moab::WriteGmsh Class Reference
Export Gmsh files. More...
#include <WriteGmsh.hpp>
+ Inheritance diagram for moab::WriteGmsh:
+ Collaboration diagram for moab::WriteGmsh:
Public Member Functions
 WriteGmsh (Interface *impl)
 Constructor.
virtual ~WriteGmsh ()
 Destructor.
ErrorCode write_file (const char *file_name, const bool overwrite, const FileOptions &opts, const EntityHandle *output_list, const int num_sets, const std::vector< std::string > &qa_list, const Tag *tag_list=NULL, int num_tags=0, int export_dimension=3)
 writes out a file
Static Public Member Functions
static WriterIfacefactory (Interface *)
 factory method
Private Attributes
InterfacembImpl
 interface instance
WriteUtilIfacemWriteIface
Detailed Description
Export Gmsh files.
Author:
Jason Kraftcheck
Known limitations:
  • Tag data and most sets cannot be saved.
  • For blocks, geometry sets, and parallel partitions, the sets are saved but the IDs may be lost.
  • File format does not support general polygons or polyhedra.
  • File format does not support higher-order volume elements other than TET10 and HEX27.
Definition at line 40 of file WriteGmsh.hpp.
Constructor.
Definition at line 25 of file WriteGmsh.cpp.
References mWriteIface, and moab::Interface::query_interface().
Referenced by factory().
                                      : mbImpl( impl )
    impl->query_interface( mWriteIface );
Destructor.
Definition at line 30 of file WriteGmsh.cpp.
References mbImpl, mWriteIface, and moab::Interface::release_interface().
Member Function Documentation
factory method
Definition at line 20 of file WriteGmsh.cpp.
References WriteGmsh().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
    return new WriteGmsh( iface );
ErrorCode moab::WriteGmsh::write_file ( const char *  file_name,
const FileOptions opts,
const EntityHandle output_list,
const int  num_sets,
const std::vector< std::string > &  qa_list,
const Tag tag_list = NULL,
int  num_tags = 0,
int  export_dimension = 3
) [virtual]
writes out a file
Writes out a file.
Implements moab::WriterIface.
Definition at line 51 of file WriteGmsh.cpp.
References moab::Range::begin(), moab::WriteUtilIface::check_doesnt_exist(), moab::ElemInfo::count, moab::DEFAULT_PRECISION, moab::Range::empty(), moab::Range::end(), moab::CN::EntityTypeName(), ErrorCode, GEOM_DIMENSION_TAG_NAME, geom_tag, moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type_and_tag(), moab::GmshUtil::get_gmsh_type(), moab::FileOptions::get_int_option(), moab::Interface::globalId_tag(), moab::GmshUtil::gmshElemTypes, moab::ElemInfo::id, moab::Interface::id_from_handle(), moab::Range::insert(), moab::intersect(), MATERIAL_SET_TAG_NAME, MB_ENTITY_NOT_FOUND, MB_FILE_DOES_NOT_EXIST, MB_FILE_WRITE_ERROR, MB_SET_ERR, MB_SUCCESS, MB_TYPE_INTEGER, MBENTITYSET, mbImpl, moab::Range::merge(), mWriteIface, moab::GmshElemType::node_order, PARALLEL_PARTITION_TAG_NAME, moab::Range::rbegin(), moab::Range::rend(), moab::Range::size(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::ElemInfo::type, and moab::Interface::type_from_handle().
    ErrorCode rval;
    Tag global_id = 0, block_tag = 0, geom_tag = 0, prtn_tag = 0;
    if( !overwrite )
        rval = mWriteIface->check_doesnt_exist( file_name );
        if( MB_SUCCESS != rval ) return rval;
    // Get tags
    global_id = mbImpl->globalId_tag();
    mbImpl->tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, block_tag );
    if( global_id ) mbImpl->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geom_tag );
    mbImpl->tag_get_handle( PARALLEL_PARTITION_TAG_NAME, 1, MB_TYPE_INTEGER, prtn_tag );
    // Define arrays to hold entity sets of interest
    Range sets[3];
    Tag set_tags[] = { block_tag, geom_tag, prtn_tag };
    Tag set_ids[]  = { block_tag, 0 /*global_id*/, prtn_tag };
    // Get entities to write
    Range elements, nodes;
    if( !output_list )
        rval = mbImpl->get_entities_by_dimension( 0, 0, nodes, false );
        for( int d = 1; d <= 3; ++d )
            Range tmp_range;
            rval = mbImpl->get_entities_by_dimension( 0, d, tmp_range, false );
            elements.merge( tmp_range );
        for( int s = 0; s < 3; ++s )
            if( set_tags[s] )
                rval = mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, set_tags + s, 0, 1, sets[s] );
    else
        for( int i = 0; i < num_sets; ++i )
            EntityHandle set = output_list[i];
            for( int d = 1; d < 3; ++d )
                Range tmp_range, tmp_nodes;
                rval = mbImpl->get_entities_by_dimension( set, d, tmp_range, true );
                if( rval != MB_SUCCESS ) return rval;
                rval = mbImpl->get_adjacencies( tmp_range, set, false, tmp_nodes );
                nodes.merge( tmp_nodes );
                if( set_tags[s] )
                    Range tmp_range;
                    rval = mbImpl->get_entities_by_type_and_tag( set, MBENTITYSET, set_tags + s, 0, 1, tmp_range );
                    sets[s].merge( tmp_range );
                    int junk;
                    rval = mbImpl->tag_get_data( set_tags[s], &set, 1, &junk );
                    if( MB_SUCCESS == rval ) sets[s].insert( set );
    if( elements.empty() )
        MB_SET_ERR( MB_ENTITY_NOT_FOUND, "Nothing to write" );
    // Get global IDs for all elements.
    // First try to get from tag.  If tag is not defined or not set
    // for all elements, use handle value instead.
    std::vector< int > global_id_array( elements.size() );
    std::vector< int >::iterator id_iter;
    if( !global_id || MB_SUCCESS != mbImpl->tag_get_data( global_id, elements, &global_id_array[0] ) )
        id_iter = global_id_array.begin();
        for( Range::iterator i = elements.begin(); i != elements.end(); ++i, ++id_iter )
            *id_iter = mbImpl->id_from_handle( *i );
    // Figure out the maximum ID value so we know where to start allocating
    // new IDs when we encounter ID conflicts.
    int max_id = 0;
    for( id_iter = global_id_array.begin(); id_iter != global_id_array.end(); ++id_iter )
        if( *id_iter > max_id ) max_id = *id_iter;
    // Initialize ElemInfo struct for each element
    std::map< EntityHandle, ElemInfo > elem_sets;  // Per-element info
    std::set< int > elem_global_ids;               // Temporary for finding duplicate IDs
    // Iterate backwards to give highest-dimension entities first dibs for
    // a conflicting ID.
    for( Range::reverse_iterator i = elements.rbegin(); i != elements.rend(); ++i )
        int id = *id_iter;
        ++id_iter;
        if( !elem_global_ids.insert( id ).second ) id = ++max_id;
        ElemInfo& ei = elem_sets[*i];
        ei.count     = 0;
        ei.id        = id;
        EntityType type = mbImpl->type_from_handle( *i );
        int num_vtx;
        const EntityHandle* conn;
        rval = mbImpl->get_connectivity( *i, conn, num_vtx );
        ei.type = GmshUtil::get_gmsh_type( type, num_vtx );
        if( ei.type < 0 )
            MB_SET_ERR( MB_FILE_WRITE_ERROR, "Gmem file format does not support element of type "
                                                 << CN::EntityTypeName( type ) << " with " << num_vtx << " vertices" );
    // Don't need these any more, free memory.
    elem_global_ids.clear();
    global_id_array.clear();
    // For each material set, geometry set, or partition; store
    // the ID of the set on each element.
        if( !set_tags[s] ) continue;
        for( Range::iterator i = sets[s].begin(); i != sets[s].end(); ++i )
            int id;
            if( set_ids[s] )
                rval = mbImpl->tag_get_data( set_ids[s], &*i, 1, &id );
            else
                id = mbImpl->id_from_handle( *i );
            Range elems;
            rval = mbImpl->get_entities_by_handle( *i, elems );
            elems = intersect( elems, elements );
            for( Range::iterator j = elems.begin(); j != elems.end(); ++j )
                elem_sets[*j].set( s, id );
    // Create file
    std::ofstream out( file_name );
    if( !out ) return MB_FILE_DOES_NOT_EXIST;
    // Write header
    out << "$MeshFormat" << std::endl;
    out << "2.0 0 " << sizeof( double ) << std::endl;
    out << "$EndMeshFormat" << std::endl;
    // Set precision for node coordinates
    int precision;
    if( MB_SUCCESS != options.get_int_option( "PRECISION", precision ) ) precision = DEFAULT_PRECISION;
    const int old_precision = out.precision();
    out.precision( precision );
    // Write nodes
    out << "$Nodes" << std::endl;
    out << nodes.size() << std::endl;
    std::vector< double > coords( 3 * nodes.size() );
    rval = mbImpl->get_coords( nodes, &coords[0] );
    std::vector< double >::iterator c = coords.begin();
    for( Range::iterator i = nodes.begin(); i != nodes.end(); ++i )
        out << mbImpl->id_from_handle( *i );
        out << " " << *c;
        ++c;
        out << " " << *c;
        ++c;
        out << " " << *c;
        ++c;
        out << std::endl;
    out << "$EndNodes" << std::endl;
    coords.clear();
    // Restore stream state
    out.precision( old_precision );
    // Write elements
    out << "$Elements" << std::endl;
    out << elem_sets.size() << std::endl;
    for( std::map< EntityHandle, ElemInfo >::iterator i = elem_sets.begin(); i != elem_sets.end(); ++i )
        int num_vtx;
        rval = mbImpl->get_connectivity( i->first, conn, num_vtx );
        out << i->second.id << ' ' << i->second.type << ' ' << i->second.count;
        for( int j = 0; j < i->second.count; ++j )
            out << ' ' << i->second.sets[j];
        const int* order = GmshUtil::gmshElemTypes[i->second.type].node_order;
        // Need to re-order vertices
        if( order )
            for( int j = 0; j < num_vtx; ++j )
                out << ' ' << mbImpl->id_from_handle( conn[order[j]] );
        else
                out << ' ' << mbImpl->id_from_handle( conn[j] );
        out << std::endl;
    out << "$EndElements" << std::endl;
    // Done
    return MB_SUCCESS;
Member Data Documentation
interface instance
Definition at line 66 of file WriteGmsh.hpp.
Referenced by write_file(), and ~WriteGmsh().
Definition at line 67 of file WriteGmsh.hpp.
Referenced by write_file(), WriteGmsh(), and ~WriteGmsh().
List of all members.
