        const void* const mat_set_id_val[] = { &mat_table };
        rval = MBI->get_entities_by_type_and_tag( 0, MBENTITYSET, &mat_tag, mat_set_id_val, 1, mat_sets );
        if( MB_SUCCESS != rval ) return rval;
        if( mat_sets.empty() )
            rval = MBI->create_meshset( MESHSET_SET, mat_set );
            rval = MBI->tag_set_data( mat_tag, &mat_set, 1, &mat_table );
        else if( 1 == mat_sets.size() )
            mat_set = mat_sets.front();
        else
        rval = MBI->add_entities( mat_set, &handle, 1 );
        // Tag the element with its id
        rval = MBI->tag_set_data( id_tag, &handle, 1, &element_id );MB_CHK_SET_ERR( rval, "Failed to assign IDs" );
        if( file_id_tag )
            rval = MBI->tag_set_data( *file_id_tag, &handle, 1, &element_id );MB_CHK_SET_ERR( rval, "Failed to assign file IDs" );
    return MB_SUCCESS;
ErrorCode moab::ReadIDEAS::create_vertices ( EntityHandle first_vertex,
) [protected]
Definition at line 129 of file ReadIDEAS.cpp.
References moab::ReadUtilIface::assign_ids(), ErrorCode, file, moab::ReadUtilIface::get_node_coords(), moab::Interface::globalId_tag(), id_tag, moab::Range::insert(), MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MBI, and readMeshIface.
    // Read two lines: first has some data, second has coordinates
    int il1, il2;
    std::string s1, s2;
    ErrorCode rval;
    std::streampos top_of_block = file.tellg();
    unsigned int num_verts      = 0;
    for( ;; )
        // Read both lines
        if( !file.getline( line1, 10000 ) ) return MB_FAILURE;
        if( !file.getline( line2, 10000 ) ) return MB_FAILURE;
            s1 = ctmp1;
            s2 = ctmp2;
            if( ( s1.empty() ) && ( s2.empty() ) ) break;
        num_verts++;
    file.seekg( top_of_block );
    std::vector< double* > arrays;
    rval = readMeshIface->get_node_coords( 3, num_verts, 0, first_vertex, arrays );
    Range verts;
    verts.insert( first_vertex, first_vertex + num_verts - 1 );
    double* x = arrays[0];
    double* y = arrays[1];
    double* z = arrays[2];
    // For now, assume ids are sequential and begin with 1
    Tag id_tag                  = MBI->globalId_tag();
    const int beginning_node_id = 1;
    int node_id                 = beginning_node_id;
    for( unsigned int i = 0; i < num_verts; i++ )
        // Get the id out of the 1st line. Check the assumption that node ids are
        // sequential and begin with 1.
        if( node_id != std::strtol( line1, &ctmp1, 10 ) )
            MB_SET_ERR( MB_FAILURE, "node_id " << node_id << " line2:" << line2 << " ctmp1:" << ctmp1 );
        else
            ++node_id;
        // Get the doubles out of the 2nd line
        x[i] = std::strtod( line2, &ctmp2 );
        y[i] = std::strtod( ctmp2 + 1, &ctmp2 );
        z[i] = std::strtod( ctmp2 + 1, NULL );
    if( !file.getline( line1, 10000 ) ) MB_SET_ERR( MB_FAILURE, " expect more lines" );
    if( !file.getline( line2, 10000 ) ) MB_SET_ERR( MB_FAILURE, " expect more lines 2" );
    // Tag the nodes with ids
    rval = readMeshIface->assign_ids( id_tag, verts, beginning_node_id );MB_CHK_SET_ERR( rval, "Failed to assign IDs" );
    if( file_id_tag )
        rval = readMeshIface->assign_ids( *file_id_tag, verts, beginning_node_id );MB_CHK_SET_ERR( rval, "Failed to assign file IDs" );
    return MB_SUCCESS;
Definition at line 20 of file ReadIDEAS.cpp.
References ReadIDEAS().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
    return new ReadIDEAS( iface );
ErrorCode moab::ReadIDEAS::load_file ( const char *  file_name,
const EntityHandle file_set,
const FileOptions opts,
const SubsetList subset_list = 0,
const Tag file_id_tag = 0
) [virtual]
Method all readers must provide to import a mesh.
Parameters:
file_nameThe file to read.
file_setOptional pointer to entity set representing file. If this is not NULL, reader may optionally tag the pointed-to set with format-specific meta-data.
subset_listAn optional struct pointer specifying the tags identifying entity sets to be read.
file_id_tagIf specified, reader should store for each entity it reads, a unique integer ID for this tag.
Author:
Jason Kraftcheck
Implements moab::ReaderIface.
Definition at line 39 of file ReadIDEAS.cpp.
References create_elements(), create_vertices(), DOUBLE_PRECISION_NODES0, DOUBLE_PRECISION_NODES1, ELEMENTS0, ELEMENTS1, ELEMENTS2, ErrorCode, file, MB_CHK_SET_ERR, MB_FILE_DOES_NOT_EXIST, MB_SET_ERR, MB_SUCCESS, MB_UNSUPPORTED_OPERATION, and skip_header().
    if( subset_list )
        MB_SET_ERR( MB_UNSUPPORTED_OPERATION, "Reading subset of files not supported for IDEAS" );
    file.open( fname );
    if( !file.good() )
        MB_SET_ERR( MB_FILE_DOES_NOT_EXIST, "Failed to open file: " << fname );
    ErrorCode rval;
    char line[10000];
    file.getline( line, 10000 );
    char* liter = line;
    while( *liter && isspace( *liter ) )
        ++liter;
    if( *liter != '-' ) return MB_FAILURE;
    ++liter;
    if( *liter != '1' ) return MB_FAILURE;
    while( *++liter )
        if( !isspace( *liter ) ) return MB_FAILURE;
    EntityHandle first_vertex = 0;
    while( !file.eof() )
        unsigned int header_id = (unsigned int)strtol( line, NULL, 10 );
        // Create vertices
        if( DOUBLE_PRECISION_NODES0 == header_id || DOUBLE_PRECISION_NODES1 == header_id )
            if( first_vertex )  // multiple vertex blocks?
                return MB_FAILURE;
            rval = create_vertices( first_vertex, file_id_tag );MB_CHK_SET_ERR( rval, "Failed to read vertices" );
        // Create elements
        else if( ELEMENTS0 == header_id || ELEMENTS1 == header_id || ELEMENTS2 == header_id )
            if( !first_vertex )  // Need to read vertices first
                return MB_FAILURE;
            rval = create_elements( first_vertex, file_id_tag );MB_CHK_SET_ERR( rval, "Failed to read elements" );
        // Skip everything else
        else
            rval = skip_header();
            if( MB_SUCCESS != rval ) return MB_FAILURE;
    file.close();
    return MB_SUCCESS;
ErrorCode moab::ReadIDEAS::read_tag_values ( const char *  file_name,
const char *  tag_name,
std::vector< int > &  tag_values_out,
) [virtual]
Read the list if all integer tag values from the file for a tag that is a single integer value per entity.
Parameters:
tag_nameThe tag for which to read values
tag_values_outOutput: The list of tag values.
subset_listAn array of tag name and value sets specifying the subset of the file to read. If multiple tags are specified, the sets that match all tags (intersection) should be read.
subset_list_lengthThe length of the 'subset_list' array.
Definition at line 30 of file ReadIDEAS.cpp.
References MB_NOT_IMPLEMENTED.
Definition at line 101 of file ReadIDEAS.cpp.
References file, and MB_SUCCESS.
    // Go until finding a pair of -1 lines
    char* ctmp;
    char line[10000];
    std::string s;
    int end_of_block = 0;
    long int il;
    while( file.getline( line, 10000 ) )
        il = std::strtol( line, &ctmp, 10 );
        if( il == -1 )
            s = ctmp;
            if( s.empty() ) end_of_block++;
        else
            end_of_block = 0;
        if( end_of_block >= 2 ) return MB_SUCCESS;
    return MB_SUCCESS;
Member Data Documentation
const unsigned moab::ReadIDEAS::DOUBLE_PRECISION_NODES0 = 781 [static, private]
Definition at line 82 of file ReadIDEAS.hpp.
const unsigned moab::ReadIDEAS::DOUBLE_PRECISION_NODES1 = 2411 [static, private]
Definition at line 83 of file ReadIDEAS.hpp.
const unsigned moab::ReadIDEAS::ELEMENTS0 = 71 [static, private]
Definition at line 91 of file ReadIDEAS.hpp.
const unsigned moab::ReadIDEAS::ELEMENTS1 = 780 [static, private]
Definition at line 92 of file ReadIDEAS.hpp.
const unsigned moab::ReadIDEAS::ELEMENTS2 = 2412 [static, private]
Definition at line 93 of file ReadIDEAS.hpp.
std::ifstream moab::ReadIDEAS::file [private]
Definition at line 54 of file ReadIDEAS.hpp.
Referenced by create_elements(), create_vertices(), load_file(), and skip_header().
const int moab::ReadIDEAS::HEX = 115 [static, private]
Definition at line 107 of file ReadIDEAS.hpp.
Referenced by create_elements().
Definition at line 61 of file ReadIDEAS.hpp.
Referenced by create_elements(), and create_vertices().
Definition at line 55 of file ReadIDEAS.hpp.
const int moab::ReadIDEAS::QUAD0 = 44 [static, private]
Definition at line 103 of file ReadIDEAS.hpp.
const int moab::ReadIDEAS::QUAD1 = 94 [static, private]
Definition at line 104 of file ReadIDEAS.hpp.
Definition at line 58 of file ReadIDEAS.hpp.
Referenced by create_vertices(), and ReadIDEAS().
const int moab::ReadIDEAS::ROD0 = 11 [static, private]
Definition at line 99 of file ReadIDEAS.hpp.
const int moab::ReadIDEAS::ROD1 = 171 [static, private]
Definition at line 100 of file ReadIDEAS.hpp.
const unsigned moab::ReadIDEAS::SINGLE_PRECISION_NODES = 15 [static, private]
Definition at line 76 of file ReadIDEAS.hpp.
const int moab::ReadIDEAS::TET = 111 [static, private]
Definition at line 105 of file ReadIDEAS.hpp.
const int moab::ReadIDEAS::TRI0 = 41 [static, private]
Definition at line 101 of file ReadIDEAS.hpp.
const int moab::ReadIDEAS::TRI1 = 91 [static, private]
Definition at line 102 of file ReadIDEAS.hpp.
const int moab::ReadIDEAS::WEDGE = 112 [static, private]
Definition at line 106 of file ReadIDEAS.hpp.
List of all members.
