moab::WriteHDF5 Class Reference
Write mesh database to MOAB's native HDF5-based file format. More...
#include <WriteHDF5.hpp>
+ Inheritance diagram for moab::WriteHDF5:
+ Collaboration diagram for moab::WriteHDF5:
Classes
struct  ExportSet
 Range of entities, grouped by type, to export. More...
struct  ExportType
struct  HDF5ErrorHandler
 Store old HDF5 error handling function. More...
struct  SpecialSetData
struct  SpecSetLess
struct  TagDesc
 Tag to write to file. More...
Public Types
typedef EntityHandle wid_t
Public Member Functions
 WriteHDF5 (Interface *iface)
virtual ~WriteHDF5 ()
ErrorCode write_file (const char *filename, const bool overwrite, const FileOptions &opts, const EntityHandle *export_sets, const int export_set_count, const std::vector< std::string > &qa_records, const Tag *tag_list=NULL, int num_tags=0, int user_dimension=3)
mhdf_FileHandle file_ptr ()
WriteUtilIfacewrite_util ()
ErrorCode create_elem_table (const ExportSet &block, long num_ents, long &first_id_out)
ErrorCode create_set_meta (long num_sets, long &first_id_out)
Static Public Member Functions
static WriterIfacefactory (Interface *)
Static Public Attributes
static const hid_t id_type = get_id_type()
Protected Types
enum  TimingValues {
  TOTAL_TIME = 0, GATHER_TIME, CREATE_TIME, CREATE_NODE_TIME,
  NEGOTIATE_TYPES_TIME, CREATE_ELEM_TIME, FILEID_EXCHANGE_TIME, CREATE_ADJ_TIME,
  CREATE_SET_TIME, SHARED_SET_IDS, SHARED_SET_CONTENTS, SET_OFFSET_TIME,
  CREATE_TAG_TIME, COORD_TIME, CONN_TIME, SET_TIME,
  SET_META, SET_CONTENT, SET_PARENT, SET_CHILD,
  ADJ_TIME, TAG_TIME, DENSE_TAG_TIME, SPARSE_TAG_TIME,
  VARLEN_TAG_TIME, NUM_TIMES
Protected Member Functions
virtual ErrorCode parallel_create_file (const char *filename, bool overwrite, const std::vector< std::string > &qa_records, const FileOptions &opts, const Tag *tag_list, int num_tags, int dimension=3, double *times=0)
virtual ErrorCode write_finished ()
virtual void debug_barrier_line (int lineno)
ErrorCode gather_tags (const Tag *user_tag_list, int user_tag_list_length)
 Gather tags.
bool check_dense_format_tag (const ExportSet &ents, const Range &all_tagged, bool prefer_dense)
ErrorCode count_adjacencies (const Range &elements, wid_t &result)
ErrorCode count_set_size (const Range &sets, long &contents_length_out, long &children_length_out, long &parents_length_out)
ErrorCode get_set_info (EntityHandle set, long &num_entities, long &num_children, long &num_parents, unsigned long &flags)
 Get information about a meshset.
ErrorCode create_set_tables (long contents_length, long children_length, long parents_length)
ErrorCode write_qa (const std::vector< std::string > &list)
 Write exodus-type QA info.
ErrorCode get_num_sparse_tagged_entities (const TagDesc &tag, size_t &count)
 Get tagged entities for which to write tag values.
ErrorCode get_sparse_tagged_entities (const TagDesc &tag, Range &range)
void get_write_entities (Range &range)
 Get entities that will be written to file.
const ExportSetfind (const ExportType &type) const
const SpecialSetDatafind_set_data (EntityHandle h) const
void print_id_map () const
void print_id_map (std::ostream &str, const char *prefix="") const
ErrorCode create_tag (const TagDesc &tag_data, unsigned long num_entities, unsigned long var_len_total)
ErrorCode assign_ids (const Range &entities, wid_t first_id)
 add entities to idMap
ErrorCode range_to_blocked_list (const Range &input_range, std::vector< wid_t > &output_id_list, bool &ranged_list)
ErrorCode range_to_blocked_list (const EntityHandle *input_ranges, size_t num_input_ranges, std::vector< wid_t > &output_id_list, bool &ranged_list)
ErrorCode range_to_id_list (const Range &input_range, wid_t *array)
ErrorCode vector_to_id_list (const std::vector< EntityHandle > &input, std::vector< wid_t > &output, bool remove_non_written=false)
 Get IDs for entities.
ErrorCode vector_to_id_list (const EntityHandle *input, wid_t *output, size_t num_entities)
ErrorCode vector_to_id_list (const EntityHandle *input, size_t input_len, wid_t *output, size_t &output_len, bool remove_non_written)
bool convert_handle_tag (EntityHandle *data, size_t count) const
bool convert_handle_tag (const EntityHandle *source, EntityHandle *dest, size_t count) const
ErrorCode get_adjacencies (EntityHandle entity, std::vector< wid_t > &adj)
ErrorCode get_tag_data_length (const TagDesc &tag_info, const Range &range, unsigned long &result)
virtual void print_times (const double times[NUM_TIMES]) const
Protected Attributes
HDF5ErrorHandler errorHandler
size_t bufferSize
 The size of the data buffer (dataBuffer).
char * dataBuffer
 A memory buffer to use for all I/O operations.
InterfaceiFace
 Interface pointer passed to constructor.
WriteUtilIfacewriteUtil
 Cached pointer to writeUtil interface.
mhdf_FileHandle filePtr
 The file handle from the mhdf library.
RangeMap< EntityHandle, wid_tidMap
 Map from entity handles to file IDs.
std::list< ExportSetexportList
 The list elements to export.
ExportSet nodeSet
 The list of nodes to export.
ExportSet setSet
 The list of sets to export.
unsigned long setContentsOffset
 Offset into set contents table (zero except for parallel)
unsigned long setChildrenOffset
 Offset into set children table (zero except for parallel)
unsigned long setParentsOffset
long maxNumSetContents
long maxNumSetChildren
long maxNumSetParents
bool writeSets
bool writeSetContents
bool writeSetChildren
bool writeSetParents
std::vector< SpecialSetDataspecialSets
 Array of special/shared sets, in order of handle value.
std::list< TagDesctagList
 The list of tags to export.
bool parallelWrite
 True if doing parallel write.
bool collectiveIO
 True if using collective IO calls for parallel write.
bool writeTagDense
 True if writing dense-formatted tag data.
hid_t writeProp
DebugOutput dbgOut
 Utility to log debug output.
bool debugTrack
 Look for overlapping and/or missing writes.
Static Protected Attributes
static MPEState topState
static MPEState subState
Private Member Functions
ErrorCode write_file_impl (const char *filename, const bool overwrite, const FileOptions &opts, const EntityHandle *export_sets, const int export_set_count, const std::vector< std::string > &qa_records, const Tag *tag_list, int num_tags, int user_dimension=3)
ErrorCode init ()
ErrorCode serial_create_file (const char *filename, bool overwrite, const std::vector< std::string > &qa_records, const Tag *tag_list, int num_tags, int dimension=3)
ErrorCode gather_mesh_info (const std::vector< EntityHandle > &export_sets)
ErrorCode gather_all_mesh ()
 Same as gather_mesh_info, except for entire mesh.
ErrorCode initialize_mesh (const Range entities_by_dim[5])
 Initialize internal data structures from gathered mesh.
ErrorCode write_nodes ()
ErrorCode write_elems (ExportSet &elemset)
ErrorCode write_sets (double *times)
ErrorCode write_set_data (const WriteUtilIface::EntityListType which_data, const hid_t handle, IODebugTrack &track, Range *ranged=0, Range *null_stripped=0, std::vector< long > *set_sizes=0)
ErrorCode write_adjacencies (const ExportSet &export_set)
ErrorCode write_tag (const TagDesc &tag_data, double *times)
 Write tag for all entities.
ErrorCode get_connectivity (Range::const_iterator begin, Range::const_iterator end, int nodes_per_element, wid_t *id_data_out)
 Get element connectivity.
ErrorCode get_tag_size (Tag tag, DataType &moab_type, int &num_bytes, int &elem_size, int &file_size, mhdf_TagDataType &file_type, hid_t &hdf_type)
ErrorCode write_sparse_ids (const TagDesc &tag_data, const Range &range, hid_t table_handle, size_t table_size, const char *name=0)
 Write ID table for sparse tag.
ErrorCode write_sparse_tag (const TagDesc &tag_data, const std::string &tag_name, DataType tag_data_type, hid_t hdf5_data_type, int hdf5_type_size)
 Write fixed-length tag data in sparse format.
ErrorCode write_var_len_indices (const TagDesc &tag_data, const Range &range, hid_t idx_table, size_t table_size, int type_size, const char *name=0)
 Write end index data_set for a variable-length tag.
ErrorCode write_var_len_data (const TagDesc &tag_data, const Range &range, hid_t table, size_t table_size, bool handle_tag, hid_t hdf_type, int type_size, const char *name=0)
 Write tag value data_set for a variable-length tag.
ErrorCode write_var_len_tag (const TagDesc &tag_info, const std::string &tag_name, DataType tag_data_type, hid_t hdf5_type, int hdf5_type_size)
 Write varialbe-length tag data.
ErrorCode write_dense_tag (const TagDesc &tag_data, const ExportSet &elem_data, const std::string &tag_name, DataType tag_data_type, hid_t hdf5_data_type, int hdf5_type_size)
 Write dense-formatted tag data.
ErrorCode write_tag_values (Tag tag_id, hid_t data_table, unsigned long data_offset, const Range &range, DataType tag_data_type, hid_t hdf5_data_type, int hdf5_type_size, unsigned long max_num_ents, IODebugTrack &debug_track)
 Write data for fixed-size tag.
Detailed Description
Author:
Jason Kraftcheck
Date:
01 April 2004
Definition at line 47 of file WriteHDF5.hpp.
Member Typedef Documentation
The type to use for entity IDs w/in the file.
NOTE: If this is changed, the value of id_type MUST be changed accordingly.
Definition at line 77 of file WriteHDF5.hpp.
Member Enumeration Documentation
Enumerator:
TOTAL_TIME
GATHER_TIME
CREATE_TIME
CREATE_NODE_TIME
CREATE_ELEM_TIME
CREATE_ADJ_TIME
CREATE_SET_TIME
SHARED_SET_IDS
SHARED_SET_CONTENTS
SET_OFFSET_TIME
CREATE_TAG_TIME
COORD_TIME
CONN_TIME
SET_TIME
SET_META
SET_CONTENT
SET_PARENT
SET_CHILD
ADJ_TIME
TAG_TIME
DENSE_TAG_TIME
SPARSE_TAG_TIME
VARLEN_TAG_TIME
NUM_TIMES
Definition at line 690 of file WriteHDF5.hpp.
Definition at line 396 of file WriteHDF5.cpp.
Referenced by factory().
    : bufferSize( WRITE_HDF5_BUFFER_SIZE ), dataBuffer( 0 ), iFace( iface ), writeUtil( 0 ), filePtr( 0 ),
      setContentsOffset( 0 ), setChildrenOffset( 0 ), setParentsOffset( 0 ), maxNumSetContents( 0 ),
      maxNumSetChildren( 0 ), maxNumSetParents( 0 ), writeSets( false ), writeSetContents( false ),
      writeSetChildren( false ), writeSetParents( false ), parallelWrite( false ), collectiveIO( false ),
      writeTagDense( false ), writeProp( H5P_DEFAULT ), dbgOut( "H5M", stderr ), debugTrack( false )
Definition at line 484 of file WriteHDF5.cpp.
References iFace, moab::Interface::release_interface(), and writeUtil.
    if( !writeUtil )  // init() failed.
        return;
    iFace->release_interface( writeUtil );
Member Function Documentation
ErrorCode moab::WriteHDF5::assign_ids ( const Range entities,
wid_t  first_id
) [protected]
Definition at line 351 of file WriteHDF5.cpp.
References moab::Range::const_pair_begin(), moab::Range::const_pair_end(), dbgOut, moab::CN::EntityTypeName(), moab::error(), moab::Interface::get_connectivity(), moab::ID_FROM_HANDLE(), idMap, iFace, moab::RangeMap< KeyType, ValType, NullVal >::insert(), MB_SUCCESS, MBPOLYGON, MBPOLYHEDRON, moab::DebugOutput::printf(), and moab::TYPE_FROM_HANDLE().
Referenced by moab::WriteHDF5Parallel::create_element_tables(), moab::WriteHDF5Parallel::create_meshset_tables(), moab::WriteHDF5Parallel::create_node_table(), and serial_create_file().
    Range::const_pair_iterator pi;
    for( pi = entities.const_pair_begin(); pi != entities.const_pair_end(); ++pi )
        const EntityHandle n = pi->second - pi->first + 1;
        dbgOut.printf( 3, "Assigning %s %lu to %lu to file IDs [%lu,%lu]\n",
                       CN::EntityTypeName( TYPE_FROM_HANDLE( pi->first ) ),
                       (unsigned long)( ID_FROM_HANDLE( pi->first ) ),
                       (unsigned long)( ID_FROM_HANDLE( pi->first ) + n - 1 ), (unsigned long)id,
                       (unsigned long)( id + n - 1 ) );
        if( TYPE_FROM_HANDLE( pi->first ) == MBPOLYGON || TYPE_FROM_HANDLE( pi->first ) == MBPOLYHEDRON )
            int num_vertices         = 0;
            const EntityHandle* conn = 0;
            iFace->get_connectivity( pi->first, conn, num_vertices );
            dbgOut.printf( 3, "  poly with %d verts/faces \n", num_vertices );
        if( !idMap.insert( pi->first, id, n ).second ) return error( MB_FAILURE );
        id += n;
    return MB_SUCCESS;
bool moab::WriteHDF5::check_dense_format_tag ( const ExportSet ents,
const Range all_tagged,
bool  prefer_dense
) [protected]
Check if tag values for a given ExportSet should be written in dense format
Parameters:
entsExportSet to consider
all_taggedRange containing all the entities in ents.range for which an explicit tag value is stored. Range may also contain entities not in ents.range, but may not contain entities in ents.range for which no tag value is stored.
prefer_denseIf true, will return true if at least 2/3 of the entities are tagged. This should not be passed as true if the tag does not have a default value, as tag values must be stored for all entities in the ExportSet for dense-formatted data.
Definition at line 2753 of file WriteHDF5.cpp.
References moab::Range::contains(), moab::Range::empty(), moab::intersect(), moab::WriteHDF5::ExportSet::range, setSet, and moab::Range::size().
Referenced by moab::WriteHDF5Parallel::create_tag_tables(), and serial_create_file().
    // If there are no tagged entities, then don't write anything
    if( ents.range.empty() ) return false;
    // If all of the entities are tagged, then write in dense format
    if( all_tagged.contains( ents.range ) ) return true;
    // Unless asked for more lenient choice of dense format, return false
    if( !prefer_dense ) return false;
    // If we're being lenient about choosing dense format, then
    // return true if at least 2/3 of the entities are tagged.
    Range xsect = intersect( setSet.range, all_tagged );
    if( 3 * xsect.size() >= 2 * setSet.range.size() ) return true;
    return false;
bool moab::WriteHDF5::convert_handle_tag ( EntityHandle data,
size_t  count
) const [protected]
When writing tags containing EntityHandles to file, need to convert tag data from EntityHandles to file IDs. This function does that.
If the handle is not valid or does not correspond to an entity that will be written to the file, the file ID is set to zero.
Parameters:
dataThe data buffer. As input, an array of EntityHandles. As output an array of file IDS, where the size of each integral file ID is the same as the size of EntityHandle.
countThe number of handles in the buffer.
Returns:
true if at least one of the handles is valid and will be written to the file or at least one of the handles is NULL (zero). false otherwise
Definition at line 345 of file WriteHDF5.cpp.
Referenced by create_tag(), write_tag_values(), and write_var_len_data().
    assert( sizeof( EntityHandle ) == sizeof( wid_t ) );
    return convert_handle_tag( data, data, count );
bool moab::WriteHDF5::convert_handle_tag ( const EntityHandle source,
EntityHandle dest,
size_t  count
) const [protected]
Definition at line 328 of file WriteHDF5.cpp.
References moab::RangeMap< KeyType, ValType, NullVal >::find(), and idMap.
    bool some_valid = false;
    for( size_t i = 0; i < count; ++i )
        if( !source[i] )
            dest[i] = 0;
        else
            dest[i] = idMap.find( source[i] );
            if( dest[i] ) some_valid = true;
    return some_valid;
ErrorCode moab::WriteHDF5::count_adjacencies ( const Range elements,
wid_t result
) [protected]
Helper function for create-file
Calculate the sum of the number of non-set adjacencies of all entities in the passed range.
Definition at line 2772 of file WriteHDF5.cpp.
References CHK_MB_ERR_0, ErrorCode, get_adjacencies(), and MB_SUCCESS.
Referenced by moab::WriteHDF5Parallel::create_adjacency_tables(), and serial_create_file().
    ErrorCode rval;
    std::vector< wid_t > adj_list;
    Range::const_iterator iter      = set.begin();
    const Range::const_iterator end = set.end();
    result                          = 0;
    for( ; iter != end; ++iter )
        adj_list.clear();
        rval = get_adjacencies( *iter, adj_list );
        CHK_MB_ERR_0( rval );
        if( adj_list.size() > 0 ) result += 2 + adj_list.size();
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5::count_set_size ( const Range sets,
long &  contents_length_out,
long &  children_length_out,
long &  parents_length_out
) [protected]
Calculate total length of set contents and child tables.
Definition at line 2809 of file WriteHDF5.cpp.
References moab::Range::begin(), CHK_MB_ERR_0, moab::Range::clear(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_handle(), get_set_info(), iFace, MB_SUCCESS, range_to_blocked_list(), and specialSets.
Referenced by moab::WriteHDF5Parallel::create_meshset_tables(), and serial_create_file().
    ErrorCode rval;
    Range set_contents;
    long contents_length_set, children_length_set, parents_length_set;
    unsigned long flags;
    std::vector< wid_t > set_contents_ids;
    std::vector< SpecialSetData >::const_iterator si = specialSets.begin();
    contents_length_out = 0;
    children_length_out = 0;
    parents_length_out  = 0;
    for( Range::const_iterator iter = sets.begin(); iter != sets.end(); ++iter )
        while( si != specialSets.end() && si->setHandle < *iter )
            ++si;
        if( si != specialSets.end() && si->setHandle == *iter )
            contents_length_out += si->contentIds.size();
            children_length_out += si->childIds.size();
            parents_length_out += si->parentIds.size();
            ++si;
            continue;
        rval = get_set_info( *iter, contents_length_set, children_length_set, parents_length_set, flags );
        // Check if can and should compress as ranges
        if( !( flags & MESHSET_ORDERED ) && contents_length_set )
            set_contents.clear();
            rval = iFace->get_entities_by_handle( *iter, set_contents, false );
            bool blocked_list;
            rval = range_to_blocked_list( set_contents, set_contents_ids, blocked_list );
            if( blocked_list )
                assert( set_contents_ids.size() % 2 == 0 );
                contents_length_set = set_contents_ids.size();
        contents_length_out += contents_length_set;
        children_length_out += children_length_set;
        parents_length_out += parents_length_set;
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5::create_elem_table ( const ExportSet block,
long  num_ents,
long &  first_id_out
Create zero-ed tables where element connectivity and adjacency data will be stored.
Definition at line 2791 of file WriteHDF5.cpp.
References CHECK_OPEN_HANDLES, CHK_MHDF_ERR_0, filePtr, MB_SUCCESS, mhdf_addElement(), mhdf_closeData(), mhdf_createConnectivity(), moab::WriteHDF5::ExportSet::name(), moab::WriteHDF5::ExportType::num_nodes, and moab::WriteHDF5::ExportType::type.
Referenced by moab::WriteHDF5Parallel::create_element_tables(), and serial_create_file().
    mhdf_Status status;
    hid_t handle;
    CHECK_OPEN_HANDLES;
    mhdf_addElement( filePtr, block.name(), block.type, &status );
    CHK_MHDF_ERR_0( status );
    handle = mhdf_createConnectivity( filePtr, block.name(), block.num_nodes, num_entities, &first_id_out, &status );
    mhdf_closeData( filePtr, handle, &status );
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5::create_set_meta ( long  num_sets,
long &  first_id_out
Create zero-ed table where set descriptions will be written
Definition at line 2868 of file WriteHDF5.cpp.
References CHECK_OPEN_HANDLES, CHK_MHDF_ERR_0, filePtr, MB_SUCCESS, mhdf_closeData(), and mhdf_createSetMeta().
    hid_t handle;
    mhdf_Status status;
    CHECK_OPEN_HANDLES;
    handle = mhdf_createSetMeta( filePtr, num_sets, &first_id_out, &status );
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5::create_set_tables ( long  contents_length,
long  parents_length
) [protected]
Create zero-ed tables where set data will be written.
Definition at line 2891 of file WriteHDF5.cpp.
References CHECK_OPEN_HANDLES, CHK_MHDF_ERR_0, filePtr, MB_SUCCESS, mhdf_closeData(), mhdf_createSetChildren(), mhdf_createSetData(), and mhdf_createSetParents().
    hid_t handle;
    mhdf_Status status;
    CHECK_OPEN_HANDLES;
    if( num_set_contents > 0 )
        handle = mhdf_createSetData( filePtr, num_set_contents, &status );
    if( num_set_children > 0 )
        handle = mhdf_createSetChildren( filePtr, num_set_children, &status );
    if( num_set_parents > 0 )
        handle = mhdf_createSetParents( filePtr, num_set_parents, &status );
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5::create_tag ( const TagDesc tag_data,
) [protected]
Write tag meta-info and create zero-ed table where tag values will be written.
Parameters:
num_entitiesNumber of entities for which to write tag data.
var_len_totalFor variable-length tags, the total number of values in the data table.
Definition at line 3096 of file WriteHDF5.cpp.
References bufferSize, CHECK_OPEN_HANDLES, CHK_MB_ERR_0, CHK_MHDF_ERR_0, convert_handle_tag(), dataBuffer, moab::WriteHDF5::TagDesc::dense_list, moab::error(), ErrorCode, filePtr, find(), get_tag_size(), id_type, iFace, MB_ENTITY_NOT_FOUND, MB_SUCCESS, MB_TAG_BIT, MB_TAG_DENSE, MB_TAG_MESH, MB_TAG_NOT_FOUND, MB_TAG_SPARSE, MB_TYPE_HANDLE, MB_VARIABLE_LENGTH, mhdf_BIT_TYPE, mhdf_closeData(), mhdf_createDenseTagData(), mhdf_createSparseTagData(), mhdf_createTag(), mhdf_createVarLenTag(), mhdf_createVarLenTagData(), mhdf_DENSE_TYPE, mhdf_MESH_TYPE, mhdf_SPARSE_TYPE, moab::WriteHDF5::ExportSet::name(), moab::Interface::tag_get_by_ptr(), moab::Interface::tag_get_data(), moab::Interface::tag_get_default_value(), moab::Interface::tag_get_name(), moab::Interface::tag_get_type(), moab::WriteHDF5::TagDesc::tag_id, TagType, and moab::WriteHDF5::ExportSet::total_num_ents.
    TagType mb_storage;
    DataType mb_type;
    mhdf_TagDataType mhdf_type;
    int tag_bytes, type_size, num_vals, storage;
    hid_t hdf_type = (hid_t)0;
    hid_t handles[3];
    std::string tag_name;
    ErrorCode rval;
    mhdf_Status status;
    CHECK_OPEN_HANDLES;
    // Get tag properties
    rval = iFace->tag_get_type( tag_data.tag_id, mb_storage );
    switch( mb_storage )
        case MB_TAG_DENSE:
            storage = mhdf_DENSE_TYPE;
            break;
        case MB_TAG_SPARSE:
            storage = mhdf_SPARSE_TYPE;
            break;
        case MB_TAG_BIT:
            storage = mhdf_BIT_TYPE;
            break;
        case MB_TAG_MESH:
            storage = mhdf_MESH_TYPE;
            break;
        default:
    rval = iFace->tag_get_name( tag_data.tag_id, tag_name );
    rval = get_tag_size( tag_data.tag_id, mb_type, tag_bytes, type_size, num_vals, mhdf_type, hdf_type );
    // Get default value
    const void *def_value, *mesh_value;
    int def_val_len, mesh_val_len;
    rval = iFace->tag_get_default_value( tag_data.tag_id, def_value, def_val_len );
    if( MB_ENTITY_NOT_FOUND == rval )
        def_value   = 0;
        def_val_len = 0;
    else if( MB_SUCCESS != rval )
        H5Tclose( hdf_type );
        return error( rval );
    // Get mesh value
    unsigned char byte;
    const EntityHandle root = 0;
    if( mb_storage == MB_TAG_BIT )
        rval         = iFace->tag_get_data( tag_data.tag_id, &root, 1, &byte );
        mesh_value   = &byte;
        mesh_val_len = 1;
    else
        rval = iFace->tag_get_by_ptr( tag_data.tag_id, &root, 1, &mesh_value, &mesh_val_len );
    if( MB_TAG_NOT_FOUND == rval )
        mesh_value   = 0;
        mesh_val_len = 0;
    // For handle-type tags, need to convert from handles to file ids
    if( MB_TYPE_HANDLE == mb_type )
        // Make sure there's room in the buffer for both
        assert( ( def_val_len + mesh_val_len ) * sizeof( long ) < (size_t)bufferSize );
        // Convert default value
        if( def_value )
            memcpy( dataBuffer, def_value, def_val_len * sizeof( EntityHandle ) );
            convert_handle_tag( reinterpret_cast< EntityHandle* >( dataBuffer ), def_val_len );
            def_value = dataBuffer;
        // Convert mesh value
        if( mesh_value )
            EntityHandle* ptr = reinterpret_cast< EntityHandle* >( dataBuffer ) + def_val_len;
            memcpy( ptr, mesh_value, mesh_val_len * sizeof( EntityHandle ) );
            if( convert_handle_tag( ptr, mesh_val_len ) )
                mesh_value = ptr;
            else
                mesh_value = 0;
    if( MB_VARIABLE_LENGTH != tag_bytes )
        // Write the tag description to the file
        mhdf_createTag( filePtr, tag_name.c_str(), mhdf_type, num_vals, storage, def_value, mesh_value, hdf_type,
                        mb_type == MB_TYPE_HANDLE ? id_type : 0, &status );
        // Create empty table for tag data
        if( num_sparse_entities )
            mhdf_createSparseTagData( filePtr, tag_name.c_str(), num_sparse_entities, handles, &status );
            mhdf_closeData( filePtr, handles[0], &status );
            mhdf_closeData( filePtr, handles[1], &status );
        for( size_t i = 0; i < tag_data.dense_list.size(); ++i )
            const ExportSet* ex = find( tag_data.dense_list[i] );
            assert( 0 != ex );
            handles[0] = mhdf_createDenseTagData( filePtr, tag_name.c_str(), ex->name(), ex->total_num_ents, &status );
    else
        mhdf_createVarLenTag( filePtr, tag_name.c_str(), mhdf_type, storage, def_value, def_val_len, mesh_value,
                              mesh_val_len, hdf_type, mb_type == MB_TYPE_HANDLE ? id_type : 0, &status );
            mhdf_createVarLenTagData( filePtr, tag_name.c_str(), num_sparse_entities, data_table_size, handles,
                                      &status );
            mhdf_closeData( filePtr, handles[2], &status );
    return MB_SUCCESS;
void moab::WriteHDF5::debug_barrier_line ( int  lineno) [protected, virtual]
Reimplemented in moab::WriteHDF5Parallel.
Definition at line 293 of file WriteHDF5.cpp.
Definition at line 391 of file WriteHDF5.cpp.
References WriteHDF5().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
    return new WriteHDF5( iface );
const ExportSet* moab::WriteHDF5::find ( const ExportType type) const [inline, protected]
Definition at line 323 of file WriteHDF5.hpp.
References exportList, MBENTITYSET, MBVERTEX, nodeSet, setSet, and moab::WriteHDF5::ExportType::type.
Referenced by moab::WriteHDF5Parallel::communicate_shared_set_ids(), create_tag(), gather_mesh_info(), moab::WriteHDF5::TagDesc::have_dense(), and write_tag().
        if( type.type == MBVERTEX )
            return &nodeSet;
        else if( type.type == MBENTITYSET )
            return &setSet;
        else
            std::list< ExportSet >::const_iterator it;
            it = std::find( exportList.begin(), exportList.end(), type );
            return it == exportList.end() ? 0 : &*it;
const SpecialSetData* moab::WriteHDF5::find_set_data ( EntityHandle  h) const [inline, protected]
Definition at line 374 of file WriteHDF5.hpp.
Referenced by moab::WriteHDF5Parallel::unpack_set().
        return const_cast< WriteHDF5* >( this )->find_set_data( h );
Definition at line 2882 of file WriteHDF5.cpp.
References moab::WriteHDF5::SpecialSetData::setHandle, and specialSets.
    SpecialSetData tmp;
    tmp.setHandle = h;
    std::vector< SpecialSetData >::iterator i;
    i = std::lower_bound( specialSets.begin(), specialSets.end(), tmp, SpecSetLess() );
    return ( i == specialSets.end() || i->setHandle != h ) ? 0 : &*i;
Definition at line 881 of file WriteHDF5.cpp.
References moab::error(), ErrorCode, moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_type(), iFace, initialize_mesh(), MB_SUCCESS, MBENTITYSET, and MBVERTEX.
Referenced by write_file_impl().
    ErrorCode rval;
    Range ranges[5];
    rval = iFace->get_entities_by_type( 0, MBVERTEX, ranges[0] );
    if( MB_SUCCESS != rval ) return error( rval );
    rval = iFace->get_entities_by_dimension( 0, 1, ranges[1] );
    rval = iFace->get_entities_by_dimension( 0, 2, ranges[2] );
    rval = iFace->get_entities_by_dimension( 0, 3, ranges[3] );
    rval = iFace->get_entities_by_type( 0, MBENTITYSET, ranges[4] );
    return initialize_mesh( ranges );
ErrorCode moab::WriteHDF5::gather_mesh_info ( const std::vector< EntityHandle > &  export_sets) [private]
Get all mesh to export from given list of sets.
Populate exportSets, nodeSet and setSet with lists of entities to write.
Parameters:
export_setsThe list of meshsets to export
Definition at line 809 of file WriteHDF5.cpp.
References moab::Range::begin(), CHK_MB_ERR_0, moab::Range::clear(), dim, moab::Range::end(), ErrorCode, find(), moab::WriteUtilIface::gather_nodes_from_elements(), moab::Interface::get_adjacencies(), moab::Interface::get_child_meshsets(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_type(), iFace, initialize_mesh(), moab::Range::insert(), MBENTITYSET, moab::Range::merge(), and writeUtil.
    ErrorCode rval;
    int dim;
    Range range;      // Temporary storage
    Range ranges[5];  // Lists of entities to export, grouped by dimension
    // Gather list of all related sets
    std::vector< EntityHandle > stack( export_sets );
    std::copy( export_sets.begin(), export_sets.end(), stack.begin() );
    std::vector< EntityHandle > set_children;
    while( !stack.empty() )
        EntityHandle meshset = stack.back();
        stack.pop_back();
        ranges[4].insert( meshset );
        // Get contained sets
        range.clear();
        rval = iFace->get_entities_by_type( meshset, MBENTITYSET, range );
        for( Range::iterator ritor = range.begin(); ritor != range.end(); ++ritor )
            if( ranges[4].find( *ritor ) == ranges[4].end() ) stack.push_back( *ritor );
        // Get child sets
        set_children.clear();
        rval = iFace->get_child_meshsets( meshset, set_children, 1 );
        for( std::vector< EntityHandle >::iterator vitor = set_children.begin(); vitor != set_children.end(); ++vitor )
            if( ranges[4].find( *vitor ) == ranges[4].end() ) stack.push_back( *vitor );
    // Gather list of all mesh entities from list of sets,
    // grouped by dimension.
    for( Range::iterator setitor = ranges[4].begin(); setitor != ranges[4].end(); ++setitor )
        for( dim = 0; dim < 4; ++dim )
            range.clear();
            rval = iFace->get_entities_by_dimension( *setitor, dim, range, false );
            ranges[dim].merge( range );
    // For each list of elements, append adjacent children and
    // nodes to lists.
    for( dim = 3; dim > 0; --dim )
        for( int cdim = 1; cdim < dim; ++cdim )
            range.clear();
            rval = iFace->get_adjacencies( ranges[dim], cdim, false, range );
            ranges[cdim].merge( range );
        range.clear();
        rval = writeUtil->gather_nodes_from_elements( ranges[dim], 0, range );
        ranges[0].merge( range );
ErrorCode moab::WriteHDF5::gather_tags ( const Tag user_tag_list,
) [protected]
Gather tags.
Definition at line 2504 of file WriteHDF5.cpp.
References CHK_MB_ERR_0, ErrorCode, moab::WriteUtilIface::get_tag_list(), moab::WriteHDF5::TagDesc::max_num_ents, moab::WriteHDF5::TagDesc::max_num_vals, MB_SUCCESS, moab::WriteHDF5::TagDesc::sparse_offset, moab::WriteHDF5::TagDesc::tag_id, tagList, moab::WriteHDF5::TagDesc::var_data_offset, moab::WriteHDF5::TagDesc::write_sparse, and writeUtil.
Referenced by moab::WriteHDF5Parallel::parallel_create_file(), and serial_create_file().
    ErrorCode result;
    std::vector< Tag > tag_list;
    std::vector< Tag >::iterator t_itor;
    Range range;
    // Get list of Tags to write
    result = writeUtil->get_tag_list( tag_list, user_tag_list, num_tags );
    CHK_MB_ERR_0( result );
    // Get list of tags
    for( t_itor = tag_list.begin(); t_itor != tag_list.end(); ++t_itor )
        // Add tag to export list
        TagDesc tag_data;
        tag_data.write_sparse    = false;
        tag_data.tag_id          = *t_itor;
        tag_data.sparse_offset   = 0;
        tag_data.var_data_offset = 0;
        tag_data.max_num_ents    = 0;
        tag_data.max_num_vals    = 0;
        tagList.push_back( tag_data );
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5::get_adjacencies ( EntityHandle  entity,
std::vector< wid_t > &  adj
) [inline, protected]
Get IDs of adjacent entities.
For all entities adjacent to the passed entity, if the adjacent entity is to be exported (ID is not zero), append the ID to the passed list.
Definition at line 1774 of file WriteHDF5.cpp.
References moab::error(), ErrorCode, moab::RangeMap< KeyType, ValType, NullVal >::find(), moab::WriteUtilIface::get_adjacencies(), idMap, MB_SUCCESS, and writeUtil.
Referenced by count_adjacencies(), and write_adjacencies().
    const EntityHandle* adj_array;
    int num_adj;
    ErrorCode rval = writeUtil->get_adjacencies( entity, adj_array, num_adj );
    size_t j = 0;
    adj.resize( num_adj );
    for( int i = 0; i < num_adj; ++i )
        if( wid_t id = idMap.find( adj_array[i] ) ) adj[j++] = id;
    adj.resize( j );
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5::get_connectivity ( Range::const_iterator  begin,
wid_t id_data_out
) [private]
ErrorCode moab::WriteHDF5::get_num_sparse_tagged_entities ( const TagDesc tag,
size_t &  count
) [protected]
Definition at line 3250 of file WriteHDF5.cpp.
References ErrorCode, get_sparse_tagged_entities(), and moab::Range::size().
Referenced by moab::WriteHDF5Parallel::create_tag_tables().
    Range tmp;
    ErrorCode rval = get_sparse_tagged_entities( tag, tmp );
    count          = tmp.size();
    return rval;
ErrorCode moab::WriteHDF5::get_set_info ( EntityHandle  set,
long &  num_entities,
long &  num_children,
long &  num_parents,
unsigned long &  flags
) [protected]
Definition at line 1102 of file WriteHDF5.cpp.
References CHK_MB_ERR_0, ErrorCode, moab::Interface::get_meshset_options(), moab::Interface::get_number_entities_by_handle(), iFace, MB_SUCCESS, moab::Interface::num_child_meshsets(), and moab::Interface::num_parent_meshsets().
Referenced by count_set_size(), and write_sets().
    ErrorCode rval;
    int i;
    unsigned int u;
    rval = iFace->get_number_entities_by_handle( set, i, false );
    num_entities = i;
    rval = iFace->num_child_meshsets( set, &i );
    num_children = i;
    rval = iFace->num_parent_meshsets( set, &i );
    num_parents = i;
    rval = iFace->get_meshset_options( set, u );
    flags = u;
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5::get_sparse_tagged_entities ( const TagDesc tag,
Range range
) [protected]
Definition at line 3258 of file WriteHDF5.cpp.
References moab::Range::clear(), moab::Range::empty(), exportList, moab::Interface::get_entities_by_type_and_tag(), moab::WriteHDF5::TagDesc::have_dense(), iFace, moab::Interface::INTERSECT, MB_SUCCESS, MBMAXTYPE, moab::Range::merge(), nodeSet, moab::WriteHDF5::ExportSet::range, setSet, and moab::WriteHDF5::TagDesc::tag_id.
Referenced by moab::WriteHDF5Parallel::create_tag_tables(), get_num_sparse_tagged_entities(), serial_create_file(), write_sparse_tag(), and write_var_len_tag().
    results.clear();
    if( !tag.have_dense( setSet ) ) results.merge( setSet.range );
    std::list< ExportSet >::reverse_iterator e;
    for( e = exportList.rbegin(); e != exportList.rend(); ++e )
        if( !tag.have_dense( *e ) ) results.merge( e->range );
    if( !tag.have_dense( nodeSet ) ) results.merge( nodeSet.range );
    if( results.empty() ) return MB_SUCCESS;
    return iFace->get_entities_by_type_and_tag( 0, MBMAXTYPE, &tag.tag_id, 0, 1, results, Interface::INTERSECT );
ErrorCode moab::WriteHDF5::get_tag_data_length ( const TagDesc tag_info,
const Range range,
unsigned long &  result
) [protected]
get sum of lengths of tag values (as number of type) for variable length tag data.
Definition at line 3057 of file WriteHDF5.cpp.
References moab::Range::begin(), bufferSize, moab::Range::clear(), dataBuffer, moab::Range::end(), moab::error(), ErrorCode, iFace, MB_SUCCESS, moab::Range::merge(), moab::Range::size(), moab::Interface::tag_get_by_ptr(), and moab::WriteHDF5::TagDesc::tag_id.
    ErrorCode rval;
    result = 0;
    // Split buffer into two pieces, one for pointers and one for sizes
    size_t step, remaining;
    step                    = bufferSize / ( sizeof( int ) + sizeof( void* ) );
    const void** ptr_buffer = reinterpret_cast< const void** >( dataBuffer );
    int* size_buffer        = reinterpret_cast< int* >( ptr_buffer + step );
    Range subrange;
    Range::const_iterator iter = range.begin();
    for( remaining = range.size(); remaining >= step; remaining -= step )
        // Get subset of range containing 'count' entities
        Range::const_iterator end = iter;
        end += step;
        subrange.clear();
        subrange.merge( iter, end );
        iter = end;
        // Get tag sizes for entities
        rval = iFace->tag_get_by_ptr( tag_info.tag_id, subrange, ptr_buffer, size_buffer );
        // Sum lengths
        for( size_t i = 0; i < step; ++i )
            result += size_buffer[i];
    // Process remaining
    subrange.clear();
    subrange.merge( iter, range.end() );
    assert( subrange.size() == remaining );
    for( size_t i = 0; i < remaining; ++i )
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5::get_tag_size ( Tag  tag,
DataType moab_type,
int &  num_bytes,
int &  elem_size,
int &  file_size,
mhdf_TagDataType file_type,
hid_t &  hdf_type
) [private]
Get size data for tag
Parameters:
tagMOAB tag ID
moab_typeOutput: DataType for tag
num_bytesOutput: MOAB tag size (bits for bit tags). MB_VARIABLE_LENGTH for variable-length tags.
elem_sizeOutput: Size of of the base data type of the tag data (e.g. sizeof(double) if moab_type == MB_TYPE_DOUBLE). One for bit and opaque tags.
array_sizeOutput: The number of valeus of size elem_size for each tag. Always 1 for opaque data. Nubmer of bits for bit tags.
file_typeOutput: mhdf type enumeration
hdf_typeOutput: Handle to HDF5 type object. Caller is responsible for releasing this object (calling H5Tclose).
Definition at line 2922 of file WriteHDF5.cpp.
References CHECK_OPEN_HANDLES, CHK_MB_ERR_0, moab::error(), ErrorCode, id_type, iFace, MB_SUCCESS, MB_TAG_ANY, MB_TAG_NOT_FOUND, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, MB_VARIABLE_DATA_LENGTH, MB_VARIABLE_LENGTH, mhdf_BITFIELD, mhdf_ENTITY_ID, mhdf_FLOAT, mhdf_INTEGER, mhdf_OPAQUE, moab::Interface::tag_get_bytes(), moab::Interface::tag_get_data(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_get_name(), and tag_type_name().
Referenced by create_tag(), and write_tag().
    ErrorCode rval;
    Tag type_handle;
    std::string tag_name, tag_type_name;
    CHECK_OPEN_HANDLES;
    // We return NULL for hdf_type if it can be determined from
    // the file_type.  The only case where it is non-zero is
    // if the user specified a specific type via a mesh tag.
    bool close_hdf_type = false;
    rval = iFace->tag_get_data_type( tag, moab_type );
    rval = iFace->tag_get_length( tag, array_length );
    if( MB_VARIABLE_DATA_LENGTH == rval )
        array_length = MB_VARIABLE_LENGTH;
    rval = iFace->tag_get_bytes( tag, num_bytes );
        num_bytes = MB_VARIABLE_LENGTH;
    switch( moab_type )
        case MB_TYPE_INTEGER:
            type_size      = sizeof( int );
            file_type      = mhdf_INTEGER;
            hdf_type       = H5T_NATIVE_INT;
            break;
        case MB_TYPE_DOUBLE:
            type_size      = sizeof( double );
            file_type      = mhdf_FLOAT;
            hdf_type       = H5T_NATIVE_DOUBLE;
            break;
        case MB_TYPE_BIT:
            type_size = sizeof( bool );
            file_type = mhdf_BITFIELD;
            assert( array_length <= 8 );
            hdf_type = H5Tcopy( H5T_NATIVE_B8 );
            H5Tset_precision( hdf_type, array_length );
            close_hdf_type = true;
            break;
        case MB_TYPE_HANDLE:
            type_size      = sizeof( EntityHandle );
            file_type      = mhdf_ENTITY_ID;
            hdf_type       = id_type;
            break;
        case MB_TYPE_OPAQUE:
            file_type = mhdf_OPAQUE;
            rval      = iFace->tag_get_name( tag, tag_name );
            tag_type_name = "__hdf5_tag_type_";
            tag_type_name += tag_name;
            rval = iFace->tag_get_handle( tag_type_name.c_str(), 0, MB_TYPE_OPAQUE, type_handle, MB_TAG_ANY );
                if( num_bytes == MB_VARIABLE_LENGTH )
                    type_size = 1;
                else
                    type_size = num_bytes;
                hdf_type       = H5Tcreate( H5T_OPAQUE, type_size );
            else if( MB_SUCCESS == rval )
                int hsize;
                rval = iFace->tag_get_bytes( type_handle, hsize );
                if( hsize != sizeof( hid_t ) ) return error( MB_FAILURE );
                rval                    = iFace->tag_get_data( type_handle, &root, 1, &hdf_type );
                if( rval != MB_SUCCESS ) return error( rval );
                type_size = H5Tget_size( hdf_type );
                if( type_size != num_bytes ) return error( MB_FAILURE );
            else
            num_bytes    = array_length;
            array_length = ( num_bytes == MB_VARIABLE_LENGTH ) ? MB_VARIABLE_LENGTH : 1;
            break;
        default:
            break;
    assert( num_bytes == MB_VARIABLE_LENGTH || ( moab_type == MB_TYPE_BIT && num_bytes == 1 ) ||
            array_length * type_size == num_bytes );
        if( !close_hdf_type )
            hdf_type = H5Tcopy( hdf_type );
            // close_hdf_type = true;
    else if( array_length > 1 && moab_type != MB_TYPE_BIT )
        hsize_t len = array_length;
#if defined( H5Tarray_create_vers ) && ( H5Tarray_create_vers > 1 )
        hid_t temp_id = H5Tarray_create2( hdf_type, 1, &len );
#else
        hid_t temp_id = H5Tarray_create( hdf_type, 1, &len, NULL );
#endif
        if( close_hdf_type ) H5Tclose( hdf_type );
        hdf_type = temp_id;
    else if( !close_hdf_type )
    return MB_SUCCESS;
void moab::WriteHDF5::get_write_entities ( Range range) [protected]
Definition at line 3273 of file WriteHDF5.cpp.
References moab::Range::clear(), exportList, moab::Range::merge(), nodeSet, moab::WriteHDF5::ExportSet::range, and setSet.
    range.clear();
    range.merge( setSet.range );
        range.merge( e->range );
    range.merge( nodeSet.range );
Definition at line 405 of file WriteHDF5.cpp.
References CHK_MB_ERR_0, moab::RangeMap< KeyType, ValType, NullVal >::clear(), moab::WriteHDF5::HDF5ErrorHandler::data, ErrorCode, errorHandler, moab::WriteHDF5::HDF5ErrorHandler::func, moab::handle_hdf5_error(), idMap, iFace, MB_SUCCESS, moab::Interface::query_interface(), subState, topState, and writeUtil.
    ErrorCode rval;
    if( writeUtil )  // init has already been called
        return MB_SUCCESS;
    #ifdef DEBUG
      H5Eset_auto(&hdf_error_handler, writeUtil); // HDF5 callback for errors
    #endif
    // For known tag types, store the corresponding HDF5 in which
    // the tag data is to be written in the file.
    // register_known_tag_types(iFace);
    // Get the util interface
    rval = iFace->query_interface( writeUtil );
    idMap.clear();
#if defined( H5Eget_auto_vers ) && H5Eget_auto_vers > 1
    herr_t err = H5Eget_auto( H5E_DEFAULT, &errorHandler.func, &errorHandler.data );
#else
    herr_t err = H5Eget_auto( &errorHandler.func, &errorHandler.data );
#endif
    if( err < 0 )
        errorHandler.func = 0;
        errorHandler.data = 0;
    else
#if defined( H5Eset_auto_vers ) && H5Eset_auto_vers > 1
        err = H5Eset_auto( H5E_DEFAULT, &handle_hdf5_error, &errorHandler );
#else
        err = H5Eset_auto( &handle_hdf5_error, &errorHandler );
#endif
        if( err < 0 )
    if( !topState.valid() ) topState = MPEState( "WriteHDF5", "yellow" );
    if( !subState.valid() ) subState = MPEState( "WriteHDF5 subevent", "cyan" );
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5::initialize_mesh ( const Range  entities_by_dim[5]) [private]
Definition at line 738 of file WriteHDF5.cpp.
References dim, moab::CN::Dimension(), moab::Range::equal_range(), moab::error(), ErrorCode, exportList, moab::GeomUtil::first(), moab::Interface::get_connectivity(), iFace, moab::WriteHDF5::ExportSet::max_num_adjs, moab::WriteHDF5::ExportSet::max_num_ents, maxNumSetChildren, maxNumSetContents, maxNumSetParents, MB_SUCCESS, MBEDGE, MBENTITYSET, MBVERTEX, nodeSet, moab::WriteHDF5::ExportType::num_nodes, moab::WriteHDF5::ExportSet::range, setSet, and moab::WriteHDF5::ExportType::type.
Referenced by gather_all_mesh(), and gather_mesh_info().
    ErrorCode rval;
    if( !ranges[0].all_of_type( MBVERTEX ) ) return error( MB_FAILURE );
    nodeSet.range        = ranges[0];
    nodeSet.type         = MBVERTEX;
    nodeSet.num_nodes    = 1;
    nodeSet.max_num_ents = nodeSet.max_num_adjs = 0;
    if( !ranges[4].all_of_type( MBENTITYSET ) ) return error( MB_FAILURE );
    setSet.range        = ranges[4];
    setSet.type         = MBENTITYSET;
    setSet.num_nodes    = 0;
    setSet.max_num_ents = setSet.max_num_adjs = 0;
    maxNumSetContents = maxNumSetChildren = maxNumSetParents = 0;
    exportList.clear();
    std::vector< Range > bins( 1024 );  // Sort entities by connectivity length
                                        // Resize is expensive due to Range copy, so start big
    for( EntityType type = MBEDGE; type < MBENTITYSET; ++type )
        ExportSet set;
        set.max_num_ents = set.max_num_adjs = 0;
        const int dim                       = CN::Dimension( type );
        // Group entities by connectivity length
        bins.clear();
        assert( dim >= 0 && dim <= 4 );
        std::pair< Range::const_iterator, Range::const_iterator > p = ranges[dim].equal_range( type );
        Range::const_iterator i                                     = p.first;
        while( i != p.second )
            Range::const_iterator first = i;
            EntityHandle const* conn;
            int len, firstlen;
            // Dummy storage vector for structured mesh "get_connectivity" function
            std::vector< EntityHandle > storage;
            rval = iFace->get_connectivity( *i, conn, firstlen, false, &storage );
            for( ++i; i != p.second; ++i )
                rval = iFace->get_connectivity( *i, conn, len, false, &storage );
                if( len != firstlen ) break;
            if( firstlen >= (int)bins.size() ) bins.resize( firstlen + 1 );
            bins[firstlen].merge( first, i );
        // Create ExportSet for each group
        for( std::vector< Range >::iterator j = bins.begin(); j != bins.end(); ++j )
            if( j->empty() ) continue;
            set.range.clear();
            set.type      = type;
            set.num_nodes = j - bins.begin();
            exportList.push_back( set );
            exportList.back().range.swap( *j );
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5::parallel_create_file ( const char *  filename,
bool  overwrite,
const std::vector< std::string > &  qa_records,
const FileOptions opts,
const Tag tag_list,
int  num_tags,
int  dimension = 3,
double *  times = 0
Function to create the file. Virtual to allow override for parallel version.
Definition at line 2536 of file WriteHDF5.cpp.
References MB_NOT_IMPLEMENTED, and MB_SET_ERR.
    MB_SET_ERR( MB_NOT_IMPLEMENTED, "WriteHDF5 does not support parallel writing" );
void moab::WriteHDF5::print_id_map ( ) const [protected]
Definition at line 3283 of file WriteHDF5.cpp.
    print_id_map( std::cout, "" );
void moab::WriteHDF5::print_id_map ( std::ostream &  str,
const char *  prefix = ""
) const [protected]
Definition at line 3288 of file WriteHDF5.cpp.
References moab::RangeMap< KeyType, ValType, NullVal >::begin(), moab::RangeMap< KeyType, ValType, NullVal >::end(), moab::CN::EntityTypeName(), moab::ID_FROM_HANDLE(), idMap, and moab::TYPE_FROM_HANDLE().
    RangeMap< EntityHandle, wid_t >::const_iterator i;
    for( i = idMap.begin(); i != idMap.end(); ++i )
        const char* n1 = CN::EntityTypeName( TYPE_FROM_HANDLE( i->begin ) );
        EntityID id    = ID_FROM_HANDLE( i->begin );
        if( 1 == i->count )
            s << pfx << n1 << " " << id << " -> " << i->value << std::endl;
        else
            const char* n2 = CN::EntityTypeName( TYPE_FROM_HANDLE( i->begin + i->count - 1 ) );
            if( n1 == n2 )
                s << pfx << n1 << " " << id << "-" << id + i->count - 1 << " -> " << i->value << "-"
                  << i->value + i->count - 1 << std::endl;
            else
                s << pfx << n1 << " " << id << "-" << n1 << " " << ID_FROM_HANDLE( i->begin + i->count - 1 ) << " -> "
                  << i->value << "-" << i->value + i->count - 1 << std::endl;
void moab::WriteHDF5::print_times ( const double  times[NUM_TIMES]) const [protected, virtual]
Definition at line 3316 of file WriteHDF5.cpp.
References ADJ_TIME, CONN_TIME, COORD_TIME, CREATE_ADJ_TIME, CREATE_ELEM_TIME, CREATE_NODE_TIME, CREATE_SET_TIME, CREATE_TAG_TIME, CREATE_TIME, DENSE_TAG_TIME, FILEID_EXCHANGE_TIME, GATHER_TIME, NEGOTIATE_TYPES_TIME, SET_CHILD, SET_CONTENT, SET_META, SET_OFFSET_TIME, SET_PARENT, SET_TIME, SHARED_SET_CONTENTS, SHARED_SET_IDS, SPARSE_TAG_TIME, TAG_TIME, TOTAL_TIME, and VARLEN_TAG_TIME.
Referenced by moab::WriteHDF5Parallel::print_times(), and write_file_impl().
    std::cout << "WriteHDF5:           " << t[TOTAL_TIME] << std::endl
              << "  gather mesh:       " << t[GATHER_TIME] << std::endl
              << "  create file:       " << t[CREATE_TIME] << std::endl
              << "    create nodes:    " << t[CREATE_NODE_TIME] << std::endl
              << "    negotiate types: " << t[NEGOTIATE_TYPES_TIME] << std::endl
              << "    create elem:     " << t[CREATE_ELEM_TIME] << std::endl
              << "    file id exch:    " << t[FILEID_EXCHANGE_TIME] << std::endl
              << "    create adj:      " << t[CREATE_ADJ_TIME] << std::endl
              << "    create set:      " << t[CREATE_SET_TIME] << std::endl
              << "      shared ids:    " << t[SHARED_SET_IDS] << std::endl
              << "      shared data:   " << t[SHARED_SET_CONTENTS] << std::endl
              << "      set offsets:   " << t[SET_OFFSET_TIME] << std::endl
              << "    create tags:     " << t[CREATE_TAG_TIME] << std::endl
              << "  coordinates:       " << t[COORD_TIME] << std::endl
              << "  connectivity:      " << t[CONN_TIME] << std::endl
              << "  sets:              " << t[SET_TIME] << std::endl
              << "    set descrip:     " << t[SET_META] << std::endl
              << "    set content:     " << t[SET_CONTENT] << std::endl
              << "    set parent:      " << t[SET_PARENT] << std::endl
              << "    set child:       " << t[SET_CHILD] << std::endl
              << "  adjacencies:       " << t[ADJ_TIME] << std::endl
              << "  tags:              " << t[TAG_TIME] << std::endl
              << "    dense data:      " << t[DENSE_TAG_TIME] << std::endl
              << "    sparse data:     " << t[SPARSE_TAG_TIME] << std::endl
              << "    var-len data:    " << t[VARLEN_TAG_TIME] << std::endl;
ErrorCode moab::WriteHDF5::range_to_blocked_list ( const Range input_range,
std::vector< wid_t > &  output_id_list,
bool &  ranged_list
) [protected]
Get possibly compacted list of IDs for passed entities
For the passed range of entities, determine if IDs can be compacted and write IDs to passed list.
If the IDs are not compacted, the output list will contain a simple ordered list of IDs.
If IDs are compacted, the output list will contain {start,count} pairs.
If the ID list is compacted, ranged_list will be 'true'. Otherwise it will be 'false'.
Definition at line 1709 of file WriteHDF5.cpp.
References moab::Range::const_pair_begin(), moab::Range::const_pair_end(), idMap, and moab::range_to_blocked_list_templ().
Referenced by moab::WriteHDF5Parallel::communicate_shared_set_data(), count_set_size(), moab::WriteHDF5Parallel::pack_set(), and write_set_data().
    return range_to_blocked_list_templ( input_range.const_pair_begin(), input_range.const_pair_end(), idMap,
                                        output_id_list, ranged_list );
ErrorCode moab::WriteHDF5::range_to_blocked_list ( const EntityHandle input_ranges,
bool &  ranged_list
) [protected]
Definition at line 1717 of file WriteHDF5.cpp.
References idMap, and moab::range_to_blocked_list_templ().
    // We assume this in the cast on the following line
    typedef std::pair< EntityHandle, EntityHandle > mtype;
    assert( sizeof( mtype ) == 2 * sizeof( EntityHandle ) );
    const mtype* arr = reinterpret_cast< const mtype* >( array );
    return range_to_blocked_list_templ( arr, arr + num_input_ranges, idMap, output_id_list, ranged_list );
ErrorCode moab::WriteHDF5::range_to_id_list ( const Range input_range,
wid_t array
) [protected]
Definition at line 1729 of file WriteHDF5.cpp.
References moab::Range::const_pair_begin(), moab::Range::const_pair_end(), idMap, and moab::range_to_id_list_templ().
Referenced by write_sparse_ids().
    return range_to_id_list_templ( range.const_pair_begin(), range.const_pair_end(), idMap, array );
ErrorCode moab::WriteHDF5::serial_create_file ( const char *  filename,
bool  overwrite,
const Tag tag_list,
int  num_tags,
int  dimension = 3
) [private]
Definition at line 2548 of file WriteHDF5.cpp.
References moab::WriteHDF5::ExportSet::adj_offset, assign_ids(), check_dense_format_tag(), CHK_MB_ERR_0, CHK_MHDF_ERR_0, count_adjacencies(), count_set_size(), create_elem_table(), create_set_meta(), create_set_tables(), create_tag(), dbgOut, moab::Range::empty(), moab::CN::EntityTypeName(), ErrorCode, exportList, filePtr, moab::WriteHDF5::ExportSet::first_id, gather_tags(), get_sparse_tagged_entities(), get_tag_data_length(), id_type, iFace, moab::WriteHDF5::ExportSet::max_num_adjs, moab::WriteHDF5::ExportSet::max_num_ents, maxNumSetChildren, maxNumSetContents, maxNumSetParents, MB_SUCCESS, MB_TAG_DENSE, MB_VARIABLE_DATA_LENGTH, MBEDGE, MBENTITYSET, MBMAXTYPE, mhdf_closeData(), mhdf_createAdjacency(), mhdf_createFile(), mhdf_createNodeCoords(), mhdf_node_type_handle(), nodeSet, moab::WriteHDF5::ExportSet::offset, moab::WriteHDF5::ExportSet::range, setChildrenOffset, setContentsOffset, setParentsOffset, setSet, moab::Range::size(), moab::Interface::tag_get_default_value(), moab::Interface::tag_get_length(), moab::Interface::tag_get_type(), tagList, TagType, topState, moab::WriteHDF5::ExportSet::total_num_ents, moab::DebugOutput::tprint(), write_qa(), writeSetChildren, writeSetContents, writeSetParents, writeSets, and writeTagDense.
    long first_id;
    mhdf_Status status;
    hid_t handle;
    std::list< ExportSet >::iterator ex_itor;
    ErrorCode rval;
    topState.start( "creating file" );
    const char* type_names[MBMAXTYPE];
    memset( type_names, 0, MBMAXTYPE * sizeof( char* ) );
    for( EntityType i = MBEDGE; i < MBENTITYSET; ++i )
        type_names[i] = CN::EntityTypeName( i );
    // Create the file
    filePtr = mhdf_createFile( filename, overwrite, type_names, MBMAXTYPE, id_type, &status );
    assert( !!filePtr );
    rval = write_qa( qa_records );
    // Create node table
    if( nodeSet.range.size() )
        nodeSet.total_num_ents = nodeSet.range.size();
        handle = mhdf_createNodeCoords( filePtr, dimension, nodeSet.total_num_ents, &first_id, &status );
        nodeSet.first_id = (wid_t)first_id;
        rval             = assign_ids( nodeSet.range, nodeSet.first_id );
    else
        nodeSet.first_id = std::numeric_limits< wid_t >::max();
    nodeSet.offset = 0;
    // Create element tables
    for( ex_itor = exportList.begin(); ex_itor != exportList.end(); ++ex_itor )
        ex_itor->total_num_ents = ex_itor->range.size();
        rval                    = create_elem_table( *ex_itor, ex_itor->total_num_ents, first_id );
        ex_itor->first_id = (wid_t)first_id;
        ex_itor->offset   = 0;
        rval              = assign_ids( ex_itor->range, ex_itor->first_id );
    // Create set tables
    writeSets = !setSet.range.empty();
    if( writeSets )
        long contents_len, children_len, parents_len;
        setSet.total_num_ents = setSet.range.size();
        setSet.max_num_ents   = setSet.total_num_ents;
        rval                  = create_set_meta( setSet.total_num_ents, first_id );
        setSet.first_id = (wid_t)first_id;
        rval            = assign_ids( setSet.range, setSet.first_id );
        rval = count_set_size( setSet.range, contents_len, children_len, parents_len );
        rval = create_set_tables( contents_len, children_len, parents_len );
        setSet.offset     = 0;
        setContentsOffset = 0;
        setChildrenOffset = 0;
        setParentsOffset  = 0;
        writeSetContents  = !!contents_len;
        writeSetChildren  = !!children_len;
        writeSetParents   = !!parents_len;
        maxNumSetContents = contents_len;
        maxNumSetChildren = children_len;
        maxNumSetParents  = parents_len;
    }  // if (!setSet.range.empty())
    // Create adjacency table after set table, because sets do not have yet an id
    // some entities are adjacent to sets (exodus?)
    // Create node adjacency table
    wid_t num_adjacencies;
#ifdef MB_H5M_WRITE_NODE_ADJACENCIES
    rval = count_adjacencies( nodeSet.range, num_adjacencies );
    nodeSet.adj_offset   = 0;
    nodeSet.max_num_adjs = num_adjacencies;
    if( num_adjacencies > 0 )
        handle = mhdf_createAdjacency( filePtr, mhdf_node_type_handle(), num_adjacencies, &status );
#endif
    // Create element adjacency tables
        rval = count_adjacencies( ex_itor->range, num_adjacencies );
        ex_itor->adj_offset   = 0;
        ex_itor->max_num_adjs = num_adjacencies;
            handle = mhdf_createAdjacency( filePtr, ex_itor->name(), num_adjacencies, &status );
    dbgOut.tprint( 1, "Gathering Tags\n" );
    rval = gather_tags( user_tag_list, num_user_tags );
    // Create the tags and tag data tables
    std::list< TagDesc >::iterator tag_iter = tagList.begin();
    for( ; tag_iter != tagList.end(); ++tag_iter )
        // As we haven't yet added any ExportSets for which to write
        // dense tag data to the TagDesc struct pointed to by
        // tag_iter, this call will initially return all tagged entities
        // in the set of entities to be written.
        Range range;
        rval = get_sparse_tagged_entities( *tag_iter, range );
        int s;
        bool var_len = ( MB_VARIABLE_DATA_LENGTH == iFace->tag_get_length( tag_iter->tag_id, s ) );
        // Determine which ExportSets we want to write dense
        // data for. We never write dense data for variable-length
        // tag data.
        if( !var_len && writeTagDense )
            // Check if we want to write this tag in dense format even if not
            // all of the entities have a tag value.  The criterion of this
            // is that the tag be dense, have a default value, and have at
            // least 2/3 of the entities tagged.
            bool prefer_dense = false;
            TagType type;
            rval = iFace->tag_get_type( tag_iter->tag_id, type );
            if( MB_TAG_DENSE == type )
                const void* defval = 0;
                rval               = iFace->tag_get_default_value( tag_iter->tag_id, defval, s );
                if( MB_SUCCESS == rval ) prefer_dense = true;
            if( check_dense_format_tag( nodeSet, range, prefer_dense ) )
                range -= nodeSet.range;
                tag_iter->dense_list.push_back( nodeSet );
            std::list< ExportSet >::const_iterator ex = exportList.begin();
            for( ; ex != exportList.end(); ++ex )
                if( check_dense_format_tag( *ex, range, prefer_dense ) )
                    range -= ex->range;
                    tag_iter->dense_list.push_back( *ex );
            if( check_dense_format_tag( setSet, range, prefer_dense ) )
                range -= setSet.range;
                tag_iter->dense_list.push_back( setSet );
        tag_iter->write_sparse = !range.empty();
        unsigned long var_len_total = 0;
        if( var_len )
            rval = get_tag_data_length( *tag_iter, range, var_len_total );
        rval = create_tag( *tag_iter, range.size(), var_len_total );
    }  // for (tags)
    topState.end();
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5::vector_to_id_list ( const std::vector< EntityHandle > &  input,
std::vector< wid_t > &  output,
bool  remove_non_written = false
) [protected]
Definition at line 1757 of file WriteHDF5.cpp.
References ErrorCode.
Referenced by moab::WriteHDF5Parallel::communicate_shared_set_data(), moab::WriteHDF5Parallel::pack_set(), vector_to_id_list(), and write_set_data().
    output.resize( input.size() );
    size_t output_size = 0;
    ErrorCode rval     = vector_to_id_list( &input[0], input.size(), &output[0], output_size, remove_zeros );
    output.resize( output_size );
    return rval;
ErrorCode moab::WriteHDF5::vector_to_id_list ( const EntityHandle input,
wid_t output,
size_t  num_entities
) [protected]
Definition at line 1768 of file WriteHDF5.cpp.
References vector_to_id_list().
    size_t output_len;
    return vector_to_id_list( input, count, output, output_len, false );
size_t  input_len,
wid_t output,
size_t &  output_len,
) [protected]
Definition at line 1734 of file WriteHDF5.cpp.
References moab::RangeMap< KeyType, ValType, NullVal >::find(), idMap, MB_SUCCESS, and output.
    const EntityHandle* i_iter = input;
    const EntityHandle* i_end  = input + input_len;
    wid_t* o_iter              = output;
    for( ; i_iter != i_end; ++i_iter )
        wid_t id = idMap.find( *i_iter );
        if( !remove_zeros || id != 0 )
            *o_iter = id;
            ++o_iter;
    output_len = o_iter - output;
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5::write_adjacencies ( const ExportSet export_set) [private]
Write adjacency info for passed set of elements
Note: Must have written element connectivity so elements have IDs assigned.
Definition at line 1790 of file WriteHDF5.cpp.
References moab::WriteHDF5::ExportSet::adj_offset, moab::IODebugTrack::all_reduce(), moab::Range::begin(), buffer, bufferSize, CHECK_OPEN_HANDLES, CHK_MB_ERR_1, CHK_MHDF_ERR_0, CHK_MHDF_ERR_1, collectiveIO, dataBuffer, dbgOut, debug_barrier, debugTrack, moab::Range::end(), ErrorCode, filePtr, moab::RangeMap< KeyType, ValType, NullVal >::find(), get_adjacencies(), id_type, idMap, moab::WriteHDF5::ExportSet::max_num_adjs, MB_SUCCESS, mhdf_closeData(), mhdf_openAdjacency(), mhdf_writeAdjacencyWithOpt(), moab::WriteHDF5::ExportSet::name(), moab::DebugOutput::print(), moab::WriteHDF5::ExportSet::range, moab::IODebugTrack::record_io(), VALGRIND_MAKE_MEM_UNDEFINED, and writeProp.
    ErrorCode rval;
    mhdf_Status status;
    Range::const_iterator iter;
    const Range::const_iterator end = elements.range.end();
    CHECK_OPEN_HANDLES;
    debug_barrier();
    /* Count Adjacencies */
    long count = 0;
    // for (iter = elements.range.begin(); iter != end; ++iter) {
    //  adj_list.clear();
    //  rval = get_adjacencies(*iter, adj_list);CHK_MB_ERR_0(rval);
    //  if (adj_list.size() > 0)
    //    count += adj_list.size() + 2;
    // if (count == 0)
    //  return MB_SUCCESS;
    long offset = elements.adj_offset;
    if( elements.max_num_adjs == 0 ) return MB_SUCCESS;
    /* Create data list */
    hid_t table = mhdf_openAdjacency( filePtr, elements.name(), &count, &status );
    IODebugTrack track( debugTrack, "Adjacencies", count );
    /* Write data */
    wid_t* buffer   = (wid_t*)dataBuffer;
    long chunk_size = bufferSize / sizeof( wid_t );
    long num_writes = ( elements.max_num_adjs + chunk_size - 1 ) / chunk_size;
    (void)VALGRIND_MAKE_MEM_UNDEFINED( dataBuffer, bufferSize );
    count = 0;
    for( iter = elements.range.begin(); iter != end; ++iter )
        adj_list.clear();
        CHK_MB_ERR_1( rval, table, status );
        if( adj_list.size() == 0 ) continue;
        // If buffer is full, flush it
        if( count + adj_list.size() + 2 > (unsigned long)chunk_size )
            dbgOut.print( 3, " writing adjacency chunk.\n" );
            track.record_io( offset, count );
            mhdf_writeAdjacencyWithOpt( table, offset, count, id_type, buffer, writeProp, &status );
            CHK_MHDF_ERR_1( status, table );
            offset += count;
            count = 0;
        buffer[count++] = idMap.find( *iter );
        buffer[count++] = adj_list.size();
        assert( adj_list.size() + 2 < (unsigned long)chunk_size );
        memcpy( buffer + count, &adj_list[0], adj_list.size() * sizeof( wid_t ) );
        count += adj_list.size();
    if( count )
        dbgOut.print( 2, " writing final adjacency chunk.\n" );
        offset += count;
        count = 0;
        --num_writes;
    // Do empty writes if necessary for parallel collective IO
    if( collectiveIO )
        while( num_writes > 0 )
            --num_writes;
            assert( writeProp != H5P_DEFAULT );
            dbgOut.print( 2, " writing empty adjacency chunk.\n" );
            mhdf_writeAdjacencyWithOpt( table, offset, 0, id_type, 0, writeProp, &status );
    mhdf_closeData( filePtr, table, &status );
    track.all_reduce();
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5::write_dense_tag ( const TagDesc tag_data,
const ExportSet elem_data,
const std::string &  tag_name,
int  hdf5_type_size
) [private]
Definition at line 2295 of file WriteHDF5.cpp.
References CHECK_OPEN_HANDLES, CHK_MB_ERR_0, CHK_MHDF_ERR_0, debugTrack, ErrorCode, filePtr, moab::WriteHDF5::ExportSet::max_num_ents, MB_SUCCESS, mhdf_closeData(), mhdf_openDenseTagData(), moab::WriteHDF5::ExportSet::name(), moab::WriteHDF5::ExportSet::offset, moab::WriteHDF5::ExportSet::range, moab::Range::size(), moab::WriteHDF5::TagDesc::tag_id, and write_tag_values().
Referenced by write_tag().
    CHECK_OPEN_HANDLES;
    // Open tables to write info
    mhdf_Status status;
    long table_size;
    hid_t table = mhdf_openDenseTagData( filePtr, name.c_str(), elem_data.name(), &table_size, &status );
    assert( elem_data.range.size() + elem_data.offset <= (unsigned long)table_size );
    IODebugTrack track( debugTrack, name + " " + elem_data.name() + " Data", table_size );
    ErrorCode rval = write_tag_values( tag_data.tag_id, table, elem_data.offset, elem_data.range, mb_data_type,
                                       value_type, value_type_size, elem_data.max_num_ents, track );
    return MB_SUCCESS;
Write out element connectivity.
Write connectivity for passed set of elements.
Note: Assigns element IDs. Note: Must do write_nodes first so node IDs get assigned.
Definition at line 1013 of file WriteHDF5.cpp.
References moab::Range::begin(), buffer, bufferSize, CHECK_OPEN_HANDLES, CHK_MB_ERR_1, CHK_MHDF_ERR_0, CHK_MHDF_ERR_1, collectiveIO, dataBuffer, dbgOut, debug_barrier, debugTrack, moab::CN::EntityTypeName(), moab::error(), ErrorCode, filePtr, moab::RangeMap< KeyType, ValType, NullVal >::find(), moab::WriteHDF5::ExportSet::first_id, moab::WriteUtilIface::get_element_connect(), id_type, idMap, moab::WriteHDF5::ExportSet::max_num_ents, MB_SET_ERR_CONT, MB_SUCCESS, mhdf_closeData(), mhdf_openConnectivity(), mhdf_writeConnectivityWithOpt(), moab::WriteHDF5::ExportSet::name(), moab::WriteHDF5::ExportType::num_nodes, moab::WriteHDF5::ExportSet::offset, moab::DebugOutput::print(), moab::DebugOutput::printf(), moab::WriteHDF5::ExportSet::range, moab::Range::size(), moab::WriteHDF5::ExportType::type, VALGRIND_MAKE_MEM_UNDEFINED, writeProp, and writeUtil.
    mhdf_Status status;
    ErrorCode rval;
    long first_id;
    int nodes_per_elem;
    long table_size;
    CHECK_OPEN_HANDLES;
    debug_barrier();
    dbgOut.printf( 2, "Writing %lu elements of type %s%d\n", (unsigned long)elems.range.size(),
                   CN::EntityTypeName( elems.type ), elems.num_nodes );
    dbgOut.print( 3, "Writing elements", elems.range );
    hid_t elem_table = mhdf_openConnectivity( filePtr, elems.name(), &nodes_per_elem, &table_size, &first_id, &status );
    IODebugTrack track( debugTrack, elems.name() && strlen( elems.name() ) ? elems.name() : "<ANONYMOUS ELEM SET?>",
                        table_size );
    assert( (unsigned long)first_id <= elems.first_id );
    assert( (unsigned long)table_size >= elems.offset + elems.range.size() );
    EntityHandle* buffer = (EntityHandle*)dataBuffer;
    int chunk_size       = bufferSize / ( elems.num_nodes * sizeof( wid_t ) );
    long offset          = elems.offset;
    long remaining       = elems.range.size();
    long num_writes      = ( remaining + chunk_size - 1 ) / chunk_size;
    if( elems.max_num_ents )
        assert( elems.max_num_ents >= remaining );
        num_writes = ( elems.max_num_ents + chunk_size - 1 ) / chunk_size;
    long remaining_writes = num_writes;
    Range::iterator iter  = elems.range.begin();
    while( remaining )
        long count = chunk_size < remaining ? chunk_size : remaining;
        remaining -= count;
        Range::iterator next = iter;
        next += count;
        rval = writeUtil->get_element_connect( iter, next, elems.num_nodes, count * elems.num_nodes, buffer );
        CHK_MB_ERR_1( rval, elem_table, status );
        iter = next;
        for( long i = 0; i < count * nodes_per_elem; ++i )
            buffer[i] = idMap.find( buffer[i] );
            if( 0 == buffer[i] )
                MB_SET_ERR_CONT( "Invalid " << elems.name() << " element connectivity. Write Aborted" );
                mhdf_closeData( filePtr, elem_table, &status );
        dbgOut.printf( 3, " writing node connectivity %ld of %ld, %ld values at %ld\n",
                       num_writes - remaining_writes + 1, num_writes, count, offset );
        mhdf_writeConnectivityWithOpt( elem_table, offset, count, id_type, buffer, writeProp, &status );
        CHK_MHDF_ERR_1( status, elem_table );
        offset += count;
        --remaining_writes;
    if( collectiveIO )
        while( remaining_writes-- )
            dbgOut.printf( 3, " writing (empty) connectivity chunk %ld of %ld.\n", num_writes - remaining_writes + 1,
                           num_writes );
            mhdf_writeConnectivityWithOpt( elem_table, offset, 0, id_type, 0, writeProp, &status );
    track.all_reduce();
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5::write_file ( const char *  filename,
const EntityHandle export_sets,
const Tag tag_list = NULL,
int  num_tags = 0,
int  user_dimension = 3
) [virtual]
Export specified meshsets to file
Parameters:
filenameThe filename to export.
export_setsArray of handles to sets to export, or NULL to export all.
export_set_countLength of export_sets array.
Implements moab::WriterIface.
Definition at line 492 of file WriteHDF5.cpp.
References bufferSize, collectiveIO, dataBuffer, dbgOut, debugTrack, moab::error(), ErrorCode, filePtr, moab::FileOptions::get_int_option(), moab::FileOptions::get_null_option(), MB_ENTITY_NOT_FOUND, MB_MEMORY_ALLOCATION_FAILED, MB_SET_ERR_CONT, MB_SUCCESS, mhdf_closeFile(), mhdf_isError(), mhdf_message(), parallelWrite, moab::DebugOutput::set_verbosity(), write_file_impl(), write_finished(), WRITE_HDF5_BUFFER_SIZE, writeProp, and writeTagDense.
Referenced by test_write_invalid_elem().
    mhdf_Status status;
    parallelWrite = false;
    collectiveIO  = false;
    // Enable debug output
    int tmpval = 0;
    if( MB_SUCCESS == opts.get_int_option( "DEBUG_IO", 1, tmpval ) ) dbgOut.set_verbosity( tmpval );
    // writeTagDense = (MB_SUCCESS == opts.get_null_option("DENSE_TAGS"));
    writeTagDense = true;
    // Enable some extra checks for reads.  Note: amongst other things this
    // will print errors if the entire file is not read, so if doing a
    // partial read that is not a parallel read, this should be disabled.
    debugTrack = ( MB_SUCCESS == opts.get_null_option( "DEBUG_BINIO" ) );
    bufferSize = WRITE_HDF5_BUFFER_SIZE;
    int buf_size;
    ErrorCode rval = opts.get_int_option( "BUFFER_SIZE", buf_size );
    if( MB_SUCCESS == rval && buf_size >= 24 ) bufferSize = buf_size;
    // Allocate internal buffer to use when gathering data to write.
    dataBuffer = (char*)malloc( bufferSize );
    if( !dataBuffer ) return error( MB_MEMORY_ALLOCATION_FAILED );
    // Clear filePtr so we know if it is open upon failure
    filePtr = 0;
    // Do actual write.
    writeProp        = H5P_DEFAULT;
    ErrorCode result = write_file_impl( filename, overwrite, opts, set_array, num_sets, qa_records, tag_list, num_tags,
                                        user_dimension );
    // Close writeProp if it was opened
    if( writeProp != H5P_DEFAULT ) H5Pclose( writeProp );
    // Free memory buffer
    free( dataBuffer );
    dataBuffer = 0;
    // Close file
    bool created_file = false;
    if( filePtr )
        created_file = true;
        mhdf_closeFile( filePtr, &status );
        filePtr = 0;
        if( mhdf_isError( &status ) )
            MB_SET_ERR_CONT( mhdf_message( &status ) );
            if( MB_SUCCESS == result ) result = MB_FAILURE;
    // Release other resources
        result = write_finished();
    else
        write_finished();
    // If write failed, remove file unless KEEP option was specified
    if( MB_SUCCESS != result && created_file && MB_ENTITY_NOT_FOUND == opts.get_null_option( "KEEP" ) )
        remove( filename );
    return result;
ErrorCode moab::WriteHDF5::write_file_impl ( const char *  filename,
const bool  overwrite,
const int  export_set_count,
const Tag tag_list,
int  num_tags,
) [private]
Do the actual work of write_file. Separated from write_file for easier resource cleanup.
Definition at line 569 of file WriteHDF5.cpp.
References ADJ_TIME, CHK_MB_ERR_0, collectiveIO, CONN_TIME, COORD_TIME, CREATE_TIME, dbgOut, debug_barrier, moab::Range::empty(), moab::error(), ErrorCode, exportList, gather_all_mesh(), gather_mesh_info(), GATHER_TIME, moab::Interface::get_dimension(), moab::FileOptions::get_null_option(), iFace, init(), moab::FileOptions::match_option(), MB_SET_ERR_CONT, MB_SUCCESS, nodeSet, NUM_TIMES, parallel_create_file(), parallelWrite, print_times(), moab::WriteHDF5::ExportSet::range, serial_create_file(), SET_TIME, setSet, moab::Range::size(), moab::Interface::tag_get_name(), TAG_TIME, tagList, moab::CpuTimer::time_elapsed(), moab::CpuTimer::time_since_birth(), topState, TOTAL_TIME, moab::DebugOutput::tprint(), write_adjacencies(), write_elems(), write_nodes(), write_sets(), and write_tag().
Referenced by write_file().
    ErrorCode result;
    std::list< TagDesc >::const_iterator t_itor;
    EntityHandle elem_count, max_id;
    double times[NUM_TIMES] = { 0 };
    if( MB_SUCCESS != init() ) return error( MB_FAILURE );
    // See if we need to report times
    bool cputime = false;
    result       = opts.get_null_option( "CPUTIME" );
    if( MB_SUCCESS == result ) cputime = true;
    CpuTimer timer;
    dbgOut.tprint( 1, "Gathering Mesh\n" );
    topState.start( "gathering mesh" );
    // Gather mesh to export
    exportList.clear();
    if( 0 == num_sets || ( 1 == num_sets && set_array[0] == 0 ) )
        result = gather_all_mesh();
        topState.end( result );
    else
        std::vector< EntityHandle > passed_export_list( set_array, set_array + num_sets );
        result = gather_mesh_info( passed_export_list );
    times[GATHER_TIME] = timer.time_elapsed();
    // if (nodeSet.range.size() == 0)
    //  return error(MB_ENTITY_NOT_FOUND);
    dbgOut.tprint( 1, "Checking ID space\n" );
    // Make sure ID space is sufficient
    elem_count = nodeSet.range.size() + setSet.range.size();
        elem_count += ex_itor->range.size();
    max_id = (EntityHandle)1 << ( 8 * sizeof( wid_t ) - 1 );
    if( elem_count > max_id )
        MB_SET_ERR_CONT( "ID space insufficient for mesh size" );
        return error( result );
    dbgOut.tprint( 1, "Creating File\n" );
    // Figure out the dimension in which to write the mesh.
    int mesh_dim;
    result = iFace->get_dimension( mesh_dim );
    if( user_dimension < 1 ) user_dimension = mesh_dim;
    user_dimension = user_dimension > mesh_dim ? mesh_dim : user_dimension;
    // Create the file layout, including all tables (zero-ed) and
    // all structure and meta information.
    const char* optnames[] = { "WRITE_PART", "FORMAT", 0 };
    int junk;
    parallelWrite = ( MB_SUCCESS == opts.match_option( "PARALLEL", optnames, junk ) );
    if( parallelWrite )
        // Just store Boolean value based on string option here.
        // parallel_create_file will set writeProp accordingly.
        // collectiveIO = (MB_SUCCESS == opts.get_null_option("COLLECTIVE"));
        // dbgOut.printf(2, "'COLLECTIVE' option = %s\n", collectiveIO ? "YES" : "NO");
        // Do this all the time, as it appears to be much faster than indep in some cases
        collectiveIO = true;
        result =
            parallel_create_file( filename, overwrite, qa_records, opts, tag_list, num_tags, user_dimension, times );
    else
        result = serial_create_file( filename, overwrite, qa_records, tag_list, num_tags, user_dimension );
    if( MB_SUCCESS != result ) return error( result );
    times[CREATE_TIME] = timer.time_elapsed();
    dbgOut.tprint( 1, "Writing Nodes.\n" );
    // Write node coordinates
    if( !nodeSet.range.empty() || parallelWrite )
        topState.start( "writing coords" );
        result = write_nodes();
    times[COORD_TIME] = timer.time_elapsed();
    dbgOut.tprint( 1, "Writing connectivity.\n" );
    // Write element connectivity
        topState.start( "writing connectivity for ", ex_itor->name() );
        result = write_elems( *ex_itor );
    times[CONN_TIME] = timer.time_elapsed();
    dbgOut.tprint( 1, "Writing sets.\n" );
    // Write meshsets
    result = write_sets( times );
    debug_barrier();
    times[SET_TIME] = timer.time_elapsed();
    dbgOut.tprint( 1, "Writing adjacencies.\n" );
    // Write adjacencies
    // Tim says don't save node adjacencies!
    result = write_adjacencies( nodeSet );
#endif
        topState.start( "writing adjacencies for ", ex_itor->name() );
        result = write_adjacencies( *ex_itor );
    times[ADJ_TIME] = timer.time_elapsed();
    dbgOut.tprint( 1, "Writing tags.\n" );
    // Write tags
    for( t_itor = tagList.begin(); t_itor != tagList.end(); ++t_itor )
        std::string name;
        iFace->tag_get_name( t_itor->tag_id, name );
        topState.start( "writing tag: ", name.c_str() );
        result = write_tag( *t_itor, times );
    times[TAG_TIME] = timer.time_elapsed();
    times[TOTAL_TIME] = timer.time_since_birth();
    if( cputime )
        print_times( times );
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5::write_finished ( ) [protected, virtual]
Definition at line 456 of file WriteHDF5.cpp.
References moab::RangeMap< KeyType, ValType, NullVal >::clear(), moab::Range::clear(), moab::WriteHDF5::HDF5ErrorHandler::data, errorHandler, exportList, moab::WriteHDF5::HDF5ErrorHandler::func, moab::handle_hdf5_error(), idMap, MB_SUCCESS, nodeSet, moab::WriteHDF5::ExportSet::range, setSet, and tagList.
    // Release memory allocated in lists
    exportList.clear();
    nodeSet.range.clear();
    setSet.range.clear();
    tagList.clear();
    idMap.clear();
    HDF5ErrorHandler handler;
    herr_t err = H5Eget_auto( H5E_DEFAULT, &handler.func, &handler.data );
#else
    herr_t err = H5Eget_auto( &handler.func, &handler.data );
#endif
    if( err >= 0 && handler.func == &handle_hdf5_error )
        assert( handler.data == &errorHandler );
        H5Eset_auto( H5E_DEFAULT, errorHandler.func, errorHandler.data );
#else
        H5Eset_auto( errorHandler.func, errorHandler.data );
#endif
    return MB_SUCCESS;
Write out the nodes.
Note: Assigns IDs to nodes.
Definition at line 904 of file WriteHDF5.cpp.
References moab::IODebugTrack::all_reduce(), moab::Range::begin(), buffer, bufferSize, CHECK_OPEN_HANDLES, CHK_MB_ERR_0, CHK_MB_ERR_1, CHK_MHDF_ERR_0, CHK_MHDF_ERR_1, collectiveIO, dataBuffer, dbgOut, debug_barrier, debugTrack, dim, ErrorCode, filePtr, moab::Interface::get_dimension(), moab::WriteUtilIface::get_node_coords(), iFace, moab::WriteHDF5::ExportSet::max_num_ents, MB_SUCCESS, mhdf_closeData(), mhdf_openNodeCoords(), mhdf_writeNodeCoordsWithOpt(), mhdf_writeNodeCoordWithOpt(), nodeSet, moab::WriteHDF5::ExportSet::offset, moab::DebugOutput::print(), moab::DebugOutput::printf(), moab::WriteHDF5::ExportSet::range, moab::IODebugTrack::record_io(), moab::Range::size(), moab::WriteHDF5::ExportSet::total_num_ents, VALGRIND_MAKE_MEM_UNDEFINED, writeProp, and writeUtil.
    mhdf_Status status;
    int dim, mesh_dim;
    ErrorCode rval;
    hid_t node_table;
    long first_id, num_nodes;
    if( !nodeSet.total_num_ents ) return MB_SUCCESS;  // No nodes!
    CHECK_OPEN_HANDLES;
    rval = iFace->get_dimension( mesh_dim );
    debug_barrier();
    dbgOut.print( 3, "Opening Node Coords\n" );
    node_table = mhdf_openNodeCoords( filePtr, &num_nodes, &dim, &first_id, &status );
    IODebugTrack track( debugTrack, "nodes", num_nodes );
    double* buffer = (double*)dataBuffer;
#ifdef BLOCKED_COORD_IO
    int chunk_size = bufferSize / sizeof( double );
#else
    int chunk_size = bufferSize / ( 3 * sizeof( double ) );
#endif
    long remaining  = nodeSet.range.size();
    if( nodeSet.max_num_ents )
        assert( nodeSet.max_num_ents >= remaining );
        num_writes = ( nodeSet.max_num_ents + chunk_size - 1 ) / chunk_size;
    long offset                = nodeSet.offset;
    Range::const_iterator iter = nodeSet.range.begin();
    dbgOut.printf( 3, "Writing %ld nodes in %ld blocks of %d\n", remaining, ( remaining + chunk_size - 1 ) / chunk_size,
                   chunk_size );
    while( remaining )
        remaining -= count;
        end += count;
        for( int d = 0; d < dim; d++ )
            if( d < mesh_dim )
                rval = writeUtil->get_node_coords( d, iter, end, count, buffer );
                CHK_MB_ERR_1( rval, node_table, status );
            else
                memset( buffer, 0, count * sizeof( double ) );
            dbgOut.printf( 3, " writing %c node chunk %ld of %ld, %ld values at %ld\n", (char)( 'X' + d ),
            mhdf_writeNodeCoordWithOpt( node_table, offset, count, d, buffer, writeProp, &status );
            CHK_MHDF_ERR_1( status, node_table );
#else
        rval = writeUtil->get_node_coords( -1, iter, end, 3 * count, buffer );
        dbgOut.printf( 3, " writing node chunk %ld of %ld, %ld values at %ld\n", num_writes - remaining_writes + 1,
        mhdf_writeNodeCoordsWithOpt( node_table, offset, count, buffer, writeProp, &status );
#endif
        iter = end;
        offset += count;
        --remaining_writes;
    if( collectiveIO )
            for( int d = 0; d < dim; ++d )
                dbgOut.printf( 3, " writing (empty) %c node chunk %ld of %ld.\n", (char)( 'X' + d ),
                               num_writes - remaining_writes, num_writes );
                mhdf_writeNodeCoordWithOpt( node_table, offset, 0, d, 0, writeProp, &status );
#else
            dbgOut.printf( 3, " writing (empty) node chunk %ld of %ld.\n", num_writes - remaining_writes, num_writes );
            mhdf_writeNodeCoordsWithOpt( node_table, offset, 0, 0, writeProp, &status );
#endif
    mhdf_closeData( filePtr, node_table, &status );
    track.all_reduce();
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5::write_qa ( const std::vector< std::string > &  list) [protected]
Write exodus-type QA info.
Definition at line 2401 of file WriteHDF5.cpp.
References CHECK_OPEN_HANDLES, CHK_MHDF_ERR_0, dbgOut, filePtr, MB_SUCCESS, mhdf_writeHistory(), moab::DebugOutput::print(), and t.
    const char* app  = "MOAB";
    const char* vers = MOAB_VERSION;
    char date_str[64];
    char time_str[64];
    CHECK_OPEN_HANDLES;
    std::vector< const char* > strs( list.size() ? list.size() : 4 );
    if( list.size() == 0 )
        time_t t = time( NULL );
        tm* lt   = localtime( &t );
#ifdef WIN32
        strftime( date_str, sizeof( date_str ), "%m/%d/%y", lt );  // VS 2008 does not support %D
        strftime( time_str, sizeof( time_str ), "%H:%M:%S", lt );  // VS 2008 does not support %T
#else
        strftime( date_str, sizeof( date_str ), "%D", lt );
        strftime( time_str, sizeof( time_str ), "%T", lt );
#endif
        strs[0] = app;
        strs[1] = vers;
        strs[2] = date_str;
        strs[3] = time_str;
    else
        for( unsigned int i = 0; i < list.size(); ++i )
            strs[i] = list[i].c_str();
    mhdf_Status status;
    dbgOut.print( 2, " writing QA history.\n" );
    mhdf_writeHistory( filePtr, &strs[0], strs.size(), &status );
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5::write_set_data ( const WriteUtilIface::EntityListType  which_data,
const hid_t  handle,
IODebugTrack track,
Range ranged = 0,
Range null_stripped = 0,
std::vector< long > *  set_sizes = 0
) [private]
Write set contents/parents/children lists
Parameters:
which_dataWhich set data to write (contents, parents, or children)
handleHDF5 handle for data set in which to write data
trackDebugging tool
rangedWill be populated with handles of sets for which contents were written in a range-compacted format. (mhdf_SET_RANGE_BIT). Should be null for parents/children.
null_strippedWill be populated with handles of sets for which invalid or null handles were stripped from the contents list. This is only done for unordered sets. This argument should be null if writing parents/children because those lists are always ordered.
set_sizesWill be populated with the length of the data written for those sets for which the handles were added to either ranged or null_stripped. Values are in handle order.
Definition at line 1131 of file WriteHDF5.cpp.
References moab::Range::begin(), buffer, bufferSize, moab::WriteUtilIface::CHILDREN, CHK_MB_ERR_0, CHK_MHDF_ERR_0, moab::WriteUtilIface::CONTENTS, dataBuffer, dbgOut, debug_barrier, moab::Range::end(), ErrorCode, moab::WriteUtilIface::get_entity_list_pointers(), id_type, moab::Range::insert(), maxNumSetChildren, maxNumSetContents, maxNumSetParents, MB_SUCCESS, mhdf_writeSetDataWithOpt(), mhdf_writeSetParentsChildrenWithOpt(), moab::WriteUtilIface::PARENTS, moab::DebugOutput::print(), moab::WriteHDF5::ExportSet::range, range_to_blocked_list(), moab::IODebugTrack::record_io(), setChildrenOffset, setContentsOffset, setParentsOffset, setSet, specialSets, vector_to_id_list(), writeProp, and writeUtil.
Referenced by write_sets().
    // ranged must be non-null for CONTENTS and null for anything else
    assert( ( which_data == WriteUtilIface::CONTENTS ) == ( 0 != ranged ) );
    ErrorCode rval;
    mhdf_Status status;
    debug_barrier();
    // Function pointer type used to write set data
    void ( *write_func )( hid_t, long, long, hid_t, const void*, hid_t, mhdf_Status* );
    long max_vals;  // Max over all procs of number of values to write to data set
    long offset;    // Offset in HDF5 dataset at which to write next block of data
    switch( which_data )
        case WriteUtilIface::CONTENTS:
            assert( ranged != 0 && null_stripped != 0 && set_sizes != 0 );
            write_func = &mhdf_writeSetDataWithOpt;
            max_vals   = maxNumSetContents;
            offset     = setContentsOffset;
            dbgOut.print( 2, "Writing set contents\n" );
            break;
        case WriteUtilIface::CHILDREN:
            assert( !ranged && !null_stripped && !set_sizes );
            write_func = &mhdf_writeSetParentsChildrenWithOpt;
            max_vals   = maxNumSetChildren;
            offset     = setChildrenOffset;
            dbgOut.print( 2, "Writing set child lists\n" );
            break;
        case WriteUtilIface::PARENTS:
            max_vals   = maxNumSetParents;
            offset     = setParentsOffset;
            dbgOut.print( 2, "Writing set parent lists\n" );
            break;
        default:
            assert( false );
            return MB_FAILURE;
    // assert(max_vals > 0); // Should have skipped this function otherwise
    // buffer to use for IO
    wid_t* buffer = reinterpret_cast< wid_t* >( dataBuffer );
    // number of handles that will fit in the buffer
    const size_t buffer_size = bufferSize / sizeof( EntityHandle );
    // the total number of write calls that must be made, including no-ops for collective io
    const size_t num_total_writes = ( max_vals + buffer_size - 1 ) / buffer_size;
    std::vector< SpecialSetData >::iterator si = specialSets.begin();
    std::vector< wid_t > remaining;         // data left over from prev iteration because it didn't fit in buffer
    size_t remaining_offset           = 0;  // avoid erasing from front of 'remaining'
    const EntityHandle* remaining_ptr = 0;  // remaining for non-ranged data
    size_t remaining_count            = 0;
    const wid_t* special_rem_ptr      = 0;
    Range::const_iterator i           = setSet.range.begin(), j, rhint, nshint;
    if( ranged ) rhint = ranged->begin();
    if( null_stripped ) nshint = null_stripped->begin();
    for( size_t w = 0; w < num_total_writes; ++w )
        if( i == setSet.range.end() && !remaining.empty() && !remaining_ptr )
            // If here, then we've written everything but we need to
            // make more write calls because we're doing collective IO
            // in parallel
            ( *write_func )( handle, 0, 0, id_type, 0, writeProp, &status );
            CHK_MHDF_ERR_0( status );
            continue;
        // If we had some left-over data from a range-compacted set
        // from the last iteration, add it to the buffer now
        size_t count = 0;
        if( !remaining.empty() )
            count = remaining.size() - remaining_offset;
            if( count > buffer_size )
                memcpy( buffer, &remaining[remaining_offset], buffer_size * sizeof( wid_t ) );
                count = buffer_size;
                remaining_offset += buffer_size;
            else
                memcpy( buffer, &remaining[remaining_offset], count * sizeof( wid_t ) );
                remaining.clear();
        // If we had some left-over data from a non-range-compacted set
        else if( remaining_ptr )
            if( remaining_count > buffer_size )
                rval = vector_to_id_list( remaining_ptr, buffer, buffer_size );
                CHK_MB_ERR_0( rval );
                remaining_ptr += count;
                remaining_count -= count;
            else
                rval = vector_to_id_list( remaining_ptr, buffer, remaining_count );
                count           = remaining_count;
                remaining_ptr   = 0;
        // If we had some left-over data from a "special" (i.e. parallel shared)
        // set.
        else if( special_rem_ptr )
                memcpy( buffer, special_rem_ptr, buffer_size * sizeof( wid_t ) );
                special_rem_ptr += count;
            else
                memcpy( buffer, special_rem_ptr, remaining_count * sizeof( wid_t ) );
        // While there is both space remaining in the buffer and
        // more sets to write, append more set data to buffer.
        while( count < buffer_size && i != setSet.range.end() )
            // Special case for "special" (i.e. parallel shared) sets:
            // we already have the data in a vector, just copy it.
            if( si != specialSets.end() && si->setHandle == *i )
                std::vector< wid_t >& list = ( which_data == WriteUtilIface::CONTENTS )  ? si->contentIds
                                             : ( which_data == WriteUtilIface::PARENTS ) ? si->parentIds
        : si->childIds;
                size_t append              = list.size();
                if( count + list.size() > buffer_size )
                    append          = buffer_size - count;
                    special_rem_ptr = &list[append];
                    remaining_count = list.size() - append;
                memcpy( buffer + count, &list[0], append * sizeof( wid_t ) );
                ++i;
                ++si;
                count += append;
                continue;
            j = i;
            ++i;
            const EntityHandle* ptr;
            int len;
            unsigned char flags;
            rval = writeUtil->get_entity_list_pointers( j, i, &ptr, which_data, &len, &flags );
            if( MB_SUCCESS != rval ) return rval;
            if( which_data == WriteUtilIface::CONTENTS && !( flags & MESHSET_ORDERED ) )
                bool compacted;
                remaining.clear();
                if( len == 0 )
                    compacted = false;
                else
                    assert( !( len % 2 ) );
                    rval = range_to_blocked_list( ptr, len / 2, remaining, compacted );
                if( compacted )
                    rhint = ranged->insert( rhint, *j );
                    set_sizes->push_back( remaining.size() );
                else if( remaining.size() != (unsigned)len )
                    nshint = null_stripped->insert( nshint, *j );
                if( count + remaining.size() <= buffer_size )
                        memcpy( buffer + count, &remaining[0], sizeof( wid_t ) * remaining.size() );
                    count += remaining.size();
                    remaining.clear();
                else
                    remaining_offset = buffer_size - count;
                    memcpy( buffer + count, &remaining[0], sizeof( wid_t ) * remaining_offset );
                    count += remaining_offset;
            else
                if( count + len > buffer_size )
                    size_t append   = buffer_size - count;
                    remaining_ptr   = ptr + append;
                    remaining_count = len - append;
                    len             = append;
                rval = vector_to_id_list( ptr, buffer + count, len );
                count += len;
        // Write the buffer.
        ( *write_func )( handle, offset, count, id_type, buffer, writeProp, &status );
        offset += count;
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5::write_sets ( double *  times) [private]
Write out meshsets
Write passed set of meshsets, including parent/child relations.
Note: Must have written nodes and element connectivity so entities have assigned IDs.
Definition at line 1363 of file WriteHDF5.cpp.
References moab::IODebugTrack::all_reduce(), moab::Range::begin(), buffer, bufferSize, CHECK_OPEN_HANDLES, moab::WriteUtilIface::CHILDREN, CHK_MB_ERR_1, CHK_MHDF_ERR_0, CHK_MHDF_ERR_1, moab::WriteUtilIface::CONTENTS, dataBuffer, dbgOut, debug_barrier, debugTrack, moab::Range::end(), ErrorCode, filePtr, get_set_info(), moab::WriteHDF5::ExportSet::max_num_ents, MB_SUCCESS, mhdf_closeData(), MHDF_INDEX_TYPE, mhdf_openSetChildren(), mhdf_openSetData(), mhdf_openSetMeta(), mhdf_openSetParents(), mhdf_SET_RANGE_BIT, mhdf_writeSetMetaWithOpt(), moab::WriteHDF5::ExportSet::offset, moab::WriteUtilIface::PARENTS, moab::DebugOutput::print(), moab::DebugOutput::printf(), moab::WriteHDF5::ExportSet::range, moab::IODebugTrack::record_io(), SET_CHILD, SET_CONTENT, SET_META, SET_PARENT, setChildrenOffset, setContentsOffset, setParentsOffset, setSet, size, moab::Range::size(), specialSets, moab::CpuTimer::time_elapsed(), topState, write_set_data(), writeProp, writeSetChildren, writeSetContents, writeSetParents, and writeSets.
    mhdf_Status status;
    ErrorCode rval;
    long first_id, size;
    hid_t table;
    CpuTimer timer;
    CHECK_OPEN_HANDLES;
    /* If no sets, just return success */
    if( !writeSets ) return MB_SUCCESS;
    debug_barrier();
    dbgOut.printf( 2, "Writing %lu non-shared sets\n", (unsigned long)setSet.range.size() );
    dbgOut.print( 3, "Non-shared sets", setSet.range );
    /* Write set parents */
    if( writeSetParents )
        topState.start( "writing parent lists for local sets" );
        table = mhdf_openSetParents( filePtr, &size, &status );
        IODebugTrack track( debugTrack, "SetParents", size );
        rval = write_set_data( WriteUtilIface::PARENTS, table, track );
        topState.end( rval );
        times[SET_PARENT] = timer.time_elapsed();
        track.all_reduce();
    /* Write set children */
    if( writeSetChildren )
        topState.start( "writing child lists for local sets" );
        table = mhdf_openSetChildren( filePtr, &size, &status );
        IODebugTrack track( debugTrack, "SetChildren", size );
        rval = write_set_data( WriteUtilIface::CHILDREN, table, track );
        times[SET_CHILD] = timer.time_elapsed();
        track.all_reduce();
    /* Write set contents */
    Range ranged_sets, null_stripped_sets;
    std::vector< long > set_sizes;
    if( writeSetContents )
        topState.start( "writing content lists for local sets" );
        table = mhdf_openSetData( filePtr, &size, &status );
        IODebugTrack track( debugTrack, "SetContents", size );
        rval = write_set_data( WriteUtilIface::CONTENTS, table, track, &ranged_sets, &null_stripped_sets, &set_sizes );
        times[SET_CONTENT] = timer.time_elapsed();
        track.all_reduce();
    assert( ranged_sets.size() + null_stripped_sets.size() == set_sizes.size() );
    /* Write set description table */
    debug_barrier();
    topState.start( "writing descriptions of local sets" );
    /* Open the table */
    table = mhdf_openSetMeta( filePtr, &size, &first_id, &status );
    IODebugTrack track_meta( debugTrack, "SetMeta", size );
    /* Some debug stuff */
    debug_barrier();
    /* Counts and buffers and such */
    mhdf_index_t* const buffer     = reinterpret_cast< mhdf_index_t* >( dataBuffer );
    const size_t buffer_size       = bufferSize / ( 4 * sizeof( mhdf_index_t ) );
    const size_t num_local_writes  = ( setSet.range.size() + buffer_size - 1 ) / buffer_size;
    const size_t num_global_writes = ( setSet.max_num_ents + buffer_size - 1 ) / buffer_size;
    assert( num_local_writes <= num_global_writes );
    assert( num_global_writes > 0 );
    /* data about sets for which number of handles written is
     * not the same as the number of handles in the set
     * (range-compacted or null handles stripped out)
    Range::const_iterator i                       = setSet.range.begin();
    Range::const_iterator r                       = ranged_sets.begin();
    Range::const_iterator s                       = null_stripped_sets.begin();
    std::vector< mhdf_index_t >::const_iterator n = set_sizes.begin();
    /* We write the end index for each list, rather than the count */
    mhdf_index_t prev_contents_end = setContentsOffset - 1;
    mhdf_index_t prev_children_end = setChildrenOffset - 1;
    mhdf_index_t prev_parents_end  = setParentsOffset - 1;
    /* While there is more data to write */
    size_t offset                                    = setSet.offset;
    std::vector< SpecialSetData >::const_iterator si = specialSets.begin();
    for( size_t w = 0; w < num_local_writes; ++w )
        // Get a buffer full of data
        size_t count = 0;
            // Get set properties
            long num_ent, num_child, num_parent;
            unsigned long flags;
                flags      = si->setFlags;
                num_ent    = si->contentIds.size();
                num_child  = si->childIds.size();
                num_parent = si->parentIds.size();
                ++si;
                if( r != ranged_sets.end() && *i == *r )
                    assert( flags & mhdf_SET_RANGE_BIT );
                    ++r;
                    ++n;
                else if( s != null_stripped_sets.end() && *i == *s )
                    ++s;
                    ++n;
            else
                assert( si == specialSets.end() || si->setHandle > *i );
                rval = get_set_info( *i, num_ent, num_child, num_parent, flags );
                // Check if size is something other than num handles in set
                    num_ent = *n;
                    ++r;
                    ++n;
                    flags |= mhdf_SET_RANGE_BIT;
                    num_ent = *n;
                    ++s;
                    ++n;
            // Put data in buffer
            mhdf_index_t* local = buffer + 4 * count;
            prev_contents_end += num_ent;
            prev_children_end += num_child;
            prev_parents_end += num_parent;
            local[0] = prev_contents_end;
            local[1] = prev_children_end;
            local[2] = prev_parents_end;
            local[3] = flags;
            // Iterate
            ++count;
            ++i;
        // Write the data
        mhdf_writeSetMetaWithOpt( table, offset, count, MHDF_INDEX_TYPE, buffer, writeProp, &status );
        track_meta.record_io( offset, count );
        offset += count;
    assert( r == ranged_sets.end() );
    assert( s == null_stripped_sets.end() );
    assert( n == set_sizes.end() );
    /* If doing parallel write with collective IO, do null write
     * calls because other procs aren't done yet and write calls
     * are collective */
    for( size_t w = num_local_writes; w != num_global_writes; ++w )
        mhdf_writeSetMetaWithOpt( table, 0, 0, MHDF_INDEX_TYPE, 0, writeProp, &status );
    topState.end();
    times[SET_META] = timer.time_elapsed();
    track_meta.all_reduce();
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5::write_sparse_ids ( const TagDesc tag_data,
const Range range,
hid_t  table_handle,
size_t  table_size,
const char *  name = 0
) [private]
Write ID table for sparse tag.
Definition at line 1939 of file WriteHDF5.cpp.
References moab::IODebugTrack::all_reduce(), moab::Range::begin(), bufferSize, CHECK_OPEN_HANDLES, CHK_MB_ERR_0, CHK_MHDF_ERR_0, collectiveIO, dataBuffer, dbgOut, debugTrack, ErrorCode, id_type, moab::WriteHDF5::TagDesc::max_num_ents, MB_SUCCESS, moab::Range::merge(), mhdf_writeSparseTagEntitiesWithOpt(), moab::DebugOutput::print(), range_to_id_list(), moab::IODebugTrack::record_io(), moab::Range::size(), moab::WriteHDF5::TagDesc::sparse_offset, VALGRIND_MAKE_MEM_UNDEFINED, and writeProp.
Referenced by write_sparse_tag(), and write_var_len_tag().
    ErrorCode rval;
    mhdf_Status status;
    CHECK_OPEN_HANDLES;
    std::string tname( name ? name : "<UNKNOWN TAG?>" );
    tname += " - Ids";
    IODebugTrack track( debugTrack, tname, table_size );
    // Set up data buffer for writing IDs
    size_t chunk_size = bufferSize / sizeof( wid_t );
    wid_t* id_buffer  = (wid_t*)dataBuffer;
    // Write IDs of tagged entities.
    long remaining  = range.size();
    long offset     = tag_data.sparse_offset;
    if( tag_data.max_num_ents )
        assert( tag_data.max_num_ents >= (unsigned long)remaining );
        num_writes = ( tag_data.max_num_ents + chunk_size - 1 ) / chunk_size;
    while( remaining )
        // Write "chunk_size" blocks of data
        long count = (unsigned long)remaining > chunk_size ? chunk_size : remaining;
        remaining -= count;
        Range::const_iterator stop = iter;
        stop += count;
        Range tmp;
        tmp.merge( iter, stop );
        iter = stop;
        assert( tmp.size() == (unsigned)count );
        rval = range_to_id_list( tmp, id_buffer );
        // Write the data
        dbgOut.print( 3, " writing sparse tag entity chunk.\n" );
        mhdf_writeSparseTagEntitiesWithOpt( id_table, offset, count, id_type, id_buffer, writeProp, &status );
        offset += count;
        --num_writes;
    }  // while (remaining)
    if( collectiveIO )
        while( num_writes-- )
            dbgOut.print( 3, " writing empty sparse tag entity chunk.\n" );
            mhdf_writeSparseTagEntitiesWithOpt( id_table, offset, 0, id_type, 0, writeProp, &status );
    track.all_reduce();
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5::write_sparse_tag ( const TagDesc tag_data,
DataType  tag_data_type,
hid_t  hdf5_data_type,
int  hdf5_type_size
) [private]
Write fixed-length tag data in sparse format.
Definition at line 2012 of file WriteHDF5.cpp.
References moab::IODebugTrack::all_reduce(), CHECK_OPEN_HANDLES, CHK_MB_ERR_0, CHK_MB_ERR_2, CHK_MHDF_ERR_0, CHK_MHDF_ERR_1, debugTrack, ErrorCode, filePtr, get_sparse_tagged_entities(), moab::WriteHDF5::TagDesc::max_num_ents, MB_SUCCESS, mhdf_closeData(), mhdf_openSparseTagData(), moab::Range::size(), moab::WriteHDF5::TagDesc::sparse_offset, subState, moab::WriteHDF5::TagDesc::tag_id, write_sparse_ids(), and write_tag_values().
    ErrorCode rval;
    mhdf_Status status;
    hid_t tables[3];
    long table_size, data_size;
    CHECK_OPEN_HANDLES;
    // Get entities for which to write tag values
    Range range;
    rval = get_sparse_tagged_entities( tag_data, range );
    mhdf_openSparseTagData( filePtr, name.c_str(), &table_size, &data_size, tables, &status );
    assert( range.size() + tag_data.sparse_offset <= (unsigned long)table_size );
    // Fixed-length tag
    assert( table_size == data_size );
    // Write IDs for tagged entities
    subState.start( "writing sparse ids for tag: ", name.c_str() );
    rval = write_sparse_ids( tag_data, range, tables[0], table_size, name.c_str() );
    subState.end( rval );
    CHK_MB_ERR_2( rval, tables, status );
    mhdf_closeData( filePtr, tables[0], &status );
    CHK_MHDF_ERR_1( status, tables[1] );
    // Set up data buffer for writing tag values
    IODebugTrack track( debugTrack, name + " Data", data_size );
    subState.start( "writing sparse values for tag: ", name.c_str() );
    rval = write_tag_values( tag_data.tag_id, tables[1], tag_data.sparse_offset, range, mb_data_type, value_type,
                             value_type_size, tag_data.max_num_ents, track );
    mhdf_closeData( filePtr, tables[1], &status );
    track.all_reduce();
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5::write_tag ( const TagDesc tag_data,
double *  times
) [private]
Write tag for all entities.
Write tag information and data.
Note: Must have already written nodes, elem connectivity and sets so that entities have IDs assigned.
Definition at line 1888 of file WriteHDF5.cpp.
References CHECK_OPEN_HANDLES, dbgOut, debug_barrier, moab::WriteHDF5::TagDesc::dense_list, DENSE_TAG_TIME, moab::error(), ErrorCode, find(), get_tag_size(), iFace, MB_SUCCESS, MB_TYPE_BIT, MB_VARIABLE_LENGTH, moab::DebugOutput::printf(), SPARSE_TAG_TIME, subState, moab::Interface::tag_get_name(), moab::WriteHDF5::TagDesc::tag_id, moab::CpuTimer::time_elapsed(), moab::DebugOutput::tprintf(), VARLEN_TAG_TIME, write_dense_tag(), moab::WriteHDF5::TagDesc::write_sparse, write_sparse_tag(), and write_var_len_tag().
Referenced by write_file_impl().
    std::string name;
    ErrorCode rval = iFace->tag_get_name( tag_data.tag_id, name );
    if( MB_SUCCESS != rval ) return error( rval );
    CHECK_OPEN_HANDLES;
    debug_barrier();
    dbgOut.tprintf( 1, "Writing tag: \"%s\"\n", name.c_str() );
    int moab_size, elem_size, array_len;
    DataType moab_type;
    mhdf_TagDataType mhdf_type;
    hid_t hdf5_type;
    rval = get_tag_size( tag_data.tag_id, moab_type, moab_size, elem_size, array_len, mhdf_type, hdf5_type );
    CpuTimer timer;
    if( array_len == MB_VARIABLE_LENGTH && tag_data.write_sparse )
        dbgOut.printf( 2, "Writing sparse data for var-len tag: \"%s\"\n", name.c_str() );
        rval = write_var_len_tag( tag_data, name, moab_type, hdf5_type, elem_size );
        times[VARLEN_TAG_TIME] += timer.time_elapsed();
    else
        int data_len = elem_size;
        if( moab_type != MB_TYPE_BIT ) data_len *= array_len;
        if( tag_data.write_sparse )
            dbgOut.printf( 2, "Writing sparse data for tag: \"%s\"\n", name.c_str() );
            rval = write_sparse_tag( tag_data, name, moab_type, hdf5_type, data_len );
            times[SPARSE_TAG_TIME] += timer.time_elapsed();
        for( size_t i = 0; MB_SUCCESS == rval && i < tag_data.dense_list.size(); ++i )
            const ExportSet* set = find( tag_data.dense_list[i] );
            assert( 0 != set );
            debug_barrier();
            dbgOut.printf( 2, "Writing dense data for tag: \"%s\" on group \"%s\"\n", name.c_str(), set->name() );
            subState.start( "writing dense data for tag: ", ( name + ":" + set->name() ).c_str() );
            rval = write_dense_tag( tag_data, *set, name, moab_type, hdf5_type, data_len );
        times[DENSE_TAG_TIME] += timer.time_elapsed();
    H5Tclose( hdf5_type );
    return MB_SUCCESS == rval ? MB_SUCCESS : error( rval );
ErrorCode moab::WriteHDF5::write_tag_values ( Tag  tag_id,
hid_t  data_table,
unsigned long  data_offset,
const Range range,
int  hdf5_type_size,
unsigned long  max_num_ents,
IODebugTrack debug_track
) [private]
Write data for fixed-size tag.
Definition at line 2321 of file WriteHDF5.cpp.
References moab::IODebugTrack::all_reduce(), moab::Range::begin(), bufferSize, CHECK_OPEN_HANDLES, CHK_MB_ERR_0, CHK_MHDF_ERR_0, collectiveIO, convert_handle_tag(), dataBuffer, dbgOut, ErrorCode, iFace, MB_SUCCESS, MB_TYPE_HANDLE, moab::Range::merge(), mhdf_writeTagValuesWithOpt(), moab::DebugOutput::print(), moab::IODebugTrack::record_io(), moab::Range::size(), moab::Interface::tag_get_data(), VALGRIND_MAKE_MEM_UNDEFINED, and writeProp.
Referenced by write_dense_tag(), and write_sparse_tag().
    mhdf_Status status;
    CHECK_OPEN_HANDLES;
    size_t chunk_size = bufferSize / value_type_size;
    assert( chunk_size > 0 );
    char* tag_buffer = (char*)dataBuffer;
    // Write the tag values
    size_t remaining           = range_in.size();
    size_t offset              = offset_in;
    Range::const_iterator iter = range_in.begin();
    if( max_num_ents )
        assert( max_num_ents >= remaining );
        num_writes = ( max_num_ents + chunk_size - 1 ) / chunk_size;
    while( remaining )
        remaining -= count;
        memset( tag_buffer, 0, count * value_type_size );
        stop += count;
        Range range;
        range.merge( iter, stop );
        iter = stop;
        assert( range.size() == (unsigned)count );
        ErrorCode rval = iFace->tag_get_data( tag_id, range, tag_buffer );
        // Convert EntityHandles to file ids
        if( mb_data_type == MB_TYPE_HANDLE )
            convert_handle_tag( reinterpret_cast< EntityHandle* >( tag_buffer ),
                                count * value_type_size / sizeof( EntityHandle ) );
        // Write the data
        dbgOut.print( 2, " writing tag value chunk.\n" );
        assert( value_type > 0 );
        mhdf_writeTagValuesWithOpt( data_table, offset, count, value_type, tag_buffer, writeProp, &status );
        offset += count;
        --num_writes;
    if( collectiveIO )
            dbgOut.print( 2, " writing empty tag value chunk.\n" );
            mhdf_writeTagValuesWithOpt( data_table, offset, 0, value_type, 0, writeProp, &status );
    track.all_reduce();
    return MB_SUCCESS;
Definition at line 204 of file WriteHDF5.hpp.
References writeUtil.
        return writeUtil;
ErrorCode moab::WriteHDF5::write_var_len_data ( const TagDesc tag_data,
const Range range,
hid_t  table,
size_t  table_size,
bool  handle_tag,
hid_t  hdf_type,
int  type_size,
) [private]
Write tag value data_set for a variable-length tag.
Definition at line 2141 of file WriteHDF5.cpp.
References moab::IODebugTrack::all_reduce(), moab::Range::begin(), buffer, bufferSize, CHECK_OPEN_HANDLES, CHK_MB_ERR_0, CHK_MHDF_ERR_0, collectiveIO, convert_handle_tag(), dataBuffer, dbgOut, debugTrack, moab::Range::end(), ErrorCode, iFace, moab::WriteHDF5::TagDesc::max_num_vals, MB_SUCCESS, mhdf_writeTagValuesWithOpt(), moab::DebugOutput::print(), moab::IODebugTrack::record_io(), moab::Interface::tag_get_by_ptr(), moab::WriteHDF5::TagDesc::tag_id, moab::WriteHDF5::TagDesc::var_data_offset, and writeProp.
Referenced by write_var_len_tag().
    ErrorCode rval;
    mhdf_Status status;
    CHECK_OPEN_HANDLES;
    assert( !handle_tag || sizeof( EntityHandle ) == type_size );
    tname += " - Values";
    const size_t buffer_size = bufferSize / type_size;
    size_t num_writes = ( table_size + buffer_size - 1 ) / buffer_size;
    if( collectiveIO )
        assert( tag_data.max_num_vals > 0 );
        num_writes = ( tag_data.max_num_vals + buffer_size - 1 ) / buffer_size;
    unsigned char* buffer      = (unsigned char*)dataBuffer;
    const void* prev_data      = 0;  // Data left over from prev iteration
    size_t prev_len            = 0;
    Range::const_iterator iter = range.begin();
    long offset                = tag_data.var_data_offset;
    while( prev_data || iter != range.end() )
        size_t count = 0;
        if( prev_data )
            size_t len;
            const void* ptr = prev_data;
            if( prev_len <= buffer_size )
                len       = prev_len;
                prev_data = 0;
                prev_len  = 0;
            else
                len       = buffer_size;
                prev_data = ( (const char*)prev_data ) + buffer_size * type_size;
                prev_len -= buffer_size;
            if( handle_tag )
                convert_handle_tag( (const EntityHandle*)ptr, (EntityHandle*)buffer, len );
            else
                memcpy( buffer, ptr, len * type_size );
            count = len;
        for( ; count < buffer_size && iter != range.end(); ++iter )
            int len;
            const void* ptr;
            rval = iFace->tag_get_by_ptr( tag_data.tag_id, &*iter, 1, &ptr, &len );
            if( len + count > buffer_size )
                prev_len  = len + count - buffer_size;
                len       = buffer_size - count;
                prev_data = ( (const char*)ptr ) + len * type_size;
            if( handle_tag )
                convert_handle_tag( (const EntityHandle*)ptr, ( (EntityHandle*)buffer ) + count, len );
            else
                memcpy( buffer + count * type_size, ptr, len * type_size );
            count += len;
        mhdf_writeTagValuesWithOpt( table, offset, count, hdf_type, buffer, writeProp, &status );
        offset += count;
        --num_writes;
    if( collectiveIO )
            dbgOut.print( 3, " writing empty var-len tag data chunk.\n" );
            mhdf_writeTagValuesWithOpt( table, 0, 0, hdf_type, 0, writeProp, &status );
    track.all_reduce();
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5::write_var_len_indices ( const TagDesc tag_data,
const Range range,
hid_t  idx_table,
size_t  table_size,
int  type_size,
) [private]
Write end index data_set for a variable-length tag.
Definition at line 2058 of file WriteHDF5.cpp.
References moab::IODebugTrack::all_reduce(), moab::Range::begin(), bufferSize, CHECK_OPEN_HANDLES, CHK_MB_ERR_0, CHK_MHDF_ERR_0, collectiveIO, dataBuffer, dbgOut, debugTrack, ErrorCode, id_type, iFace, moab::WriteHDF5::TagDesc::max_num_ents, MB_SUCCESS, moab::Range::merge(), MHDF_INDEX_TYPE, mhdf_writeSparseTagIndicesWithOpt(), moab::DebugOutput::print(), moab::IODebugTrack::record_io(), moab::Range::size(), moab::WriteHDF5::TagDesc::sparse_offset, moab::Interface::tag_get_by_ptr(), moab::WriteHDF5::TagDesc::tag_id, VALGRIND_MAKE_MEM_UNDEFINED, moab::WriteHDF5::TagDesc::var_data_offset, and writeProp.
    ErrorCode rval;
    mhdf_Status status;
    CHECK_OPEN_HANDLES;
    tname += " - End Indices";
    // Set up data buffer for writing indices
    size_t chunk_size        = bufferSize / ( std::max( sizeof( void* ), sizeof( long ) ) + sizeof( int ) );
    mhdf_index_t* idx_buffer = (mhdf_index_t*)dataBuffer;
    const void** junk        = (const void**)dataBuffer;
    int* size_buffer         = (int*)( dataBuffer + chunk_size * std::max( sizeof( void* ), sizeof( mhdf_index_t ) ) );
    long data_offset  = tag_data.var_data_offset - 1;  // Offset at which to write data buffer
    size_t remaining  = range.size();
    size_t offset     = tag_data.sparse_offset;
    size_t num_writes = ( remaining + chunk_size - 1 ) / chunk_size;
    while( remaining )
        size_t count = remaining > chunk_size ? chunk_size : remaining;
        remaining -= count;
        stop += count;
        Range tmp;
        iter = stop;
        rval = iFace->tag_get_by_ptr( tag_data.tag_id, tmp, junk, size_buffer );
        // Calculate end indices
        dbgOut.print( 3, " writing var-len tag offset chunk.\n" );
        for( size_t i = 0; i < count; ++i )
            data_offset += size_buffer[i];
            idx_buffer[i] = data_offset;
        // Write
        mhdf_writeSparseTagIndicesWithOpt( idx_table, offset, count, MHDF_INDEX_TYPE, idx_buffer, writeProp, &status );
        offset += count;
        --num_writes;
    if( collectiveIO )
            mhdf_writeSparseTagIndicesWithOpt( idx_table, offset, 0, id_type, 0, writeProp, &status );
    track.all_reduce();
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5::write_var_len_tag ( const TagDesc tag_info,
hid_t  hdf5_type,
int  hdf5_type_size
) [private]
Write varialbe-length tag data.
Definition at line 2244 of file WriteHDF5.cpp.
References CHECK_OPEN_HANDLES, CHK_MB_ERR_0, CHK_MB_ERR_1, CHK_MB_ERR_2, CHK_MHDF_ERR_0, CHK_MHDF_ERR_1, CHK_MHDF_ERR_2, ErrorCode, filePtr, get_sparse_tagged_entities(), MB_SUCCESS, MB_TYPE_HANDLE, mhdf_closeData(), mhdf_openSparseTagData(), moab::Range::size(), moab::WriteHDF5::TagDesc::sparse_offset, subState, write_sparse_ids(), write_var_len_data(), and write_var_len_indices().
    ErrorCode rval;
    mhdf_Status status;
    hid_t tables[3];
    long table_size;
    long data_table_size;
    CHECK_OPEN_HANDLES;
    Range range;
    mhdf_openSparseTagData( filePtr, name.c_str(), &table_size, &data_table_size, tables, &status );
    subState.start( "writing ids for var-len tag: ", name.c_str() );
    CHK_MHDF_ERR_2( status, tables + 1 );
    // Write offsets for tagged entities
    subState.start( "writing indices for var-len tag: ", name.c_str() );
    rval = write_var_len_indices( tag_data, range, tables[2], table_size, type_size, name.c_str() );
    CHK_MB_ERR_1( rval, tables[1], status );
    mhdf_closeData( filePtr, tables[2], &status );
    // Write the actual tag data
    subState.start( "writing values for var-len tag: ", name.c_str() );
    rval = write_var_len_data( tag_data, range, tables[1], data_table_size, mb_data_type == MB_TYPE_HANDLE, hdf_type,
    return MB_SUCCESS;
Member Data Documentation
Store old HDF5 error handling function.
Definition at line 211 of file WriteHDF5.hpp.
Referenced by init(), and write_finished().
The largest number of values to write for any processor (needed to do collective IO).
Definition at line 343 of file WriteHDF5.hpp.
Referenced by moab::WriteHDF5Parallel::create_meshset_tables(), initialize_mesh(), serial_create_file(), and write_set_data().
True if doing parallel write.
Definition at line 384 of file WriteHDF5.hpp.
Referenced by write_file(), and write_file_impl().
unsigned long moab::WriteHDF5::setChildrenOffset [protected]
Offset into set children table (zero except for parallel)
Definition at line 340 of file WriteHDF5.hpp.
Referenced by moab::WriteHDF5Parallel::create_meshset_tables(), serial_create_file(), write_set_data(), and write_sets().
unsigned long moab::WriteHDF5::setContentsOffset [protected]
Offset into set contents table (zero except for parallel)
Definition at line 338 of file WriteHDF5.hpp.
std::vector< SpecialSetData > moab::WriteHDF5::specialSets [protected]
Array of special/shared sets, in order of handle value.
Definition at line 373 of file WriteHDF5.hpp.
Referenced by moab::WriteHDF5Parallel::communicate_shared_set_data(), count_set_size(), find_set_data(), write_set_data(), and write_sets().
hid_t moab::WriteHDF5::writeProp [protected]
Property set to pass to H5Dwrite calls. For serial, should be H5P_DEFAULTS. For parallel, may request collective IO.
Definition at line 393 of file WriteHDF5.hpp.
Referenced by moab::WriteHDF5Parallel::parallel_create_file(), write_adjacencies(), write_elems(), write_file(), write_nodes(), write_set_data(), write_sets(), write_sparse_ids(), write_tag_values(), write_var_len_data(), and write_var_len_indices().
bool moab::WriteHDF5::writeSets [protected]
Flags idicating if set data should be written. For the normal (non-parallel) case, these values will depend only on whether or not there is any data to be written. For parallel-meshes, opening the data table is collective so the values must depend on whether or not any processor has meshsets to be written.
Definition at line 351 of file WriteHDF5.hpp.
Referenced by moab::WriteHDF5Parallel::create_meshset_tables(), serial_create_file(), and write_sets().
True if writing dense-formatted tag data.
Definition at line 388 of file WriteHDF5.hpp.
Referenced by moab::WriteHDF5Parallel::create_tag_tables(), serial_create_file(), and write_file().
List of all members.
