moab::WriteCGNS Class Reference
Export CGNS files. More...
#include <WriteCGNS.hpp>
+ Inheritance diagram for moab::WriteCGNS:
+ Collaboration diagram for moab::WriteCGNS:
Classes
class  SetStruct
Public Member Functions
 WriteCGNS (Interface *impl)
 Constructor.
virtual ~WriteCGNS ()
 Destructor.
ErrorCode write_file (const char *file_name, const bool overwrite, const FileOptions &opts, const EntityHandle *output_list, const int num_sets, const std::vector< std::string > &qa_list, const Tag *tag_list=NULL, int num_tags=0, int export_dimension=3)
 writes out a file
ErrorCode get_vertex_entities (cgsize_t &VrtSize, std::vector< moab::EntityHandle > &Nodes)
ErrorCode get_edge_entities (cgsize_t &EdgeSize, std::vector< moab::EntityHandle > &Edges)
ErrorCode get_face_entities (cgsize_t &FaceSize, std::vector< moab::EntityHandle > &Faces)
ErrorCode get_cell_entities (cgsize_t &CellSize, std::vector< moab::EntityHandle > &Cells)
ErrorCode write_coord_cgns (std::vector< moab::EntityHandle > &nodes)
ErrorCode set_tag_values (std::vector< moab::Tag > &TagHandles, std::vector< moab::EntityHandle > &Edges, std::vector< moab::EntityHandle > &Faces, std::vector< moab::EntityHandle > &Cells, std::vector< WriteCGNS::SetStruct > &Sets)
ErrorCode get_set_entities (int i, std::vector< moab::Tag > &TagHandles, std::vector< WriteCGNS::SetStruct > &Sets)
ErrorCode get_cgns_type (int i, std::vector< WriteCGNS::SetStruct > &Sets)
ErrorCode get_conn_table (std::vector< moab::EntityHandle > &Elements, std::vector< int > &Begin, std::vector< int > &End, std::vector< moab::Tag > &TagHandles, std::vector< WriteCGNS::SetStruct > &Sets, std::vector< std::vector< cgsize_t > > &ConnTable)
int moab_cgns_conv (const EntityHandle handle)
Static Public Member Functions
static WriterIfacefactory (Interface *)
 factory method
Private Attributes
InterfacembImpl
WriteUtilIfacemWriteIface
const char * fileName
int IndexFile
const char * BaseName
int IndexBase
const char * ZoneName
int IndexZone
int IndexSection
int IndexCoord [3]
int celldim
int physdim
cgsize_t isize [3]
std::vector< moab::EntityHandleNodes
std::vector< moab::EntityHandleEdges
std::vector< moab::EntityHandleFaces
std::vector< moab::EntityHandleCells
cgsize_t VrtSize
cgsize_t EdgeSize
cgsize_t FaceSize
cgsize_t CellSize
Detailed Description
Export CGNS files.
Author:
Carlos Junqueira Junior
Definition at line 46 of file WriteCGNS.hpp.
Constructor.
Definition at line 25 of file WriteCGNS.cpp.
References IndexCoord, isize, mWriteIface, and moab::Interface::query_interface().
Referenced by factory().
    : mbImpl( impl ), fileName( NULL ), IndexFile( 0 ), BaseName( NULL ), IndexBase( 0 ), ZoneName( NULL ),
      IndexZone( 0 ), IndexSection( 0 ), celldim( 0 ), physdim( 0 ), VrtSize( 0 ), EdgeSize( 0 ), FaceSize( 0 ),
      CellSize( 0 )
    impl->query_interface( mWriteIface );
    IndexCoord[0] = IndexCoord[1] = IndexCoord[2] = 0;
    isize[0] = isize[1] = isize[2] = 0;
Destructor.
Definition at line 35 of file WriteCGNS.cpp.
References mbImpl, mWriteIface, and moab::Interface::release_interface().
Member Function Documentation
factory method
Definition at line 20 of file WriteCGNS.cpp.
References WriteCGNS().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
    return new WriteCGNS( iface );
ErrorCode moab::WriteCGNS::get_cell_entities ( cgsize_t CellSize,
std::vector< moab::EntityHandle > &  Cells
Definition at line 337 of file WriteCGNS.cpp.
References celldim, ErrorCode, moab::Interface::get_entities_by_dimension(), mbImpl, and physdim.
Referenced by write_file().
    ErrorCode rval;
    // The first input is 0 because one queries the entire mesh.
    // Get all entities of dimension = 3 in Cell
    rval = mbImpl->get_entities_by_dimension( 0, 3, Cells_, false );
    if( Cells_.size() )
        celldim = 3;
        physdim = 3;
        // get the amout of volumes
        CellSize_ = Cells_.size();
    // done
    return rval;
ErrorCode moab::WriteCGNS::get_cgns_type ( int  i,
std::vector< WriteCGNS::SetStruct > &  Sets
Definition at line 637 of file WriteCGNS.cpp.
References MB_SUCCESS.
Referenced by set_tag_values().
    std::vector< int > Test;
    int Sum = 0;
    // NbEntities is a vector which has the number of entities of each type
    // 0-MBEDGE | 1-MBTRI | 2-MBQUAD | 3-MBTET | 4-MBPYRAMID | 5-MBPRISM | 6-MBHEX
    // if NbEntities[i]>0 then Test[i]=1
    // else then Test[i]=0
    for( int j = 0; j < (int)Sets[i].NbEntities.size(); ++j )
        if( Sets[i].NbEntities[j] > 0 )
            Test.push_back( 1 );
            Sum++;
        else
            Test.push_back( 0 );
    // Test the Sum
    // if Sum > 1 then the Set is MIXED
    // if Sum = 0 then the Set is Homogeneous
    // else then the Set is empty
    if( Sum > 1 )
        Sets[i].CGNSType = MIXED;
    else if( Sum == 1 )
        int j = 0;
        std::cout << "Homogeneous Type\n";
        while( j < (int)Sets[i].NbEntities.size() && Sets[i].NbEntities[j] != 1 )
            ++j;
        switch( j )
            case 0:
                Sets[i].CGNSType = BAR_2;
                break;
            case 1:
                Sets[i].CGNSType = TRI_3;
                break;
            case 2:
                Sets[i].CGNSType = QUAD_4;
                break;
            case 3:
                Sets[i].CGNSType = TETRA_4;
                break;
            case 4:
                Sets[i].CGNSType = PYRA_5;
                break;
            case 5:
                Sets[i].CGNSType = PENTA_6;
                break;
            case 6:
                Sets[i].CGNSType = HEXA_8;
                break;
            default:
                std::cout << "It was not possible to identify the CGNSType\n";
                return MB_FAILURE;
    else
        Sets[i].CGNSType = ElementTypeNull;
    }  // NOT SURE IF THAT'S THE RIGHT WAY.......
    // Clear the test vector
    Test.clear();
    return MB_SUCCESS;
ErrorCode moab::WriteCGNS::get_conn_table ( std::vector< moab::EntityHandle > &  Elements,
std::vector< int > &  Begin,
std::vector< int > &  End,
std::vector< moab::Tag > &  TagHandles,
std::vector< WriteCGNS::SetStruct > &  Sets,
std::vector< std::vector< cgsize_t > > &  ConnTable
Definition at line 715 of file WriteCGNS.cpp.
References cgsize_t, ErrorCode, moab::Interface::get_connectivity(), MB_SUCCESS, mbImpl, moab_cgns_conv(), and moab::Interface::tag_get_data().
    ErrorCode rval;
    //   int Begin = 0; // GOT TO WORK ON THIS
    //   int End;
    // Get the number of Tags in the mesh
    int NbTags = TagHandles.size();
    // Test all Elements, get their ids and connectivity
    // to fill ConnTable
    for( std::vector< moab::EntityHandle >::iterator i = Elements.begin(); i != Elements.end(); ++i )
        int id;
        // Test all Tags
        for( int j = 0; j < NbTags; ++j )
            // Test if the Tag has data
            if( Sets[j].IdSet != -1 )
                // Try to get data from entity
                rval = mbImpl->tag_get_data( TagHandles[j], &*i, 1, &id );
                if( MB_SUCCESS != rval )
                    return rval;
                // If successful id==j
                if( id == j )
                    // Get the entity type of the EntityHandle wich points to Cells
                    int num_vtx;               // Number of MeshVertices in array connectivity.
                    const EntityHandle* conn;  // Array in which connectivity of entity_handle is returned.
                    // Gets a pointer to constant connectivity data of entity_handle
                    rval = mbImpl->get_connectivity( *i, conn, num_vtx );
                        return rval;
                    // If the Set is MIXED type
                    // push CGNS ENUM type of the entity
                    // before the connectivity
                    if( Sets[j].CGNSType == MIXED )
                        ConnTable[j].push_back( moab_cgns_conv( *i ) );  // moab_cgns_conv return an int which
        // represents the CGNS type
                        Begin[j]++;
                    End[j] = Begin[j] + num_vtx;
                    // Push conn in ConnTable in which "j" is the Set Index
                    for( int k = Begin[j]; k < End[j]; ++k )
                        ConnTable[j].push_back( (cgsize_t)conn[k - Begin[j]] );
                    Begin[j] = End[j];
    return MB_SUCCESS;
ErrorCode moab::WriteCGNS::get_edge_entities ( cgsize_t EdgeSize,
std::vector< moab::EntityHandle > &  Edges
Definition at line 301 of file WriteCGNS.cpp.
    ErrorCode rval;
    // Get all entities of dimension = 1 in Edges
    rval = mbImpl->get_entities_by_dimension( 0, 1, Edges_, false );
    if( Edges_.size() > 0 )
        celldim = 1;
        physdim = 1;
        // get the amout of edges
        EdgeSize_ = Edges_.size();
    // done
    return rval;
ErrorCode moab::WriteCGNS::get_face_entities ( cgsize_t FaceSize,
std::vector< moab::EntityHandle > &  Faces
Definition at line 319 of file WriteCGNS.cpp.
    ErrorCode rval;
    // Get all entities of dimension = 2 in Faces
    rval = mbImpl->get_entities_by_dimension( 0, 2, Faces_, false );
    if( Faces_.size() )
        celldim = 2;
        physdim = 2;
        // get the amout of faces
        FaceSize_ = Faces_.size();
    // done
    return rval;
ErrorCode moab::WriteCGNS::get_set_entities ( int  i,
Definition at line 532 of file WriteCGNS.cpp.
References ErrorCode, moab::Interface::get_number_entities_by_type_and_tag(), MB_SUCCESS, MBEDGE, MBHEX, mbImpl, MBPRISM, MBPYRAMID, MBQUAD, MBTET, and MBTRI.
    ErrorCode rval;
    // Get the number of MBEDGE entities
    // NbEntities[0] holds the number of MBEDGE in the "Sets"
    int Number = 0;
    rval       = mbImpl->get_number_entities_by_type_and_tag( 0, MBEDGE, &TagHandles[i], 0, 1, Number );
    if( rval != MB_SUCCESS )
        std::cout << "Problem to get the number of entities by type and tag\n";
        return rval;
    Sets[i].NbEntities.push_back( Number );  // MBEDGE == Sets[i].NbEntities[0]
    Sets[i].NbEdges += Number;
    std::cout << "\tNumber of MBEDGE = " << Number << "\n";
    // Get the number of MBTRI entities
    // NbEntities[1] holds the number of MBTRI in the "Sets"
    Number = 0;
    rval   = mbImpl->get_number_entities_by_type_and_tag( 0, MBTRI, &TagHandles[i], 0, 1, Number );
        return rval;
    Sets[i].NbEntities.push_back( Number );  // MBTRI == Sets[i].NbEntities[1]
    Sets[i].NbFaces += Number;
    std::cout << "\tNumber of MBTRI = " << Number << "\n";
    // Get the number of MBQUAD entities
    // NbEntities[2] holds the number of MBQUAD in the "Sets"
    Number = 0;
    rval   = mbImpl->get_number_entities_by_type_and_tag( 0, MBQUAD, &TagHandles[i], 0, 1, Number );
        return rval;
    Sets[i].NbEntities.push_back( Number );  // MBQUAD == Sets[i].NbEntities[2]
    std::cout << "\tNumber of MBQUAD = " << Number << "\n";
    // Get the number of MBTET entities
    // NbEntities[3] holds the number of MBTET in the "Sets"
    Number = 0;
    rval   = mbImpl->get_number_entities_by_type_and_tag( 0, MBTET, &TagHandles[i], 0, 1, Number );
        return rval;
    Sets[i].NbEntities.push_back( Number );  // MBTET == Sets[i].NbEntities[3]
    Sets[i].NbCells += Number;
    std::cout << "\tNumber of MBTET = " << Number << "\n";
    // Get the number of MBPYRAMID entities
    // NbEntities[4] holds the number of MBPYRAMID in the "Sets"
    Number = 0;
    rval   = mbImpl->get_number_entities_by_type_and_tag( 0, MBPYRAMID, &TagHandles[i], 0, 1, Number );
        return rval;
    Sets[i].NbEntities.push_back( Number );  // MBPYRAMID == Sets[i].NbEntities[4]
    std::cout << "\tNumber of MBPYRAMID = " << Number << "\n";
    // Get the number of MBPRISM entities - MBPRISM == PENTA_6
    // NbEntities[5] holds the number of MBPRISM in the "Sets"
    Number = 0;
    rval   = mbImpl->get_number_entities_by_type_and_tag( 0, MBPRISM, &TagHandles[i], 0, 1, Number );
        return rval;
    Sets[i].NbEntities.push_back( Number );  // MBPRISM == Sets[i].NbEntities[5]
    std::cout << "\tNumber of MBPRISM = " << Number << "\n";
    // Get the number of MBHEX entities
    // NbEntities[6] holds the number of MBHEX in the "Sets"
    Number = 0;
    rval   = mbImpl->get_number_entities_by_type_and_tag( 0, MBHEX, &TagHandles[i], 0, 1, Number );
        return rval;
    Sets[i].NbEntities.push_back( Number );  // MBHEX == Sets[i].NbEntities[6]
    std::cout << "\tNumber of MBHEX = " << Number << "\n";
    std::cout << "\tTotal number of Edges = " << Sets[i].NbEdges << "\n";
    std::cout << "\tTotal number of Faces = " << Sets[i].NbFaces << "\n";
    std::cout << "\tTotal number of Cells = " << Sets[i].NbCells << "\n";
    return MB_SUCCESS;
ErrorCode moab::WriteCGNS::get_vertex_entities ( cgsize_t VrtSize,
std::vector< moab::EntityHandle > &  Nodes
Definition at line 278 of file WriteCGNS.cpp.
References celldim, ErrorCode, moab::Interface::get_entities_by_dimension(), mbImpl, Nodes, and physdim.
    ErrorCode rval;
    // Get vertex entities
    // Retrieves all entities of dimension = 0 in "Nodes"
    rval = mbImpl->get_entities_by_dimension( 0, 0, Nodes_, false );
    if( Nodes.size() > 0 )
        celldim = 0;
        physdim = 0;
        // get the amout of vertex
        VrtSize_ = Nodes_.size();
    else
        std::cout << "The mesh has not node points.\n";
    // done
    return rval;
< Mesh Edge
< Triangular element (including shells)
< Quadrilateral element (including shells)
< Tetrahedral element
< Pyramid element
< Wedge element
< Hexahedral element
Definition at line 783 of file WriteCGNS.cpp.
References MBEDGE, MBHEX, mbImpl, MBPRISM, MBPYRAMID, MBQUAD, MBTET, MBTRI, and moab::Interface::type_from_handle().
Referenced by get_conn_table().
    EntityType MoabType = mbImpl->type_from_handle( handle );
    switch( MoabType )
        case MBEDGE: /**< Mesh Edge */
            return BAR_2;
        case MBTRI: /**< Triangular element (including shells) */
            return TRI_3;
        case MBQUAD: /**< Quadrilateral element (including shells) */
            return QUAD_4;
        case MBTET: /**< Tetrahedral element */
            return TETRA_4;
        case MBPYRAMID: /**< Pyramid element */
            return PYRA_5;
        case MBPRISM: /**< Wedge element */
            return PENTA_6;
        case MBHEX: /**< Hexahedral element */
            return HEXA_8;
        default:
            return 0;
ErrorCode moab::WriteCGNS::set_tag_values ( std::vector< moab::Tag > &  TagHandles,
std::vector< moab::EntityHandle > &  Edges,
std::vector< moab::EntityHandle > &  Faces,
std::vector< moab::EntityHandle > &  Cells,
Definition at line 438 of file WriteCGNS.cpp.
References Cells, ErrorCode, Faces, get_cgns_type(), get_set_entities(), MB_SUCCESS, mbImpl, physdim, moab::Interface::tag_get_name(), and moab::Interface::tag_set_data().
    ErrorCode rval;
    // Loop over all Tags
    for( int i = 0; i < NbTags; ++i )
        // Allocate another position in the vector of SetStruct using a default constructor
        Sets.push_back( SetStruct() );
        // Get the Tag name
        rval = mbImpl->tag_get_name( TagHandles[i], Sets[i].TagName );
            std::cout << "Problem to get Tag Name\n";
            return rval;
        std::cout << "Tag name= " << Sets[i].TagName << "\n";
        // Count all entities by type and put in Sets[i].NbEntities vector
        rval = get_set_entities( i, TagHandles, Sets );
            std::cout << "Problem to get Set entities\n";
            return rval;
        // Get the CGNSTYpe of the Set
        rval = get_cgns_type( i, Sets );
            std::cout << "Problem to get CGNSType\n";
            return rval;
        std::cout << "\tSets[" << i << "].CGNSType= " << Sets[i].CGNSType << "\n";
        // int Number;
        // Set a data index for Edges and TagHandles[i]
        if( Sets[i].CGNSType == BAR_2 || Sets[i].CGNSType == TRI_3 || Sets[i].CGNSType == QUAD_4 ||
            Sets[i].CGNSType == TETRA_4 || Sets[i].CGNSType == PYRA_5 || Sets[i].CGNSType == PENTA_6 ||
            Sets[i].CGNSType == HEXA_8 || Sets[i].CGNSType == MIXED )
            if( Sets[i].NbEdges > 0 && physdim < 3 )
                const std::vector< int > tag_values( Edges_.size(), i );
                rval = mbImpl->tag_set_data( TagHandles[i], &Edges_[0], Edges_.size(), &tag_values[0] );
                    std::cout << "Problem to set data for 1-D entities\n";
                    return rval;
            if( Sets[i].NbFaces > 0 && physdim > 1 )
                // Set a data index for Faces and TagHandles[i]
                const std::vector< int > tag_values( Faces.size(), i );
                rval = mbImpl->tag_set_data( TagHandles[i], &Faces_[0], Faces_.size(), &tag_values[0] );
                    std::cout << "Problem to set data for 2-D entities\n";
                    return rval;
            if( Sets[i].NbCells > 0 && physdim > 2 )
                // Set a data index for Cells and TagHandles[i]
                const std::vector< int > tag_values( Cells.size(), i );
                rval = mbImpl->tag_set_data( TagHandles[i], &Cells_[0], Cells_.size(), &tag_values[0] );
                    std::cout << "Problem to set data for 3-D entities\n";
                    return rval;
            // IdSet gets the Set Index indicating that it is not empty
            Sets[i].IdSet = i;
        std::cout << "\tSets[" << i << "].IdSet = " << Sets[i].IdSet << "\n\n";
    return MB_SUCCESS;
Definition at line 354 of file WriteCGNS.cpp.
References ErrorCode, moab::Interface::get_coords(), IndexBase, IndexCoord, IndexFile, IndexZone, MB_SUCCESS, and mbImpl.
    ErrorCode rval;
    const int num_entities = (int)Nodes_.size();
    // Moab works with one vector for the threee coordinates
    std::vector< double > Coords( 3 * num_entities );
    std::vector< double >::iterator c = Coords.begin();
    // CGNS uses one vector for each coordinate
    std::vector< double > CoordX;
    std::vector< double > CoordY;
    std::vector< double > CoordZ;
    // Summ the values of all coordinates to be sure if it is not zero
    double SumX = 0;
    double SumY = 0;
    double SumZ = 0;
    // Get the moab coordinates - Coords is the output
    rval = mbImpl->get_coords( &Nodes_[0], num_entities, &Coords[0] );
        std::cout << "Error getting coordinates from nodes.\n";
        return rval;
    // Reserve the size of nodes
    CoordX.reserve( Nodes_.size() );
    CoordY.reserve( Nodes_.size() );
    CoordZ.reserve( Nodes_.size() );
    for( std::vector< moab::EntityHandle >::iterator i = Nodes_.begin(); i != Nodes_.end(); ++i )
        CoordX.push_back( *c );  // Put the X coordinate in CoordX vector
        SumX += abs( *c );       // Sum all X coordinates
        ++c;                     // Move to Y coordinate
        CoordY.push_back( *c );  // Put the Y coordinate in CoordY vector
        SumY += abs( *c );       // Sum all Y coordinates
        ++c;                     // Move to Z coordinate
        CoordZ.push_back( *c );  // Put the Z coordinate in CoordZ vector
        SumZ += abs( *c );       // Sum all Z coordinates
        ++c;                     // Move to X coordinate
    // If X coordinate is not empty then write CoordX (user must use SIDS-standard names here)
    if( SumX != 0 )
        if( cg_coord_write( IndexFile, IndexBase, IndexZone, RealDouble, "CoordinateX", &CoordX[0], &IndexCoord[0] ) )
            std::cout << " Error writing X coordinates.\n";
            cg_error_exit();
    // If Y coordinate is not empty then write CoordY (user must use SIDS-standard names here)
    if( SumY != 0 )
        if( cg_coord_write( IndexFile, IndexBase, IndexZone, RealDouble, "CoordinateY", &CoordY[0], &IndexCoord[1] ) )
            std::cout << " Error writing Y coordinates.\n";
            cg_error_exit();
    // If Z coordinate is not empty then write CoordZ (user must use SIDS-standard names here)
    if( SumZ != 0 )
        if( cg_coord_write( IndexFile, IndexBase, IndexZone, RealDouble, "CoordinateZ", &CoordZ[0], &IndexCoord[2] ) )
            std::cout << " Error writing Z coordinates.\n";
            cg_error_exit();
    // Clear vectors
    Coords.clear();
    CoordX.clear();
    CoordY.clear();
    CoordZ.clear();
    // done
    return MB_SUCCESS;
ErrorCode moab::WriteCGNS::write_file ( const char *  file_name,
const FileOptions opts,
const EntityHandle output_list,
const int  num_sets,
const std::vector< std::string > &  qa_list,
const Tag tag_list = NULL,
int  num_tags = 0,
int  export_dimension = 3
) [virtual]
writes out a file
Implements moab::WriterIface.
Definition at line 41 of file WriteCGNS.cpp.
References BaseName, celldim, Cells, CellSize, cgsize_t, moab::WriteUtilIface::check_doesnt_exist(), Edges, EdgeSize, ErrorCode, Faces, FaceSize, fileName, get_cell_entities(), get_conn_table(), get_edge_entities(), get_face_entities(), get_vertex_entities(), IndexBase, IndexFile, IndexSection, IndexZone, isize, MB_SUCCESS, mbImpl, mWriteIface, Nodes, physdim, set_tag_values(), moab::Interface::tag_get_tags(), VrtSize, write_coord_cgns(), and ZoneName.
    ErrorCode rval;
    if( !overwrite )
        rval = mWriteIface->check_doesnt_exist( file_name );
        if( MB_SUCCESS != rval ) return rval;
    std::cout << "THE CGNS CONVERSION ONLY WORKS FOR ENTITIES CITED BELOW:";
    std::cout << "\n   -MBVERTEX\n   -MBEDGE\n   -MBTRI\n   -MBQUAD";
    std::cout << "\n   -MBTET\n   -MBPYRAMID\n   -MBHEX\n";
    // Get entities to write
    // Get and count vertex entities
    rval = get_vertex_entities( VrtSize, Nodes );
        return rval;
    // Get and count edge entities
    rval = get_edge_entities( EdgeSize, Edges );
        return rval;
    // Get and count face entities
    rval = get_face_entities( FaceSize, Faces );
        return rval;
    // Get and count cell entities
    rval = get_cell_entities( CellSize, Cells );
        return rval;
    std::cout << "\nThe Number of Vertex is " << VrtSize << ".\n";
    std::cout << "The Number of Edges is " << EdgeSize << ".\n";
    std::cout << "The Number of Faces is " << FaceSize << ".\n";
    std::cout << "The Number of Cells is " << CellSize << ".\n\n";
    // save filename to member variable so we don't need to pass as an argument
    // to called functions
    fileName = file_name;
    std::cout << fileName << " file is a " << physdim << "-D mesh.\n";
    // Open file
    IndexFile = 0;
    // open the cgns file
    // filename:      (input) Name of the CGNS file, including path name if necessary. There is no
    // limit on the
    //                length of this character variable.
    // CG_MODE_WRITE: (input) Mode used for opening the file. The modes currently supported are
    // CG_MODE_READ,
    //                CG_MODE_WRITE, and CG_MODE_MODIFY.
    // filePtr:       (output) CGNS file index number.
    if( cg_open( fileName, CG_MODE_WRITE, &IndexFile ) )
        std::cout << "Error opening file\n";
        cg_error_exit();
    // Give a base name
    BaseName = "Cgns Base";
    if( cg_base_write( IndexFile, BaseName, celldim, physdim, &IndexBase ) )
        std::cout << "Error creating CGNS base";
    // Give a zone name
    ZoneName = "Cgns Zone";
    // isize array contains the total vertex size, cell size, and boundary
    // vertex size for the zone
    // Note that for unstructured zones, the index dimension is always 1
    isize[0] = VrtSize;   // isize[0] contains the total vertex size
    isize[1] = CellSize;  // isize[1] contains the total cell size
    isize[2] = 0;         // isize[2] = 0 for unsorted elements
    // Create zone */
    // ZoneType_t: Unstructured
    if( cg_zone_write( IndexFile, IndexBase, ZoneName, isize, Unstructured, &IndexZone ) )
        std::cout << "Error creating CGNS zone\n";
        cg_error_exit();
    // Write the vertex coordinates
    rval = write_coord_cgns( Nodes );
        return rval;
    // Create a vector to hold the Tags
    std::vector< moab::Tag > TagHandles;
    // Get Tags
    rval = mbImpl->tag_get_tags( TagHandles );
        return rval;
    std::cout << "\nThe mesh has " << NbTags << " Tags.\n";
    // Create a vector of size NbTags
    // Sets have informations about the entity set
    std::vector< SetStruct > Sets;
    Sets.reserve( NbTags );
    // Fill Sets with all information needed
    rval = set_tag_values( TagHandles, Edges, Faces, Cells, Sets );
        std::cout << "Problem to set tag values\n";
        return rval;
    // Create a matrix to hold connectivity
    std::vector< std::vector< cgsize_t > > ConnTable;
    ConnTable.resize( NbTags );
    std::vector< int > Begin( NbTags, 0 );
    std::vector< int > End( NbTags, 0 );
    // Take the connectivity of higher dimension entities
    cgsize_t BeginSetsIndex = 1;
    cgsize_t EndSetsIndex;
    switch( physdim )
        case 1:
            rval = get_conn_table( Edges, Begin, End, TagHandles, Sets, ConnTable );
                std::cout << "Problem to fill the connectivity table for 1-D entities\n";
                return rval;
                if( Sets[i].IdSet != -1 )
                    const char* SectionName = Sets[i].TagName.c_str();
                    EndSetsIndex            = BeginSetsIndex + Sets[i].NbEdges - 1;
                    // Write the section in CGNS file
                    if( cg_section_write( IndexFile, IndexBase, IndexBase, SectionName, Sets[i].CGNSType,
                                          BeginSetsIndex, EndSetsIndex, 0, &ConnTable[i][0], &IndexSection ) )
                        std::cout << "Issue on writing connectivity - 3-D\n";
                        cg_error_exit();
                    BeginSetsIndex = EndSetsIndex + 1;
            break;
        case 2:
                return rval;
            rval = get_conn_table( Faces, Begin, End, TagHandles, Sets, ConnTable );
                std::cout << "Problem to fill the connectivity table for 2-D entities\n";
                return rval;
                    EndSetsIndex            = BeginSetsIndex + Sets[i].NbEdges + Sets[i].NbFaces - 1;
                        std::cout << "Issue on writing connectivity -- 2-D\n";
                        cg_error_exit();
            break;
        case 3:
                return rval;
            rval = get_conn_table( Cells, Begin, End, TagHandles, Sets, ConnTable );
                std::cout << "Problem to fill the connectivity table for 3-D entities\n";
                return rval;
                    EndSetsIndex            = BeginSetsIndex + Sets[i].NbFaces + Sets[i].NbCells - 1;
                    std::cout << "BeginSetsIndex = " << BeginSetsIndex << "\tEndSetsIndex = " << EndSetsIndex << "\n";
                        std::cout << "Issue on writing connectivity -- 3-D\n";
                        cg_error_exit();
            break;
        default:
            std::cout << "Issue on Physical dimension\n";
            return MB_FAILURE;
    // Close the CGNS mesh file
    if( cg_close( IndexFile ) )
        std::cout << "Error closing file\n";
        cg_error_exit();
    // done
    return MB_SUCCESS;
Member Data Documentation
const char* moab::WriteCGNS::BaseName [private]
Definition at line 139 of file WriteCGNS.hpp.
std::vector< moab::EntityHandle > moab::WriteCGNS::Cells [private]
Definition at line 161 of file WriteCGNS.hpp.
Referenced by set_tag_values(), and write_file().
Definition at line 167 of file WriteCGNS.hpp.
std::vector< moab::EntityHandle > moab::WriteCGNS::Edges [private]
Definition at line 159 of file WriteCGNS.hpp.
Definition at line 165 of file WriteCGNS.hpp.
std::vector< moab::EntityHandle > moab::WriteCGNS::Faces [private]
Definition at line 160 of file WriteCGNS.hpp.
Definition at line 166 of file WriteCGNS.hpp.
const char* moab::WriteCGNS::fileName [private]
Definition at line 135 of file WriteCGNS.hpp.
Definition at line 140 of file WriteCGNS.hpp.
Referenced by write_coord_cgns(), and write_file().
int moab::WriteCGNS::IndexCoord[3] [private]
Definition at line 150 of file WriteCGNS.hpp.
Referenced by write_coord_cgns(), and WriteCGNS().
Definition at line 136 of file WriteCGNS.hpp.
Definition at line 147 of file WriteCGNS.hpp.
Definition at line 144 of file WriteCGNS.hpp.
Definition at line 155 of file WriteCGNS.hpp.
Referenced by write_file(), and WriteCGNS().
Definition at line 132 of file WriteCGNS.hpp.
Referenced by write_file(), WriteCGNS(), and ~WriteCGNS().
std::vector< moab::EntityHandle > moab::WriteCGNS::Nodes [private]
Definition at line 158 of file WriteCGNS.hpp.
Referenced by get_vertex_entities(), and write_file().
Definition at line 164 of file WriteCGNS.hpp.
const char* moab::WriteCGNS::ZoneName [private]
Definition at line 143 of file WriteCGNS.hpp.
List of all members.
