moab::WriteCCMIO Class Reference
#include <WriteCCMIO.hpp>
+ Inheritance diagram for moab::WriteCCMIO:
+ Collaboration diagram for moab::WriteCCMIO:
Classes
class  MaterialSetData
class  MeshInfo
 contains the general information about a mesh More...
class  NeumannSetData
Public Member Functions
 WriteCCMIO (Interface *impl)
 Constructor.
virtual ~WriteCCMIO ()
 Destructor.
ErrorCode write_file (const char *file_name, const bool overwrite, const FileOptions &opts, const EntityHandle *output_list, const int num_sets, const std::vector< std::string > &qa_list, const Tag *tag_list=NULL, int num_tags=0, int export_dimension=3)
 writes out a file
Static Public Member Functions
static WriterIfacefactory (Interface *)
Protected Member Functions
ErrorCode open_file (const char *filename, bool overwrite, CCMIOID &rootID)
 number of dimensions in this file
Private Member Functions
ErrorCode gather_matset_info (std::vector< EntityHandle > &matsets, std::vector< MaterialSetData > &matset_data, Range &all_verts)
ErrorCode gather_neuset_info (std::vector< EntityHandle > &neusets, std::vector< NeumannSetData > &neuset_data)
 gathers elements in each neuset
ErrorCode close_and_compress (const char *filename, CCMIOID rootID)
ErrorCode initialize_file (MeshInfo &mesh_info)
ErrorCode write_nodes (CCMIOID rootID, const Range &nodes, const int dimension, CCMIOID &verticesID)
 write vertices to file
ErrorCode write_cells_and_faces (CCMIOID rootID, std::vector< WriteCCMIO::MaterialSetData > &matset_data, std::vector< WriteCCMIO::NeumannSetData > &neuset_data, Range &verts, CCMIOID &topologyID)
 write cells and internal/boundary faces, using vgids and verts input
ErrorCode write_external_faces (CCMIOID rootID, CCMIOID topologyID, int set_num, Range &facets)
 write external faces, including connectivity and connected cells
ErrorCode get_gids (const Range &ents, int *&gids, int &minid, int &maxid)
ErrorCode write_meshes (MeshInfo &mesh_info, std::vector< MaterialSetData > &matset_data, std::vector< NeumannSetData > &neuset_data, Range &verts, const int *vgids)
ErrorCode get_valid_sides (Range &elems, const int sense, WriteCCMIO::NeumannSetData &neuset_data)
void reset_matset (std::vector< MaterialSetData > &matset_info)
ErrorCode get_neuset_elems (EntityHandle neuset, int current_sense, Range &forward_elems, Range &reverse_elems)
ErrorCode transform_coords (const int dimension, const int num_nodes, double *coords)
ErrorCode write_problem_description (CCMIOID rootID, CCMIOID stateID, CCMIOID &problemID, CCMIOID processorID, std::vector< MaterialSetData > &matset_data, std::vector< NeumannSetData > &neuset_data)
ErrorCode get_sets (const EntityHandle *ent_handles, int num_sets, std::vector< EntityHandle > &matsets, std::vector< EntityHandle > &dirsets, std::vector< EntityHandle > &neusets, std::vector< EntityHandle > &partsets)
ErrorCode create_ccmio_structure (CCMIOID rootID, CCMIOID &stateID, CCMIOID &processorID)
 create state and processor nodes
ErrorCode write_solution_data ()
 write solution (tag) data
ErrorCode write_processor (CCMIOID processorID, CCMIOID verticesID, CCMIOID topologyID)
 finalize processor
int moab_to_ccmio_type (EntityType etype, int has_mid_nodes[])
 convert MOAB to CCMIO type
ErrorCode write_int_option (const char *opt_name, EntityHandle seth, Tag &tag, CCMIOID &node)
ErrorCode write_dbl_option (const char *opt_name, EntityHandle seth, Tag &tag, CCMIOID &node)
ErrorCode write_str_option (const char *opt_name, EntityHandle seth, Tag &tag, CCMIOID &node, const char *other_name=NULL)
Private Attributes
InterfacembImpl
 interface instance
WriteUtilIfacemWriteIface
std::string fileName
 file name
EntityHandle mCurrentMeshHandle
 Meshset Handle for the mesh that is currently being read.
Tag mMaterialSetTag
Tag mDirichletSetTag
Tag mNeumannSetTag
Tag mPartitionSetTag
Tag mHasMidNodesTag
Tag mGlobalIdTag
Tag mNameTag
Tag mMaterialIdTag
Tag mMaterialTypeTag
Tag mRadiationTag
Tag mPorosityIdTag
Tag mSpinIdTag
Tag mGroupIdTag
Tag mColorIdxTag
Tag mProcessorIdTag
Tag mLightMaterialTag
Tag mFreeSurfaceMaterialTag
Tag mThicknessTag
Tag mProstarRegionNumberTag
Tag mBoundaryTypeTag
Tag mCreatingProgramTag
Tag mEntityMark
int mDimension
bool mWholeMesh
Detailed Description
Definition at line 51 of file WriteCCMIO.hpp.
Constructor.
Get and cache predefined tag handles
Definition at line 111 of file WriteCCMIO.cpp.
References DIRICHLET_SET_TAG_NAME, moab::Interface::globalId_tag(), HAS_MID_NODES_TAG_NAME, MATERIAL_SET_TAG_NAME, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_BIT, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, mbImpl, mDirichletSetTag, mEntityMark, mGlobalIdTag, mHasMidNodesTag, mMaterialSetTag, mNameTag, mNeumannSetTag, mPartitionSetTag, mWriteIface, NAME_TAG_NAME, NAME_TAG_SIZE, NEUMANN_SET_TAG_NAME, PARALLEL_PARTITION_TAG_NAME, moab::Interface::query_interface(), and moab::Interface::tag_get_handle().
Referenced by factory().
    : mbImpl( impl ), mCurrentMeshHandle( 0 ), mPartitionSetTag( 0 ), mNameTag( 0 ), mMaterialIdTag( 0 ),
      mMaterialTypeTag( 0 ), mRadiationTag( 0 ), mPorosityIdTag( 0 ), mSpinIdTag( 0 ), mGroupIdTag( 0 ),
      mColorIdxTag( 0 ), mProcessorIdTag( 0 ), mLightMaterialTag( 0 ), mFreeSurfaceMaterialTag( 0 ), mThicknessTag( 0 ),
      mProstarRegionNumberTag( 0 ), mBoundaryTypeTag( 0 ), mCreatingProgramTag( 0 ), mDimension( 0 ),
      mWholeMesh( false )
    assert( impl != NULL );
    impl->query_interface( mWriteIface );
    // Initialize in case tag_get_handle fails below
    //! Get and cache predefined tag handles
    int negone = -1;
    impl->tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mMaterialSetTag, MB_TAG_SPARSE | MB_TAG_CREAT,
                          &negone );
    impl->tag_get_handle( DIRICHLET_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mDirichletSetTag, MB_TAG_SPARSE | MB_TAG_CREAT,
                          &negone );
    impl->tag_get_handle( NEUMANN_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mNeumannSetTag, MB_TAG_SPARSE | MB_TAG_CREAT,
                          &negone );
    mGlobalIdTag = impl->globalId_tag();
#ifdef MOAB_HAVE_MPI
    impl->tag_get_handle( PARALLEL_PARTITION_TAG_NAME, 1, MB_TYPE_INTEGER, mPartitionSetTag, MB_TAG_SPARSE );
    // No need to check result, if it's not there, we don't create one
#endif
    int dum_val_array[] = { -1, -1, -1, -1 };
    impl->tag_get_handle( HAS_MID_NODES_TAG_NAME, 4, MB_TYPE_INTEGER, mHasMidNodesTag, MB_TAG_SPARSE | MB_TAG_CREAT,
                          dum_val_array );
    impl->tag_get_handle( "__WriteCCMIO element mark", 1, MB_TYPE_BIT, mEntityMark, MB_TAG_CREAT );
    // Don't need to check return of following, since it doesn't matter if there isn't one
    mbImpl->tag_get_handle( NAME_TAG_NAME, NAME_TAG_SIZE, MB_TYPE_OPAQUE, mNameTag );
Member Function Documentation
ErrorCode moab::WriteCCMIO::close_and_compress ( const char *  filename,
CCMIOID  rootID
) [private]
Definition at line 286 of file WriteCCMIO.cpp.
References CHK_SET_CCMERR, moab::error(), and MB_SUCCESS.
Referenced by write_file().
    CCMIOError error = kCCMIONoErr;
    CCMIOCloseFile( &error, rootID );
    CHK_SET_CCMERR( error, "File close failed" );
    // The CCMIO library uses ADF to store the actual data.  Unfortunately,
    // ADF leaks disk space;  deleting a node does not recover all the disk
    // space.  Now that everything is successfully written it might be useful
    // to call CCMIOCompress() here to ensure that the file is as small as
    // possible.  Please see the Core API documentation for caveats on its
    // usage.
    // CCMIOCompress(&error, const_cast<char*>(filename));CHK_SET_CCMERR(error, "Error compressing
    // file");
    return MB_SUCCESS;
ErrorCode moab::WriteCCMIO::create_ccmio_structure ( CCMIOID  rootID,
CCMIOID &  stateID,
CCMIOID &  processorID
) [private]
Definition at line 249 of file WriteCCMIO.cpp.
References CHK_SET_CCMERR, moab::error(), moab::kStateName, MB_SUCCESS, and TRUE.
    // Create problem state and other CCMIO nodes under it
    // Create a new state (or re-use an existing one).
    if( CCMIOGetState( NULL, rootID, kStateName, NULL, &stateID ) != kCCMIONoErr )
        CCMIONewState( &error, rootID, kStateName, NULL, NULL, &stateID );
        CHK_SET_CCMERR( error, "Trouble creating state" );
    // Create or get an old processor for this state
    CCMIOSize_t i = CCMIOSIZEC( 0 );
    if( CCMIONextEntity( NULL, stateID, kCCMIOProcessor, &i, &processorID ) != kCCMIONoErr )
        CCMIONewEntity( &error, stateID, kCCMIOProcessor, NULL, &processorID );
        CHK_SET_CCMERR( error, "Trouble creating processor node" );
    // Get rid of any data that may be in this processor (if the state was
    // not new).
    else
        CCMIOClearProcessor( &error, stateID, processorID, TRUE, TRUE, TRUE, TRUE, TRUE );
        CHK_SET_CCMERR( error, "Trouble clearing processor data" );
     //  for (; i < CCMIOSIZEC(partsets.size()); i++) {
     CCMIOSize_t id = CCMIOSIZEC(0);
     if (CCMIONextEntity(NULL, stateID, kCCMIOProcessor, &id, &processorID) != kCCMIONoErr)
     CCMIONewEntity(&error, stateID, kCCMIOProcessor, NULL, &processorID);
     CHKCCMERR(error, "Trouble creating processor node.");
    return MB_SUCCESS;
Definition at line 106 of file WriteCCMIO.cpp.
References WriteCCMIO().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
    return new WriteCCMIO( iface );
ErrorCode moab::WriteCCMIO::gather_matset_info ( std::vector< EntityHandle > &  matsets,
std::vector< MaterialSetData > &  matset_data,
Range all_verts
) [private]
gathers elements in each matset, and all the vertices used by them; marks the vertices with the mEntityMark bit flag
Definition at line 618 of file WriteCCMIO.cpp.
References moab::Range::empty(), ErrorCode, moab::WriteUtilIface::gather_nodes_from_elements(), moab::Interface::get_entities_by_dimension(), MB_CHK_SET_ERR, MB_FILE_WRITE_ERROR, MB_SET_ERR, MB_SUCCESS, mbImpl, mDimension, mEntityMark, mMaterialSetTag, mNameTag, mWholeMesh, mWriteIface, NAME_TAG_SIZE, moab::Interface::tag_get_data(), moab::Interface::tag_set_data(), and moab::Interface::type_from_handle().
    ErrorCode result;
    matset_data.resize( matsets.size() );
    if( 1 == matsets.size() && 0 == matsets[0] )
        // Whole mesh
        mWholeMesh = true;
        result = mbImpl->get_entities_by_dimension( 0, mDimension, matset_data[0].elems );MB_CHK_SET_ERR( result, "Trouble getting all elements in mesh" );
        result = mWriteIface->gather_nodes_from_elements( matset_data[0].elems, mEntityMark, all_verts );MB_CHK_SET_ERR( result, "Trouble gathering nodes from elements" );
        return result;
    std::vector< unsigned char > marks;
    for( unsigned int i = 0; i < matsets.size(); i++ )
        EntityHandle this_set = matset_data[i].setHandle = matsets[i];
        // Get all Entity Handles in the set
        result = mbImpl->get_entities_by_dimension( this_set, mDimension, matset_data[i].elems, true );MB_CHK_SET_ERR( result, "Trouble getting m-dimensional ents" );
        // Get all connected vertices
        result = mWriteIface->gather_nodes_from_elements( matset_data[i].elems, mEntityMark, all_verts );MB_CHK_SET_ERR( result, "Trouble getting vertices for a matset" );
        // Check for consistent entity type
        EntityType start_type = mbImpl->type_from_handle( *matset_data[i].elems.begin() );
        if( start_type == mbImpl->type_from_handle( *matset_data[i].elems.rbegin() ) )
            matset_data[i].entityType = start_type;
        // Mark elements in this matset
        marks.resize( matset_data[i].elems.size(), 0x1 );
        result = mbImpl->tag_set_data( mEntityMark, matset_data[i].elems, &marks[0] );MB_CHK_SET_ERR( result, "Couln't mark entities being output" );
        // Get id for this matset
        result = mbImpl->tag_get_data( mMaterialSetTag, &this_set, 1, &matset_data[i].matsetId );MB_CHK_SET_ERR( result, "Couln't get global id for material set" );
        // Get name for this matset
        if( mNameTag )
            char dum_name[NAME_TAG_SIZE];
            result = mbImpl->tag_get_data( mNameTag, &this_set, 1, dum_name );
            if( MB_SUCCESS == result ) matset_data[i].setName = dum_name;
            // Reset success, so later checks don't fail
            result = MB_SUCCESS;
    if( all_verts.empty() )
        MB_SET_ERR( MB_FILE_WRITE_ERROR, "No vertices from elements" );
    return MB_SUCCESS;
ErrorCode moab::WriteCCMIO::gather_neuset_info ( std::vector< EntityHandle > &  neusets,
std::vector< NeumannSetData > &  neuset_data
) [private]
Definition at line 678 of file WriteCCMIO.cpp.
References ErrorCode, moab::Interface::get_entities_by_dimension(), MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_NOT_FOUND, mbImpl, mDimension, mGlobalIdTag, mNameTag, mNeumannSetTag, NAME_TAG_SIZE, and moab::Interface::tag_get_data().
    ErrorCode result;
    neuset_info.resize( neusets.size() );
    for( unsigned int i = 0; i < neusets.size(); i++ )
        EntityHandle this_set = neuset_info[i].setHandle = neusets[i];
        // Get all Entity Handles of one less dimension than that being output
        result = mbImpl->get_entities_by_dimension( this_set, mDimension - 1, neuset_info[i].elems, true );MB_CHK_SET_ERR( result, "Trouble getting (m-1)-dimensional ents for neuset" );
        result = mbImpl->tag_get_data( mGlobalIdTag, &this_set, 1, &neuset_info[i].neusetId );
        if( MB_TAG_NOT_FOUND == result )
            result = mbImpl->tag_get_data( mNeumannSetTag, &this_set, 1, &neuset_info[i].neusetId );
            if( MB_SUCCESS != result )
                // Need some id; use the loop iteration number
                neuset_info[i].neusetId = i;
        // Get name for this neuset
        if( mNameTag )
            if( MB_SUCCESS == result ) neuset_info[i].setName = dum_name;
    return MB_SUCCESS;
ErrorCode moab::WriteCCMIO::get_gids ( const Range ents,
int *&  gids,
int &  minid,
int &  maxid
) [private]
Definition at line 715 of file WriteCCMIO.cpp.
References ErrorCode, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, mGlobalIdTag, moab::Range::size(), moab::Interface::tag_get_data(), and moab::Interface::tag_set_data().
Referenced by write_external_faces().
    int num_ents     = ents.size();
    gids             = new int[num_ents];
    ErrorCode result = mbImpl->tag_get_data( mGlobalIdTag, ents, &gids[0] );MB_CHK_SET_ERR( result, "Couldn't get global id data" );
    minid = *std::min_element( gids, gids + num_ents );
    maxid = *std::max_element( gids, gids + num_ents );
    if( 0 == minid )
        // gids need to be assigned
        for( int i = 1; i <= num_ents; i++ )
            gids[i] = i;
        result = mbImpl->tag_set_data( mGlobalIdTag, ents, &gids[0] );MB_CHK_SET_ERR( result, "Couldn't set global id data" );
        maxid = num_ents;
    return MB_SUCCESS;
ErrorCode moab::WriteCCMIO::get_neuset_elems ( EntityHandle  neuset,
int  current_sense,
Range forward_elems,
Range reverse_elems
) [private]
Definition at line 1276 of file WriteCCMIO.cpp.
References moab::Range::begin(), moab::CN::Dimension(), moab::Range::end(), moab::Range::erase(), ErrorCode, moab::Interface::get_entities_by_handle(), MB_TYPE_INTEGER, MBENTITYSET, mbImpl, moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), and moab::TYPE_FROM_HANDLE().
    Range neuset_elems, neuset_meshsets;
    // Get the sense tag; don't need to check return, might be an error if the tag
    // hasn't been created yet
    Tag sense_tag = 0;
    mbImpl->tag_get_handle( "SENSE", 1, MB_TYPE_INTEGER, sense_tag );
    // Get the entities in this set, non-recursive
    ErrorCode result = mbImpl->get_entities_by_handle( neuset, neuset_elems );
    if( MB_FAILURE == result ) return result;
    // Now remove the meshsets into the neuset_meshsets; first find the first meshset,
    Range::iterator range_iter = neuset_elems.begin();
    while( TYPE_FROM_HANDLE( *range_iter ) != MBENTITYSET && range_iter != neuset_elems.end() )
        ++range_iter;
    // Then, if there are some, copy them into neuset_meshsets and erase from neuset_elems
    if( range_iter != neuset_elems.end() )
        std::copy( range_iter, neuset_elems.end(), range_inserter( neuset_meshsets ) );
        neuset_elems.erase( range_iter, neuset_elems.end() );
    // OK, for the elements, check the sense of this set and copy into the right range
    // (if the sense is 0, copy into both ranges)
    // Need to step forward on list until we reach the right dimension
    Range::iterator dum_it = neuset_elems.end();
    --dum_it;
    int target_dim = CN::Dimension( TYPE_FROM_HANDLE( *dum_it ) );
    dum_it         = neuset_elems.begin();
    while( target_dim != CN::Dimension( TYPE_FROM_HANDLE( *dum_it ) ) && dum_it != neuset_elems.end() )
        ++dum_it;
    if( current_sense == 1 || current_sense == 0 )
        std::copy( dum_it, neuset_elems.end(), range_inserter( forward_elems ) );
    if( current_sense == -1 || current_sense == 0 )
        std::copy( dum_it, neuset_elems.end(), range_inserter( reverse_elems ) );
    // Now loop over the contained meshsets, getting the sense of those and calling this
    // function recursively
    for( range_iter = neuset_meshsets.begin(); range_iter != neuset_meshsets.end(); ++range_iter )
        // First get the sense; if it's not there, by convention it's forward
        int this_sense;
        if( 0 == sense_tag || MB_FAILURE == mbImpl->tag_get_data( sense_tag, &( *range_iter ), 1, &this_sense ) )
            this_sense = 1;
        // Now get all the entities on this meshset, with the proper (possibly reversed) sense
        get_neuset_elems( *range_iter, this_sense * current_sense, forward_elems, reverse_elems );
    return result;
ErrorCode moab::WriteCCMIO::get_sets ( const EntityHandle ent_handles,
int  num_sets,
std::vector< EntityHandle > &  dirsets,
std::vector< EntityHandle > &  partsets
) [private]
Definition at line 313 of file WriteCCMIO.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::Range::end(), moab::Interface::get_entities_by_type_and_tag(), MB_SUCCESS, MBENTITYSET, mbImpl, mDirichletSetTag, mMaterialSetTag, mNeumannSetTag, mPartitionSetTag, and moab::Interface::tag_get_data().
    if( num_sets == 0 )
        // Default to all defined sets
        Range this_range;
        mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &mMaterialSetTag, NULL, 1, this_range );
        std::copy( this_range.begin(), this_range.end(), std::back_inserter( matsets ) );
        this_range.clear();
        mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &mDirichletSetTag, NULL, 1, this_range );
        std::copy( this_range.begin(), this_range.end(), std::back_inserter( dirsets ) );
        this_range.clear();
        mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &mNeumannSetTag, NULL, 1, this_range );
        std::copy( this_range.begin(), this_range.end(), std::back_inserter( neusets ) );
        if( mPartitionSetTag )
            this_range.clear();
            mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &mPartitionSetTag, NULL, 1, this_range );
            std::copy( this_range.begin(), this_range.end(), std::back_inserter( partsets ) );
    else
        int dummy;
        for( const EntityHandle* iter = ent_handles; iter < ent_handles + num_sets; ++iter )
            if( MB_SUCCESS == mbImpl->tag_get_data( mMaterialSetTag, &( *iter ), 1, &dummy ) )
                matsets.push_back( *iter );
            else if( MB_SUCCESS == mbImpl->tag_get_data( mDirichletSetTag, &( *iter ), 1, &dummy ) )
                dirsets.push_back( *iter );
            else if( MB_SUCCESS == mbImpl->tag_get_data( mNeumannSetTag, &( *iter ), 1, &dummy ) )
                neusets.push_back( *iter );
            else if( mPartitionSetTag && MB_SUCCESS == mbImpl->tag_get_data( mPartitionSetTag, &( *iter ), 1, &dummy ) )
                partsets.push_back( *iter );
    return MB_SUCCESS;
ErrorCode moab::WriteCCMIO::get_valid_sides ( Range elems,
const int  sense,
WriteCCMIO::NeumannSetData neuset_data
) [private]
int moab::WriteCCMIO::moab_to_ccmio_type ( EntityType  etype,
int  has_mid_nodes[]
) [private]
Definition at line 1138 of file WriteCCMIO.cpp.
References MBEDGE, MBHEX, MBPOLYHEDRON, MBPRISM, MBPYRAMID, MBQUAD, MBTET, and MBVERTEX.
Referenced by write_cells_and_faces().
    int ctype = -1;
    if( has_mid_nodes[0] || has_mid_nodes[2] || has_mid_nodes[3] ) return ctype;
    switch( etype )
        case MBVERTEX:
            ctype = 1;
            break;
        case MBEDGE:
            if( !has_mid_nodes[1] )
                ctype = 2;
            else
                ctype = 28;
            break;
        case MBQUAD:
            if( has_mid_nodes[1] )
                ctype = 4;
            else
                ctype = 3;
            break;
        case MBTET:
                ctype = 23;
            else
                ctype = 13;
            break;
        case MBPRISM:
                ctype = 22;
            else
                ctype = 12;
            break;
        case MBPYRAMID:
                ctype = 24;
            else
                ctype = 14;
            break;
        case MBHEX:
                ctype = 21;
            else
                ctype = 11;
            break;
        case MBPOLYHEDRON:
            ctype = 255;
            break;
        default:
            break;
    return ctype;
ErrorCode moab::WriteCCMIO::open_file ( const char *  filename,
bool  overwrite,
CCMIOID &  rootID
) [protected]
open a file for writing
Definition at line 304 of file WriteCCMIO.cpp.
    CCMIOOpenFile( &error, filename, kCCMIOWrite, &rootID );
    CHK_SET_CCMERR( error, "Cannot open file" );
    return MB_SUCCESS;
void moab::WriteCCMIO::reset_matset ( std::vector< MaterialSetData > &  matset_info) [private]
ErrorCode moab::WriteCCMIO::transform_coords ( const int  dimension,
double *  coords
) [private]
Definition at line 791 of file WriteCCMIO.cpp.
References ErrorCode, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_NOT_FOUND, MB_TYPE_DOUBLE, mbImpl, mesh, MESH_TRANSFORM_TAG_NAME, moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
Referenced by write_nodes().
    Tag trans_tag;
    ErrorCode result = mbImpl->tag_get_handle( MESH_TRANSFORM_TAG_NAME, 16, MB_TYPE_DOUBLE, trans_tag );
    if( result == MB_TAG_NOT_FOUND )
        return MB_SUCCESS;
    else if( MB_SUCCESS != result )
        return result;
    double trans_matrix[16];
    const EntityHandle mesh = 0;
    result                  = mbImpl->tag_get_data( trans_tag, &mesh, 1, trans_matrix );MB_CHK_SET_ERR( result, "Couldn't get transform data" );
    double* tmp_coords = coords;
    for( int i = 0; i < num_nodes; i++, tmp_coords += 1 )
        double vec1[3] = { 0.0, 0.0, 0.0 };
        for( int row = 0; row < 3; row++ )
            vec1[row] += ( trans_matrix[( row * 4 ) + 0] * coords[0] );
            vec1[row] += ( trans_matrix[( row * 4 ) + 1] * coords[num_nodes] );
            if( 3 == dimension ) vec1[row] += ( trans_matrix[( row * 4 ) + 2] * coords[2 * num_nodes] );
        coords[0]             = vec1[0];
        coords[num_nodes]     = vec1[1];
        coords[2 * num_nodes] = vec1[2];
    return MB_SUCCESS;
ErrorCode moab::WriteCCMIO::write_cells_and_faces ( CCMIOID  rootID,
std::vector< WriteCCMIO::MaterialSetData > &  matset_data,
std::vector< WriteCCMIO::NeumannSetData > &  neuset_data,
Range verts,
CCMIOID &  topologyID
) [private]
Definition at line 822 of file WriteCCMIO.cpp.
References moab::WriteUtilIface::assign_ids(), moab::Range::begin(), CHK_SET_CCMERR, moab::Range::clear(), moab::Range::empty(), moab::error(), ErrorCode, moab::Skinner::find_skin(), moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), moab::CN::HasMidNodes(), moab::Range::insert(), MAX_NODES_PER_ELEMENT, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_OPAQUE, mbImpl, MBPOLYGON, MBPOLYHEDRON, mDimension, mEntityMark, moab::Range::merge(), mGlobalIdTag, moab_to_ccmio_type(), mWholeMesh, mWriteIface, moab::CN::NumSubEntities(), moab::CN::SideNumber(), moab::Range::size(), moab::CN::SubEntityConn(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), moab::TYPE_FROM_HANDLE(), moab::Interface::type_from_handle(), and write_external_faces().
    std::vector< int > connect;
    ErrorCode result;
    CCMIOID cellMapID, cells;
    // Don't usually have anywhere near 31 nodes per element
    connect.reserve( 31 );
    Range::const_iterator rit;
    // Create the topology node, and the cell and cell map nodes
    CCMIONewEntity( &error, rootID, kCCMIOTopology, "Topology", &topologyID );
    CHK_SET_CCMERR( error, "Trouble creating topology node" );
    CCMIONewEntity( &error, rootID, kCCMIOMap, "Cell map", &cellMapID );
    CHK_SET_CCMERR( error, "Failure creating Cell Map node" );
    CCMIONewEntity( &error, topologyID, kCCMIOCells, "Cells", &cells );
    CHK_SET_CCMERR( error, "Trouble creating Cell node under Topology node" );
    // Loop over material sets, doing each one at a time
    Range all_elems;
    unsigned int i, num_elems = 0;
    int max_id = 1;
    std::vector< int > egids;
    int tot_elems = 0;
    for( unsigned int m = 0; m < matset_data.size(); m++ )
        tot_elems += matset_data[m].elems.size();
        unsigned int this_num = matset_data[m].elems.size();
        // Save all elements being output
        all_elems.merge( matset_data[m].elems );
        // Assign global ids for elements being written
        egids.resize( matset_data[m].elems.size() );
        for( i = 0; i < this_num; i++ )
            egids[i] = max_id++;
        result = mbImpl->tag_set_data( mGlobalIdTag, matset_data[m].elems, &egids[0] );MB_CHK_SET_ERR( result, "Failed to assign global ids for all elements being written" );
        // Write cell ids and material types for this matset; reuse egids for cell mat type
        CCMIOWriteMap( &error, cellMapID, CCMIOSIZEC( tot_elems ), CCMIOSIZEC( tot_elems ), &egids[0],
                       CCMIOINDEXC( 0 == m ? kCCMIOStart : num_elems ),
                       CCMIOINDEXC( matset_data.size() == m ? kCCMIOEnd : num_elems + this_num ) );
        CHK_SET_CCMERR( error, "Trouble writing cell map" );
        if( -1 == matset_data[m].matsetId )
                egids[i] = m;
        else
                egids[i] = matset_data[m].matsetId;
        CCMIOWriteCells( &error, cells, cellMapID, &egids[0], CCMIOINDEXC( 0 == m ? kCCMIOStart : num_elems ),
        CHK_SET_CCMERR( error, "Trouble writing Cell node" );
        // Write cell entity types
        const EntityHandle* conn;
        int num_conn;
        int has_mid_nodes[4];
        std::vector< EntityHandle > storage;
        for( i = 0, rit = matset_data[m].elems.begin(); i < this_num; i++, ++rit )
            result = mbImpl->get_connectivity( *rit, conn, num_conn, false, &storage );MB_CHK_SET_ERR( result, "Trouble getting connectivity for entity type check" );
            CN::HasMidNodes( mbImpl->type_from_handle( *rit ), num_conn, has_mid_nodes );
            egids[i] = moab_to_ccmio_type( mbImpl->type_from_handle( *rit ), has_mid_nodes );
        CCMIOWriteOpt1i( &error, cells, "CellTopologyType", CCMIOSIZEC( tot_elems ), &egids[0],
        CHK_SET_CCMERR( error, "Failed to write cell topo types" );
        num_elems += this_num;
    // Get skin and neumann set faces
    Range neuset_facets, skin_facets;
    Skinner skinner( mbImpl );
    result = skinner.find_skin( 0, all_elems, mDimension - 1, skin_facets );MB_CHK_SET_ERR( result, "Failed to get skin facets" );
    // Remove neumann set facets from skin facets, we have to output these
    // separately
    for( i = 0; i < neuset_data.size(); i++ )
        neuset_facets.merge( neuset_data[i].elems );
    skin_facets -= neuset_facets;
    // Make neuset_facets the union, and get ids for them
    neuset_facets.merge( skin_facets );
    result = mWriteIface->assign_ids( neuset_facets, mGlobalIdTag, 1 );
    int fmaxid = neuset_facets.size();
    // Write external faces
        Range::reverse_iterator rrit;
        unsigned char cmarks[2];
        Range ext_faces;
        std::vector< EntityHandle > mcells;
        // Removing the faces connected to two regions
        for( rrit = neuset_data[i].elems.rbegin(); rrit != neuset_data[i].elems.rend(); ++rrit )
            mcells.clear();
            result = mbImpl->get_adjacencies( &( *rrit ), 1, mDimension, false, mcells );MB_CHK_SET_ERR( result, "Trouble getting bounding cells" );
            result = mbImpl->tag_get_data( mEntityMark, &mcells[0], mcells.size(), cmarks );MB_CHK_SET_ERR( result, "Trouble getting mark tags on cells bounding facets" );
            if( mcells.size() == 2 && ( mWholeMesh || ( cmarks[0] && cmarks[1] ) ) )
            else
                // External face
                ext_faces.insert( *rrit );
        if( ext_faces.size() != 0 && neuset_data[i].neusetId != 0 )
            result = write_external_faces( rootID, topologyID, neuset_data[i].neusetId, ext_faces );MB_CHK_SET_ERR( result, "Trouble writing Neumann set facets" );
        ext_faces.clear();
    if( !skin_facets.empty() )
        result = write_external_faces( rootID, topologyID, 0, skin_facets );MB_CHK_SET_ERR( result, "Trouble writing skin facets" );
    // Now internal faces; loop over elements, do each face on the element
    // Mark tag, for face marking on each non-polyhedral element
    if( num_elems > 1 )
    {  // No internal faces for just one element
        Tag fmark_tag;
        unsigned char mval = 0x0, omval;
        result = mbImpl->tag_get_handle( "__fmark", 1, MB_TYPE_OPAQUE, fmark_tag, MB_TAG_DENSE | MB_TAG_CREAT, &mval );MB_CHK_SET_ERR( result, "Couldn't create mark tag" );
        std::vector< EntityHandle > tmp_face_cells, storage;
        std::vector< int > iface_connect, iface_cells;
        EntityHandle tmp_connect[CN::MAX_NODES_PER_ELEMENT];  // tmp connect vector
        const EntityHandle *connectc, *oconnectc;
        int num_connectc;  // Cell connectivity
        const EntityHandle* connectf;
        int num_connectf;  // Face connectivity
        for( i = 0, rit = all_elems.begin(); i < num_elems; i++, ++rit )
            EntityType etype = TYPE_FROM_HANDLE( *rit );
            // If not polyh, get mark
            if( MBPOLYHEDRON != etype && MBPOLYGON != etype )
                result = mbImpl->tag_get_data( fmark_tag, &( *rit ), 1, &mval );MB_CHK_SET_ERR( result, "Couldn't get mark data" );
            // Get cell connectivity, and whether it's a polyhedron
            result = mbImpl->get_connectivity( *rit, connectc, num_connectc, false, &storage );MB_CHK_SET_ERR( result, "Couldn't get entity connectivity" );
            // If polyh, write faces directly
            bool is_polyh = ( MBPOLYHEDRON == etype );
            int num_facets = ( is_polyh ? num_connectc : CN::NumSubEntities( etype, mDimension - 1 ) );
            // Loop over each facet of element, outputting it if not marked
            for( int f = 0; f < num_facets; f++ )
                // If this face marked, skip
                if( !is_polyh && ( ( mval >> f ) & 0x1 ) ) continue;
                // Get face connect and adj cells
                if( !is_polyh )
                    // (from CN)
                    CN::SubEntityConn( connectc, etype, mDimension - 1, f, tmp_connect, num_connectf );
                    connectf = tmp_connect;
                else
                    // Directly
                    result = mbImpl->get_connectivity( connectc[f], connectf, num_connectf, false );MB_CHK_SET_ERR( result, "Couldn't get polyhedron connectivity" );
                // Get adj cells from face connect (same for poly's and not, since both usually
                // go through vertices anyway)
                tmp_face_cells.clear();
                result = mbImpl->get_adjacencies( connectf, num_connectf, mDimension, false, tmp_face_cells );MB_CHK_SET_ERR( result, "Error getting adj hexes" );
                // If this face only bounds one cell, skip, since we exported external faces
                // before this loop
                if( tmp_face_cells.size() != 2 ) continue;
                // Switch cells so that *rit is always 1st (face connectivity is always written such
                // that that one is with forward sense)
                int side_num = 0, sense = 0, offset = 0;
                if( !is_polyh && tmp_face_cells[0] != *rit )
                    EntityHandle tmph = tmp_face_cells[0];
                    tmp_face_cells[0] = tmp_face_cells[1];
                    tmp_face_cells[1] = tmph;
                // Save ids of cells
                assert( tmp_face_cells[0] != tmp_face_cells[1] );
                iface_cells.resize( iface_cells.size() + 2 );
                result = mbImpl->tag_get_data( mGlobalIdTag, &tmp_face_cells[0], tmp_face_cells.size(),
                                               &iface_cells[iface_cells.size() - 2] );MB_CHK_SET_ERR( result, "Trouble getting global ids for bounded cells" );
                iface_connect.push_back( num_connectf );
                // Save indices of face vertices
                unsigned int tmp_size = iface_connect.size();
                iface_connect.resize( tmp_size + num_connectf );
                result = mbImpl->tag_get_data( mGlobalIdTag, connectf, num_connectf, &iface_connect[tmp_size] );MB_CHK_SET_ERR( result, "Trouble getting global id for internal face" );
                // Mark other cell with the right side #
                if( !is_polyh )
                    // Mark other cell for this face, if there is another cell
                    result = mbImpl->get_connectivity( tmp_face_cells[1], oconnectc, num_connectc, false, &storage );MB_CHK_SET_ERR( result, "Couldn't get other entity connectivity" );
                    // Get side number in other cell
                    CN::SideNumber( TYPE_FROM_HANDLE( tmp_face_cells[1] ), oconnectc, connectf, num_connectf,
                                    mDimension - 1, side_num, sense, offset );
                    // Set mark for that face on the other cell
                    result = mbImpl->tag_get_data( fmark_tag, &tmp_face_cells[1], 1, &omval );MB_CHK_SET_ERR( result, "Couldn't get mark data for other cell" );
                omval |= ( 0x1 << (unsigned int)side_num );
                result = mbImpl->tag_set_data( fmark_tag, &tmp_face_cells[1], 1, &omval );MB_CHK_SET_ERR( result, "Couldn't set mark data for other cell" );
            }  // Loop over faces in elem
        }      // Loop over elems
        // Write internal faces
        CCMIOID mapID;
        CCMIONewEntity( &error, rootID, kCCMIOMap, NULL, &mapID );
        CHK_SET_CCMERR( error, "Trouble creating Internal Face map node" );
        unsigned int num_ifaces = iface_cells.size() / 2;
        // Set gids for internal faces; reuse egids
        egids.resize( num_ifaces );
        for( i = 1; i <= num_ifaces; i++ )
            egids[i - 1] = fmaxid + i;
        CCMIOWriteMap( &error, mapID, CCMIOSIZEC( num_ifaces ), CCMIOSIZEC( fmaxid + num_ifaces ), &egids[0],
                       CCMIOINDEXC( kCCMIOStart ), CCMIOINDEXC( kCCMIOEnd ) );
        CHK_SET_CCMERR( error, "Trouble writing Internal Face map node" );
        CCMIOID id;
        CCMIONewEntity( &error, topologyID, kCCMIOInternalFaces, "Internal faces", &id );
        CHK_SET_CCMERR( error, "Failed to create Internal face node under Topology node" );
        CCMIOWriteFaces( &error, id, kCCMIOInternalFaces, mapID, CCMIOSIZEC( iface_connect.size() ), &iface_connect[0],
        CHK_SET_CCMERR( error, "Failure writing Internal face connectivity" );
        CCMIOWriteFaceCells( &error, id, kCCMIOInternalFaces, mapID, &iface_cells[0], CCMIOINDEXC( kCCMIOStart ),
        CHK_SET_CCMERR( error, "Failure writing Internal face cells" );
    return MB_SUCCESS;
ErrorCode moab::WriteCCMIO::write_dbl_option ( const char *  opt_name,
EntityHandle  seth,
Tag tag,
CCMIOID &  node
) [private]
Definition at line 554 of file WriteCCMIO.cpp.
References CHK_SET_CCMERR, moab::error(), ErrorCode, MB_SUCCESS, MB_TYPE_DOUBLE, mbImpl, moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
Referenced by write_problem_description().
    ErrorCode rval;
    if( !tag )
        rval = mbImpl->tag_get_handle( opt_name, 1, MB_TYPE_DOUBLE, tag );
        // Return success since that just means we don't have to write this option
        if( MB_SUCCESS != rval ) return MB_SUCCESS;
    double dum_val;
    rval = mbImpl->tag_get_data( tag, &seth, 1, &dum_val );
    CCMIOWriteOptf( &error, node, opt_name, dum_val );
    CHK_SET_CCMERR( error, "Trouble writing int option" );
    return MB_SUCCESS;
ErrorCode moab::WriteCCMIO::write_external_faces ( CCMIOID  rootID,
CCMIOID  topologyID,
int  set_num,
Range facets
) [private]
Definition at line 1194 of file WriteCCMIO.cpp.
References moab::Range::begin(), CHK_SET_CCMERR, moab::Range::end(), moab::error(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), moab::WriteUtilIface::get_element_connect(), get_gids(), MB_CHK_SET_ERR, MB_FILE_WRITE_ERROR, MB_SET_ERR, MB_SUCCESS, mbImpl, mDimension, mEntityMark, mGlobalIdTag, mWholeMesh, mWriteIface, moab::Range::rbegin(), moab::Range::size(), and moab::Interface::tag_get_data().
    CCMIOID mapID, id;
    // Get gids for these faces
    int *gids        = NULL, minid, maxid;
    ErrorCode result = get_gids( facets, gids, minid, maxid );MB_CHK_SET_ERR( result, "Trouble getting global ids for facets" );
    // Write the face id map
    CHK_SET_CCMERR( error, "Problem creating face id map" );
    CCMIOWriteMap( &error, mapID, CCMIOSIZEC( facets.size() ), CCMIOSIZEC( maxid ), gids, CCMIOINDEXC( kCCMIOStart ),
    CHK_SET_CCMERR( error, "Problem writing face id map" );
    // Get the connectivity of the faces; set size by how many verts in last facet
    const EntityHandle* connect;
    int num_connect;
    result = mbImpl->get_connectivity( *facets.rbegin(), connect, num_connect );MB_CHK_SET_ERR( result, "Failed to get connectivity of last facet" );
    std::vector< int > fconnect( facets.size() * ( num_connect + 1 ) );
    result = mWriteIface->get_element_connect( facets.begin(), facets.end(), num_connect, mGlobalIdTag, fconnect.size(),
                                               &fconnect[0], true );MB_CHK_SET_ERR( result, "Failed to get facet connectivity" );
    // Get and write a new external face entity
    CCMIONewIndexedEntity( &error, topologyID, kCCMIOBoundaryFaces, set_num, "Boundary faces", &id );
    CHK_SET_CCMERR( error, "Problem creating boundary face entity" );
    CCMIOWriteFaces( &error, id, kCCMIOBoundaryFaces, mapID, CCMIOSIZEC( fconnect.size() ), &fconnect[0],
    CHK_SET_CCMERR( error, "Problem writing boundary faces" );
    // Get info on bounding cells; reuse fconnect
    std::vector< EntityHandle > cells;
    int i, j = 0;
    Range dead_facets;
    Range::iterator rit;
    // About error checking in this loop: if any facets have no bounding cells,
    // this is an error, since global ids for facets are computed outside this loop
    for( rit = facets.begin(), i = 0; rit != facets.end(); ++rit, i++ )
        cells.clear();
        // Get cell then gid of cell
        result = mbImpl->get_adjacencies( &( *rit ), 1, mDimension, false, cells );MB_CHK_SET_ERR( result, "Trouble getting bounding cells" );
        if( cells.empty() )
            MB_SET_ERR( MB_FILE_WRITE_ERROR, "External facet with no output bounding cell" );
        // Check we don't bound more than one cell being output
        result = mbImpl->tag_get_data( mEntityMark, &cells[0], cells.size(), cmarks );MB_CHK_SET_ERR( result, "Trouble getting mark tags on cells bounding facets" );
        if( cells.size() == 2 && ( mWholeMesh || ( cmarks[0] && cmarks[1] ) ) )
            MB_SET_ERR( MB_FILE_WRITE_ERROR, "External facet with two output bounding cells" );
        else if( 1 == cells.size() && !mWholeMesh && !cmarks[0] )
            MB_SET_ERR( MB_FILE_WRITE_ERROR, "External facet with no output bounding cells" );
        // Make sure 1st cell is the one being output
        if( 2 == cells.size() && !( cmarks[0] | 0x0 ) && ( cmarks[1] & 0x1 ) ) cells[0] = cells[1];
        // Get gid for bounded cell
        result = mbImpl->tag_get_data( mGlobalIdTag, &cells[0], 1, &fconnect[j] );MB_CHK_SET_ERR( result, "Couldn't get global id tag for bounded cell" );
        j++;
    // Write the bounding cell data
    CCMIOWriteFaceCells( &error, id, kCCMIOBoundaryFaces, mapID, &fconnect[0], CCMIOINDEXC( kCCMIOStart ),
    CHK_SET_CCMERR( error, "Problem writing boundary cell data" );
    return MB_SUCCESS;
ErrorCode moab::WriteCCMIO::write_file ( const char *  file_name,
const FileOptions opts,
const EntityHandle output_list,
const int  num_sets,
const std::vector< std::string > &  qa_list,
const Tag tag_list = NULL,
int  num_tags = 0,
int  export_dimension = 3
) [virtual]
writes out a file
Implements moab::WriterIface.
Definition at line 157 of file WriteCCMIO.cpp.
References moab::WriteUtilIface::assign_ids(), close_and_compress(), create_ccmio_structure(), ErrorCode, gather_matset_info(), gather_neuset_info(), get_sets(), MB_CHK_SET_ERR, MB_FILE_WRITE_ERROR, MB_SET_ERR, MB_SUCCESS, mDimension, mDirichletSetTag, mGlobalIdTag, mMaterialSetTag, mNeumannSetTag, mWriteIface, open_file(), write_cells_and_faces(), write_nodes(), write_problem_description(), write_processor(), and write_solution_data().
    assert( 0 != mMaterialSetTag && 0 != mNeumannSetTag && 0 != mDirichletSetTag );
    ErrorCode result;
    // Check overwrite flag and file existence
    if( !overwrite )
        FILE* file = fopen( file_name, "r" );
        if( file )
            fclose( file );
            MB_SET_ERR( MB_FILE_WRITE_ERROR, "File exists but overwrite set to false" );
    mDimension = 3;
    std::vector< EntityHandle > matsets, dirsets, neusets, partsets;
    // Separate into material, dirichlet, neumann, partition sets
    result = get_sets( ent_handles, num_sets, matsets, dirsets, neusets, partsets );MB_CHK_SET_ERR( result, "Failed to get material/etc. sets" );
    // If entity handles were input but didn't contain matsets, return error
    if( ent_handles && matsets.empty() )
        MB_SET_ERR( MB_FILE_WRITE_ERROR, "Sets input to write but no material sets found" );
    // Otherwise, if no matsets, use root set
    if( matsets.empty() ) matsets.push_back( 0 );
    std::vector< MaterialSetData > matset_info;
    Range all_verts;
    result = gather_matset_info( matsets, matset_info, all_verts );MB_CHK_SET_ERR( result, "gathering matset info failed" );
    // Assign vertex gids
    result = mWriteIface->assign_ids( all_verts, mGlobalIdTag, 1 );MB_CHK_SET_ERR( result, "Failed to assign vertex global ids" );
    // Some CCMIO descriptors
    CCMIOID rootID, topologyID, stateID, problemID, verticesID, processorID;
    // Try to open the file and establish state
    result = open_file( file_name, overwrite, rootID );MB_CHK_SET_ERR( result, "Couldn't open file or create state" );
    result = create_ccmio_structure( rootID, stateID, processorID );MB_CHK_SET_ERR( result, "Problem creating CCMIO file structure" );
    result = write_nodes( rootID, all_verts, mDimension, verticesID );MB_CHK_SET_ERR( result, "write_nodes failed" );
    std::vector< NeumannSetData > neuset_info;
    result = gather_neuset_info( neusets, neuset_info );MB_CHK_SET_ERR( result, "Failed to get neumann set info" );
    result = write_cells_and_faces( rootID, matset_info, neuset_info, all_verts, topologyID );MB_CHK_SET_ERR( result, "write_cells_and_faces failed" );
    result = write_problem_description( rootID, stateID, problemID, processorID, matset_info, neuset_info );MB_CHK_SET_ERR( result, "write_problem_description failed" );
    result = write_solution_data();MB_CHK_SET_ERR( result, "Trouble writing solution data" );
    result = write_processor( processorID, verticesID, topologyID );MB_CHK_SET_ERR( result, "Trouble writing processor" );
    result = close_and_compress( file_name, rootID );MB_CHK_SET_ERR( result, "Close or compress failed" );
    return MB_SUCCESS;
ErrorCode moab::WriteCCMIO::write_int_option ( const char *  opt_name,
EntityHandle  seth,
Tag tag,
CCMIOID &  node
) [private]
Definition at line 531 of file WriteCCMIO.cpp.
References CHK_SET_CCMERR, moab::error(), ErrorCode, MB_SUCCESS, MB_TYPE_INTEGER, mbImpl, moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
    ErrorCode rval;
    if( !tag )
        rval = mbImpl->tag_get_handle( opt_name, 1, MB_TYPE_INTEGER, tag );
    int dum_val;
    CCMIOWriteOpti( &error, node, opt_name, dum_val );
    return MB_SUCCESS;
ErrorCode moab::WriteCCMIO::write_meshes ( MeshInfo mesh_info,
std::vector< NeumannSetData > &  neuset_data,
Range verts,
const int *  vgids
) [private]
ErrorCode moab::WriteCCMIO::write_nodes ( CCMIOID  rootID,
const Range nodes,
CCMIOID &  verticesID
) [private]
Definition at line 734 of file WriteCCMIO.cpp.
References moab::Range::begin(), CHK_SET_CCMERR, moab::Range::end(), moab::error(), ErrorCode, moab::WriteUtilIface::get_node_coords(), MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, mbImpl, mGlobalIdTag, mWriteIface, moab::Range::size(), moab::Interface::tag_get_data(), and transform_coords().
    // Get/write map (global ids) first (gids already assigned)
    unsigned int num_verts = verts.size();
    std::vector< int > vgids( num_verts );
    ErrorCode result = mbImpl->tag_get_data( mGlobalIdTag, verts, &vgids[0] );MB_CHK_SET_ERR( result, "Failed to get global ids for vertices" );
    // Create the map node for vertex ids, and write them to that node
    CCMIOID mapID;
    CCMIONewEntity( &error, rootID, kCCMIOMap, "Vertex map", &mapID );
    CHK_SET_CCMERR( error, "Failure creating Vertex map node" );
    int maxid = *std::max_element( vgids.begin(), vgids.end() );
    CCMIOWriteMap( &error, mapID, CCMIOSIZEC( num_verts ), CCMIOSIZEC( maxid ), &vgids[0], CCMIOINDEXC( kCCMIOStart ),
    CHK_SET_CCMERR( error, "Problem writing node map" );
    // Create the vertex coordinate node, and write it
    CCMIONewEntity( &error, rootID, kCCMIOVertices, "Vertices", &verticesID );
    CHK_SET_CCMERR( error, "Trouble creating vertices node" );
    // Get the vertex locations
    double* coords = new double[3 * num_verts];
    std::vector< double* > coord_arrays( 3 );
    // Cppcheck warning (false positive): variable coord_arrays is assigned a value that is never
    // used
    coord_arrays[0] = coords;
    coord_arrays[1] = coords + num_verts;
    coord_arrays[2] = ( dimension == 3 ? coords + 2 * num_verts : NULL );
    result          = mWriteIface->get_node_coords( -1, verts.begin(), verts.end(), 3 * num_verts, coords );
    if( result != MB_SUCCESS )
        delete[] coords;
        return result;
    // Transform coordinates, if necessary
    result = transform_coords( dimension, num_verts, coords );
        delete[] coords;
        MB_SET_ERR( result, "Trouble transforming vertex coordinates" );
    // Write the vertices
    CCMIOWriteVerticesd( &error, verticesID, CCMIOSIZEC( dimension ), 1.0, mapID, coords, CCMIOINDEXC( kCCMIOStart ),
    CHK_SET_CCMERR( error, "CCMIOWriteVertices failed" );
    // Clean up
    delete[] coords;
    return MB_SUCCESS;
ErrorCode moab::WriteCCMIO::write_problem_description ( CCMIOID  rootID,
CCMIOID  stateID,
CCMIOID &  problemID,
) [private]
Definition at line 358 of file WriteCCMIO.cpp.
References moab::Range::begin(), CHK_SET_CCMERR, moab::Range::empty(), moab::error(), ErrorCode, moab::Interface::get_entities_by_type_and_tag(), MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_ANY, MB_TYPE_OPAQUE, MBENTITYSET, mbImpl, mBoundaryTypeTag, mColorIdxTag, mCreatingProgramTag, mesh, mFreeSurfaceMaterialTag, mGroupIdTag, mLightMaterialTag, mMaterialIdTag, mMaterialTypeTag, mNameTag, mPorosityIdTag, mProcessorIdTag, mProstarRegionNumberTag, mRadiationTag, mSpinIdTag, mThicknessTag, NAME_TAG_SIZE, moab::Interface::tag_get_bytes(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), write_dbl_option(), write_int_option(), and write_str_option().
    // Write out a dummy problem description.  If we happen to know that
    // there already is a problem description previously recorded that
    // is valid we could skip this step.
    CCMIOID id;
    ErrorCode rval;
    bool root_tagged = false, other_set_tagged = false;
    Tag simname;
    Range dum_sets;
    rval = mbImpl->tag_get_handle( "Title", 0, MB_TYPE_OPAQUE, simname, MB_TAG_ANY );
    if( MB_SUCCESS == rval )
        int tag_size;
        rval = mbImpl->tag_get_bytes( simname, tag_size );
            std::vector< char > title_tag( tag_size + 1 );
            rval = mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &simname, NULL, 1, dum_sets );
            if( MB_SUCCESS == rval && !dum_sets.empty() )
                rval = mbImpl->tag_get_data( simname, &( *dum_sets.begin() ), 1, &title_tag[0] );MB_CHK_SET_ERR( rval, "Problem getting simulation name tag" );
                other_set_tagged = true;
            else if( MB_SUCCESS == rval )
                // Check to see if interface was tagged
                rval = mbImpl->tag_get_data( simname, &mesh, 1, &title_tag[0] );
                    root_tagged = true;
                else
                    rval = MB_SUCCESS;
            *title_tag.rbegin() = '\0';
            if( root_tagged || other_set_tagged )
                CCMIONode rootNode;
                if( kCCMIONoErr == CCMIOGetEntityNode( &error, rootID, &rootNode ) )
                    CCMIOSetTitle( &error, rootNode, &title_tag[0] );
                    CHK_SET_CCMERR( error, "Trouble setting title" );
    rval = mbImpl->tag_get_handle( "CreatingProgram", 0, MB_TYPE_OPAQUE, mCreatingProgramTag, MB_TAG_ANY );
        int tag_size;
        rval = mbImpl->tag_get_bytes( mCreatingProgramTag, tag_size );
            std::vector< char > cp_tag( tag_size + 1 );
            rval = mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &mCreatingProgramTag, NULL, 1, dum_sets );
                rval = mbImpl->tag_get_data( mCreatingProgramTag, &( *dum_sets.begin() ), 1, &cp_tag[0] );MB_CHK_SET_ERR( rval, "Problem getting creating program tag" );
                rval = mbImpl->tag_get_data( mCreatingProgramTag, &mesh, 1, &cp_tag[0] );
                    root_tagged = true;
                else
                    rval = MB_SUCCESS;
            *cp_tag.rbegin() = '\0';
                CCMIONode rootNode;
                    CCMIOWriteOptstr( &error, processorID, "CreatingProgram", &cp_tag[0] );
                    CHK_SET_CCMERR( error, "Trouble setting creating program" );
    CCMIONewEntity( &error, rootID, kCCMIOProblemDescription, NULL, &problemID );
    CHK_SET_CCMERR( error, "Trouble creating problem node" );
    // Write material types and other info
    for( unsigned int i = 0; i < matset_data.size(); i++ )
        if( !matset_data[i].setName.empty() )
            CCMIONewIndexedEntity( &error, problemID, kCCMIOCellType, matset_data[i].matsetId,
                                   matset_data[i].setName.c_str(), &id );
            CHK_SET_CCMERR( error, "Failure creating celltype node" );
            CCMIOWriteOptstr( &error, id, "MaterialType", matset_data[i].setName.c_str() );
            CHK_SET_CCMERR( error, "Error assigning material name" );
        else
            std::ostringstream os;
            std::string mat_name = "Material", temp_str;
            os << mat_name << ( i + 1 );
            temp_str = os.str();
            strcpy( dum_name, temp_str.c_str() );
            CCMIONewIndexedEntity( &error, problemID, kCCMIOCellType, matset_data[i].matsetId, dum_name, &id );
            CCMIOWriteOptstr( &error, id, "MaterialType", dum_name );
            os.str( "" );
        rval = write_int_option( "MaterialId", matset_data[i].setHandle, mMaterialIdTag, id );MB_CHK_SET_ERR( rval, "Trouble writing MaterialId option" );
        rval = write_int_option( "Radiation", matset_data[i].setHandle, mRadiationTag, id );MB_CHK_SET_ERR( rval, "Trouble writing Radiation option" );
        rval = write_int_option( "PorosityId", matset_data[i].setHandle, mPorosityIdTag, id );MB_CHK_SET_ERR( rval, "Trouble writing PorosityId option" );
        rval = write_int_option( "SpinId", matset_data[i].setHandle, mSpinIdTag, id );MB_CHK_SET_ERR( rval, "Trouble writing SpinId option" );
        rval = write_int_option( "GroupId", matset_data[i].setHandle, mGroupIdTag, id );MB_CHK_SET_ERR( rval, "Trouble writing GroupId option" );
        rval = write_int_option( "ColorIdx", matset_data[i].setHandle, mColorIdxTag, id );MB_CHK_SET_ERR( rval, "Trouble writing ColorIdx option" );
        rval = write_int_option( "ProcessorId", matset_data[i].setHandle, mProcessorIdTag, id );MB_CHK_SET_ERR( rval, "Trouble writing ProcessorId option" );
        rval = write_int_option( "LightMaterial", matset_data[i].setHandle, mLightMaterialTag, id );MB_CHK_SET_ERR( rval, "Trouble writing LightMaterial option." );
        rval = write_int_option( "FreeSurfaceMaterial", matset_data[i].setHandle, mFreeSurfaceMaterialTag, id );MB_CHK_SET_ERR( rval, "Trouble writing FreeSurfaceMaterial option" );
        rval = write_dbl_option( "Thickness", matset_data[i].setHandle, mThicknessTag, id );MB_CHK_SET_ERR( rval, "Trouble writing Thickness option" );
        rval = write_str_option( "MaterialType", matset_data[i].setHandle, mMaterialTypeTag, id );MB_CHK_SET_ERR( rval, "Trouble writing MaterialType option" );
    // Write neumann set info
    for( unsigned int i = 0; i < neuset_data.size(); i++ )
        // Use the label to encode the id
        std::ostringstream dum_id;
        dum_id << neuset_data[i].neusetId;
        CCMIONewIndexedEntity( &error, problemID, kCCMIOBoundaryRegion, neuset_data[i].neusetId, dum_id.str().c_str(),
                               &id );
        CHK_SET_CCMERR( error, "Failure creating BoundaryRegion node" );
        rval = write_str_option( "BoundaryName", neuset_data[i].setHandle, mNameTag, id );MB_CHK_SET_ERR( rval, "Trouble writing boundary type number" );
        rval = write_str_option( "BoundaryType", neuset_data[i].setHandle, mBoundaryTypeTag, id );MB_CHK_SET_ERR( rval, "Trouble writing boundary type number" );
        rval = write_int_option( "ProstarRegionNumber", neuset_data[i].setHandle, mProstarRegionNumberTag, id );MB_CHK_SET_ERR( rval, "Trouble writing prostar region number" );
    CCMIOWriteState( &error, stateID, problemID, "Example state" );
    CHK_SET_CCMERR( error, "Failure writing problem state" );
    // Get cell types; reuse cell ids array
    //  for (i = 0, rit = all_elems.begin(); i < num_elems; i++, ++rit) {
    //    egids[i] = ccm_types[mbImpl->type_from_handle(*rit)];
    //    assert(-1 != egids[i]);
    return MB_SUCCESS;
ErrorCode moab::WriteCCMIO::write_processor ( CCMIOID  processorID,
CCMIOID  verticesID,
CCMIOID  topologyID
) [private]
finalize processor
Definition at line 237 of file WriteCCMIO.cpp.
    // Now we have the mesh (vertices and topology) and the post data written.
    // Since we now have their IDs, we can write out the processor information.
    CCMIOWriteProcessor( &error, processorID, NULL, &verticesID, NULL, &topologyID, NULL, NULL, NULL, NULL );
    CHK_SET_CCMERR( error, "Problem writing CCMIO processor" );
    return MB_SUCCESS;
Definition at line 231 of file WriteCCMIO.cpp.
References MB_SUCCESS.
    // For now, no solution (tag) data
    return MB_SUCCESS;
ErrorCode moab::WriteCCMIO::write_str_option ( const char *  opt_name,
EntityHandle  seth,
Tag tag,
CCMIOID &  node,
const char *  other_name = NULL
) [private]
Definition at line 577 of file WriteCCMIO.cpp.
References CHK_SET_CCMERR, moab::error(), ErrorCode, MB_SUCCESS, MB_TAG_ANY, MB_TYPE_OPAQUE, mbImpl, moab::Interface::tag_get_bytes(), moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
    int tag_size;
    ErrorCode rval;
    if( !tag )
        rval = mbImpl->tag_get_handle( opt_name, 0, MB_TYPE_OPAQUE, tag, MB_TAG_ANY );
    rval = mbImpl->tag_get_bytes( tag, tag_size );
    std::vector< char > opt_val( tag_size + 1 );
    rval = mbImpl->tag_get_data( tag, &seth, 1, &opt_val[0] );
    // Null-terminate if necessary
    if( std::find( opt_val.begin(), opt_val.end(), '\0' ) == opt_val.end() ) *opt_val.rbegin() = '\0';
    if( other_name )
        CCMIOWriteOptstr( &error, node, other_name, &opt_val[0] );
        CHK_SET_CCMERR( error, "Failure writing an option string MaterialType" );
    else
        CCMIOWriteOptstr( &error, node, opt_name, &opt_val[0] );
    return MB_SUCCESS;
Member Data Documentation
std::string moab::WriteCCMIO::fileName [private]
file name
Definition at line 139 of file WriteCCMIO.hpp.
Definition at line 155 of file WriteCCMIO.hpp.
Definition at line 153 of file WriteCCMIO.hpp.
Definition at line 142 of file WriteCCMIO.hpp.
Definition at line 147 of file WriteCCMIO.hpp.
Referenced by get_sets(), write_file(), and WriteCCMIO().
Definition at line 150 of file WriteCCMIO.hpp.
Referenced by WriteCCMIO().
Definition at line 152 of file WriteCCMIO.hpp.
Cached tags for reading. Note that all these tags are defined when the core is initialized.
Definition at line 146 of file WriteCCMIO.hpp.
Referenced by gather_matset_info(), get_sets(), write_file(), and WriteCCMIO().
Definition at line 149 of file WriteCCMIO.hpp.
Referenced by get_sets(), and WriteCCMIO().
List of all members.
