moab::WriteTemplate Class Reference
#include <WriteTemplate.hpp>
+ Inheritance diagram for moab::WriteTemplate:
+ Collaboration diagram for moab::WriteTemplate:
Classes
struct  DirichletSetData
struct  MaterialSetData
class  MeshInfo
 contains the general information about a mesh More...
struct  NeumannSetData
Public Member Functions
 WriteTemplate (Interface *impl)
 Constructor.
virtual ~WriteTemplate ()
 Destructor.
ErrorCode write_file (const char *file_name, const bool overwrite, const FileOptions &opts, const EntityHandle *output_list, const int num_sets, const std::vector< std::string > &qa_list, const Tag *tag_list=NULL, int num_tags=0, int export_dimension=3)
 writes out a file
Static Public Member Functions
static WriterIfacefactory (Interface *)
Protected Member Functions
ErrorCode open_file (const char *filename)
 number of dimensions in this file
Private Member Functions
ErrorCode gather_mesh_information (MeshInfo &mesh_info, std::vector< MaterialSetData > &matset_info, std::vector< NeumannSetData > &neuset_info, std::vector< DirichletSetData > &dirset_info, std::vector< EntityHandle > &matsets, std::vector< EntityHandle > &neusets, std::vector< EntityHandle > &dirsets)
ErrorCode initialize_file (MeshInfo &mesh_info)
ErrorCode write_nodes (const int num_nodes, const Range &nodes, const int dimension)
ErrorCode write_matsets (MeshInfo &mesh_info, std::vector< MaterialSetData > &matset_data, std::vector< NeumannSetData > &neuset_data)
ErrorCode get_valid_sides (Range &elems, const int sense, WriteTemplate::NeumannSetData &neuset_data)
void reset_matset (std::vector< MaterialSetData > &matset_info)
ErrorCode get_neuset_elems (EntityHandle neuset, int current_sense, Range &forward_elems, Range &reverse_elems)
Private Attributes
InterfacembImpl
 interface instance
WriteUtilIfacemWriteIface
std::string fileName
 file name
Tag mMaterialSetTag
Tag mDirichletSetTag
Tag mNeumannSetTag
Tag mGlobalIdTag
Tag mEntityMark
Detailed Description
Definition at line 50 of file WriteTemplate.hpp.
Constructor.
Get and cache predefined tag handles
Definition at line 54 of file WriteTemplate.cpp.
References DIRICHLET_SET_TAG_NAME, moab::Interface::globalId_tag(), MATERIAL_SET_TAG_NAME, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_BIT, MB_TYPE_INTEGER, mDirichletSetTag, mEntityMark, mGlobalIdTag, mMaterialSetTag, mNeumannSetTag, mWriteIface, NEUMANN_SET_TAG_NAME, moab::Interface::query_interface(), and moab::Interface::tag_get_handle().
Referenced by factory().
                                              : mbImpl( impl )
    assert( impl != NULL );
    impl->query_interface( mWriteIface );
    // Initialize in case tag_get_handle fails below
    //! Get and cache predefined tag handles
    int negone = -1;
    impl->tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mMaterialSetTag, MB_TAG_SPARSE | MB_TAG_CREAT,
                          &negone );
    impl->tag_get_handle( DIRICHLET_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mDirichletSetTag, MB_TAG_SPARSE | MB_TAG_CREAT,
                          &negone );
    impl->tag_get_handle( NEUMANN_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mNeumannSetTag, MB_TAG_SPARSE | MB_TAG_CREAT,
                          &negone );
    mGlobalIdTag = impl->globalId_tag();
    impl->tag_get_handle( "WriteTemplate element mark", 1, MB_TYPE_BIT, mEntityMark, MB_TAG_CREAT );
Member Function Documentation
Definition at line 49 of file WriteTemplate.cpp.
References WriteTemplate().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
    return new WriteTemplate( iface );
ErrorCode moab::WriteTemplate::gather_mesh_information ( MeshInfo mesh_info,
std::vector< MaterialSetData > &  matset_info,
std::vector< NeumannSetData > &  neuset_info,
std::vector< DirichletSetData > &  dirset_info,
std::vector< EntityHandle > &  matsets,
std::vector< EntityHandle > &  neusets,
std::vector< EntityHandle > &  dirsets
) [private]
Definition at line 184 of file WriteTemplate.cpp.
References moab::Range::begin(), moab::CN::Dimension(), moab::WriteTemplate::MaterialSetData::element_type, moab::WriteTemplate::MaterialSetData::elements, moab::WriteTemplate::NeumannSetData::elements, moab::Range::end(), ErrorCode, moab::EXOII_MAX_ELEM_TYPE, moab::WriteUtilIface::gather_nodes_from_elements(), moab::Interface::get_connectivity(), moab::ExoIIUtil::get_element_type_from_num_verts(), moab::Interface::get_entities_by_handle(), get_neuset_elems(), moab::Interface::get_parent_meshsets(), get_valid_sides(), moab::WriteTemplate::MaterialSetData::id, moab::WriteTemplate::DirichletSetData::id, moab::WriteTemplate::NeumannSetData::id, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TYPE_BIT, mbImpl, MBMAXTYPE, MBVERTEX, mDirichletSetTag, mEntityMark, moab::WriteTemplate::NeumannSetData::mesh_set_handle, mMaterialSetTag, mNeumannSetTag, moab::WriteTemplate::MaterialSetData::moab_type, mWriteIface, moab::WriteTemplate::DirichletSetData::nodes, moab::WriteTemplate::MeshInfo::nodes, moab::WriteTemplate::MeshInfo::num_dim, moab::WriteTemplate::MeshInfo::num_elements, moab::WriteTemplate::MeshInfo::num_matsets, moab::WriteTemplate::MeshInfo::num_nodes, moab::WriteTemplate::MaterialSetData::number_attributes, moab::WriteTemplate::MaterialSetData::number_elements, moab::WriteTemplate::NeumannSetData::number_elements, moab::WriteTemplate::DirichletSetData::number_nodes, moab::WriteTemplate::MaterialSetData::number_nodes_per_element, moab::Range::size(), moab::Interface::tag_delete(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), moab::TYPE_FROM_HANDLE(), moab::Interface::type_from_handle(), and moab::ExoIIUtil::VerticesPerElement.
Referenced by write_file().
    std::vector< EntityHandle >::iterator vector_iter, end_vector_iter;
    mesh_info.num_nodes    = 0;
    mesh_info.num_elements = 0;
    mesh_info.num_matsets  = 0;
    int id = 0;
    vector_iter     = matsets.begin();
    end_vector_iter = matsets.end();
    mesh_info.num_matsets = matsets.size();
    std::vector< EntityHandle > parent_meshsets;
    // Clean out the bits for the element mark
    mbImpl->tag_delete( mEntityMark );
    mbImpl->tag_get_handle( "WriteTemplate element mark", 1, MB_TYPE_BIT, mEntityMark, MB_TAG_CREAT );
    int highest_dimension_of_element_matsets = 0;
    for( vector_iter = matsets.begin(); vector_iter != matsets.end(); ++vector_iter )
        WriteTemplate::MaterialSetData matset_data;
        matset_data.elements = new Range;
        // For the purpose of qa records, get the parents of these matsets
        if( mbImpl->get_parent_meshsets( *vector_iter, parent_meshsets ) != MB_SUCCESS ) return MB_FAILURE;
        // Get all Entity Handles in the mesh set
        Range dummy_range;
        mbImpl->get_entities_by_handle( *vector_iter, dummy_range, true );
        // Find the dimension of the last entity in this range
        Range::iterator entity_iter = dummy_range.end();
        --entity_iter;
        int this_dim = CN::Dimension( TYPE_FROM_HANDLE( *entity_iter ) );
        entity_iter  = dummy_range.begin();
        while( entity_iter != dummy_range.end() && CN::Dimension( TYPE_FROM_HANDLE( *entity_iter ) ) != this_dim )
            ++entity_iter;
        if( entity_iter != dummy_range.end() )
            std::copy( entity_iter, dummy_range.end(), range_inserter( *( matset_data.elements ) ) );
        assert( matset_data.elements->begin() == matset_data.elements->end() ||
                CN::Dimension( TYPE_FROM_HANDLE( *( matset_data.elements->begin() ) ) ) == this_dim );
        // Get the matset's id
        if( mbImpl->tag_get_data( mMaterialSetTag, &( *vector_iter ), 1, &id ) != MB_SUCCESS )
            MB_SET_ERR( MB_FAILURE, "Couldn't get matset id from a tag for an element matset" );
        matset_data.id                = id;
        matset_data.number_attributes = 0;
        // Iterate through all the elements in the meshset
        Range::iterator elem_range_iter, end_elem_range_iter;
        elem_range_iter     = matset_data.elements->begin();
        end_elem_range_iter = matset_data.elements->end();
        // Get the entity type for this matset, verifying that it's the same for all elements
        // THIS ASSUMES HANDLES SORT BY TYPE!!!
        EntityType entity_type = TYPE_FROM_HANDLE( *elem_range_iter );
        --end_elem_range_iter;
        if( entity_type != TYPE_FROM_HANDLE( *( end_elem_range_iter++ ) ) )
            MB_SET_ERR( MB_FAILURE, "Entities in matset " << id << " not of common type" );
        int dimension = CN::Dimension( entity_type );
        if( dimension > highest_dimension_of_element_matsets ) highest_dimension_of_element_matsets = dimension;
        matset_data.moab_type = mbImpl->type_from_handle( *( matset_data.elements->begin() ) );
        if( MBMAXTYPE == matset_data.moab_type ) return MB_FAILURE;
        std::vector< EntityHandle > tmp_conn;
        mbImpl->get_connectivity( &( *( matset_data.elements->begin() ) ), 1, tmp_conn );
        matset_data.element_type =
            ExoIIUtil::get_element_type_from_num_verts( tmp_conn.size(), entity_type, dimension );
        if( matset_data.element_type == EXOII_MAX_ELEM_TYPE )
            MB_SET_ERR( MB_FAILURE, "Element type in matset " << id << " didn't get set correctly" );
        matset_data.number_nodes_per_element = ExoIIUtil::VerticesPerElement[matset_data.element_type];
        // Number of nodes for this matset
        matset_data.number_elements = matset_data.elements->size();
        // Total number of elements
        mesh_info.num_elements += matset_data.number_elements;
        // Get the nodes for the elements
        mWriteIface->gather_nodes_from_elements( *matset_data.elements, mEntityMark, mesh_info.nodes );
        if( !neusets.empty() )
            // If there are neusets, keep track of which elements are being written out
            for( Range::iterator iter = matset_data.elements->begin(); iter != matset_data.elements->end(); ++iter )
                unsigned char bit = 0x1;
                mbImpl->tag_set_data( mEntityMark, &( *iter ), 1, &bit );
        matset_info.push_back( matset_data );
    // If user hasn't entered dimension, we figure it out
    if( mesh_info.num_dim == 0 )
        // Never want 1 or zero dimensions
        if( highest_dimension_of_element_matsets < 2 )
            mesh_info.num_dim = 3;
        else
            mesh_info.num_dim = highest_dimension_of_element_matsets;
    Range::iterator range_iter, end_range_iter;
    range_iter     = mesh_info.nodes.begin();
    end_range_iter = mesh_info.nodes.end();
    mesh_info.num_nodes = mesh_info.nodes.size();
    //------dirsets--------
    vector_iter     = dirsets.begin();
    end_vector_iter = dirsets.end();
    for( ; vector_iter != end_vector_iter; ++vector_iter )
        WriteTemplate::DirichletSetData dirset_data;
        dirset_data.id           = 0;
        dirset_data.number_nodes = 0;
        // Get the dirset's id
        if( mbImpl->tag_get_data( mDirichletSetTag, &( *vector_iter ), 1, &id ) != MB_SUCCESS )
            MB_SET_ERR( MB_FAILURE, "Couldn't get id tag for dirset " << id );
        dirset_data.id = id;
        std::vector< EntityHandle > node_vector;
        // Get the nodes of the dirset that are in mesh_info.nodes
        if( mbImpl->get_entities_by_handle( *vector_iter, node_vector, true ) != MB_SUCCESS )
            MB_SET_ERR( MB_FAILURE, "Couldn't get nodes in dirset " << id );
        std::vector< EntityHandle >::iterator iter, end_iter;
        iter     = node_vector.begin();
        end_iter = node_vector.end();
        int j                     = 0;
        unsigned char node_marked = 0;
        ErrorCode result;
        for( ; iter != end_iter; ++iter )
            if( TYPE_FROM_HANDLE( *iter ) != MBVERTEX ) continue;
            result = mbImpl->tag_get_data( mEntityMark, &( *iter ), 1, &node_marked );MB_CHK_SET_ERR( result, "Couldn't get mark data" );
            if( 0x1 == node_marked ) dirset_data.nodes.push_back( *iter );
            j++;
        dirset_data.number_nodes = dirset_data.nodes.size();
        dirset_info.push_back( dirset_data );
    //------neusets--------
    vector_iter     = neusets.begin();
    end_vector_iter = neusets.end();
        WriteTemplate::NeumannSetData neuset_data;
        // Get the neuset's id
        if( mbImpl->tag_get_data( mNeumannSetTag, &( *vector_iter ), 1, &id ) != MB_SUCCESS ) return MB_FAILURE;
        neuset_data.id              = id;
        neuset_data.mesh_set_handle = *vector_iter;
        // Get the sides in two lists, one forward the other reverse; starts with forward sense
        // by convention
        Range forward_elems, reverse_elems;
        if( get_neuset_elems( *vector_iter, 0, forward_elems, reverse_elems ) == MB_FAILURE ) return MB_FAILURE;
        ErrorCode result = get_valid_sides( forward_elems, 1, neuset_data );MB_CHK_SET_ERR( result, "Couldn't get valid sides data" );
        result = get_valid_sides( reverse_elems, -1, neuset_data );MB_CHK_SET_ERR( result, "Couldn't get valid sides data" );
        neuset_data.number_elements = neuset_data.elements.size();
        neuset_info.push_back( neuset_data );
    return MB_SUCCESS;
ErrorCode moab::WriteTemplate::get_neuset_elems ( EntityHandle  neuset,
int  current_sense,
Range reverse_elems
) [private]
Definition at line 600 of file WriteTemplate.cpp.
References moab::Range::begin(), moab::CN::Dimension(), moab::Range::end(), moab::Range::erase(), ErrorCode, moab::Interface::get_entities_by_handle(), MB_TYPE_INTEGER, MBENTITYSET, mbImpl, moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), and moab::TYPE_FROM_HANDLE().
Referenced by gather_mesh_information().
    Range neuset_elems, neuset_meshsets;
    // Get the sense tag; don't need to check return, might be an error if the tag
    // hasn't been created yet
    Tag sense_tag = 0;
    mbImpl->tag_get_handle( "SENSE", 1, MB_TYPE_INTEGER, sense_tag );
    // Get the entities in this set
    ErrorCode result = mbImpl->get_entities_by_handle( neuset, neuset_elems, true );
    if( MB_FAILURE == result ) return result;
    // Now remove the meshsets into the neuset_meshsets; first find the first meshset,
    Range::iterator range_iter = neuset_elems.begin();
    while( TYPE_FROM_HANDLE( *range_iter ) != MBENTITYSET && range_iter != neuset_elems.end() )
        ++range_iter;
    // Then, if there are some, copy them into neuset_meshsets and erase from neuset_elems
    if( range_iter != neuset_elems.end() )
        std::copy( range_iter, neuset_elems.end(), range_inserter( neuset_meshsets ) );
        neuset_elems.erase( range_iter, neuset_elems.end() );
    // OK, for the elements, check the sense of this set and copy into the right range
    // (if the sense is 0, copy into both ranges)
    // Need to step forward on list until we reach the right dimension
    Range::iterator dum_it = neuset_elems.end();
    --dum_it;
    int target_dim = CN::Dimension( TYPE_FROM_HANDLE( *dum_it ) );
    dum_it         = neuset_elems.begin();
    while( target_dim != CN::Dimension( TYPE_FROM_HANDLE( *dum_it ) ) && dum_it != neuset_elems.end() )
        ++dum_it;
    if( current_sense == 1 || current_sense == 0 )
        std::copy( dum_it, neuset_elems.end(), range_inserter( forward_elems ) );
    if( current_sense == -1 || current_sense == 0 )
        std::copy( dum_it, neuset_elems.end(), range_inserter( reverse_elems ) );
    // Now loop over the contained meshsets, getting the sense of those and calling this
    // function recursively
    for( range_iter = neuset_meshsets.begin(); range_iter != neuset_meshsets.end(); ++range_iter )
        // First get the sense; if it's not there, by convention it's forward
        int this_sense;
        if( 0 == sense_tag || MB_FAILURE == mbImpl->tag_get_data( sense_tag, &( *range_iter ), 1, &this_sense ) )
            this_sense = 1;
        // Now get all the entities on this meshset, with the proper (possibly reversed) sense
        get_neuset_elems( *range_iter, this_sense * current_sense, forward_elems, reverse_elems );
    return result;
ErrorCode moab::WriteTemplate::get_valid_sides ( Range elems,
const int  sense,
) [private]
Definition at line 394 of file WriteTemplate.cpp.
References moab::Range::begin(), moab::CN::Dimension(), moab::WriteTemplate::NeumannSetData::elements, moab::Range::end(), ErrorCode, moab::Interface::get_adjacencies(), moab::WriteTemplate::NeumannSetData::id, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, mbImpl, mEntityMark, moab::Interface::side_number(), moab::WriteTemplate::NeumannSetData::side_numbers, moab::Interface::tag_get_data(), and moab::TYPE_FROM_HANDLE().
    // This is where we see if underlying element of side set element is included in output
    unsigned char element_marked = 0;
    ErrorCode result;
    for( Range::iterator iter = elems.begin(); iter != elems.end(); ++iter )
        // Should insert here if "side" is a quad/tri on a quad/tri mesh
        result = mbImpl->tag_get_data( mEntityMark, &( *iter ), 1, &element_marked );MB_CHK_SET_ERR( result, "Couldn't get mark data" );
        if( 0x1 == element_marked )
            neuset_data.elements.push_back( *iter );
            // TJT TODO: the sense should really be # edges + 1or2
            neuset_data.side_numbers.push_back( ( sense == 1 ? 1 : 2 ) );
        else
        {  // Then "side" is probably a quad/tri on a hex/tet mesh
            std::vector< EntityHandle > parents;
            int dimension = CN::Dimension( TYPE_FROM_HANDLE( *iter ) );
            // Get the adjacent parent element of "side"
            if( mbImpl->get_adjacencies( &( *iter ), 1, dimension + 1, false, parents ) != MB_SUCCESS )
                MB_SET_ERR( MB_FAILURE, "Couldn't get adjacencies for neuset" );
            if( !parents.empty() )
                // Make sure the adjacent parent element will be output
                for( unsigned int k = 0; k < parents.size(); k++ )
                    result = mbImpl->tag_get_data( mEntityMark, &( parents[k] ), 1, &element_marked );MB_CHK_SET_ERR( result, "Couldn't get mark data" );
                    int side_no, this_sense, this_offset;
                    if( 0x1 == element_marked &&
                        mbImpl->side_number( parents[k], *iter, side_no, this_sense, this_offset ) == MB_SUCCESS &&
                        this_sense == sense )
                        neuset_data.elements.push_back( parents[k] );
                        neuset_data.side_numbers.push_back( side_no + 1 );
                        break;
            else
                MB_SET_ERR( MB_FAILURE, "No parent element exists for element in neuset " << neuset_data.id );
    return MB_SUCCESS;
Definition at line 558 of file WriteTemplate.cpp.
References MB_SUCCESS, moab::WriteTemplate::MeshInfo::num_dim, and moab::WriteTemplate::MeshInfo::num_nodes.
    // Perform the initializations
    int coord_size, ncoords;
    coord_size = mesh_info.num_dim;
    std::cout << "Coord_size = " << coord_size << std::endl;
    /* Template - write coord size */
    ncoords = mesh_info.num_nodes;
    std::cout << "ncoords = " << ncoords << std::endl;
    /* Template - write num nodes*/
    /* Template - write information on the element types & numbers (depends
       on material and other sets) */
    /* Node coordinate arrays: */
    /* Template - initialize variable to hold coordinate arrays */
    return MB_SUCCESS;
ErrorCode moab::WriteTemplate::open_file ( const char *  filename) [protected]
open a file for writing
Definition at line 581 of file WriteTemplate.cpp.
References MB_SET_ERR, and MB_SUCCESS.
    // Not a valid filename
    if( strlen( (const char*)filename ) == 0 )
        MB_SET_ERR( MB_FAILURE, "Output filename not specified" );
    /* Template - open file & store somewhere */
    // File couldn't be opened
    if( /* Template - check for file open error here! */ false )
        MB_SET_ERR( MB_FAILURE, "Cannot open " << filename );
    return MB_SUCCESS;
void moab::WriteTemplate::reset_matset ( std::vector< MaterialSetData > &  matset_info) [private]
Definition at line 83 of file WriteTemplate.cpp.
    std::vector< WriteTemplate::MaterialSetData >::iterator iter;
    for( iter = matset_info.begin(); iter != matset_info.end(); ++iter )
        delete( *iter ).elements;
ErrorCode moab::WriteTemplate::write_file ( const char *  file_name,
const FileOptions opts,
const EntityHandle output_list,
const int  num_sets,
const std::vector< std::string > &  qa_list,
const Tag tag_list = NULL,
int  num_tags = 0,
int  export_dimension = 3
) [virtual]
writes out a file
Implements moab::WriterIface.
Definition at line 91 of file WriteTemplate.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::Range::end(), fileName, gather_mesh_information(), moab::Interface::get_entities_by_type_and_tag(), initialize_file(), MB_FILE_WRITE_ERROR, MB_SUCCESS, MBENTITYSET, mbImpl, mDirichletSetTag, mMaterialSetTag, mNeumannSetTag, moab::WriteTemplate::MeshInfo::nodes, moab::WriteTemplate::MeshInfo::num_dim, moab::WriteTemplate::MeshInfo::num_nodes, reset_matset(), moab::Interface::tag_get_data(), write_matsets(), and write_nodes().
    assert( 0 != mMaterialSetTag && 0 != mNeumannSetTag && 0 != mDirichletSetTag );
    // Check the file name
    if( NULL == strstr( file_name, ".template" ) ) return MB_FAILURE;
    std::vector< EntityHandle > matsets, dirsets, neusets;
    fileName = file_name;
    // Separate into material sets, dirichlet sets, neumann sets
    if( num_sets == 0 )
        // Default to all defined sets
        Range this_range;
        mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &mMaterialSetTag, NULL, 1, this_range );
        std::copy( this_range.begin(), this_range.end(), std::back_inserter( matsets ) );
        this_range.clear();
        mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &mDirichletSetTag, NULL, 1, this_range );
        std::copy( this_range.begin(), this_range.end(), std::back_inserter( dirsets ) );
        this_range.clear();
        mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &mNeumannSetTag, NULL, 1, this_range );
        std::copy( this_range.begin(), this_range.end(), std::back_inserter( neusets ) );
    else
        int dummy;
        for( const EntityHandle* iter = ent_handles; iter < ent_handles + num_sets; ++iter )
            if( MB_SUCCESS == mbImpl->tag_get_data( mMaterialSetTag, &( *iter ), 1, &dummy ) )
                matsets.push_back( *iter );
            else if( MB_SUCCESS == mbImpl->tag_get_data( mDirichletSetTag, &( *iter ), 1, &dummy ) )
                dirsets.push_back( *iter );
            else if( MB_SUCCESS == mbImpl->tag_get_data( mNeumannSetTag, &( *iter ), 1, &dummy ) )
                neusets.push_back( *iter );
    // If there is nothing to write just return.
    if( matsets.empty() && dirsets.empty() && neusets.empty() ) return MB_FILE_WRITE_ERROR;
    std::vector< WriteTemplate::MaterialSetData > matset_info;
    std::vector< WriteTemplate::DirichletSetData > dirset_info;
    std::vector< WriteTemplate::NeumannSetData > neuset_info;
    MeshInfo mesh_info;
    matset_info.clear();
    if( gather_mesh_information( mesh_info, matset_info, neuset_info, dirset_info, matsets, neusets, dirsets ) !=
        MB_SUCCESS )
        reset_matset( matset_info );
        return MB_FAILURE;
    // Try to open the file after gather mesh info succeeds
    if( /* Test for file open failure */ false )
        return MB_FAILURE;
    if( initialize_file( mesh_info ) != MB_SUCCESS )
        return MB_FAILURE;
    if( write_nodes( mesh_info.num_nodes, mesh_info.nodes, mesh_info.num_dim ) != MB_SUCCESS )
        return MB_FAILURE;
    if( write_matsets( mesh_info, matset_info, neuset_info ) )
        return MB_FAILURE;
    return MB_SUCCESS;
ErrorCode moab::WriteTemplate::write_matsets ( MeshInfo mesh_info,
std::vector< MaterialSetData > &  matset_data,
std::vector< NeumannSetData > &  neuset_data
) [private]
Definition at line 518 of file WriteTemplate.cpp.
References moab::Range::begin(), moab::WriteTemplate::MaterialSetData::elements, moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), MB_SUCCESS, mbImpl, mGlobalIdTag, and moab::Interface::tag_get_data().
    unsigned int i;
    std::vector< int > connect;
    const EntityHandle* connecth;
    int num_connecth;
    ErrorCode result;
    // Don't usually have anywhere near 31 nodes per element
    connect.reserve( 31 );
    Range::iterator rit;
    WriteTemplate::MaterialSetData matset;
    for( i = 0; i < matset_data.size(); i++ )
        matset = matset_data[i];
        for( rit = matset.elements->begin(); rit != matset.elements->end(); ++rit )
            // Get the connectivity of this element
            result = mbImpl->get_connectivity( *rit, connecth, num_connecth );
            if( MB_SUCCESS != result ) return result;
            // Get the vertex ids
            result = mbImpl->tag_get_data( mGlobalIdTag, connecth, num_connecth, &connect[0] );
            // Write the data
            /* Template - write element connectivity here */
            if( /* Template - check for error condition! */ false ) return MB_FAILURE;
    return MB_SUCCESS;
ErrorCode moab::WriteTemplate::write_nodes ( const int  num_nodes,
const Range nodes,
const int  dimension
) [private]
Definition at line 451 of file WriteTemplate.cpp.
References ErrorCode, moab::WriteUtilIface::get_node_coords(), MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_NOT_FOUND, MB_TYPE_DOUBLE, mbImpl, mesh, MESH_TRANSFORM_TAG_NAME, mGlobalIdTag, mWriteIface, moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
    // See if should transform coordinates
    ErrorCode result;
    Tag trans_tag;
    result                = mbImpl->tag_get_handle( MESH_TRANSFORM_TAG_NAME, 16, MB_TYPE_DOUBLE, trans_tag );
    bool transform_needed = true;
    if( result == MB_TAG_NOT_FOUND ) transform_needed = false;
    int num_coords_to_fill = transform_needed ? 3 : dimension;
    std::vector< double* > coord_arrays( 3 );
    coord_arrays[0] = new double[num_nodes];
    coord_arrays[1] = new double[num_nodes];
    coord_arrays[2] = NULL;
    if( num_coords_to_fill == 3 ) coord_arrays[2] = new double[num_nodes];
    result = mWriteIface->get_node_coords( dimension, num_nodes, nodes, mGlobalIdTag, 0, coord_arrays );
    if( result != MB_SUCCESS )
        delete[] coord_arrays[0];
        delete[] coord_arrays[1];
        if( coord_arrays[2] ) delete[] coord_arrays[2];
        return result;
    if( transform_needed )
        double trans_matrix[16];
        const EntityHandle mesh = 0;
        result                  = mbImpl->tag_get_data( trans_tag, &mesh, 1, trans_matrix );MB_CHK_SET_ERR( result, "Couldn't get transform data" );
        for( int i = 0; i < num_nodes; i++ )
            double vec1[3];
            double vec2[3];
            vec2[0] = coord_arrays[0][i];
            vec2[1] = coord_arrays[1][i];
            vec2[2] = coord_arrays[2][i];
            for( int row = 0; row < 3; row++ )
                vec1[row] = 0.0;
                for( int col = 0; col < 3; col++ )
                    vec1[row] += ( trans_matrix[( row * 4 ) + col] * vec2[col] );
            coord_arrays[0][i] = vec1[0];
            coord_arrays[1][i] = vec1[1];
            coord_arrays[2][i] = vec1[2];
    // Write the nodes
    /* Template - write nodes to file here in some way */
    // Clean up
    return MB_SUCCESS;
Member Data Documentation
std::string moab::WriteTemplate::fileName [private]
file name
Definition at line 138 of file WriteTemplate.hpp.
Definition at line 145 of file WriteTemplate.hpp.
Referenced by write_matsets(), write_nodes(), and WriteTemplate().
Cached tags for reading. Note that all these tags are defined when the core is initialized.
Definition at line 142 of file WriteTemplate.hpp.
Referenced by gather_mesh_information(), write_file(), and WriteTemplate().
List of all members.
