, including all inherited members.
get_data(TagId tag_handle, const EntityHandle *handles, int num_handles, void *data, const void *default_value) const | moab::SparseTagSuperCollection | |
get_data(TagId tag_handle, const EntityHandle *handles, int num_handles, const void **data, int *lengths, const void *default_value, int default_value_length) const | moab::SparseTagSuperCollection | |
get_data(TagId tag_handle, const Range &handles, void *data, const void *default_value) const | moab::SparseTagSuperCollection | |
get_data(TagId tag_handle, const Range &handles, const void **data, int *lengths, const void *default_value, int default_value_length) const | moab::SparseTagSuperCollection | |
get_entities(const TagId tag_handle, Range &entities) | moab::SparseTagSuperCollection | |
get_entities(const TagId tag_handle, const EntityType type, Range &entities) | moab::SparseTagSuperCollection | |
get_entities(const Range &range, const TagId tag_handle, const EntityType type, Range &entities) | moab::SparseTagSuperCollection | |
get_entities_with_tag_value(const TagId tag_handle, const TagInfo &tag_info, const EntityType type, Range &entities, const void *tag_value, int value_size) | moab::SparseTagSuperCollection | |
get_entities_with_tag_value(const Range &range, const TagId tag_handle, const TagInfo &tag_info, const EntityType type, Range &entities, const void *tag_value, int value_size) | moab::SparseTagSuperCollection | |
get_memory_use(TagId tag_id, unsigned long &total, unsigned long &per_entity) | moab::SparseTagSuperCollection | |
get_number_entities(const TagId tag_handle, const EntityType type, int &num_ent) | moab::SparseTagSuperCollection | |
get_number_entities(const Range &range, const TagId tag_handle, const EntityType type, int &num_ent) | moab::SparseTagSuperCollection | |
get_tags(const EntityHandle entity, std::vector< Tag > &all_tags) | moab::SparseTagSuperCollection | |
mDataTags | moab::SparseTagSuperCollection | [private] |
release_tag_id(TagId tag_id) | moab::SparseTagSuperCollection | |
remove_data(const TagId tag_handle, const EntityHandle entity_handle) | moab::SparseTagSuperCollection | |
reserve_tag_id(int data_size, TagId tag_id) | moab::SparseTagSuperCollection | |
reset_data() | moab::SparseTagSuperCollection | |
set_data(TagId tag_handle, const EntityHandle *handles, int num_handles, const void *data) | moab::SparseTagSuperCollection | |
set_data(TagId tag_handle, const EntityHandle *handles, int num_handles, void const *const *data_pointers, const int *lengths=0, bool one_value=false) | moab::SparseTagSuperCollection | |
set_data(TagId tag_handle, const Range &handles, const void *data) | moab::SparseTagSuperCollection | |
set_data(TagId tag_handle, const Range &handles, void const *const *data_pointers, const int *lengths=0, bool one_value=false) | moab::SparseTagSuperCollection | |
SparseTagSuperCollection() | moab::SparseTagSuperCollection | [inline] |
tag_iterate(TagId tag_handle, Range::iterator &iter, const Range::iterator &end, void *&data_ptr, const void *default_value) | moab::SparseTagSuperCollection | |
tag_size(const TagId tag_id) const | moab::SparseTagSuperCollection | |
~SparseTagSuperCollection() | moab::SparseTagSuperCollection | [virtual] |
