moab::VertexSequence Member List
This is the complete list of members for moab::VertexSequence, including all inherited members.
append_entities(EntityID count)moab::EntitySequence [protected]
array(Coord coord)moab::VertexSequence [inline, private]
array(Coord coord) const moab::VertexSequence [inline, private]
Coord enum namemoab::VertexSequence [private]
create_data_subset(EntityHandle start, EntityHandle end) const moab::VertexSequence [virtual]
moab::EntitySequence::create_data_subset(EntityHandle start_handle, EntityHandle end_handle, int num_sequence_arrays, unsigned const *bytes_per_element) const moab::EntitySequence [protected]
data() const moab::EntitySequence [inline]
data(SequenceData *ptr)moab::EntitySequence [inline]
end_handle() const moab::EntitySequence [inline]
EntitySequence(EntityHandle h)moab::EntitySequence [inline, protected]
EntitySequence(EntitySequence &split_from, EntityHandle here)moab::EntitySequence [inline, protected]
EntitySequence(EntityHandle start, EntityID count, SequenceData *dat)moab::EntitySequence [inline]
get_const_memory_use(unsigned long &bytes_per_entity, unsigned long &size_of_sequence) const moab::VertexSequence [virtual]
get_coordinate_arrays(double *&x, double *&y, double *&z)moab::VertexSequence [inline]
get_coordinate_arrays(const double *&x, const double *&y, const double *&z) const moab::VertexSequence [inline]
get_coordinates(EntityHandle handle, double &x, double &y, double &z) const moab::VertexSequence [inline]
get_coordinates(EntityHandle handle, double coords[3]) const moab::VertexSequence [inline]
get_coordinates_ref(EntityHandle handle, const double *&x, const double *&y, const double *&z) const moab::VertexSequence [inline]
get_per_entity_memory_use(EntityHandle first, EntityHandle last) const moab::EntitySequence [virtual]
merge(EntitySequence &other)moab::EntitySequence [virtual]
pop_back(EntityID count)moab::EntitySequence [virtual]
pop_front(EntityID count)moab::EntitySequence [virtual]
prepend_entities(EntityID count)moab::EntitySequence [protected]
push_back(EntityID count)moab::VertexSequence
push_front(EntityID count)moab::VertexSequence
set_coordinates(EntityHandle entity, double x, double y, double z)moab::VertexSequence [inline]
set_coordinates(EntityHandle entity, const double xyz[3])moab::VertexSequence [inline]
size() const moab::EntitySequence [inline]
split(EntityHandle here)moab::VertexSequence [virtual]
start_handle() const moab::EntitySequence [inline]
type() const moab::EntitySequence [inline]
using_entire_data() const moab::EntitySequence
values_per_entity() const moab::EntitySequence [virtual]
VertexSequence(EntityHandle start, EntityID count, SequenceData *dat)moab::VertexSequence [inline]
VertexSequence(EntityHandle start, EntityID count, EntityID data_size)moab::VertexSequence [inline]
VertexSequence(VertexSequence &split_from, EntityHandle here)moab::VertexSequence [inline, private]
X enum valuemoab::VertexSequence [private]
x_array()moab::VertexSequence [inline, private]
x_array() const moab::VertexSequence [inline, private]
Y enum valuemoab::VertexSequence [private]
y_array()moab::VertexSequence [inline, private]
y_array() const moab::VertexSequence [inline, private]
Z enum valuemoab::VertexSequence [private]
z_array()moab::VertexSequence [inline, private]
z_array() const moab::VertexSequence [inline, private]
~EntitySequence()moab::EntitySequence [inline, virtual]
~VertexSequence()moab::VertexSequence [virtual]
