moab::TempestOnlineMap Class Reference
An offline map between two Meshes. More...
#include <TempestOnlineMap.hpp>
+ Collaboration diagram for moab::TempestOnlineMap:
Public Types
enum  DiscretizationType { DiscretizationType_FV, DiscretizationType_CGLL, DiscretizationType_DGLL, DiscretizationType_PCLOUD }
typedef double(* sample_function )(double, double)
Public Member Functions
 TempestOnlineMap (moab::TempestRemapper *remapper)
 Generate the metadata associated with the offline map.
virtual ~TempestOnlineMap ()
 Define a virtual destructor.
moab::ErrorCode GenerateRemappingWeights (std::string strInputType, std::string strOutputType, const GenerateOfflineMapAlgorithmOptions &mapOptions, const std::string &srcDofTagName="GLOBAL_ID", const std::string &tgtDofTagName="GLOBAL_ID")
 Generate the offline map, given the source and target mesh and discretization details. This method generates the mapping between the two meshes based on the overlap and stores the result in the SparseMatrix.
moab::ErrorCode ReadParallelMap (const char *strSource, const std::vector< int > &owned_dof_ids, bool row_major_ownership=true)
moab::ErrorCode WriteParallelMap (const std::string &strTarget)
 Write the TempestOnlineMap to a parallel NetCDF file.
virtual int IsConsistent (double dTolerance)
 Determine if the map is first-order accurate.
virtual int IsConservative (double dTolerance)
 Determine if the map is conservative.
virtual int IsMonotone (double dTolerance)
 Determine if the map is monotone.
const DataArray1D< double > & GetGlobalSourceAreas () const
 If we computed the reduction, get the vector representing the source areas for all entities in the mesh.
const DataArray1D< double > & GetGlobalTargetAreas () const
 If we computed the reduction, get the vector representing the target areas for all entities in the mesh.
moab::ErrorCode SetDOFmapTags (const std::string srcDofTagName, const std::string tgtDofTagName)
 Store the tag names associated with global DoF ids for source and target meshes.
moab::ErrorCode SetDOFmapAssociation (DiscretizationType srcType, bool isSrcContinuous, DataArray3D< int > *srcdataGLLNodes, DataArray3D< int > *srcdataGLLNodesSrc, DiscretizationType destType, bool isDestContinuous, DataArray3D< int > *tgtdataGLLNodes)
 Compute the association between the solution tag global DoF numbering and the local matrix numbering so that matvec operations can be performed consistently.
int GetSourceGlobalNDofs ()
 Get the number of total Degrees-Of-Freedom defined on the source mesh.
int GetDestinationGlobalNDofs ()
 Get the number of total Degrees-Of-Freedom defined on the destination mesh.
int GetSourceLocalNDofs ()
 Get the number of local Degrees-Of-Freedom defined on the source mesh.
int GetDestinationLocalNDofs ()
 Get the number of local Degrees-Of-Freedom defined on the destination mesh.
int GetSourceNDofsPerElement ()
 Get the number of Degrees-Of-Freedom per element on the source mesh.
int GetDestinationNDofsPerElement ()
 Get the number of Degrees-Of-Freedom per element on the destination mesh.
void SetSourceNDofsPerElement (int ns)
 Set the number of Degrees-Of-Freedom per element on the source mesh.
void SetDestinationNDofsPerElement (int nt)
int GetRowGlobalDoF (int localID) const
 Get the global Degrees-Of-Freedom ID on the destination mesh.
int GetIndexOfRowGlobalDoF (int globalRowDoF) const
 Get the index of globaRowDoF.
int GetColGlobalDoF (int localID) const
 Get the global Degrees-Of-Freedom ID on the source mesh.
int GetIndexOfColGlobalDoF (int globalColDoF) const
 Get the index of globaColDoF.
moab::ErrorCode ApplyWeights (std::vector< double > &srcVals, std::vector< double > &tgtVals, bool transpose=false)
 Apply the weight matrix onto the source vector provided as input, and return the column vector (solution projection) after the map application Compute: tgtVals = A(S->T) * , or if (transpose) tgtVals = [A(T->S)]^T * .
moab::ErrorCode ApplyWeights (moab::Tag srcSolutionTag, moab::Tag tgtSolutionTag, bool transpose=false)
 Apply the weight matrix onto the source vector (tag) provided as input, and return the column vector (solution projection) in a tag, after the map application Compute: tgtVals = A(S->T) * , or if (transpose) tgtVals = [A(T->S)]^T * .
moab::ErrorCode DefineAnalyticalSolution (moab::Tag &exactSolnTag, const std::string &solnName, Remapper::IntersectionContext ctx, sample_function testFunction, moab::Tag *clonedSolnTag=NULL, std::string cloneSolnName="")
 Define an analytical solution over the given (source or target) mesh, as specificed in the context. This routine will define a tag that is compatible with the specified discretization method type and order and sample the solution exactly using the analytical function provided by the user.
moab::ErrorCode ComputeMetrics (Remapper::IntersectionContext ctx, moab::Tag &exactTag, moab::Tag &approxTag, std::map< std::string, double > &metrics, bool verbose=true)
 Compute the error between a sampled (exact) solution and a projected solution in various error norms.
moab::ErrorCode fill_row_ids (std::vector< int > &ids_of_interest)
moab::ErrorCode fill_col_ids (std::vector< int > &ids_of_interest)
moab::ErrorCode set_col_dc_dofs (std::vector< int > &values_entities)
moab::ErrorCode set_row_dc_dofs (std::vector< int > &values_entities)
Private Member Functions
moab::ErrorCode LinearRemapNN_MOAB (bool use_GID_matching=false, bool strict_check=false)
 Compute the remapping weights as a permutation matrix that relates DoFs on the source mesh to DoFs on the target mesh.
void LinearRemapFVtoFV_Tempest_MOAB (int nOrder)
 Compute the remapping weights for a FV field defined on the source to a FV field defined on the target mesh.
void LinearRemapSE0_Tempest_MOAB (const DataArray3D< int > &dataGLLNodes, const DataArray3D< double > &dataGLLJacobian)
 Generate the OfflineMap for linear conserative element-average spectral element to element average remapping.
void LinearRemapSE4_Tempest_MOAB (const DataArray3D< int > &dataGLLNodes, const DataArray3D< double > &dataGLLJacobian, int nMonotoneType, bool fContinuousIn, bool fNoConservation)
 Generate the OfflineMap for cubic conserative element-average spectral element to element average remapping.
void LinearRemapFVtoGLL_MOAB (const DataArray3D< int > &dataGLLNodes, const DataArray3D< double > &dataGLLJacobian, const DataArray1D< double > &dataGLLNodalArea, int nOrder, int nMonotoneType, bool fContinuous, bool fNoConservation)
 Generate the OfflineMap for remapping from finite volumes to finite elements.
void LinearRemapGLLtoGLL2_MOAB (const DataArray3D< int > &dataGLLNodesIn, const DataArray3D< double > &dataGLLJacobianIn, const DataArray3D< int > &dataGLLNodesOut, const DataArray3D< double > &dataGLLJacobianOut, const DataArray1D< double > &dataNodalAreaOut, int nPin, int nPout, int nMonotoneType, bool fContinuousIn, bool fContinuousOut, bool fNoConservation)
 Generate the OfflineMap for remapping from finite elements to finite elements.
void LinearRemapGLLtoGLL2_Pointwise_MOAB (const DataArray3D< int > &dataGLLNodesIn, const DataArray3D< double > &dataGLLJacobianIn, const DataArray3D< int > &dataGLLNodesOut, const DataArray3D< double > &dataGLLJacobianOut, const DataArray1D< double > &dataNodalAreaOut, int nPin, int nPout, int nMonotoneType, bool fContinuousIn, bool fContinuousOut)
 Generate the OfflineMap for remapping from finite elements to finite elements (pointwise interpolation).
moab::ErrorCode WriteSCRIPMapFile (const std::string &strOutputFile)
 Copy the local matrix from Tempest SparseMatrix representation (ELL) to the parallel CSR Eigen Matrix for scalable application of matvec needed for projections.
moab::ErrorCode WriteHDF5MapFile (const std::string &filename)
 Parallel I/O with NetCDF to write out the SCRIP file from multiple processors.
void setup_sizes_dimensions ()
Private Attributes
moab::TempestRemapperm_remapper
 The fundamental remapping operator object.
moab::Interfacem_interface
 The reference to the moab::Core object that contains source/target and overlap sets.
moab::Tag m_dofTagSrc
 The original tag data and local to global DoF mapping to associate matrix values to solution.
moab::Tag m_dofTagDest
std::vector< unsigned > row_gdofmap
std::vector< unsigned > col_gdofmap
std::vector< unsigned > srccol_gdofmap
std::vector< int > row_dtoc_dofmap
std::vector< int > col_dtoc_dofmap
std::vector< int > srccol_dtoc_dofmap
std::map< int, int > rowMap
std::map< int, int > colMap
DataArray3D< int > dataGLLNodesSrc
DataArray3D< int > dataGLLNodesSrcCov
DataArray3D< int > dataGLLNodesDest
DiscretizationType m_srcDiscType
DiscretizationType m_destDiscType
int m_nTotDofs_Src
int m_nTotDofs_SrcCov
int m_nTotDofs_Dest
int m_nDofsPEl_Src
int m_nDofsPEl_Dest
DiscretizationType m_eInputType
DiscretizationType m_eOutputType
bool m_bConserved
int m_iMonotonicity
Mesh * m_meshInput
Mesh * m_meshInputCov
Mesh * m_meshOutput
Mesh * m_meshOverlap
bool is_parallel
bool is_root
int rank
int size
int root_proc
Detailed Description
Definition at line 48 of file TempestOnlineMap.hpp.
Member Typedef Documentation
typedef double( * moab::TempestOnlineMap::sample_function)(double, double)
Definition at line 347 of file TempestOnlineMap.hpp.
Member Enumeration Documentation
Enumerator:
Definition at line 64 of file TempestOnlineMap.hpp.
Definition at line 55 of file TempestOnlineMap.cpp.
References moab::Remapper::get_interface(), moab::TempestRemapper::GetCoveringMesh(), moab::TempestRemapper::GetMesh(), is_parallel, is_root, m_interface, m_meshInput, m_meshInputCov, m_meshOutput, m_meshOverlap, m_remapper, moab::Remapper::OverlapMesh, rank, root_proc, setup_sizes_dimensions(), size, moab::Remapper::SourceMesh, and moab::Remapper::TargetMesh.
        : OfflineMap(), m_remapper( remapper )
    // Get the references for the MOAB core objects
    m_interface = m_remapper->get_interface();
#ifdef MOAB_HAVE_MPI
    m_pcomm = m_remapper->get_parallel_communicator();
#endif
    // Update the references to the meshes
    m_meshInput    = remapper->GetMesh( moab::Remapper::SourceMesh );
    m_meshInputCov = remapper->GetCoveringMesh();
    m_meshOutput   = remapper->GetMesh( moab::Remapper::TargetMesh );
    m_meshOverlap  = remapper->GetMesh( moab::Remapper::OverlapMesh );
    is_parallel = false;
    is_root     = true;
    rank        = 0;
    root_proc   = rank;
    size        = 1;
    int flagInit;
    MPI_Initialized( &flagInit );
    if( flagInit )
        is_parallel = true;
        assert( m_pcomm != NULL );
        rank    = m_pcomm->rank();
        size    = m_pcomm->size();
        is_root = ( rank == 0 );
#endif
    // Compute and store the total number of source and target DoFs corresponding
    // to number of rows and columns in the mapping.
    // Initialize dimension information from file
    this->setup_sizes_dimensions();
    // Build a matrix of source and target discretization so that we know how to assign
    // the global DoFs in parallel for the mapping weights
    // For example, FV->FV: rows X cols = faces_source X faces_target
Definition at line 145 of file TempestOnlineMap.cpp.
    m_interface = NULL;
    m_pcomm = NULL;
#endif
    m_meshInput   = NULL;
    m_meshOutput  = NULL;
    m_meshOverlap = NULL;
Member Function Documentation
moab::ErrorCode moab::TempestOnlineMap::ApplyWeights ( std::vector< double > &  srcVals,
std::vector< double > &  tgtVals,
bool  transpose = false
Referenced by main().
moab::ErrorCode moab::TempestOnlineMap::ApplyWeights ( moab::Tag  srcSolutionTag,
Definition at line 1700 of file TempestOnlineMap.cpp.
References moab::Remapper::CoveringMesh, ErrorCode, MB_CHK_SET_ERR, MB_SUCCESS, moab::Range::size(), and moab::Remapper::TargetMesh.
    moab::ErrorCode rval;
    std::vector< double > solSTagVals;
    std::vector< double > solTTagVals;
    moab::Range sents, tents;
    if( m_remapper->point_cloud_source || m_remapper->point_cloud_target )
        if( m_remapper->point_cloud_source )
            moab::Range& covSrcEnts = m_remapper->GetMeshVertices( moab::Remapper::CoveringMesh );
            solSTagVals.resize( covSrcEnts.size(), -1.0 );
            sents = covSrcEnts;
        else
            moab::Range& covSrcEnts = m_remapper->GetMeshEntities( moab::Remapper::CoveringMesh );
            solSTagVals.resize( covSrcEnts.size() * this->GetSourceNDofsPerElement() * this->GetSourceNDofsPerElement(),
                                -1.0 );
            sents = covSrcEnts;
        if( m_remapper->point_cloud_target )
            moab::Range& tgtEnts = m_remapper->GetMeshVertices( moab::Remapper::TargetMesh );
            solTTagVals.resize( tgtEnts.size(), -1.0 );
            tents = tgtEnts;
        else
            moab::Range& tgtEnts = m_remapper->GetMeshEntities( moab::Remapper::TargetMesh );
            solTTagVals.resize(
                tgtEnts.size() * this->GetDestinationNDofsPerElement() * this->GetDestinationNDofsPerElement(), -1.0 );
            tents = tgtEnts;
    else
                            -1.0 );
        solTTagVals.resize(
        sents = covSrcEnts;
        tents = tgtEnts;
    // The tag data is np*np*n_el_src
    rval = m_interface->tag_get_data( srcSolutionTag, sents, &solSTagVals[0] );MB_CHK_SET_ERR( rval, "Getting local tag data failed" );
    // Compute the application of weights on the suorce solution data and store it in the
    // destination solution vector data Optionally, can also perform the transpose application of
    // the weight matrix. Set the 3rd argument to true if this is needed
    rval = this->ApplyWeights( solSTagVals, solTTagVals, transpose );MB_CHK_SET_ERR( rval, "Applying remap operator onto source vector data failed" );
    // The tag data is np*np*n_el_dest
    rval = m_interface->tag_set_data( tgtSolutionTag, tents, &solTTagVals[0] );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
    return moab::MB_SUCCESS;
moab::ErrorCode moab::TempestOnlineMap::ComputeMetrics ( Remapper::IntersectionContext  ctx,
moab::Tag exactTag,
moab::Tag approxTag,
std::map< std::string, double > &  metrics,
bool  verbose = true
Definition at line 2128 of file TempestOnlineMap.cpp.
References entities, moab::error(), ErrorCode, MB_CHK_ERR, MB_SUCCESS, moab::Range::size(), moab::Remapper::SourceMesh, and moab::Remapper::TargetMesh.
    const bool outputEnabled = ( is_root );
    int discOrder;
    DiscretizationType discMethod;
    moab::EntityHandle meshset;
    moab::Range entities;
    Mesh* trmesh;
    switch( ctx )
        case Remapper::SourceMesh:
            meshset    = m_remapper->m_covering_source_set;
            trmesh     = m_remapper->m_covering_source;
            entities   = ( m_remapper->point_cloud_source ? m_remapper->m_covering_source_vertices
                                                          : m_remapper->m_covering_source_entities );
            discOrder  = m_nDofsPEl_Src;
            discMethod = m_eInputType;
            break;
        case Remapper::TargetMesh:
            meshset = m_remapper->m_target_set;
            trmesh  = m_remapper->m_target;
            entities =
                ( m_remapper->point_cloud_target ? m_remapper->m_target_vertices : m_remapper->m_target_entities );
            discOrder  = m_nDofsPEl_Dest;
            discMethod = m_eOutputType;
            break;
        default:
            if( outputEnabled )
                std::cout << "Invalid context specified for defining an analytical solution tag" << std::endl;
            return moab::MB_FAILURE;
    // Let us create teh solution tag with appropriate information for name, discretization order
    // (DoF space)
    std::string exactTagName, projTagName;
    const int ntotsize = entities.size() * discOrder * discOrder;
    int ntotsize_glob  = 0;
    std::vector< double > exactSolution( ntotsize, 0.0 ), projSolution( ntotsize, 0.0 );
    rval = m_interface->tag_get_name( exactTag, exactTagName );MB_CHK_ERR( rval );
    rval = m_interface->tag_get_data( exactTag, entities, &exactSolution[0] );MB_CHK_ERR( rval );
    rval = m_interface->tag_get_name( approxTag, projTagName );MB_CHK_ERR( rval );
    rval = m_interface->tag_get_data( approxTag, entities, &projSolution[0] );MB_CHK_ERR( rval );
    std::vector< double > errnorms( 3, 0.0 ), globerrnorms( 3, 0.0 );  //  L1Err, L2Err, LinfErr
    for( int i = 0; i < ntotsize; ++i )
        const double error = fabs( exactSolution[i] - projSolution[i] );
        errnorms[0] += error;
        errnorms[1] += error * error;
        errnorms[2] = ( error > errnorms[2] ? error : errnorms[2] );
    if( m_pcomm )
        MPI_Reduce( &ntotsize, &ntotsize_glob, 1, MPI_INT, MPI_SUM, 0, m_pcomm->comm() );
        MPI_Reduce( &errnorms[0], &globerrnorms[0], 2, MPI_DOUBLE, MPI_SUM, 0, m_pcomm->comm() );
        MPI_Reduce( &errnorms[2], &globerrnorms[2], 1, MPI_DOUBLE, MPI_MAX, 0, m_pcomm->comm() );
#else
    ntotsize_glob = ntotsize;
    globerrnorms = errnorms;
#endif
    globerrnorms[0] = ( globerrnorms[0] / ntotsize_glob );
    globerrnorms[1] = std::sqrt( globerrnorms[1] / ntotsize_glob );
    metrics.clear();
    metrics["L1Error"]   = globerrnorms[0];
    metrics["L2Error"]   = globerrnorms[1];
    metrics["LinfError"] = globerrnorms[2];
    if( verbose && is_root )
        std::cout << "Error metrics when comparing " << projTagName << " against " << exactTagName << std::endl;
        std::cout << "\t L_1 error   = " << globerrnorms[0] << std::endl;
        std::cout << "\t L_2 error   = " << globerrnorms[1] << std::endl;
        std::cout << "\t L_inf error = " << globerrnorms[2] << std::endl;
moab::ErrorCode moab::TempestOnlineMap::DefineAnalyticalSolution ( moab::Tag exactSolnTag,
const std::string &  solnName,
moab::Tag clonedSolnTag = NULL,
std::string  cloneSolnName = ""
Definition at line 1766 of file TempestOnlineMap.cpp.
References entities, ErrorCode, MB_CHK_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, moab::Range::size(), moab::Remapper::SourceMesh, and moab::Remapper::TargetMesh.
    int discOrder;
    Mesh* trmesh;
    switch( ctx )
            break;
            entities =
            break;
        default:
            if( outputEnabled )
    // (DoF space)
    rval = m_interface->tag_get_handle( solnName.c_str(), discOrder * discOrder, MB_TYPE_DOUBLE, solnTag,
                                        MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_ERR( rval );
    if( clonedSolnTag != NULL )
        if( cloneSolnName.size() == 0 )
            cloneSolnName = solnName + std::string( "Cloned" );
        rval = m_interface->tag_get_handle( cloneSolnName.c_str(), discOrder * discOrder, MB_TYPE_DOUBLE,
                                            *clonedSolnTag, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_ERR( rval );
    // Triangular quadrature rule
    const int TriQuadratureOrder = 10;
    if( outputEnabled ) std::cout << "Using triangular quadrature of order " << TriQuadratureOrder << std::endl;
    TriangularQuadratureRule triquadrule( TriQuadratureOrder );
    const int TriQuadraturePoints = triquadrule.GetPoints();
    const DataArray2D< double >& TriQuadratureG = triquadrule.GetG();
    const DataArray1D< double >& TriQuadratureW = triquadrule.GetW();
    // Output data
    DataArray1D< double > dVar;
    DataArray1D< double > dVarMB;  // re-arranged local MOAB vector
    // Nodal geometric area
    DataArray1D< double > dNodeArea;
    // Calculate element areas
    // trmesh->CalculateFaceAreas(fContainsConcaveFaces);
    if( discMethod == DiscretizationType_CGLL || discMethod == DiscretizationType_DGLL )
        /* Get the spectral points and sample the functionals accordingly */
        const bool fGLL          = true;
        const bool fGLLIntegrate = false;
        // Generate grid metadata
        DataArray3D< int > dataGLLNodes;
        DataArray3D< double > dataGLLJacobian;
        GenerateMetaData( *trmesh, discOrder, false, dataGLLNodes, dataGLLJacobian );
        // Number of elements
        int nElements = trmesh->faces.size();
        // Verify all elements are quadrilaterals
        for( int k = 0; k < nElements; k++ )
            const Face& face = trmesh->faces[k];
            if( face.edges.size() != 4 )
                _EXCEPTIONT( "Non-quadrilateral face detected; "
                             "incompatible with --gll" );
        // Number of unique nodes
        int iMaxNode = 0;
        for( int i = 0; i < discOrder; i++ )
            for( int j = 0; j < discOrder; j++ )
                    if( dataGLLNodes[i][j][k] > iMaxNode )
                        iMaxNode = dataGLLNodes[i][j][k];
        // Get Gauss-Lobatto quadrature nodes
        DataArray1D< double > dG;
        DataArray1D< double > dW;
        GaussLobattoQuadrature::GetPoints( discOrder, 0.0, 1.0, dG, dW );
        // Get Gauss quadrature nodes
        const int nGaussP = 10;
        DataArray1D< double > dGaussG;
        DataArray1D< double > dGaussW;
        GaussQuadrature::GetPoints( nGaussP, 0.0, 1.0, dGaussG, dGaussW );
        // Allocate data
        dVar.Allocate( iMaxNode );
        dVarMB.Allocate( discOrder * discOrder * nElements );
        dNodeArea.Allocate( iMaxNode );
        // Sample data
            // Sample data at GLL nodes
            if( fGLL )
                        // Apply local map
                        Node node;
                        Node dDx1G;
                        Node dDx2G;
                        ApplyLocalMap( face, trmesh->nodes, dG[i], dG[j], node, dDx1G, dDx2G );
                        // Sample data at this point
                        double dNodeLon = atan2( node.y, node.x );
                        if( dNodeLon < 0.0 )
                            dNodeLon += 2.0 * M_PI;
                        double dNodeLat = asin( node.z );
                        double dSample = ( *testFunction )( dNodeLon, dNodeLat );
                        dVar[dataGLLNodes[j][i][k] - 1] = dSample;
                // High-order Gaussian integration over basis function
            else
                DataArray2D< double > dCoeff( discOrder, discOrder );
                for( int p = 0; p < nGaussP; p++ )
                    for( int q = 0; q < nGaussP; q++ )
                        // Apply local map
                        Node node;
                        Node dDx1G;
                        Node dDx2G;
                        ApplyLocalMap( face, trmesh->nodes, dGaussG[p], dGaussG[q], node, dDx1G, dDx2G );
                        // Cross product gives local Jacobian
                        Node nodeCross = CrossProduct( dDx1G, dDx2G );
                        double dJacobian =
                            sqrt( nodeCross.x * nodeCross.x + nodeCross.y * nodeCross.y + nodeCross.z * nodeCross.z );
                        // Find components of quadrature point in basis
                        // of the first Face
                        SampleGLLFiniteElement( 0, discOrder, dGaussG[p], dGaussG[q], dCoeff );
                        // Integrate
                                double dNodalArea = dCoeff[i][j] * dGaussW[p] * dGaussW[q] * dJacobian;
                                dVar[dataGLLNodes[i][j][k] - 1] += dSample * dNodalArea;
                                dNodeArea[dataGLLNodes[i][j][k] - 1] += dNodalArea;
        // Divide by area
        if( fGLLIntegrate )
            for( size_t i = 0; i < dVar.GetRows(); i++ )
                dVar[i] /= dNodeArea[i];
        // Let us rearrange the data based on DoF ID specification
        if( ctx == Remapper::SourceMesh )
            for( unsigned j = 0; j < entities.size(); j++ )
                for( int p = 0; p < discOrder; p++ )
                    for( int q = 0; q < discOrder; q++ )
                        const int offsetDOF = j * discOrder * discOrder + p * discOrder + q;
                        dVarMB[offsetDOF]   = dVar[col_dtoc_dofmap[offsetDOF]];
        else
                        dVarMB[offsetDOF]   = dVar[row_dtoc_dofmap[offsetDOF]];
        // Set the tag data
        rval = m_interface->tag_set_data( solnTag, entities, &dVarMB[0] );MB_CHK_ERR( rval );
    else
        // assert( discOrder == 1 );
        if( discMethod == DiscretizationType_FV )
            /* Compute an element-wise integral to store the sampled solution based on Quadrature
             * rules */
            // Resize the array
            dVar.Allocate( trmesh->faces.size() );
            std::vector< Node >& nodes = trmesh->nodes;
            // Loop through all Faces
            for( size_t i = 0; i < trmesh->faces.size(); i++ )
                const Face& face = trmesh->faces[i];
                // Loop through all sub-triangles
                for( size_t j = 0; j < face.edges.size() - 2; j++ )
                    const Node& node0 = nodes[face[0]];
                    const Node& node1 = nodes[face[j + 1]];
                    const Node& node2 = nodes[face[j + 2]];
                    // Triangle area
                    Face faceTri( 3 );
                    faceTri.SetNode( 0, face[0] );
                    faceTri.SetNode( 1, face[j + 1] );
                    faceTri.SetNode( 2, face[j + 2] );
                    double dTriangleArea = CalculateFaceArea( faceTri, nodes );
                    // Calculate the element average
                    double dTotalSample = 0.0;
                    // Loop through all quadrature points
                    for( int k = 0; k < TriQuadraturePoints; k++ )
                        Node node( TriQuadratureG[k][0] * node0.x + TriQuadratureG[k][1] * node1.x +
                                       TriQuadratureG[k][2] * node2.x,
                                   TriQuadratureG[k][0] * node0.y + TriQuadratureG[k][1] * node1.y +
                                       TriQuadratureG[k][2] * node2.y,
                                   TriQuadratureG[k][0] * node0.z + TriQuadratureG[k][1] * node1.z +
                                       TriQuadratureG[k][2] * node2.z );
                        double dMagnitude = node.Magnitude();
                        node.x /= dMagnitude;
                        node.y /= dMagnitude;
                        node.z /= dMagnitude;
                        double dLon = atan2( node.y, node.x );
                        if( dLon < 0.0 )
                            dLon += 2.0 * M_PI;
                        double dLat = asin( node.z );
                        double dSample = ( *testFunction )( dLon, dLat );
                        dTotalSample += dSample * TriQuadratureW[k] * dTriangleArea;
                    dVar[i] += dTotalSample / trmesh->vecFaceArea[i];
            rval = m_interface->tag_set_data( solnTag, entities, &dVar[0] );MB_CHK_ERR( rval );
        else /* discMethod == DiscretizationType_PCLOUD */
            /* Get the coordinates of the vertices and sample the functionals accordingly */
            // Resize the array
            dVar.Allocate( nodes.size() );
            for( size_t j = 0; j < nodes.size(); j++ )
                Node& node        = nodes[j];
                if( dLon < 0.0 )
                    dLon += 2.0 * M_PI;
                dVar[j]        = dSample;
moab::ErrorCode moab::TempestOnlineMap::fill_col_ids ( std::vector< int > &  ids_of_interest) [inline]
Definition at line 382 of file TempestOnlineMap.hpp.
References col_gdofmap, and MB_SUCCESS.
        ids_of_interest.reserve( col_gdofmap.size() );
        // need to add 1
        for( auto it = col_gdofmap.begin(); it != col_gdofmap.end(); it++ )
            ids_of_interest.push_back( *it + 1 );
moab::ErrorCode moab::TempestOnlineMap::fill_row_ids ( std::vector< int > &  ids_of_interest) [inline]
Definition at line 372 of file TempestOnlineMap.hpp.
References MB_SUCCESS, and row_gdofmap.
        ids_of_interest.reserve( row_gdofmap.size() );
        // need to add 1
        for( auto it = row_gdofmap.begin(); it != row_gdofmap.end(); it++ )
moab::ErrorCode moab::TempestOnlineMap::GenerateRemappingWeights ( std::string  strInputType,
const GenerateOfflineMapAlgorithmOptions &  mapOptions,
const std::string &  srcDofTagName = "GLOBAL_ID",
const std::string &  tgtDofTagName = "GLOBAL_ID"
the tag should be created already in the e3sm workflow; if not, create it here
Definition at line 731 of file TempestOnlineMap.cpp.
References dbgprint, moab::error(), ErrorCode, MB_ALREADY_ALLOCATED, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TAG_EXCL, MB_TYPE_DOUBLE, moab::Remapper::OverlapMesh, moab::DebugOutput::printf(), rank, moab::DebugOutput::set_prefix(), and size.
    NcError error( NcError::silent_nonfatal );
    moab::DebugOutput dbgprint( std::cout, rank, 0 );
    dbgprint.set_prefix( "[TempestOnlineMap]: " );
    const bool m_bPointCloudSource = ( m_remapper->point_cloud_source );
    const bool m_bPointCloudTarget = ( m_remapper->point_cloud_target );
    const bool m_bPointCloud       = m_bPointCloudSource || m_bPointCloudTarget;
    try
        // Check command line parameters (data type arguments)
        STLStringHelper::ToLower( strInputType );
        STLStringHelper::ToLower( strOutputType );
        DiscretizationType eInputType;
        DiscretizationType eOutputType;
        if( strInputType == "fv" )
            eInputType = DiscretizationType_FV;
        else if( strInputType == "cgll" )
            eInputType = DiscretizationType_CGLL;
        else if( strInputType == "dgll" )
            eInputType = DiscretizationType_DGLL;
        else if( strInputType == "pcloud" )
            eInputType = DiscretizationType_PCLOUD;
        else
            _EXCEPTION1( "Invalid \"in_type\" value (%s), expected [fv|cgll|dgll]", strInputType.c_str() );
        if( strOutputType == "fv" )
            eOutputType = DiscretizationType_FV;
        else if( strOutputType == "cgll" )
            eOutputType = DiscretizationType_CGLL;
        else if( strOutputType == "dgll" )
            eOutputType = DiscretizationType_DGLL;
        else if( strOutputType == "pcloud" )
            eOutputType = DiscretizationType_PCLOUD;
        else
            _EXCEPTION1( "Invalid \"out_type\" value (%s), expected [fv|cgll|dgll]", strOutputType.c_str() );
        // set all required input params
        m_bConserved  = !mapOptions.fNoConservation;
        m_eInputType  = eInputType;
        m_eOutputType = eOutputType;
        // Method flags
        std::string strMapAlgorithm( "" );
        int nMonotoneType    = ( mapOptions.fMonotone ) ? ( 1 ) : ( 0 );
        // Make an index of method arguments
        std::set< std::string > setMethodStrings;
            int iLast = 0;
            for( size_t i = 0; i <= mapOptions.strMethod.length(); i++ )
                if( ( i == mapOptions.strMethod.length() ) || ( mapOptions.strMethod[i] == ';' ) )
                    std::string strMethodString = mapOptions.strMethod.substr( iLast, i - iLast );
                    STLStringHelper::RemoveWhitespaceInPlace( strMethodString );
                    if( strMethodString.length() > 0 )
                        setMethodStrings.insert( strMethodString );
                    iLast = i + 1;
        for( auto it : setMethodStrings )
            // Piecewise constant monotonicity
            if( it == "mono2" )
                if( nMonotoneType != 0 )
                    _EXCEPTIONT( "Multiple monotonicity specifications found (--mono) or (--method \"mono#\")" );
                if( ( m_eInputType == DiscretizationType_FV ) && ( m_eOutputType == DiscretizationType_FV ) )
                    _EXCEPTIONT( "--method \"mono2\" is only used when remapping to/from CGLL or DGLL grids" );
                nMonotoneType = 2;
                // Piecewise linear monotonicity
            else if( it == "mono3" )
                    _EXCEPTIONT( "--method \"mono3\" is only used when remapping to/from CGLL or DGLL grids" );
                nMonotoneType = 3;
                // Volumetric remapping from FV to GLL
            else if( it == "volumetric" )
                if( ( m_eInputType != DiscretizationType_FV ) || ( m_eOutputType == DiscretizationType_FV ) )
                    _EXCEPTIONT( "--method \"volumetric\" may only be used for FV->CGLL or FV->DGLL remapping" );
                strMapAlgorithm = "volumetric";
                // Inverse distance mapping
            else if( it == "invdist" )
                if( ( m_eInputType != DiscretizationType_FV ) || ( m_eOutputType != DiscretizationType_FV ) )
                    _EXCEPTIONT( "--method \"invdist\" may only be used for FV->FV remapping" );
                strMapAlgorithm = "invdist";
                // Delaunay triangulation mapping
            else if( it == "delaunay" )
                    _EXCEPTIONT( "--method \"delaunay\" may only be used for FV->FV remapping" );
                strMapAlgorithm = "delaunay";
                // Bilinear
            else if( it == "bilin" )
                    _EXCEPTIONT( "--method \"bilin\" may only be used for FV->FV remapping" );
                strMapAlgorithm = "fvbilin";
                // Integrated bilinear (same as mono3 when source grid is CGLL/DGLL)
            else if( it == "intbilin" )
                if( m_eOutputType != DiscretizationType_FV )
                    _EXCEPTIONT( "--method \"intbilin\" may only be used when mapping to FV." );
                if( m_eInputType == DiscretizationType_FV )
                    strMapAlgorithm = "fvintbilin";
                else
                    strMapAlgorithm = "mono3";
                // Integrated bilinear with generalized Barycentric coordinates
            else if( it == "intbilingb" )
                    _EXCEPTIONT( "--method \"intbilingb\" may only be used for FV->FV remapping" );
                strMapAlgorithm = "fvintbilingb";
            else
                _EXCEPTION1( "Invalid --method argument \"%s\"", it.c_str() );
        m_nDofsPEl_Src =
            ( m_eInputType == DiscretizationType_FV || m_eInputType == DiscretizationType_PCLOUD ? 1
        : mapOptions.nPin );
        m_nDofsPEl_Dest =
            ( m_eOutputType == DiscretizationType_FV || m_eOutputType == DiscretizationType_PCLOUD ? 1
        : mapOptions.nPout );
        rval = SetDOFmapTags( srcDofTagName, tgtDofTagName );MB_CHK_ERR( rval );
        ///   the tag should be created already in the e3sm workflow; if not, create it here
        Tag areaTag;
        rval = m_interface->tag_get_handle( "aream", 1, MB_TYPE_DOUBLE, areaTag,
                                             MB_TAG_DENSE |  MB_TAG_EXCL | MB_TAG_CREAT );
        if ( MB_ALREADY_ALLOCATED == rval )
            if( is_root ) dbgprint.printf( 0, "aream tag already defined \n" );
        double dTotalAreaInput = 0.0, dTotalAreaOutput = 0.0;
        if( !m_bPointCloudSource )
            // Calculate Input Mesh Face areas
            if( is_root ) dbgprint.printf( 0, "Calculating input mesh Face areas\n" );
            double dTotalAreaInput_loc = m_meshInput->CalculateFaceAreas( mapOptions.fSourceConcave );
            rval = m_interface->tag_set_data( areaTag, m_remapper->m_source_entities, m_meshInput->vecFaceArea );MB_CHK_ERR( rval );
            dTotalAreaInput            = dTotalAreaInput_loc;
            if( m_pcomm )
                MPI_Reduce( &dTotalAreaInput_loc, &dTotalAreaInput, 1, MPI_DOUBLE, MPI_SUM, 0, m_pcomm->comm() );
#endif
            if( is_root ) dbgprint.printf( 0, "Input Mesh Geometric Area: %1.15e\n", dTotalAreaInput );
            // Input mesh areas
            m_meshInputCov->CalculateFaceAreas( mapOptions.fSourceConcave );
            // we do not need to set the area on coverage mesh, only on source and target meshes
            // rval = m_interface->tag_set_data( areaTag, m_remapper->m_covering_source_entities, m_meshInputCov->vecFaceArea );MB_CHK_ERR( rval );
        if( !m_bPointCloudTarget )
            // Calculate Output Mesh Face areas
            if( is_root ) dbgprint.printf( 0, "Calculating output mesh Face areas\n" );
            double dTotalAreaOutput_loc = m_meshOutput->CalculateFaceAreas( mapOptions.fTargetConcave );
            dTotalAreaOutput            = dTotalAreaOutput_loc;
            if( m_pcomm )
                MPI_Reduce( &dTotalAreaOutput_loc, &dTotalAreaOutput, 1, MPI_DOUBLE, MPI_SUM, 0, m_pcomm->comm() );
#endif
            if( is_root ) dbgprint.printf( 0, "Output Mesh Geometric Area: %1.15e\n", dTotalAreaOutput );
            rval = m_interface->tag_set_data( areaTag, m_remapper->m_target_entities, m_meshOutput->vecFaceArea );MB_CHK_ERR( rval );
        if( !m_bPointCloud )
            // Verify that overlap mesh is in the correct order, only if size == 1
            if( 1 == size )
                int ixSourceFaceMax = ( -1 );
                int ixTargetFaceMax = ( -1 );
                if( m_meshOverlap->vecSourceFaceIx.size() != m_meshOverlap->vecTargetFaceIx.size() )
                    _EXCEPTIONT( "Invalid overlap mesh:\n"
                                 "    Possible mesh file corruption?" );
                for( unsigned i = 0; i < m_meshOverlap->faces.size(); i++ )
                    if( m_meshOverlap->vecSourceFaceIx[i] + 1 > ixSourceFaceMax )
                        ixSourceFaceMax = m_meshOverlap->vecSourceFaceIx[i] + 1;
                    if( m_meshOverlap->vecTargetFaceIx[i] + 1 > ixTargetFaceMax )
                        ixTargetFaceMax = m_meshOverlap->vecTargetFaceIx[i] + 1;
                // Check for forward correspondence in overlap mesh
                if( m_meshInputCov->faces.size() - ixSourceFaceMax == 0 )
                    if( is_root ) dbgprint.printf( 0, "Overlap mesh forward correspondence found\n" );
                else if( m_meshOutput->faces.size() - ixSourceFaceMax == 0 )
                {  // Check for reverse correspondence in overlap mesh
                    if( is_root ) dbgprint.printf( 0, "Overlap mesh reverse correspondence found (reversing)\n" );
                    // Reorder overlap mesh
                    m_meshOverlap->ExchangeFirstAndSecondMesh();
                else
                {  // No correspondence found
                    _EXCEPTION4( "Invalid overlap mesh:\n    No correspondence found with input and output meshes "
                                 "(%i,%i) vs (%i,%i)",
                                 m_meshInputCov->faces.size(), m_meshOutput->faces.size(), ixSourceFaceMax,
                                 ixTargetFaceMax );
            // Calculate Face areas
            if( is_root ) dbgprint.printf( 0, "Calculating overlap mesh Face areas\n" );
            double dTotalAreaOverlap_loc = m_meshOverlap->CalculateFaceAreas( false );
            double dTotalAreaOverlap     = dTotalAreaOverlap_loc;
            if( m_pcomm )
                MPI_Reduce( &dTotalAreaOverlap_loc, &dTotalAreaOverlap, 1, MPI_DOUBLE, MPI_SUM, 0, m_pcomm->comm() );
#endif
            if( is_root ) dbgprint.printf( 0, "Overlap Mesh Area: %1.15e\n", dTotalAreaOverlap );
            // Correct areas to match the areas calculated in the overlap mesh
            // if (fCorrectAreas) // In MOAB-TempestRemap, we will always keep this to be true
                if( is_root ) dbgprint.printf( 0, "Correcting source/target areas to overlap mesh areas\n" );
                DataArray1D< double > dSourceArea( m_meshInputCov->faces.size() );
                DataArray1D< double > dTargetArea( m_meshOutput->faces.size() );
                assert( m_meshOverlap->vecSourceFaceIx.size() == m_meshOverlap->faces.size() );
                assert( m_meshOverlap->vecTargetFaceIx.size() == m_meshOverlap->faces.size() );
                assert( m_meshOverlap->vecFaceArea.GetRows() == m_meshOverlap->faces.size() );
                assert( m_meshInputCov->vecFaceArea.GetRows() == m_meshInputCov->faces.size() );
                assert( m_meshOutput->vecFaceArea.GetRows() == m_meshOutput->faces.size() );
                for( size_t i = 0; i < m_meshOverlap->faces.size(); i++ )
                    if( m_meshOverlap->vecSourceFaceIx[i] < 0 || m_meshOverlap->vecTargetFaceIx[i] < 0 )
                        continue;  // skip this cell since it is ghosted
                    // let us recompute the source/target areas based on overlap mesh areas
                    assert( static_cast< size_t >( m_meshOverlap->vecSourceFaceIx[i] ) < m_meshInputCov->faces.size() );
                    dSourceArea[m_meshOverlap->vecSourceFaceIx[i]] += m_meshOverlap->vecFaceArea[i];
                    assert( static_cast< size_t >( m_meshOverlap->vecTargetFaceIx[i] ) < m_meshOutput->faces.size() );
                    dTargetArea[m_meshOverlap->vecTargetFaceIx[i]] += m_meshOverlap->vecFaceArea[i];
                for( size_t i = 0; i < m_meshInputCov->faces.size(); i++ )
                    if( fabs( dSourceArea[i] - m_meshInputCov->vecFaceArea[i] ) < 1.0e-10 )
                        m_meshInputCov->vecFaceArea[i] = dSourceArea[i];
                for( size_t i = 0; i < m_meshOutput->faces.size(); i++ )
                    if( fabs( dTargetArea[i] - m_meshOutput->vecFaceArea[i] ) < 1.0e-10 )
                        m_meshOutput->vecFaceArea[i] = dTargetArea[i];
            // Set source mesh areas in map
            if( !m_bPointCloudSource && eInputType == DiscretizationType_FV )
                this->SetSourceAreas( m_meshInputCov->vecFaceArea );
                if( m_meshInputCov->vecMask.size() )
                    this->SetSourceMask( m_meshInputCov->vecMask );
            // Set target mesh areas in map
            if( !m_bPointCloudTarget && eOutputType == DiscretizationType_FV )
                this->SetTargetAreas( m_meshOutput->vecFaceArea );
                if( m_meshOutput->vecMask.size() )
                    this->SetTargetMask( m_meshOutput->vecMask );
                // Recalculate input mesh area from overlap mesh
                if (fabs(dTotalAreaOverlap - dTotalAreaInput) > 1.0e-10) {
                    dbgprint.printf(0, "Overlap mesh only covers a sub-area of the sphere\n");
                    dbgprint.printf(0, "Recalculating source mesh areas\n");
                    dTotalAreaInput = m_meshInput->CalculateFaceAreasFromOverlap(m_meshOverlap);
                    dbgprint.printf(0, "New Input Mesh Geometric Area: %1.15e\n", dTotalAreaInput);
        // Finite volume input / Finite volume output
        if( ( eInputType == DiscretizationType_FV ) && ( eOutputType == DiscretizationType_FV ) )
            // Generate reverse node array and edge map
            if( m_meshInputCov->revnodearray.size() == 0 ) m_meshInputCov->ConstructReverseNodeArray();
            if( m_meshInputCov->edgemap.size() == 0 ) m_meshInputCov->ConstructEdgeMap( false );
            // Initialize coordinates for map
            this->InitializeSourceCoordinatesFromMeshFV( *m_meshInputCov );
            this->InitializeTargetCoordinatesFromMeshFV( *m_meshOutput );
            // Finite volume input / Finite element output
            rval = this->SetDOFmapAssociation( eInputType, false, NULL, NULL, eOutputType, false, NULL );MB_CHK_ERR( rval );
            // Construct remap for FV-FV
            if( is_root ) dbgprint.printf( 0, "Calculating remap weights\n" );
            // Construct OfflineMap
            if( strMapAlgorithm == "invdist" )
                if( is_root ) AnnounceStartBlock( "Calculating map (invdist)" );
                LinearRemapFVtoFVInvDist( *m_meshInputCov, *m_meshOutput, *m_meshOverlap, *this );
            else if( strMapAlgorithm == "delaunay" )
                if( is_root ) AnnounceStartBlock( "Calculating map (delaunay)" );
                LinearRemapTriangulation( *m_meshInputCov, *m_meshOutput, *m_meshOverlap, *this );
            else if( strMapAlgorithm == "fvintbilin" )
                if( is_root ) AnnounceStartBlock( "Calculating map (intbilin)" );
                LinearRemapIntegratedBilinear( *m_meshInputCov, *m_meshOutput, *m_meshOverlap, *this );
            else if( strMapAlgorithm == "fvintbilingb" )
                if( is_root ) AnnounceStartBlock( "Calculating map (intbilingb)" );
                LinearRemapIntegratedGeneralizedBarycentric( *m_meshInputCov, *m_meshOutput, *m_meshOverlap, *this );
            else if( strMapAlgorithm == "fvbilin" )
                if( is_root ) AnnounceStartBlock( "Calculating map (bilin)" );
                LinearRemapBilinear( *m_meshInputCov, *m_meshOutput, *m_meshOverlap, *this );
            else
                if( is_root ) AnnounceStartBlock( "Calculating map (default)" );
                // LinearRemapFVtoFV( *m_meshInputCov, *m_meshOutput, *m_meshOverlap,
                //                   ( mapOptions.fMonotone ) ? ( 1 ) : ( mapOptions.nPin ), *this );
                LinearRemapFVtoFV_Tempest_MOAB( ( mapOptions.fMonotone ? 1 : mapOptions.nPin ) );
        else if( eInputType == DiscretizationType_FV )
            if( is_root ) dbgprint.printf( 0, "Generating output mesh meta data\n" );
            double dNumericalArea_loc = GenerateMetaData( *m_meshOutput, mapOptions.nPout, mapOptions.fNoBubble,
                                                          dataGLLNodesDest, dataGLLJacobian );
            double dNumericalArea = dNumericalArea_loc;
            if( m_pcomm )
                MPI_Reduce( &dNumericalArea_loc, &dNumericalArea, 1, MPI_DOUBLE, MPI_SUM, 0, m_pcomm->comm() );
#endif
            if( is_root ) dbgprint.printf( 0, "Output Mesh Numerical Area: %1.15e\n", dNumericalArea );
            this->InitializeTargetCoordinatesFromMeshFE( *m_meshOutput, mapOptions.nPout, dataGLLNodesDest );
            // Generate the continuous Jacobian
            bool fContinuous = ( eOutputType == DiscretizationType_CGLL );
            if( eOutputType == DiscretizationType_CGLL )
                GenerateUniqueJacobian( dataGLLNodesDest, dataGLLJacobian, this->GetTargetAreas() );
            else
                GenerateDiscontinuousJacobian( dataGLLJacobian, this->GetTargetAreas() );
                                               ( eOutputType == DiscretizationType_CGLL ), &dataGLLNodesDest );MB_CHK_ERR( rval );
            // Generate remap weights
            if( strMapAlgorithm == "volumetric" )
                if( is_root ) dbgprint.printf( 0, "Calculating remapping weights for FV->GLL (volumetric)\n" );
                LinearRemapFVtoGLL_Volumetric( *m_meshInputCov, *m_meshOutput, *m_meshOverlap, dataGLLNodesDest,
                                               dataGLLJacobian, this->GetTargetAreas(), mapOptions.nPin, *this,
                                               nMonotoneType, fContinuous, mapOptions.fNoConservation );
            else
                if( is_root ) dbgprint.printf( 0, "Calculating remapping weights for FV->GLL\n" );
                LinearRemapFVtoGLL( *m_meshInputCov, *m_meshOutput, *m_meshOverlap, dataGLLNodesDest, dataGLLJacobian,
                                    this->GetTargetAreas(), mapOptions.nPin, *this, nMonotoneType, fContinuous,
        else if( ( eInputType == DiscretizationType_PCLOUD ) || ( eOutputType == DiscretizationType_PCLOUD ) )
                else
                    if( is_root ) dbgprint.printf( 0, "Generating input mesh meta data\n" );
                    DataArray3D< double > dataGLLJacobianSrc;
                    GenerateMetaData( *m_meshInputCov, mapOptions.nPin, mapOptions.fNoBubble, dataGLLNodesSrcCov,
                                      dataGLLJacobian );
                    GenerateMetaData( *m_meshInput, mapOptions.nPin, mapOptions.fNoBubble, dataGLLNodesSrc,
                                      dataGLLJacobianSrc );
            // else { /* Source is a point cloud dataset */ }
                if( m_meshOutput->revnodearray.size() == 0 ) m_meshOutput->ConstructReverseNodeArray();
                if( m_meshOutput->edgemap.size() == 0 ) m_meshOutput->ConstructEdgeMap( false );
                if( eOutputType == DiscretizationType_FV )
                    this->InitializeSourceCoordinatesFromMeshFV( *m_meshOutput );
                else
                    GenerateMetaData( *m_meshOutput, mapOptions.nPout, mapOptions.fNoBubble, dataGLLNodesDest,
                                      dataGLLJacobian );
            // else { /* Target is a point cloud dataset */ }
                eInputType, ( eInputType == DiscretizationType_CGLL ),
                ( m_bPointCloudSource || eInputType == DiscretizationType_FV ? NULL : &dataGLLNodesSrcCov ),
                ( m_bPointCloudSource || eInputType == DiscretizationType_FV ? NULL : &dataGLLNodesSrc ), eOutputType,
                ( eOutputType == DiscretizationType_CGLL ), ( m_bPointCloudTarget ? NULL : &dataGLLNodesDest ) );MB_CHK_ERR( rval );
            // Construct remap
            if( is_root ) dbgprint.printf( 0, "Calculating remap weights with Nearest-Neighbor method\n" );
            rval = LinearRemapNN_MOAB( true /*use_GID_matching*/, false /*strict_check*/ );MB_CHK_ERR( rval );
        else if( ( eInputType != DiscretizationType_FV ) && ( eOutputType == DiscretizationType_FV ) )
            DataArray3D< double > dataGLLJacobianSrc, dataGLLJacobian;
            // double dNumericalAreaCov_loc =
                              dataGLLJacobian );
            double dNumericalArea_loc = GenerateMetaData( *m_meshInput, mapOptions.nPin, mapOptions.fNoBubble,
                                                          dataGLLNodesSrc, dataGLLJacobianSrc );
            // if ( is_root ) dbgprint.printf ( 0, "Input Mesh: Coverage Area: %1.15e, Output Area:
            // %1.15e\n", dNumericalAreaCov_loc, dTotalAreaOutput_loc );
            // assert(dNumericalAreaCov_loc >= dTotalAreaOutput_loc);
            if( m_pcomm )
#endif
            if( is_root )
                dbgprint.printf( 0, "Input Mesh Numerical Area: %1.15e\n", dNumericalArea );
                if( fabs( dNumericalArea - dTotalAreaInput ) > 1.0e-12 )
                    dbgprint.printf( 0, "WARNING: Significant mismatch between input mesh "
                                        "numerical area and geometric area\n" );
            if( dataGLLNodesSrcCov.GetSubColumns() != m_meshInputCov->faces.size() )
                _EXCEPTIONT( "Number of element does not match between metadata and "
                             "input mesh" );
            this->InitializeSourceCoordinatesFromMeshFE( *m_meshInputCov, mapOptions.nPin, dataGLLNodesSrcCov );
            // Generate the continuous Jacobian for input mesh
            bool fContinuousIn = ( eInputType == DiscretizationType_CGLL );
            if( eInputType == DiscretizationType_CGLL )
                GenerateUniqueJacobian( dataGLLNodesSrcCov, dataGLLJacobian, this->GetSourceAreas() );
            else
                GenerateDiscontinuousJacobian( dataGLLJacobian, this->GetSourceAreas() );
            // Finite element input / Finite volume output
            rval = this->SetDOFmapAssociation( eInputType, ( eInputType == DiscretizationType_CGLL ),
                                               &dataGLLNodesSrcCov, &dataGLLNodesSrc, eOutputType, false, NULL );MB_CHK_ERR( rval );
            // Generate remap
                _EXCEPTIONT( "Unimplemented: Volumetric currently unavailable for"
                             "GLL input mesh" );
            LinearRemapSE4_Tempest_MOAB( dataGLLNodesSrcCov, dataGLLJacobian, nMonotoneType, fContinuousIn,
        else if( ( eInputType != DiscretizationType_FV ) && ( eOutputType != DiscretizationType_FV ) )
            DataArray3D< double > dataGLLJacobianIn, dataGLLJacobianSrc;
            DataArray3D< double > dataGLLJacobianOut;
            // Input metadata
                              dataGLLJacobianIn );
            double dNumericalAreaSrc_loc = GenerateMetaData( *m_meshInput, mapOptions.nPin, mapOptions.fNoBubble,
            double dNumericalAreaIn      = dNumericalAreaSrc_loc;
            if( m_pcomm )
                MPI_Reduce( &dNumericalAreaSrc_loc, &dNumericalAreaIn, 1, MPI_DOUBLE, MPI_SUM, 0, m_pcomm->comm() );
#endif
            if( is_root )
                dbgprint.printf( 0, "Input Mesh Numerical Area: %1.15e\n", dNumericalAreaIn );
                if( fabs( dNumericalAreaIn - dTotalAreaInput ) > 1.0e-12 )
            // Output metadata
            double dNumericalAreaOut_loc = GenerateMetaData( *m_meshOutput, mapOptions.nPout, mapOptions.fNoBubble,
                                                             dataGLLNodesDest, dataGLLJacobianOut );
            double dNumericalAreaOut     = dNumericalAreaOut_loc;
            if( m_pcomm )
                MPI_Reduce( &dNumericalAreaOut_loc, &dNumericalAreaOut, 1, MPI_DOUBLE, MPI_SUM, 0, m_pcomm->comm() );
#endif
            if( is_root )
                dbgprint.printf( 0, "Output Mesh Numerical Area: %1.15e\n", dNumericalAreaOut );
                if( fabs( dNumericalAreaOut - dTotalAreaOutput ) > 1.0e-12 )
                    if( is_root )
                        dbgprint.printf( 0, "WARNING: Significant mismatch between output mesh "
                GenerateUniqueJacobian( dataGLLNodesSrcCov, dataGLLJacobianIn, this->GetSourceAreas() );
            else
                GenerateDiscontinuousJacobian( dataGLLJacobianIn, this->GetSourceAreas() );
            // Generate the continuous Jacobian for output mesh
            bool fContinuousOut = ( eOutputType == DiscretizationType_CGLL );
                GenerateUniqueJacobian( dataGLLNodesDest, dataGLLJacobianOut, this->GetTargetAreas() );
            else
                GenerateDiscontinuousJacobian( dataGLLJacobianOut, this->GetTargetAreas() );
            // Input Finite Element to Output Finite Element
            // Generate remap
            LinearRemapGLLtoGLL2_MOAB( dataGLLNodesSrcCov, dataGLLJacobianIn, dataGLLNodesDest, dataGLLJacobianOut,
                                       this->GetTargetAreas(), mapOptions.nPin, mapOptions.nPout, nMonotoneType,
                                       fContinuousIn, fContinuousOut, mapOptions.fNoConservation );
        else
            _EXCEPTIONT( "Not implemented" );
#ifdef MOAB_HAVE_EIGEN3
        copy_tempest_sparsemat_to_eigen3();
#endif
            // Remove ghosted entities from overlap set
            moab::Range ghostedEnts;
            rval = m_remapper->GetOverlapAugmentedEntities( ghostedEnts );MB_CHK_ERR( rval );
            moab::EntityHandle m_meshOverlapSet = m_remapper->GetMeshSet( moab::Remapper::OverlapMesh );
            rval                                = m_interface->remove_entities( m_meshOverlapSet, ghostedEnts );MB_CHK_SET_ERR( rval, "Deleting ghosted entities failed" );
#endif
        // Verify consistency, conservation and monotonicity, globally
        if( !mapOptions.fNoCheck )
            if( is_root ) dbgprint.printf( 0, "Verifying map" );
            this->IsConsistent( 1.0e-8 );
            if( !mapOptions.fNoConservation ) this->IsConservative( 1.0e-8 );
                this->IsMonotone( 1.0e-12 );
    catch( Exception& e )
        dbgprint.printf( 0, "%s", e.ToString().c_str() );
        return ( moab::MB_FAILURE );
    catch( ... )
int moab::TempestOnlineMap::GetColGlobalDoF ( int  localID) const [inline]
Definition at line 479 of file TempestOnlineMap.hpp.
    return col_gdofmap[localColID];
Definition at line 497 of file TempestOnlineMap.hpp.
    return m_nDofsPEl_Dest;
const DataArray1D< double >& moab::TempestOnlineMap::GetGlobalSourceAreas ( ) const
const DataArray1D< double >& moab::TempestOnlineMap::GetGlobalTargetAreas ( ) const
int moab::TempestOnlineMap::GetIndexOfColGlobalDoF ( int  globalColDoF) const [inline]
Definition at line 484 of file TempestOnlineMap.hpp.
    return globalColDoF + 1;  // temporary
int moab::TempestOnlineMap::GetIndexOfRowGlobalDoF ( int  globalRowDoF) const [inline]
Definition at line 473 of file TempestOnlineMap.hpp.
    return globalRowDoF + 1;
int moab::TempestOnlineMap::GetRowGlobalDoF ( int  localID) const [inline]
Definition at line 468 of file TempestOnlineMap.hpp.
    return row_gdofmap[localRowID];
Definition at line 490 of file TempestOnlineMap.hpp.
    return m_nDofsPEl_Src;
int moab::TempestOnlineMap::IsConservative ( double  dTolerance) [virtual]
Definition at line 1520 of file TempestOnlineMap.cpp.
References ierr, rank, and size.
#ifndef MOAB_HAVE_MPI
    return OfflineMap::IsConservative( dTolerance );
#else
    // return OfflineMap::IsConservative(dTolerance);
    int ierr;
    // Get map entries
    DataArray1D< int > dataRows;
    DataArray1D< int > dataCols;
    DataArray1D< double > dataEntries;
    const DataArray1D< double >& dTargetAreas = this->GetTargetAreas();
    const DataArray1D< double >& dSourceAreas = this->GetSourceAreas();
    // Calculate column sums
    std::vector< int > dColumnsUnique;
    std::vector< double > dColumnSums;
    int nColumns = m_mapRemap.GetColumns();
    m_mapRemap.GetEntries( dataRows, dataCols, dataEntries );
    dColumnSums.resize( m_nTotDofs_SrcCov, 0.0 );
    dColumnsUnique.resize( m_nTotDofs_SrcCov, -1 );
    for( unsigned i = 0; i < dataEntries.GetRows(); i++ )
        dColumnSums[dataCols[i]] += dataEntries[i] * dTargetAreas[dataRows[i]] / dSourceAreas[dataCols[i]];
        assert( dataCols[i] < m_nTotDofs_SrcCov );
        // GID for column DoFs: col_gdofmap[ col_ldofmap [ dataCols[i] ] ]
        int colGID = this->GetColGlobalDoF( dataCols[i] );  // col_gdofmap[ col_ldofmap [ dataCols[i] ] ];
        // int colGID = col_gdofmap[ col_ldofmap [ dataCols[i] ] ];
        dColumnsUnique[dataCols[i]] = colGID;
        // std::cout << "Column dataCols[i]=" << dataCols[i] << " with GID = " << colGID <<
        // std::endl;
    int rootProc = 0;
    std::vector< int > nElementsInProc;
    const int nDATA = 3;
    if( !rank ) nElementsInProc.resize( size * nDATA );
    int senddata[nDATA] = { nColumns, m_nTotDofs_SrcCov, m_nTotDofs_Src };
    ierr = MPI_Gather( senddata, nDATA, MPI_INT, nElementsInProc.data(), nDATA, MPI_INT, rootProc, m_pcomm->comm() );
    if( ierr != MPI_SUCCESS ) return -1;
    int nTotVals = 0, nTotColumns = 0, nTotColumnsUnq = 0;
    std::vector< int > dColumnIndices;
    std::vector< double > dColumnSourceAreas;
    std::vector< double > dColumnSumsTotal;
    std::vector< int > displs, rcount;
    if( rank == rootProc )
        displs.resize( size + 1, 0 );
        rcount.resize( size, 0 );
        int gsum = 0;
        for( int ir = 0; ir < size; ++ir )
            nTotVals += nElementsInProc[ir * nDATA];
            nTotColumns += nElementsInProc[ir * nDATA + 1];
            nTotColumnsUnq += nElementsInProc[ir * nDATA + 2];
            displs[ir] = gsum;
            rcount[ir] = nElementsInProc[ir * nDATA + 1];
            gsum += rcount[ir];
            // printf("%d: nTotColumns: %d, Displs: %d, rcount: %d, gsum = %d\n", ir, nTotColumns,
            // displs[ir], rcount[ir], gsum);
        dColumnIndices.resize( nTotColumns, -1 );
        dColumnSumsTotal.resize( nTotColumns, 0.0 );
        // dColumnSourceAreas.resize ( nTotColumns, 0.0 );
    // Gather all ColumnSums to root process and accumulate
    // We expect that the sums of all columns equate to 1.0 within user specified tolerance
    // Need to do a gatherv here since different processes have different number of elements
    // MPI_Reduce(&dColumnSums[0], &dColumnSumsTotal[0], m_mapRemap.GetColumns(), MPI_DOUBLE,
    // MPI_SUM, 0, m_pcomm->comm());
    ierr = MPI_Gatherv( &dColumnsUnique[0], m_nTotDofs_SrcCov, MPI_INT, &dColumnIndices[0], rcount.data(),
                        displs.data(), MPI_INT, rootProc, m_pcomm->comm() );
    ierr = MPI_Gatherv( &dColumnSums[0], m_nTotDofs_SrcCov, MPI_DOUBLE, &dColumnSumsTotal[0], rcount.data(),
                        displs.data(), MPI_DOUBLE, rootProc, m_pcomm->comm() );
    // ierr = MPI_Gatherv ( &dSourceAreas[0], m_nTotDofs_SrcCov, MPI_DOUBLE, &dColumnSourceAreas[0],
    // rcount.data(), displs.data(), MPI_DOUBLE, rootProc, m_pcomm->comm() ); if ( ierr !=
    // MPI_SUCCESS ) return -1;
    // Clean out unwanted arrays now
    dColumnSums.clear();
    dColumnsUnique.clear();
    // Verify all column sums equal the input Jacobian
    int fConservative = 0;
        displs[size] = ( nTotColumns );
        // std::vector<double> dColumnSumsOnRoot(nTotColumnsUnq, 0.0);
        std::map< int, double > dColumnSumsOnRoot;
        // std::map<int, double> dColumnSourceAreasOnRoot;
        for( int ir = 0; ir < size; ir++ )
            for( int ips = displs[ir]; ips < displs[ir + 1]; ips++ )
                if( dColumnIndices[ips] < 0 ) continue;
                // printf("%d, %d: dColumnIndices[ips]: %d\n", ir, ips, dColumnIndices[ips]);
                assert( dColumnIndices[ips] < nTotColumnsUnq );
                dColumnSumsOnRoot[dColumnIndices[ips]] += dColumnSumsTotal[ips];  // / dColumnSourceAreas[ips];
                // dColumnSourceAreasOnRoot[ dColumnIndices[ips] ] = dColumnSourceAreas[ips];
                // dColumnSourceAreas[ dColumnIndices[ips] ]
        for( std::map< int, double >::iterator it = dColumnSumsOnRoot.begin(); it != dColumnSumsOnRoot.end(); ++it )
            // if ( fabs ( it->second - dColumnSourceAreasOnRoot[it->first] ) > dTolerance )
            if( fabs( it->second - 1.0 ) > dTolerance )
                fConservative++;
                Announce( "TempestOnlineMap is not conservative in column "
                          // "%i (%1.15e)", it->first, it->second );
                          "%i (%1.15e)",
                          it->first, it->second /* / dColumnSourceAreasOnRoot[it->first] */ );
    // TODO: Just do a broadcast from root instead of a reduction
    ierr = MPI_Bcast( &fConservative, 1, MPI_INT, rootProc, m_pcomm->comm() );
    return fConservative;
#endif
int moab::TempestOnlineMap::IsConsistent ( double  dTolerance) [virtual]
Definition at line 1474 of file TempestOnlineMap.cpp.
References ierr.
Referenced by read_map_from_disk().
    return OfflineMap::IsConsistent( dTolerance );
#else
    // Get map entries
    // Calculate row sums
    DataArray1D< double > dRowSums;
    dRowSums.Allocate( m_mapRemap.GetRows() );
    for( unsigned i = 0; i < dataRows.GetRows(); i++ )
        dRowSums[dataRows[i]] += dataEntries[i];
    // Verify all row sums are equal to 1
    int fConsistent = 0;
    for( unsigned i = 0; i < dRowSums.GetRows(); i++ )
        if( fabs( dRowSums[i] - 1.0 ) > dTolerance )
            fConsistent++;
            int rowGID = row_gdofmap[i];
            Announce( "TempestOnlineMap is not consistent in row %i (%1.15e)", rowGID, dRowSums[i] );
    int ierr;
    int fConsistentGlobal = 0;
    ierr = MPI_Allreduce( &fConsistent, &fConsistentGlobal, 1, MPI_INT, MPI_SUM, m_pcomm->comm() );
    return fConsistentGlobal;
#endif
int moab::TempestOnlineMap::IsMonotone ( double  dTolerance) [virtual]
Definition at line 1662 of file TempestOnlineMap.cpp.
References ierr.
    return OfflineMap::IsMonotone( dTolerance );
#else
    // Get map entries
    // Verify all entries are in the range [0,1]
    int fMonotone = 0;
        if( ( dataEntries[i] < -dTolerance ) || ( dataEntries[i] > 1.0 + dTolerance ) )
            fMonotone++;
            Announce( "TempestOnlineMap is not monotone in entry (%i): %1.15e", i, dataEntries[i] );
    int ierr;
    int fMonotoneGlobal = 0;
    ierr = MPI_Allreduce( &fMonotone, &fMonotoneGlobal, 1, MPI_INT, MPI_SUM, m_pcomm->comm() );
    return fMonotoneGlobal;
#endif
Definition at line 115 of file TempestLinearRemap.cpp.
References dbgprint, moab::DebugOutput::printf(), rank, and moab::DebugOutput::set_prefix().
    // Order of triangular quadrature rule
    const int TriQuadRuleOrder = 4;
    // Verify ReverseNodeArray has been calculated
    if( m_meshInputCov->faces.size() > 0 && m_meshInputCov->revnodearray.size() == 0 )
        _EXCEPTIONT( "ReverseNodeArray has not been calculated for m_meshInput" );
    TriangularQuadratureRule triquadrule( TriQuadRuleOrder );
    // Number of coefficients needed at this order
#ifdef RECTANGULAR_TRUNCATION
    int nCoefficients = nOrder * nOrder;
#endif
#ifdef TRIANGULAR_TRUNCATION
    int nCoefficients = nOrder * ( nOrder + 1 ) / 2;
#endif
    // Number of faces you need
    const int nRequiredFaceSetSize = nCoefficients;
    // Fit weight exponent
    const int nFitWeightsExponent = nOrder + 2;
    // Announcemnets
    moab::DebugOutput dbgprint( std::cout, this->rank, 0 );
    dbgprint.set_prefix( "[LinearRemapFVtoFV_Tempest_MOAB]: " );
    if( is_root )
        dbgprint.printf( 0, "Finite Volume to Finite Volume Projection\n" );
        dbgprint.printf( 0, "Triangular quadrature rule order %i\n", TriQuadRuleOrder );
        dbgprint.printf( 0, "Number of coefficients: %i\n", nCoefficients );
        dbgprint.printf( 0, "Required adjacency set size: %i\n", nRequiredFaceSetSize );
        dbgprint.printf( 0, "Fit weights exponent: %i\n", nFitWeightsExponent );
    // Current overlap face
    int ixOverlap                  = 0;
    const unsigned outputFrequency = ( m_meshInputCov->faces.size() / 10 ) + 1;
    DataArray2D< double > dIntArray;
    DataArray1D< double > dConstraint( nCoefficients );
    // Loop through all faces on m_meshInput
    for( size_t ixFirst = 0; ixFirst < m_meshInputCov->faces.size(); ixFirst++ )
        // Output every 1000 elements
#ifdef VERBOSE
        if( ixFirst % outputFrequency == 0 && is_root )
            dbgprint.printf( 0, "Element %zu/%lu\n", ixFirst, m_meshInputCov->faces.size() );
#endif
        // Find the set of Faces that overlap faceFirst
        int ixOverlapBegin    = ixOverlap;
        unsigned ixOverlapEnd = ixOverlapBegin;
        for( ; ixOverlapEnd < m_meshOverlap->faces.size(); ixOverlapEnd++ )
            if( ixFirst - m_meshOverlap->vecSourceFaceIx[ixOverlapEnd] != 0 )
                break;
        unsigned nOverlapFaces = ixOverlapEnd - ixOverlapBegin;
        if( nOverlapFaces == 0 ) continue;
        // Build integration array
        BuildIntegrationArray( *m_meshInputCov, *m_meshOverlap, triquadrule, ixFirst, ixOverlapBegin, ixOverlapEnd,
                               nOrder, dIntArray );
        // Set of Faces to use in building the reconstruction and associated
        // distance metric.
        AdjacentFaceVector vecAdjFaces;
        GetAdjacentFaceVectorByEdge( *m_meshInputCov, ixFirst, nRequiredFaceSetSize, vecAdjFaces );
        // Number of adjacent Faces
        int nAdjFaces = vecAdjFaces.size();
        // Determine the conservative constraint equation
        double dFirstArea = m_meshInputCov->vecFaceArea[ixFirst];
        dConstraint.Zero();
        for( int p = 0; p < nCoefficients; p++ )
            for( unsigned j = 0; j < nOverlapFaces; j++ )
                dConstraint[p] += dIntArray[p][j];
            dConstraint[p] /= dFirstArea;
        // Build the fit array from the integration operator
        DataArray2D< double > dFitArray;
        DataArray1D< double > dFitWeights;
        DataArray2D< double > dFitArrayPlus;
        BuildFitArray( *m_meshInputCov, triquadrule, ixFirst, vecAdjFaces, nOrder, nFitWeightsExponent, dConstraint,
                       dFitArray, dFitWeights );
        // Compute the inverse fit array
        bool fSuccess = InvertFitArray_Corrected( dConstraint, dFitArray, dFitWeights, dFitArrayPlus );
        // Multiply integration array and fit array
        DataArray2D< double > dComposedArray( nAdjFaces, nOverlapFaces );
        if( fSuccess )
            // Multiply integration array and inverse fit array
            for( int i = 0; i < nAdjFaces; i++ )
                for( size_t j = 0; j < nOverlapFaces; j++ )
                    for( int k = 0; k < nCoefficients; k++ )
                        dComposedArray( i, j ) += dIntArray( k, j ) * dFitArrayPlus( i, k );
            // Unable to invert fit array, drop to 1st order.  In this case
            // dFitArrayPlus(0,0) = 1 and all other entries are zero.
        else
            dComposedArray.Zero();
                dComposedArray( 0, j ) += dIntArray( 0, j );
        // Put composed array into map
        for( unsigned i = 0; i < vecAdjFaces.size(); i++ )
                int& ixFirstFaceLoc  = vecAdjFaces[i].first;
                int& ixSecondFaceLoc = m_meshOverlap->vecTargetFaceIx[ixOverlap + j];
                // int ixFirstFaceGlob = m_remapper->GetGlobalID(moab::Remapper::SourceMesh,
                // ixFirstFaceLoc); int ixSecondFaceGlob =
                // m_remapper->GetGlobalID(moab::Remapper::TargetMesh, ixSecondFaceLoc);
                // signal to not participate, because it is a ghost target
                if( ixSecondFaceLoc < 0 ) continue;  // do not do anything
                m_mapRemap( ixSecondFaceLoc, ixFirstFaceLoc ) +=
                    dComposedArray[i][j] / m_meshOutput->vecFaceArea[ixSecondFaceLoc];
        // Increment the current overlap index
        ixOverlap += nOverlapFaces;
    return;
void moab::TempestOnlineMap::LinearRemapFVtoGLL_MOAB ( const DataArray3D< int > &  dataGLLNodes,
const DataArray3D< double > &  dataGLLJacobian,
const DataArray1D< double > &  dataGLLNodalArea,
int  nOrder,
int  nMonotoneType,
bool  fContinuous,
) [private]
void moab::TempestOnlineMap::LinearRemapGLLtoGLL2_MOAB ( const DataArray3D< int > &  dataGLLNodesIn,
const DataArray3D< double > &  dataGLLJacobianIn,
const DataArray3D< int > &  dataGLLNodesOut,
const DataArray3D< double > &  dataGLLJacobianOut,
const DataArray1D< double > &  dataNodalAreaOut,
int  nPin,
int  nPout,
int  nMonotoneType,
bool  fContinuousIn,
) [private]
Definition at line 894 of file TempestLinearRemap.cpp.
References center(), dbgprint, ForceIntArrayConsistencyConservation(), moab::DebugOutput::printf(), moab::DebugOutput::set_prefix(), and t.
    TriangularQuadratureRule triquadrule( 8 );
    const DataArray2D< double >& dG = triquadrule.GetG();
    const DataArray1D< double >& dW = triquadrule.GetW();
    // Get SparseMatrix represntation of the OfflineMap
    SparseMatrix< double >& smatMap = this->GetSparseMatrix();
    // Sample coefficients
    DataArray2D< double > dSampleCoeffIn( nPin, nPin );
    DataArray2D< double > dSampleCoeffOut( nPout, nPout );
    // Announcemnets
    dbgprint.set_prefix( "[LinearRemapGLLtoGLL2_MOAB]: " );
    if( is_root )
        dbgprint.printf( 0, "Finite Element to Finite Element Projection\n" );
        dbgprint.printf( 0, "Order of the input FE polynomial interpolant: %i\n", nPin );
        dbgprint.printf( 0, "Order of the output FE polynomial interpolant: %i\n", nPout );
    // Build the integration array for each element on m_meshOverlap
    DataArray3D< double > dGlobalIntArray( nPin * nPin, m_meshOverlap->faces.size(), nPout * nPout );
    // Number of overlap Faces per source Face
    DataArray1D< int > nAllOverlapFaces( m_meshInputCov->faces.size() );
    int ixOverlap = 0;
        // Determine how many overlap Faces and triangles are present
        int nOverlapFaces    = 0;
        size_t ixOverlapTemp = ixOverlap;
        for( ; ixOverlapTemp < m_meshOverlap->faces.size(); ixOverlapTemp++ )
            // const Face & faceOverlap = m_meshOverlap->faces[ixOverlapTemp];
            if( ixFirst - m_meshOverlap->vecSourceFaceIx[ixOverlapTemp] != 0 )
                break;
            nOverlapFaces++;
        nAllOverlapFaces[ixFirst] = nOverlapFaces;
        ixOverlap += nAllOverlapFaces[ixFirst];
    // Geometric area of each output node
    DataArray2D< double > dGeometricOutputArea( m_meshOutput->faces.size(), nPout * nPout );
    // Area of each overlap element in the output basis
    DataArray2D< double > dOverlapOutputArea( m_meshOverlap->faces.size(), nPout * nPout );
    ixOverlap                      = 0;
    if( is_root ) dbgprint.printf( 0, "Building conservative distribution maps\n" );
    // generic triangle used for area computation, for triangles around the center of overlap face;
    // used for overlap faces with more than 4 edges;
    // nodes array will be set for each triangle;
    // these triangles are not part of the mesh structure, they are just temporary during
    //   aforementioned decomposition.
    Face faceTri( 3 );
    NodeVector nodes( 3 );
    faceTri.SetNode( 0, 0 );
    faceTri.SetNode( 1, 1 );
    faceTri.SetNode( 2, 2 );
#ifdef VERBOSE
        // Announce computation progress
#endif
        // Quantities from the First Mesh
        const Face& faceFirst = m_meshInputCov->faces[ixFirst];
        const NodeVector& nodesFirst = m_meshInputCov->nodes;
        // Number of overlapping Faces and triangles
        int nOverlapFaces = nAllOverlapFaces[ixFirst];
        if( !nOverlapFaces ) continue;
        // // Calculate total element Jacobian
        // double dTotalJacobian = 0.0;
        // for (int s = 0; s < nPin; s++) {
        //     for (int t = 0; t < nPin; t++) {
        //         dTotalJacobian += dataGLLJacobianIn[s][t][ixFirst];
        // Loop through all Overlap Faces
        for( int i = 0; i < nOverlapFaces; i++ )
            // Quantities from the overlap Mesh
            const Face& faceOverlap = m_meshOverlap->faces[ixOverlap + i];
            const NodeVector& nodesOverlap = m_meshOverlap->nodes;
            // Quantities from the Second Mesh
            int ixSecond = m_meshOverlap->vecTargetFaceIx[ixOverlap + i];
            if( ixSecond < 0 ) continue;  // do not do anything
            const NodeVector& nodesSecond = m_meshOutput->nodes;
            const Face& faceSecond = m_meshOutput->faces[ixSecond];
            int nbEdges           = faceOverlap.edges.size();
            int nOverlapTriangles = 1;
            Node center;  // not used if nbEdges == 3
            if( nbEdges > 3 )
            {  // decompose from center in this case
                nOverlapTriangles = nbEdges;
                for( int k = 0; k < nbEdges; k++ )
                    const Node& node = nodesOverlap[faceOverlap[k]];
                    center           = center + node;
                center = center / nbEdges;
                center = center.Normalized();  // project back on sphere of radius 1
            Node node0, node1, node2;
            double dTriArea;
            // Loop over all sub-triangles of this Overlap Face
            for( int j = 0; j < nOverlapTriangles; j++ )
                if( nbEdges == 3 )  // will come here only once, nOverlapTriangles == 1 in this case
                    node0    = nodesOverlap[faceOverlap[0]];
                    node1    = nodesOverlap[faceOverlap[1]];
                    node2    = nodesOverlap[faceOverlap[2]];
                    dTriArea = CalculateFaceArea( faceOverlap, nodesOverlap );
                else  // decompose polygon in triangles around the center
                    node0    = center;
                    node1    = nodesOverlap[faceOverlap[j]];
                    int j1   = ( j + 1 ) % nbEdges;
                    node2    = nodesOverlap[faceOverlap[j1]];
                    nodes[0] = center;
                    nodes[1] = node1;
                    nodes[2] = node2;
                    dTriArea = CalculateFaceArea( faceTri, nodes );
                for( int k = 0; k < triquadrule.GetPoints(); k++ )
                    // Get the nodal location of this point
                    double dX[3];
                    dX[0] = dG( k, 0 ) * node0.x + dG( k, 1 ) * node1.x + dG( k, 2 ) * node2.x;
                    dX[1] = dG( k, 0 ) * node0.y + dG( k, 1 ) * node1.y + dG( k, 2 ) * node2.y;
                    dX[2] = dG( k, 0 ) * node0.z + dG( k, 1 ) * node1.z + dG( k, 2 ) * node2.z;
                    double dMag = sqrt( dX[0] * dX[0] + dX[1] * dX[1] + dX[2] * dX[2] );
                    dX[0] /= dMag;
                    dX[1] /= dMag;
                    dX[2] /= dMag;
                    Node nodeQuadrature( dX[0], dX[1], dX[2] );
                    // Find the components of this quadrature point in the basis
                    // of the first Face.
                    double dAlphaIn;
                    double dBetaIn;
                    ApplyInverseMap( faceFirst, nodesFirst, nodeQuadrature, dAlphaIn, dBetaIn );
                    // of the second Face.
                    double dAlphaOut;
                    double dBetaOut;
                    ApplyInverseMap( faceSecond, nodesSecond, nodeQuadrature, dAlphaOut, dBetaOut );
                                        // Check inverse map value
                                        if ((dAlphaIn < 0.0) || (dAlphaIn > 1.0) ||
                                            (dBetaIn  < 0.0) || (dBetaIn  > 1.0)
                                            _EXCEPTION2("Inverse Map out of range (%1.5e %1.5e)",
                                                dAlphaIn, dBetaIn);
                                        if ((dAlphaOut < 0.0) || (dAlphaOut > 1.0) ||
                                            (dBetaOut  < 0.0) || (dBetaOut  > 1.0)
                                                dAlphaOut, dBetaOut);
                    // Sample the First finite element at this point
                    SampleGLLFiniteElement( nMonotoneType, nPin, dAlphaIn, dBetaIn, dSampleCoeffIn );
                    // Sample the Second finite element at this point
                    SampleGLLFiniteElement( nMonotoneType, nPout, dAlphaOut, dBetaOut, dSampleCoeffOut );
                    // Overlap output area
                    for( int s = 0; s < nPout; s++ )
                        for( int t = 0; t < nPout; t++ )
                            double dNodeArea = dSampleCoeffOut[s][t] * dW[k] * dTriArea;
                            dOverlapOutputArea[ixOverlap + i][s * nPout + t] += dNodeArea;
                            dGeometricOutputArea[ixSecond][s * nPout + t] += dNodeArea;
                    // Compute overlap integral
                    int ixp = 0;
                    for( int p = 0; p < nPin; p++ )
                        for( int q = 0; q < nPin; q++ )
                            int ixs = 0;
                                    dGlobalIntArray[ixp][ixOverlap + i][ixs] +=
                                        dSampleCoeffOut[s][t] * dSampleCoeffIn[p][q] * dW[k] * dTriArea;
                                    ixs++;
                            ixp++;
        // Coefficients
        DataArray2D< double > dCoeff( nOverlapFaces * nPout * nPout, nPin * nPin );
            // int ixSecondFace = m_meshOverlap->vecTargetFaceIx[ixOverlap + i];
            int ixp = 0;
                    int ixs = 0;
                            dCoeff[i * nPout * nPout + ixs][ixp] = dGlobalIntArray[ixp][ixOverlap + i][ixs] /
        dOverlapOutputArea[ixOverlap + i][s * nPout + t];
                            ixs++;
                    ixp++;
        // Source areas
        DataArray1D< double > vecSourceArea( nPin * nPin );
                vecSourceArea[p * nPin + q] = dataGLLJacobianIn[p][q][ixFirst];
        // Target areas
        DataArray1D< double > vecTargetArea( nOverlapFaces * nPout * nPout );
            // int ixSecond = m_meshOverlap->vecTargetFaceIx[ixOverlap + i];
            int ixs = 0;
                    vecTargetArea[i * nPout * nPout + ixs] = dOverlapOutputArea[ixOverlap + i][nPout * s + t];
                    ixs++;
        // Force consistency and conservation
        if( !fNoConservation )
            ForceIntArrayConsistencyConservation( vecSourceArea, vecTargetArea, dCoeff, ( nMonotoneType != 0 ) );
        // Update global coefficients
            int ixp = 0;
                    int ixs = 0;
                            dGlobalIntArray[ixp][ixOverlap + i][ixs] =
                                dCoeff[i * nPout * nPout + ixs][ixp] * dOverlapOutputArea[ixOverlap + i][s * nPout + t];
                            ixs++;
                    ixp++;
#ifdef VVERBOSE
        // Check column sums (conservation)
        for( int i = 0; i < nPin * nPin; i++ )
            double dColSum = 0.0;
            for( int j = 0; j < nOverlapFaces * nPout * nPout; j++ )
                dColSum += dCoeff[j][i] * vecTargetArea[j];
            printf( "Col %i: %1.15e\n", i, dColSum / vecSourceArea[i] );
        // Check row sums (consistency)
            double dRowSum = 0.0;
                dRowSum += dCoeff[j][i];
            printf( "Row %i: %1.15e\n", j, dRowSum );
#endif
    // Build redistribution map within target element
    if( is_root ) dbgprint.printf( 0, "Building redistribution maps on target mesh\n" );
    DataArray1D< double > dRedistSourceArea( nPout * nPout );
    DataArray1D< double > dRedistTargetArea( nPout * nPout );
    std::vector< DataArray2D< double > > dRedistributionMaps;
    dRedistributionMaps.resize( m_meshOutput->faces.size() );
    for( size_t ixSecond = 0; ixSecond < m_meshOutput->faces.size(); ixSecond++ )
        dRedistributionMaps[ixSecond].Allocate( nPout * nPout, nPout * nPout );
        for( int i = 0; i < nPout * nPout; i++ )
            dRedistributionMaps[ixSecond][i][i] = 1.0;
        for( int s = 0; s < nPout * nPout; s++ )
            dRedistSourceArea[s] = dGeometricOutputArea[ixSecond][s];
            dRedistTargetArea[s] = dataGLLJacobianOut[s / nPout][s % nPout][ixSecond];
            ForceIntArrayConsistencyConservation( dRedistSourceArea, dRedistTargetArea, dRedistributionMaps[ixSecond],
                for( int t = 0; t < nPout * nPout; t++ )
                    dRedistributionMaps[ixSecond][s][t] *= dRedistTargetArea[s] / dRedistSourceArea[t];
    // Construct the total geometric area
    DataArray1D< double > dTotalGeometricArea( dataNodalAreaOut.GetRows() );
                dTotalGeometricArea[dataGLLNodesOut[s][t][ixSecond] - 1] +=
                    dGeometricOutputArea[ixSecond][s * nPout + t];
    // Compose the integration operator with the output map
    ixOverlap = 0;
    if( is_root ) dbgprint.printf( 0, "Assembling map\n" );
    // Map from source DOFs to target DOFs with redistribution applied
    DataArray2D< double > dRedistributedOp( nPin * nPin, nPout * nPout );
#ifdef VERBOSE
#endif
        for( int j = 0; j < nOverlapFaces; j++ )
            int ixSecondFace = m_meshOverlap->vecTargetFaceIx[ixOverlap + j];
            if( ixSecondFace < 0 ) continue;  // do not do anything
            dRedistributedOp.Zero();
            for( int p = 0; p < nPin * nPin; p++ )
                        dRedistributedOp[p][s] +=
                            dRedistributionMaps[ixSecondFace][s][t] * dGlobalIntArray[p][ixOverlap + j][t];
            int ixp = 0;
                    int ixFirstNode;
                    if( fContinuousIn )
                        ixFirstNode = dataGLLNodesIn[p][q][ixFirst] - 1;
                    else
                        ixFirstNode = ixFirst * nPin * nPin + p * nPin + q;
                    int ixs = 0;
                            int ixSecondNode;
                            if( fContinuousOut )
                                ixSecondNode = dataGLLNodesOut[s][t][ixSecondFace] - 1;
                                    smatMap( ixSecondNode, ixFirstNode ) +=
                                        dRedistributedOp[ixp][ixs] / dataNodalAreaOut[ixSecondNode];
                                else
                                        dRedistributedOp[ixp][ixs] / dTotalGeometricArea[ixSecondNode];
                            else
                                ixSecondNode = ixSecondFace * nPout * nPout + s * nPout + t;
                                        dRedistributedOp[ixp][ixs] / dataGLLJacobianOut[s][t][ixSecondFace];
                                else
                                        dRedistributedOp[ixp][ixs] / dGeometricOutputArea[ixSecondFace][s * nPout + t];
                            ixs++;
                    ixp++;
    return;
void moab::TempestOnlineMap::LinearRemapGLLtoGLL2_Pointwise_MOAB ( const DataArray3D< int > &  dataGLLNodesIn,
int  nPin,
int  nPout,
int  nMonotoneType,
bool  fContinuousIn,
bool  fContinuousOut
) [private]
Generate the OfflineMap for remapping from finite elements to finite elements (pointwise interpolation).
Definition at line 1444 of file TempestLinearRemap.cpp.
References dbgprint, moab::DebugOutput::printf(), moab::DebugOutput::set_prefix(), and t.
    // Gauss-Lobatto quadrature within Faces
    DataArray1D< double > dGL;
    DataArray1D< double > dWL;
    GaussLobattoQuadrature::GetPoints( nPout, 0.0, 1.0, dGL, dWL );
    // Announcemnets
    dbgprint.set_prefix( "[LinearRemapGLLtoGLL2_Pointwise_MOAB]: " );
    if( is_root )
        dbgprint.printf( 0, "Finite Element to Finite Element (Pointwise) Projection\n" );
    int ixOverlap = 0;
            if( ixFirst - m_meshOverlap->vecSourceFaceIx[ixOverlapTemp] != 0 ) break;
            nAllOverlapFaces[ixFirst]++;
    // Number of times this point was found
    DataArray1D< bool > fSecondNodeFound( dataNodalAreaOut.GetRows() );
    ixOverlap                      = 0;
    // Loop through all faces on m_meshInputCov
#ifdef VERBOSE
#endif
            // Loop through all nodes on the second face
                    size_t ixSecondNode;
                        ixSecondNode = dataGLLNodesOut[s][t][ixSecond] - 1;
                    else
                        ixSecondNode = ixSecond * nPout * nPout + s * nPout + t;
                    if( ixSecondNode >= fSecondNodeFound.GetRows() )
                        _EXCEPTIONT( "Logic error" );
                    // Check if this node has been found already
                    if( fSecondNodeFound[ixSecondNode] )
                        continue;
                    // Check this node
                    Node node;
                    Node dDx1G;
                    Node dDx2G;
                    ApplyLocalMap( faceSecond, nodesSecond, dGL[t], dGL[s], node, dDx1G, dDx2G );
                    double dAlphaIn;
                    double dBetaIn;
                    ApplyInverseMap( faceFirst, nodesFirst, node, dAlphaIn, dBetaIn );
                    // Check if this node is within the first Face
                    if( ( dAlphaIn < -1.0e-10 ) || ( dAlphaIn > 1.0 + 1.0e-10 ) || ( dBetaIn < -1.0e-10 ) ||
                        ( dBetaIn > 1.0 + 1.0e-10 ) )
                        continue;
                    // Node is within the overlap region, mark as found
                    fSecondNodeFound[ixSecondNode] = true;
                    // Add to map
                            int ixFirstNode;
                            if( fContinuousIn )
                            else
                            smatMap( ixSecondNode, ixFirstNode ) += dSampleCoeffIn[p][q];
    // Check for missing samples
    for( size_t i = 0; i < fSecondNodeFound.GetRows(); i++ )
        if( !fSecondNodeFound[i] )
            _EXCEPTION1( "Can't sample point %i", i );
    return;
moab::ErrorCode moab::TempestOnlineMap::LinearRemapNN_MOAB ( bool  use_GID_matching = false,
bool  strict_check = false
) [private]
Compute the remapping weights as a permutation matrix that relates DoFs on the source mesh to DoFs on the target mesh.
Definition at line 52 of file TempestLinearRemap.cpp.
References col_gdofmap, m_nTotDofs_Dest, m_nTotDofs_SrcCov, MB_SUCCESS, and row_gdofmap.
    /* m_mapRemap size = (m_nTotDofs_Dest X m_nTotDofs_SrcCov)  */
#ifdef VVERBOSE
        std::ofstream output_file( "rowcolindices.txt", std::ios::out );
        output_file << m_nTotDofs_Dest << " " << m_nTotDofs_SrcCov << " " << row_gdofmap.size() << " "
                    << row_ldofmap.size() << " " << col_gdofmap.size() << " " << col_ldofmap.size() << "\n";
        output_file << "Rows \n";
        for( unsigned iv = 0; iv < row_gdofmap.size(); iv++ )
            output_file << row_gdofmap[iv] << " " << row_dofmap[iv] << "\n";
        output_file << "Cols \n";
        for( unsigned iv = 0; iv < col_gdofmap.size(); iv++ )
            output_file << col_gdofmap[iv] << " " << col_dofmap[iv] << "\n";
        output_file.flush();  // required here
        output_file.close();
#endif
    if( use_GID_matching )
        std::map< unsigned, unsigned > src_gl;
        for( unsigned it = 0; it < col_gdofmap.size(); ++it )
            src_gl[col_gdofmap[it]] = it;
        std::map< unsigned, unsigned >::iterator iter;
        for( unsigned it = 0; it < row_gdofmap.size(); ++it )
            unsigned row = row_gdofmap[it];
            iter         = src_gl.find( row );
            if( strict_check && iter == src_gl.end() )
                std::cout << "Searching for global target DOF " << row
                          << " but could not find correspondence in source mesh.\n";
                assert( false );
            else if( iter == src_gl.end() )
                continue;
            else
                unsigned icol = src_gl[row];
                unsigned irow = it;
                // Set the permutation matrix in local space
                m_mapRemap( irow, icol ) = 1.0;
    else
        /* Create a Kd-tree to perform local queries to find nearest neighbors */
void moab::TempestOnlineMap::LinearRemapSE0_Tempest_MOAB ( const DataArray3D< int > &  dataGLLNodes,
) [private]
Generate the OfflineMap for linear conserative element-average spectral element to element average remapping.
void moab::TempestOnlineMap::LinearRemapSE4_Tempest_MOAB ( const DataArray3D< int > &  dataGLLNodes,
int  nMonotoneType,
bool  fContinuousIn,
bool  fNoConservation
) [private]
Generate the OfflineMap for cubic conserative element-average spectral element to element average remapping.
Definition at line 469 of file TempestLinearRemap.cpp.
References center(), dbgprint, ForceConsistencyConservation3(), moab::DebugOutput::printf(), and moab::DebugOutput::set_prefix().
    // Order of the polynomial interpolant
    int nP = dataGLLNodes.GetRows();
    DataArray2D< double > dSampleCoeff( nP, nP );
    // GLL Quadrature nodes on quadrilateral elements
    GaussLobattoQuadrature::GetPoints( nP, 0.0, 1.0, dG, dW );
    // Announcements
    dbgprint.set_prefix( "[LinearRemapSE4_Tempest_MOAB]: " );
    if( is_root )
        dbgprint.printf( 0, "Finite Element to Finite Volume Projection\n" );
        dbgprint.printf( 0, "Order of the FE polynomial interpolant: %i\n", nP );
    // NodeVector from m_meshOverlap
    // Vector of source areas
    DataArray1D< double > vecSourceArea( nP * nP );
    DataArray1D< double > vecTargetArea;
    DataArray2D< double > dCoeff;
#ifdef VERBOSE
    std::stringstream sstr;
    sstr << "remapdata_" << rank << ".txt";
    std::ofstream output_file( sstr.str() );
#endif
    // Current Overlap Face
    int ixOverlap                  = 0;
    Face faceTri( 3 );
    // Loop over all input Faces
        if( faceFirst.edges.size() != 4 )
            _EXCEPTIONT( "Only quadrilateral elements allowed for SE remapping" );
#ifdef VERBOSE
#endif
        // Need to re-number the overlap elements such that vecSourceFaceIx[a:b] = 0, then 1 and so
        // on wrt the input mesh data Then the overlap_end and overlap_begin will be correct.
        // However, the relation with MOAB and Tempest will go out of the roof
                break;
            nOverlapFaces++;
        // No overlaps
            continue;
        // Allocate remap coefficients array for meshFirst Face
        DataArray3D< double > dRemapCoeff( nP, nP, nOverlapFaces );
        // Find the local remap coefficients
            const Face& faceOverlap = m_meshOverlap->faces[ixOverlap + j];
            if( m_meshOverlap->vecFaceArea[ixOverlap + j] < 1.e-16 )  // machine precision
                Announce( "Very small overlap at index %i area polygon: (%1.10e )", ixOverlap + j,
                          m_meshOverlap->vecFaceArea[ixOverlap + j] );
                int n = faceOverlap.edges.size();
                Announce( "Number nodes: %d", n );
                for( int k = 0; k < n; k++ )
                    Node nd = nodesOverlap[faceOverlap[k]];
                    Announce( "Node %d  %d  : %1.10e  %1.10e %1.10e ", k, faceOverlap[k], nd.x, nd.y, nd.z );
                continue;
            // #ifdef VERBOSE
            // if ( is_root )
            //     Announce ( "\tLocal ID: %i/%i = %i, areas = %2.8e", j + ixOverlap, nOverlapFaces,
            //     m_remapper->lid_to_gid_covsrc[m_meshOverlap->vecSourceFaceIx[ixOverlap + j]],
            //     m_meshOverlap->vecFaceArea[ixOverlap + j] );
            // #endif
            if( nbEdges > 3 )
            double dTriangleArea;
            for( int k = 0; k < nOverlapTriangles; k++ )
                    dTriangleArea = CalculateFaceArea( faceOverlap, nodesOverlap );
                    node0         = center;
                    node1         = nodesOverlap[faceOverlap[k]];
                    int k1        = ( k + 1 ) % nbEdges;
                    node2         = nodesOverlap[faceOverlap[k1]];
                    nodes[0]      = center;
                    nodes[1]      = node1;
                    nodes[2]      = node2;
                // Coordinates of quadrature Node
                for( int l = 0; l < TriQuadraturePoints; l++ )
                    Node nodeQuadrature;
                    nodeQuadrature.x = TriQuadratureG[l][0] * node0.x + TriQuadratureG[l][1] * node1.x +
                                       TriQuadratureG[l][2] * node2.x;
                    nodeQuadrature.y = TriQuadratureG[l][0] * node0.y + TriQuadratureG[l][1] * node1.y +
                                       TriQuadratureG[l][2] * node2.y;
                    nodeQuadrature.z = TriQuadratureG[l][0] * node0.z + TriQuadratureG[l][1] * node1.z +
                                       TriQuadratureG[l][2] * node2.z;
                    nodeQuadrature = nodeQuadrature.Normalized();
                    double dAlpha;
                    double dBeta;
                    ApplyInverseMap( faceFirst, nodesFirst, nodeQuadrature, dAlpha, dBeta );
                    if( ( dAlpha < -1.0e-13 ) || ( dAlpha > 1.0 + 1.0e-13 ) || ( dBeta < -1.0e-13 ) ||
                        ( dBeta > 1.0 + 1.0e-13 ) )
                        _EXCEPTION4( "Inverse Map for element %d and subtriangle %d out of range "
                                     "(%1.5e %1.5e)",
                                     j, l, dAlpha, dBeta );
                    // Sample the finite element at this point
                    SampleGLLFiniteElement( nMonotoneType, nP, dAlpha, dBeta, dSampleCoeff );
                    // Add sample coefficients to the map if m_meshOverlap->vecFaceArea[ixOverlap + j] > 0
                    for( int p = 0; p < nP; p++ )
                        for( int q = 0; q < nP; q++ )
                            dRemapCoeff[p][q][j] += TriQuadratureW[l] * dTriangleArea * dSampleCoeff[p][q] /
                                                    m_meshOverlap->vecFaceArea[ixOverlap + j];
#ifdef VERBOSE
        output_file << "[" << m_remapper->lid_to_gid_covsrc[ixFirst] << "] \t";
                    output_file << dRemapCoeff[p][q][j] << " ";
        output_file << std::endl;
#endif
            double dTargetArea = 0.0;
                dTargetArea += m_meshOverlap->vecFaceArea[ixOverlap + j];
                    vecSourceArea[p * nP + q] = dataGLLJacobian[p][q][ixFirst];
            const double areaTolerance = 1e-10;
            // Source elements are completely covered by target volumes
            if( fabs( m_meshInputCov->vecFaceArea[ixFirst] - dTargetArea ) <= areaTolerance )
                vecTargetArea.Allocate( nOverlapFaces );
                    vecTargetArea[j] = m_meshOverlap->vecFaceArea[ixOverlap + j];
                dCoeff.Allocate( nOverlapFaces, nP * nP );
                            dCoeff[j][p * nP + q] = dRemapCoeff[p][q][j];
                // Target volumes only partially cover source elements
            else if( m_meshInputCov->vecFaceArea[ixFirst] - dTargetArea > areaTolerance )
                double dExtraneousArea = m_meshInputCov->vecFaceArea[ixFirst] - dTargetArea;
                vecTargetArea.Allocate( nOverlapFaces + 1 );
                vecTargetArea[nOverlapFaces] = dExtraneousArea;
#ifdef VERBOSE
                Announce( "Partial volume: %i (%1.10e / %1.10e)", ixFirst, dTargetArea,
                          m_meshInputCov->vecFaceArea[ixFirst] );
#endif
                if( dTargetArea > m_meshInputCov->vecFaceArea[ixFirst] )
                    _EXCEPTIONT( "Partial element area exceeds total element area" );
                dCoeff.Allocate( nOverlapFaces + 1, nP * nP );
                        dCoeff[nOverlapFaces][p * nP + q] = dataGLLJacobian[p][q][ixFirst];
                            dCoeff[nOverlapFaces][p * nP + q] -=
                                dRemapCoeff[p][q][j] * m_meshOverlap->vecFaceArea[ixOverlap + j];
                        dCoeff[nOverlapFaces][p * nP + q] /= dExtraneousArea;
                // Source elements only partially cover target volumes
            else
                Announce( "Coverage area: %1.10e, and target element area: %1.10e)", ixFirst,
                          m_meshInputCov->vecFaceArea[ixFirst], dTargetArea );
                _EXCEPTIONT( "Target grid must be a subset of source grid" );
            ForceConsistencyConservation3( vecSourceArea, vecTargetArea, dCoeff, ( nMonotoneType > 0 )
                                           /*, m_remapper->lid_to_gid_covsrc[ixFirst]*/ );
                        dRemapCoeff[p][q][j] = dCoeff[j][p * nP + q];
#ifdef VERBOSE
        // output_file << "[" << m_remapper->lid_to_gid_covsrc[ixFirst] << "] \t";
        // for ( int j = 0; j < nOverlapFaces; j++ )
        //     for ( int p = 0; p < nP; p++ )
        //         for ( int q = 0; q < nP; q++ )
        //             output_file << dRemapCoeff[p][q][j] << " ";
        // output_file << std::endl;
#endif
        // Put these remap coefficients into the SparseMatrix map
                    if( fContinuousIn )
                        int ixFirstNode = dataGLLNodes[p][q][ixFirst] - 1;
                        smatMap( ixSecondFace, ixFirstNode ) += dRemapCoeff[p][q][j] *
        m_meshOverlap->vecFaceArea[ixOverlap + j] /
        m_meshOutput->vecFaceArea[ixSecondFace];
                    else
                        int ixFirstNode = ixFirst * nP * nP + p * nP + q;
#ifdef VERBOSE
#endif
    return;
moab::ErrorCode moab::TempestOnlineMap::ReadParallelMap ( const char *  strSource,
const std::vector< int > &  owned_dof_ids,
bool  row_major_ownership = true
Generate the metadata associated with the offline map.
Read the OfflineMap from a NetCDF file.
Definition at line 1169 of file TempestOnlineMapIO.cpp.
References CHECK_EXCEPTION, moab::TupleList::enableWriteAccess(), moab::error(), moab::TupleList::get_n(), moab::TupleList::inc_n(), moab::TupleList::initialize(), MB_SUCCESS, rank, moab::TupleList::reset(), size, moab::TupleList::sort(), moab::TupleList::vi_rd, moab::TupleList::vi_wr, moab::TupleList::vr_rd, and moab::TupleList::vr_wr.
    NcVar *varRow = NULL, *varCol = NULL, *varS = NULL;
    int nS = 0, nA = 0, nB = 0;
#ifdef MOAB_HAVE_PNETCDF
    // some variables will be used just in the case netcdfpar reader fails
    int ncfile = -1, ret = 0;
    int ndims, nvars, ngatts, unlimited;
#endif
#ifdef MOAB_HAVE_NETCDFPAR
    bool is_independent = true;
    ParNcFile ncMap( m_pcomm->comm(), MPI_INFO_NULL, strSource, NcFile::ReadOnly, NcFile::Netcdf4 );
    // ParNcFile ncMap( m_pcomm->comm(), MPI_INFO_NULL, strFilename.c_str(), NcmpiFile::replace, NcmpiFile::classic5 );
#else
    NcFile ncMap( strSource, NcFile::ReadOnly );
#endif
#define CHECK_EXCEPTION( obj, type, varstr )                                                      \
        if( obj == NULL )        \
            _EXCEPTION3( "Map file \"%s\" does not contain %s \"%s\"", strSource, type, varstr ); \
    // Read SparseMatrix entries
    if( ncMap.is_valid() )
        NcDim* dimNS = ncMap.get_dim( "n_s" );
        CHECK_EXCEPTION( dimNS, "dimension", "n_s" );
        NcDim* dimNA = ncMap.get_dim( "n_a" );
        CHECK_EXCEPTION( dimNA, "dimension", "n_a" );
        NcDim* dimNB = ncMap.get_dim( "n_b" );
        CHECK_EXCEPTION( dimNB, "dimension", "n_b" );
        // store total number of nonzeros
        nS = dimNS->size();
        nA = dimNA->size();
        nB = dimNB->size();
        varRow = ncMap.get_var( "row" );
        CHECK_EXCEPTION( varRow, "variable", "row" );
        varCol = ncMap.get_var( "col" );
        CHECK_EXCEPTION( varCol, "variable", "col" );
        varS = ncMap.get_var( "S" );
        CHECK_EXCEPTION( varS, "variable", "S" );
        ncMap.enable_var_par_access( varRow, is_independent );
        ncMap.enable_var_par_access( varCol, is_independent );
        ncMap.enable_var_par_access( varS, is_independent );
#endif
    else
        // read the file using pnetcdf directly, in parallel; need to have MPI, we do not check that anymore
        // why build wth pnetcdf without MPI ?
        // ParNcFile ncMap( m_pcomm->comm(), MPI_INFO_NULL, strSource, NcFile::ReadOnly, NcFile::Netcdf4 );
        ret = ncmpi_open( m_pcomm->comm(), strSource, NC_NOWRITE, MPI_INFO_NULL, &ncfile );
        ERR_PARNC( ret );  // bail out completely
        ret = ncmpi_inq( ncfile, &ndims, &nvars, &ngatts, &unlimited );
        ERR_PARNC( ret );
        // find dimension ids for n_S
        int ins;
        ret = ncmpi_inq_dimid( ncfile, "n_s", &ins );
        ERR_PARNC( ret );
        MPI_Offset leng;
        ret = ncmpi_inq_dimlen( ncfile, ins, &leng );
        ERR_PARNC( ret );
        nS  = (int)leng;
        ret = ncmpi_inq_dimid( ncfile, "n_b", &ins );
        ERR_PARNC( ret );
        ERR_PARNC( ret );
        nB = (int)leng;
#else
        _EXCEPTION1( "cannot read the file %s", strSource );
#endif
    // Let us declare the map object for every process
    SparseMatrix< double >& sparseMatrix = this->GetSparseMatrix();
    int localSize   = nS / size;
    long offsetRead = rank * localSize;
    // leftovers on last rank
    if( rank == size - 1 )
        localSize += nS % size;
    std::vector< int > vecRow, vecCol;
    std::vector< double > vecS;
    vecRow.resize( localSize );
    vecCol.resize( localSize );
    vecS.resize( localSize );
        varRow->set_cur( (long)( offsetRead ) );
        varRow->get( &( vecRow[0] ), localSize );
        varCol->set_cur( (long)( offsetRead ) );
        varCol->get( &( vecCol[0] ), localSize );
        varS->set_cur( (long)( offsetRead ) );
        varS->get( &( vecS[0] ), localSize );
        ncMap.close();
    else
        // fill the local vectors with the variables from pnetcdf file; first inquire, then fill
        MPI_Offset start = (MPI_Offset)offsetRead;
        MPI_Offset count = (MPI_Offset)localSize;
        int varid;
        ret = ncmpi_inq_varid( ncfile, "S", &varid );
        ERR_PARNC( ret );
        ret = ncmpi_get_vara_double_all( ncfile, varid, &start, &count, &vecS[0] );
        ERR_PARNC( ret );
        ret = ncmpi_inq_varid( ncfile, "row", &varid );
        ERR_PARNC( ret );
        ret = ncmpi_get_vara_int_all( ncfile, varid, &start, &count, &vecRow[0] );
        ERR_PARNC( ret );
        ret = ncmpi_inq_varid( ncfile, "col", &varid );
        ERR_PARNC( ret );
        ret = ncmpi_get_vara_int_all( ncfile, varid, &start, &count, &vecCol[0] );
        ERR_PARNC( ret );
        ret = ncmpi_close( ncfile );
        ERR_PARNC( ret );
#endif
    // Now let us set the necessary global-to-local ID maps so that A*x operations
    // can be performed cleanly as if map was computed online
    row_dtoc_dofmap.clear();
    // row_dtoc_dofmap.reserve( nB / size );
    col_dtoc_dofmap.clear();
    rowMap.clear();
    colMap.clear();
    // col_dtoc_dofmap.reserve( 2 * nA / size );
    // row_dtoc_dofmap.resize( m_nTotDofs_Dest, UINT_MAX );
    // col_dtoc_dofmap.resize( m_nTotDofs_SrcCov, UINT_MAX );
#ifdef MOAB_HAVE_MPI
    // bother with tuple list only if size > 1
    // otherwise, just fill the sparse matrix
    if( size > 1 )
        std::vector< int > ownership;
        // the default trivial partitioning scheme
        int nDofs = nB;                   // this is for row partitioning
        if( !row_partition ) nDofs = nA;  // column partitioning
        // assert(row_major_ownership == true); // this block is valid only for row-based partitioning
        ownership.resize( size );
        int nPerPart   = nDofs / size;
        int nRemainder = nDofs % size;  // Keep the remainder in root
        ownership[0]   = nPerPart + nRemainder;
        for( int ip = 1, roffset = ownership[0]; ip < size; ++ip )
            roffset += nPerPart;
            ownership[ip] = roffset;
        moab::TupleList* tl = new moab::TupleList;
        unsigned numr       = 1;                     //
        tl->initialize( 3, 0, 0, numr, localSize );  // to proc, row, col, value
        tl->enableWriteAccess();
        // populate
        for( int i = 0; i < localSize; i++ )
            int rowval  = vecRow[i] - 1;  // dofs are 1 based in the file
            int colval  = vecCol[i] - 1;
            int to_proc = -1;
            int dof_val = colval;
            if( row_partition ) dof_val = rowval;
            if( ownership[0] > dof_val )
                to_proc = 0;
            else
                for( int ip = 1; ip < size; ++ip )
                    if( ownership[ip - 1] <= dof_val && ownership[ip] > dof_val )
                        to_proc = ip;
                        break;
            int n                = tl->get_n();
            tl->vi_wr[3 * n]     = to_proc;
            tl->vi_wr[3 * n + 1] = rowval;
            tl->vi_wr[3 * n + 2] = colval;
            tl->vr_wr[n]         = vecS[i];
            tl->inc_n();
        // heavy communication
        ( m_pcomm->proc_config().crystal_router() )->gs_transfer( 1, *tl, 0 );
        if( owned_dof_ids.size() > 0 )
            // we need to send desired dof to the rendez_vous point
            moab::TupleList tl_re;                                 //
            tl_re.initialize( 2, 0, 0, 0, owned_dof_ids.size() );  // to proc, value
            tl_re.enableWriteAccess();
            // send first to rendez_vous point, decided by trivial partitioning
            for( size_t i = 0; i < owned_dof_ids.size(); i++ )
                int to_proc = -1;
                int dof_val = owned_dof_ids[i] - 1;  // dofs are 1 based in the file, partition from 0 ?
                    to_proc = 0;
                else
                            to_proc = ip;
                            break;
                int n                  = tl_re.get_n();
                tl_re.vi_wr[2 * n]     = to_proc;
                tl_re.vi_wr[2 * n + 1] = dof_val;
                tl_re.inc_n();
            ( m_pcomm->proc_config().crystal_router() )->gs_transfer( 1, tl_re, 0 );
            // now we know in tl_re where do we need to send back dof_val
            moab::TupleList::buffer sort_buffer;
            sort_buffer.buffer_init( tl_re.get_n() );
            tl_re.sort( 1, &sort_buffer );  // so now we order by value
            sort_buffer.buffer_init( tl->get_n() );
            int indexOrder = 2;                  //  colVal
            if( row_partition ) indexOrder = 1;  //  rowVal
            //tl->sort( indexOrder, &sort_buffer );
            std::map< int, int > startDofIndex, endDofIndex;  // indices in tl_re for values we want
            int dofVal = -1;
            if( tl_re.get_n() > 0 ) dofVal = tl_re.vi_rd[1];  // first dof val on this rank
            startDofIndex[dofVal] = 0;
            endDofIndex[dofVal]   = 0;  // start and end
            for( unsigned k = 1; k < tl_re.get_n(); k++ )
                int newDof = tl_re.vi_rd[2 * k + 1];
                if( dofVal == newDof )
                    endDofIndex[dofVal] = k;  // increment by 1 actually
                else
                    dofVal                = newDof;
                    startDofIndex[dofVal] = k;
            // basically, for each value we are interested in, index in tl_re with those values are
            // tl_re.vi_rd[2*startDofIndex+1] == valDof == tl_re.vi_rd[2*endDofIndex+1]
            // so now we have ordered
            // tl_re shows to what proc do we need to send the tuple (row, col, val)
            moab::TupleList* tl_back = new moab::TupleList;
            // localSize is a good guess, but maybe it should be bigger ?
            // this could be bigger for repeated dofs
            tl_back->initialize( 3, 0, 0, numr, tl->get_n() );  // to proc, row, col, value
            tl_back->enableWriteAccess();
            // now loop over tl and tl_re to see where to send
            // form the new tuple, which will contain the desired dofs per task, per row or column distribution
            for( unsigned k = 0; k < tl->get_n(); k++ )
                int valDof = tl->vi_rd[3 * k + indexOrder];  // 1 for row, 2 for column // first value, it should be
                for( int ire = startDofIndex[valDof]; ire <= endDofIndex[valDof]; ire++ )
                    int to_proc               = tl_re.vi_rd[2 * ire];
                    int n                     = tl_back->get_n();
                    tl_back->vi_wr[3 * n]     = to_proc;
                    tl_back->vi_wr[3 * n + 1] = tl->vi_rd[3 * k + 1];  // row
                    tl_back->vi_wr[3 * n + 2] = tl->vi_rd[3 * k + 2];  // col
                    tl_back->vr_wr[n]         = tl->vr_rd[k];
                    tl_back->inc_n();
            // now communicate to the desired tasks:
            ( m_pcomm->proc_config().crystal_router() )->gs_transfer( 1, *tl_back, 0 );
            tl_re.reset();  // clear memory, although this will go out of scope
            tl->reset();
            tl = tl_back;
        int rindexMax = 0, cindexMax = 0;
        // populate the sparsematrix, using rowMap and colMap
        for( int i = 0; i < n; i++ )
            int rindex, cindex;
            const int& vecRowValue = tl->vi_wr[3 * i + 1];
            const int& vecColValue = tl->vi_wr[3 * i + 2];
            std::map< int, int >::iterator riter = rowMap.find( vecRowValue );
            if( riter == rowMap.end() )
                rowMap[vecRowValue] = rindexMax;
                rindex              = rindexMax;
                row_gdofmap.push_back( vecRowValue );
                // row_dtoc_dofmap.push_back( vecRowValue );
                rindexMax++;
            else
                rindex = riter->second;
            std::map< int, int >::iterator citer = colMap.find( vecColValue );
            if( citer == colMap.end() )
                colMap[vecColValue] = cindexMax;
                cindex              = cindexMax;
                col_gdofmap.push_back( vecColValue );
                // col_dtoc_dofmap.push_back( vecColValue );
                cindexMax++;
            else
                cindex = citer->second;
            sparseMatrix( rindex, cindex ) = tl->vr_wr[i];
        tl->reset();
    else
#endif
        for( int i = 0; i < nS; i++ )
            int rindex, cindex;
            const int& vecRowValue = vecRow[i] - 1;  // the rows, cols are 1 based in the file
            const int& vecColValue = vecCol[i] - 1;
                rindex              = rindexMax;
                rindexMax++;
            else
                cindex              = cindexMax;
                cindexMax++;
            else
            sparseMatrix( rindex, cindex ) = vecS[i];
    m_nTotDofs_SrcCov = sparseMatrix.GetColumns();
    m_nTotDofs_Dest   = sparseMatrix.GetRows();
    this->copy_tempest_sparsemat_to_eigen3();
#endif
    // Reset the source and target data first
    m_rowVector.setZero();
    m_colVector.setZero();
    return moab::MB_SUCCESS;
moab::ErrorCode moab::TempestOnlineMap::set_col_dc_dofs ( std::vector< int > &  values_entities)
Definition at line 687 of file TempestOnlineMap.cpp.
References MB_SUCCESS.
    // col_gdofmap has global dofs , that should be in the list of values, such that
    // row_dtoc_dofmap[offsetDOF] = localDOF;
    // //  we need to find col_dtoc_dofmap such that: col_gdofmap[ col_dtoc_dofmap[i] ] == values_entities [i];
    // we know that col_gdofmap[0..(nbcols-1)] = global_col_dofs -> in values_entities
    // form first inverse
    col_dtoc_dofmap.resize( values_entities.size() );
    for( int j = 0; j < (int)values_entities.size(); j++ )
        if( colMap.find( values_entities[j] - 1 ) != colMap.end() )
            col_dtoc_dofmap[j] = colMap[values_entities[j] - 1];
        else
            col_dtoc_dofmap[j] = -1;  // signal that this value should not be used in
            // std::cout <<"values_entities[j] -  1: " << values_entities[j] -  1 <<" at index j = " << j <<  " not
            // found in colMap \n";
moab::ErrorCode moab::TempestOnlineMap::set_row_dc_dofs ( std::vector< int > &  values_entities)
Definition at line 710 of file TempestOnlineMap.cpp.
    // row_dtoc_dofmap = values_entities; // needs to point to local
    //  we need to find row_dtoc_dofmap such that: row_gdofmap[ row_dtoc_dofmap[i] ] == values_entities [i];
    row_dtoc_dofmap.resize( values_entities.size() );
        if( rowMap.find( values_entities[j] - 1 ) != rowMap.end() )
            row_dtoc_dofmap[j] = rowMap[values_entities[j] - 1];  // values are 1 based, but rowMap, colMap are not
        else
            row_dtoc_dofmap[j] = -1;  // not all values are used
            // found in rowMap \n";
Get the number of Degrees-Of-Freedom per element on the destination mesh.
Definition at line 508 of file TempestOnlineMap.hpp.
    m_nDofsPEl_Dest = nt;
moab::ErrorCode moab::TempestOnlineMap::SetDOFmapAssociation ( DiscretizationType  srcType,
bool  isSrcContinuous,
DataArray3D< int > *  srcdataGLLNodes,
DataArray3D< int > *  srcdataGLLNodesSrc,
DiscretizationType  destType,
bool  isDestContinuous,
DataArray3D< int > *  tgtdataGLLNodes
Compute the association between the solution tag global DoF numbering and the local matrix numbering so that matvec operations can be performed consistently.
Definition at line 214 of file TempestOnlineMap.cpp.
References ErrorCode, MB_CHK_ERR, MB_SUCCESS, and rank.
    moab::ErrorCode rval;
    std::vector< bool > dgll_cgll_row_ldofmap, dgll_cgll_col_ldofmap, dgll_cgll_covcol_ldofmap;
    std::vector< int > src_soln_gdofs, locsrc_soln_gdofs, tgt_soln_gdofs;
    // We are assuming that these are element based tags that are sized: np * np
    m_srcDiscType  = srcType;
    m_destDiscType = destType;
    bool vprint = is_root && false;
#ifdef VVERBOSE
        src_soln_gdofs.resize( m_remapper->m_covering_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src, -1 );
        rval = m_interface->tag_get_data( m_dofTagSrc, m_remapper->m_covering_source_entities, &src_soln_gdofs[0] );MB_CHK_ERR( rval );
        locsrc_soln_gdofs.resize( m_remapper->m_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src );
        rval = m_interface->tag_get_data( m_dofTagSrc, m_remapper->m_source_entities, &locsrc_soln_gdofs[0] );MB_CHK_ERR( rval );
        tgt_soln_gdofs.resize( m_remapper->m_target_entities.size() * m_nDofsPEl_Dest * m_nDofsPEl_Dest );
        rval = m_interface->tag_get_data( m_dofTagDest, m_remapper->m_target_entities, &tgt_soln_gdofs[0] );MB_CHK_ERR( rval );
        if( is_root )
                std::ofstream output_file( "sourcecov-gids-0.txt" );
                output_file << "I, GDOF\n";
                for( unsigned i = 0; i < src_soln_gdofs.size(); ++i )
                    output_file << i << ", " << src_soln_gdofs[i] << "\n";
                output_file << "ELEMID, IDOF, LDOF, GDOF, NDOF\n";
                m_nTotDofs_SrcCov = 0;
                if( isSrcContinuous )
                    dgll_cgll_covcol_ldofmap.resize(
                        m_remapper->m_covering_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src, false );
                for( unsigned j = 0; j < m_remapper->m_covering_source_entities.size(); j++ )
                    for( int p = 0; p < m_nDofsPEl_Src; p++ )
                        for( int q = 0; q < m_nDofsPEl_Src; q++ )
                            const int localDOF  = ( *srcdataGLLNodes )[p][q][j] - 1;
                            const int offsetDOF = j * m_nDofsPEl_Src * m_nDofsPEl_Src + p * m_nDofsPEl_Src + q;
                            if( isSrcContinuous && !dgll_cgll_covcol_ldofmap[localDOF] )
                                m_nTotDofs_SrcCov++;
                                dgll_cgll_covcol_ldofmap[localDOF] = true;
                            output_file << m_remapper->lid_to_gid_covsrc[j] << ", " << offsetDOF << ", " << localDOF
                                        << ", " << src_soln_gdofs[offsetDOF] << ", " << m_nTotDofs_SrcCov << "\n";
                dgll_cgll_covcol_ldofmap.clear();
                std::ofstream output_file( "source-gids-0.txt" );
                for( unsigned i = 0; i < locsrc_soln_gdofs.size(); ++i )
                    output_file << i << ", " << locsrc_soln_gdofs[i] << "\n";
                m_nTotDofs_Src = 0;
                    dgll_cgll_col_ldofmap.resize(
                        m_remapper->m_source_entities.size() * m_nDofsPEl_Src * m_nDofsPEl_Src, false );
                for( unsigned j = 0; j < m_remapper->m_source_entities.size(); j++ )
                            const int localDOF  = ( *srcdataGLLNodesSrc )[p][q][j] - 1;
                            if( isSrcContinuous && !dgll_cgll_col_ldofmap[localDOF] )
                                m_nTotDofs_Src++;
                                dgll_cgll_col_ldofmap[localDOF] = true;
                            output_file << m_remapper->lid_to_gid_src[j] << ", " << offsetDOF << ", " << localDOF
                                        << ", " << locsrc_soln_gdofs[offsetDOF] << ", " << m_nTotDofs_Src << "\n";
                dgll_cgll_col_ldofmap.clear();
                std::ofstream output_file( "target-gids-0.txt" );
                for( unsigned i = 0; i < tgt_soln_gdofs.size(); ++i )
                    output_file << i << ", " << tgt_soln_gdofs[i] << "\n";
                output_file << "ELEMID, IDOF, GDOF, NDOF\n";
                m_nTotDofs_Dest = 0;
                    output_file << m_remapper->lid_to_gid_tgt[i] << ", " << i << ", " << tgt_soln_gdofs[i] << ", "
                                << m_nTotDofs_Dest << "\n";
                    m_nTotDofs_Dest++;
        else
                std::ofstream output_file( "sourcecov-gids-1.txt" );
                std::ofstream output_file( "source-gids-1.txt" );
                m_nTotDofs_Src = 0;
                                m_nTotDofs_Src++;
                std::ofstream output_file( "target-gids-1.txt" );
                    m_nTotDofs_Dest++;
#endif
    // Now compute the mapping and store it for the covering mesh
    int srcTagSize = ( m_eInputType == DiscretizationType_FV ? 1 : m_nDofsPEl_Src * m_nDofsPEl_Src );
    if( m_remapper->point_cloud_source )
        assert( m_nDofsPEl_Src == 1 );
        col_gdofmap.resize( m_remapper->m_covering_source_vertices.size(), UINT_MAX );
        col_dtoc_dofmap.resize( m_remapper->m_covering_source_vertices.size(), UINT_MAX );
        src_soln_gdofs.resize( m_remapper->m_covering_source_vertices.size(), UINT_MAX );
        rval = m_interface->tag_get_data( m_dofTagSrc, m_remapper->m_covering_source_vertices, &src_soln_gdofs[0] );MB_CHK_ERR( rval );
        srcTagSize = 1;
    else
        col_gdofmap.resize( m_remapper->m_covering_source_entities.size() * srcTagSize, UINT_MAX );
        col_dtoc_dofmap.resize( m_remapper->m_covering_source_entities.size() * srcTagSize, UINT_MAX );
        src_soln_gdofs.resize( m_remapper->m_covering_source_entities.size() * srcTagSize, UINT_MAX );
    // std::cout << "TOnlineMap: Process: " << rank << " and covering entities = [" <<
    // col_dofmap.size() << ", " << src_soln_gdofs.size() << "]\n"; MPI_Barrier(MPI_COMM_WORLD);
#ifdef ALTERNATE_NUMBERING_IMPLEMENTATION
    unsigned maxSrcIndx = 0;
    // for ( unsigned j = 0; j < m_covering_source_entities.size(); j++ )
    std::vector< int > locdofs( srcTagSize );
    std::map< Node, moab::EntityHandle > mapLocalMBNodes;
    double elcoords[3];
    for( unsigned iel = 0; iel < m_remapper->m_covering_source_entities.size(); ++iel )
        EntityHandle eh = m_remapper->m_covering_source_entities[iel];
        rval            = m_interface->get_coords( &eh, 1, elcoords );MB_CHK_ERR( rval );
        Node elCentroid( elcoords[0], elcoords[1], elcoords[2] );
        mapLocalMBNodes.insert( std::pair< Node, moab::EntityHandle >( elCentroid, eh ) );
    const NodeVector& nodes = m_remapper->m_covering_source->nodes;
    for( unsigned j = 0; j < m_remapper->m_covering_source->faces.size(); j++ )
        const Face& face = m_remapper->m_covering_source->faces[j];
        Node centroid;
        centroid.x = centroid.y = centroid.z = 0.0;
        for( unsigned l = 0; l < face.edges.size(); ++l )
            centroid.x += nodes[face[l]].x;
            centroid.y += nodes[face[l]].y;
            centroid.z += nodes[face[l]].z;
        const double factor = 1.0 / face.edges.size();
        centroid.x *= factor;
        centroid.y *= factor;
        centroid.z *= factor;
        EntityHandle current_eh;
        if( mapLocalMBNodes.find( centroid ) != mapLocalMBNodes.end() )
            current_eh = mapLocalMBNodes[centroid];
        rval = m_interface->tag_get_data( m_dofTagSrc, &current_eh, 1, &locdofs[0] );MB_CHK_ERR( rval );
                const int offsetDOF = p * m_nDofsPEl_Src + q;
                maxSrcIndx          = ( localDOF > maxSrcIndx ? localDOF : maxSrcIndx );
                std::cout << "Col: " << current_eh << ", " << m_remapper->lid_to_gid_covsrc[j] << ", " << offsetDOF
                          << ", " << localDOF << ", " << locdofs[offsetDOF] - 1 << ", " << maxSrcIndx << "\n";
#endif
    if( srcdataGLLNodes == NULL )
    { /* we only have a mapping for elements as DoFs */
        for( unsigned i = 0; i < col_gdofmap.size(); ++i )
            assert( src_soln_gdofs[i] > 0 );
            col_gdofmap[i]     = src_soln_gdofs[i] - 1;
            col_dtoc_dofmap[i] = i;
            if( vprint ) std::cout << "Col: " << i << ", " << col_gdofmap[i] << "\n";
    else
            dgll_cgll_covcol_ldofmap.resize( m_remapper->m_covering_source_entities.size() * srcTagSize, false );
                    const int offsetDOF = j * srcTagSize + p * m_nDofsPEl_Src + q;
                    if( !isSrcContinuous ) m_nTotDofs_SrcCov++;
                    assert( src_soln_gdofs[offsetDOF] > 0 );
                    col_gdofmap[localDOF]      = src_soln_gdofs[offsetDOF] - 1;
                    col_dtoc_dofmap[offsetDOF] = localDOF;
                    if( vprint )
                        std::cout << "Col: " << m_remapper->lid_to_gid_covsrc[j] << ", " << offsetDOF << ", "
                                  << localDOF << ", " << col_gdofmap[offsetDOF] << ", " << m_nTotDofs_SrcCov << "\n";
        srccol_gdofmap.resize( m_remapper->m_source_vertices.size(), UINT_MAX );
        srccol_dtoc_dofmap.resize( m_remapper->m_covering_source_vertices.size(), UINT_MAX );
        locsrc_soln_gdofs.resize( m_remapper->m_source_vertices.size(), UINT_MAX );
        rval = m_interface->tag_get_data( m_dofTagSrc, m_remapper->m_source_vertices, &locsrc_soln_gdofs[0] );MB_CHK_ERR( rval );
    else
        srccol_gdofmap.resize( m_remapper->m_source_entities.size() * srcTagSize, UINT_MAX );
        srccol_dtoc_dofmap.resize( m_remapper->m_source_entities.size() * srcTagSize, UINT_MAX );
        locsrc_soln_gdofs.resize( m_remapper->m_source_entities.size() * srcTagSize, UINT_MAX );
    // Now compute the mapping and store it for the original source mesh
    m_nTotDofs_Src = 0;
    if( srcdataGLLNodesSrc == NULL )
        for( unsigned i = 0; i < srccol_gdofmap.size(); ++i )
            assert( locsrc_soln_gdofs[i] > 0 );
            srccol_gdofmap[i]     = locsrc_soln_gdofs[i] - 1;
            srccol_dtoc_dofmap[i] = i;
            m_nTotDofs_Src++;
    else
        if( isSrcContinuous ) dgll_cgll_col_ldofmap.resize( m_remapper->m_source_entities.size() * srcTagSize, false );
                        m_nTotDofs_Src++;
                    if( !isSrcContinuous ) m_nTotDofs_Src++;
                    assert( locsrc_soln_gdofs[offsetDOF] > 0 );
                    srccol_gdofmap[localDOF]      = locsrc_soln_gdofs[offsetDOF] - 1;
                    srccol_dtoc_dofmap[offsetDOF] = localDOF;
    int tgtTagSize = ( m_eOutputType == DiscretizationType_FV ? 1 : m_nDofsPEl_Dest * m_nDofsPEl_Dest );
    if( m_remapper->point_cloud_target )
        assert( m_nDofsPEl_Dest == 1 );
        row_gdofmap.resize( m_remapper->m_target_vertices.size(), UINT_MAX );
        row_dtoc_dofmap.resize( m_remapper->m_target_vertices.size(), UINT_MAX );
        tgt_soln_gdofs.resize( m_remapper->m_target_vertices.size(), UINT_MAX );
        rval = m_interface->tag_get_data( m_dofTagDest, m_remapper->m_target_vertices, &tgt_soln_gdofs[0] );MB_CHK_ERR( rval );
        tgtTagSize = 1;
    else
        row_gdofmap.resize( m_remapper->m_target_entities.size() * tgtTagSize, UINT_MAX );
        row_dtoc_dofmap.resize( m_remapper->m_target_entities.size() * tgtTagSize, UINT_MAX );
        tgt_soln_gdofs.resize( m_remapper->m_target_entities.size() * tgtTagSize, UINT_MAX );
    // Now compute the mapping and store it for the target mesh
    // To access the GID for each row: row_gdofmap [ row_ldofmap [ 0 : local_ndofs ] ] = GDOF
    if( tgtdataGLLNodes == NULL )
        for( unsigned i = 0; i < row_gdofmap.size(); ++i )
            assert( tgt_soln_gdofs[i] > 0 );
            row_gdofmap[i]     = tgt_soln_gdofs[i] - 1;
            row_dtoc_dofmap[i] = i;
            if( vprint ) std::cout << "Row: " << i << ", " << row_gdofmap[i] << "\n";
            m_nTotDofs_Dest++;
    else
        if( isTgtContinuous ) dgll_cgll_row_ldofmap.resize( m_remapper->m_target_entities.size() * tgtTagSize, false );
        for( unsigned j = 0; j < m_remapper->m_target_entities.size(); j++ )
            for( int p = 0; p < m_nDofsPEl_Dest; p++ )
                for( int q = 0; q < m_nDofsPEl_Dest; q++ )
                    const int localDOF  = ( *tgtdataGLLNodes )[p][q][j] - 1;
                    const int offsetDOF = j * tgtTagSize + p * m_nDofsPEl_Dest + q;
                    if( isTgtContinuous && !dgll_cgll_row_ldofmap[localDOF] )
                        m_nTotDofs_Dest++;
                        dgll_cgll_row_ldofmap[localDOF] = true;
                    if( !isTgtContinuous ) m_nTotDofs_Dest++;
                    assert( tgt_soln_gdofs[offsetDOF] > 0 );
                    row_gdofmap[localDOF]      = tgt_soln_gdofs[offsetDOF] - 1;
                    if( vprint )
                        std::cout << "Row: " << m_remapper->lid_to_gid_tgt[j] << ", " << offsetDOF << ", " << localDOF
                                  << ", " << row_gdofmap[offsetDOF] << ", " << m_nTotDofs_Dest << "\n";
    // Let us also allocate the local representation of the sparse matrix
#if defined( MOAB_HAVE_EIGEN3 ) && defined( VERBOSE )
    if( vprint )
        std::cout << "[" << rank << "]"
                  << "DoFs: row = " << m_nTotDofs_Dest << ", " << row_gdofmap.size() << ", col = " << m_nTotDofs_Src
                  << ", " << m_nTotDofs_SrcCov << ", " << col_gdofmap.size() << "\n";
        // std::cout << "Max col_dofmap: " << maxcol << ", Min col_dofmap" << mincol << "\n";
#endif
    // check monotonicity of row_gdofmap and col_gdofmap
#ifdef CHECK_INCREASING_DOF
    for( size_t i = 0; i < row_gdofmap.size() - 1; i++ )
        if( row_gdofmap[i] > row_gdofmap[i + 1] )
            std::cout << " on rank " << rank << " in row_gdofmap[" << i << "]=" << row_gdofmap[i] << " > row_gdofmap["
                      << i + 1 << "]=" << row_gdofmap[i + 1] << " \n";
    for( size_t i = 0; i < col_gdofmap.size() - 1; i++ )
        if( col_gdofmap[i] > col_gdofmap[i + 1] )
            std::cout << " on rank " << rank << " in col_gdofmap[" << i << "]=" << col_gdofmap[i] << " > col_gdofmap["
                      << i + 1 << "]=" << col_gdofmap[i + 1] << " \n";
#endif
moab::ErrorCode moab::TempestOnlineMap::SetDOFmapTags ( const std::string  srcDofTagName,
const std::string  tgtDofTagName
Store the tag names associated with global DoF ids for source and target meshes.
Definition at line 158 of file TempestOnlineMap.cpp.
References ErrorCode, ierr, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_ANY, MB_TAG_NOT_FOUND, and MB_TYPE_INTEGER.
    int tagSize = 0;
    tagSize     = ( m_eInputType == DiscretizationType_FV ? 1 : m_nDofsPEl_Src * m_nDofsPEl_Src );
    rval =
        m_interface->tag_get_handle( srcDofTagName.c_str(), tagSize, MB_TYPE_INTEGER, this->m_dofTagSrc, MB_TAG_ANY );
    if( rval == moab::MB_TAG_NOT_FOUND && m_eInputType != DiscretizationType_FV )
        int ntot_elements = 0, nelements = m_remapper->m_source_entities.size();
        int ierr = MPI_Allreduce( &nelements, &ntot_elements, 1, MPI_INT, MPI_SUM, m_pcomm->comm() );
        if( ierr != 0 ) MB_CHK_SET_ERR( MB_FAILURE, "MPI_Allreduce failed to get total source elements" );
#else
        ntot_elements = nelements;
#endif
        rval = m_remapper->GenerateCSMeshMetadata( ntot_elements, m_remapper->m_covering_source_entities,
                                                   &m_remapper->m_source_entities, srcDofTagName, m_nDofsPEl_Src );MB_CHK_ERR( rval );
        rval = m_interface->tag_get_handle( srcDofTagName.c_str(), m_nDofsPEl_Src * m_nDofsPEl_Src, MB_TYPE_INTEGER,
                                            this->m_dofTagSrc, MB_TAG_ANY );MB_CHK_ERR( rval );
    else
        MB_CHK_ERR( rval );
    tagSize = ( m_eOutputType == DiscretizationType_FV ? 1 : m_nDofsPEl_Dest * m_nDofsPEl_Dest );
    rval =
        m_interface->tag_get_handle( tgtDofTagName.c_str(), tagSize, MB_TYPE_INTEGER, this->m_dofTagDest, MB_TAG_ANY );
    if( rval == moab::MB_TAG_NOT_FOUND && m_eOutputType != DiscretizationType_FV )
        int ntot_elements = 0, nelements = m_remapper->m_target_entities.size();
#else
#endif
        rval = m_remapper->GenerateCSMeshMetadata( ntot_elements, m_remapper->m_target_entities, NULL, tgtDofTagName,
                                                   m_nDofsPEl_Dest );MB_CHK_ERR( rval );
        rval = m_interface->tag_get_handle( tgtDofTagName.c_str(), m_nDofsPEl_Dest * m_nDofsPEl_Dest, MB_TYPE_INTEGER,
                                            this->m_dofTagDest, MB_TAG_ANY );MB_CHK_ERR( rval );
    else
        MB_CHK_ERR( rval );
Set the number of Degrees-Of-Freedom per element on the source mesh.
Definition at line 503 of file TempestOnlineMap.hpp.
    m_nDofsPEl_Src = ns;
Definition at line 98 of file TempestOnlineMap.cpp.
References moab::TempestRemapper::RLL.
Referenced by TempestOnlineMap().
    if( m_meshInputCov )
        std::vector< std::string > dimNames;
        std::vector< int > dimSizes;
        if( m_remapper->m_source_type == moab::TempestRemapper::RLL && m_remapper->m_source_metadata.size() )
            dimNames.push_back( "lat" );
            dimNames.push_back( "lon" );
            dimSizes.resize( 2, 0 );
            dimSizes[0] = m_remapper->m_source_metadata[1];
            dimSizes[1] = m_remapper->m_source_metadata[2];
        else
            dimNames.push_back( "num_elem" );
            dimSizes.push_back( m_meshInputCov->faces.size() );
        this->InitializeSourceDimensions( dimNames, dimSizes );
    if( m_meshOutput )
        if( m_remapper->m_target_type == moab::TempestRemapper::RLL && m_remapper->m_target_metadata.size() )
            dimSizes[0] = m_remapper->m_target_metadata[1];
            dimSizes[1] = m_remapper->m_target_metadata[2];
        else
            dimSizes.push_back( m_meshOutput->faces.size() );
        this->InitializeTargetDimensions( dimNames, dimSizes );
moab::ErrorCode moab::TempestOnlineMap::WriteHDF5MapFile ( const std::string &  filename) [private]
Parallel I/O with NetCDF to write out the SCRIP file from multiple processors.
Need to get the global maximum of number of vertices per element Key issue is that when calling InitializeCoordinatesFromMeshFV, the allocation for dVertexLon/dVertexLat are made based on the maximum vertices in the current process. However, when writing this out, other processes may have a different size for the same array. This is hence a mess to consolidate in h5mtoscrip eventually.
Definition at line 764 of file TempestOnlineMapIO.cpp.
References ErrorCode, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TAG_VARLEN, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, rank, moab::TempestRemapper::RLL, root_set, size, and t.
     * Need to get the global maximum of number of vertices per element
     * Key issue is that when calling InitializeCoordinatesFromMeshFV, the allocation for
     *dVertexLon/dVertexLat are made based on the maximum vertices in the current process. However,
     *when writing this out, other processes may have a different size for the same array. This is
     *hence a mess to consolidate in h5mtoscrip eventually.
    /* Let us compute all relevant data for the current original source mesh on the process */
    DataArray1D< double > vecSourceFaceArea, vecTargetFaceArea;
    DataArray1D< double > dSourceCenterLon, dSourceCenterLat, dTargetCenterLon, dTargetCenterLat;
    DataArray2D< double > dSourceVertexLon, dSourceVertexLat, dTargetVertexLon, dTargetVertexLat;
    if( m_srcDiscType == DiscretizationType_FV || m_srcDiscType == DiscretizationType_PCLOUD )
        this->InitializeCoordinatesFromMeshFV(
            *m_meshInput, dSourceCenterLon, dSourceCenterLat, dSourceVertexLon, dSourceVertexLat,
            ( this->m_remapper->m_source_type == moab::TempestRemapper::RLL ) /* fLatLon = false */,
            m_remapper->max_source_edges );
        vecSourceFaceArea.Allocate( m_meshInput->vecFaceArea.GetRows() );
        for( unsigned i = 0; i < m_meshInput->vecFaceArea.GetRows(); ++i )
            vecSourceFaceArea[i] = m_meshInput->vecFaceArea[i];
    else
        DataArray3D< double > dataGLLJacobianSrc;
        this->InitializeCoordinatesFromMeshFE( *m_meshInput, m_nDofsPEl_Src, dataGLLNodesSrc, dSourceCenterLon,
                                               dSourceCenterLat, dSourceVertexLon, dSourceVertexLat );
        // Generate the continuous Jacobian for input mesh
        GenerateMetaData( *m_meshInput, m_nDofsPEl_Src, false /* fBubble */, dataGLLNodesSrc, dataGLLJacobianSrc );
        if( m_srcDiscType == DiscretizationType_CGLL )
            GenerateUniqueJacobian( dataGLLNodesSrc, dataGLLJacobianSrc, m_meshInput->vecFaceArea );
        else
            GenerateDiscontinuousJacobian( dataGLLJacobianSrc, m_meshInput->vecFaceArea );
        vecSourceFaceArea.Allocate( m_meshInput->faces.size() * m_nDofsPEl_Src * m_nDofsPEl_Src );
        int offset = 0;
        for( size_t e = 0; e < m_meshInput->faces.size(); e++ )
            for( int s = 0; s < m_nDofsPEl_Src; s++ )
                for( int t = 0; t < m_nDofsPEl_Src; t++ )
                    vecSourceFaceArea[srccol_dtoc_dofmap[offset + s * m_nDofsPEl_Src + t]] =
                        dataGLLJacobianSrc[s][t][e];
            offset += m_nDofsPEl_Src * m_nDofsPEl_Src;
    if( m_destDiscType == DiscretizationType_FV || m_destDiscType == DiscretizationType_PCLOUD )
            *m_meshOutput, dTargetCenterLon, dTargetCenterLat, dTargetVertexLon, dTargetVertexLat,
            ( this->m_remapper->m_target_type == moab::TempestRemapper::RLL ) /* fLatLon = false */,
            m_remapper->max_target_edges );
        vecTargetFaceArea.Allocate( m_meshOutput->vecFaceArea.GetRows() );
        for( unsigned i = 0; i < m_meshOutput->vecFaceArea.GetRows(); ++i )
            vecTargetFaceArea[i] = m_meshOutput->vecFaceArea[i];
    else
        DataArray3D< double > dataGLLJacobianDest;
        this->InitializeCoordinatesFromMeshFE( *m_meshOutput, m_nDofsPEl_Dest, dataGLLNodesDest, dTargetCenterLon,
                                               dTargetCenterLat, dTargetVertexLon, dTargetVertexLat );
        GenerateMetaData( *m_meshOutput, m_nDofsPEl_Dest, false /* fBubble */, dataGLLNodesDest, dataGLLJacobianDest );
        if( m_destDiscType == DiscretizationType_CGLL )
            GenerateUniqueJacobian( dataGLLNodesDest, dataGLLJacobianDest, m_meshOutput->vecFaceArea );
        else
            GenerateDiscontinuousJacobian( dataGLLJacobianDest, m_meshOutput->vecFaceArea );
        vecTargetFaceArea.Allocate( m_meshOutput->faces.size() * m_nDofsPEl_Dest * m_nDofsPEl_Dest );
        int offset = 0;
        for( size_t e = 0; e < m_meshOutput->faces.size(); e++ )
            for( int s = 0; s < m_nDofsPEl_Dest; s++ )
                for( int t = 0; t < m_nDofsPEl_Dest; t++ )
                    vecTargetFaceArea[row_dtoc_dofmap[offset + s * m_nDofsPEl_Dest + t]] = dataGLLJacobianDest[s][t][e];
            offset += m_nDofsPEl_Dest * m_nDofsPEl_Dest;
    moab::EntityHandle& m_meshOverlapSet = m_remapper->m_overlap_set;
    int tot_src_ents                     = m_remapper->m_source_entities.size();
    int tot_tgt_ents                     = m_remapper->m_target_entities.size();
    int tot_src_size                     = dSourceCenterLon.GetRows();
    int tot_tgt_size                     = m_dTargetCenterLon.GetRows();
    int tot_vsrc_size                    = dSourceVertexLon.GetRows() * dSourceVertexLon.GetColumns();
    int tot_vtgt_size                    = m_dTargetVertexLon.GetRows() * m_dTargetVertexLon.GetColumns();
    const int weightMatNNZ = m_weightMatrix.nonZeros();
    moab::Tag tagMapMetaData, tagMapIndexRow, tagMapIndexCol, tagMapValues, srcEleIDs, tgtEleIDs;
    rval = m_interface->tag_get_handle( "SMAT_DATA", 13, moab::MB_TYPE_INTEGER, tagMapMetaData,
                                        moab::MB_TAG_CREAT | moab::MB_TAG_SPARSE );MB_CHK_SET_ERR( rval, "Retrieving tag handles failed" );
    rval = m_interface->tag_get_handle( "SMAT_ROWS", weightMatNNZ, moab::MB_TYPE_INTEGER, tagMapIndexRow,
                                        moab::MB_TAG_CREAT | moab::MB_TAG_SPARSE | moab::MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Retrieving tag handles failed" );
    rval = m_interface->tag_get_handle( "SMAT_COLS", weightMatNNZ, moab::MB_TYPE_INTEGER, tagMapIndexCol,
    rval = m_interface->tag_get_handle( "SMAT_VALS", weightMatNNZ, moab::MB_TYPE_DOUBLE, tagMapValues,
    rval = m_interface->tag_get_handle( "SourceGIDS", tot_src_size, moab::MB_TYPE_INTEGER, srcEleIDs,
    rval = m_interface->tag_get_handle( "TargetGIDS", tot_tgt_size, moab::MB_TYPE_INTEGER, tgtEleIDs,
    moab::Tag srcAreaValues, tgtAreaValues;
    rval = m_interface->tag_get_handle( "SourceAreas", tot_src_size, moab::MB_TYPE_DOUBLE, srcAreaValues,
    rval = m_interface->tag_get_handle( "TargetAreas", tot_tgt_size, moab::MB_TYPE_DOUBLE, tgtAreaValues,
    moab::Tag tagSrcCoordsCLon, tagSrcCoordsCLat, tagTgtCoordsCLon, tagTgtCoordsCLat;
    rval = m_interface->tag_get_handle( "SourceCoordCenterLon", tot_src_size, moab::MB_TYPE_DOUBLE, tagSrcCoordsCLon,
    rval = m_interface->tag_get_handle( "SourceCoordCenterLat", tot_src_size, moab::MB_TYPE_DOUBLE, tagSrcCoordsCLat,
    rval = m_interface->tag_get_handle( "TargetCoordCenterLon", tot_tgt_size, moab::MB_TYPE_DOUBLE, tagTgtCoordsCLon,
    rval = m_interface->tag_get_handle( "TargetCoordCenterLat", tot_tgt_size, moab::MB_TYPE_DOUBLE, tagTgtCoordsCLat,
    moab::Tag tagSrcCoordsVLon, tagSrcCoordsVLat, tagTgtCoordsVLon, tagTgtCoordsVLat;
    rval = m_interface->tag_get_handle( "SourceCoordVertexLon", tot_vsrc_size, moab::MB_TYPE_DOUBLE, tagSrcCoordsVLon,
    rval = m_interface->tag_get_handle( "SourceCoordVertexLat", tot_vsrc_size, moab::MB_TYPE_DOUBLE, tagSrcCoordsVLat,
    rval = m_interface->tag_get_handle( "TargetCoordVertexLon", tot_vtgt_size, moab::MB_TYPE_DOUBLE, tagTgtCoordsVLon,
    rval = m_interface->tag_get_handle( "TargetCoordVertexLat", tot_vtgt_size, moab::MB_TYPE_DOUBLE, tagTgtCoordsVLat,
    moab::Tag srcMaskValues, tgtMaskValues;
    if( m_iSourceMask.IsAttached() )
        rval = m_interface->tag_get_handle( "SourceMask", m_iSourceMask.GetRows(), moab::MB_TYPE_INTEGER, srcMaskValues,
    if( m_iTargetMask.IsAttached() )
        rval = m_interface->tag_get_handle( "TargetMask", m_iTargetMask.GetRows(), moab::MB_TYPE_INTEGER, tgtMaskValues,
    std::vector< int > smatrowvals( weightMatNNZ ), smatcolvals( weightMatNNZ );
    std::vector< double > smatvals( weightMatNNZ );
    // const double* smatvals = m_weightMatrix.valuePtr();
    // Loop over the matrix entries and find the max global ID for rows and columns
    for( int k = 0, offset = 0; k < m_weightMatrix.outerSize(); ++k )
        for( moab::TempestOnlineMap::WeightMatrix::InnerIterator it( m_weightMatrix, k ); it; ++it, ++offset )
            smatrowvals[offset] = this->GetRowGlobalDoF( it.row() );
            smatcolvals[offset] = this->GetColGlobalDoF( it.col() );
            smatvals[offset]    = it.value();
    /* Set the global IDs for the DoFs */
    // col_gdofmap [ col_ldofmap [ 0 : local_ndofs ] ] = GDOF
    // row_gdofmap [ row_ldofmap [ 0 : local_ndofs ] ] = GDOF
    int maxrow = 0, maxcol = 0;
    std::vector< int > src_global_dofs( tot_src_size ), tgt_global_dofs( tot_tgt_size );
    for( int i = 0; i < tot_src_size; ++i )
        src_global_dofs[i] = srccol_gdofmap[i];
        maxcol             = ( src_global_dofs[i] > maxcol ) ? src_global_dofs[i] : maxcol;
    for( int i = 0; i < tot_tgt_size; ++i )
        tgt_global_dofs[i] = row_gdofmap[i];
        maxrow             = ( tgt_global_dofs[i] > maxrow ) ? tgt_global_dofs[i] : maxrow;
    // The metadata in H5M file contains the following data:
    //   1. n_a: Total source entities: (number of elements in source mesh)
    //   2. n_b: Total target entities: (number of elements in target mesh)
    //   3. nv_a: Max edge size of elements in source mesh
    //   4. nv_b: Max edge size of elements in target mesh
    //   5. maxrows: Number of rows in remap weight matrix
    //   6. maxcols: Number of cols in remap weight matrix
    //   7. nnz: Number of total nnz in sparse remap weight matrix
    //   8. np_a: The order of the field description on the source mesh: >= 1
    //   9. np_b: The order of the field description on the target mesh: >= 1
    //   10. method_a: The type of discretization for field on source mesh: [0 = FV, 1 = cGLL, 2 =
    //   dGLL]
    //   11. method_b: The type of discretization for field on target mesh: [0 = FV, 1 = cGLL, 2 =
    //   dGLL]
    //   12. conserved: Flag to specify whether the remap operator has conservation constraints: [0,
    //   1]
    //   13. monotonicity: Flags to specify whether the remap operator has monotonicity constraints:
    //   [0, 1, 2]
    int map_disc_details[6];
    map_disc_details[0] = m_nDofsPEl_Src;
    map_disc_details[1] = m_nDofsPEl_Dest;
    map_disc_details[2] = ( m_srcDiscType == DiscretizationType_FV || m_srcDiscType == DiscretizationType_PCLOUD
                                ? 0
                                : ( m_srcDiscType == DiscretizationType_CGLL ? 1 : 2 ) );
    map_disc_details[3] = ( m_destDiscType == DiscretizationType_FV || m_destDiscType == DiscretizationType_PCLOUD
                                ? 0
                                : ( m_destDiscType == DiscretizationType_CGLL ? 1 : 2 ) );
    map_disc_details[4] = ( m_bConserved ? 1 : 0 );
    map_disc_details[5] = m_iMonotonicity;
    int loc_smatmetadata[13] = { tot_src_ents,
                                 tot_tgt_ents,
                                 m_remapper->max_source_edges,
                                 m_remapper->max_target_edges,
                                 maxrow + 1,
                                 maxcol + 1,
                                 weightMatNNZ,
                                 map_disc_details[0],
                                 map_disc_details[1],
                                 map_disc_details[2],
                                 map_disc_details[3],
                                 map_disc_details[4],
                                 map_disc_details[5] };
    rval                     = m_interface->tag_set_data( tagMapMetaData, &m_meshOverlapSet, 1, &loc_smatmetadata[0] );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
    int glb_smatmetadata[13] = { 0,
                                 0,
                                 0,
                                 0,
                                 0,
                                 0,
                                 0,
    int loc_buf[7]           = {
        tot_src_ents, tot_tgt_ents, weightMatNNZ, m_remapper->max_source_edges, m_remapper->max_target_edges,
        maxrow,       maxcol };
    int glb_buf[4] = { 0, 0, 0, 0 };
    MPI_Reduce( &loc_buf[0], &glb_buf[0], 3, MPI_INT, MPI_SUM, 0, m_pcomm->comm() );
    glb_smatmetadata[0] = glb_buf[0];
    glb_smatmetadata[1] = glb_buf[1];
    glb_smatmetadata[6] = glb_buf[2];
    MPI_Reduce( &loc_buf[3], &glb_buf[0], 4, MPI_INT, MPI_MAX, 0, m_pcomm->comm() );
    glb_smatmetadata[2] = glb_buf[0];
    glb_smatmetadata[3] = glb_buf[1];
    glb_smatmetadata[4] = glb_buf[2];
    glb_smatmetadata[5] = glb_buf[3];
#else
    int glb_smatmetadata[13] = { tot_src_ents,
                                 tot_tgt_ents,
                                 maxrow,
                                 maxcol,
                                 weightMatNNZ,
#endif
    // These values represent number of rows and columns. So should be 1-based.
    glb_smatmetadata[4]++;
    glb_smatmetadata[5]++;
    if( this->is_root )
        std::cout << "  " << this->rank << "  Writing remap weights with size [" << glb_smatmetadata[4] << " X "
                  << glb_smatmetadata[5] << "] and NNZ = " << glb_smatmetadata[6] << std::endl;
        EntityHandle root_set = 0;
        rval                  = m_interface->tag_set_data( tagMapMetaData, &root_set, 1, &glb_smatmetadata[0] );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
    int dsize;
    const int numval          = weightMatNNZ;
    const void* smatrowvals_d = smatrowvals.data();
    const void* smatcolvals_d = smatcolvals.data();
    const void* smatvals_d    = smatvals.data();
    rval = m_interface->tag_set_by_ptr( tagMapIndexRow, &m_meshOverlapSet, 1, &smatrowvals_d, &numval );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
    rval = m_interface->tag_set_by_ptr( tagMapIndexCol, &m_meshOverlapSet, 1, &smatcolvals_d, &numval );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
    rval = m_interface->tag_set_by_ptr( tagMapValues, &m_meshOverlapSet, 1, &smatvals_d, &numval );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
    const void* srceleidvals_d = src_global_dofs.data();
    const void* tgteleidvals_d = tgt_global_dofs.data();
    dsize                      = src_global_dofs.size();
    rval = m_interface->tag_set_by_ptr( srcEleIDs, &m_meshOverlapSet, 1, &srceleidvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
    dsize = tgt_global_dofs.size();
    rval  = m_interface->tag_set_by_ptr( tgtEleIDs, &m_meshOverlapSet, 1, &tgteleidvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
    /* Set the source and target areas */
    const void* srcareavals_d = vecSourceFaceArea;
    const void* tgtareavals_d = vecTargetFaceArea;
    dsize                     = tot_src_size;
    rval = m_interface->tag_set_by_ptr( srcAreaValues, &m_meshOverlapSet, 1, &srcareavals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
    dsize = tot_tgt_size;
    rval  = m_interface->tag_set_by_ptr( tgtAreaValues, &m_meshOverlapSet, 1, &tgtareavals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
    /* Set the coordinates for source and target center vertices */
    const void* srccoordsclonvals_d = &dSourceCenterLon[0];
    const void* srccoordsclatvals_d = &dSourceCenterLat[0];
    dsize                           = dSourceCenterLon.GetRows();
    rval = m_interface->tag_set_by_ptr( tagSrcCoordsCLon, &m_meshOverlapSet, 1, &srccoordsclonvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
    rval = m_interface->tag_set_by_ptr( tagSrcCoordsCLat, &m_meshOverlapSet, 1, &srccoordsclatvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
    const void* tgtcoordsclonvals_d = &m_dTargetCenterLon[0];
    const void* tgtcoordsclatvals_d = &m_dTargetCenterLat[0];
    dsize                           = vecTargetFaceArea.GetRows();
    rval = m_interface->tag_set_by_ptr( tagTgtCoordsCLon, &m_meshOverlapSet, 1, &tgtcoordsclonvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
    rval = m_interface->tag_set_by_ptr( tagTgtCoordsCLat, &m_meshOverlapSet, 1, &tgtcoordsclatvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
    /* Set the coordinates for source and target element vertices */
    const void* srccoordsvlonvals_d = &( dSourceVertexLon[0][0] );
    const void* srccoordsvlatvals_d = &( dSourceVertexLat[0][0] );
    dsize                           = dSourceVertexLon.GetRows() * dSourceVertexLon.GetColumns();
    rval = m_interface->tag_set_by_ptr( tagSrcCoordsVLon, &m_meshOverlapSet, 1, &srccoordsvlonvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
    rval = m_interface->tag_set_by_ptr( tagSrcCoordsVLat, &m_meshOverlapSet, 1, &srccoordsvlatvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
    const void* tgtcoordsvlonvals_d = &( m_dTargetVertexLon[0][0] );
    const void* tgtcoordsvlatvals_d = &( m_dTargetVertexLat[0][0] );
    dsize                           = m_dTargetVertexLon.GetRows() * m_dTargetVertexLon.GetColumns();
    rval = m_interface->tag_set_by_ptr( tagTgtCoordsVLon, &m_meshOverlapSet, 1, &tgtcoordsvlonvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
    rval = m_interface->tag_set_by_ptr( tagTgtCoordsVLat, &m_meshOverlapSet, 1, &tgtcoordsvlatvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
    /* Set the masks for source and target meshes if available */
        const void* srcmaskvals_d = m_iSourceMask;
        dsize                     = m_iSourceMask.GetRows();
        rval = m_interface->tag_set_by_ptr( srcMaskValues, &m_meshOverlapSet, 1, &srcmaskvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
        const void* tgtmaskvals_d = m_iTargetMask;
        dsize                     = m_iTargetMask.GetRows();
        rval = m_interface->tag_set_by_ptr( tgtMaskValues, &m_meshOverlapSet, 1, &tgtmaskvals_d, &dsize );MB_CHK_SET_ERR( rval, "Setting local tag data failed" );
    const char* writeOptions = ( this->size > 1 ? "PARALLEL=WRITE_PART" : "" );
#else
    const char* writeOptions = "";
#endif
    // EntityHandle sets[3] = {m_remapper->m_source_set, m_remapper->m_target_set, m_remapper->m_overlap_set};
    EntityHandle sets[1] = { m_remapper->m_overlap_set };
    rval                 = m_interface->write_file( strOutputFile.c_str(), NULL, writeOptions, sets, 1 );MB_CHK_ERR( rval );
#ifdef WRITE_SCRIP_FILE
    sstr.str( "" );
    sstr << ctx.outFilename.substr( 0, lastindex ) << "_" << proc_id << ".nc";
    std::map< std::string, std::string > mapAttributes;
    mapAttributes["Creator"] = "MOAB mbtempest workflow";
    if( !ctx.proc_id ) std::cout << "Writing offline map to file: " << sstr.str() << std::endl;
    this->Write( strOutputFile.c_str(), mapAttributes, NcFile::Netcdf4 );
    sstr.str( "" );
#endif
moab::ErrorCode moab::TempestOnlineMap::WriteParallelMap ( const std::string &  strTarget)
Write the TempestOnlineMap to a parallel NetCDF file.
Definition at line 156 of file TempestOnlineMapIO.cpp.
References ErrorCode, and MB_CHK_ERR.
Referenced by main().
    size_t lastindex      = strFilename.find_last_of( "." );
    std::string extension = strFilename.substr( lastindex + 1, strFilename.size() );
    // Write the map file to disk in parallel
    if( extension == "nc" )
        /* Invoke the actual call to write the parallel map to disk in SCRIP format */
        rval = this->WriteSCRIPMapFile( strFilename.c_str() );MB_CHK_ERR( rval );
    else
        /* Write to the parallel H5M format */
        rval = this->WriteHDF5MapFile( strFilename.c_str() );MB_CHK_ERR( rval );
    return rval;
moab::ErrorCode moab::TempestOnlineMap::WriteSCRIPMapFile ( const std::string &  strOutputFile) [private]
Copy the local matrix from Tempest SparseMatrix representation (ELL) to the parallel CSR Eigen Matrix for scalable application of matvec needed for projections.
Parallel I/O with HDF5 to write out the remapping weights from multiple processors.
Definition at line 180 of file TempestOnlineMapIO.cpp.
References moab::TupleList::enableWriteAccess(), moab::error(), ErrorCode, moab::TupleList::get_n(), ierr, moab::TupleList::inc_n(), moab::TupleList::initialize(), MB_CHK_SET_ERR, MB_SUCCESS, nr, rank, moab::TempestRemapper::RLL, size, moab::Remapper::SourceMesh, moab::Remapper::TargetMesh, moab::TupleList::vi_wr, and moab::TupleList::vr_wr.
    NcError error( NcError::silent_nonfatal );
    ParNcFile ncMap( m_pcomm->comm(), MPI_INFO_NULL, strFilename.c_str(), NcFile::Replace, NcFile::Netcdf4 );
#else
    NcFile ncMap( strFilename.c_str(), NcFile::Replace );
#endif
    if( !ncMap.is_valid() )
        _EXCEPTION1( "Unable to open output map file \"%s\"", strFilename.c_str() );
    // Attributes
    ncMap.add_att( "Title", "MOAB-TempestRemap Online Regridding Weight Generator" );
            ( this->m_remapper->m_source_type == moab::TempestRemapper::RLL ), /* fLatLon = false */
    else
            GenerateUniqueJacobian( dataGLLNodesSrc, dataGLLJacobianSrc, vecSourceFaceArea );
        else
            GenerateDiscontinuousJacobian( dataGLLJacobianSrc, vecSourceFaceArea );
            ( this->m_remapper->m_target_type == moab::TempestRemapper::RLL ), /* fLatLon = false */
    else
            GenerateUniqueJacobian( dataGLLNodesDest, dataGLLJacobianDest, vecTargetFaceArea );
        else
            GenerateDiscontinuousJacobian( dataGLLJacobianDest, vecTargetFaceArea );
    // Map dimensions
    unsigned nA = ( vecSourceFaceArea.GetRows() );
    unsigned nB = ( vecTargetFaceArea.GetRows() );
    std::vector< int > masksA, masksB;
    ErrorCode rval = m_remapper->GetIMasks( moab::Remapper::SourceMesh, masksA );MB_CHK_SET_ERR( rval, "Trouble getting masks for source" );
    rval = m_remapper->GetIMasks( moab::Remapper::TargetMesh, masksB );MB_CHK_SET_ERR( rval, "Trouble getting masks for target" );
    // Number of nodes per Face
    int nSourceNodesPerFace = dSourceVertexLon.GetColumns();
    int nTargetNodesPerFace = dTargetVertexLon.GetColumns();
    // if source or target cells have triangles at poles, center of those triangles need to come from
    // the original quad, not from center in 3d, converted to 2d again
    // start copy OnlineMap.cpp tempestremap
    // right now, do this only for source  mesh; copy the logic for target mesh
    for( unsigned i = 0; i < nA; i++ )
        const Face& face = m_meshInput->faces[i];
        int nNodes          = face.edges.size();
        int indexNodeAtPole = -1;
        if( 3 == nNodes )  // check if one node at the poles
            for( int j = 0; j < nNodes; j++ )
                if( fabs( fabs( dSourceVertexLat[i][j] ) - 90.0 ) < 1.0e-12 )
                    indexNodeAtPole = j;
                    break;
        if( indexNodeAtPole < 0 ) continue;  // continue i loop, do nothing
        // recompute center of cell, from 3d data; add one 2 nodes at pole, and average
        int nodeAtPole = face[indexNodeAtPole];  // use the overloaded operator
        Node nodePole  = m_meshInput->nodes[nodeAtPole];
        Node newCenter = nodePole * 2;
        for( int j = 1; j < nNodes; j++ )
            int indexi       = ( indexNodeAtPole + j ) % nNodes;  // nNodes is 3 !
            const Node& node = m_meshInput->nodes[face[indexi]];
            newCenter        = newCenter + node;
        newCenter = newCenter * 0.25;
        newCenter = newCenter.Normalized();
#ifdef VERBOSE
        double iniLon = dSourceCenterLon[i], iniLat = dSourceCenterLat[i];
#endif
        // dSourceCenterLon, dSourceCenterLat
        XYZtoRLL_Deg( newCenter.x, newCenter.y, newCenter.z, dSourceCenterLon[i], dSourceCenterLat[i] );
#ifdef VERBOSE
        std::cout << " modify center of triangle from " << iniLon << " " << iniLat << " to " << dSourceCenterLon[i]
                  << " " << dSourceCenterLat[i] << "\n";
#endif
    // first move data if in parallel
#if defined( MOAB_HAVE_MPI )
    int max_row_dof, max_col_dof;  // output; arrays will be re-distributed in chunks [maxdof/size]
    // if (size > 1)
        int ierr = rearrange_arrays_by_dofs( srccol_gdofmap, vecSourceFaceArea, dSourceCenterLon, dSourceCenterLat,
                                             dSourceVertexLon, dSourceVertexLat, masksA, nA, nSourceNodesPerFace,
                                             max_col_dof );  // now nA will be close to maxdof/size
        if( ierr != 0 )
            _EXCEPTION1( "Unable to arrange source data %d ", nA );
        // rearrange target data: (nB)
        ierr = rearrange_arrays_by_dofs( row_gdofmap, vecTargetFaceArea, dTargetCenterLon, dTargetCenterLat,
                                         dTargetVertexLon, dTargetVertexLat, masksB, nB, nTargetNodesPerFace,
                                         max_row_dof );  // now nA will be close to maxdof/size
        if( ierr != 0 )
            _EXCEPTION1( "Unable to arrange target data %d ", nB );
#endif
    // Number of non-zeros in the remap matrix operator
    int nS = m_weightMatrix.nonZeros();
#if defined( MOAB_HAVE_MPI ) && defined( MOAB_HAVE_NETCDFPAR )
    int locbuf[5] = { (int)nA, (int)nB, nS, nSourceNodesPerFace, nTargetNodesPerFace };
    int offbuf[3] = { 0, 0, 0 };
    int globuf[5] = { 0, 0, 0, 0, 0 };
    MPI_Scan( locbuf, offbuf, 3, MPI_INT, MPI_SUM, m_pcomm->comm() );
    MPI_Allreduce( locbuf, globuf, 3, MPI_INT, MPI_SUM, m_pcomm->comm() );
    MPI_Allreduce( &locbuf[3], &globuf[3], 2, MPI_INT, MPI_MAX, m_pcomm->comm() );
    // MPI_Scan is inclusive of data in current rank; modify accordingly.
    offbuf[0] -= nA;
    offbuf[1] -= nB;
    offbuf[2] -= nS;
#else
    int globuf[5]            = { (int)nA, (int)nB, nS, nSourceNodesPerFace, nTargetNodesPerFace };
#endif
    // Write output dimensions entries
    unsigned nSrcGridDims = ( m_vecSourceDimSizes.size() );
    unsigned nDstGridDims = ( m_vecTargetDimSizes.size() );
    NcDim* dimSrcGridRank = ncMap.add_dim( "src_grid_rank", nSrcGridDims );
    NcDim* dimDstGridRank = ncMap.add_dim( "dst_grid_rank", nDstGridDims );
    NcVar* varSrcGridDims = ncMap.add_var( "src_grid_dims", ncInt, dimSrcGridRank );
    NcVar* varDstGridDims = ncMap.add_var( "dst_grid_dims", ncInt, dimDstGridRank );
    ncMap.enable_var_par_access( varSrcGridDims, is_independent );
    ncMap.enable_var_par_access( varDstGridDims, is_independent );
#endif
    char szDim[64];
    if( ( nSrcGridDims == 1 ) && ( m_vecSourceDimSizes[0] != (int)nA ) )
        varSrcGridDims->put( &globuf[0], 1 );
        varSrcGridDims->add_att( "name0", "num_dof" );
    else
        for( unsigned i = 0; i < m_vecSourceDimSizes.size(); i++ )
            int tmp = ( i == 0 ? globuf[0] : m_vecSourceDimSizes[i] );
            varSrcGridDims->set_cur( nSrcGridDims - i - 1 );
            varSrcGridDims->put( &( tmp ), 1 );
            sprintf( szDim, "name%i", i );
            varSrcGridDims->add_att( szDim, m_vecSourceDimNames[nSrcGridDims - i - 1].c_str() );
    if( ( nDstGridDims == 1 ) && ( m_vecTargetDimSizes[0] != (int)nB ) )
        varDstGridDims->put( &globuf[1], 1 );
        varDstGridDims->add_att( "name0", "num_dof" );
    else
        for( unsigned i = 0; i < m_vecTargetDimSizes.size(); i++ )
            int tmp = ( i == 0 ? globuf[1] : m_vecTargetDimSizes[i] );
            varDstGridDims->set_cur( nDstGridDims - i - 1 );
            varDstGridDims->put( &( tmp ), 1 );
            varDstGridDims->add_att( szDim, m_vecTargetDimNames[nDstGridDims - i - 1].c_str() );
    // Source and Target mesh resolutions
    NcDim* dimNA = ncMap.add_dim( "n_a", globuf[0] );
    NcDim* dimNB = ncMap.add_dim( "n_b", globuf[1] );
    NcDim* dimNVA = ncMap.add_dim( "nv_a", globuf[3] );
    NcDim* dimNVB = ncMap.add_dim( "nv_b", globuf[4] );
    // Write coordinates
    NcVar* varYCA = ncMap.add_var( "yc_a", ncDouble, dimNA );
    NcVar* varYCB = ncMap.add_var( "yc_b", ncDouble, dimNB );
    NcVar* varXCA = ncMap.add_var( "xc_a", ncDouble, dimNA );
    NcVar* varXCB = ncMap.add_var( "xc_b", ncDouble, dimNB );
    NcVar* varYVA = ncMap.add_var( "yv_a", ncDouble, dimNA, dimNVA );
    NcVar* varYVB = ncMap.add_var( "yv_b", ncDouble, dimNB, dimNVB );
    NcVar* varXVA = ncMap.add_var( "xv_a", ncDouble, dimNA, dimNVA );
    NcVar* varXVB = ncMap.add_var( "xv_b", ncDouble, dimNB, dimNVB );
    // Write masks
    NcVar* varMaskA = ncMap.add_var( "mask_a", ncInt, dimNA );
    NcVar* varMaskB = ncMap.add_var( "mask_b", ncInt, dimNB );
    ncMap.enable_var_par_access( varYCA, is_independent );
    ncMap.enable_var_par_access( varYCB, is_independent );
    ncMap.enable_var_par_access( varXCA, is_independent );
    ncMap.enable_var_par_access( varXCB, is_independent );
    ncMap.enable_var_par_access( varYVA, is_independent );
    ncMap.enable_var_par_access( varYVB, is_independent );
    ncMap.enable_var_par_access( varXVA, is_independent );
    ncMap.enable_var_par_access( varXVB, is_independent );
    ncMap.enable_var_par_access( varMaskA, is_independent );
    ncMap.enable_var_par_access( varMaskB, is_independent );
#endif
    varYCA->add_att( "units", "degrees" );
    varYCB->add_att( "units", "degrees" );
    varXCA->add_att( "units", "degrees" );
    varXCB->add_att( "units", "degrees" );
    varYVA->add_att( "units", "degrees" );
    varYVB->add_att( "units", "degrees" );
    varXVA->add_att( "units", "degrees" );
    varXVB->add_att( "units", "degrees" );
    // Verify dimensionality
    if( dSourceCenterLon.GetRows() != nA )
        _EXCEPTIONT( "Mismatch between dSourceCenterLon and nA" );
    if( dSourceCenterLat.GetRows() != nA )
        _EXCEPTIONT( "Mismatch between dSourceCenterLat and nA" );
    if( dTargetCenterLon.GetRows() != nB )
        _EXCEPTIONT( "Mismatch between dTargetCenterLon and nB" );
    if( dTargetCenterLat.GetRows() != nB )
        _EXCEPTIONT( "Mismatch between dTargetCenterLat and nB" );
    if( dSourceVertexLon.GetRows() != nA )
        _EXCEPTIONT( "Mismatch between dSourceVertexLon and nA" );
    if( dSourceVertexLat.GetRows() != nA )
        _EXCEPTIONT( "Mismatch between dSourceVertexLat and nA" );
    if( dTargetVertexLon.GetRows() != nB )
        _EXCEPTIONT( "Mismatch between dTargetVertexLon and nB" );
    if( dTargetVertexLat.GetRows() != nB )
        _EXCEPTIONT( "Mismatch between dTargetVertexLat and nB" );
    varYCA->set_cur( (long)offbuf[0] );
    varYCA->put( &( dSourceCenterLat[0] ), nA );
    varYCB->set_cur( (long)offbuf[1] );
    varYCB->put( &( dTargetCenterLat[0] ), nB );
    varXCA->set_cur( (long)offbuf[0] );
    varXCA->put( &( dSourceCenterLon[0] ), nA );
    varXCB->set_cur( (long)offbuf[1] );
    varXCB->put( &( dTargetCenterLon[0] ), nB );
    varYVA->set_cur( (long)offbuf[0] );
    varYVA->put( &( dSourceVertexLat[0][0] ), nA, nSourceNodesPerFace );
    varYVB->set_cur( (long)offbuf[1] );
    varYVB->put( &( dTargetVertexLat[0][0] ), nB, nTargetNodesPerFace );
    varXVA->set_cur( (long)offbuf[0] );
    varXVA->put( &( dSourceVertexLon[0][0] ), nA, nSourceNodesPerFace );
    varXVB->set_cur( (long)offbuf[1] );
    varXVB->put( &( dTargetVertexLon[0][0] ), nB, nTargetNodesPerFace );
    varMaskA->set_cur( (long)offbuf[0] );
    varMaskA->put( &( masksA[0] ), nA );
    varMaskB->set_cur( (long)offbuf[1] );
    varMaskB->put( &( masksB[0] ), nB );
    // Write areas
    NcVar* varAreaA = ncMap.add_var( "area_a", ncDouble, dimNA );
    ncMap.enable_var_par_access( varAreaA, is_independent );
#endif
    varAreaA->set_cur( (long)offbuf[0] );
    varAreaA->put( &( vecSourceFaceArea[0] ), nA );
    NcVar* varAreaB = ncMap.add_var( "area_b", ncDouble, dimNB );
    ncMap.enable_var_par_access( varAreaB, is_independent );
#endif
    varAreaB->set_cur( (long)offbuf[1] );
    varAreaB->put( &( vecTargetFaceArea[0] ), nB );
    // Write SparseMatrix entries
    DataArray1D< int > vecRow( nS );
    DataArray1D< int > vecCol( nS );
    DataArray1D< double > vecS( nS );
    DataArray1D< double > dFracA( nA );
    DataArray1D< double > dFracB( nB );
    moab::TupleList tlValRow, tlValCol;
    // value has to be sent to processor row/nB for for fracA and col/nA for fracB
    // vecTargetArea (indexRow ) has to be sent for fracA (index col?)
    // vecTargetFaceArea will have to be sent to col index, with its index !
    tlValRow.initialize( 2, 0, 0, numr, nS );  // to proc(row),  global row , value
    tlValCol.initialize( 3, 0, 0, numr, nS );  // to proc(col),  global row / col, value
    tlValRow.enableWriteAccess();
    tlValCol.enableWriteAccess();
             dFracA[ col ] += val / vecSourceFaceArea[ col ] * vecTargetFaceArea[ row ];
             dFracB[ row ] += val ;
    int offset = 0;
    int nAbase = ( max_col_dof + 1 ) / size;  // it is nA, except last rank ( == size - 1 )
    int nBbase = ( max_row_dof + 1 ) / size;  // it is nB, except last rank ( == size - 1 )
#endif
    for( int i = 0; i < m_weightMatrix.outerSize(); ++i )
        for( WeightMatrix::InnerIterator it( m_weightMatrix, i ); it; ++it )
            vecRow[offset] = 1 + this->GetRowGlobalDoF( it.row() );  // row index
            vecCol[offset] = 1 + this->GetColGlobalDoF( it.col() );  // col index
            vecS[offset]   = it.value();                             // value
                // value M(row, col) will contribute to procRow and procCol values for fracA and fracB
                int procRow = ( vecRow[offset] - 1 ) / nBbase;
                if( procRow >= size ) procRow = size - 1;
                int procCol = ( vecCol[offset] - 1 ) / nAbase;
                if( procCol >= size ) procCol = size - 1;
                int nrInd                     = tlValRow.get_n();
                tlValRow.vi_wr[2 * nrInd]     = procRow;
                tlValRow.vi_wr[2 * nrInd + 1] = vecRow[offset] - 1;
                tlValRow.vr_wr[nrInd]         = vecS[offset];
                tlValRow.inc_n();
                int ncInd                     = tlValCol.get_n();
                tlValCol.vi_wr[3 * ncInd]     = procCol;
                tlValCol.vi_wr[3 * ncInd + 1] = vecRow[offset] - 1;
                tlValCol.vi_wr[3 * ncInd + 2] = vecCol[offset] - 1;  // this is column
                tlValCol.vr_wr[ncInd]         = vecS[offset];
                tlValCol.inc_n();
#endif
            offset++;
    // need to send values for their row and col processors, to compute fractions there
    // now do the heavy communication
    ( m_pcomm->proc_config().crystal_router() )->gs_transfer( 1, tlValCol, 0 );
    ( m_pcomm->proc_config().crystal_router() )->gs_transfer( 1, tlValRow, 0 );
    // we have now, for example,  dFracB[ row ] += val ;
    // so we know that on current task, we received tlValRow
    // reminder dFracA[ col ] += val / vecSourceFaceArea[ col ] * vecTargetFaceArea[ row ];
    //          dFracB[ row ] += val ;
    for( unsigned i = 0; i < tlValRow.get_n(); i++ )
        // int fromProc = tlValRow.vi_wr[2 * i];
        int gRowInd       = tlValRow.vi_wr[2 * i + 1];
        int localIndexRow = gRowInd - nBbase * rank;  // modulo nBbase rank is from 0 to size - 1;
        double wgt        = tlValRow.vr_wr[i];
        assert( localIndexRow >= 0 );
        assert( nB - localIndexRow > 0 );
        dFracB[localIndexRow] += wgt;
    // to compute dFracA we need vecTargetFaceArea[ row ]; we know the row, and we can get the proc we need it from
    std::set< int > neededRows;
    for( unsigned i = 0; i < tlValCol.get_n(); i++ )
        int rRowInd = tlValCol.vi_wr[3 * i + 1];
        neededRows.insert( rRowInd );
        // we need vecTargetFaceAreaGlobal[ rRowInd ]; this exists on proc procRow
    moab::TupleList tgtAreaReq;
    tgtAreaReq.initialize( 2, 0, 0, 0, neededRows.size() );
    tgtAreaReq.enableWriteAccess();
    for( std::set< int >::iterator sit = neededRows.begin(); sit != neededRows.end(); sit++ )
        int neededRow = *sit;
        int procRow   = neededRow / nBbase;
        int nr                       = tgtAreaReq.get_n();
        tgtAreaReq.vi_wr[2 * nr]     = procRow;
        tgtAreaReq.vi_wr[2 * nr + 1] = neededRow;
        tgtAreaReq.inc_n();
    ( m_pcomm->proc_config().crystal_router() )->gs_transfer( 1, tgtAreaReq, 0 );
    // we need to send back the tgtArea corresponding to row
    moab::TupleList tgtAreaInfo;  // load it with tgtArea at row
    tgtAreaInfo.initialize( 2, 0, 0, 1, tgtAreaReq.get_n() );
    tgtAreaInfo.enableWriteAccess();
    for( unsigned i = 0; i < tgtAreaReq.get_n(); i++ )
        int from_proc     = tgtAreaReq.vi_wr[2 * i];
        int row           = tgtAreaReq.vi_wr[2 * i + 1];
        int locaIndexRow  = row - rank * nBbase;
        double areaToSend = vecTargetFaceArea[locaIndexRow];
        // int remoteIndex = tgtAreaReq.vi_wr[3*i + 2] ;
        tgtAreaInfo.vi_wr[2 * i]     = from_proc;  // send back requested info
        tgtAreaInfo.vi_wr[2 * i + 1] = row;
        tgtAreaInfo.vr_wr[i]         = areaToSend;  // this will be tgt area at row
        tgtAreaInfo.inc_n();
    ( m_pcomm->proc_config().crystal_router() )->gs_transfer( 1, tgtAreaInfo, 0 );
    std::map< int, double > areaAtRow;
    for( unsigned i = 0; i < tgtAreaInfo.get_n(); i++ )
        // we have received from proc, value for row !
        int row        = tgtAreaInfo.vi_wr[2 * i + 1];
        areaAtRow[row] = tgtAreaInfo.vr_wr[i];
    // we have now for rows the
    // it is ordered by index, so:
    // now compute reminder dFracA[ col ] += val / vecSourceFaceArea[ col ] * vecTargetFaceArea[ row ];
    // tgtAreaInfo will have at index i the area we need (from row)
    // there should be an easier way :(
        int colInd      = tlValCol.vi_wr[3 * i + 2];
        double val      = tlValCol.vr_wr[i];
        int localColInd = colInd - rank * nAbase;  // < local nA
        auto itMap = areaAtRow.find( rRowInd );  // it should be different from end
        if( itMap != areaAtRow.end() )
            double areaRow = itMap->second;  // we fished a lot for this !
            dFracA[localColInd] += val / vecSourceFaceArea[localColInd] * areaRow;
#endif
    // Load in data
    NcDim* dimNS = ncMap.add_dim( "n_s", globuf[2] );
    NcVar* varRow = ncMap.add_var( "row", ncInt, dimNS );
    NcVar* varCol = ncMap.add_var( "col", ncInt, dimNS );
    NcVar* varS   = ncMap.add_var( "S", ncDouble, dimNS );
#ifdef MOAB_HAVE_NETCDFPAR
#endif
    varRow->set_cur( (long)offbuf[2] );
    varRow->put( vecRow, nS );
    varCol->set_cur( (long)offbuf[2] );
    varCol->put( vecCol, nS );
    varS->set_cur( (long)offbuf[2] );
    varS->put( &( vecS[0] ), nS );
    // Calculate and write fractional coverage arrays
    NcVar* varFracA = ncMap.add_var( "frac_a", ncDouble, dimNA );
    ncMap.enable_var_par_access( varFracA, is_independent );
#endif
    varFracA->add_att( "name", "fraction of target coverage of source dof" );
    varFracA->add_att( "units", "unitless" );
    varFracA->set_cur( (long)offbuf[0] );
    varFracA->put( &( dFracA[0] ), nA );
    NcVar* varFracB = ncMap.add_var( "frac_b", ncDouble, dimNB );
    ncMap.enable_var_par_access( varFracB, is_independent );
#endif
    varFracB->add_att( "name", "fraction of source coverage of target dof" );
    varFracB->add_att( "units", "unitless" );
    varFracB->set_cur( (long)offbuf[1] );
    varFracB->put( &( dFracB[0] ), nB );
    // Add global attributes
    // std::map<std::string, std::string>::const_iterator iterAttributes =
    //     mapAttributes.begin();
    // for (; iterAttributes != mapAttributes.end(); iterAttributes++) {
    //     ncMap.add_att(
    //         iterAttributes->first.c_str(),
    //         iterAttributes->second.c_str());
    ncMap.close();
Member Data Documentation
std::vector< int > moab::TempestOnlineMap::col_dtoc_dofmap [private]
Definition at line 443 of file TempestOnlineMap.hpp.
std::vector< unsigned > moab::TempestOnlineMap::col_gdofmap [private]
Definition at line 440 of file TempestOnlineMap.hpp.
Referenced by fill_col_ids(), and LinearRemapNN_MOAB().
std::map< int, int > moab::TempestOnlineMap::colMap [private]
Definition at line 445 of file TempestOnlineMap.hpp.
DataArray3D< int > moab::TempestOnlineMap::dataGLLNodesDest [private]
Definition at line 447 of file TempestOnlineMap.hpp.
DataArray3D< int > moab::TempestOnlineMap::dataGLLNodesSrc [private]
DataArray3D< int > moab::TempestOnlineMap::dataGLLNodesSrcCov [private]
Definition at line 462 of file TempestOnlineMap.hpp.
Definition at line 454 of file TempestOnlineMap.hpp.
The original tag data and local to global DoF mapping to associate matrix values to solution.
Definition at line 439 of file TempestOnlineMap.hpp.
Definition at line 455 of file TempestOnlineMap.hpp.
The reference to the moab::Core object that contains source/target and overlap sets.
Definition at line 427 of file TempestOnlineMap.hpp.
Definition at line 457 of file TempestOnlineMap.hpp.
Definition at line 458 of file TempestOnlineMap.hpp.
Definition at line 459 of file TempestOnlineMap.hpp.
Definition at line 460 of file TempestOnlineMap.hpp.
Definition at line 452 of file TempestOnlineMap.hpp.
Definition at line 449 of file TempestOnlineMap.hpp.
Referenced by LinearRemapNN_MOAB().
The fundamental remapping operator object.
Definition at line 414 of file TempestOnlineMap.hpp.
Definition at line 463 of file TempestOnlineMap.hpp.
std::vector< int > moab::TempestOnlineMap::row_dtoc_dofmap [private]
std::vector< unsigned > moab::TempestOnlineMap::row_gdofmap [private]
Referenced by fill_row_ids(), and LinearRemapNN_MOAB().
std::map< int, int > moab::TempestOnlineMap::rowMap [private]
std::vector< int > moab::TempestOnlineMap::srccol_dtoc_dofmap [private]
std::vector< unsigned > moab::TempestOnlineMap::srccol_gdofmap [private]
List of all members.
