MOAB: Mesh Oriented datABase
(version 5.1.1)
An offline map between two Meshes. More...
#include <TempestOfflineMap.hpp>
Public Types | |
enum | DiscretizationType { DiscretizationType_FV, DiscretizationType_CGLL, DiscretizationType_DGLL } |
Public Member Functions | |
TempestOfflineMap (moab::TempestRemapper *remapper) | |
Generate the metadata associated with the offline map. | |
virtual | ~TempestOfflineMap () |
Define a virtual destructor. | |
moab::ErrorCode | GenerateOfflineMap (std::string strInputType="fv", std::string strOutputType="fv", const int nPin=1, const int nPout=1, bool fBubble=false, int fMonotoneTypeID=0, bool fVolumetric=false, bool fNoConservation=false, bool fNoCheck=false, const std::string srcDofTagName="GLOBAL_ID", const std::string tgtDofTagName="GLOBAL_ID", const std::string strVariables="", const std::string strInputData="", const std::string strOutputData="", const std::string strNColName="", const bool fOutputDouble=false, const std::string strPreserveVariables="", const bool fPreserveAll=false, const double dFillValueOverride=0.0, const bool fInputConcave=false, const bool fOutputConcave=false) |
Generate the offline map, given the source and target mesh and discretization details. This method generates the mapping between the two meshes based on the overlap and stores the result in the SparseMatrix. | |
virtual bool | IsConsistent (double dTolerance) |
virtual bool | IsConservative (double dTolerance) |
Determine if the map is conservative. | |
virtual bool | IsMonotone (double dTolerance) |
Determine if the map is monotone. | |
const DataVector< double > & | GetGlobalSourceAreas () const |
If we computed the reduction, get the vector representing the source areas for all entities in the mesh. | |
const DataVector< double > & | GetGlobalTargetAreas () const |
If we computed the reduction, get the vector representing the target areas for all entities in the mesh. | |
Public Attributes | |
moab::TempestRemapper * | m_remapper |
Copy the local matrix from Tempest SparseMatrix representation (ELL) to the parallel CSR Eigen Matrix for scalable application of matvec needed for projections. | |
OfflineMap * | m_weightMapGlobal |
The SparseMatrix representing this operator. | |
bool | m_globalMapAvailable |
The boolean flag representing whether the root process has the updated global view. | |
moab::Interface * | mbCore |
The DataVector that stores the global (GID-based) areas of the source mesh. | |
moab::Tag | m_dofTagSrc |
The original tag data and local to global DoF mapping to associate matrix values to solution. | |
moab::Tag | m_dofTagDest |
std::vector< unsigned long > | row_dofmap |
std::vector< unsigned long > | col_dofmap |
std::vector< unsigned long > | srccol_dofmap |
std::vector< unsigned long > | row_gdofmap |
std::vector< unsigned long > | col_gdofmap |
std::vector< unsigned long > | srccol_gdofmap |
std::vector< unsigned long > | row_ldofmap |
std::vector< unsigned long > | col_ldofmap |
std::vector< unsigned long > | srccol_ldofmap |
DataMatrix3D< int > | dataGLLNodesSrc |
DataMatrix3D< int > | dataGLLNodesSrcCov |
DataMatrix3D< int > | dataGLLNodesDest |
DiscretizationType | m_srcDiscType |
DiscretizationType | m_destDiscType |
int | m_nTotDofs_Src |
int | m_nTotDofs_SrcCov |
int | m_nTotDofs_Dest |
int | m_nDofsPEl_Src |
int | m_nDofsPEl_Dest |
Mesh * | m_meshInput |
Mesh * | m_meshInputCov |
Mesh * | m_meshOutput |
Mesh * | m_meshOverlap |
bool | is_parallel |
bool | is_root |
int | rank |
int | size |
Private Member Functions | |
moab::ErrorCode | GatherAllToRoot () |
Gather the mapping matrix that was computed in different processors and accumulate the data on the root so that OfflineMap can be generated in parallel. | |
void | LinearRemapFVtoFV_Tempest_MOAB (int nOrder) |
Compute the remapping weights for a FV field defined on the source to a FV field defined on the target mesh. | |
void | LinearRemapSE0_Tempest_MOAB (const DataMatrix3D< int > &dataGLLNodes, const DataMatrix3D< double > &dataGLLJacobian) |
Generate the OfflineMap for linear conserative element-average spectral element to element average remapping. | |
void | LinearRemapSE4_Tempest_MOAB (const DataMatrix3D< int > &dataGLLNodes, const DataMatrix3D< double > &dataGLLJacobian, int nMonotoneType, bool fContinuousIn, bool fNoConservation) |
Generate the OfflineMap for cubic conserative element-average spectral element to element average remapping. | |
void | LinearRemapFVtoGLL_Simple_MOAB (const DataMatrix3D< int > &dataGLLNodes, const DataMatrix3D< double > &dataGLLJacobian, const DataVector< double > &dataGLLNodalArea, int nOrder, int nMonotoneType, bool fContinuous, bool fNoConservation) |
Generate the OfflineMap for remapping from finite volumes to finite elements using simple sampling of the FV reconstruction. | |
void | LinearRemapFVtoGLL_Volumetric_MOAB (const DataMatrix3D< int > &dataGLLNodes, const DataMatrix3D< double > &dataGLLJacobian, const DataVector< double > &dataGLLNodalArea, int nOrder, int nMonotoneType, bool fContinuous, bool fNoConservation) |
Generate the OfflineMap for remapping from finite volumes to finite elements using a new experimental method. | |
void | LinearRemapFVtoGLL_MOAB (const DataMatrix3D< int > &dataGLLNodes, const DataMatrix3D< double > &dataGLLJacobian, const DataVector< double > &dataGLLNodalArea, int nOrder, int nMonotoneType, bool fContinuous, bool fNoConservation) |
Generate the OfflineMap for remapping from finite volumes to finite elements. | |
void | LinearRemapGLLtoGLL2_MOAB (const DataMatrix3D< int > &dataGLLNodesIn, const DataMatrix3D< double > &dataGLLJacobianIn, const DataMatrix3D< int > &dataGLLNodesOut, const DataMatrix3D< double > &dataGLLJacobianOut, const DataVector< double > &dataNodalAreaOut, int nPin, int nPout, int nMonotoneType, bool fContinuousIn, bool fContinuousOut, bool fNoConservation) |
Generate the OfflineMap for remapping from finite elements to finite elements. | |
void | LinearRemapGLLtoGLL2_Pointwise_MOAB (const DataMatrix3D< int > &dataGLLNodesIn, const DataMatrix3D< double > &dataGLLJacobianIn, const DataMatrix3D< int > &dataGLLNodesOut, const DataMatrix3D< double > &dataGLLJacobianOut, const DataVector< double > &dataNodalAreaOut, int nPin, int nPout, int nMonotoneType, bool fContinuousIn, bool fContinuousOut) |
Generate the OfflineMap for remapping from finite elements to finite elements (pointwise interpolation). | |
moab::ErrorCode | SetDofMapTags (const std::string srcDofTagName, const std::string tgtDofTagName) |
Store the tag names associated with global DoF ids for source and target meshes. | |
moab::ErrorCode | SetDofMapAssociation (DiscretizationType srcType, bool isSrcContinuous, DataMatrix3D< int > *srcdataGLLNodes, DataMatrix3D< int > *srcdataGLLNodesSrc, DiscretizationType destType, bool isDestContinuous, DataMatrix3D< int > *tgtdataGLLNodes) |
Compute the association between the solution tag global DoF numbering and the local matrix numbering so that matvec operations can be performed consistently. |
Definition at line 54 of file TempestOfflineMap.hpp.
Definition at line 71 of file TempestOfflineMap.hpp.
Definition at line 35 of file TempestOfflineMap.cpp.
References dbgprint, moab::Remapper::get_interface(), moab::TempestRemapper::GetCoveringMesh(), moab::TempestRemapper::GetMesh(), moab::Remapper::IntersectedMesh, is_parallel, is_root, m_globalMapAvailable, m_meshInput, m_meshInputCov, m_meshOutput, m_meshOverlap, m_remapper, m_weightMapGlobal, mbCore, moab::DebugOutput::printf(), rank, size, moab::Remapper::SourceMesh, and moab::Remapper::TargetMesh.
: OfflineMap(), m_remapper ( remapper ) { // Get the references for the MOAB core objects mbCore = m_remapper->get_interface(); #ifdef MOAB_HAVE_MPI pcomm = m_remapper->get_parallel_communicator(); #endif // Update the references to the meshes m_meshInput = remapper->GetMesh ( moab::Remapper::SourceMesh ); m_meshInputCov = remapper->GetCoveringMesh(); m_meshOutput = remapper->GetMesh ( moab::Remapper::TargetMesh ); m_meshOverlap = remapper->GetMesh ( moab::Remapper::IntersectedMesh ); m_globalMapAvailable = false; is_parallel = false; is_root = true; rank = 0; size = 1; #ifdef MOAB_HAVE_MPI int flagInit; MPI_Initialized( &flagInit ); if (flagInit) { is_parallel = true; assert(pcomm != NULL); rank = pcomm->rank(); size = pcomm->size(); is_root = (rank == 0); } #endif moab::DebugOutput dbgprint ( std::cout, rank ); // Compute and store the total number of source and target DoFs corresponding // to number of rows and columns in the mapping. // Initialize dimension information from file std::vector<std::string> dimNames(1); std::vector<int> dimSizes(1); dimNames[0] = "num_elem"; dbgprint.printf ( 0, "Initializing dimensions of map\n" ); dbgprint.printf ( 0, "Input mesh\n" ); dimSizes[0] = m_meshInputCov->faces.size(); this->InitializeSourceDimensions(dimNames, dimSizes); dbgprint.printf ( 0, "Output mesh\n" ); dimSizes[0] = m_meshOutput->faces.size(); this->InitializeTargetDimensions(dimNames, dimSizes); m_weightMapGlobal = NULL; // Build a matrix of source and target discretization so that we know how to assign // the global DoFs in parallel for the mapping weights // For example, FV->FV: rows X cols = faces_source X faces_target }
moab::TempestOfflineMap::~TempestOfflineMap | ( | ) | [virtual] |
Definition at line 93 of file TempestOfflineMap.cpp.
{ delete m_weightMapGlobal; mbCore = NULL; #ifdef MOAB_HAVE_MPI pcomm = NULL; #endif m_meshInput = NULL; m_meshOutput = NULL; m_meshOverlap = NULL; }
moab::ErrorCode moab::TempestOfflineMap::GatherAllToRoot | ( | ) | [private] |
moab::ErrorCode moab::TempestOfflineMap::GenerateOfflineMap | ( | std::string | strInputType = "fv" , |
std::string | strOutputType = "fv" , |
const int | nPin = 1 , |
const int | nPout = 1 , |
bool | fBubble = false , |
int | fMonotoneTypeID = 0 , |
bool | fVolumetric = false , |
bool | fNoConservation = false , |
bool | fNoCheck = false , |
const std::string | srcDofTagName = "GLOBAL_ID" , |
const std::string | tgtDofTagName = "GLOBAL_ID" , |
const std::string | strVariables = "" , |
const std::string | strInputData = "" , |
const std::string | strOutputData = "" , |
const std::string | strNColName = "" , |
const bool | fOutputDouble = false , |
const std::string | strPreserveVariables = "" , |
const bool | fPreserveAll = false , |
const double | dFillValueOverride = 0.0 , |
const bool | fInputConcave = false , |
const bool | fOutputConcave = false |
Definition at line 481 of file TempestOfflineMap.cpp.
References dbgprint, moab::error(), MB_CHK_ERR, MB_FAILURE, MB_SUCCESS, ParseVariableList(), moab::DebugOutput::printf(), rank, and size.
Referenced by main().
{ NcError error ( NcError::silent_nonfatal ); moab::DebugOutput dbgprint ( std::cout, ( rank ) ); moab::ErrorCode rval; try { // Check command line parameters (data arguments) if ( ( strInputData != "" ) && ( strOutputData == "" ) ) { _EXCEPTIONT ( "--in_data specified without --out_data" ); } if ( ( strInputData == "" ) && ( strOutputData != "" ) ) { _EXCEPTIONT ( "--out_data specified without --in_data" ); } // Check command line parameters (data type arguments) STLStringHelper::ToLower ( strInputType ); STLStringHelper::ToLower ( strOutputType ); DiscretizationType eInputType; DiscretizationType eOutputType; if ( strInputType == "fv" ) { eInputType = DiscretizationType_FV; } else if ( strInputType == "cgll" ) { eInputType = DiscretizationType_CGLL; } else if ( strInputType == "dgll" ) { eInputType = DiscretizationType_DGLL; } else { _EXCEPTION1 ( "Invalid \"in_type\" value (%s), expected [fv|cgll|dgll]", strInputType.c_str() ); } if ( strOutputType == "fv" ) { eOutputType = DiscretizationType_FV; } else if ( strOutputType == "cgll" ) { eOutputType = DiscretizationType_CGLL; } else if ( strOutputType == "dgll" ) { eOutputType = DiscretizationType_DGLL; } else { _EXCEPTION1 ( "Invalid \"out_type\" value (%s), expected [fv|cgll|dgll]", strOutputType.c_str() ); } // Monotonicity flags int nMonotoneType = fMonotoneTypeID; // Parse variable list std::vector< std::string > vecVariableStrings; ParseVariableList ( strVariables, vecVariableStrings ); // Parse preserve variable list std::vector< std::string > vecPreserveVariableStrings; ParseVariableList ( strPreserveVariables, vecPreserveVariableStrings ); if ( fPreserveAll && ( vecPreserveVariableStrings.size() != 0 ) ) { _EXCEPTIONT ( "--preserveall and --preserve cannot both be specified" ); } m_nDofsPEl_Src = nPin; m_nDofsPEl_Dest = nPout; rval = SetDofMapTags(srcDofTagName, tgtDofTagName); // Calculate Face areas if ( is_root ) dbgprint.printf ( 0, "Calculating input mesh Face areas\n" ); double dTotalAreaInput_loc = m_meshInput->CalculateFaceAreas(fInputConcave); double dTotalAreaInput = dTotalAreaInput_loc; #ifdef MOAB_HAVE_MPI if (pcomm) MPI_Allreduce ( &dTotalAreaInput_loc, &dTotalAreaInput, 1, MPI_DOUBLE, MPI_SUM, pcomm->comm() ); #endif if ( is_root ) dbgprint.printf ( 0, "Input Mesh Geometric Area: %1.15e\n", dTotalAreaInput ); // Input mesh areas m_meshInputCov->CalculateFaceAreas(fInputConcave); if ( eInputType == DiscretizationType_FV ) { this->SetSourceAreas ( m_meshInputCov->vecFaceArea ); } // Calculate Face areas if ( is_root ) dbgprint.printf ( 0, "Calculating output mesh Face areas\n" ); double dTotalAreaOutput_loc = m_meshOutput->CalculateFaceAreas(fOutputConcave); double dTotalAreaOutput = dTotalAreaOutput_loc; #ifdef MOAB_HAVE_MPI if (pcomm) MPI_Allreduce ( &dTotalAreaOutput_loc, &dTotalAreaOutput, 1, MPI_DOUBLE, MPI_SUM, pcomm->comm() ); #endif if ( is_root ) dbgprint.printf ( 0, "Output Mesh Geometric Area: %1.15e\n", dTotalAreaOutput ); // Output mesh areas if ( eOutputType == DiscretizationType_FV ) { this->SetTargetAreas ( m_meshOutput->vecFaceArea ); } // Verify that overlap mesh is in the correct order int ixSourceFaceMax = ( -1 ); int ixTargetFaceMax = ( -1 ); if ( m_meshOverlap->vecSourceFaceIx.size() != m_meshOverlap->vecTargetFaceIx.size() ) { _EXCEPTIONT ( "Invalid overlap mesh:\n" " Possible mesh file corruption?" ); } for ( unsigned i = 0; i < m_meshOverlap->vecSourceFaceIx.size(); i++ ) { if ( m_meshOverlap->vecSourceFaceIx[i] + 1 > ixSourceFaceMax ) { ixSourceFaceMax = m_meshOverlap->vecSourceFaceIx[i] + 1; } if ( m_meshOverlap->vecTargetFaceIx[i] + 1 > ixTargetFaceMax ) { ixTargetFaceMax = m_meshOverlap->vecTargetFaceIx[i] + 1; } } /* // Check for forward correspondence in overlap mesh if ( // m_meshInputCov->faces.size() - ixSourceFaceMax == 0 //&& ( m_meshOutput->faces.size() - ixTargetFaceMax == 0 ) ) { if ( is_root ) dbgprint.printf ( 0, "Overlap mesh forward correspondence found\n" ); } else if ( // m_meshOutput->faces.size() - ixSourceFaceMax == 0 //&& ( m_meshInputCov->faces.size() - ixTargetFaceMax == 0 ) ) { // Check for reverse correspondence in overlap mesh if ( is_root ) dbgprint.printf ( 0, "Overlap mesh reverse correspondence found (reversing)\n" ); // Reorder overlap mesh m_meshOverlap->ExchangeFirstAndSecondMesh(); } else { // No correspondence found _EXCEPTION4 ( "Invalid overlap mesh:\n" " No correspondence found with input and output meshes (%i,%i) vs (%i,%i)", m_meshInputCov->faces.size(), m_meshOutput->faces.size(), ixSourceFaceMax, ixTargetFaceMax ); } */ // Calculate Face areas if ( is_root ) dbgprint.printf ( 0, "Calculating overlap mesh Face areas\n" ); double dTotalAreaOverlap_loc = m_meshOverlap->CalculateFaceAreas(false); double dTotalAreaOverlap = dTotalAreaOverlap_loc; #ifdef MOAB_HAVE_MPI if (pcomm) MPI_Allreduce ( &dTotalAreaOverlap_loc, &dTotalAreaOverlap, 1, MPI_DOUBLE, MPI_SUM, pcomm->comm() ); #endif if ( is_root ) dbgprint.printf ( 0, "Overlap Mesh Area: %1.15e\n", dTotalAreaOverlap ); // Partial cover if ( fabs ( dTotalAreaOverlap - dTotalAreaInput ) > 1.0e-10 ) { if ( !fNoCheck ) { if ( is_root ) dbgprint.printf ( 0, "WARNING: Significant mismatch between overlap mesh area " "and input mesh area.\n Automatically enabling --nocheck\n" ); fNoCheck = true; } } /* // Recalculate input mesh area from overlap mesh if (fabs(dTotalAreaOverlap - dTotalAreaInput) > 1.0e-10) { dbgprint.printf(0, "Overlap mesh only covers a sub-area of the sphere\n"); dbgprint.printf(0, "Recalculating source mesh areas\n"); dTotalAreaInput = m_meshInput->CalculateFaceAreasFromOverlap(m_meshOverlap); dbgprint.printf(0, "New Input Mesh Geometric Area: %1.15e\n", dTotalAreaInput); } */ // Finite volume input / Finite volume output if ( ( eInputType == DiscretizationType_FV ) && ( eOutputType == DiscretizationType_FV ) ) { // Generate reverse node array and edge map m_meshInputCov->ConstructReverseNodeArray(); m_meshInputCov->ConstructEdgeMap(); // Initialize coordinates for map this->InitializeSourceCoordinatesFromMeshFV ( *m_meshInputCov ); this->InitializeTargetCoordinatesFromMeshFV ( *m_meshOutput ); // Finite volume input / Finite element output rval = this->SetDofMapAssociation(eInputType, false, NULL, NULL, eOutputType, false, NULL);MB_CHK_ERR(rval); // Construct OfflineMap if ( is_root ) dbgprint.printf ( 0, "Calculating offline map\n" ); LinearRemapFVtoFV_Tempest_MOAB ( nPin ); } else if ( eInputType == DiscretizationType_FV ) { DataMatrix3D<double> dataGLLJacobian; if ( is_root ) dbgprint.printf ( 0, "Generating output mesh meta data\n" ); double dNumericalArea_loc = GenerateMetaData ( *m_meshOutput, nPout, fBubble, dataGLLNodesDest, dataGLLJacobian ); double dNumericalArea = dNumericalArea_loc; #ifdef MOAB_HAVE_MPI if (pcomm) MPI_Allreduce ( &dNumericalArea_loc, &dNumericalArea, 1, MPI_DOUBLE, MPI_SUM, pcomm->comm() ); #endif if ( is_root ) dbgprint.printf ( 0, "Output Mesh Numerical Area: %1.15e\n", dNumericalArea ); // Initialize coordinates for map this->InitializeSourceCoordinatesFromMeshFV ( *m_meshInputCov ); this->InitializeTargetCoordinatesFromMeshFE ( *m_meshOutput, nPout, dataGLLNodesDest ); // Generate the continuous Jacobian bool fContinuous = ( eOutputType == DiscretizationType_CGLL ); if ( eOutputType == DiscretizationType_CGLL ) { GenerateUniqueJacobian ( dataGLLNodesDest, dataGLLJacobian, this->GetTargetAreas() ); } else { GenerateDiscontinuousJacobian ( dataGLLJacobian, this->GetTargetAreas() ); } // Generate reverse node array and edge map m_meshInputCov->ConstructReverseNodeArray(); m_meshInputCov->ConstructEdgeMap(); // Finite volume input / Finite element output rval = this->SetDofMapAssociation(eInputType, false, NULL, NULL, eOutputType, (eOutputType == DiscretizationType_CGLL), &dataGLLNodesDest);MB_CHK_ERR(rval); // Generate remap weights if ( is_root ) dbgprint.printf ( 0, "Calculating offline map\n" ); if ( fVolumetric ) { LinearRemapFVtoGLL_Volumetric_MOAB ( dataGLLNodesDest, dataGLLJacobian, this->GetTargetAreas(), nPin, nMonotoneType, fContinuous, fNoConservation ); } else { LinearRemapFVtoGLL_MOAB ( dataGLLNodesDest, dataGLLJacobian, this->GetTargetAreas(), nPin, nMonotoneType, fContinuous, fNoConservation ); } } else if ( ( eInputType != DiscretizationType_FV ) && ( eOutputType == DiscretizationType_FV ) ) { DataMatrix3D<double> dataGLLJacobianSrc, dataGLLJacobian; if ( is_root ) dbgprint.printf ( 0, "Generating input mesh meta data\n" ); // double dNumericalAreaCov_loc = GenerateMetaData ( *m_meshInputCov, nPin, fBubble, dataGLLNodesSrcCov, dataGLLJacobian ); double dNumericalArea_loc = GenerateMetaData ( *m_meshInput, nPin, fBubble, dataGLLNodesSrc, dataGLLJacobianSrc ); // if ( is_root ) dbgprint.printf ( 0, "Input Mesh: Coverage Area: %1.15e, Output Area: %1.15e\n", dNumericalAreaCov_loc, dTotalAreaOutput_loc ); // assert(dNumericalAreaCov_loc >= dTotalAreaOutput_loc); double dNumericalArea = dNumericalArea_loc; #ifdef MOAB_HAVE_MPI if (pcomm) MPI_Allreduce ( &dNumericalArea_loc, &dNumericalArea, 1, MPI_DOUBLE, MPI_SUM, pcomm->comm() ); #endif if ( is_root ) dbgprint.printf ( 0, "Input Mesh Numerical Area: %1.15e\n", dNumericalArea ); if ( fabs ( dNumericalArea - dTotalAreaInput ) > 1.0e-12 ) { dbgprint.printf ( 0, "WARNING: Significant mismatch between input mesh " "numerical area and geometric area\n" ); } if ( dataGLLNodesSrcCov.GetSubColumns() != m_meshInputCov->faces.size() ) { _EXCEPTIONT ( "Number of element does not match between metadata and " "input mesh" ); } // Initialize coordinates for map this->InitializeSourceCoordinatesFromMeshFE ( *m_meshInputCov, nPin, dataGLLNodesSrcCov ); this->InitializeSourceCoordinatesFromMeshFE ( *m_meshInput, nPin, dataGLLNodesSrc ); this->InitializeTargetCoordinatesFromMeshFV ( *m_meshOutput ); // Generate the continuous Jacobian for input mesh bool fContinuousIn = ( eInputType == DiscretizationType_CGLL ); if ( eInputType == DiscretizationType_CGLL ) { GenerateUniqueJacobian ( dataGLLNodesSrcCov, dataGLLJacobian, this->GetSourceAreas() ); } else { GenerateDiscontinuousJacobian ( dataGLLJacobian, this->GetSourceAreas() ); } // Finite element input / Finite volume output rval = this->SetDofMapAssociation(eInputType, (eInputType == DiscretizationType_CGLL), &dataGLLNodesSrcCov, &dataGLLNodesSrc, eOutputType, false, NULL);MB_CHK_ERR(rval); // Generate offline map if ( is_root ) dbgprint.printf ( 0, "Calculating offline map\n" ); if ( fVolumetric ) { _EXCEPTIONT ( "Unimplemented: Volumetric currently unavailable for" "GLL input mesh" ); } LinearRemapSE4_Tempest_MOAB ( dataGLLNodesSrcCov, dataGLLJacobian, nMonotoneType, fContinuousIn, fNoConservation ); } else if ( ( eInputType != DiscretizationType_FV ) && ( eOutputType != DiscretizationType_FV ) ) { DataMatrix3D<double> dataGLLJacobianIn, dataGLLJacobianSrc; DataMatrix3D<double> dataGLLJacobianOut; // Input metadata if ( is_root ) dbgprint.printf ( 0, "Generating input mesh meta data" ); double dNumericalAreaIn_loc = GenerateMetaData ( *m_meshInputCov, nPin, fBubble, dataGLLNodesSrcCov, dataGLLJacobianIn ); double dNumericalAreaSrc_loc = GenerateMetaData ( *m_meshInput, nPin, fBubble, dataGLLNodesSrc, dataGLLJacobianSrc ); assert(dNumericalAreaIn_loc >= dNumericalAreaSrc_loc); double dNumericalAreaIn = dNumericalAreaSrc_loc; #ifdef MOAB_HAVE_MPI if (pcomm) MPI_Allreduce ( &dNumericalAreaSrc_loc, &dNumericalAreaIn, 1, MPI_DOUBLE, MPI_SUM, pcomm->comm() ); #endif if ( is_root ) dbgprint.printf ( 0, "Input Mesh Numerical Area: %1.15e", dNumericalAreaIn ); if ( fabs ( dNumericalAreaIn - dTotalAreaInput ) > 1.0e-12 ) { dbgprint.printf ( 0, "WARNING: Significant mismatch between input mesh " "numerical area and geometric area" ); } // Output metadata if ( is_root ) dbgprint.printf ( 0, "Generating output mesh meta data" ); double dNumericalAreaOut_loc = GenerateMetaData ( *m_meshOutput, nPout, fBubble, dataGLLNodesDest, dataGLLJacobianOut ); double dNumericalAreaOut = dNumericalAreaOut_loc; #ifdef MOAB_HAVE_MPI if (pcomm) MPI_Allreduce ( &dNumericalAreaOut_loc, &dNumericalAreaOut, 1, MPI_DOUBLE, MPI_SUM, pcomm->comm() ); #endif if ( is_root ) dbgprint.printf ( 0, "Output Mesh Numerical Area: %1.15e", dNumericalAreaOut ); if ( fabs ( dNumericalAreaOut - dTotalAreaOutput ) > 1.0e-12 ) { if ( is_root ) dbgprint.printf ( 0, "WARNING: Significant mismatch between output mesh " "numerical area and geometric area" ); } // Initialize coordinates for map this->InitializeSourceCoordinatesFromMeshFE ( *m_meshInputCov, nPin, dataGLLNodesSrcCov ); this->InitializeSourceCoordinatesFromMeshFE ( *m_meshInput, nPin, dataGLLNodesSrc ); this->InitializeTargetCoordinatesFromMeshFE ( *m_meshOutput, nPout, dataGLLNodesDest ); // Generate the continuous Jacobian for input mesh bool fContinuousIn = ( eInputType == DiscretizationType_CGLL ); if ( eInputType == DiscretizationType_CGLL ) { GenerateUniqueJacobian ( dataGLLNodesSrcCov, dataGLLJacobianIn, this->GetSourceAreas() ); } else { GenerateDiscontinuousJacobian ( dataGLLJacobianIn, this->GetSourceAreas() ); } // Generate the continuous Jacobian for output mesh bool fContinuousOut = ( eOutputType == DiscretizationType_CGLL ); if ( eOutputType == DiscretizationType_CGLL ) { GenerateUniqueJacobian ( dataGLLNodesDest, dataGLLJacobianOut, this->GetTargetAreas() ); } else { GenerateDiscontinuousJacobian ( dataGLLJacobianOut, this->GetTargetAreas() ); } // Input Finite Element to Output Finite Element rval = this->SetDofMapAssociation(eInputType, (eInputType == DiscretizationType_CGLL), &dataGLLNodesSrcCov, &dataGLLNodesSrc, eOutputType, (eOutputType == DiscretizationType_CGLL), &dataGLLNodesDest);MB_CHK_ERR(rval); // Generate offline map if ( is_root ) dbgprint.printf ( 0, "Calculating offline map" ); LinearRemapGLLtoGLL2_MOAB ( dataGLLNodesSrcCov, dataGLLJacobianIn, dataGLLNodesDest, dataGLLJacobianOut, this->GetTargetAreas(), nPin, nPout, nMonotoneType, fContinuousIn, fContinuousOut, fNoConservation ); } else { _EXCEPTIONT ( "Not implemented" ); } #ifdef MOAB_HAVE_EIGEN CopyTempestSparseMat_Eigen(); #endif // Verify consistency, conservation and monotonicity // gather weights to root process to perform consistency/conservation checks if ( !fNoCheck && false) { if ( !m_globalMapAvailable && size > 1 ) { // gather weights to root process to perform consistency/conservation checks rval = this->GatherAllToRoot();MB_CHK_ERR(rval); } if ( is_root ) dbgprint.printf ( 0, "Verifying map" ); this->IsConsistent ( 1.0e-8 ); if ( !fNoConservation ) this->IsConservative ( 1.0e-8 ); if ( nMonotoneType != 0 ) { this->IsMonotone ( 1.0e-12 ); } } // Apply Offline Map to data if ( strInputData != "" ) { if ( is_root ) dbgprint.printf ( 0, "Applying offline map to data\n" ); this->SetFillValueOverride ( static_cast<float> ( dFillValueOverride ) ); this->Apply ( strInputData, strOutputData, vecVariableStrings, strNColName, fOutputDouble, false ); } // Copy variables from input file to output file if ( ( strInputData != "" ) && ( strOutputData != "" ) ) { if ( fPreserveAll ) { if ( is_root ) dbgprint.printf ( 0, "Preserving variables" ); this->PreserveAllVariables ( strInputData, strOutputData ); } else if ( vecPreserveVariableStrings.size() != 0 ) { if ( is_root ) dbgprint.printf ( 0, "Preserving variables" ); this->PreserveVariables ( strInputData, strOutputData, vecPreserveVariableStrings ); } } } catch ( Exception & e ) { dbgprint.printf ( 0, "%s", e.ToString().c_str() ); return ( moab::MB_FAILURE ); } catch ( ... ) { return ( moab::MB_FAILURE ); } return moab::MB_SUCCESS; }
const DataVector< double > & moab::TempestOfflineMap::GetGlobalSourceAreas | ( | ) | const [inline] |
Definition at line 432 of file TempestOfflineMap.hpp.
References m_weightMapGlobal.
{ #ifdef MOAB_HAVE_MPI if (pcomm->size() > 1) { return m_weightMapGlobal->GetSourceAreas(); } else { return this->GetSourceAreas(); } #else return this->GetSourceAreas(); #endif }
const DataVector< double > & moab::TempestOfflineMap::GetGlobalTargetAreas | ( | ) | const [inline] |
Definition at line 446 of file TempestOfflineMap.hpp.
{ #ifdef MOAB_HAVE_MPI if (pcomm->size() > 1) { return m_weightMapGlobal->GetTargetAreas(); } else { return this->GetTargetAreas(); } #else return this->GetTargetAreas(); #endif }
bool moab::TempestOfflineMap::IsConservative | ( | double | dTolerance | ) | [virtual] |
Definition at line 1192 of file TempestOfflineMap.cpp.
{ // Get map entries DataVector<int> dataRows; DataVector<int> dataCols; DataVector<double> dataEntries; const DataVector<double>& dTargetAreas = this->GetGlobalTargetAreas(); const DataVector<double>& dSourceAreas = this->GetGlobalSourceAreas(); // Calculate column sums DataVector<double> dColumnSums; if ( size > 1 ) { if ( rank ) return true; SparseMatrix<double>& m_mapRemapGlobal = m_weightMapGlobal->GetSparseMatrix(); m_mapRemapGlobal.GetEntries ( dataRows, dataCols, dataEntries ); dColumnSums.Initialize ( m_mapRemapGlobal.GetColumns() ); } else { m_mapRemap.GetEntries ( dataRows, dataCols, dataEntries ); dColumnSums.Initialize ( m_mapRemap.GetColumns() ); } for ( unsigned i = 0; i < dataRows.GetRows(); i++ ) { dColumnSums[dataCols[i]] += dataEntries[i] * dTargetAreas[dataRows[i]]; } // Verify all column sums equal the input Jacobian bool fConservative = true; for ( unsigned i = 0; i < dColumnSums.GetRows(); i++ ) { if ( fabs ( dColumnSums[i] - dSourceAreas[i] ) > dTolerance ) { fConservative = false; Announce ( "TempestOfflineMap is not conservative in column " "%i (%1.15e / %1.15e)", i, dColumnSums[i], dSourceAreas[i] ); } } return fConservative; }
bool moab::TempestOfflineMap::IsConsistent | ( | double | dTolerance | ) | [virtual] |
Read the OfflineMap from a NetCDF file. Write the TempestOfflineMap to a parallel NetCDF file. Determine if the map is first-order accurate.
Definition at line 1146 of file TempestOfflineMap.cpp.
{ // Get map entries DataVector<int> dataRows; DataVector<int> dataCols; DataVector<double> dataEntries; // Calculate row sums DataVector<double> dRowSums; if ( size > 1 ) { if ( rank ) return true; SparseMatrix<double>& m_mapRemapGlobal = m_weightMapGlobal->GetSparseMatrix(); m_mapRemapGlobal.GetEntries ( dataRows, dataCols, dataEntries ); dRowSums.Initialize ( m_mapRemapGlobal.GetRows() ); } else { m_mapRemap.GetEntries ( dataRows, dataCols, dataEntries ); dRowSums.Initialize ( m_mapRemap.GetRows() ); } for ( unsigned i = 0; i < dataRows.GetRows(); i++ ) { dRowSums[dataRows[i]] += dataEntries[i]; } // Verify all row sums are equal to 1 bool fConsistent = true; for ( unsigned i = 0; i < dRowSums.GetRows(); i++ ) { if ( fabs ( dRowSums[i] - 1.0 ) > dTolerance ) { fConsistent = false; Announce ( "TempestOfflineMap is not consistent in row %i (%1.15e)", i, dRowSums[i] ); } } return fConsistent; }
bool moab::TempestOfflineMap::IsMonotone | ( | double | dTolerance | ) | [virtual] |
Definition at line 1242 of file TempestOfflineMap.cpp.
{ // Get map entries DataVector<int> dataRows; DataVector<int> dataCols; DataVector<double> dataEntries; if ( size > 1 ) { if ( rank ) return true; SparseMatrix<double>& m_mapRemapGlobal = m_weightMapGlobal->GetSparseMatrix(); m_mapRemapGlobal.GetEntries ( dataRows, dataCols, dataEntries ); } else m_mapRemap.GetEntries ( dataRows, dataCols, dataEntries ); // Verify all entries are in the range [0,1] bool fMonotone = true; for ( unsigned i = 0; i < dataRows.GetRows(); i++ ) { if ( ( dataEntries[i] < -dTolerance ) || ( dataEntries[i] > 1.0 + dTolerance ) ) { fMonotone = false; Announce ( "TempestOfflineMap is not monotone in entry (%i): %1.15e", i, dataEntries[i] ); } } return fMonotone; }
void moab::TempestOfflineMap::LinearRemapFVtoFV_Tempest_MOAB | ( | int | nOrder | ) | [private] |
Definition at line 251 of file TempestLinearRemap.cpp.
References BuildFitArray(), BuildIntegrationArray(), GetAdjacentFaceVectorByEdge(), InvertFitArray_Corrected(), is_root, ixOverlap, m_meshInputCov, m_meshOutput, and m_meshOverlap.
{ // Order of triangular quadrature rule const int TriQuadRuleOrder = 4; // Verify ReverseNodeArray has been calculated if ( m_meshInputCov->revnodearray.size() == 0 ) { _EXCEPTIONT ( "ReverseNodeArray has not been calculated for m_meshInput" ); } // Triangular quadrature rule TriangularQuadratureRule triquadrule ( TriQuadRuleOrder ); // Number of coefficients needed at this order #ifdef RECTANGULAR_TRUNCATION int nCoefficients = nOrder * nOrder; #endif #ifdef TRIANGULAR_TRUNCATION int nCoefficients = nOrder * ( nOrder + 1 ) / 2; #endif // Number of faces you need const int nRequiredFaceSetSize = nCoefficients; // Fit weight exponent const int nFitWeightsExponent = nOrder + 2; // Announcemnets if ( is_root ) { Announce ( "[moab::TempestOfflineMap::LinearRemapFVtoFV_Tempest_MOAB] Finite Volume to Finite Volume Projection" ); Announce ( "Triangular quadrature rule order %i", TriQuadRuleOrder ); Announce ( "Number of coefficients: %i", nCoefficients ); Announce ( "Required adjacency set size: %i", nRequiredFaceSetSize ); Announce ( "Fit weights exponent: %i", nFitWeightsExponent ); } // Current overlap face int ixOverlap = 0; #ifdef VERBOSE const unsigned outputFrequency = (m_meshInputCov->faces.size()/10); #endif // Loop through all faces on m_meshInput for ( size_t ixFirst = 0; ixFirst < m_meshInputCov->faces.size(); ixFirst++ ) { #ifdef VERBOSE // Output every 1000 elements if ( ixFirst % outputFrequency == 0 ) { Announce ( "Element %i/%i", ixFirst, m_meshInputCov->faces.size() ); } #endif // This Face // Find the set of Faces that overlap faceFirst int ixOverlapBegin = ixOverlap; unsigned ixOverlapEnd = ixOverlapBegin; for ( ; ixOverlapEnd < m_meshOverlap->faces.size(); ixOverlapEnd++ ) { if ( ixFirst - m_meshOverlap->vecSourceFaceIx[ixOverlapEnd] != 0 ) { break; } } unsigned nOverlapFaces = ixOverlapEnd - ixOverlapBegin; // if ( is_root ) Announce ( "Element %i / %i :: [%i, %i]", ixFirst, m_meshInputCov->faces.size(), ixOverlapBegin, ixOverlapEnd ); if ( nOverlapFaces == 0 ) continue; // Build integration array DataMatrix<double> dIntArray; BuildIntegrationArray ( *m_meshInputCov, *m_meshOverlap, triquadrule, ixFirst, ixOverlapBegin, ixOverlapEnd, nOrder, dIntArray ); // Set of Faces to use in building the reconstruction and associated // distance metric. AdjacentFaceVector vecAdjFaces; GetAdjacentFaceVectorByEdge ( *m_meshInputCov, ixFirst, nRequiredFaceSetSize, vecAdjFaces ); // Number of adjacent Faces int nAdjFaces = vecAdjFaces.size(); // Determine the conservative constraint equation DataVector<double> dConstraint; dConstraint.Initialize ( nCoefficients ); double dFirstArea = m_meshInputCov->vecFaceArea[ixFirst]; for ( int p = 0; p < nCoefficients; p++ ) { for ( unsigned j = 0; j < nOverlapFaces; j++ ) { dConstraint[p] += dIntArray[p][j]; } dConstraint[p] /= dFirstArea; } // Build the fit array from the integration operator DataMatrix<double> dFitArray; DataVector<double> dFitWeights; DataMatrix<double> dFitArrayPlus; BuildFitArray ( *m_meshInputCov, triquadrule, ixFirst, vecAdjFaces, nOrder, nFitWeightsExponent, dConstraint, dFitArray, dFitWeights ); // Compute the inverse fit array InvertFitArray_Corrected ( dConstraint, dFitArray, dFitWeights, dFitArrayPlus ); // Multiply integration array and fit array DataMatrix<double> dComposedArray; dComposedArray.Initialize ( nAdjFaces, nOverlapFaces ); for ( int i = 0; i < nAdjFaces; i++ ) { for ( unsigned j = 0; j < nOverlapFaces; j++ ) { for ( int k = 0; k < nCoefficients; k++ ) { dComposedArray[i][j] += dIntArray[k][j] * dFitArrayPlus[i][k]; } } } // Put composed array into map for ( unsigned i = 0; i < vecAdjFaces.size(); i++ ) { for ( unsigned j = 0; j < nOverlapFaces; j++ ) { int& ixFirstFaceLoc = vecAdjFaces[i].first; int& ixSecondFaceLoc = m_meshOverlap->vecTargetFaceIx[ixOverlap + j]; // int ixFirstFaceGlob = m_remapper->GetGlobalID(moab::Remapper::SourceMesh, ixFirstFaceLoc); // int ixSecondFaceGlob = m_remapper->GetGlobalID(moab::Remapper::TargetMesh, ixSecondFaceLoc); m_mapRemap ( ixSecondFaceLoc, ixFirstFaceLoc ) += dComposedArray[i][j] / m_meshOutput->vecFaceArea[ixSecondFaceLoc]; } } // Increment the current overlap index ixOverlap += nOverlapFaces; } return; }
void moab::TempestOfflineMap::LinearRemapFVtoGLL_MOAB | ( | const DataMatrix3D< int > & | dataGLLNodes, |
const DataMatrix3D< double > & | dataGLLJacobian, | ||
const DataVector< double > & | dataGLLNodalArea, | ||
int | nOrder, | ||
int | nMonotoneType, | ||
bool | fContinuous, | ||
bool | fNoConservation | ||
) | [private] |
Definition at line 2026 of file TempestLinearRemap.cpp.
References BuildFitArray(), dgesv_(), moab::GeomUtil::first(), ForceIntArrayConsistencyConservation(), GetAdjacentFaceVectorByEdge(), GetReferenceNode_MOAB(), InvertFitArray_Corrected(), ixOverlap, n, size, and t.
{ // NOTE: Reducing this quadrature rule order greatly affects error norms // Order of triangular quadrature rule const int TriQuadRuleOrder = 8; // Verify ReverseNodeArray has been calculated if ( m_meshInputCov->revnodearray.size() == 0 ) { _EXCEPTIONT ( "ReverseNodeArray has not been calculated for m_meshInput" ); } if ( m_meshInputCov->edgemap.size() == 0 ) { _EXCEPTIONT ( "EdgeMap has not been calculated for m_meshInput" ); } // Triangular quadrature rule TriangularQuadratureRule triquadrule ( TriQuadRuleOrder ); const DataMatrix<double> & dG = triquadrule.GetG(); const DataVector<double> & dW = triquadrule.GetW(); // Get SparseMatrix represntation of the OfflineMap SparseMatrix<double> & smatMap = this->GetSparseMatrix(); // Fit weight exponent int nFitWeightsExponent = nOrder + 2; // Order of the finite element method int nP = dataGLLNodes.GetRows(); // Sample coefficients DataMatrix<double> dSampleCoeff; dSampleCoeff.Initialize ( nP, nP ); // Number of elements needed #ifdef RECTANGULAR_TRUNCATION int nCoefficients = nOrder * nOrder; #endif #ifdef TRIANGULAR_TRUNCATION int nCoefficients = nOrder * ( nOrder + 1 ) / 2; #endif int nRequiredFaceSetSize = nCoefficients; // Announcemnets if ( is_root ) { Announce ( "[moab::TempestOfflineMap::LinearRemapFVtoGLL_MOAB] Finite Volume to Finite Element Projection" ); Announce ( "Triangular quadrature rule order %i", TriQuadRuleOrder ); Announce ( "Order of the FE polynomial interpolant: %i", nP ); Announce ( "Number of coefficients: %i", nCoefficients ); Announce ( "Required adjacency set size: %i", nRequiredFaceSetSize ); Announce ( "Fit weights exponent: %i", nFitWeightsExponent ); } // Current overlap face int ixOverlap = 0; // Build the integration array for each element on m_meshOverlap DataMatrix3D<double> dGlobalIntArray; dGlobalIntArray.Initialize ( nCoefficients, m_meshOverlap->faces.size(), nP * nP ); // Number of overlap Faces per source Face DataVector<int> nAllOverlapFaces; nAllOverlapFaces.Initialize ( m_meshInputCov->faces.size() ); // DataVector<int> nAllTotalOverlapTriangles; // nAllTotalOverlapTriangles.Initialize ( m_meshInputCov->faces.size() ); for ( size_t ixFirst = 0; ixFirst < m_meshInputCov->faces.size(); ixFirst++ ) { size_t ixOverlapTemp = ixOverlap; for ( ; ixOverlapTemp < m_meshOverlap->faces.size(); ixOverlapTemp++ ) { // const Face & faceOverlap = m_meshOverlap->faces[ixOverlapTemp]; if ( ixFirst - m_meshOverlap->vecSourceFaceIx[ixOverlapTemp] != 0 ) { break; } nAllOverlapFaces[ixFirst]++; // nAllTotalOverlapTriangles[ixFirst] += faceOverlap.edges.size() - 2; } // Increment the current overlap index ixOverlap += nAllOverlapFaces[ixFirst]; } // Loop through all faces on m_meshInput ixOverlap = 0; #ifdef VERBOSE const unsigned outputFrequency = (m_meshInputCov->faces.size()/10); #endif for ( size_t ixFirst = 0; ixFirst < m_meshInputCov->faces.size(); ixFirst++ ) { #ifdef VERBOSE // Announce computation progress if ( ixFirst % outputFrequency == 0 && is_root ) { Announce ( "Element %i/%i", ixFirst, m_meshInputCov->faces.size() ); } #endif // This Face const Face & faceFirst = m_meshInputCov->faces[ixFirst]; // Area of the First Face // double dFirstArea = m_meshInputCov->vecFaceArea[ixFirst]; // Coordinate axes Node nodeRef = GetReferenceNode_MOAB ( faceFirst, m_meshInputCov->nodes ); Node nodeA1 = m_meshInputCov->nodes[faceFirst[1]] - nodeRef; Node nodeA2 = m_meshInputCov->nodes[faceFirst[2]] - nodeRef; Node nodeC = CrossProduct ( nodeA1, nodeA2 ); // Fit matrix DataMatrix<double> dFit; dFit.Initialize ( 3, 3 ); dFit[0][0] = nodeA1.x; dFit[0][1] = nodeA1.y; dFit[0][2] = nodeA1.z; dFit[1][0] = nodeA2.x; dFit[1][1] = nodeA2.y; dFit[1][2] = nodeA2.z; dFit[2][0] = nodeC.x; dFit[2][1] = nodeC.y; dFit[2][2] = nodeC.z; // Number of overlapping Faces and triangles int nOverlapFaces = nAllOverlapFaces[ixFirst]; // int nTotalOverlapTriangles = nAllTotalOverlapTriangles[ixFirst]; // Loop through all Overlap Faces for ( int i = 0; i < nOverlapFaces; i++ ) { // Quantities from the overlap Mesh const Face & faceOverlap = m_meshOverlap->faces[ixOverlap + i]; const NodeVector & nodesOverlap = m_meshOverlap->nodes; int nOverlapTriangles = faceOverlap.edges.size() - 2; // Quantities from the Second Mesh int ixSecond = m_meshOverlap->vecTargetFaceIx[ixOverlap + i]; const NodeVector & nodesSecond = m_meshOutput->nodes; const Face & faceSecond = m_meshOutput->faces[ixSecond]; // Loop over all sub-triangles of this Overlap Face for ( int j = 0; j < nOverlapTriangles; j++ ) { // Cornerpoints of triangle const Node & node0 = nodesOverlap[faceOverlap[0]]; const Node & node1 = nodesOverlap[faceOverlap[j + 1]]; const Node & node2 = nodesOverlap[faceOverlap[j + 2]]; // Calculate the area of the modified Face Face faceTri ( 3 ); faceTri.SetNode ( 0, faceOverlap[0] ); faceTri.SetNode ( 1, faceOverlap[j + 1] ); faceTri.SetNode ( 2, faceOverlap[j + 2] ); double dTriArea = CalculateFaceArea ( faceTri, nodesOverlap ); for ( int k = 0; k < triquadrule.GetPoints(); k++ ) { double * dGL = dG[k]; // Get the nodal location of this point double dX[3]; dX[0] = dGL[0] * node0.x + dGL[1] * node1.x + dGL[2] * node2.x; dX[1] = dGL[0] * node0.y + dGL[1] * node1.y + dGL[2] * node2.y; dX[2] = dGL[0] * node0.z + dGL[1] * node1.z + dGL[2] * node2.z; double dMag = sqrt ( dX[0] * dX[0] + dX[1] * dX[1] + dX[2] * dX[2] ); dX[0] /= dMag; dX[1] /= dMag; dX[2] /= dMag; Node nodeQuadrature ( dX[0], dX[1], dX[2] ); dX[0] -= nodeRef.x; dX[1] -= nodeRef.y; dX[2] -= nodeRef.z; // Find the coefficients for this point of the polynomial int n = 3; int nrhs = 1; int lda = 3; int ipiv[3]; int ldb = 3; int info; DataMatrix<double> dFitTemp; dFitTemp = dFit; dgesv_ ( &n, &nrhs, & ( dFitTemp[0][0] ), &lda, ipiv, dX, &ldb, &info ); // Find the components of this quadrature point in the basis // of the finite element. double dAlpha; double dBeta; ApplyInverseMap ( faceSecond, nodesSecond, nodeQuadrature, dAlpha, dBeta ); /* // Check inverse map value if ((dAlpha < -1.0e-12) || (dAlpha > 1.0 + 1.0e-12) || (dBeta < -1.0e-12) || (dBeta > 1.0 + 1.0e-12) ) { _EXCEPTION2("Inverse Map out of range (%1.5e %1.5e)", dAlpha, dBeta); } */ // Sample the finite element at this point SampleGLLFiniteElement ( nMonotoneType, nP, dAlpha, dBeta, dSampleCoeff ); // Sample this point in the GLL element int ixs = 0; for ( int s = 0; s < nP; s++ ) { for ( int t = 0; t < nP; t++ ) { int ixp = 0; for ( int p = 0; p < nOrder; p++ ) { #ifdef TRIANGULAR_TRUNCATION const int redOrder = p; #else const int redOrder = 0; #endif for ( int q = 0; q < nOrder - redOrder; q++ ) { dGlobalIntArray[ixp][ixOverlap + i][ixs] += dSampleCoeff[s][t] * IPow ( dX[0], p ) * IPow ( dX[1], q ) * dW[k] * dTriArea / dataGLLJacobian[s][t][ixSecond]; ixp++; } } ixs++; } } } } } // Increment the current overlap index ixOverlap += nOverlapFaces; } // Reverse map std::vector< std::vector<int> > vecReverseFaceIx; vecReverseFaceIx.resize ( m_meshOutput->faces.size() ); for ( size_t i = 0; i < m_meshOverlap->faces.size(); i++ ) { int ixSecond = m_meshOverlap->vecTargetFaceIx[i]; vecReverseFaceIx[ixSecond].push_back ( i ); } // Force consistency and conservation for ( size_t ixSecond = 0; ixSecond < m_meshOutput->faces.size(); ixSecond++ ) { if ( vecReverseFaceIx[ixSecond].size() == 0 ) continue; DataMatrix<double> dCoeff; dCoeff.Initialize ( nP * nP, vecReverseFaceIx[ixSecond].size() ); for ( size_t i = 0; i < vecReverseFaceIx[ixSecond].size(); i++ ) { int ijxOverlap = vecReverseFaceIx[ixSecond][i]; for ( int s = 0; s < nP * nP; s++ ) { dCoeff[s][i] = dGlobalIntArray[0][ijxOverlap][s]; } } // Target areas DataVector<double> vecTargetArea; vecTargetArea.Initialize ( nP * nP ); for ( int s = 0; s < nP * nP; s++ ) { vecTargetArea[s] = dataGLLJacobian[s / nP][s % nP][ixSecond]; } // Source areas DataVector<double> vecSourceArea; vecSourceArea.Initialize ( vecReverseFaceIx[ixSecond].size() ); for ( size_t i = 0; i < vecReverseFaceIx[ixSecond].size(); i++ ) { int ijxOverlap = vecReverseFaceIx[ixSecond][i]; vecSourceArea[i] = m_meshOverlap->vecFaceArea[ijxOverlap]; } if ( !fNoConservation ) { ForceIntArrayConsistencyConservation ( vecSourceArea, vecTargetArea, dCoeff, ( nMonotoneType != 0 ) ); } for ( size_t i = 0; i < vecReverseFaceIx[ixSecond].size(); i++ ) { int ijxOverlap = vecReverseFaceIx[ixSecond][i]; for ( int s = 0; s < nP * nP; s++ ) { //printf("%1.15e %1.15e\n", dGlobalIntArray[0][ixOverlap][s], dCoeff[s][i]); dGlobalIntArray[0][ijxOverlap][s] = dCoeff[s][i]; } } } // Construct finite-volume fit matrix and compose with integration operator ixOverlap = 0; for ( size_t ixFirst = 0; ixFirst < m_meshInputCov->faces.size(); ixFirst++ ) { #ifdef VERBOSE // Announce computation progress if ( ixFirst % outputFrequency == 0 ) { Announce ( "Element %i", ixFirst ); } #endif // Area of the First Face double dFirstArea = m_meshInputCov->vecFaceArea[ixFirst]; // Number of overlapping Faces and triangles int nOverlapFaces = nAllOverlapFaces[ixFirst]; // Determine the conservative constraint equation DataVector<double> dConstraint; dConstraint.Initialize ( nCoefficients ); for ( int p = 0; p < nCoefficients; p++ ) { for ( int i = 0; i < nOverlapFaces; i++ ) { int ixSecond = m_meshOverlap->vecTargetFaceIx[ixOverlap + i]; for ( int s = 0; s < nP * nP; s++ ) { dConstraint[p] += dGlobalIntArray[p][ixOverlap + i][s] * dataGLLJacobian[s / nP][s % nP][ixSecond] / dFirstArea; } } } // Set of Faces to use in building the reconstruction and associated // distance metric. AdjacentFaceVector vecAdjFaces; GetAdjacentFaceVectorByEdge ( *m_meshInputCov, ixFirst, nRequiredFaceSetSize, vecAdjFaces ); // Number of adjacent Faces int nAdjFaces = vecAdjFaces.size(); for ( int x = 0; x < nAdjFaces; x++ ) { if ( vecAdjFaces[x].first == ( -1 ) ) { _EXCEPTION(); } } // Build the fit operator DataMatrix<double> dFitArray; DataVector<double> dFitWeights; DataMatrix<double> dFitArrayPlus; BuildFitArray ( *m_meshInputCov, triquadrule, ixFirst, vecAdjFaces, nOrder, nFitWeightsExponent, dConstraint, dFitArray, dFitWeights ); // Compute the inverse fit array InvertFitArray_Corrected ( dConstraint, dFitArray, dFitWeights, dFitArrayPlus ); // Multiply integration array and fit array DataMatrix<double> dComposedArray; dComposedArray.Initialize ( nAdjFaces, nOverlapFaces * nP * nP ); for ( int j = 0; j < nOverlapFaces; j++ ) { // int ixSecond = m_meshOverlap->vecTargetFaceIx[ixOverlap + j]; for ( int i = 0; i < nAdjFaces; i++ ) { for ( int s = 0; s < nP * nP; s++ ) { for ( int k = 0; k < nCoefficients; k++ ) { dComposedArray[i][j * nP * nP + s] += dGlobalIntArray[k][ixOverlap + j][s] * dFitArrayPlus[i][k]; } } } } // Put composed array into map for ( size_t i = 0; i < vecAdjFaces.size(); i++ ) { for ( int j = 0; j < nOverlapFaces; j++ ) { int ixFirstFace = vecAdjFaces[i].first; int ixSecondFace = m_meshOverlap->vecTargetFaceIx[ixOverlap + j]; for ( int s = 0; s < nP; s++ ) { for ( int t = 0; t < nP; t++ ) { int jx = j * nP * nP + s * nP + t; if ( fContinuous ) { int ixSecondNode = dataGLLNodes[s][t][ixSecondFace] - 1; smatMap ( ixSecondNode, ixFirstFace ) += dComposedArray[i][jx] * dataGLLJacobian[s][t][ixSecondFace] / dataGLLNodalArea[ixSecondNode]; } else { int ixSecondNode = ixSecondFace * nP * nP + s * nP + t; smatMap ( ixSecondNode, ixFirstFace ) += dComposedArray[i][jx]; } } } } } ixOverlap += nOverlapFaces; } return; }
void moab::TempestOfflineMap::LinearRemapFVtoGLL_Simple_MOAB | ( | const DataMatrix3D< int > & | dataGLLNodes, |
int | nOrder, | ||
) | [private] |
Definition at line 1307 of file TempestLinearRemap.cpp.
References BuildFitArray(), dgesv_(), GetAdjacentFaceVectorByEdge(), GetReferenceNode_MOAB(), InvertFitArray_Corrected(), ixOverlap, n, and t.
{ // Order of triangular quadrature rule const int TriQuadRuleOrder = 8; // Verify ReverseNodeArray has been calculated if ( m_meshInputCov->revnodearray.size() == 0 ) { _EXCEPTIONT ( "ReverseNodeArray has not been calculated for m_meshInput" ); } if ( m_meshInputCov->edgemap.size() == 0 ) { _EXCEPTIONT ( "EdgeMap has not been calculated for m_meshInput" ); } // Get SparseMatrix represntation of the OfflineMap SparseMatrix<double> & smatMap = this->GetSparseMatrix(); // Fit weight exponent int nFitWeightsExponent = nOrder + 2; // Order of the finite element method int nP = dataGLLNodes.GetRows(); // Announcemnets if ( is_root ) { Announce ( "[moab::TempestOfflineMap::LinearRemapFVtoGLL_Simple_MOAB] Finite Volume to Finite Element (Simple) Projection" ); Announce ( "Triangular quadrature rule order %i", TriQuadRuleOrder ); Announce ( "Order of the FE polynomial interpolant: %i", nP ); } // Mesh utilities MeshUtilitiesFuzzy meshutil; // GLL nodes DataVector<double> dG; DataVector<double> dW; GaussLobattoQuadrature::GetPoints ( nP, 0.0, 1.0, dG, dW ); // Triangular quadrature rule TriangularQuadratureRule triquadrule ( TriQuadRuleOrder ); // Number of elements needed #ifdef RECTANGULAR_TRUNCATION int nCoefficients = nOrder * nOrder; #endif #ifdef TRIANGULAR_TRUNCATION int nCoefficients = nOrder * ( nOrder + 1 ) / 2; #endif int nRequiredFaceSetSize = nCoefficients; // Set of found nodes std::set<int> setFoundNodes; // Loop through all faces on m_meshInput int ixOverlap = 0; #ifdef VERBOSE const unsigned outputFrequency = (m_meshInputCov->faces.size()/10); #endif for ( size_t ixFirst = 0; ixFirst < m_meshInputCov->faces.size(); ixFirst++ ) { #ifdef VERBOSE // Announce computation progress if ( ixFirst % outputFrequency == 0 ) { Announce ( "Element %i", ixFirst ); } #endif // This Face const Face & faceFirst = m_meshInputCov->faces[ixFirst]; // Coordinate axes Node nodeRef = GetReferenceNode_MOAB ( faceFirst, m_meshInputCov->nodes ); Node nodeA1 = m_meshInputCov->nodes[faceFirst[1]] - nodeRef; Node nodeA2 = m_meshInputCov->nodes[faceFirst[2]] - nodeRef; Node nodeC = CrossProduct ( nodeA1, nodeA2 ); // Fit matrix DataMatrix<double> dFit; dFit.Initialize ( 3, 3 ); dFit[0][0] = nodeA1.x; dFit[0][1] = nodeA1.y; dFit[0][2] = nodeA1.z; dFit[1][0] = nodeA2.x; dFit[1][1] = nodeA2.y; dFit[1][2] = nodeA2.z; dFit[2][0] = nodeC.x; dFit[2][1] = nodeC.y; dFit[2][2] = nodeC.z; // Set of Faces to use in building the reconstruction and associated // distance metric. AdjacentFaceVector vecAdjFaces; GetAdjacentFaceVectorByEdge ( *m_meshInputCov, ixFirst, nRequiredFaceSetSize, vecAdjFaces ); // Blank constraint DataVector<double> dConstraint; // Least squares arrays DataMatrix<double> dFitArray; DataVector<double> dFitWeights; DataMatrix<double> dFitArrayPlus; BuildFitArray ( *m_meshInputCov, triquadrule, ixFirst, vecAdjFaces, nOrder, nFitWeightsExponent, dConstraint, dFitArray, dFitWeights ); // Compute the inverse fit array InvertFitArray_Corrected ( dConstraint, dFitArray, dFitWeights, dFitArrayPlus ); // Number of overlapping Faces int nOverlapFaces = 0; size_t ixOverlapTemp = ixOverlap; for ( ; ixOverlapTemp < m_meshOverlap->faces.size(); ixOverlapTemp++ ) { // const Face & faceOverlap = m_meshOverlap->faces[ixOverlapTemp]; if ( ixFirst - m_meshOverlap->vecSourceFaceIx[ixOverlapTemp] != 0 ) { break; } nOverlapFaces++; } // Loop through all Overlap Faces for ( int i = 0; i < nOverlapFaces; i++ ) { // Quantities from the overlap Mesh // const Face & faceOverlap = m_meshOverlap->faces[ixOverlap + i]; // Quantities from the Second Mesh int ixSecondFace = m_meshOverlap->vecTargetFaceIx[ixOverlap + i]; // const NodeVector & nodesSecond = m_meshOutput->nodes; const Face & faceSecond = m_meshOutput->faces[ixSecondFace]; for ( int s = 0; s < nP; s++ ) { for ( int t = 0; t < nP; t++ ) { // Determine if this Node is in faceFirst Node node; Node dDx1G; Node dDx2G; ApplyLocalMap ( faceSecond, m_meshOutput->nodes, dG[s], dG[t], node, dDx1G, dDx2G ); Face::NodeLocation loc; int ixLocation; meshutil.ContainsNode ( faceFirst, m_meshInputCov->nodes, node, loc, ixLocation ); if ( loc == Face::NodeLocation_Exterior ) { continue; } // Second node index int ixSecondNode; if ( fContinuous ) { ixSecondNode = dataGLLNodes[t][s][ixSecondFace] - 1; } else { ixSecondNode = ixSecondFace * nP * nP + s * nP + t; } // Avoid duplicates if ( setFoundNodes.find ( ixSecondNode ) != setFoundNodes.end() ) { continue; } setFoundNodes.insert ( ixSecondNode ); // Find the coefficients for this point double dX[3]; dX[0] = node.x - nodeRef.x; dX[1] = node.y - nodeRef.y; dX[2] = node.z - nodeRef.z; // if (ixSecondNode < 10) { // double dLon = atan2(node.y, node.x); // if (dLon < 0.0) { // dLon += 2.0 * M_PI; // } // double dLat = asin(node.z); // dLon *= 180.0 / M_PI; // dLat *= 180.0 / M_PI; // printf("%i %1.15e %1.15e\n", ixSecondNode, dLon, dLat); // } int n = 3; int nrhs = 1; int lda = 3; int ipiv[3]; int ldb = 3; int info; DataMatrix<double> dFitTemp; dFitTemp = dFit; dgesv_ ( &n, &nrhs, & ( dFitTemp[0][0] ), &lda, ipiv, dX, &ldb, &info ); // Sample the reconstruction at this point int ixp = 0; #ifdef RECTANGULAR_TRUNCATION for ( int p = 0; p < nOrder; p++ ) { for ( int q = 0; q < nOrder; q++ ) { #endif #ifdef TRIANGULAR_TRUNCATION for ( int p = 0; p < nOrder; p++ ) { for ( int q = 0; q < nOrder - p; q++ ) { #endif for ( size_t nx = 0; nx < vecAdjFaces.size(); nx++ ) { int ixAdjFace = vecAdjFaces[nx].first; smatMap ( ixSecondNode, ixAdjFace ) += IPow ( dX[0], p ) * IPow ( dX[1], q ) * dFitArrayPlus[nx][ixp]; } ixp++; } } } } }
void moab::TempestOfflineMap::LinearRemapFVtoGLL_Volumetric_MOAB | ( | const DataMatrix3D< int > & | dataGLLNodes, |
int | nOrder, | ||
) | [private] |
Definition at line 1601 of file TempestLinearRemap.cpp.
References BuildFitArray(), BuildIntegrationArray(), ForceIntArrayConsistencyConservation(), GetAdjacentFaceVectorByEdge(), InvertFitArray_Corrected(), ixOverlap, and n.
{ // Order of triangular quadrature rule const int TriQuadRuleOrder = 4; // Verify ReverseNodeArray has been calculated if ( m_meshInputCov->revnodearray.size() == 0 ) { _EXCEPTIONT ( "ReverseNodeArray has not been calculated for m_meshInput" ); } // Triangular quadrature rule TriangularQuadratureRule triquadrule ( TriQuadRuleOrder ); // Fit weight exponent int nFitWeightsExponent = nOrder + 2; // Order of the finite element method int nP = dataGLLNodes.GetRows(); // Announcemnets if ( is_root ) { Announce ( "[moab::TempestOfflineMap::LinearRemapFVtoGLL_Volumetric_MOAB] Finite Volume to Finite Element (Volumetric) Projection" ); Announce ( "Triangular quadrature rule order %i", TriQuadRuleOrder ); Announce ( "Order of the FE polynomial interpolant: %i", nP ); } // Gauss-Lobatto quadrature nodes and weights DataVector<double> dG; DataVector<double> dW; GaussLobattoQuadrature::GetPoints ( nP, 0.0, 1.0, dG, dW ); // Get SparseMatrix represntation of the OfflineMap SparseMatrix<double> & smatMap = this->GetSparseMatrix(); // Number of elements needed #ifdef RECTANGULAR_TRUNCATION int nCoefficients = nOrder * nOrder; #endif #ifdef TRIANGULAR_TRUNCATION int nCoefficients = nOrder * ( nOrder + 1 ) / 2; #endif // #pragma message "This should be a command-line parameter" int nRequiredFaceSetSize = nCoefficients; // Accumulated weight vector DataVector<double> dAccumW ( nP + 1 ); dAccumW[0] = 0.0; for ( int i = 1; i < nP + 1; i++ ) { dAccumW[i] = dAccumW[i - 1] + dW[i - 1]; } if ( fabs ( dAccumW[dAccumW.GetRows() - 1] - 1.0 ) > 1.0e-14 ) { _EXCEPTIONT ( "Logic error in accumulated weight" ); } // Create sub-element mesh and redistribution map Announce ( "Generating sub-element mesh" ); Mesh meshTargetSubElement; DataVector<double> dFiniteVolumeArea ( nP * nP ); DataVector<double> dQuadratureArea ( nP * nP ); std::vector< DataMatrix<double> > dRedistributionMaps; dRedistributionMaps.resize ( m_meshOutput->faces.size() ); for ( size_t ixSecond = 0; ixSecond < m_meshOutput->faces.size(); ixSecond++ ) { const Face & faceSecond = m_meshOutput->faces[ixSecond]; const Node & nodeOutput0 = m_meshOutput->nodes[faceSecond[0]]; const Node & nodeOutput1 = m_meshOutput->nodes[faceSecond[1]]; const Node & nodeOutput2 = m_meshOutput->nodes[faceSecond[2]]; const Node & nodeOutput3 = m_meshOutput->nodes[faceSecond[3]]; for ( int q = 0; q < nP; q++ ) { for ( int p = 0; p < nP; p++ ) { Node node0 = InterpolateQuadrilateralNode ( nodeOutput0, nodeOutput1, nodeOutput2, nodeOutput3, dAccumW[p], dAccumW[q] ); Node node1 = InterpolateQuadrilateralNode ( nodeOutput0, nodeOutput1, nodeOutput2, nodeOutput3, dAccumW[p + 1], dAccumW[q] ); Node node2 = InterpolateQuadrilateralNode ( nodeOutput0, nodeOutput1, nodeOutput2, nodeOutput3, dAccumW[p + 1], dAccumW[q + 1] ); Node node3 = InterpolateQuadrilateralNode ( nodeOutput0, nodeOutput1, nodeOutput2, nodeOutput3, dAccumW[p], dAccumW[q + 1] ); int nNodeStart = meshTargetSubElement.nodes.size(); meshTargetSubElement.nodes.push_back ( node0 ); meshTargetSubElement.nodes.push_back ( node1 ); meshTargetSubElement.nodes.push_back ( node2 ); meshTargetSubElement.nodes.push_back ( node3 ); Face faceNew ( 4 ); faceNew.SetNode ( 0, nNodeStart ); faceNew.SetNode ( 1, nNodeStart + 1 ); faceNew.SetNode ( 2, nNodeStart + 2 ); faceNew.SetNode ( 3, nNodeStart + 3 ); meshTargetSubElement.faces.push_back ( faceNew ); dFiniteVolumeArea[q * nP + p] = CalculateFaceArea ( faceNew, meshTargetSubElement.nodes ); dQuadratureArea[q * nP + p] = dataGLLJacobian[q][p][ixSecond]; } } dRedistributionMaps[ixSecond].Initialize ( nP * nP, nP * nP ); for ( int i = 0; i < nP * nP; i++ ) { dRedistributionMaps[ixSecond][i][i] = 1.0; } if ( !fNoConservation ) { ForceIntArrayConsistencyConservation ( dFiniteVolumeArea, dQuadratureArea, dRedistributionMaps[ixSecond], ( nMonotoneType != 0 ) ); } /* double dSumQuadArea = 0.0; double dSumFVArea = 0.0; for (int i = 0; i < nP * nP; i++) { dSumQuadArea += dQuadratureArea[i]; dSumFVArea += dFiniteVolumeArea[i]; } if (fabs(dSumQuadArea - dSumFVArea) > 1.0e-14) { printf("%1.15e\n", dSumQuadArea - dSumFVArea); _EXCEPTION(); } */ for ( int i = 0; i < nP * nP; i++ ) { for ( int j = 0; j < nP * nP; j++ ) { dRedistributionMaps[ixSecond][i][j] *= dQuadratureArea[i] / dFiniteVolumeArea[j]; } } /* for (int i = 0; i < nP * nP; i++) { double dSum = 0.0; for (int j = 0; j < nP * nP; j++) { dSum += dRedistributionMaps[ixSecond][i][j] * dFiniteVolumeArea[j]; } printf("%i %1.15e %1.15e\n", i, dSum, dQuadratureArea[i]); } _EXCEPTION(); */ /* for (int i = 0; i < nP * nP; i++) { for (int j = 0; j < nP * nP; j++) { printf("%i %i %1.15e\n", i, j, dRedistributionMaps[ixSecond][i][j]); } } _EXCEPTION(); */ } // Current overlap face int ixOverlap = 0; #ifdef VERBOSE const unsigned outputFrequency = (m_meshInputCov->faces.size()/10); #endif // Loop through all faces on m_meshInput for ( size_t ixFirst = 0; ixFirst < m_meshInputCov->faces.size(); ixFirst++ ) { #ifdef VERBOSE // Announce computation progress if ( ixFirst % outputFrequency == 0 ) { Announce ( "Element %i", ixFirst ); } #endif // This Face // const Face & faceFirst = m_meshInputCov->faces[ixFirst]; // Find the set of Faces that overlap faceFirst size_t ixOverlapBegin = ixOverlap; size_t ixOverlapEnd = ixOverlapBegin; for ( ; ixOverlapEnd < m_meshOverlap->faces.size(); ixOverlapEnd++ ) { if ( ixFirst - m_meshOverlap->vecSourceFaceIx[ixOverlapEnd] != 0 ) break; } size_t nOverlapFaces = ixOverlapEnd - ixOverlapBegin; // Create a new Mesh representing the division of target finite // elements associated with this finite volume. Mesh meshThisElement; meshThisElement.faces.reserve ( nOverlapFaces * nP * nP ); meshThisElement.vecTargetFaceIx.reserve ( nOverlapFaces * nP * nP ); for ( size_t i = ixOverlapBegin; i < ixOverlapEnd; i++ ) { int iTargetFace = m_meshOverlap->vecTargetFaceIx[i]; int iSubElementBegin = iTargetFace * nP * nP; // int iSubElementEnd = ( iTargetFace + 1 ) * nP * nP; int iSubElement = iSubElementBegin; for ( int p = 0; p < nP; p++ ) { for ( int q = 0; q < nP; q++ ) { // Calculate overlap polygon between sub-element // and finite volume NodeVector nodevecOutput; GenerateOverlapFace<MeshUtilitiesFuzzy, Node> ( *m_meshInputCov, meshTargetSubElement, ixFirst, iSubElementBegin + p * nP + q, nodevecOutput ); /* if (nodevecOutput.size() < 3) { continue; } Face faceNew(nodevecOutput.size()); for (int n = 0; n < nodevecOutput.size(); n++) { faceNew.SetNode(n, n); } Real dArea = CalculateFaceArea(faceNew, nodevecOutput); if (dArea < 1.0e-13) { continue; } */ /* if (dataGLLNodes[p][q][iTargetFace] - 1 == 3) { printf("%1.15e %1.15e %1.15e\n", dArea, dataGLLJacobian[p][q][iTargetFace], dataGLLNodalArea[dataGLLNodes[p][q][iTargetFace] - 1]); } */ Face faceNew ( nodevecOutput.size() ); for ( size_t n = 0; n < nodevecOutput.size(); n++ ) { meshThisElement.nodes.push_back ( nodevecOutput[n] ); faceNew.SetNode ( n, meshThisElement.nodes.size() - 1 ); } meshThisElement.faces.push_back ( faceNew ); meshThisElement.vecTargetFaceIx.push_back ( dataGLLNodes[p][q][iTargetFace] - 1 ); iSubElement++; } } } if ( meshThisElement.faces.size() != nOverlapFaces * nP * nP ) { _EXCEPTIONT ( "Logic error" ); } // Build integration array DataMatrix<double> dIntArray; BuildIntegrationArray ( *m_meshInputCov, meshThisElement, triquadrule, ixFirst, 0, meshThisElement.faces.size(), nOrder, dIntArray ); // Set of Faces to use in building the reconstruction and associated // distance metric. AdjacentFaceVector vecAdjFaces; GetAdjacentFaceVectorByEdge ( *m_meshInputCov, ixFirst, nRequiredFaceSetSize, vecAdjFaces ); // Number of adjacent Faces int nAdjFaces = vecAdjFaces.size(); // Determine the conservative constraint equation DataVector<double> dConstraint; dConstraint.Initialize ( nCoefficients ); double dFirstArea = m_meshInputCov->vecFaceArea[ixFirst]; for ( int p = 0; p < nCoefficients; p++ ) { for ( size_t j = 0; j < meshThisElement.faces.size(); j++ ) { dConstraint[p] += dIntArray[p][j]; } dConstraint[p] /= dFirstArea; } // Least squares arrays DataMatrix<double> dFitArray; DataVector<double> dFitWeights; DataMatrix<double> dFitArrayPlus; BuildFitArray ( *m_meshInputCov, triquadrule, ixFirst, vecAdjFaces, nOrder, nFitWeightsExponent, dConstraint, dFitArray, dFitWeights ); // Compute the inverse fit array InvertFitArray_Corrected ( dConstraint, dFitArray, dFitWeights, dFitArrayPlus ); // Multiply integration array and fit array DataMatrix<double> dComposedArray; dComposedArray.Initialize ( nAdjFaces, meshThisElement.faces.size() ); for ( int i = 0; i < nAdjFaces; i++ ) { for ( size_t j = 0; j < meshThisElement.faces.size(); j++ ) { for ( int k = 0; k < nCoefficients; k++ ) { dComposedArray[i][j] += dIntArray[k][j] * dFitArrayPlus[i][k]; } } } // Apply redistribution operator DataMatrix<double> dRedistributedArray; dRedistributedArray.Initialize ( nAdjFaces, meshThisElement.faces.size() ); for ( int i = 0; i < nAdjFaces; i++ ) { for ( size_t j = 0; j < meshThisElement.faces.size(); j++ ) { int ixSubElement = j % ( nP * nP ); int ixElement = j / ( nP * nP ); int ixSecondFace = m_meshOverlap->vecTargetFaceIx[ixOverlap + ixElement]; for ( int k = 0; k < nP * nP; k++ ) { dRedistributedArray[i][j] += dComposedArray[i][ixElement * nP * nP + k] * dRedistributionMaps[ixSecondFace][ixSubElement][k]; } } } // Put composed array into map for ( size_t i = 0; i < vecAdjFaces.size(); i++ ) { for ( size_t j = 0; j < meshThisElement.faces.size(); j++ ) { int ixFirstFace = vecAdjFaces[i].first; int ixSecondNode = meshThisElement.vecTargetFaceIx[j]; smatMap ( ixSecondNode, ixFirstFace ) += dRedistributedArray[i][j] / dataGLLNodalArea[ixSecondNode]; // meshThisElement.vecFaceArea[j]; // dataGLLJacobian[ixS][ixT][ixSecondElement]; } } // Increment the current overlap index ixOverlap += nOverlapFaces; //_EXCEPTION(); } return; }
void moab::TempestOfflineMap::LinearRemapGLLtoGLL2_MOAB | ( | const DataMatrix3D< int > & | dataGLLNodesIn, |
const DataMatrix3D< double > & | dataGLLJacobianIn, | ||
const DataMatrix3D< int > & | dataGLLNodesOut, | ||
const DataMatrix3D< double > & | dataGLLJacobianOut, | ||
const DataVector< double > & | dataNodalAreaOut, | ||
int | nPin, | ||
int | nPout, | ||
bool | fContinuousIn, | ||
bool | fContinuousOut, | ||
) | [private] |
Definition at line 2531 of file TempestLinearRemap.cpp.
References ForceIntArrayConsistencyConservation(), ixOverlap, and t.
{ // Triangular quadrature rule TriangularQuadratureRule triquadrule ( 8 ); const DataMatrix<double> & dG = triquadrule.GetG(); const DataVector<double> & dW = triquadrule.GetW(); // Get SparseMatrix represntation of the OfflineMap SparseMatrix<double> & smatMap = this->GetSparseMatrix(); // Sample coefficients DataMatrix<double> dSampleCoeffIn; dSampleCoeffIn.Initialize ( nPin, nPin ); DataMatrix<double> dSampleCoeffOut; dSampleCoeffOut.Initialize ( nPout, nPout ); // Announcemnets if ( is_root ) { Announce ( "[moab::TempestOfflineMap::LinearRemapGLLtoGLL2_MOAB] Finite Element to Finite Element Projection" ); Announce ( "Order of the input FE polynomial interpolant: %i", nPin ); Announce ( "Order of the output FE polynomial interpolant: %i", nPout ); } // Build the integration array for each element on m_meshOverlap DataMatrix3D<double> dGlobalIntArray; dGlobalIntArray.Initialize ( nPin * nPin, m_meshOverlap->faces.size(), nPout * nPout ); // Number of overlap Faces per source Face DataVector<int> nAllOverlapFaces; nAllOverlapFaces.Initialize ( m_meshInputCov->faces.size() ); int ixOverlap = 0; for ( size_t ixFirst = 0; ixFirst < m_meshInputCov->faces.size(); ixFirst++ ) { size_t ixOverlapTemp = ixOverlap; for ( ; ixOverlapTemp < m_meshOverlap->faces.size(); ixOverlapTemp++ ) { // const Face & faceOverlap = m_meshOverlap->faces[ixOverlapTemp]; if ( ixFirst - m_meshOverlap->vecSourceFaceIx[ixOverlapTemp] != 0 ) { break; } nAllOverlapFaces[ixFirst]++; } // Increment the current overlap index ixOverlap += nAllOverlapFaces[ixFirst]; } // Geometric area of each output node DataMatrix<double> dGeometricOutputArea; dGeometricOutputArea.Initialize ( m_meshOutput->faces.size(), nPout * nPout ); // Area of each overlap element in the output basis DataMatrix<double> dOverlapOutputArea; dOverlapOutputArea.Initialize ( m_meshOverlap->faces.size(), nPout * nPout ); // Loop through all faces on m_meshInput ixOverlap = 0; #ifdef VERBOSE const unsigned outputFrequency = (m_meshInputCov->faces.size()/10); #endif if ( is_root ) Announce ( "Building conservative distribution maps" ); for ( size_t ixFirst = 0; ixFirst < m_meshInputCov->faces.size(); ixFirst++ ) { #ifdef VERBOSE // Announce computation progress if ( ixFirst % outputFrequency == 0 && is_root ) { Announce ( "Element %i", ixFirst ); } #endif // Quantities from the First Mesh const Face & faceFirst = m_meshInputCov->faces[ixFirst]; const NodeVector & nodesFirst = m_meshInputCov->nodes; // Number of overlapping Faces and triangles int nOverlapFaces = nAllOverlapFaces[ixFirst]; if ( !nOverlapFaces ) continue; /* // Calculate total element Jacobian double dTotalJacobian = 0.0; for (int s = 0; s < nPin; s++) { for (int t = 0; t < nPin; t++) { dTotalJacobian += dataGLLJacobianIn[s][t][ixFirst]; } } */ // Loop through all Overlap Faces for ( int i = 0; i < nOverlapFaces; i++ ) { // Quantities from the overlap Mesh const Face & faceOverlap = m_meshOverlap->faces[ixOverlap + i]; const NodeVector & nodesOverlap = m_meshOverlap->nodes; int nOverlapTriangles = faceOverlap.edges.size() - 2; // Quantities from the Second Mesh int ixSecond = m_meshOverlap->vecTargetFaceIx[ixOverlap + i]; const NodeVector & nodesSecond = m_meshOutput->nodes; const Face & faceSecond = m_meshOutput->faces[ixSecond]; // Loop over all sub-triangles of this Overlap Face for ( int j = 0; j < nOverlapTriangles; j++ ) { // Cornerpoints of triangle const Node & node0 = nodesOverlap[faceOverlap[0]]; const Node & node1 = nodesOverlap[faceOverlap[j + 1]]; const Node & node2 = nodesOverlap[faceOverlap[j + 2]]; // Calculate the area of the modified Face Face faceTri ( 3 ); faceTri.SetNode ( 0, faceOverlap[0] ); faceTri.SetNode ( 1, faceOverlap[j + 1] ); faceTri.SetNode ( 2, faceOverlap[j + 2] ); double dTriArea = CalculateFaceArea ( faceTri, nodesOverlap ); for ( int k = 0; k < triquadrule.GetPoints(); k++ ) { double * dGL = dG[k]; // Get the nodal location of this point double dX[3]; dX[0] = dGL[0] * node0.x + dGL[1] * node1.x + dGL[2] * node2.x; dX[1] = dGL[0] * node0.y + dGL[1] * node1.y + dGL[2] * node2.y; dX[2] = dGL[0] * node0.z + dGL[1] * node1.z + dGL[2] * node2.z; double dMag = sqrt ( dX[0] * dX[0] + dX[1] * dX[1] + dX[2] * dX[2] ); dX[0] /= dMag; dX[1] /= dMag; dX[2] /= dMag; Node nodeQuadrature ( dX[0], dX[1], dX[2] ); // Find the components of this quadrature point in the basis // of the first Face. double dAlphaIn; double dBetaIn; ApplyInverseMap ( faceFirst, nodesFirst, nodeQuadrature, dAlphaIn, dBetaIn ); // Find the components of this quadrature point in the basis // of the second Face. double dAlphaOut; double dBetaOut; ApplyInverseMap ( faceSecond, nodesSecond, nodeQuadrature, dAlphaOut, dBetaOut ); /* // Check inverse map value if ((dAlphaIn < 0.0) || (dAlphaIn > 1.0) || (dBetaIn < 0.0) || (dBetaIn > 1.0) ) { _EXCEPTION2("Inverse Map out of range (%1.5e %1.5e)", dAlphaIn, dBetaIn); } // Check inverse map value if ((dAlphaOut < 0.0) || (dAlphaOut > 1.0) || (dBetaOut < 0.0) || (dBetaOut > 1.0) ) { _EXCEPTION2("Inverse Map out of range (%1.5e %1.5e)", dAlphaOut, dBetaOut); } */ // Sample the First finite element at this point SampleGLLFiniteElement ( nMonotoneType, nPin, dAlphaIn, dBetaIn, dSampleCoeffIn ); // Sample the Second finite element at this point SampleGLLFiniteElement ( nMonotoneType, nPout, dAlphaOut, dBetaOut, dSampleCoeffOut ); // Overlap output area for ( int s = 0; s < nPout; s++ ) { for ( int t = 0; t < nPout; t++ ) { double dNodeArea = dSampleCoeffOut[s][t] * dW[k] * dTriArea; dOverlapOutputArea[ixOverlap + i][s * nPout + t] += dNodeArea; dGeometricOutputArea[ixSecond][s * nPout + t] += dNodeArea; } } // Compute overlap integral int ixp = 0; for ( int p = 0; p < nPin; p++ ) { for ( int q = 0; q < nPin; q++ ) { int ixs = 0; for ( int s = 0; s < nPout; s++ ) { for ( int t = 0; t < nPout; t++ ) { // Sample the Second finite element at this point dGlobalIntArray[ixp][ixOverlap + i][ixs] += dSampleCoeffOut[s][t] * dSampleCoeffIn[p][q] * dW[k] * dTriArea; ixs++; } } ixp++; } } } } } // Coefficients DataMatrix<double> dCoeff; dCoeff.Initialize ( nOverlapFaces * nPout * nPout, nPin * nPin ); for ( int i = 0; i < nOverlapFaces; i++ ) { // int ixSecondFace = m_meshOverlap->vecTargetFaceIx[ixOverlap + i]; int ixp = 0; for ( int p = 0; p < nPin; p++ ) { for ( int q = 0; q < nPin; q++ ) { int ixs = 0; for ( int s = 0; s < nPout; s++ ) { for ( int t = 0; t < nPout; t++ ) { dCoeff[i * nPout * nPout + ixs][ixp] = dGlobalIntArray[ixp][ixOverlap + i][ixs] / dOverlapOutputArea[ixOverlap + i][s * nPout + t]; ixs++; } } ixp++; } } } // Source areas DataVector<double> vecSourceArea ( nPin * nPin ); for ( int p = 0; p < nPin; p++ ) { for ( int q = 0; q < nPin; q++ ) { vecSourceArea[p * nPin + q] = dataGLLJacobianIn[p][q][ixFirst]; } } // Target areas DataVector<double> vecTargetArea ( nOverlapFaces * nPout * nPout ); for ( int i = 0; i < nOverlapFaces; i++ ) { // int ixSecond = m_meshOverlap->vecTargetFaceIx[ixOverlap + i]; int ixs = 0; for ( int s = 0; s < nPout; s++ ) { for ( int t = 0; t < nPout; t++ ) { vecTargetArea[i * nPout * nPout + ixs] = dOverlapOutputArea[ixOverlap + i][nPout * s + t]; ixs++; } } } // Force consistency and conservation if ( !fNoConservation ) { ForceIntArrayConsistencyConservation ( vecSourceArea, vecTargetArea, dCoeff, ( nMonotoneType != 0 ) ); } // Update global coefficients for ( int i = 0; i < nOverlapFaces; i++ ) { int ixp = 0; for ( int p = 0; p < nPin; p++ ) { for ( int q = 0; q < nPin; q++ ) { int ixs = 0; for ( int s = 0; s < nPout; s++ ) { for ( int t = 0; t < nPout; t++ ) { dGlobalIntArray[ixp][ixOverlap + i][ixs] = dCoeff[i * nPout * nPout + ixs][ixp] * dOverlapOutputArea[ixOverlap + i][s * nPout + t]; ixs++; } } ixp++; } } } /* // Check column sums (conservation) for (int i = 0; i < nPin * nPin; i++) { double dColSum = 0.0; for (int j = 0; j < nOverlapFaces * nPout * nPout; j++) { dColSum += dCoeff[j][i] * vecTargetArea[j]; } printf("Col %i: %1.15e\n", i, dColSum / vecSourceArea[i]); } // Check row sums (consistency) for (int j = 0; j < nOverlapFaces * nPout * nPout; j++) { double dRowSum = 0.0; for (int i = 0; i < nPin * nPin; i++) { dRowSum += dCoeff[j][i]; } printf("Row %i: %1.15e\n", j, dRowSum); } _EXCEPTION(); */ // Increment the current overlap index ixOverlap += nOverlapFaces; } // Build redistribution map within target element Announce ( "Building redistribution maps on target mesh" ); DataVector<double> dRedistSourceArea ( nPout * nPout ); DataVector<double> dRedistTargetArea ( nPout * nPout ); std::vector< DataMatrix<double> > dRedistributionMaps; dRedistributionMaps.resize ( m_meshOutput->faces.size() ); for ( size_t ixSecond = 0; ixSecond < m_meshOutput->faces.size(); ixSecond++ ) { dRedistributionMaps[ixSecond].Initialize ( nPout * nPout, nPout * nPout ); for ( int i = 0; i < nPout * nPout; i++ ) { dRedistributionMaps[ixSecond][i][i] = 1.0; } for ( int s = 0; s < nPout * nPout; s++ ) { dRedistSourceArea[s] = dGeometricOutputArea[ixSecond][s]; } for ( int s = 0; s < nPout * nPout; s++ ) { dRedistTargetArea[s] = dataGLLJacobianOut[s / nPout][s % nPout][ixSecond]; } if ( !fNoConservation ) { ForceIntArrayConsistencyConservation ( dRedistSourceArea, dRedistTargetArea, dRedistributionMaps[ixSecond], ( nMonotoneType != 0 ) ); for ( int s = 0; s < nPout * nPout; s++ ) { for ( int t = 0; t < nPout * nPout; t++ ) { dRedistributionMaps[ixSecond][s][t] *= dRedistTargetArea[s] / dRedistSourceArea[t]; } } } } // Construct the total geometric area DataVector<double> dTotalGeometricArea ( dataNodalAreaOut.GetRows() ); for ( size_t ixSecond = 0; ixSecond < m_meshOutput->faces.size(); ixSecond++ ) { for ( int s = 0; s < nPout; s++ ) { for ( int t = 0; t < nPout; t++ ) { dTotalGeometricArea[dataGLLNodesOut[s][t][ixSecond] - 1] += dGeometricOutputArea[ixSecond][s * nPout + t]; } } } // Compose the integration operator with the output map ixOverlap = 0; Announce ( "Assembling map" ); // Map from source DOFs to target DOFs with redistribution applied DataMatrix<double> dRedistributedOp ( nPin * nPin, nPout * nPout ); for ( size_t ixFirst = 0; ixFirst < m_meshInputCov->faces.size(); ixFirst++ ) { #ifdef VERBOSE // Announce computation progress if ( ixFirst % outputFrequency == 0 ) { Announce ( "Element %i", ixFirst ); } #endif // Number of overlapping Faces and triangles int nOverlapFaces = nAllOverlapFaces[ixFirst]; // Put composed array into map for ( int j = 0; j < nOverlapFaces; j++ ) { int ixSecondFace = m_meshOverlap->vecTargetFaceIx[ixOverlap + j]; dRedistributedOp.Zero(); for ( int p = 0; p < nPin * nPin; p++ ) { for ( int s = 0; s < nPout * nPout; s++ ) { for ( int t = 0; t < nPout * nPout; t++ ) { dRedistributedOp[p][s] += dRedistributionMaps[ixSecondFace][s][t] * dGlobalIntArray[p][ixOverlap + j][t]; } } } int ixp = 0; for ( int p = 0; p < nPin; p++ ) { for ( int q = 0; q < nPin; q++ ) { int ixFirstNode; if ( fContinuousIn ) { ixFirstNode = dataGLLNodesIn[p][q][ixFirst] - 1; } else { ixFirstNode = ixFirst * nPin * nPin + p * nPin + q; } int ixs = 0; for ( int s = 0; s < nPout; s++ ) { for ( int t = 0; t < nPout; t++ ) { int ixSecondNode; if ( fContinuousOut ) { ixSecondNode = dataGLLNodesOut[s][t][ixSecondFace] - 1; if ( !fNoConservation ) { smatMap ( ixSecondNode, ixFirstNode ) += dRedistributedOp[ixp][ixs] / dataNodalAreaOut[ixSecondNode]; } else { smatMap ( ixSecondNode, ixFirstNode ) += dRedistributedOp[ixp][ixs] / dTotalGeometricArea[ixSecondNode]; } } else { ixSecondNode = ixSecondFace * nPout * nPout + s * nPout + t; if ( !fNoConservation ) { smatMap ( ixSecondNode, ixFirstNode ) += dRedistributedOp[ixp][ixs] / dataGLLJacobianOut[s][t][ixSecondFace]; } else { smatMap ( ixSecondNode, ixFirstNode ) += dRedistributedOp[ixp][ixs] / dGeometricOutputArea[ixSecondFace][s * nPout + t]; } } ixs++; } } ixp++; } } } // Increment the current overlap index ixOverlap += nOverlapFaces; } return; }
void moab::TempestOfflineMap::LinearRemapGLLtoGLL2_Pointwise_MOAB | ( | const DataMatrix3D< int > & | dataGLLNodesIn, |
int | nPin, | ||
int | nPout, | ||
bool | fContinuousOut | ||
) | [private] |
Generate the OfflineMap for remapping from finite elements to finite elements (pointwise interpolation).
Definition at line 3117 of file TempestLinearRemap.cpp.
{ // Gauss-Lobatto quadrature within Faces DataVector<double> dGL; DataVector<double> dWL; GaussLobattoQuadrature::GetPoints ( nPout, 0.0, 1.0, dGL, dWL ); // Utilities MeshUtilitiesFuzzy utils; // Get SparseMatrix represntation of the OfflineMap SparseMatrix<double> & smatMap = this->GetSparseMatrix(); // Sample coefficients DataMatrix<double> dSampleCoeffIn; dSampleCoeffIn.Initialize ( nPin, nPin ); // Announcemnets if ( is_root ) { Announce ( "[moab::TempestOfflineMap::LinearRemapGLLtoGLL2_Pointwise_MOAB] Finite Element to Finite Element (Pointwise) Projection" ); Announce ( "Order of the input FE polynomial interpolant: %i", nPin ); Announce ( "Order of the output FE polynomial interpolant: %i", nPout ); } // Number of overlap Faces per source Face DataVector<int> nAllOverlapFaces; nAllOverlapFaces.Initialize ( m_meshInputCov->faces.size() ); int ixOverlap = 0; for ( size_t ixFirst = 0; ixFirst < m_meshInputCov->faces.size(); ixFirst++ ) { size_t ixOverlapTemp = ixOverlap; for ( ; ixOverlapTemp < m_meshOverlap->faces.size(); ixOverlapTemp++ ) { // const Face & faceOverlap = m_meshOverlap->faces[ixOverlapTemp]; if ( ixFirst - m_meshOverlap->vecSourceFaceIx[ixOverlapTemp] != 0 ) break; nAllOverlapFaces[ixFirst]++; } // Increment the current overlap index ixOverlap += nAllOverlapFaces[ixFirst]; } // Number of times this point was found DataVector<bool> fSecondNodeFound ( dataNodalAreaOut.GetRows() ); ixOverlap = 0; #ifdef VERBOSE const unsigned outputFrequency = (m_meshInputCov->faces.size()/10); #endif // Loop through all faces on m_meshInputCov for ( size_t ixFirst = 0; ixFirst < m_meshInputCov->faces.size(); ixFirst++ ) { #ifdef VERBOSE // Announce computation progress if ( ixFirst % outputFrequency == 0 ) { Announce ( "Element %i", ixFirst ); } #endif // Quantities from the First Mesh const Face & faceFirst = m_meshInputCov->faces[ixFirst]; const NodeVector & nodesFirst = m_meshInputCov->nodes; // Number of overlapping Faces and triangles int nOverlapFaces = nAllOverlapFaces[ixFirst]; // Loop through all Overlap Faces for ( int i = 0; i < nOverlapFaces; i++ ) { // Quantities from the overlap Mesh // const Face & faceOverlap = m_meshOverlap->faces[ixOverlap + i]; // const NodeVector & nodesOverlap = m_meshOverlap->nodes; // size_t nOverlapTriangles = faceOverlap.edges.size() - 2; // Quantities from the Second Mesh int ixSecond = m_meshOverlap->vecTargetFaceIx[ixOverlap + i]; const NodeVector & nodesSecond = m_meshOutput->nodes; const Face & faceSecond = m_meshOutput->faces[ixSecond]; // Loop through all nodes on the second face for ( int s = 0; s < nPout; s++ ) { for ( int t = 0; t < nPout; t++ ) { size_t ixSecondNode; if ( fContinuousOut ) { ixSecondNode = dataGLLNodesOut[s][t][ixSecond] - 1; } else { ixSecondNode = ixSecond * nPout * nPout + s * nPout + t; } if ( ixSecondNode >= fSecondNodeFound.GetRows() ) { _EXCEPTIONT ( "Logic error" ); } // Check if this node has been found already if ( fSecondNodeFound[ixSecondNode] ) { continue; } // Check this node Node node; Node dDx1G; Node dDx2G; ApplyLocalMap ( faceSecond, nodesSecond, dGL[t], dGL[s], node, dDx1G, dDx2G ); // Find the components of this quadrature point in the basis // of the first Face. double dAlphaIn; double dBetaIn; ApplyInverseMap ( faceFirst, nodesFirst, node, dAlphaIn, dBetaIn ); // Check if this node is within the first Face if ( ( dAlphaIn < -1.0e-10 ) || ( dAlphaIn > 1.0 + 1.0e-10 ) || ( dBetaIn < -1.0e-10 ) || ( dBetaIn > 1.0 + 1.0e-10 ) ) { continue; } // Node is within the overlap region, mark as found fSecondNodeFound[ixSecondNode] = true; // Sample the First finite element at this point SampleGLLFiniteElement ( nMonotoneType, nPin, dAlphaIn, dBetaIn, dSampleCoeffIn ); // Add to map for ( int p = 0; p < nPin; p++ ) { for ( int q = 0; q < nPin; q++ ) { int ixFirstNode; if ( fContinuousIn ) { ixFirstNode = dataGLLNodesIn[p][q][ixFirst] - 1; } else { ixFirstNode = ixFirst * nPin * nPin + p * nPin + q; } smatMap ( ixSecondNode, ixFirstNode ) += dSampleCoeffIn[p][q]; } } } } } // Increment the current overlap index ixOverlap += nOverlapFaces; } // Check for missing samples for ( size_t i = 0; i < fSecondNodeFound.GetRows(); i++ ) { if ( !fSecondNodeFound[i] ) { _EXCEPTION1 ( "Can't sample point %i", i ); } } return; }
void moab::TempestOfflineMap::LinearRemapSE0_Tempest_MOAB | ( | const DataMatrix3D< int > & | dataGLLNodes, |
const DataMatrix3D< double > & | dataGLLJacobian | ||
) | [private] |
Generate the OfflineMap for linear conserative element-average spectral element to element average remapping.
void moab::TempestOfflineMap::LinearRemapSE4_Tempest_MOAB | ( | const DataMatrix3D< int > & | dataGLLNodes, |
) | [private] |
Generate the OfflineMap for cubic conserative element-average spectral element to element average remapping.
Definition at line 862 of file TempestLinearRemap.cpp.
References ForceConsistencyConservation3(), ixOverlap, and l.
{ // Order of the polynomial interpolant int nP = dataGLLNodes.GetRows(); // Order of triangular quadrature rule const int TriQuadRuleOrder = 4; // Triangular quadrature rule TriangularQuadratureRule triquadrule ( TriQuadRuleOrder ); int TriQuadraturePoints = triquadrule.GetPoints(); const DataMatrix<double> & TriQuadratureG = triquadrule.GetG(); const DataVector<double> & TriQuadratureW = triquadrule.GetW(); // Sample coefficients DataMatrix<double> dSampleCoeff; dSampleCoeff.Initialize ( nP, nP ); // GLL Quadrature nodes on quadrilateral elements DataVector<double> dG; DataVector<double> dW; GaussLobattoQuadrature::GetPoints ( nP, 0.0, 1.0, dG, dW ); // Announcemnets if ( is_root ) { Announce ( "[moab::TempestOfflineMap::LinearRemapSE4_Tempest_MOAB] Finite Element to Finite Volume Projection" ); Announce ( "Triangular quadrature rule order %i", TriQuadRuleOrder ); Announce ( "Order of the FE polynomial interpolant: %i", nP ); } // Get SparseMatrix represntation of the OfflineMap SparseMatrix<double> & smatMap = this->GetSparseMatrix(); // NodeVector from m_meshOverlap const NodeVector & nodesOverlap = m_meshOverlap->nodes; const NodeVector & nodesFirst = m_meshInputCov->nodes; // Vector of source areas DataVector<double> vecSourceArea; vecSourceArea.Initialize ( nP * nP ); DataVector<double> vecTargetArea; DataMatrix<double> dCoeff; #ifdef VERBOSE std::stringstream sstr; sstr << "remapdata_" << rank << ".txt"; std::ofstream output_file ( sstr.str() ); #endif // Current Overlap Face int ixOverlap = 0; #ifdef VERBOSE const unsigned outputFrequency = (m_meshInputCov->faces.size()/10); #endif // Loop over all input Faces for ( size_t ixFirst = 0; ixFirst < m_meshInputCov->faces.size(); ixFirst++ ) { const Face & faceFirst = m_meshInputCov->faces[ixFirst]; if ( faceFirst.edges.size() != 4 ) { _EXCEPTIONT ( "Only quadrilateral elements allowed for SE remapping" ); } #ifdef VERBOSE // Announce computation progress if ( ixFirst % outputFrequency == 0 ) { Announce ( "Element %i/%i", ixFirst, m_meshInputCov->faces.size() ); } #endif // Need to re-number the overlap elements such that vecSourceFaceIx[a:b] = 0, then 1 and so on wrt the input mesh data // Then the overlap_end and overlap_begin will be correct. However, the relation with MOAB and Tempest will go out of the roof // Determine how many overlap Faces and triangles are present int nOverlapFaces = 0; size_t ixOverlapTemp = ixOverlap; for ( ; ixOverlapTemp < m_meshOverlap->faces.size(); ixOverlapTemp++ ) { // const Face & faceOverlap = m_meshOverlap->faces[ixOverlapTemp]; if ( ixFirst - m_meshOverlap->vecSourceFaceIx[ixOverlapTemp] != 0 ) { break; } nOverlapFaces++; } // No overlaps if ( nOverlapFaces == 0 ) { continue; } // Allocate remap coefficients array for meshFirst Face DataMatrix3D<double> dRemapCoeff; dRemapCoeff.Initialize ( nP, nP, nOverlapFaces ); // Find the local remap coefficients for ( int j = 0; j < nOverlapFaces; j++ ) { const Face & faceOverlap = m_meshOverlap->faces[ixOverlap + j]; // #ifdef VERBOSE // if ( is_root ) // Announce ( "\tLocal ID: %i/%i = %i, areas = %2.8e", j + ixOverlap, nOverlapFaces, m_remapper->lid_to_gid_covsrc[m_meshOverlap->vecSourceFaceIx[ixOverlap + j]], m_meshOverlap->vecFaceArea[ixOverlap + j] ); // #endif int nOverlapTriangles = faceOverlap.edges.size() - 2; // #define USE_MININDEX #ifdef USE_MININDEX // first find out the minimum node, start there the triangle decomposition int minIndex = 0; int nnodes = faceOverlap.edges.size(); for (int j1=1; j1<nnodes; j1++) { if ( nodesOverlap[faceOverlap[j1]] < nodesOverlap[faceOverlap[minIndex]] ) { minIndex = j1; } } #endif // Loop over all sub-triangles of this Overlap Face for ( int k = 0; k < nOverlapTriangles; k++ ) { #ifdef USE_MININDEX // Cornerpoints of triangle, they start at the minimal Node, for consistency const Node & node0 = nodesOverlap[faceOverlap[minIndex]]; const Node & node1 = nodesOverlap[faceOverlap[(minIndex + k + 1)%nnodes]]; const Node & node2 = nodesOverlap[faceOverlap[(minIndex + k + 2)%nnodes]]; // Calculate the area of the modified Face Face faceTri ( 3 ); faceTri.SetNode ( 0, faceOverlap[minIndex] ); faceTri.SetNode ( 1, faceOverlap[(minIndex + k + 1)%nnodes] ); faceTri.SetNode ( 2, faceOverlap[(minIndex + k + 2)%nnodes] ); #else // Cornerpoints of triangle const Node & node0 = nodesOverlap[faceOverlap[0]]; const Node & node1 = nodesOverlap[faceOverlap[k+1]]; const Node & node2 = nodesOverlap[faceOverlap[k+2]]; // Calculate the area of the modified Face Face faceTri(3); faceTri.SetNode(0, faceOverlap[0]); faceTri.SetNode(1, faceOverlap[k+1]); faceTri.SetNode(2, faceOverlap[k+2]); #endif double dTriangleArea = CalculateFaceArea ( faceTri, nodesOverlap ); // Coordinates of quadrature Node for ( int l = 0; l < TriQuadraturePoints; l++ ) { Node nodeQuadrature; nodeQuadrature.x = TriQuadratureG[l][0] * node0.x + TriQuadratureG[l][1] * node1.x + TriQuadratureG[l][2] * node2.x; nodeQuadrature.y = TriQuadratureG[l][0] * node0.y + TriQuadratureG[l][1] * node1.y + TriQuadratureG[l][2] * node2.y; nodeQuadrature.z = TriQuadratureG[l][0] * node0.z + TriQuadratureG[l][1] * node1.z + TriQuadratureG[l][2] * node2.z; double dMag = sqrt ( nodeQuadrature.x * nodeQuadrature.x + nodeQuadrature.y * nodeQuadrature.y + nodeQuadrature.z * nodeQuadrature.z ); nodeQuadrature.x /= dMag; nodeQuadrature.y /= dMag; nodeQuadrature.z /= dMag; // Find components of quadrature point in basis // of the first Face double dAlpha; double dBeta; ApplyInverseMap ( faceFirst, nodesFirst, nodeQuadrature, dAlpha, dBeta ); // Check inverse map value if ( ( dAlpha < -1.0e-13 ) || ( dAlpha > 1.0 + 1.0e-13 ) || ( dBeta < -1.0e-13 ) || ( dBeta > 1.0 + 1.0e-13 ) ) { _EXCEPTION2 ( "Inverse Map out of range (%1.5e %1.5e)", dAlpha, dBeta ); } // Sample the finite element at this point SampleGLLFiniteElement ( nMonotoneType, nP, dAlpha, dBeta, dSampleCoeff ); // Add sample coefficients to the map for ( int p = 0; p < nP; p++ ) { for ( int q = 0; q < nP; q++ ) { dRemapCoeff[p][q][j] += TriQuadratureW[l] * dTriangleArea * dSampleCoeff[p][q] / m_meshOverlap->vecFaceArea[ixOverlap + j]; } } } } } #ifdef VERBOSE output_file << "[" << m_remapper->lid_to_gid_covsrc[ixFirst] << "] \t"; for ( int j = 0; j < nOverlapFaces; j++ ) { for ( int p = 0; p < nP; p++ ) { for ( int q = 0; q < nP; q++ ) { output_file << dRemapCoeff[p][q][j] << " "; } } } output_file << std::endl; #endif // Force consistency and conservation if ( !fNoConservation ) { double dTargetArea = 0.0; for ( int j = 0; j < nOverlapFaces; j++ ) { dTargetArea += m_meshOverlap->vecFaceArea[ixOverlap + j]; } for ( int p = 0; p < nP; p++ ) { for ( int q = 0; q < nP; q++ ) { vecSourceArea[p * nP + q] = dataGLLJacobian[p][q][ixFirst]; } } const double areaTolerance = 1e-10; // Source elements are completely covered by target volumes if ( fabs ( m_meshInputCov->vecFaceArea[ixFirst] - dTargetArea ) <= areaTolerance ) { vecTargetArea.Initialize ( nOverlapFaces ); for ( int j = 0; j < nOverlapFaces; j++ ) { vecTargetArea[j] = m_meshOverlap->vecFaceArea[ixOverlap + j]; } dCoeff.Initialize ( nOverlapFaces, nP * nP ); for ( int j = 0; j < nOverlapFaces; j++ ) { for ( int p = 0; p < nP; p++ ) { for ( int q = 0; q < nP; q++ ) { dCoeff[j][p * nP + q] = dRemapCoeff[p][q][j]; } } } // Target volumes only partially cover source elements } else if ( m_meshInputCov->vecFaceArea[ixFirst] - dTargetArea > areaTolerance ) { double dExtraneousArea = m_meshInputCov->vecFaceArea[ixFirst] - dTargetArea; vecTargetArea.Initialize ( nOverlapFaces + 1 ); for ( int j = 0; j < nOverlapFaces; j++ ) { vecTargetArea[j] = m_meshOverlap->vecFaceArea[ixOverlap + j]; } vecTargetArea[nOverlapFaces] = dExtraneousArea; #ifdef VERBOSE Announce ( "Partial volume: %i (%1.10e / %1.10e)", ixFirst, dTargetArea, m_meshInputCov->vecFaceArea[ixFirst] ); #endif if ( dTargetArea > m_meshInputCov->vecFaceArea[ixFirst] ) { _EXCEPTIONT ( "Partial element area exceeds total element area" ); } dCoeff.Initialize ( nOverlapFaces + 1, nP * nP ); for ( int j = 0; j < nOverlapFaces; j++ ) { for ( int p = 0; p < nP; p++ ) { for ( int q = 0; q < nP; q++ ) { dCoeff[j][p * nP + q] = dRemapCoeff[p][q][j]; } } } for ( int p = 0; p < nP; p++ ) { for ( int q = 0; q < nP; q++ ) { dCoeff[nOverlapFaces][p * nP + q] = dataGLLJacobian[p][q][ixFirst]; } } for ( int j = 0; j < nOverlapFaces; j++ ) { for ( int p = 0; p < nP; p++ ) { for ( int q = 0; q < nP; q++ ) { dCoeff[nOverlapFaces][p * nP + q] -= dRemapCoeff[p][q][j] * m_meshOverlap->vecFaceArea[ixOverlap + j]; } } } for ( int p = 0; p < nP; p++ ) { for ( int q = 0; q < nP; q++ ) { dCoeff[nOverlapFaces][p * nP + q] /= dExtraneousArea; } } // Source elements only partially cover target volumes } else { Announce ( "Coverage area: %1.10e, and target element area: %1.10e)", ixFirst, m_meshInputCov->vecFaceArea[ixFirst], dTargetArea ); _EXCEPTIONT ( "Target grid must be a subset of source grid" ); } ForceConsistencyConservation3 ( vecSourceArea, vecTargetArea, dCoeff, ( nMonotoneType > 0 ) /*, m_remapper->lid_to_gid_covsrc[ixFirst]*/ ); for ( int j = 0; j < nOverlapFaces; j++ ) { for ( int p = 0; p < nP; p++ ) { for ( int q = 0; q < nP; q++ ) { dRemapCoeff[p][q][j] = dCoeff[j][p * nP + q]; } } } } #ifdef VERBOSE // output_file << "[" << m_remapper->lid_to_gid_covsrc[ixFirst] << "] \t"; // for ( int j = 0; j < nOverlapFaces; j++ ) // { // for ( int p = 0; p < nP; p++ ) // { // for ( int q = 0; q < nP; q++ ) // { // output_file << dRemapCoeff[p][q][j] << " "; // } // } // } // output_file << std::endl; #endif // Put these remap coefficients into the SparseMatrix map for ( int j = 0; j < nOverlapFaces; j++ ) { int ixSecondFace = m_meshOverlap->vecTargetFaceIx[ixOverlap + j]; if (ixSecondFace < 0) // signal to not participate, because it is a ghost target continue; // do not do anything for ( int p = 0; p < nP; p++ ) { for ( int q = 0; q < nP; q++ ) { if ( fContinuousIn ) { int ixFirstNode = dataGLLNodes[p][q][ixFirst] - 1; smatMap ( ixSecondFace, ixFirstNode ) += dRemapCoeff[p][q][j] * m_meshOverlap->vecFaceArea[ixOverlap + j] / m_meshOutput->vecFaceArea[ixSecondFace]; } else { int ixFirstNode = ixFirst * nP * nP + p * nP + q; smatMap ( ixSecondFace, ixFirstNode ) += dRemapCoeff[p][q][j] * m_meshOverlap->vecFaceArea[ixOverlap + j] / m_meshOutput->vecFaceArea[ixSecondFace]; } } } } // Increment the current overlap index ixOverlap += nOverlapFaces; } #ifdef VERBOSE output_file.flush(); // required here output_file.close(); #endif return; }
moab::ErrorCode moab::TempestOfflineMap::SetDofMapAssociation | ( | DiscretizationType | srcType, |
bool | isSrcContinuous, | ||
DataMatrix3D< int > * | srcdataGLLNodes, | ||
DataMatrix3D< int > * | srcdataGLLNodesSrc, | ||
DiscretizationType | destType, | ||
bool | isDestContinuous, | ||
DataMatrix3D< int > * | tgtdataGLLNodes | ||
) | [private] |
Compute the association between the solution tag global DoF numbering and the local matrix numbering so that matvec operations can be performed consistently.
Definition at line 158 of file TempestOfflineMap.cpp.
References MB_CHK_ERR, MB_SUCCESS, and rank.
{ moab::ErrorCode rval; std::vector<bool> dgll_cgll_row_ldofmap, dgll_cgll_col_ldofmap, dgll_cgll_covcol_ldofmap; std::vector<int> src_soln_gdofs, locsrc_soln_gdofs, tgt_soln_gdofs; // We are assuming that these are element based tags that are sized: np * np m_srcDiscType = srcType; m_destDiscType = destType; bool vprint = is_root && false; #ifdef VVERBOSE { src_soln_gdofs.resize(m_remapper->m_covering_source_entities.size()*m_nDofsPEl_Src*m_nDofsPEl_Src, -1); rval = mbCore->tag_get_data ( m_dofTagSrc, m_remapper->m_covering_source_entities, &src_soln_gdofs[0] );MB_CHK_ERR(rval); locsrc_soln_gdofs.resize(m_remapper->m_source_entities.size()*m_nDofsPEl_Src*m_nDofsPEl_Src); rval = mbCore->tag_get_data ( m_dofTagSrc, m_remapper->m_source_entities, &locsrc_soln_gdofs[0] );MB_CHK_ERR(rval); tgt_soln_gdofs.resize(m_remapper->m_target_entities.size()*m_nDofsPEl_Dest*m_nDofsPEl_Dest); rval = mbCore->tag_get_data ( m_dofTagDest, m_remapper->m_target_entities, &tgt_soln_gdofs[0] );MB_CHK_ERR(rval); if (is_root) { { std::ofstream output_file ( "sourcecov-gids-0.txt" ); output_file << "I, GDOF\n"; for (unsigned i=0; i < src_soln_gdofs.size(); ++i) output_file << i << ", " << src_soln_gdofs[i] << "\n"; output_file << "ELEMID, IDOF, LDOF, GDOF, NDOF\n"; m_nTotDofs_SrcCov=0; if (isSrcContinuous) dgll_cgll_covcol_ldofmap.resize (m_remapper->m_covering_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src, false); for ( unsigned j = 0; j < m_remapper->m_covering_source_entities.size(); j++ ) { for ( int p = 0; p < m_nDofsPEl_Src; p++ ) { for ( int q = 0; q < m_nDofsPEl_Src; q++) { const int ldof = (*srcdataGLLNodes)[p][q][j] - 1; const int idof = j * m_nDofsPEl_Src * m_nDofsPEl_Src + p * m_nDofsPEl_Src + q; if ( isSrcContinuous && !dgll_cgll_covcol_ldofmap[ldof] ) { m_nTotDofs_SrcCov++; dgll_cgll_covcol_ldofmap[ldof] = true; } output_file << m_remapper->lid_to_gid_covsrc[j] << ", " << idof << ", " << ldof << ", " << src_soln_gdofs[idof] << ", " << m_nTotDofs_SrcCov << "\n"; } } } output_file.flush(); // required here output_file.close(); dgll_cgll_covcol_ldofmap.clear(); } { std::ofstream output_file ( "source-gids-0.txt" ); output_file << "I, GDOF\n"; for (unsigned i=0; i < locsrc_soln_gdofs.size(); ++i) output_file << i << ", " << locsrc_soln_gdofs[i] << "\n"; output_file << "ELEMID, IDOF, LDOF, GDOF, NDOF\n"; m_nTotDofs_Src=0; if (isSrcContinuous) dgll_cgll_col_ldofmap.resize (m_remapper->m_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src, false); for ( unsigned j = 0; j < m_remapper->m_source_entities.size(); j++ ) { for ( int p = 0; p < m_nDofsPEl_Src; p++ ) { for ( int q = 0; q < m_nDofsPEl_Src; q++) { const int ldof = (*srcdataGLLNodesSrc)[p][q][j] - 1; const int idof = j * m_nDofsPEl_Src * m_nDofsPEl_Src + p * m_nDofsPEl_Src + q; if ( isSrcContinuous && !dgll_cgll_col_ldofmap[ldof] ) { m_nTotDofs_Src++; dgll_cgll_col_ldofmap[ldof] = true; } output_file << m_remapper->lid_to_gid_src[j] << ", " << idof << ", " << ldof << ", " << locsrc_soln_gdofs[idof] << ", " << m_nTotDofs_Src << "\n"; } } } output_file.flush(); // required here output_file.close(); dgll_cgll_col_ldofmap.clear(); } { std::ofstream output_file ( "target-gids-0.txt" ); output_file << "I, GDOF\n"; for (unsigned i=0; i < tgt_soln_gdofs.size(); ++i) output_file << i << ", " << tgt_soln_gdofs[i] << "\n"; output_file << "ELEMID, IDOF, GDOF, NDOF\n"; m_nTotDofs_Dest=0; for (unsigned i=0; i < tgt_soln_gdofs.size(); ++i) { output_file << m_remapper->lid_to_gid_tgt[i] << ", " << i << ", " << tgt_soln_gdofs[i] << ", " << m_nTotDofs_Dest << "\n"; m_nTotDofs_Dest++; } output_file.flush(); // required here output_file.close(); } } else { { std::ofstream output_file ( "sourcecov-gids-1.txt" ); output_file << "I, GDOF\n"; for (unsigned i=0; i < src_soln_gdofs.size(); ++i) output_file << i << ", " << src_soln_gdofs[i] << "\n"; output_file << "ELEMID, IDOF, LDOF, GDOF, NDOF\n"; m_nTotDofs_SrcCov=0; if (isSrcContinuous) dgll_cgll_covcol_ldofmap.resize (m_remapper->m_covering_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src, false); for ( unsigned j = 0; j < m_remapper->m_covering_source_entities.size(); j++ ) { for ( int p = 0; p < m_nDofsPEl_Src; p++ ) { for ( int q = 0; q < m_nDofsPEl_Src; q++) { const int ldof = (*srcdataGLLNodes)[p][q][j] - 1; const int idof = j * m_nDofsPEl_Src * m_nDofsPEl_Src + p * m_nDofsPEl_Src + q; if ( isSrcContinuous && !dgll_cgll_covcol_ldofmap[ldof] ) { m_nTotDofs_SrcCov++; dgll_cgll_covcol_ldofmap[ldof] = true; } output_file << m_remapper->lid_to_gid_covsrc[j] << ", " << idof << ", " << ldof << ", " << src_soln_gdofs[idof] << ", " << m_nTotDofs_SrcCov << "\n"; } } } output_file.flush(); // required here output_file.close(); dgll_cgll_covcol_ldofmap.clear(); } { std::ofstream output_file ( "source-gids-1.txt" ); output_file << "I, GDOF\n"; for (unsigned i=0; i < locsrc_soln_gdofs.size(); ++i) output_file << i << ", " << locsrc_soln_gdofs[i] << "\n"; output_file << "ELEMID, IDOF, LDOF, GDOF, NDOF\n"; m_nTotDofs_Src=0; if (isSrcContinuous) dgll_cgll_col_ldofmap.resize (m_remapper->m_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src, false); for ( unsigned j = 0; j < m_remapper->m_source_entities.size(); j++ ) { for ( int p = 0; p < m_nDofsPEl_Src; p++ ) { for ( int q = 0; q < m_nDofsPEl_Src; q++) { const int ldof = (*srcdataGLLNodesSrc)[p][q][j] - 1; const int idof = j * m_nDofsPEl_Src * m_nDofsPEl_Src + p * m_nDofsPEl_Src + q; if ( isSrcContinuous && !dgll_cgll_col_ldofmap[ldof] ) { m_nTotDofs_Src++; dgll_cgll_col_ldofmap[ldof] = true; } output_file << m_remapper->lid_to_gid_src[j] << ", " << idof << ", " << ldof << ", " << locsrc_soln_gdofs[idof] << ", " << m_nTotDofs_Src << "\n"; } } } output_file.flush(); // required here output_file.close(); dgll_cgll_col_ldofmap.clear(); } { std::ofstream output_file ( "target-gids-1.txt" ); output_file << "I, GDOF\n"; for (unsigned i=0; i < tgt_soln_gdofs.size(); ++i) output_file << i << ", " << tgt_soln_gdofs[i] << "\n"; output_file << "ELEMID, IDOF, GDOF, NDOF\n"; m_nTotDofs_Dest=0; for (unsigned i=0; i < tgt_soln_gdofs.size(); ++i) { output_file << m_remapper->lid_to_gid_tgt[i] << ", " << i << ", " << tgt_soln_gdofs[i] << ", " << m_nTotDofs_Dest << "\n"; m_nTotDofs_Dest++; } output_file.flush(); // required here output_file.close(); } } } #endif // Now compute the mapping and store it for the covering mesh col_dofmap.resize (m_remapper->m_covering_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src, ULONG_MAX); col_ldofmap.resize (m_remapper->m_covering_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src, ULONG_MAX); col_gdofmap.resize (m_remapper->m_covering_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src, ULONG_MAX); src_soln_gdofs.resize(m_remapper->m_covering_source_entities.size()*m_nDofsPEl_Src*m_nDofsPEl_Src, INT_MAX); rval = mbCore->tag_get_data ( m_dofTagSrc, m_remapper->m_covering_source_entities, &src_soln_gdofs[0] );MB_CHK_ERR(rval); m_nTotDofs_SrcCov = 0; if (srcdataGLLNodes == NULL || srcType == DiscretizationType_FV) { /* we only have a mapping for elements as DoFs */ for (unsigned i=0; i < col_dofmap.size(); ++i) { col_dofmap[i] = i; col_ldofmap[i] = i; col_gdofmap[i] = src_soln_gdofs[i]; if (vprint) std::cout << "Col: " << i << ", " << src_soln_gdofs[i] << "\n"; m_nTotDofs_SrcCov++; } } else { if (isSrcContinuous) dgll_cgll_covcol_ldofmap.resize (m_remapper->m_covering_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src, false); // Put these remap coefficients into the SparseMatrix map for ( unsigned j = 0; j < m_remapper->m_covering_source_entities.size(); j++ ) { for ( int p = 0; p < m_nDofsPEl_Src; p++ ) { for ( int q = 0; q < m_nDofsPEl_Src; q++) { const int ldof = (*srcdataGLLNodes)[p][q][j] - 1; const int idof = j * m_nDofsPEl_Src * m_nDofsPEl_Src + p * m_nDofsPEl_Src + q; if ( isSrcContinuous && !dgll_cgll_covcol_ldofmap[ldof] ) { m_nTotDofs_SrcCov++; dgll_cgll_covcol_ldofmap[ldof] = true; } if ( !isSrcContinuous ) m_nTotDofs_SrcCov++; col_dofmap[ idof ] = ldof; col_ldofmap[ ldof ] = idof; assert(src_soln_gdofs[idof] > 0); col_gdofmap[ idof ] = src_soln_gdofs[idof] - 1; if (vprint) std::cout << "Col: " << m_remapper->lid_to_gid_covsrc[j] << ", " << idof << ", " << ldof << ", " << col_gdofmap[idof] << ", " << m_nTotDofs_SrcCov << "\n"; } } } } srccol_dofmap.resize (m_remapper->m_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src, ULONG_MAX); srccol_ldofmap.resize (m_remapper->m_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src, ULONG_MAX); srccol_gdofmap.resize (m_remapper->m_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src, ULONG_MAX); locsrc_soln_gdofs.resize(m_remapper->m_source_entities.size()*m_nDofsPEl_Src*m_nDofsPEl_Src, INT_MAX); rval = mbCore->tag_get_data ( m_dofTagSrc, m_remapper->m_source_entities, &locsrc_soln_gdofs[0] );MB_CHK_ERR(rval); // Now compute the mapping and store it for the original source mesh m_nTotDofs_Src = 0; if (srcdataGLLNodesSrc == NULL || srcType == DiscretizationType_FV) { /* we only have a mapping for elements as DoFs */ for (unsigned i=0; i < srccol_dofmap.size(); ++i) { srccol_dofmap[i] = i; srccol_ldofmap[i] = i; srccol_gdofmap[i] = locsrc_soln_gdofs[i]; m_nTotDofs_Src++; } } else { if (isSrcContinuous) dgll_cgll_col_ldofmap.resize(m_remapper->m_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src, false); // Put these remap coefficients into the SparseMatrix map for ( unsigned j = 0; j < m_remapper->m_source_entities.size(); j++ ) { for ( int p = 0; p < m_nDofsPEl_Src; p++ ) { for ( int q = 0; q < m_nDofsPEl_Src; q++ ) { const int ldof = (*srcdataGLLNodesSrc)[p][q][j] - 1; const int idof = j * m_nDofsPEl_Src * m_nDofsPEl_Src + p * m_nDofsPEl_Src + q; if ( isSrcContinuous && !dgll_cgll_col_ldofmap[ldof] ) { m_nTotDofs_Src++; dgll_cgll_col_ldofmap[ldof] = true; } if ( !isSrcContinuous ) m_nTotDofs_Src++; srccol_dofmap[ idof ] = ldof; srccol_ldofmap[ ldof ] = idof; srccol_gdofmap[ idof ] = locsrc_soln_gdofs[idof] - 1; } } } } row_dofmap.resize (m_remapper->m_target_entities.size() * m_nDofsPEl_Dest * m_nDofsPEl_Dest, ULONG_MAX); row_ldofmap.resize (m_remapper->m_target_entities.size() * m_nDofsPEl_Dest * m_nDofsPEl_Dest, ULONG_MAX); row_gdofmap.resize (m_remapper->m_target_entities.size() * m_nDofsPEl_Dest * m_nDofsPEl_Dest, ULONG_MAX); tgt_soln_gdofs.resize(m_remapper->m_target_entities.size()*m_nDofsPEl_Dest*m_nDofsPEl_Dest, INT_MAX); rval = mbCore->tag_get_data ( m_dofTagDest, m_remapper->m_target_entities, &tgt_soln_gdofs[0] );MB_CHK_ERR(rval); // Now compute the mapping and store it for the target mesh m_nTotDofs_Dest = 0; if (tgtdataGLLNodes == NULL || destType == DiscretizationType_FV) { /* we only have a mapping for elements as DoFs */ for (unsigned i=0; i < row_dofmap.size(); ++i) { row_dofmap[i] = i; row_ldofmap[i] = i; row_gdofmap[i] = tgt_soln_gdofs[i]; // if (vprint) std::cout << "Row: " << m_remapper->lid_to_gid_tgt[i] << ", " << i << ", " << row_dofmap[i] << ", " << row_ldofmap[i] << ", " << tgt_soln_gdofs[i] << ", " << row_gdofmap[i] << "\n"; m_nTotDofs_Dest++; } } else { if (isTgtContinuous) dgll_cgll_row_ldofmap.resize (m_remapper->m_target_entities.size() * m_nDofsPEl_Dest * m_nDofsPEl_Dest, false); // Put these remap coefficients into the SparseMatrix map for ( unsigned j = 0; j < m_remapper->m_target_entities.size(); j++ ) { for ( int p = 0; p < m_nDofsPEl_Dest; p++ ) { for ( int q = 0; q < m_nDofsPEl_Dest; q++ ) { const int ldof = (*tgtdataGLLNodes)[p][q][j] - 1; const int idof = j * m_nDofsPEl_Dest * m_nDofsPEl_Dest + p * m_nDofsPEl_Dest + q; if ( isTgtContinuous && !dgll_cgll_row_ldofmap[ldof] ) { m_nTotDofs_Dest++; dgll_cgll_row_ldofmap[ldof] = true; } if ( !isTgtContinuous ) m_nTotDofs_Dest++; row_dofmap[ idof ] = ldof; row_ldofmap[ ldof ] = idof; row_gdofmap[ idof ] = tgt_soln_gdofs[idof] - 1; if (vprint) std::cout << "Row: " << idof << ", " << ldof << ", " << tgt_soln_gdofs[idof] - 1 << "\n"; } } } } // Let us also allocate the local representation of the sparse matrix #ifdef MOAB_HAVE_EIGEN // if (vprint) { std::cout << "[" << rank << "]" << "DoFs: row = " << m_nTotDofs_Dest << ", " << row_dofmap.size() << ", col = " << m_nTotDofs_Src << ", " << m_nTotDofs_SrcCov << ", " << col_dofmap.size() << "\n"; // std::cout << "Max col_dofmap: " << maxcol << ", Min col_dofmap" << mincol << "\n"; } #endif return moab::MB_SUCCESS; }
moab::ErrorCode moab::TempestOfflineMap::SetDofMapTags | ( | const std::string | srcDofTagName, |
const std::string | tgtDofTagName | ||
) | [private] |
Store the tag names associated with global DoF ids for source and target meshes.
Definition at line 144 of file TempestOfflineMap.cpp.
References MB_CHK_ERR, MB_SUCCESS, MB_TAG_ANY, and MB_TYPE_INTEGER.
{ moab::ErrorCode rval; rval = mbCore->tag_get_handle ( srcDofTagName.c_str(), m_nDofsPEl_Src*m_nDofsPEl_Src, MB_TYPE_INTEGER, this->m_dofTagSrc, MB_TAG_ANY );MB_CHK_ERR(rval); rval = mbCore->tag_get_handle ( tgtDofTagName.c_str(), m_nDofsPEl_Dest*m_nDofsPEl_Dest, MB_TYPE_INTEGER, this->m_dofTagDest, MB_TAG_ANY );MB_CHK_ERR(rval); return moab::MB_SUCCESS; }
std::vector<unsigned long> moab::TempestOfflineMap::col_dofmap |
Definition at line 411 of file TempestOfflineMap.hpp.
std::vector<unsigned long> moab::TempestOfflineMap::col_gdofmap |
Definition at line 412 of file TempestOfflineMap.hpp.
std::vector<unsigned long> moab::TempestOfflineMap::col_ldofmap |
Definition at line 413 of file TempestOfflineMap.hpp.
DataMatrix3D<int> moab::TempestOfflineMap::dataGLLNodesDest |
Definition at line 415 of file TempestOfflineMap.hpp.
DataMatrix3D<int> moab::TempestOfflineMap::dataGLLNodesSrc |
DataMatrix3D<int> moab::TempestOfflineMap::dataGLLNodesSrcCov |
Definition at line 425 of file TempestOfflineMap.hpp.
Referenced by TempestOfflineMap().
Referenced by LinearRemapFVtoFV_Tempest_MOAB(), and TempestOfflineMap().
Definition at line 416 of file TempestOfflineMap.hpp.
Definition at line 410 of file TempestOfflineMap.hpp.
The original tag data and local to global DoF mapping to associate matrix values to solution.
The boolean flag representing whether the root process has the updated global view.
Definition at line 375 of file TempestOfflineMap.hpp.
Definition at line 420 of file TempestOfflineMap.hpp.
Definition at line 421 of file TempestOfflineMap.hpp.
Definition at line 422 of file TempestOfflineMap.hpp.
Definition at line 423 of file TempestOfflineMap.hpp.
Definition at line 418 of file TempestOfflineMap.hpp.
Definition at line 417 of file TempestOfflineMap.hpp.
Copy the local matrix from Tempest SparseMatrix representation (ELL) to the parallel CSR Eigen Matrix for scalable application of matvec needed for projections.
The fundamental remapping operator object.
Definition at line 364 of file TempestOfflineMap.hpp.
OfflineMap* moab::TempestOfflineMap::m_weightMapGlobal |
The SparseMatrix representing this operator.
Definition at line 370 of file TempestOfflineMap.hpp.
Referenced by GetGlobalSourceAreas(), GetGlobalTargetAreas(), and TempestOfflineMap().
The DataVector that stores the global (GID-based) areas of the source mesh.
The DataVector that stores the global (GID-based) areas of the target mesh. The reference to the moab::Core object that contains source/target and overlap sets.
Definition at line 398 of file TempestOfflineMap.hpp.
Definition at line 426 of file TempestOfflineMap.hpp.
std::vector<unsigned long> moab::TempestOfflineMap::row_dofmap |
std::vector<unsigned long> moab::TempestOfflineMap::row_gdofmap |
std::vector<unsigned long> moab::TempestOfflineMap::row_ldofmap |
std::vector<unsigned long> moab::TempestOfflineMap::srccol_dofmap |
std::vector<unsigned long> moab::TempestOfflineMap::srccol_gdofmap |
std::vector<unsigned long> moab::TempestOfflineMap::srccol_ldofmap |
