moab::ReadParallel Class Reference
#include <ReadParallel.hpp>
+ Collaboration diagram for moab::ReadParallel:
Public Types
enum  ParallelActions {
  PA_READ = 0, PA_READ_PART = 1, PA_BROADCAST = 2, PA_DELETE_NONLOCAL = 3,
  PA_CHECK_GIDS_SERIAL = 4, PA_GET_FILESET_ENTS = 5, PA_RESOLVE_SHARED_ENTS = 6, PA_EXCHANGE_GHOSTS = 7,
  PA_RESOLVE_SHARED_SETS = 8, PA_AUGMENT_SETS_WITH_GHOSTS = 9, PA_PRINT_PARALLEL = 10, PA_CREATE_TRIVIAL_PARTITION = 11,
  PA_CORRECT_THIN_GHOSTS = 12
enum  ParallelOpts {
  POPT_NONE = 0, POPT_BCAST, POPT_BCAST_DELETE, POPT_READ_DELETE,
  POPT_READ_PART, POPT_DEFAULT
Public Member Functions
ErrorCode load_file (const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const ReaderIface::SubsetList *subset_list=0, const Tag *file_id_tag=0)
 load a file
ErrorCode load_file (const char **file_names, const int num_files, const EntityHandle *file_set, const FileOptions &opts, const ReaderIface::SubsetList *subset_list=0, const Tag *file_id_tag=0)
 load multiple files
ErrorCode load_file (const char **file_names, const int num_files, const EntityHandle *file_set, int parallel_mode, std::string &partition_tag_name, std::vector< int > &partition_tag_vals, bool distrib, bool partition_by_rank, std::vector< int > &pa_vec, const FileOptions &opts, const ReaderIface::SubsetList *subset_list, const Tag *file_id_tag, const int reader_rank, const bool cputime, const int resolve_dim, const int shared_dim, const int ghost_dim, const int bridge_dim, const int num_layers, const int addl_ents)
 ReadParallel (Interface *impl=NULL, ParallelComm *pc=NULL)
 Constructor.
virtual ~ReadParallel ()
 Destructor.
ErrorCode delete_nonlocal_entities (std::string &ptag_name, std::vector< int > &ptag_vals, bool distribute, EntityHandle file_set)
 PUBLIC TO ALLOW TESTING.
ErrorCode delete_nonlocal_entities (EntityHandle file_set)
Static Public Member Functions
static ReaderIfacefactory (Interface *)
Static Public Attributes
static const char * parallelOptsNames [] = { "NONE", "BCAST", "BCAST_DELETE", "READ_DELETE", "READ_PART", "", 0 }
static const char * ParallelActionsNames []
Protected Member Functions
ErrorCode create_partition_sets (std::string &ptag_name, EntityHandle file_set)
Private Attributes
InterfacembImpl
ParallelCommmyPcomm
DebugOutput myDebug
ErrormError
Detailed Description
Definition at line 17 of file ReadParallel.hpp.
Member Enumeration Documentation
Enumerator:
PA_READ
PA_READ_PART
PA_BROADCAST
PA_DELETE_NONLOCAL
PA_GET_FILESET_ENTS
PA_EXCHANGE_GHOSTS
PA_PRINT_PARALLEL
Definition at line 66 of file ReadParallel.hpp.
Enumerator:
POPT_NONE
POPT_BCAST
POPT_BCAST_DELETE
POPT_READ_DELETE
POPT_READ_PART
POPT_DEFAULT
Definition at line 85 of file ReadParallel.hpp.
moab::ReadParallel::ReadParallel ( Interface impl = NULL,
ParallelComm pc = NULL
Constructor.
Definition at line 39 of file ReadParallel.cpp.
References moab::debug, moab::ParallelComm::get_pcomm(), mbImpl, mError, MPI_COMM_WORLD, myDebug, myPcomm, moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::Interface::query_interface(), moab::DebugOutput::set_rank(), and moab::DebugOutput::set_verbosity().
    : mbImpl( impl ), myPcomm( pc ), myDebug( "ReadPara", std::cerr )
    if( !myPcomm )
        myPcomm = ParallelComm::get_pcomm( mbImpl, 0 );
        if( NULL == myPcomm ) myPcomm = new ParallelComm( mbImpl, MPI_COMM_WORLD );
    myDebug.set_rank( myPcomm->proc_config().proc_rank() );
    if( debug )  // For backwards compatibility, enable all debug output if constant is true
        myDebug.set_verbosity( 10 );
    impl->query_interface( mError );
virtual moab::ReadParallel::~ReadParallel ( ) [inline, virtual]
Destructor.
Definition at line 62 of file ReadParallel.hpp.
Member Function Documentation
ErrorCode moab::ReadParallel::create_partition_sets ( std::string &  ptag_name,
) [protected]
Definition at line 720 of file ReadParallel.cpp.
References moab::Range::empty(), ErrorCode, moab::Interface::get_entities_by_type_and_tag(), MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBENTITYSET, mbImpl, myPcomm, PARALLEL_PARTITION_TAG_NAME, moab::ParallelComm::partition_sets(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::Range::size(), moab::Interface::tag_delete_data(), moab::Interface::tag_get_handle(), and moab::Interface::tag_set_data().
Referenced by load_file().
    int proc_rk      = myPcomm->proc_config().proc_rank();
    ErrorCode result = MB_SUCCESS;
    Tag ptag;
    // Tag the partition sets with a standard tag name
    if( ptag_name.empty() ) ptag_name = PARALLEL_PARTITION_TAG_NAME;
    bool tag_created = false;
    result = mbImpl->tag_get_handle( ptag_name.c_str(), 1, MB_TYPE_INTEGER, ptag, MB_TAG_SPARSE | MB_TAG_CREAT, 0,
                                     &tag_created );MB_CHK_SET_ERR( result, "Trouble getting PARALLEL_PARTITION tag" );
    if( !tag_created )
        // This tag already exists; better check to see that tagged sets
        // agree with this partition
        Range tagged_sets;
        int* proc_rk_ptr = &proc_rk;
        result = mbImpl->get_entities_by_type_and_tag( file_set, MBENTITYSET, &ptag, (const void* const*)&proc_rk_ptr,
                                                       1, tagged_sets );MB_CHK_SET_ERR( result, "Trouble getting tagged sets" );
        if( !tagged_sets.empty() && tagged_sets != myPcomm->partition_sets() )
            result = mbImpl->tag_delete_data( ptag, tagged_sets );MB_CHK_SET_ERR( result, "Trouble deleting data of PARALLEL_PARTITION tag" );
        else if( tagged_sets == myPcomm->partition_sets() )
            return MB_SUCCESS;
    // If we get here, we need to assign the tag
    std::vector< int > values( myPcomm->partition_sets().size() );
    for( unsigned int i = 0; i < myPcomm->partition_sets().size(); i++ )
        values[i] = proc_rk;
    result = mbImpl->tag_set_data( ptag, myPcomm->partition_sets(), &values[0] );MB_CHK_SET_ERR( result, "Trouble setting data to PARALLEL_PARTITION tag" );
    return MB_SUCCESS;
ErrorCode moab::ReadParallel::delete_nonlocal_entities ( std::string &  ptag_name,
std::vector< int > &  ptag_vals,
bool  distribute,
Definition at line 654 of file ReadParallel.cpp.
References ErrorCode, moab::Interface::get_entities_by_type_and_tag(), moab::Range::insert(), MB_CHK_ERR, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TYPE_INTEGER, MBENTITYSET, mbImpl, myDebug, myPcomm, moab::ParallelComm::partition_sets(), moab::DebugOutput::print(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), moab::Range::size(), moab::Range::swap(), moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
    Range partition_sets;
    Tag ptag;
    ErrorCode result = mbImpl->tag_get_handle( ptag_name.c_str(), 1, MB_TYPE_INTEGER, ptag );MB_CHK_SET_ERR( result, "Failed getting tag handle in delete_nonlocal_entities" );
    result = mbImpl->get_entities_by_type_and_tag( file_set, MBENTITYSET, &ptag, NULL, 1, myPcomm->partition_sets() );MB_CHK_SET_ERR( result, "Failed to get sets with partition-type tag" );
    int proc_sz = myPcomm->proc_config().proc_size();
    if( !ptag_vals.empty() )
        // Values input, get sets with those values
        Range tmp_sets;
        std::vector< int > tag_vals( myPcomm->partition_sets().size() );
        result = mbImpl->tag_get_data( ptag, myPcomm->partition_sets(), &tag_vals[0] );MB_CHK_SET_ERR( result, "Failed to get tag data for partition vals tag" );
        for( std::vector< int >::iterator pit = tag_vals.begin(); pit != tag_vals.end(); ++pit )
            std::vector< int >::iterator pit2 = std::find( ptag_vals.begin(), ptag_vals.end(), *pit );
            if( pit2 != ptag_vals.end() ) tmp_sets.insert( myPcomm->partition_sets()[pit - tag_vals.begin()] );
        myPcomm->partition_sets().swap( tmp_sets );
    if( distribute )
        // For now, require that number of partition sets be greater
        // than number of procs
        if( myPcomm->partition_sets().size() < (unsigned int)proc_sz )
            MB_SET_ERR( MB_FAILURE, "Too few parts; P = " << proc_rk << ", tag = " << ptag
                                                          << ", # sets = " << myPcomm->partition_sets().size() );
        Range tmp_sets;
        // Distribute the partition sets
        unsigned int num_sets     = myPcomm->partition_sets().size() / proc_sz;
        unsigned int num_leftover = myPcomm->partition_sets().size() % proc_sz;
        int begin_set             = 0;
        if( proc_rk < (int)num_leftover )
            num_sets++;
            begin_set = num_sets * proc_rk;
        else
            begin_set = proc_rk * num_sets + num_leftover;
        for( unsigned int i = 0; i < num_sets; i++ )
            tmp_sets.insert( myPcomm->partition_sets()[begin_set + i] );
    myDebug.print( 1, "My partition sets: ", myPcomm->partition_sets() );
    result = delete_nonlocal_entities( file_set );MB_CHK_ERR( result );
    return MB_SUCCESS;
Definition at line 758 of file ReadParallel.cpp.
References moab::Range::begin(), moab::Interface::delete_entities(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::ReadUtilIface::gather_related_ents(), moab::Interface::get_entities_by_handle(), MB_CHK_SET_ERR, MB_SUCCESS, MBENTITYSET, mbImpl, myDebug, myPcomm, moab::ParallelComm::partition_sets(), moab::DebugOutput::print(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::Interface::query_interface(), moab::Interface::remove_entities(), moab::Range::subset_by_type(), moab::subtract(), and moab::DebugOutput::tprint().
    // Get partition entities and ents related to/used by those
    // get ents in the partition
    ReadUtilIface* read_iface;
    mbImpl->query_interface( read_iface );
    Range partition_ents, all_sets;
    myDebug.tprint( 2, "Gathering related entities.\n" );
    ErrorCode result = read_iface->gather_related_ents( myPcomm->partition_sets(), partition_ents, &file_set );MB_CHK_SET_ERR( result, "Failure gathering related entities" );
    // Get pre-existing entities
    Range file_ents;
    result = mbImpl->get_entities_by_handle( file_set, file_ents );MB_CHK_SET_ERR( result, "Couldn't get pre-existing entities" );
    if( 0 == myPcomm->proc_config().proc_rank() )
        myDebug.print( 2, "File entities: ", file_ents );
    // Get deletable entities by subtracting partition ents from file ents
    Range deletable_ents = subtract( file_ents, partition_ents );
    // Cache deletable vs. keepable sets
    Range deletable_sets = deletable_ents.subset_by_type( MBENTITYSET );
    Range keepable_sets  = subtract( file_ents.subset_by_type( MBENTITYSET ), deletable_sets );
    myDebug.tprint( 2, "Removing deletable entities from keepable sets.\n" );
    // Remove deletable ents from all keepable sets
    for( Range::iterator rit = keepable_sets.begin(); rit != keepable_sets.end(); ++rit )
        result = mbImpl->remove_entities( *rit, deletable_ents );MB_CHK_SET_ERR( result, "Failure removing deletable entities" );
    result = mbImpl->remove_entities( file_set, deletable_ents );MB_CHK_SET_ERR( result, "Failure removing deletable entities" );
    myDebug.tprint( 2, "Deleting deletable entities.\n" );
        myDebug.print( 2, "Deletable sets: ", deletable_sets );
    // Delete sets, then ents
    if( !deletable_sets.empty() )
        result = mbImpl->delete_entities( deletable_sets );MB_CHK_SET_ERR( result, "Failure deleting sets in delete_nonlocal_entities" );
    deletable_ents -= deletable_sets;
        myDebug.print( 2, "Deletable entities: ", deletable_ents );
    if( !deletable_ents.empty() )
        result = mbImpl->delete_entities( deletable_ents );MB_CHK_SET_ERR( result, "Failure deleting entities in delete_nonlocal_entities" );
    return MB_SUCCESS;
ErrorCode moab::ReadParallel::load_file ( const char *  file_name,
const EntityHandle file_set,
const FileOptions opts,
const ReaderIface::SubsetList subset_list = 0,
const Tag file_id_tag = 0
) [inline]
load a file
Definition at line 117 of file ReadParallel.hpp.
Referenced by load_file(), moab::Core::load_file(), and main().
    return load_file( &file_name, 1, file_set, opts, subset_list, file_id_tag );
ErrorCode moab::ReadParallel::load_file ( const char **  file_names,
load multiple files
Definition at line 54 of file ReadParallel.cpp.
References ErrorCode, moab::FileOptions::get_int_option(), moab::FileOptions::get_ints_option(), moab::FileOptions::get_null_option(), moab::FileOptions::get_option(), moab::FileOptions::get_real_option(), moab::FileOptions::get_str_option(), load_file(), moab::FileOptions::mark_all_seen(), moab::FileOptions::match_option(), MB_CHK_ERR, MB_ENTITY_NOT_FOUND, MB_SET_ERR, MB_SUCCESS, MB_TAG_NOT_FOUND, MB_TYPE_OUT_OF_RANGE, mbImpl, myDebug, myPcomm, PA_AUGMENT_SETS_WITH_GHOSTS, PA_BROADCAST, PA_CHECK_GIDS_SERIAL, PA_CORRECT_THIN_GHOSTS, PA_CREATE_TRIVIAL_PARTITION, PA_DELETE_NONLOCAL, PA_EXCHANGE_GHOSTS, PA_GET_FILESET_ENTS, PA_PRINT_PARALLEL, PA_READ, PA_READ_PART, PA_RESOLVE_SHARED_ENTS, PA_RESOLVE_SHARED_SETS, PARALLEL_PARTITION_TAG_NAME, parallelOptsNames, POPT_BCAST, POPT_BCAST_DELETE, POPT_DEFAULT, POPT_READ_DELETE, POPT_READ_PART, moab::DebugOutput::print(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::ParallelComm::set_debug_verbosity(), moab::Interface::set_sequence_multiplier(), moab::DebugOutput::set_verbosity(), moab::Interface::tag_get_handle(), and moab::DebugOutput::tprint().
    int tmpval;
    if( MB_SUCCESS == opts.get_int_option( "DEBUG_PIO", 1, tmpval ) )
        myDebug.set_verbosity( tmpval );
        myPcomm->set_debug_verbosity( tmpval );
    myDebug.tprint( 1, "Setting up...\n" );
    // Get parallel settings
    int parallel_mode;
    ErrorCode result = opts.match_option( "PARALLEL", parallelOptsNames, parallel_mode );
    if( MB_FAILURE == result )
        MB_SET_ERR( MB_FAILURE, "Unexpected value for 'PARALLEL' option" );
    else if( MB_ENTITY_NOT_FOUND == result )
        parallel_mode = 0;
    // Get partition setting
    bool distrib;
    std::string partition_tag_name;
    result = opts.get_option( "PARTITION", partition_tag_name );
        distrib            = false;
        partition_tag_name = "";
    else
        distrib = true;
        if( partition_tag_name.empty() ) partition_tag_name = PARALLEL_PARTITION_TAG_NAME;
        // Also get deprecated PARTITION_DISTRIBUTE option
        // so that higher-level code doesn't return an error
        // due to an unrecognized option
        opts.get_null_option( "PARTITION_DISTRIBUTE" );
    // Get partition tag value(s), if any, and whether they're to be
    // distributed or assigned
    std::vector< int > partition_tag_vals;
    opts.get_ints_option( "PARTITION_VAL", partition_tag_vals );
    // see if partition tag name is "TRIVIAL", if the tag exists
    bool create_trivial_partition = false;
    if( partition_tag_name == std::string( "TRIVIAL" ) )
        Tag ttag;  // see if the trivial tag exists
        result = mbImpl->tag_get_handle( partition_tag_name.c_str(), ttag );
        if( MB_TAG_NOT_FOUND == result ) create_trivial_partition = true;
    // See if we need to report times
    bool cputime = false;
    result       = opts.get_null_option( "CPUTIME" );
    if( MB_SUCCESS == result ) cputime = true;
    bool print_parallel = false;
    result              = opts.get_null_option( "PRINT_PARALLEL" );
    if( MB_SUCCESS == result ) print_parallel = true;
    // Get ghosting options
    std::string ghost_str;
    int bridge_dim, ghost_dim = -1, num_layers, addl_ents = 0;
    result = opts.get_str_option( "PARALLEL_GHOSTS", ghost_str );
    if( MB_TYPE_OUT_OF_RANGE == result )
        ghost_dim  = 3;
        bridge_dim = 0;
        num_layers = 1;
    else if( MB_SUCCESS == result )
        int num_fields = sscanf( ghost_str.c_str(), "%d.%d.%d.%d", &ghost_dim, &bridge_dim, &num_layers, &addl_ents );
        if( 3 > num_fields )
            MB_SET_ERR( MB_FAILURE, "Didn't read 3 fields from PARALLEL_GHOSTS string" );
    // Get resolve_shared_ents option
    std::string shared_str;
    int resolve_dim = -2, shared_dim = -1;
    result = opts.get_str_option( "PARALLEL_RESOLVE_SHARED_ENTS", shared_str );
        resolve_dim = -1;
        shared_dim  = -1;
        int num_fields = sscanf( shared_str.c_str(), "%d.%d", &resolve_dim, &shared_dim );
        if( 2 != num_fields )
            MB_SET_ERR( MB_FAILURE, "Didn't read 2 fields from PARALLEL_RESOLVE_SHARED_ENTS string" );
    // Get skip augmenting with ghosts option
    bool skip_augment = false;
    result            = opts.get_null_option( "SKIP_AUGMENT_WITH_GHOSTS" );
    if( MB_SUCCESS == result ) skip_augment = true;
    bool correct_thin_ghosts = false;
    result                   = opts.get_null_option( "PARALLEL_THIN_GHOST_LAYER" );
    if( MB_SUCCESS == result ) correct_thin_ghosts = true;
    // Get MPI IO processor rank
    int reader_rank;
    result = opts.get_int_option( "MPI_IO_RANK", reader_rank );
        reader_rank = 0;
    else if( MB_SUCCESS != result )
        MB_SET_ERR( MB_FAILURE, "Unexpected value for 'MPI_IO_RANK' option" );
    // Now that we've parsed all the parallel options, make an instruction queue
    std::vector< int > pa_vec;
    bool is_reader = ( reader_rank == (int)myPcomm->proc_config().proc_rank() );
    bool partition_by_rank = false;
    if( MB_SUCCESS == opts.get_null_option( "PARTITION_BY_RANK" ) )
        partition_by_rank = true;
        if( !partition_tag_vals.empty() )
            MB_SET_ERR( MB_FAILURE, "Cannot specify both PARTITION_VALS and PARTITION_BY_RANK" );
    double factor_seq;
    if( MB_SUCCESS == opts.get_real_option( "PARALLEL_SEQUENCE_FACTOR", factor_seq ) )
        if( factor_seq < 1. ) MB_SET_ERR( MB_FAILURE, "cannot have sequence factor less than 1." );
        mbImpl->set_sequence_multiplier( factor_seq );
    switch( parallel_mode )
        case POPT_BCAST:
            myDebug.print( 1, "Read mode is BCAST\n" );
            if( is_reader )
                pa_vec.push_back( PA_READ );
                pa_vec.push_back( PA_CHECK_GIDS_SERIAL );
                pa_vec.push_back( PA_GET_FILESET_ENTS );
            pa_vec.push_back( PA_BROADCAST );
            if( !is_reader ) pa_vec.push_back( PA_GET_FILESET_ENTS );
            break;
        case POPT_BCAST_DELETE:
            myDebug.print( 1, "Read mode is BCAST_DELETE\n" );
            if( is_reader )
                if( create_trivial_partition ) pa_vec.push_back( PA_CREATE_TRIVIAL_PARTITION );
            pa_vec.push_back( PA_DELETE_NONLOCAL );
            break;
        case POPT_DEFAULT:
        case POPT_READ_DELETE:
            myDebug.print( 1, "Read mode is READ_DELETE\n" );
            break;
        case POPT_READ_PART:
            myDebug.print( 1, "Read mode is READ_PART\n" );
            pa_vec.push_back( PA_READ_PART );
            break;
        default:
            MB_SET_ERR( MB_FAILURE, "Unexpected parallel read mode" );
    if( -2 != resolve_dim ) pa_vec.push_back( PA_RESOLVE_SHARED_ENTS );
    if( -1 != ghost_dim ) pa_vec.push_back( PA_EXCHANGE_GHOSTS );
        pa_vec.push_back( PA_RESOLVE_SHARED_SETS );
        if( -1 != ghost_dim && !skip_augment ) pa_vec.push_back( PA_AUGMENT_SETS_WITH_GHOSTS );
        if( -1 != ghost_dim && correct_thin_ghosts ) pa_vec.push_back( PA_CORRECT_THIN_GHOSTS );
    if( print_parallel ) pa_vec.push_back( PA_PRINT_PARALLEL );
    result = load_file( file_names, num_files, file_set, parallel_mode, partition_tag_name, partition_tag_vals, distrib,
                        partition_by_rank, pa_vec, opts, subset_list, file_id_tag, reader_rank, cputime, resolve_dim,
                        shared_dim, ghost_dim, bridge_dim, num_layers, addl_ents );MB_CHK_ERR( result );
    if( parallel_mode == POPT_BCAST_DELETE && !is_reader ) opts.mark_all_seen();
    return MB_SUCCESS;
int  parallel_mode,
std::string &  partition_tag_name,
std::vector< int > &  partition_tag_vals,
bool  distrib,
std::vector< int > &  pa_vec,
const ReaderIface::SubsetList subset_list,
const Tag file_id_tag,
const bool  cputime,
const int  addl_ents
Definition at line 268 of file ReadParallel.cpp.
References moab::Interface::add_entities(), moab::ParallelComm::augment_default_sets_with_ghosts(), moab::Range::begin(), moab::ParallelComm::broadcast_entities(), moab::ParallelComm::check_global_ids(), moab::Range::clear(), moab::ParallelComm::correct_thin_ghost_layers(), moab::Interface::create_meshset(), create_partition_sets(), moab::debug, delete_nonlocal_entities(), moab::Range::empty(), entities, ErrorCode, moab::ParallelComm::exchange_ghost_cells(), moab::ParallelComm::filter_pstatus(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type(), moab::Core::get_entities_by_type_and_tag(), id_tag, moab::Range::insert(), moab::ParallelComm::list_entities(), moab::Interface::list_entities(), MB_CHK_SET_ERR, MB_NOT_IMPLEMENTED, MB_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TAG_SPARSE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, MBENTITYSET, mbImpl, MBVERTEX, MESHSET_SET, MPI_COMM_WORLD, myDebug, myPcomm, moab::ReaderIface::SubsetList::num_parts, moab::ReaderIface::IDTag::num_tag_values, PA_AUGMENT_SETS_WITH_GHOSTS, PA_BROADCAST, PA_CHECK_GIDS_SERIAL, PA_CORRECT_THIN_GHOSTS, PA_CREATE_TRIVIAL_PARTITION, PA_DELETE_NONLOCAL, PA_EXCHANGE_GHOSTS, PA_GET_FILESET_ENTS, PA_PRINT_PARALLEL, PA_READ, PA_READ_PART, PA_RESOLVE_SHARED_ENTS, PA_RESOLVE_SHARED_SETS, ParallelActionsNames, moab::ReaderIface::SubsetList::part_number, moab::ParallelComm::partition_sets(), moab::ProcConfig::proc_comm(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), PSTATUS_NOT, PSTATUS_NOT_OWNED, rank, moab::ParallelComm::rank(), moab::ParallelComm::resolve_shared_ents(), moab::ParallelComm::resolve_shared_sets(), moab::Core::serial_load_file(), moab::Range::size(), moab::ParallelComm::size(), moab::Range::subset_by_dimension(), moab::Interface::tag_delete(), moab::Core::tag_get_handle(), moab::Interface::tag_get_handle(), moab::ReaderIface::SubsetList::tag_list, moab::ReaderIface::SubsetList::tag_list_length, moab::Interface::tag_set_data(), moab::ReaderIface::IDTag::tag_values, moab::DebugOutput::tprint(), and moab::DebugOutput::tprintf().
    if( myPcomm == NULL ) myPcomm = new ParallelComm( mbImpl, MPI_COMM_WORLD );
    Range entities;
    Tag file_set_tag = 0;
    int other_sets   = 0;
    ReaderWriterSet::iterator iter;
    Range other_file_sets, file_sets;
    Core* impl = dynamic_cast< Core* >( mbImpl );
    std::vector< double > act_times( pa_vec.size() + 1 );
    std::vector< int >::iterator vit;
    int i, j;
    act_times[0] = MPI_Wtime();
    // Make a new set for the parallel read
    EntityHandle file_set;
    if( !file_set_ptr || !( *file_set_ptr ) )
        result = mbImpl->create_meshset( MESHSET_SET, file_set );MB_CHK_SET_ERR( result, "Trouble creating file set" );
    else
        file_set = *file_set_ptr;
    bool i_read     = false;
    Tag id_tag      = 0;
    bool use_id_tag = false;
    Range ents;
    for( i = 1, vit = pa_vec.begin(); vit != pa_vec.end(); ++vit, i++ )
        ErrorCode tmp_result = MB_SUCCESS;
        switch( *vit )
            case PA_READ:
                i_read = true;
                for( j = 0; j < num_files; j++ )
                    myDebug.tprintf( 1, "Reading file: \"%s\"\n", file_names[j] );
                    EntityHandle new_file_set;
                    result = mbImpl->create_meshset( MESHSET_SET, new_file_set );MB_CHK_SET_ERR( result, "Trouble creating file set" );
                    tmp_result = impl->serial_load_file( file_names[j], &new_file_set, opts, subset_list, file_id_tag );
                    if( MB_SUCCESS != tmp_result ) break;
                    // Put the contents of each file set for the reader into the
                    // file set for the parallel read
                    assert( 0 != new_file_set );
                    Range all_ents;
                    tmp_result = mbImpl->get_entities_by_handle( new_file_set, all_ents );
                    all_ents.insert( new_file_set );
                    tmp_result = mbImpl->add_entities( file_set, all_ents );
                // Mark the file set for this parallel reader
                tmp_result = mbImpl->tag_get_handle( "__file_set", 1, MB_TYPE_INTEGER, file_set_tag,
                                                     MB_TAG_SPARSE | MB_TAG_CREAT );
                tmp_result = mbImpl->tag_set_data( file_set_tag, &file_set, 1, &other_sets );
                break;
            case PA_READ_PART: {
                myDebug.tprintf( 1, "Reading file: \"%s\"\n", file_names[0] );
                i_read = true;
                if( num_files != 1 )
                    MB_SET_ERR( MB_NOT_IMPLEMENTED, "Multiple file read not supported for READ_PART" );
                // If we're going to resolve shared entities, then we need
                // to ask the file reader to populate a tag with unique ids
                // (typically file ids/indices/whatever.)
                if( std::find( pa_vec.begin(), pa_vec.end(), PA_RESOLVE_SHARED_ENTS ) != pa_vec.end() )
                    use_id_tag = true;
                    if( !file_id_tag )
                        // This tag is really used for resolving shared entities with crystal router
                        // In the end, this is an identifier that gets converted to long
                        // In hdf5 file reader, we also convert from hdf5 file id type to long
                        tmp_result = mbImpl->tag_get_handle( "", sizeof( long ), MB_TYPE_OPAQUE, id_tag,
                                                             MB_TAG_DENSE | MB_TAG_CREAT );
                        file_id_tag = &id_tag;
                ReaderIface::IDTag parts = { partition_tag_name.c_str(), 0, 0 };
                ReaderIface::SubsetList sl;
                sl.num_parts = 0;
                int rank     = myPcomm->rank();
                if( partition_by_rank )
                    assert( partition_tag_vals.empty() );
                    parts.tag_values     = &rank;
                    parts.num_tag_values = 1;
                else
                    sl.num_parts   = myPcomm->size();
                    sl.part_number = myPcomm->rank();
                        parts.tag_values     = &partition_tag_vals[0];
                        parts.num_tag_values = partition_tag_vals.size();
                std::vector< ReaderIface::IDTag > subset;
                if( subset_list )
                    std::vector< ReaderIface::IDTag > tmplist( subset_list->tag_list,
                                                               subset_list->tag_list + subset_list->tag_list_length );
                    tmplist.push_back( parts );
                    subset.swap( tmplist );
                    sl.tag_list        = &subset[0];
                    sl.tag_list_length = subset.size();
                else
                    sl.tag_list        = &parts;
                    sl.tag_list_length = 1;
                tmp_result = impl->serial_load_file( *file_names, &file_set, opts, &sl, file_id_tag );
                if( !partition_tag_name.empty() )
                    Tag part_tag;
                    tmp_result = impl->tag_get_handle( partition_tag_name.c_str(), 1, MB_TYPE_INTEGER, part_tag );
                    tmp_result = impl->get_entities_by_type_and_tag( file_set, MBENTITYSET, &part_tag, 0, 1,
            break;
            case PA_GET_FILESET_ENTS:
                myDebug.tprint( 1, "Getting fileset entities.\n" );
                // Get entities in the file set, and add actual file set to it;
                // mark the file set to make sure any receiving procs know which it is
                tmp_result = mbImpl->get_entities_by_handle( file_set, entities );
                    entities.clear();
                    break;
                // Add actual file set to entities too
                entities.insert( file_set );
                break;
            case PA_CREATE_TRIVIAL_PARTITION: {
                myDebug.tprint( 1, "create trivial partition, for higher dim entities.\n" );
                // get high dim entities (2 or 3)
                Range hi_dim_ents = entities.subset_by_dimension( 3 );
                if( hi_dim_ents.empty() ) hi_dim_ents = entities.subset_by_dimension( 2 );
                if( hi_dim_ents.empty() ) hi_dim_ents = entities.subset_by_dimension( 1 );
                if( hi_dim_ents.empty() ) MB_SET_ERR( MB_FAILURE, "there are no elements of dim 1-3" );
                size_t num_hi_ents     = hi_dim_ents.size();
                unsigned int num_parts = myPcomm->size();
                // create first the trivial partition tag
                int dum_id = -1;
                Tag ttag;  // trivial tag
                tmp_result = mbImpl->tag_get_handle( partition_tag_name.c_str(), 1, MB_TYPE_INTEGER, ttag,
                                                     MB_TAG_CREAT | MB_TAG_SPARSE, &dum_id );MB_CHK_SET_ERR( tmp_result, "Can't create trivial partition tag" );
                // Compute the number of high dim entities on each part
                size_t nPartEnts = num_hi_ents / num_parts;
                // Number of extra entities after equal split over parts
                int iextra          = num_hi_ents % num_parts;
                Range::iterator itr = hi_dim_ents.begin();
                for( int k = 0; k < (int)num_parts; k++ )
                    // create a mesh set, insert a subrange of entities
                    EntityHandle part_set;
                    tmp_result = mbImpl->create_meshset( MESHSET_SET, part_set );MB_CHK_SET_ERR( tmp_result, "Can't create part set" );
                    entities.insert( part_set );
                    tmp_result = mbImpl->tag_set_data( ttag, &part_set, 1, &k );MB_CHK_SET_ERR( tmp_result, "Can't set trivial partition tag" );
                    Range subrange;
                    size_t num_ents_in_part = nPartEnts;
                    if( i < iextra ) num_ents_in_part++;
                    for( size_t i1 = 0; i1 < num_ents_in_part; i1++, itr++ )
                        subrange.insert( *itr );
                    tmp_result = mbImpl->add_entities( part_set, subrange );MB_CHK_SET_ERR( tmp_result, "Can't add entities to trivial part " << k );
                    myDebug.tprintf( 1, "create trivial part %d with %lu entities \n", k, num_ents_in_part );
                    tmp_result = mbImpl->add_entities( file_set, &part_set, 1 );MB_CHK_SET_ERR( tmp_result, "Can't add trivial part to file set " << k );
            break;
            case PA_BROADCAST:
                // Do the actual broadcast; if single-processor, ignore error
                myDebug.tprint( 1, "Broadcasting mesh.\n" );
                if( myPcomm->proc_config().proc_size() > 1 )
                    tmp_result = myPcomm->broadcast_entities( reader_rank, entities );
                if( debug )
                    std::cerr << "Bcast done; entities:" << std::endl;
                    mbImpl->list_entities( 0, 0 );
                // Add the received entities to this fileset if I wasn't the reader
                if( !i_read && MB_SUCCESS == tmp_result ) tmp_result = mbImpl->add_entities( file_set, entities );
                break;
            case PA_DELETE_NONLOCAL:
                myDebug.tprint( 1, "Deleting nonlocal entities.\n" );
                tmp_result = delete_nonlocal_entities( partition_tag_name, partition_tag_vals, distrib, file_set );
                if( debug )
                    std::cerr << "Delete nonlocal done; entities:" << std::endl;
                if( MB_SUCCESS == tmp_result ) tmp_result = create_partition_sets( partition_tag_name, file_set );
                break;
            case PA_CHECK_GIDS_SERIAL:
                myDebug.tprint( 1, "Checking global IDs.\n" );
                tmp_result = myPcomm->check_global_ids( file_set, 0, 1, true, false );
                break;
            case PA_RESOLVE_SHARED_ENTS:
                myDebug.tprint( 1, "Resolving shared entities.\n" );
                if( 1 == myPcomm->size() )
                else
                    tmp_result =
                        myPcomm->resolve_shared_ents( file_set, resolve_dim, shared_dim, use_id_tag ? file_id_tag : 0 );
#ifndef NDEBUG
                // check number of owned vertices through pcomm's public interface
                tmp_result = mbImpl->get_entities_by_type( 0, MBVERTEX, ents );
                    tmp_result = myPcomm->filter_pstatus( ents, PSTATUS_NOT_OWNED, PSTATUS_NOT );
                    myDebug.tprintf( 1, "Proc %u reports %lu owned vertices.\n", myPcomm->proc_config().proc_rank(),
                                     ents.size() );
#endif
                break;
            case PA_EXCHANGE_GHOSTS:
                myDebug.tprint( 1, "Exchanging ghost entities.\n" );
                tmp_result = myPcomm->exchange_ghost_cells( ghost_dim, bridge_dim, num_layers, addl_ents, true, true,
                                                            &file_set );
                break;
            case PA_RESOLVE_SHARED_SETS:
                myDebug.tprint( 1, "Resolving shared sets.\n" );
                else
                    tmp_result = myPcomm->resolve_shared_sets( file_set, use_id_tag ? file_id_tag : 0 );
                break;
            case PA_AUGMENT_SETS_WITH_GHOSTS:
                myDebug.tprint( 1, "Augmenting sets with ghost entities.\n" );
                else
                    tmp_result = myPcomm->augment_default_sets_with_ghosts( file_set );
                break;
            case PA_CORRECT_THIN_GHOSTS:
                myDebug.tprint( 1, "correcting thin ghost layers.\n" );
                if( 2 >= myPcomm->size() )  // it is a problem only for multi-shared entities
                else
                    tmp_result = myPcomm->correct_thin_ghost_layers();
                break;
            case PA_PRINT_PARALLEL:
                myDebug.tprint( 1, "Printing parallel information.\n" );
                tmp_result = myPcomm->list_entities( 0, -1 );
                break;
            default:
                MB_SET_ERR( MB_FAILURE, "Unexpected parallel action" );
        }  // switch (*vit)
            MB_SET_ERR( MB_FAILURE, "Failed in step " << ParallelActionsNames[*vit] );
        if( cputime ) act_times[i] = MPI_Wtime();
    }  // for (i = 1, vit = pa_vec.begin(); vit != pa_vec.end(); ++vit, i++)
    if( use_id_tag )
        result = mbImpl->tag_delete( id_tag );MB_CHK_SET_ERR( result, "Trouble deleting id tag" );
    if( cputime )
        for( i = pa_vec.size(); i > 0; i-- )
            act_times[i] -= act_times[i - 1];
        // Replace initial time with overall time
        act_times[0] = MPI_Wtime() - act_times[0];
        // Get the maximum over all procs
        if( 0 != myPcomm->proc_config().proc_rank() )
            MPI_Reduce( &act_times[0], 0, pa_vec.size() + 1, MPI_DOUBLE, MPI_MAX, 0,
                        myPcomm->proc_config().proc_comm() );
        else
#if( MPI_VERSION >= 2 )
            MPI_Reduce( MPI_IN_PLACE, &act_times[0], pa_vec.size() + 1, MPI_DOUBLE, MPI_MAX, 0,
#else
            // Note, extra comm-size allocation is required
            std::vector< double > act_times_tmp( pa_vec.size() + 1 );
            MPI_Reduce( &act_times[0], &act_times_tmp[0], pa_vec.size() + 1, MPI_DOUBLE, MPI_MAX, 0,
            act_times = act_times_tmp;  // extra copy here too
#endif
            std::cout << "Parallel Read times: " << std::endl;
                std::cout << "  " << act_times[i] << " " << ParallelActionsNames[*vit] << std::endl;
            std::cout << "  " << act_times[0] << " PARALLEL TOTAL" << std::endl;
    return MB_SUCCESS;
Member Data Documentation
Definition at line 114 of file ReadParallel.hpp.
Referenced by ReadParallel().
Initial value:
 { "PARALLEL READ",
                                                     "PARALLEL READ PART",
                                                     "PARALLEL BROADCAST",
                                                     "PARALLEL DELETE NONLOCAL",
                                                     "PARALLEL CHECK_GIDS_SERIAL",
                                                     "PARALLEL GET_FILESET_ENTS",
                                                     "PARALLEL RESOLVE_SHARED_ENTS",
                                                     "PARALLEL EXCHANGE_GHOSTS",
                                                     "PARALLEL RESOLVE_SHARED_SETS",
                                                     "PARALLEL_AUGMENT_SETS_WITH_GHOSTS",
                                                     "PARALLEL PRINT_PARALLEL",
                                                     "PARALLEL_CREATE_TRIVIAL_PARTITION",
                                                     "PARALLEL_CORRECT_THIN_GHOST_LAYERS" }
Definition at line 83 of file ReadParallel.hpp.
const char * moab::ReadParallel::parallelOptsNames = { "NONE", "BCAST", "BCAST_DELETE", "READ_DELETE", "READ_PART", "", 0 } [static]
Definition at line 64 of file ReadParallel.hpp.
List of all members.
