moab::WriteHDF5Parallel Class Reference
Write MOAB HDF5 file in parallel. More...
#include <WriteHDF5Parallel.hpp>
+ Inheritance diagram for moab::WriteHDF5Parallel:
+ Collaboration diagram for moab::WriteHDF5Parallel:
Classes
struct  DataSetCreator
 Argument ot create_dataset. More...
struct  NoopDescCreator
Public Member Functions
 WriteHDF5Parallel (Interface *iface)
virtual ~WriteHDF5Parallel ()
Static Public Member Functions
static WriterIfacefactory (Interface *)
Protected Member Functions
virtual void debug_barrier_line (int lineno)
virtual void print_times (const double *times) const
virtual ErrorCode parallel_create_file (const char *filename, bool overwrite, const std::vector< std::string > &qa_records, const FileOptions &opts, const Tag *user_tag_list=0, int user_tag_count=0, int dimension=3, double *times=0)
ErrorCode gather_interface_meshes (Range &non_local_ents)
ErrorCode exchange_file_ids (const Range &non_local_ents)
ErrorCode communicate_shared_set_ids (const Range &owned, const Range &remote)
 Get remote ids for shared sets.
ErrorCode pack_set (Range::const_iterator set, unsigned long *set_data, size_t set_data_length)
ErrorCode unpack_set (EntityHandle set, const unsigned long *set_data, size_t set_data_length)
 Unpack set data from communication.
ErrorCode communicate_shared_set_data (const Range &owned, const Range &remote)
ErrorCode create_node_table (int dimension)
 Create the node table in the file.
ErrorCode negotiate_type_list ()
ErrorCode create_element_tables ()
 Create tables to hold element connectivity.
ErrorCode create_adjacency_tables ()
 Create tables to hold element adjacencies.
ErrorCode create_meshset_tables (double *times)
 Create tables for mesh sets.
ErrorCode create_tag_tables ()
 Write tag descriptions and create tables to hold tag data.
void remove_remote_entities (EntityHandle relative, Range &range)
 Remove any remote mesh entities from the passed range.
void remove_remote_entities (EntityHandle relative, std::vector< EntityHandle > &vect)
void remove_remote_sets (EntityHandle relative, Range &range)
void remove_remote_sets (EntityHandle relative, std::vector< EntityHandle > &vect)
ErrorCode get_sharedset_tags ()
 get any existing tags which aren't excluded and add to shared set tags
ErrorCode append_serial_tag_data (std::vector< unsigned char > &buffer, const WriteHDF5::TagDesc &tag)
ErrorCode check_serial_tag_data (const std::vector< unsigned char > &buffer, std::vector< TagDesc * > *missing=0, std::vector< TagDesc * > *newlist=0)
 helper function for create_tag_tables
ErrorCode create_dataset (int num_datasets, const long *num_owned_entities, long *offsets_out, long *max_proc_ents_out, long *total_ents_out, const DataSetCreator &creator=NoopDescCreator(), ExportSet *groups[]=0, wid_t *first_ids_out=NULL)
 Do typical communication for dataset creation.
void print_shared_sets ()
void print_set_sharing_data (const Range &range, const char *label, Tag idt)
Private Attributes
ParallelCommmyPcomm
 pcomm controlling parallel nature of mesh
bool pcommAllocated
 whether this instance allocated (and dtor should delete) the pcomm
H5S_seloper_t hslabOp
 Operation to use to append hyperslab selections.
Detailed Description
Author:
Jason Kraftcheck 22 July 2004
Definition at line 20 of file WriteHDF5Parallel.hpp.
Consturctor
Definition at line 279 of file WriteHDF5Parallel.cpp.
Referenced by factory().
    : WriteHDF5( iface ), myPcomm( NULL ), pcommAllocated( false ), hslabOp( H5S_SELECT_OR )
Definition at line 284 of file WriteHDF5Parallel.cpp.
References myPcomm, and pcommAllocated.
    if( pcommAllocated && myPcomm ) delete myPcomm;
Member Function Documentation
ErrorCode moab::WriteHDF5Parallel::append_serial_tag_data ( std::vector< unsigned char > &  buffer,
const WriteHDF5::TagDesc tag
) [protected]
Definition at line 582 of file WriteHDF5Parallel.cpp.
References moab::serial_tag_data::def_val_len, moab::error(), ErrorCode, moab::WriteHDF5::iFace, moab::serial_tag_data::len(), MB_SUCCESS, MB_VARIABLE_DATA_LENGTH, MB_VARIABLE_LENGTH, moab::serial_tag_data::name, moab::serial_tag_data::name_len, moab::serial_tag_data::set_default_value(), moab::serial_tag_data::size, moab::serial_tag_data::storage, moab::Interface::tag_get_data_type(), moab::Interface::tag_get_default_value(), moab::Interface::tag_get_length(), moab::Interface::tag_get_name(), moab::Interface::tag_get_type(), moab::WriteHDF5::TagDesc::tag_id, and moab::serial_tag_data::type.
Referenced by create_tag_tables().
    ErrorCode rval;
    std::string name;
    rval = iFace->tag_get_name( tag.tag_id, name );
    if( MB_SUCCESS != rval ) return error( rval );
    // Get name length, including space for null char
    size_t name_len = name.size() + 1;
    if( name_len == 1 ) return MB_SUCCESS;  // Skip tags with no name
    DataType data_type;
    rval = iFace->tag_get_data_type( tag.tag_id, data_type );
    // Get default value
    int def_val_len;
    const void* def_val;
    if( MB_SUCCESS != iFace->tag_get_default_value( tag.tag_id, def_val, def_val_len ) )
        def_val_len = 0;
        def_val     = 0;
    // Allocate struct within buffer
    size_t init_size = buffer.size();
    buffer.resize( init_size + serial_tag_data::len( name_len, def_val_len, data_type ) );
    serial_tag_data* ptr = reinterpret_cast< serial_tag_data* >( &buffer[init_size] );
    // Populate struct
    rval = iFace->tag_get_type( tag.tag_id, ptr->storage );
    ptr->type = data_type;
    rval      = iFace->tag_get_length( tag.tag_id, ptr->size );
    if( MB_VARIABLE_DATA_LENGTH == rval )
        ptr->size = MB_VARIABLE_LENGTH;
    else if( MB_SUCCESS != rval )
    ptr->name_len = name_len;
    Range range;
    memset( ptr->name, 0, ptr->name_len );
    memcpy( ptr->name, name.data(), name.size() );
    ptr->def_val_len = def_val_len;
    ptr->set_default_value( def_val );
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5Parallel::check_serial_tag_data ( const std::vector< unsigned char > &  buffer,
std::vector< TagDesc * > *  missing = 0,
std::vector< TagDesc * > *  newlist = 0
) [protected]
Definition at line 632 of file WriteHDF5Parallel.cpp.
References moab::serial_tag_data::def_val_len, moab::serial_tag_data::default_value(), moab::error(), ErrorCode, moab::WriteHDF5::iFace, moab::serial_tag_data::len(), moab::WriteHDF5::TagDesc::max_num_ents, moab::WriteHDF5::TagDesc::max_num_vals, MB_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_VARLEN, MB_VARIABLE_LENGTH, moab::serial_tag_data::name, size, moab::serial_tag_data::size, moab::WriteHDF5::TagDesc::sparse_offset, moab::serial_tag_data::storage, moab::Interface::tag_get_data_type(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_get_name(), moab::WriteHDF5::TagDesc::tag_id, moab::WriteHDF5::tagList, moab::serial_tag_data::type, moab::WriteHDF5::TagDesc::var_data_offset, and moab::WriteHDF5::TagDesc::write_sparse.
    ErrorCode rval;
    // Use 'write_sparse' field as a 'visited' mark
    std::list< TagDesc >::iterator tag_iter;
    if( missing )
        for( tag_iter = tagList.begin(); tag_iter != tagList.end(); ++tag_iter )
            tag_iter->write_sparse = true;
    // Use a set as a temporary for what will ultimately go in
    // newlist because we need to pass back newlist in the order
    // of the tagList member.
    std::set< TagDesc* > newset;
    // Iterate over data from, updating the local list of tags.
    // Be careful to keep tagList sorted such that in the end all
    // procs have the same list in the same order.
    std::vector< unsigned char >::const_iterator diter = buffer.begin();
    while( diter < buffer.end() )
        // Get struct from buffer
        const serial_tag_data* ptr = reinterpret_cast< const serial_tag_data* >( &*diter );
        // Find local struct for tag
        std::string name( ptr->name );
        std::string n;
        iFace->tag_get_name( tag_iter->tag_id, n );  // Second time we've called, so shouldn't fail
        if( n > name )
            tag_iter = tagList.begin();  // New proc, start search from beginning
        while( n < name )
            ++tag_iter;
            if( tag_iter == tagList.end() ) break;
        if( tag_iter == tagList.end() || n != name )
        {  // New tag
            TagDesc newtag;
            if( ptr->size == MB_VARIABLE_LENGTH )
                rval = iFace->tag_get_handle( name.c_str(), ptr->def_val_len, ptr->type, newtag.tag_id,
                                              MB_TAG_VARLEN | MB_TAG_CREAT | ptr->storage, ptr->default_value() );
            else
                rval = iFace->tag_get_handle( name.c_str(), ptr->size, ptr->type, newtag.tag_id,
            newtag.sparse_offset   = 0;
            newtag.var_data_offset = 0;
            newtag.write_sparse    = false;
            newtag.max_num_ents    = 0;
            newtag.max_num_vals    = 0;
            tag_iter = tagList.insert( tag_iter, newtag );
            if( newlist ) newset.insert( &*tag_iter );
        else
        {  // Check that tag is as expected
            DataType type;
            iFace->tag_get_data_type( tag_iter->tag_id, type );
            if( type != ptr->type )
                MB_SET_ERR( MB_FAILURE, "Processes have inconsistent data type for tag \"" << name << "\"" );
            int size;
            iFace->tag_get_length( tag_iter->tag_id, size );
            if( size != ptr->size )
                MB_SET_ERR( MB_FAILURE, "Processes have inconsistent size for tag \"" << name << "\"" );
            tag_iter->write_sparse = false;
        // Step to next variable-length struct.
        diter += ptr->len();
    // Now pass back any local tags that weren't in the buffer
    if( missing )
            if( tag_iter->write_sparse )
                missing->push_back( &*tag_iter );
    // Be careful to populate newlist in the same, sorted, order as tagList
    if( newlist )
            if( newset.find( &*tag_iter ) != newset.end() ) newlist->push_back( &*tag_iter );
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5Parallel::communicate_shared_set_data ( const Range owned,
const Range remote
) [protected]
Communicate set contents between processors such that each owner knows the contents, parents, & child lists from all processors that have a copy of the set.
Definition at line 1860 of file WriteHDF5Parallel.cpp.
References moab::Range::begin(), CHECK_MB, CHECK_MPI, moab::CREATE_HANDLE(), moab::WriteHDF5::dbgOut, moab::Range::end(), ErrorCode, moab::Interface::get_child_meshsets(), moab::Interface::get_entities_by_handle(), moab::ParallelComm::get_entityset_owner(), moab::ParallelComm::get_entityset_procs(), moab::Interface::get_meshset_options(), moab::Interface::get_parent_meshsets(), moab::ID_FROM_HANDLE(), moab::WriteHDF5::iFace, MB_SUCCESS, MBENTITYSET, moab::Range::merge(), mhdf_SET_RANGE_BIT, myPcomm, pack_set(), moab::DebugOutput::printf(), moab::ProcConfig::proc_comm(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::WriteHDF5::range_to_blocked_list(), rank, moab::WriteHDF5::SpecialSetData::setFlags, moab::WriteHDF5::SpecialSetData::setHandle, size, moab::Range::size(), moab::WriteHDF5::specialSets, moab::DebugOutput::tprintf(), unpack_set(), and moab::WriteHDF5::vector_to_id_list().
Referenced by create_meshset_tables().
    ErrorCode rval;
    int mperr;
    const unsigned rank = myPcomm->proc_config().proc_rank();
    const MPI_Comm comm = myPcomm->proc_config().proc_comm();
    dbgOut.tprintf( 1, "COMMUNICATING SHARED SET DATA (%lu owned & %lu remote)\n", (unsigned long)owned.size(),
                    (unsigned long)remote.size() );
    // Calculate the total number of messages to be in transit (send and receive)
    size_t nummess = 0;
    std::vector< unsigned > procs;
    Range shared( owned );
    shared.merge( remote );
    for( Range::iterator i = shared.begin(); i != shared.end(); ++i )
        procs.clear();
        rval = myPcomm->get_entityset_procs( *i, procs );
        CHECK_MB( rval );
        nummess += procs.size();
    // Choose a receive buffer size. We need 4*sizeof(long) minimum,
    // but that is almost useless so use 16*sizeof(long) as the minimum
    // instead. Choose an upper limit such that we don't exceed 32 MB
    // of allocated memory (unless we absolutely must to meet the minimum.)
    // Also, don't initially choose buffers larger than 128*sizeof(long).
    const size_t MAX_BUFFER_MEM = 32 * 1024 * 1024 / sizeof( long );
    // const size_t INIT_BUFFER_SIZE = 128;
    const size_t INIT_BUFFER_SIZE = 1024;
    const size_t MIN_BUFFER_SIZE  = 16;
    size_t init_buff_size         = INIT_BUFFER_SIZE;
    if( init_buff_size * nummess > MAX_BUFFER_MEM ) init_buff_size = MAX_BUFFER_MEM / nummess;
    if( init_buff_size < MIN_BUFFER_SIZE ) init_buff_size = MIN_BUFFER_SIZE;
    dbgOut.printf( 2, "Using buffer size of %lu for an expected message count of %lu\n", (unsigned long)init_buff_size,
                   (unsigned long)nummess );
    // Count number of recvs
    size_t numrecv = 0;
    for( Range::iterator i = owned.begin(); i != owned.end(); ++i )
        procs.clear();
        CHECK_MB( rval );
        numrecv += procs.size();
        if( std::find( procs.begin(), procs.end(), rank ) != procs.end() ) --numrecv;
    // Post receive buffers for all owned sets for all sharing procs
    std::vector< MPI_Request > recv_req( numrecv, MPI_REQUEST_NULL );
    std::vector< MPI_Request > lrecv_req( numrecv, MPI_REQUEST_NULL );
    std::vector< std::vector< unsigned long > > recv_buf( numrecv, std::vector< unsigned long >( init_buff_size ) );
    int idx = 0;
        procs.clear();
        CHECK_MB( rval );
        for( size_t j = 0; j < procs.size(); ++j )
            if( procs[j] == rank ) continue;
            int tag = ID_FROM_HANDLE( *i );
            if( *i != CREATE_HANDLE( MBENTITYSET, tag ) )
#ifndef NDEBUG
                abort();
#endif
                CHECK_MB( MB_FAILURE );
            dbgOut.printf( 5, "Posting buffer to receive set %d from proc %u\n", tag, procs[j] );
            mperr =
                MPI_Irecv( &recv_buf[idx][0], init_buff_size, MPI_UNSIGNED_LONG, procs[j], tag, comm, &recv_req[idx] );
            CHECK_MPI( mperr );
            ++idx;
    assert( (size_t)idx == numrecv );
    // Now send set data for all remote sets that I know about
    std::vector< MPI_Request > send_req( remote.size() );
    std::vector< std::vector< unsigned long > > send_buf( remote.size() );
    idx = 0;
    for( Range::iterator i = remote.begin(); i != remote.end(); ++i, ++idx )
        send_buf[idx].resize( init_buff_size );
        rval = pack_set( i, &send_buf[idx][0], init_buff_size );
        CHECK_MB( rval );
        EntityHandle remote_handle;
        unsigned owner;
        rval = myPcomm->get_entityset_owner( *i, owner, &remote_handle );
        CHECK_MB( rval );
        int tag = ID_FROM_HANDLE( remote_handle );
        assert( remote_handle == CREATE_HANDLE( MBENTITYSET, tag ) );
        dbgOut.printf( 5, "Sending %lu values for set %d to proc %u\n",
                       send_buf[idx][1] + send_buf[idx][2] + send_buf[idx][3] + 4, tag, owner );
        mperr = MPI_Isend( &send_buf[idx][0], init_buff_size, MPI_UNSIGNED_LONG, owner, tag, comm, &send_req[idx] );
        CHECK_MPI( mperr );
    // Tag mattag;
    // iFace->tag_get_handle(MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mattag);
    // Now initialize local data for managing contents of owned, shared sets
    assert( specialSets.empty() );
    specialSets.clear();
    specialSets.reserve( owned.size() );
        // int block;
        // if (MB_SUCCESS != iFace->tag_get_data(mattag, &*i, 1, &block))
        //  block = 0;
        // std::vector<int> ids;
        SpecialSetData data;
        data.setHandle = *i;
        rval           = iFace->get_meshset_options( *i, data.setFlags );
        CHECK_MB( rval );
        specialSets.push_back( data );
        std::vector< EntityHandle > list;
        if( data.setFlags & MESHSET_ORDERED )
            list.clear();
            rval = iFace->get_entities_by_handle( *i, list );
            CHECK_MB( rval );
            rval = vector_to_id_list( list, specialSets.back().contentIds, true );
            CHECK_MB( rval );
            // if (block)
            //  get_global_ids(iFace, &list[0], list.size(), MESHSET_ORDERED, ids);
        else
            Range range;
            rval = iFace->get_entities_by_handle( *i, range );
            CHECK_MB( rval );
            bool ranged;
            rval = range_to_blocked_list( range, specialSets.back().contentIds, ranged );
            if( ranged ) specialSets.back().setFlags |= mhdf_SET_RANGE_BIT;
            // if (block) {
            //  std::vector<EntityHandle> tmp;
            //  for (Range::const_pair_iterator pi = range.const_pair_begin(); pi !=
            //  range.const_pair_end(); ++pi) {
            //    tmp.push_back(pi->first);
            //    tmp.push_back(pi->second);
            //  get_global_ids(iFace, &tmp[0], tmp.size(), ranged ? 0 : MESHSET_ORDERED, ids);
        list.clear();
        rval = iFace->get_parent_meshsets( *i, list );
        CHECK_MB( rval );
        rval = vector_to_id_list( list, specialSets.back().parentIds, true );
        CHECK_MB( rval );
        rval = iFace->get_child_meshsets( *i, list );
        CHECK_MB( rval );
        rval = vector_to_id_list( list, specialSets.back().childIds, true );
        CHECK_MB( rval );
    // Process received buffers, repost larger buffers where necessary
    size_t remaining = numrecv;
    numrecv          = 0;
    while( remaining-- )
        std::vector< unsigned long > dead;
        MPI_Status status;
        mperr = MPI_Waitany( recv_req.size(), &recv_req[0], &idx, &status );
        CHECK_MPI( mperr );
        EntityHandle handle                = CREATE_HANDLE( MBENTITYSET, status.MPI_TAG );
        std::vector< unsigned long >& buff = recv_buf[idx];
        size_t size                        = buff[1] + buff[2] + buff[3] + 4;
        dbgOut.printf( 5, "Received %lu values for set %d from proc %d\n", (unsigned long)size, status.MPI_TAG,
                       status.MPI_SOURCE );
        if( size <= init_buff_size )
            rval = unpack_set( handle, &buff[0], init_buff_size );
            CHECK_MB( rval );
            dead.swap( buff );  // Release memory
        else
            // Data was too big for init_buff_size
            // repost with larger buffer
            buff.resize( size );
            dbgOut.printf( 5, "Re-Posting buffer to receive set %d from proc %d with size %lu\n", status.MPI_TAG,
                           status.MPI_SOURCE, (unsigned long)size );
            mperr = MPI_Irecv( &buff[0], size, MPI_UNSIGNED_LONG, status.MPI_SOURCE, status.MPI_TAG, comm,
                               &lrecv_req[idx] );
            CHECK_MPI( mperr );
            ++numrecv;
        recv_req[idx] = MPI_REQUEST_NULL;
    // Wait for sends to complete
    MPI_Waitall( send_req.size(), &send_req[0], MPI_STATUSES_IGNORE );
    // Re-send sets that didn't fit initial buffer size
    idx = 0;
        std::vector< unsigned long >& buff = send_buf[idx];
        if( size <= init_buff_size ) continue;
        rval = pack_set( i, &buff[0], size );
        CHECK_MB( rval );
        unsigned owner;
        CHECK_MB( rval );
        dbgOut.printf( 5, "Sending %lu values for set %d to proc %u\n", (unsigned long)size, tag, owner );
        mperr = MPI_Isend( &buff[0], size, MPI_UNSIGNED_LONG, owner, tag, comm, &send_req[idx] );
        CHECK_MPI( mperr );
        MPI_Status status;
        mperr = MPI_Waitany( lrecv_req.size(), &lrecv_req[0], &idx, &status );
        CHECK_MPI( mperr );
        dbgOut.printf( 5, "Received %lu values for set %d from proc %d\n", 4 + buff[1] + buff[2] + buff[3],
                       status.MPI_TAG, status.MPI_SOURCE );
        rval = unpack_set( handle, &buff[0], buff.size() );
        CHECK_MB( rval );
        lrecv_req[idx] = MPI_REQUEST_NULL;
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5Parallel::communicate_shared_set_ids ( const Range owned,
const Range remote
) [protected]
Definition at line 1511 of file WriteHDF5Parallel.cpp.
References moab::Range::begin(), CHECK_MB, CHECK_MPI, moab::WriteHDF5::dbgOut, moab::Range::end(), moab::error(), ErrorCode, moab::RangeMap< KeyType, ValType, NullVal >::find(), moab::WriteHDF5::find(), moab::ParallelComm::get_entityset_local_handle(), moab::ParallelComm::get_entityset_owner(), moab::ParallelComm::get_entityset_owners(), moab::ParallelComm::get_entityset_procs(), moab::ParallelComm::get_owned_sets(), moab::DebugOutput::get_verbosity(), moab::WriteHDF5::idMap, moab::RangeMap< KeyType, ValType, NullVal >::insert(), moab::Range::insert(), moab::intersect(), MB_SUCCESS, myPcomm, moab::DebugOutput::print(), print_shared_sets(), moab::DebugOutput::printf(), moab::ProcConfig::proc_comm(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::Range::rbegin(), moab::Range::rend(), size, moab::Range::size(), moab::SSVB, and moab::DebugOutput::tprint().
    ErrorCode rval;
    int mperr;
    const int TAG = 0xD0E;
    // const unsigned rank = myPcomm->proc_config().proc_rank();
    dbgOut.tprint( 1, "COMMUNICATING SHARED SET IDS\n" );
    dbgOut.print( 6, "Owned, shared sets: ", owned );
    // Post receive buffers for all procs for which we share sets
    rval = myPcomm->get_entityset_owners( procs );
    CHECK_MB( rval );
    std::vector< unsigned >::iterator it = std::find( procs.begin(), procs.end(), myPcomm->proc_config().proc_rank() );
    if( it != procs.end() ) procs.erase( it );
    std::vector< MPI_Request > recv_req( procs.size(), MPI_REQUEST_NULL );
    std::vector< std::vector< unsigned long > > recv_buf( procs.size() );
    size_t recv_count = 0;
    for( size_t i = 0; i < procs.size(); ++i )
        Range tmp;
        rval = myPcomm->get_owned_sets( procs[i], tmp );
        CHECK_MB( rval );
        size_t count =
            intersect( tmp, remote ).size();  // Necessary because we might not be writing all of the database
        if( count )
            dbgOut.printf( 6, "Sets owned by proc %u (remote handles): ", procs[i] );
            if( dbgOut.get_verbosity() >= 6 )
                Range remote_handles;
                tmp = intersect( tmp, remote );
                for( Range::iterator j = tmp.begin(); j != tmp.end(); ++j )
                    unsigned r;
                    EntityHandle h;
                    myPcomm->get_entityset_owner( *j, r, &h );
                    assert( r == procs[i] );
                    remote_handles.insert( h );
                dbgOut.print( 6, remote_handles );
            recv_count++;
            recv_buf[i].resize( 2 * count + 1 );
            dbgOut.printf( 5, "Posting receive buffer of size %lu for proc %u (%lu of %lu owned sets)\n",
                           (unsigned long)recv_buf[i].size(), procs[i], count, tmp.size() );
            mperr =
                MPI_Irecv( &recv_buf[i][0], recv_buf[i].size(), MPI_UNSIGNED_LONG, procs[i], TAG, comm, &recv_req[i] );
            CHECK_MPI( mperr );
    // Send set ids to all procs with which we share them
    // First build per-process lists of sets for which we need to send data
    std::map< unsigned, Range > send_sets;
    std::vector< unsigned > set_procs;
    for( Range::reverse_iterator i = owned.rbegin(); i != owned.rend(); ++i )
        set_procs.clear();
        rval = myPcomm->get_entityset_procs( *i, set_procs );
        CHECK_MB( rval );
        for( size_t j = 0; j < set_procs.size(); ++j )
            if( set_procs[j] != myPcomm->proc_config().proc_rank() ) send_sets[set_procs[j]].insert( *i );
    assert( send_sets.find( myPcomm->proc_config().proc_rank() ) == send_sets.end() );
    // Now send the data
    std::vector< std::vector< unsigned long > > send_buf( send_sets.size() );
    std::vector< MPI_Request > send_req( send_sets.size() );
    std::map< unsigned, Range >::iterator si = send_sets.begin();
    for( size_t i = 0; si != send_sets.end(); ++si, ++i )
        dbgOut.printf( 6, "Sending data for shared sets to proc %u: ", si->first );
        dbgOut.print( 6, si->second );
        send_buf[i].reserve( 2 * si->second.size() + 1 );
        send_buf[i].push_back( si->second.size() );
        for( Range::iterator j = si->second.begin(); j != si->second.end(); ++j )
            send_buf[i].push_back( *j );
            send_buf[i].push_back( idMap.find( *j ) );
        dbgOut.printf( 5, "Sending buffer of size %lu to proc %u (%lu of %lu owned sets)\n",
                       (unsigned long)send_buf[i].size(), si->first, si->second.size(), owned.size() );
        mperr = MPI_Isend( &send_buf[i][0], send_buf[i].size(), MPI_UNSIGNED_LONG, si->first, TAG, comm, &send_req[i] );
    // Process received data
    MPI_Status status;
    int idx;
    while( recv_count-- )
        CHECK_MPI( mperr );
        assert( (unsigned)status.MPI_SOURCE == procs[idx] );
        assert( 2 * recv_buf[idx].front() + 1 == recv_buf[idx].size() );
        const size_t n = std::min< size_t >( recv_buf[idx].front(), ( recv_buf[idx].size() - 1 ) / 2 );
        dbgOut.printf( 5, "Received buffer of size %lu from proc %d\n", (unsigned long)( 2 * n + 1 ),
                       (int)status.MPI_SOURCE );
        for( size_t i = 0; i < n; ++i )
            EntityHandle handle = 0;
            rval                = myPcomm->get_entityset_local_handle( procs[idx], recv_buf[idx][2 * i + 1], handle );
            CHECK_MB( rval );
            assert( handle != 0 );
            if( !idMap.insert( handle, recv_buf[idx][2 * i + 2], 1 ).second )
                error( MB_FAILURE );  // Conflicting IDs??????
    assert( MPI_SUCCESS == MPI_Waitany( recv_req.size(), &recv_req[0], &idx, &status ) &&
            MPI_UNDEFINED == idx );  // Check that we got them all
    // Wait for all sends to complete before we release send
    // buffers (implicitly releases when we return from this function)
    std::vector< MPI_Status > stats( send_req.size() );
    mperr = MPI_Waitall( send_req.size(), &send_req[0], &stats[0] );
    CHECK_MPI( mperr );
    if( dbgOut.get_verbosity() >= SSVB ) print_shared_sets();
    return MB_SUCCESS;
Definition at line 1402 of file WriteHDF5Parallel.cpp.
References CHECK_HDFN, CHECK_MB, moab::WriteHDF5::count_adjacencies(), create_dataset(), ErrorCode, moab::WriteHDF5::exportList, moab::WriteHDF5::file_ptr(), MB_SUCCESS, mhdf_closeData(), mhdf_createAdjacency(), moab::WriteHDF5::ExportSet::name(), moab::WriteHDF5::nodeSet, and size.
Referenced by parallel_create_file().
    struct AdjSetCreator : public DataSetCreator
        ErrorCode operator()( WriteHDF5* file, long size, const ExportSet* ex, long& start_id ) const
            mhdf_Status status;
            hid_t handle = mhdf_createAdjacency( file->file_ptr(), ex->name(), size, &status );
            CHECK_HDFN( status );
            mhdf_closeData( file->file_ptr(), handle, &status );
            start_id = -1;
            return MB_SUCCESS;
    std::vector< ExportSet* > groups;
#ifdef WRITE_NODE_ADJACENCIES
    groups.push_back( &nodeSet );
#endif
    for( std::list< ExportSet >::iterator ex_iter = exportList.begin(); ex_iter != exportList.end(); ++ex_iter )
        groups.push_back( &*ex_iter );
    ErrorCode rval;
    const int numtypes = groups.size();
    std::vector< long > counts( numtypes );
    std::vector< long > offsets( numtypes );
    std::vector< long > max_ents( numtypes );
    std::vector< long > totals( numtypes );
    for( int i = 0; i < numtypes; ++i )
        wid_t count;
        rval = count_adjacencies( groups[i]->range, count );
        CHECK_MB( rval );
        counts[i] = count;
    rval = create_dataset( numtypes, &counts[0], &offsets[0], &max_ents[0], &totals[0], AdjSetCreator(), &groups[0] );
    CHECK_MB( rval );
    // Cppcheck warning (false positive): variable groups is assigned a value that is never used
        groups[i]->max_num_adjs = max_ents[i];
        groups[i]->adj_offset   = offsets[i];
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5Parallel::create_dataset ( int  num_datasets,
const long *  num_owned_entities,
long *  offsets_out,
long *  max_proc_ents_out,
long *  total_ents_out,
const DataSetCreator creator = NoopDescCreator(),
ExportSet groups[] = 0,
wid_t first_ids_out = NULL
) [protected]
Given the number of entities each processor intends to write, do necessary communication and create dataset on root, passing back misc info to each proc.
Parameters:
creatorFunctor to do actual dataset creation. Used only on root process.
num_datasetsThe number of datasets to create.
groupsThird argument passed to DataSetCreator. Array of length num_datasets pr NULL.
num_owned_entitiesThe number of entities this proc will write. Array of length num_datasets .
offsets_outOutput: The offset in the dataset at which this process should write. Array of length num_datasets .
max_proc_ents_outOutput: The maximun number of entities that any proc will write Array of length num_datasets .
total_ents_outOutput: The size of the created dataset (sum of counts over all procs) Array of length num_datasets .
first_ids_outOutput: The first ID of the first entity in the data set. First ID for this proc's entities is first_id_out+offset_out Array of length num_datasets or NULL.
Definition at line 1080 of file WriteHDF5Parallel.cpp.
References CHECK_MB, CHECK_MPI, ErrorCode, MB_SUCCESS, myPcomm, moab::ProcConfig::proc_comm(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), rank, and VALGRIND_CHECK_MEM_IS_DEFINED.
Referenced by create_adjacency_tables(), create_element_tables(), create_meshset_tables(), create_node_table(), and create_tag_tables().
    int result;
    ErrorCode rval;
    const unsigned nproc = myPcomm->proc_config().proc_size();
    // Gather entity counts for each processor on root
    std::vector< long > counts( rank ? 0 : nproc * num_datasets );
    (void)VALGRIND_CHECK_MEM_IS_DEFINED( &num_owned, sizeof( long ) );
    result = MPI_Gather( const_cast< long* >( num_owned ), num_datasets, MPI_LONG, &counts[0], num_datasets, MPI_LONG,
                         0, comm );
    CHECK_MPI( result );
    // Create node data in file
    DatasetVals zero_val = { 0, 0, 0 };
    std::vector< DatasetVals > cumulative( num_datasets, zero_val );
    if( rank == 0 )
        for( unsigned i = 0; i < nproc; i++ )
            const long* proc_data = &counts[i * num_datasets];
            for( int index = 0; index < num_datasets; ++index )
                cumulative[index].total += proc_data[index];
                if( proc_data[index] > cumulative[index].max_count ) cumulative[index].max_count = proc_data[index];
            if( cumulative[index].total )
                rval = creator( this, cumulative[index].total, groups ? groups[index] : 0, cumulative[index].start_id );
                CHECK_MB( rval );
            else
                cumulative[index].start_id = -1;
    // Send id offset to every proc
    result = MPI_Bcast( (void*)&cumulative[0], 3 * num_datasets, MPI_LONG, 0, comm );
        if( first_ids_out ) first_ids_out[index] = (wid_t)cumulative[index].start_id;
        max_proc_entities[index] = cumulative[index].max_count;
        total_entities[index]    = cumulative[index].total;
    // Convert array of per-process counts to per-process offsets
    if( rank == 0 )
        // Initialize prev_size with data sizes for root process
        std::vector< long > prev_size( counts.begin(), counts.begin() + num_datasets );
        // Root process gets offset zero
        std::fill( counts.begin(), counts.begin() + num_datasets, 0L );
        // For each proc other than this one (root)
        for( unsigned i = 1; i < nproc; ++i )
            // Get pointer to offsets for previous process in list
            long* prev_data = &counts[( i - 1 ) * num_datasets];
            // Get pointer to offsets for this process in list
            // For each data set
            for( int j = 0; j < num_datasets; ++j )
                // Get size of data in dataset from process i
                long mysize = proc_data[j];
                // Offset for process i is offset of previous process plus
                // number of values previous process will write
                proc_data[j] = prev_data[j] + prev_size[j];
                // Store my size, as it is no longer available in 'counts'
                prev_size[j] = mysize;
    // Send each proc it's offset in the table
    if( rank == 0 )
        (void)VALGRIND_CHECK_MEM_IS_DEFINED( &counts[0], num_datasets * nproc * sizeof( long ) );
    result = MPI_Scatter( &counts[0], num_datasets, MPI_LONG, offsets_out, num_datasets, MPI_LONG, 0, comm );
    return MB_SUCCESS;
Definition at line 1363 of file WriteHDF5Parallel.cpp.
References moab::WriteHDF5::assign_ids(), CHECK_MB, create_dataset(), moab::WriteHDF5::create_elem_table(), ErrorCode, moab::WriteHDF5::exportList, MB_SUCCESS, and size.
    struct ElemSetCreator : public DataSetCreator
            return file->create_elem_table( *ex, size, start_id );
    const int numtypes = exportList.size();
    std::vector< ExportSet* > groups( numtypes );
    std::vector< long > counts( numtypes ), offsets( numtypes ), max_ents( numtypes ), total_ents( numtypes );
    std::vector< wid_t > start_ids( numtypes );
    size_t idx = 0;
    std::list< ExportSet >::iterator ex_iter;
    for( ex_iter = exportList.begin(); ex_iter != exportList.end(); ++ex_iter, ++idx )
        groups[idx] = &*ex_iter;
        counts[idx] = ex_iter->range.size();
    ErrorCode rval = create_dataset( numtypes, &counts[0], &offsets[0], &max_ents[0], &total_ents[0], ElemSetCreator(),
                                     &groups[0], &start_ids[0] );
    CHECK_MB( rval );
    for( idx = 0, ex_iter = exportList.begin(); ex_iter != exportList.end(); ++ex_iter, ++idx )
        ex_iter->first_id       = start_ids[idx];
        ex_iter->offset         = offsets[idx];
        ex_iter->max_num_ents   = max_ents[idx];
        ex_iter->total_num_ents = total_ents[idx];
        rval                    = assign_ids( ex_iter->range, ex_iter->first_id + ex_iter->offset );
        CHECK_MB( rval );
    return MB_SUCCESS;
Definition at line 2110 of file WriteHDF5Parallel.cpp.
References moab::WriteHDF5::assign_ids(), CHECK_MB, communicate_shared_set_data(), communicate_shared_set_ids(), moab::WriteHDF5::count_set_size(), create_dataset(), moab::WriteHDF5::create_set_meta(), moab::WriteHDF5::create_set_tables(), moab::WriteHDF5::dbgOut, END_SERIAL, ErrorCode, moab::WriteHDF5::ExportSet::first_id, moab::ParallelComm::get_owned_sets(), moab::ParallelComm::get_shared_sets(), moab::WriteHDF5::iFace, moab::intersect(), moab::WriteHDF5::ExportSet::max_num_ents, moab::WriteHDF5::maxNumSetChildren, moab::WriteHDF5::maxNumSetContents, moab::WriteHDF5::maxNumSetParents, MB_SUCCESS, myPcomm, moab::WriteHDF5::ExportSet::offset, moab::print_type_sets(), moab::DebugOutput::printf(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::WriteHDF5::ExportSet::range, rank, moab::WriteHDF5::SET_OFFSET_TIME, moab::WriteHDF5::setChildrenOffset, moab::WriteHDF5::setContentsOffset, moab::WriteHDF5::setParentsOffset, moab::WriteHDF5::setSet, moab::WriteHDF5::SHARED_SET_CONTENTS, moab::WriteHDF5::SHARED_SET_IDS, size, moab::Range::size(), START_SERIAL, moab::subtract(), moab::CpuTimer::time_elapsed(), moab::WriteHDF5::ExportSet::total_num_ents, moab::WriteHDF5::writeSetChildren, moab::WriteHDF5::writeSetContents, moab::WriteHDF5::writeSetParents, and moab::WriteHDF5::writeSets.
    Range::const_iterator riter;
    START_SERIAL;
    print_type_sets( iFace, &dbgOut, setSet.range );
    END_SERIAL;
    CpuTimer timer;
    // Remove remote sets from setSets
    Range shared, owned, remote;
    ErrorCode rval = myPcomm->get_shared_sets( shared );
    CHECK_MB( rval );
    shared = intersect( shared, setSet.range );
    rval   = myPcomm->get_owned_sets( rank, owned );
    CHECK_MB( rval );
    owned        = intersect( owned, setSet.range );
    remote       = subtract( shared, owned );
    setSet.range = subtract( setSet.range, remote );
    // Create set meta table
    struct SetDescCreator : public DataSetCreator
        ErrorCode operator()( WriteHDF5* writer, long size, const ExportSet*, long& start_id ) const
            return writer->create_set_meta( size, start_id );
    long count = setSet.range.size();
    rval = create_dataset( 1, &count, &setSet.offset, &setSet.max_num_ents, &setSet.total_num_ents, SetDescCreator(),
                           NULL, &setSet.first_id );
    CHECK_MB( rval );
    writeSets = setSet.max_num_ents > 0;
    rval = assign_ids( setSet.range, setSet.first_id + setSet.offset );
    CHECK_MB( rval );
    if( times ) times[SET_OFFSET_TIME] = timer.time_elapsed();
    // Exchange file IDS for sets between all procs
    rval = communicate_shared_set_ids( owned, remote );
    CHECK_MB( rval );
    if( times ) times[SHARED_SET_IDS] = timer.time_elapsed();
    // Communicate remote set contents, children, etc.
    rval = communicate_shared_set_data( owned, remote );
    CHECK_MB( rval );
    if( times ) times[SHARED_SET_CONTENTS] = timer.time_elapsed();
    // Communicate counts for owned sets
    long data_counts[3];  // { #contents, #children, #parents }
    rval = count_set_size( setSet.range, data_counts[0], data_counts[1], data_counts[2] );
    CHECK_MB( rval );
    if( times ) times[SET_OFFSET_TIME] += timer.time_elapsed();
    long offsets[3], max_counts[3], totals[3];
    rval = create_dataset( 3, data_counts, offsets, max_counts, totals );
    CHECK_MB( rval );
    // Create the datasets
    if( 0 == myPcomm->proc_config().proc_rank() )
        rval = create_set_tables( totals[0], totals[1], totals[2] );
        CHECK_MB( rval );
    // Store communicated global data
    setContentsOffset = offsets[0];
    setChildrenOffset = offsets[1];
    setParentsOffset  = offsets[2];
    maxNumSetContents = max_counts[0];
    maxNumSetChildren = max_counts[1];
    maxNumSetParents  = max_counts[2];
    writeSetContents  = totals[0] > 0;
    writeSetChildren  = totals[1] > 0;
    writeSetParents   = totals[2] > 0;
    dbgOut.printf( 2, "set contents: %ld local, %ld global, offset = %ld\n", data_counts[0], totals[0], offsets[0] );
    dbgOut.printf( 2, "set children: %ld local, %ld global, offset = %ld\n", data_counts[1], totals[1], offsets[1] );
    dbgOut.printf( 2, "set parents: %ld local, %ld global, offset = %ld\n", data_counts[2], totals[2], offsets[2] );
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5Parallel::create_node_table ( int  dimension) [protected]
Definition at line 1180 of file WriteHDF5Parallel.cpp.
References moab::WriteHDF5::assign_ids(), CHECK_HDFN, CHECK_MB, create_dataset(), ErrorCode, moab::WriteHDF5::file_ptr(), moab::WriteHDF5::ExportSet::first_id, moab::WriteHDF5::ExportSet::max_num_ents, MB_SUCCESS, mhdf_closeData(), mhdf_createNodeCoords(), moab::WriteHDF5::nodeSet, moab::WriteHDF5::ExportType::num_nodes, moab::WriteHDF5::ExportSet::offset, moab::WriteHDF5::ExportSet::range, moab::Range::size(), and moab::WriteHDF5::ExportSet::total_num_ents.
    nodeSet.num_nodes = dimension;  // Put it here so NodeSetCreator can access it
    struct NodeSetCreator : public DataSetCreator
        ErrorCode operator()( WriteHDF5* file, long count, const ExportSet* group, long& start_id ) const
            mhdf_Status status;
            hid_t handle = mhdf_createNodeCoords( file->file_ptr(), group->num_nodes, count, &start_id, &status );
            return MB_SUCCESS;
    const long count   = nodeSet.range.size();
    ExportSet* array[] = { &nodeSet };
    ErrorCode rval     = create_dataset( 1, &count, &nodeSet.offset, &nodeSet.max_num_ents, &nodeSet.total_num_ents,
                                         NodeSetCreator(), array, &nodeSet.first_id );
    CHECK_MB( rval );
    return assign_ids( nodeSet.range, nodeSet.first_id + nodeSet.offset );
Definition at line 753 of file WriteHDF5Parallel.cpp.
References append_serial_tag_data(), moab::WriteHDF5::check_dense_format_tag(), CHECK_MB, CHECK_MPI, check_serial_tag_data(), create_dataset(), moab::WriteHDF5::create_tag(), moab::WriteHDF5::dbgOut, moab::error(), ErrorCode, moab::WriteHDF5::exportList, moab::get_bit(), moab::WriteHDF5::get_num_sparse_tagged_entities(), moab::WriteHDF5::get_sparse_tagged_entities(), moab::WriteHDF5::get_tag_data_length(), moab::DebugOutput::get_verbosity(), moab::WriteHDF5::iFace, MB_SET_ERR_CONT, MB_SUCCESS, MB_TAG_DENSE, MB_VARIABLE_DATA_LENGTH, moab::my_Gatherv(), myPcomm, moab::WriteHDF5::nodeSet, moab::DebugOutput::print(), moab::DebugOutput::printf(), moab::ProcConfig::proc_comm(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::WriteHDF5::ExportSet::range, rank, moab::set_bit(), moab::WriteHDF5::setSet, size, moab::Range::size(), moab::WriteHDF5::subState, moab::Interface::tag_get_default_value(), moab::Interface::tag_get_length(), moab::Interface::tag_get_name(), moab::Interface::tag_get_type(), moab::WriteHDF5::tagList, TagType, moab::DebugOutput::tprint(), and moab::WriteHDF5::writeTagDense.
    ErrorCode rval;
    int err;
    const int rank      = myPcomm->proc_config().proc_rank();
    subState.start( "negotiating tag list" );
    dbgOut.tprint( 1, "communicating tag metadata\n" );
    dbgOut.printf( 2, "Exchanging tag data for %d tags.\n", (int)tagList.size() );
    // Sort tagList contents in alphabetical order by tag name
    tagList.sort( TagNameCompare( iFace ) );
    // Negotiate total list of tags to write
    // Build concatenated list of all tag data
    std::vector< unsigned char > tag_buffer;
        rval = append_serial_tag_data( tag_buffer, *tag_iter );
        CHECK_MB( rval );
    // Broadcast list from root to all other procs
    unsigned long size = tag_buffer.size();
    err                = MPI_Bcast( &size, 1, MPI_UNSIGNED_LONG, 0, comm );
    CHECK_MPI( err );
    tag_buffer.resize( size );
    err = MPI_Bcast( &tag_buffer[0], size, MPI_UNSIGNED_CHAR, 0, comm );
    CHECK_MPI( err );
    // Update local tag list
    std::vector< TagDesc* > missing;
    rval = check_serial_tag_data( tag_buffer, &missing, 0 );
    CHECK_MB( rval );
    // Check if we're done (0->done, 1->more, 2+->error)
    int code, lcode = ( MB_SUCCESS != rval ) ? rval + 2 : missing.empty() ? 0 : 1;
    err = MPI_Allreduce( &lcode, &code, 1, MPI_INT, MPI_MAX, comm );
    CHECK_MPI( err );
    if( code > 1 )
        MB_SET_ERR_CONT( "Inconsistent tag definitions between procs" );
        return error( (ErrorCode)( code - 2 ) );
    // If not done...
    if( code )
        dbgOut.print( 1, "Not all procs had same tag definitions, negotiating...\n" );
        // Get tags defined on this proc but not on root proc
        tag_buffer.clear();
        for( size_t i = 0; i < missing.size(); ++i )
            rval = append_serial_tag_data( tag_buffer, *missing[i] );
            CHECK_MB( rval );
        // Gather extra tag definitions on root processor
        std::vector< int > junk;               // don't care how many from each proc
        assert( rank || tag_buffer.empty() );  // must be empty on root
        err = my_Gatherv( &tag_buffer[0], tag_buffer.size(), MPI_UNSIGNED_CHAR, tag_buffer, junk, 0, comm );
        CHECK_MPI( err );
        // Process serialized tag descriptions on root, and
        rval = MB_SUCCESS;
        if( 0 == rank )
            std::vector< TagDesc* > newlist;
            rval = check_serial_tag_data( tag_buffer, 0, &newlist );
            tag_buffer.clear();
            // re-serialize a unique list of new tag definitions
            for( size_t i = 0; MB_SUCCESS == rval && i != newlist.size(); ++i )
                rval = append_serial_tag_data( tag_buffer, *newlist[i] );
                CHECK_MB( rval );
        // Broadcast any new tag definitions from root to other procs
        long this_size = tag_buffer.size();
        if( MB_SUCCESS != rval ) this_size = -rval;
        err = MPI_Bcast( &this_size, 1, MPI_LONG, 0, comm );
        CHECK_MPI( err );
        if( this_size < 0 )
            return error( (ErrorCode)-this_size );
        tag_buffer.resize( this_size );
        err = MPI_Bcast( &tag_buffer[0], this_size, MPI_UNSIGNED_CHAR, 0, comm );
        CHECK_MPI( err );
        // Process new tag definitions
        rval = check_serial_tag_data( tag_buffer, 0, 0 );
        CHECK_MB( rval );
    subState.end();
    subState.start( "negotiate which element/tag combinations are dense" );
    // Figure out for which tag/element combinations we can
    // write dense tag data.
    // Construct a table of bits,
    // where each row of the table corresponds to a tag
    // and each column to an element group.
    // Two extra, because first is nodes and last is sets.
    // (n+7)/8 is ceil(n/8)
    const int bytes_per_tag = ( exportList.size() + 9 ) / 8;
    std::vector< unsigned char > data( bytes_per_tag * tagList.size(), 0 );
    std::vector< unsigned char > recv( data.size(), 0 );
    unsigned char* iter = &data[0];
    if( writeTagDense && !data.empty() )
        for( tag_iter = tagList.begin(); tag_iter != tagList.end(); ++tag_iter, iter += bytes_per_tag )
            Range tagged;
            rval = get_sparse_tagged_entities( *tag_iter, tagged );
            CHECK_MB( rval );
            int s;
            if( MB_VARIABLE_DATA_LENGTH == iFace->tag_get_length( tag_iter->tag_id, s ) ) continue;
            std::string n;
            // Check if we want to write this tag in dense format even if not
            // all of the entities have a tag value.  The criterion of this
            // is that the tag be dense, have a default value, and have at
            // least 2/3 of the entities tagged.
            bool prefer_dense = false;
            TagType type;
            rval = iFace->tag_get_type( tag_iter->tag_id, type );
            CHECK_MB( rval );
            if( MB_TAG_DENSE == type )
                const void* defval = 0;
                rval               = iFace->tag_get_default_value( tag_iter->tag_id, defval, s );
                if( MB_SUCCESS == rval ) prefer_dense = true;
            int i = 0;
            if( check_dense_format_tag( nodeSet, tagged, prefer_dense ) )
                set_bit( i, iter );
                dbgOut.printf( 2, "Can write dense data for \"%s\"/Nodes\n", n.c_str() );
            std::list< ExportSet >::const_iterator ex_iter = exportList.begin();
            for( ++i; ex_iter != exportList.end(); ++i, ++ex_iter )
                // when writing in parallel, on some partitions, some of these element ranges might
                // be empty so do not turn this tag as sparse, just because of that, leave it dense,
                // if we prefer dense
                if( ( prefer_dense && ex_iter->range.empty() ) ||
                    check_dense_format_tag( *ex_iter, tagged, prefer_dense ) )
                    set_bit( i, iter );
                    dbgOut.printf( 2, "Can write dense data for \"%s\"/%s\n", n.c_str(), ex_iter->name() );
            if( check_dense_format_tag( setSet, tagged, prefer_dense ) )
                set_bit( i, iter );
                dbgOut.printf( 2, "Can write dense data for \"%s\"/Sets\n", n.c_str() );
        // Do bit-wise AND of list over all processors (only write dense format
        // if all proccesses want dense format for this group of entities).
        err = MPI_Allreduce( &data[0], &recv[0], data.size(), MPI_UNSIGNED_CHAR, MPI_BAND,
                             myPcomm->proc_config().proc_comm() );
        CHECK_MPI( err );
    }  // if (writeTagDense)
    // Store initial counts for sparse-formatted tag data.
    // The total number of values to send and receive will be the number of
    // tags plus the number of var-len tags because we need to negotiate
    // offsets into two different tables for the var-len tags.
    std::vector< long > counts;
    // Record dense tag/element combinations
    iter                       = &recv[0];
    const unsigned char* iter2 = &data[0];
         ++tag_iter, iter += bytes_per_tag, iter2 += bytes_per_tag )
        Range tagged;
        CHECK_MB( rval );
        std::string n;
        int i = 0;
        if( get_bit( i, iter ) )
            assert( get_bit( i, iter2 ) );
            tag_iter->dense_list.push_back( nodeSet );
            tagged -= nodeSet.range;
            dbgOut.printf( 2, "Will write dense data for \"%s\"/Nodes\n", n.c_str() );
                tag_iter->dense_list.push_back( *ex_iter );
                dbgOut.printf( 2, "WIll write dense data for \"%s\"/%s\n", n.c_str(), ex_iter->name() );
                tagged -= ex_iter->range;
            tag_iter->dense_list.push_back( setSet );
            dbgOut.printf( 2, "Will write dense data for \"%s\"/Sets\n", n.c_str() );
            tagged -= setSet.range;
        counts.push_back( tagged.size() );
        int s;
            unsigned long data_len;
            rval = get_tag_data_length( *tag_iter, tagged, data_len );
            CHECK_MB( rval );
            counts.push_back( data_len );
    subState.end();
    subState.start( "Negotiate offsets for sparse tag info" );
    std::vector< long > offsets( counts.size() ), maxima( counts.size() ), totals( counts.size() );
    rval = create_dataset( counts.size(), &counts[0], &offsets[0], &maxima[0], &totals[0] );
    CHECK_MB( rval );
    // Copy values into local structs and if root then create tables
    size_t idx = 0;
    for( tag_iter = tagList.begin(); tag_iter != tagList.end(); ++tag_iter, ++idx )
        assert( idx < counts.size() );
        tag_iter->sparse_offset = offsets[idx];
        tag_iter->max_num_ents  = maxima[idx];
        tag_iter->write_sparse  = ( 0 != totals[idx] );
        int s;
            ++idx;
            tag_iter->var_data_offset = offsets[idx];
            tag_iter->max_num_vals    = maxima[idx];
        else
            tag_iter->var_data_offset = 0;
            tag_iter->max_num_vals    = 0;
    subState.end();
    // Create tag tables on root process
        size_t iidx = 0;
        for( tag_iter = tagList.begin(); tag_iter != tagList.end(); ++tag_iter, ++iidx )
            assert( iidx < totals.size() );
            unsigned long num_ents = totals[iidx];
            unsigned long num_val  = 0;
            int s;
                ++iidx;
                num_val = totals[iidx];
            dbgOut.printf( 2, "Writing tag description for tag 0x%lx with %lu values\n",
                           (unsigned long)tag_iter->tag_id, num_val ? num_val : num_ents );
            rval = create_tag( *tag_iter, num_ents, num_val );
    if( dbgOut.get_verbosity() > 1 )
        dbgOut.printf( 2, "Tags: %12s %8s %8s %8s %8s %8s\n", "Name", "Count", "Offset", "Var Off", "Max Ent",
                       "Handle" );
            std::string name;
            iFace->tag_get_name( tag_iter->tag_id, name );
            size_t this_size;
            get_num_sparse_tagged_entities( *tag_iter, this_size );
            dbgOut.printf( 2, "%18s %8lu %8lu %8lu %8lu 0x%7lx\n", name.c_str(), (unsigned long)this_size,
                           (unsigned long)tag_iter->sparse_offset, (unsigned long)tag_iter->var_data_offset,
                           (unsigned long)tag_iter->max_num_ents, (unsigned long)tag_iter->tag_id );
    return MB_SUCCESS;
void moab::WriteHDF5Parallel::debug_barrier_line ( int  lineno) [protected, virtual]
Reimplemented from moab::WriteHDF5.
Definition at line 263 of file WriteHDF5Parallel.cpp.
References moab::WriteHDF5::dbgOut, moab::DebugOutput::get_verbosity(), myPcomm, moab::DebugOutput::printf(), moab::ProcConfig::proc_comm(), and moab::ParallelComm::proc_config().
    const unsigned threshold   = 2;
    static unsigned long count = 0;
    if( dbgOut.get_verbosity() >= threshold && myPcomm )
        dbgOut.printf( threshold, "*********** Debug Barrier %lu (@%d)***********\n", ++count, lineno );
        MPI_Barrier( myPcomm->proc_config().proc_comm() );
ErrorCode moab::WriteHDF5Parallel::exchange_file_ids ( const Range non_local_ents) [protected]
For entities that will be written by another processor but are referenced by entities on this processor, get the file Ids that will be assigned to those so they can be referenced by entities to be written on this processor.
Parameters:
non_local_entsList of entities that are not to be written by this processor but are referenced by other entities that are to be written.
Definition at line 2257 of file WriteHDF5Parallel.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::WriteHDF5::dbgOut, moab::Range::end(), moab::CN::EntityTypeName(), moab::error(), ErrorCode, moab::ParallelComm::exchange_tags(), moab::WriteHDF5::exportList, moab::ParallelComm::filter_pstatus(), moab::RangeMap< KeyType, ValType, NullVal >::find(), moab::ParallelComm::get_owner(), moab::ID_FROM_HANDLE(), moab::WriteHDF5::idMap, moab::WriteHDF5::iFace, moab::RangeMap< KeyType, ValType, NullVal >::insert(), MB_SET_ERR, MB_SET_ERR_CONT, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_HANDLE, moab::Range::merge(), myPcomm, moab::WriteHDF5::nodeSet, moab::DebugOutput::printf(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), PSTATUS_AND, PSTATUS_SHARED, moab::WriteHDF5::ExportSet::range, moab::Range::size(), moab::Interface::tag_delete(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), and moab::TYPE_FROM_HANDLE().
    ErrorCode rval;
    // For each entity owned on the interface, write its file id to
    // a tag. The sets of entities to be written should already contain
    // only owned entities so by intersecting with them we not only
    // filter by entities to be written, but also restrict to entities
    // owned by the proc
    // Get list of interface entities
    Range imesh, tmp;
    for( std::list< ExportSet >::reverse_iterator i = exportList.rbegin(); i != exportList.rend(); ++i )
        tmp.clear();
        rval = myPcomm->filter_pstatus( i->range, PSTATUS_SHARED, PSTATUS_AND, -1, &tmp );
        imesh.merge( tmp );
    tmp.clear();
    rval = myPcomm->filter_pstatus( nodeSet.range, PSTATUS_SHARED, PSTATUS_AND, -1, &tmp );
    imesh.merge( tmp );
    // Create tag to store file IDs
    EntityHandle default_val = 0;
    Tag file_id_tag          = 0;
    rval = iFace->tag_get_handle( "__hdf5_ll_fileid", 1, MB_TYPE_HANDLE, file_id_tag, MB_TAG_DENSE | MB_TAG_CREAT,
                                  &default_val );
    // Copy file IDs into tag
    std::vector< EntityHandle > file_id_vect( imesh.size() );
    Range::const_iterator i;
    std::vector< EntityHandle >::iterator j = file_id_vect.begin();
    for( i = imesh.begin(); i != imesh.end(); ++i, ++j )
        *j = idMap.find( *i );
        if( !*j )
            iFace->tag_delete( file_id_tag );
            return error( MB_FAILURE );
    rval = iFace->tag_set_data( file_id_tag, imesh, &file_id_vect[0] );
    // Do communication
    rval = myPcomm->exchange_tags( file_id_tag, imesh );
    // Copy file IDs from tag into idMap for remote entities
    file_id_vect.resize( nonlocal.size() );
    rval = iFace->tag_get_data( file_id_tag, nonlocal, &file_id_vect[0] );
    for( i = nonlocal.begin(); i != nonlocal.end(); ++i, ++j )
        if( *j == 0 )
            int owner = -1;
            myPcomm->get_owner( *i, owner );
            const char* name = CN::EntityTypeName( TYPE_FROM_HANDLE( *i ) );
            int id           = ID_FROM_HANDLE( *i );
            MB_SET_ERR_CONT( "Process " << myPcomm->proc_config().proc_rank()
                                        << " did not receive valid id handle for shared " << name << " " << id
                                        << " owned by process " << owner );
            dbgOut.printf( 1,
                           "Did not receive valid remote id for "
                           "shared %s %d owned by process %d",
                           name, id, owner );
        else
            if( !idMap.insert( *i, *j, 1 ).second )
#ifndef NDEBUG
    // Check that writer is correct with regards to which entities
    // that it owns by verifying that the file ids that we thought
    // we were sending where not received instead
    file_id_vect.resize( imesh.size() );
    rval = iFace->tag_get_data( file_id_tag, imesh, &file_id_vect[0] );
    int invalid_count = 0;
        EntityHandle h = idMap.find( *i );
        if( *j != h )
            ++invalid_count;
            dbgOut.printf( 1, "Conflicting ownership for %s %ld\n", CN::EntityTypeName( TYPE_FROM_HANDLE( *i ) ),
                           (long)ID_FROM_HANDLE( *i ) );
    if( invalid_count )
        MB_SET_ERR( MB_FAILURE, invalid_count << " entities with conflicting ownership found by process "
                                              << ". This will result in duplicate entities written to file" );
#endif
    return iFace->tag_delete( file_id_tag );
Definition at line 274 of file WriteHDF5Parallel.cpp.
References WriteHDF5Parallel().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
    return new WriteHDF5Parallel( iface );
Figure out which mesh local mesh is duplicated on remote processors and which processor will write that mesh.
Parameters:
non_local_entsOutput list of entities that are not to be written by this processor but are referenced by other entities that are to be written.
Definition at line 295 of file WriteHDF5Parallel.cpp.
References moab::Range::clear(), moab::WriteHDF5::dbgOut, moab::error(), ErrorCode, moab::WriteHDF5::exportList, moab::ParallelComm::filter_pstatus(), MB_SUCCESS, moab::Range::merge(), myPcomm, moab::WriteHDF5::nodeSet, moab::DebugOutput::print(), PSTATUS_AND, PSTATUS_NOT_OWNED, moab::WriteHDF5::ExportSet::range, moab::WriteHDF5::setSet, and moab::subtract().
    ErrorCode result;
    // START_SERIAL;
    dbgOut.print( 3, "Pre-interface mesh:\n" );
    dbgOut.print( 3, nodeSet.range );
    for( std::list< ExportSet >::iterator eiter = exportList.begin(); eiter != exportList.end(); ++eiter )
        dbgOut.print( 3, eiter->range );
    dbgOut.print( 3, setSet.range );
    // Move handles of non-owned entities from lists of entities
    // that this processor will write to the 'nonowned' list.
    nonowned.clear();
    result = myPcomm->filter_pstatus( nodeSet.range, PSTATUS_NOT_OWNED, PSTATUS_AND, -1, &nonowned );
    if( MB_SUCCESS != result ) return error( result );
    nodeSet.range = subtract( nodeSet.range, nonowned );
        Range tmpset;
        result = myPcomm->filter_pstatus( eiter->range, PSTATUS_NOT_OWNED, PSTATUS_AND, -1, &tmpset );
        eiter->range = subtract( eiter->range, tmpset );
        nonowned.merge( tmpset );
    dbgOut.print( 3, "Post-interface mesh:\n" );
    // END_SERIAL;
    return MB_SUCCESS;
Communicate with other processors to negotiate the types of elements that will be written (the union of the types defined on each proc.)
Definition at line 1228 of file WriteHDF5Parallel.cpp.
References moab::WriteHDF5::ExportSet::adj_offset, CHECK_MPI, moab::WriteHDF5::dbgOut, moab::CN::EntityTypeName(), moab::WriteHDF5::exportList, moab::WriteHDF5::ExportSet::first_id, MB_SUCCESS, myPcomm, moab::WriteHDF5::ExportType::num_nodes, moab::WriteHDF5::ExportSet::offset, moab::DebugOutput::print(), moab::DebugOutput::printf(), moab::ProcConfig::proc_comm(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), moab::WriteHDF5::ExportType::type, VALGRIND_CHECK_MEM_IS_DEFINED, and moab::VALGRIND_MAKE_VEC_UNDEFINED().
    int result;
    exportList.sort();
    int num_types = exportList.size();
    // Get list of types on this processor
    typedef std::vector< std::pair< int, int > > typelist;
    typelist my_types( num_types );
    (void)VALGRIND_MAKE_VEC_UNDEFINED( my_types );
    typelist::iterator viter = my_types.begin();
        viter->first  = eiter->type;
        viter->second = eiter->num_nodes;
        ++viter;
    dbgOut.print( 2, "Local Element Types:\n" );
    for( viter = my_types.begin(); viter != my_types.end(); ++viter )
        int type  = viter->first;
        int count = viter->second;
        dbgOut.printf( 2, "  %s : %d\n", CN::EntityTypeName( (EntityType)type ), count );
    // Broadcast number of types from root to all nodes
    int num_types0 = num_types;
    result         = MPI_Bcast( &num_types0, 1, MPI_INT, 0, comm );
    // Broadcast type list from root to all nodes
    typelist root_types( num_types0 );
    if( 0 == myPcomm->proc_config().proc_rank() ) root_types = my_types;
    result = MPI_Bcast( (void*)&root_types[0], 2 * num_types0, MPI_INT, 0, comm );
    // Build local list of any types that root did not know about
    typelist non_root_types;
    viter = root_types.begin();
    for( typelist::iterator iter = my_types.begin(); iter != my_types.end(); ++iter )
        if( viter == root_types.end() || *viter != *iter )
            non_root_types.push_back( *iter );
        else
            ++viter;
    // Determine if any process had types not defined on the root
    int non_root_count = non_root_types.size();
    int not_done;
    result = MPI_Allreduce( &non_root_count, &not_done, 1, MPI_INT, MPI_LOR, comm );
    if( not_done )
        // Get number of types each processor has that root does not
        std::vector< int > counts( myPcomm->proc_config().proc_size() );
        int two_count = 2 * non_root_count;
        result        = MPI_Gather( &two_count, 1, MPI_INT, &counts[0], 1, MPI_INT, 0, comm );
        // Get list of types from each processor
        std::vector< int > displs( myPcomm->proc_config().proc_size() + 1 );
        (void)VALGRIND_MAKE_VEC_UNDEFINED( displs );
        displs[0] = 0;
        for( unsigned long i = 1; i <= myPcomm->proc_config().proc_size(); ++i )
            displs[i] = displs[i - 1] + counts[i - 1];
        int total = displs[myPcomm->proc_config().proc_size()];
        typelist alltypes( total / 2 );
        (void)VALGRIND_MAKE_VEC_UNDEFINED( alltypes );
        (void)VALGRIND_CHECK_MEM_IS_DEFINED( &non_root_types[0], non_root_types.size() * sizeof( int ) );
        result = MPI_Gatherv( (void*)&non_root_types[0], 2 * non_root_count, MPI_INT, (int*)&alltypes[0], &counts[0],
                              &displs[0], MPI_INT, 0, comm );
        // Merge type lists.
        // Prefer O(n) insertions with O(ln n) search time because
        // we expect data from a potentially large number of processes,
        // but with a small total number of element types.
            for( viter = alltypes.begin(); viter != alltypes.end(); ++viter )
                typelist::iterator titer = std::lower_bound( my_types.begin(), my_types.end(), *viter );
                if( titer == my_types.end() || *titer != *viter ) my_types.insert( titer, *viter );
            dbgOut.print( 2, "Global Element Types:\n" );
                dbgOut.printf( 2, "  %s : %d\n", CN::EntityTypeName( (EntityType)viter->first ), viter->second );
        // Send total number of types to each processor
        total  = my_types.size();
        result = MPI_Bcast( &total, 1, MPI_INT, 0, comm );
        // Send list of types to each processor
        my_types.resize( total );
        result = MPI_Bcast( (void*)&my_types[0], 2 * total, MPI_INT, 0, comm );
    else
        // Special case: if root had types but some subset of procs did not
        // have those types, but there are no types that the root doesn't
        // know about then we still need to update processes that are missing
        // types.
        my_types.swap( root_types );
    // Insert missing types into exportList, with an empty
    // range of entities to export.
        while( ex_iter != exportList.end() && *ex_iter < *viter )
            ++ex_iter;
        if( ex_iter == exportList.end() || !( *ex_iter == *viter ) )
            ExportSet insert;
            insert.type       = (EntityType)viter->first;
            insert.num_nodes  = viter->second;
            insert.first_id   = 0;
            insert.offset     = 0;
            insert.adj_offset = 0;
            ex_iter           = exportList.insert( ex_iter, insert );
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5Parallel::pack_set ( Range::const_iterator  set,
unsigned long *  set_data,
) [protected]
Pack set data for communication.
If set_data_length is insufficient for the set data, the length entries at indices 1, 2, and 3 of set_data will be set with the necessary lengths, but no data will be written to set_data beyond that.
Definition at line 1669 of file WriteHDF5Parallel.cpp.
References CHECK_MB, moab::WriteUtilIface::CHILDREN, moab::WriteUtilIface::CONTENTS, ErrorCode, moab::WriteUtilIface::get_entity_list_pointers(), MB_SUCCESS, mhdf_SET_RANGE_BIT, moab::WriteUtilIface::PARENTS, moab::WriteHDF5::range_to_blocked_list(), moab::WriteHDF5::vector_to_id_list(), and moab::WriteHDF5::writeUtil.
Referenced by communicate_shared_set_data().
    ErrorCode rval;
    const EntityHandle* ptr;
    int len;
    unsigned char flags;
    std::vector< wid_t > tmp;
    size_t newlen;
    // Buffer must always contain at least flags and desired sizes
    assert( buffer_size >= 4 );
    buffer_size -= 4;
    Range::const_iterator nd = it;
    ++nd;
    rval = writeUtil->get_entity_list_pointers( it, nd, &ptr, WriteUtilIface::CONTENTS, &len, &flags );
    CHECK_MB( rval );
    // Tag mattag;
    // int block;
    // if (MB_SUCCESS != iFace->tag_get_data(mattag, &*it, 1, &block))
    //  block = 0;
    // if (block) {
    //  get_global_ids(iFace, ptr, len, flags, ids);
    if( len && !( flags & MESHSET_ORDERED ) )
        tmp.clear();
        bool blocked = false;
        assert( ( 0 == len % 2 ) );
        rval = range_to_blocked_list( ptr, len / 2, tmp, blocked );
        CHECK_MB( rval );
        if( blocked ) flags |= mhdf_SET_RANGE_BIT;
    else
        tmp.resize( len );
        rval = vector_to_id_list( ptr, len, &tmp[0], newlen, true );
        CHECK_MB( rval );
        tmp.resize( newlen );
    buffer[0] = flags;
    buffer[1] = tmp.size();
    if( tmp.size() <= buffer_size ) std::copy( tmp.begin(), tmp.end(), buffer + 4 );
    rval = writeUtil->get_entity_list_pointers( it, nd, &ptr, WriteUtilIface::CHILDREN, &len );
    CHECK_MB( rval );
    tmp.resize( len );
    buffer[2] = tmp.size();
    if( tmp.size() <= buffer_size - buffer[1] ) std::copy( tmp.begin(), tmp.end(), buffer + 4 + buffer[1] );
    rval = writeUtil->get_entity_list_pointers( it, nd, &ptr, WriteUtilIface::PARENTS, &len );
    CHECK_MB( rval );
    tmp.resize( len );
    buffer[3] = tmp.size();
    if( tmp.size() <= buffer_size - buffer[1] - buffer[2] )
        std::copy( tmp.begin(), tmp.end(), buffer + 4 + buffer[1] + buffer[2] );
    return MB_SUCCESS;
ErrorCode moab::WriteHDF5Parallel::parallel_create_file ( const char *  filename,
bool  overwrite,
const std::vector< std::string > &  qa_records,
const FileOptions opts,
const Tag user_tag_list = 0,
int  user_tag_count = 0,
int  dimension = 3,
double *  times = 0
Called by normal (non-parallel) writer. Sets up necessary data for parallel write.
Definition at line 334 of file WriteHDF5Parallel.cpp.
References moab::WriteHDF5::collectiveIO, moab::WriteHDF5::CREATE_ADJ_TIME, create_adjacency_tables(), moab::WriteHDF5::CREATE_ELEM_TIME, create_element_tables(), create_meshset_tables(), create_node_table(), moab::WriteHDF5::CREATE_NODE_TIME, moab::WriteHDF5::CREATE_SET_TIME, create_tag_tables(), moab::WriteHDF5::CREATE_TAG_TIME, moab::WriteHDF5::dbgOut, debug_barrier, moab::CN::EntityTypeName(), moab::error(), ErrorCode, exchange_file_ids(), moab::WriteHDF5::FILEID_EXCHANGE_TIME, moab::WriteHDF5::filePtr, gather_interface_meshes(), moab::WriteHDF5::gather_tags(), moab::FileOptions::get_int_option(), moab::FileOptions::get_null_option(), moab::ParallelComm::get_pcomm(), moab::FileOptions::get_str_option(), moab::HDF5_can_append_hyperslabs(), hslabOp, moab::WriteHDF5::id_type, moab::WriteHDF5::iFace, moab::DebugOutput::limit_output_to_first_N_procs(), MB_SET_ERR, MB_SUCCESS, MBEDGE, MBENTITYSET, MBMAXTYPE, mhdf_closeFile(), mhdf_createFile(), mhdf_message(), mhdf_openFileWithOpt(), MPI_COMM_WORLD, myPcomm, negotiate_type_list(), moab::WriteHDF5::NEGOTIATE_TYPES_TIME, pcommAllocated, moab::DebugOutput::print(), moab::ProcConfig::proc_comm(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::DebugOutput::set_rank(), moab::CpuTimer::time_elapsed(), moab::WriteHDF5::topState, moab::DebugOutput::tprint(), moab::DebugOutput::tprintf(), moab::WriteHDF5::write_qa(), and moab::WriteHDF5::writeProp.
    ErrorCode rval;
    mhdf_Status status;
    int pcomm_no = 0;
    opts.get_int_option( "PARALLEL_COMM", pcomm_no );
    myPcomm = ParallelComm::get_pcomm( iFace, pcomm_no );
    if( 0 == myPcomm )
        myPcomm        = new ParallelComm( iFace, MPI_COMM_WORLD );
        pcommAllocated = true;
    MPI_Info info = MPI_INFO_NULL;
    std::string cb_size;
    rval = opts.get_str_option( "CB_BUFFER_SIZE", cb_size );
        MPI_Info_create( &info );
        MPI_Info_set( info, const_cast< char* >( "cb_buffer_size" ), const_cast< char* >( cb_size.c_str() ) );
    dbgOut.set_rank( myPcomm->proc_config().proc_rank() );
    dbgOut.limit_output_to_first_N_procs( 32 );
    Range nonlocal;
    debug_barrier();
    dbgOut.tprint( 1, "Gathering interface meshes\n" );
    rval = gather_interface_meshes( nonlocal );
    /**************** Get tag names for sets likely to be shared ***********/
    // debug_barrier();
    // dbgOut.tprint(1, "Getting shared entity sets\n");
    // rval = get_sharedset_tags();
    // if (MB_SUCCESS != rval) return error(rval);
    /**************** Create actual file and write meta info ***************/
    debug_barrier();
    if( myPcomm->proc_config().proc_rank() == 0 )
        dbgOut.tprintf( 1, "Creating file: %s\n", filename );
        // Create the file
        const char* type_names[MBMAXTYPE];
        memset( type_names, 0, MBMAXTYPE * sizeof( char* ) );
        for( EntityType i = MBEDGE; i < MBENTITYSET; ++i )
            type_names[i] = CN::EntityTypeName( i );
        dbgOut.tprint( 1, "call mhdf_createFile\n" );
        filePtr = mhdf_createFile( filename, overwrite, type_names, MBMAXTYPE, id_type, &status );
        if( !filePtr )
            MB_SET_ERR( MB_FAILURE, mhdf_message( &status ) );
        dbgOut.tprint( 1, "call write_qa\n" );
        rval = write_qa( qa_records );
    /**************** Create node coordinate table ***************/
    CpuTimer timer;
    debug_barrier();
    dbgOut.tprint( 1, "creating node table\n" );
    topState.start( "creating node table" );
    rval = create_node_table( dimension );
    topState.end( rval );
    if( times ) times[CREATE_NODE_TIME] = timer.time_elapsed();
    /**************** Create element tables ***************/
    debug_barrier();
    dbgOut.tprint( 1, "negotiating element types\n" );
    topState.start( "negotiating element types" );
    rval = negotiate_type_list();
    if( times ) times[NEGOTIATE_TYPES_TIME] = timer.time_elapsed();
    dbgOut.tprint( 1, "creating element table\n" );
    topState.start( "creating element tables" );
    rval = create_element_tables();
    if( times ) times[CREATE_ELEM_TIME] = timer.time_elapsed();
    /*************** Exchange file IDs *****************/
    debug_barrier();
    dbgOut.tprint( 1, "communicating file ids\n" );
    topState.start( "communicating file ids" );
    rval = exchange_file_ids( nonlocal );
    if( times ) times[FILEID_EXCHANGE_TIME] = timer.time_elapsed();
    /**************** Create meshset tables *********************/
    debug_barrier();
    dbgOut.tprint( 1, "creating meshset table\n" );
    topState.start( "creating meshset tables" );
    rval = create_meshset_tables( times );
    if( times ) times[CREATE_SET_TIME] = timer.time_elapsed();
    /**************** Create adjacency tables *********************/
    debug_barrier();
    dbgOut.tprint( 1, "creating adjacency table\n" );
    topState.start( "creating adjacency tables" );
    rval = create_adjacency_tables();
    if( times ) times[CREATE_ADJ_TIME] = timer.time_elapsed();
    /**************** Create tag data *********************/
    debug_barrier();
    dbgOut.tprint( 1, "creating tag tables\n" );
    topState.start( "creating tag tables" );
    rval = gather_tags( user_tag_list, user_tag_count );
    rval = create_tag_tables();
    if( times ) times[CREATE_TAG_TIME] = timer.time_elapsed();
    /************** Close serial file and reopen parallel *****************/
    if( 0 == myPcomm->proc_config().proc_rank() ) mhdf_closeFile( filePtr, &status );
    dbgOut.tprint( 1, "(re)opening file in parallel mode\n" );
    unsigned long junk;
    hid_t hdf_opt = H5Pcreate( H5P_FILE_ACCESS );
    H5Pset_fapl_mpio( hdf_opt, myPcomm->proc_config().proc_comm(), info );
    filePtr = mhdf_openFileWithOpt( filename, 1, &junk, id_type, hdf_opt, &status );
    H5Pclose( hdf_opt );
    if( !filePtr )
    if( collectiveIO )
        dbgOut.print( 1, "USING COLLECTIVE IO\n" );
        writeProp = H5Pcreate( H5P_DATASET_XFER );
        H5Pset_dxpl_mpio( writeProp, H5FD_MPIO_COLLECTIVE );
    /* Test if we can use H5S_APPEND when selecting hyperslabs */
    if( MB_SUCCESS != opts.get_null_option( "HYPERSLAB_OR" ) &&
        ( MB_SUCCESS == opts.get_null_option( "HYPERSLAB_APPEND" ) || HDF5_can_append_hyperslabs() ) )
        dbgOut.print( 1, "HDF5 library supports H5Sselect_hyperlsab with H5S_SELECT_APPEND\n" );
        hslabOp = H5S_SELECT_APPEND;
    dbgOut.tprint( 1, "Exiting parallel_create_file\n" );
    return MB_SUCCESS;
void moab::WriteHDF5Parallel::print_set_sharing_data ( const Range range,
const char *  label,
Tag  idt
) [protected]
Definition at line 1453 of file WriteHDF5Parallel.cpp.
References moab::Range::begin(), moab::WriteHDF5::dbgOut, moab::Range::end(), moab::RangeMap< KeyType, ValType, NullVal >::find(), moab::ParallelComm::get_entityset_owner(), moab::ParallelComm::get_entityset_procs(), moab::WriteHDF5::idMap, moab::WriteHDF5::iFace, myPcomm, moab::DebugOutput::print(), moab::DebugOutput::printf(), moab::SSVB, and moab::Interface::tag_get_data().
Referenced by print_shared_sets().
    dbgOut.printf( SSVB, "set\tid\towner\t%-*s\tfid\tshared\n", (int)( sizeof( EntityHandle ) * 2 ), "handle" );
    for( Range::iterator it = range.begin(); it != range.end(); ++it )
        int id;
        iFace->tag_get_data( idt, &*it, 1, &id );
        unsigned owner      = 0;
        wid_t file_id       = 0;
        myPcomm->get_entityset_owner( *it, owner, &handle );
        if( !idMap.find( *it, file_id ) ) file_id = 0;
        dbgOut.printf( SSVB, "%s\t%d\t%u\t%lx\t%lu\t", label, id, owner, (unsigned long)handle,
                       (unsigned long)file_id );
        myPcomm->get_entityset_procs( *it, procs );
        if( procs.empty() )
            dbgOut.print( SSVB, "<none>\n" );
        else
            for( unsigned i = 0; i < procs.size() - 1; ++i )
                dbgOut.printf( SSVB, "%u,", procs[i] );
            dbgOut.printf( SSVB, "%u\n", procs.back() );
Definition at line 1480 of file WriteHDF5Parallel.cpp.
References DIRICHLET_SET_TAG_NAME, geom, GEOM_DIMENSION_TAG_NAME, moab::Interface::get_entities_by_type_and_tag(), moab::Interface::globalId_tag(), moab::WriteHDF5::iFace, MATERIAL_SET_TAG_NAME, MB_SUCCESS, MB_TYPE_INTEGER, MBENTITYSET, NEUMANN_SET_TAG_NAME, print_set_sharing_data(), and moab::Interface::tag_get_handle().
Referenced by communicate_shared_set_ids().
    const char* tag_names[][2] = { { MATERIAL_SET_TAG_NAME, "block" },
                                   { DIRICHLET_SET_TAG_NAME, "nodeset" },
                                   { NEUMANN_SET_TAG_NAME, "sideset" },
                                   { 0, 0 } };
    for( int i = 0; tag_names[i][0]; ++i )
        Tag tag;
        if( MB_SUCCESS != iFace->tag_get_handle( tag_names[i][0], 1, MB_TYPE_INTEGER, tag ) ) continue;
        Range tagged;
        iFace->get_entities_by_type_and_tag( 0, MBENTITYSET, &tag, 0, 1, tagged );
        print_set_sharing_data( tagged, tag_names[i][1], tag );
    Tag geom, id;
    if( MB_SUCCESS != iFace->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geom ) ) return;
    id = iFace->globalId_tag();
    const char* geom_names[] = { "vertex", "curve", "surface", "volume" };
    for( int d = 0; d <= 3; ++d )
        Range tagged;
        const void* vals[] = { &d };
        iFace->get_entities_by_type_and_tag( 0, MBENTITYSET, &geom, vals, 1, tagged );
        print_set_sharing_data( tagged, geom_names[d], id );
void moab::WriteHDF5Parallel::print_times ( const double *  times) const [protected, virtual]
Definition at line 2389 of file WriteHDF5Parallel.cpp.
References myPcomm, moab::WriteHDF5::NUM_TIMES, moab::WriteHDF5::print_times(), moab::ProcConfig::proc_comm(), moab::ParallelComm::proc_config(), and moab::ProcConfig::proc_rank().
    if( !myPcomm )
        WriteHDF5::print_times( times );
    else
        double recv[NUM_TIMES];
        MPI_Reduce( (void*)times, recv, NUM_TIMES, MPI_DOUBLE, MPI_MAX, 0, myPcomm->proc_config().proc_comm() );
        if( 0 == myPcomm->proc_config().proc_rank() ) WriteHDF5::print_times( recv );
void moab::WriteHDF5Parallel::remove_remote_entities ( EntityHandle  relative,
Range range
) [protected]
Remove any remote mesh entities from the passed range.
Definition at line 2194 of file WriteHDF5Parallel.cpp.
References moab::Range::begin(), moab::CREATE_HANDLE(), moab::Range::end(), moab::WriteHDF5::exportList, moab::intersect(), moab::Range::lower_bound(), MBENTITYSET, moab::Range::merge(), moab::WriteHDF5::nodeSet, moab::WriteHDF5::ExportSet::range, remove_remote_sets(), moab::WriteHDF5::setSet, and moab::Range::swap().
Referenced by remove_remote_entities().
    Range result;
    result.merge( intersect( range, nodeSet.range ) );
    result.merge( intersect( range, setSet.range ) );
        result.merge( intersect( range, eiter->range ) );
    // result.merge(intersect(range, myParallelSets));
    Range sets;
    int junk;
    sets.merge( Range::lower_bound( range.begin(), range.end(), CREATE_HANDLE( MBENTITYSET, 0, junk ) ), range.end() );
    remove_remote_sets( relative, sets );
    result.merge( sets );
    range.swap( result );
std::vector< EntityHandle > &  vect
) [protected]
Definition at line 2219 of file WriteHDF5Parallel.cpp.
References moab::Range::end(), moab::Range::find(), moab::Range::insert(), and remove_remote_entities().
    Range intrsct;
    for( std::vector< EntityHandle >::const_iterator iter = vect.begin(); iter != vect.end(); ++iter )
        intrsct.insert( *iter );
    remove_remote_entities( relative, intrsct );
    unsigned int read, write;
    for( read = write = 0; read < vect.size(); ++read )
        if( intrsct.find( vect[read] ) != intrsct.end() )
            if( read != write ) vect[write] = vect[read];
            ++write;
    if( write != vect.size() ) vect.resize( write );
void moab::WriteHDF5Parallel::remove_remote_sets ( EntityHandle  relative,
Range range
) [protected]
Definition at line 2211 of file WriteHDF5Parallel.cpp.
References moab::intersect(), moab::WriteHDF5::ExportSet::range, moab::WriteHDF5::setSet, and moab::Range::swap().
Referenced by remove_remote_entities(), and remove_remote_sets().
    Range result( intersect( range, setSet.range ) );
    // Store the non-intersecting entities separately if needed
    // Range remaining(subtract(range, result));
) [protected]
Definition at line 2238 of file WriteHDF5Parallel.cpp.
References moab::Range::end(), moab::Range::find(), moab::Range::insert(), and remove_remote_sets().
    Range intrsct;
    remove_remote_sets( relative, intrsct );
            ++write;
ErrorCode moab::WriteHDF5Parallel::unpack_set ( EntityHandle  set,
const unsigned long *  set_data,
size_t  set_data_length
) [protected]
Unpack set data from communication.
Definition at line 1792 of file WriteHDF5Parallel.cpp.
References moab::WriteHDF5::SpecialSetData::childIds, children, moab::WriteHDF5::SpecialSetData::contentIds, moab::convert_to_ranged_ids(), moab::WriteHDF5::find_set_data(), MB_SUCCESS, moab::merge_ranged_ids(), moab::merge_vector_ids(), mhdf_SET_RANGE_BIT, moab::WriteHDF5::SpecialSetData::parentIds, and moab::WriteHDF5::SpecialSetData::setFlags.
    // Use local variables for readability
    assert( buffer[1] + buffer[2] + buffer[3] <= buffer_size );
    const unsigned long flags      = buffer[0];
    unsigned long num_content      = buffer[1];
    const unsigned long num_child  = buffer[2];
    const unsigned long num_parent = buffer[3];
    const unsigned long* contents  = buffer + 4;
    const unsigned long* children  = contents + num_content;
    const unsigned long* parents   = children + num_child;
    SpecialSetData* data = find_set_data( set );
    assert( NULL != data );
    if( NULL == data ) return MB_FAILURE;
    // Tag mattag;
    // int block;
    // if (MB_SUCCESS != iFace->tag_get_data(mattag, &set, 1, &block))
    //  block = 0;
    // If either the current data or the new data is in ranged format,
    // then change the other to ranged format if it isn't already
    // in both cases when they differ, the data will end up "compressed range"
    if( ( flags & mhdf_SET_RANGE_BIT ) != ( data->setFlags & mhdf_SET_RANGE_BIT ) )
        if( flags & mhdf_SET_RANGE_BIT )
            tmp = data->contentIds;
            convert_to_ranged_ids( &tmp[0], tmp.size(), data->contentIds );
            data->setFlags |= mhdf_SET_RANGE_BIT;
        else
            tmp.clear();
            convert_to_ranged_ids( contents, num_content, tmp );
            num_content = tmp.size();
            if( sizeof( wid_t ) < sizeof( long ) )
                size_t old_size = tmp.size();
                tmp.resize( sizeof( long ) * old_size / sizeof( wid_t ) );
                unsigned long* array = reinterpret_cast< unsigned long* >( &tmp[0] );
                for( long i = ( (long)old_size ) - 1; i >= 0; --i )
                    array[i] = tmp[i];
                contents = array;
            else if( sizeof( wid_t ) > sizeof( long ) )
                std::copy( tmp.begin(), tmp.end(), array );
            contents = reinterpret_cast< unsigned long* >( &tmp[0] );
    if( data->setFlags & mhdf_SET_RANGE_BIT )
        merge_ranged_ids( contents, num_content, data->contentIds );
    else
        merge_vector_ids( contents, num_content, data->contentIds );
    merge_vector_ids( children, num_child, data->childIds );
    merge_vector_ids( parents, num_parent, data->parentIds );
    return MB_SUCCESS;
Member Data Documentation
H5S_seloper_t moab::WriteHDF5Parallel::hslabOp [private]
Operation to use to append hyperslab selections.
Definition at line 186 of file WriteHDF5Parallel.hpp.
whether this instance allocated (and dtor should delete) the pcomm
Definition at line 183 of file WriteHDF5Parallel.hpp.
Referenced by parallel_create_file(), and ~WriteHDF5Parallel().
List of all members.
