moab::ReadTemplate Class Reference
Template for implementing new file readers in MOAB This class is a template for writing new file readers in MOAB. This shows how to efficiently create vertices and elements using the ReadUtilIface class, and to translate indices in connectivity lists into vertex handles created during the read. More...
#include <ReadTemplate.hpp>
+ Inheritance diagram for moab::ReadTemplate:
+ Collaboration diagram for moab::ReadTemplate:
Public Member Functions
ErrorCode load_file (const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0)
 Load mesh from a file.
ErrorCode read_tag_values (const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0)
 Read tag values from a file.
 ReadTemplate (Interface *impl=NULL)
 Constructor.
virtual ~ReadTemplate ()
 Destructor.
Static Public Member Functions
static ReaderIfacefactory (Interface *)
 factory method
Private Member Functions
ErrorCode read_vertices (int num_verts, EntityHandle &start_vertex, Range &read_ents)
 Read vertex data and create vertices in MOAB database.
ErrorCode read_elements (int num_elems, EntityHandle start_vertex, EntityHandle &start_elem, Range &read_ents)
 Read element data and create elements in MOAB database.
ErrorCode create_sets (int num_sets, EntityHandle start_vertex, int num_verts, EntityHandle start_elem, int num_elems, Range &read_ents)
 Read entity set data and create/populate sets in MOAB database.
ErrorCode process_options (const FileOptions &opts)
 Process options passed into the reader.
Private Attributes
ReadUtilIfacereadMeshIface
InterfacembImpl
 interface instance
const char * fileName
Detailed Description
After writing the new reader class, you should also modify src/ReaderWriterSet.cpp, to register the new reader along with the file extensions that it reads. This will turn on automatic creating of this reader based on file extension, which is done in Core::serial_load_file.
Definition at line 23 of file ReadTemplate.hpp.
Constructor.
Definition at line 24 of file ReadTemplate.cpp.
References mbImpl, moab::Interface::query_interface(), and readMeshIface.
Referenced by factory().
                                            : mbImpl( impl ), fileName( NULL )
    mbImpl->query_interface( readMeshIface );
Destructor.
Definition at line 29 of file ReadTemplate.cpp.
References mbImpl, readMeshIface, and moab::Interface::release_interface().
Member Function Documentation
ErrorCode ReadTemplate::create_sets ( int  num_sets,
int  num_verts,
int  num_elems,
Range read_ents
) [private]
Read/create sets.
Parameters:
num_setsNumber of sets to be read
start_vertexStarting vertex handle
num_vertsTotal number of vertices read from file
start_elemStarting element handle
num_elemsTotal number of elements read from file
read_entsRange storing all entities read from this file
Definition at line 208 of file ReadTemplate.cpp.
References moab::Interface::add_entities(), moab::Interface::create_meshset(), ErrorCode, fileName, moab::Range::insert(), MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, and MESHSET_SET.
Referenced by load_file().
    ErrorCode result = MB_SUCCESS;
    EntityHandle this_set;
    for( int i = 0; i < num_sets; i++ )
        // Create set
        result = mbImpl->create_meshset( MESHSET_SET, this_set );MB_CHK_SET_ERR( result, fileName << ": Trouble creating set" );
        Range set_ents;
        // Read/compute what's in this set; REMEMBER TO CONVERT THESE TO MOAB HANDLES
        // Add them to the set
        result = mbImpl->add_entities( this_set, set_ents );MB_CHK_SET_ERR( result, fileName << ": Trouble putting entities in set" );
        // Add the new set to read_ents
        read_ents.insert( this_set );
    return MB_SUCCESS;
ReaderIface * ReadTemplate::factory ( Interface iface) [static]
factory method
Definition at line 19 of file ReadTemplate.cpp.
References ReadTemplate().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
    return new ReadTemplate( iface );
ErrorCode ReadTemplate::load_file ( const char *  file_name,
const EntityHandle file_set,
const FileOptions opts,
const SubsetList subset_list = 0,
const Tag file_id_tag = 0
) [virtual]
Method all readers must provide to import a mesh.
Parameters:
file_nameThe file to read.
file_setOptional pointer to entity set representing file. If this is not NULL, reader may optionally tag the pointed-to set with format-specific meta-data.
subset_listAn optional struct pointer specifying the tags identifying entity sets to be read.
file_id_tagIf specified, reader should store for each entity it reads, a unique integer ID for this tag.
Author:
Jason Kraftcheck
Implements moab::ReaderIface.
Definition at line 47 of file ReadTemplate.cpp.
References moab::Interface::add_entities(), create_sets(), ErrorCode, filename, fileName, MB_CHK_SET_ERR, MB_FILE_DOES_NOT_EXIST, MB_SET_ERR, MB_SUCCESS, mbImpl, process_options(), read_elements(), and read_vertices().
    if( subset_list )
        // See src/moab/ReaderIface.hpp, definition of SubsetList struct; this basically specifies
        // an integer tag and tag values for sets to read on this proc, or a part number and total #
        // parts for reading a trivial partition of entities
    // Save filename to member variable so we don't need to pass as an argument
    // to called functions
    fileName = filename;
    // Process options; see src/FileOptions.hpp for API for FileOptions class, and
    // doc/metadata_info.doc for a description of various options used by some of the readers in
    // MOAB
    ErrorCode result = process_options( opts );MB_CHK_SET_ERR( result, fileName << ": problem reading options" );
    // Open file; filePtr is member of ReadTemplate, change to whatever mechanism is used to
    // identify file
    FILE* filePtr = fopen( fileName, "r" );
    if( !filePtr )
        MB_SET_ERR( MB_FILE_DOES_NOT_EXIST, fileName << ": fopen returned error" );
    // Read number of verts, elements, sets
    long num_verts = 0, num_elems = 0, num_sets = 0;
    // read_ents keeps a running set of entities read from this file, including vertices, elements,
    // and sets; these will get added to file_set (if input) at the end of the read
    Range read_ents;
    // start_vertex is passed back so we know how to convert indices from the file into vertex
    // handles; most of the time this is done by adding start_vertex to the (0-based) index; if the
    // index is 1-based, you also need to subtract one; see read_elements for details
    EntityHandle start_vertex;
    result = read_vertices( num_verts, start_vertex, read_ents );
    if( MB_SUCCESS != result )
        fclose( filePtr );
        return result;
    // Create/read elements; this template assumes that all elements are the same type, so can be
    // read in a single call to read_elements, and kept track of with a single start_elem handle. If
    // there are more entity types, might have to keep these start handles in an array/vector.
    // start_elem is only really needed if you're reading sets later, and need to convert some
    // file-based index to an entity handle
    EntityHandle start_elem;
    result = read_elements( num_elems, start_vertex, start_elem, read_ents );
        fclose( filePtr );
        return result;
    // Read/create entity sets; typically these sets have some tag identifying what they're for, see
    // doc/metadata_info.doc for examples of different kinds of sets and how they're marked
    result = create_sets( num_sets, start_vertex, num_verts, start_elem, num_elems, read_ents );
        fclose( filePtr );
        return result;
    // Finally, add all read_ents into the file set, if one was input
    if( file_set && *file_set )
        result = mbImpl->add_entities( *file_set, read_ents );
            fclose( filePtr );
            return result;
    fclose( filePtr );
    return result;
Parameters:
optsOptions passed into this read
Definition at line 236 of file ReadTemplate.cpp.
References moab::FileOptions::mark_all_seen(), and MB_SUCCESS.
    // Mark all options seen, to avoid compile warning on unused variable
    opts.mark_all_seen();
    return MB_SUCCESS;
ErrorCode ReadTemplate::read_elements ( int  num_elems,
Range read_ents
) [private]
Read/create elements.
Parameters:
num_elemsNumber of elements to be read
start_vertexStarting vertex handle; used to offset connectivity indices
start_elemStarting element handle; may be used later to offset set entities
Definition at line 157 of file ReadTemplate.cpp.
References ErrorCode, fileName, moab::ReadUtilIface::get_element_connect(), moab::Range::insert(), MB_CHK_SET_ERR, MB_SUCCESS, MBHEX, OFFSET, moab::Range::rbegin(), readMeshIface, and moab::ReadUtilIface::update_adjacencies().
    // Get the entity type being read
    EntityType ent_type = MBHEX;
    // Get the number of vertices per entity
    int verts_per_elem = 8;
    // Create the element sequence; passes back a pointer to the internal storage for connectivity
    // and the starting entity handle
    EntityHandle* conn_array;
    ErrorCode result =
        readMeshIface->get_element_connect( num_elems, verts_per_elem, ent_type, 1, start_elem, conn_array );MB_CHK_SET_ERR( result, fileName << ": Trouble reading elements" );
    // Read connectivity into conn_array directly
    for( long i = 0; i < num_elems; i++ )
    // Convert file-based connectivity indices to vertex handles in-place; be careful, if indices
    // are smaller than handles, need to do from the end of the list so we don't overwrite data
    // Here, we assume indices are smaller than handles, just for demonstration; create an
    // integer-type pointer to connectivity initialized to same start of connectivity array
    int* ind_array = reinterpret_cast< int* >( conn_array );
    // OFFSET is value of first vertex index in file; most files are 1-based, but some might be
    // 0-based
    int OFFSET = 1;
    for( long i = num_elems * verts_per_elem - 1; i >= 0; i-- )
        conn_array[i] = ind_array[i] + start_vertex + OFFSET;
        // This assert assumes last handle in read_ents is highest vertex handle in this file
        assert( conn_array[i] >= start_vertex && conn_array[i] <= *read_ents.rbegin() );
    // Notify MOAB of the new elements
    result = readMeshIface->update_adjacencies( start_elem, num_elems, verts_per_elem, conn_array );
    if( MB_SUCCESS != result ) return result;
    // Add elements to read_ents
    if( num_elems ) read_ents.insert( start_elem, start_elem + num_elems - 1 );
    return MB_SUCCESS;
ErrorCode ReadTemplate::read_tag_values ( const char *  file_name,
const char *  tag_name,
std::vector< int > &  tag_values_out,
) [virtual]
Read the list if all integer tag values from the file for a tag that is a single integer value per entity.
Parameters:
tag_nameThe tag for which to read values
tag_values_outOutput: The list of tag values.
subset_listAn array of tag name and value sets specifying the subset of the file to read. If multiple tags are specified, the sets that match all tags (intersection) should be read.
subset_list_lengthThe length of the 'subset_list' array.
Definition at line 38 of file ReadTemplate.cpp.
References MB_NOT_IMPLEMENTED.
    return MB_NOT_IMPLEMENTED;
ErrorCode ReadTemplate::read_vertices ( int  num_verts,
Range read_ents
) [private]
Parameters:
num_vertsNumber of vertices to be read
start_vertexStarting vertex handle; used later to offset connectivity indices
Definition at line 133 of file ReadTemplate.cpp.
References ErrorCode, fileName, moab::ReadUtilIface::get_node_coords(), moab::Range::insert(), MB_CHK_SET_ERR, and readMeshIface.
    // Allocate nodes; these are allocated in one shot, get contiguous handles starting with
    // start_handle, and the reader is passed back double*'s pointing to MOAB's native storage for
    // vertex coordinates for those verts
    std::vector< double* > coord_arrays;
    ErrorCode result = readMeshIface->get_node_coords( 3, num_verts, 1, start_vertex, coord_arrays );MB_CHK_SET_ERR( result, fileName << ": Trouble reading vertices" );
    // Fill in vertex coordinate arrays
    double *x = coord_arrays[0], *y = coord_arrays[1], *z = coord_arrays[2];
    for( long i = 0; i < num_verts; ++i )
        // Read x/y/z; do something with them for now to avoid warning
        if( x || y || z )
    if( num_verts ) read_ents.insert( start_vertex, start_vertex + num_verts - 1 );
    return result;
Member Data Documentation
const char* moab::ReadTemplate::fileName [private]
Definition at line 89 of file ReadTemplate.hpp.
Referenced by create_sets(), load_file(), read_elements(), and read_vertices().
interface instance
Definition at line 87 of file ReadTemplate.hpp.
Referenced by create_sets(), load_file(), ReadTemplate(), and ~ReadTemplate().
List of all members.
