moab::gs_data Class Reference
#include <gs.hpp>
Classes
class  crystal_data
Public Member Functions
 gs_data (uint n, const long *label, const Ulong *ulabel, uint maxv, const unsigned int nlabels, const unsigned int nulabels, crystal_data *crystal, ErrorCode &Init_Result)
 gs_data ()
 ~gs_data ()
ErrorCode initialize (uint n, const long *label, const Ulong *ulabel, uint maxv, const unsigned int nlabels, const unsigned int nulabels, crystal_data *crystal)
void reset ()
void gs_data_op (realType *u, int op)
void gs_data_op_vec (realType *u, uint n, int op)
void gs_data_op_many (realType **u, uint n, int op)
Public Attributes
sintlocal_cm
Detailed Description
Definition at line 15 of file gs.hpp.
moab::gs_data::gs_data ( uint  n,
const long *  label,
const Ulong ulabel,
uint  maxv,
crystal_data crystal,
ErrorCode Init_Result
) [inline]
Constructor for moab_gs_data: takes all arguments and initializes moab_gs_data. If needs_reset is false after calling constructor, initialization has failed.
param n number of tuples in tuple list param label pointer to signed labels param ulabel pointer to unsigned labels param maxv max vector size param nlabels number of signed long labels (not including gid) param nulabels number of unsigned long labels param crystal moab_crystal_data contains MPI_Comm and is used for message passing
Definition at line 199 of file gs.hpp.
References initialize().
        Init_Result = this->initialize( n, label, ulabel, maxv, nlabels, nulabels, crystal );
moab::gs_data::gs_data ( ) [inline]
Default constructor (Note: moab_gs_data must be initialized before use!)
Definition at line 214 of file gs.hpp.
Definition at line 216 of file gs.hpp.
References reset().
        reset();
Member Function Documentation
void moab::gs_data::gs_data_op ( realType u,
int  op
Definition at line 751 of file gs.cpp.
References local_cm, moab::local_condense(), and moab::local_uncondense().
    local_condense( u, op, this->local_cm );
#ifdef MOAB_HAVE_MPI
    this->nlinfo->nonlocal( u, op, _comm );
#endif
    local_uncondense( u, local_cm );
void moab::gs_data::gs_data_op_many ( realType **  u,
uint  n,
int  op
Definition at line 775 of file gs.cpp.
References moab::fail(), local_cm, moab::local_condense(), and moab::local_uncondense().
    uint i;
    if( n > nlinfo->_maxv )
        moab::fail( "%s: initialized with max vec size = %d,"
                    " but called with vec size = %d\n",
                    __FILE__, nlinfo->_maxv, n );
#endif
    for( i = 0; i < n; ++i )
        local_condense( u[i], op, local_cm );
                __FILE__, 6, n );
    this->nlinfo->nonlocal_many( u, n, op, _comm );
#endif
        local_uncondense( u[i], local_cm );
void moab::gs_data::gs_data_op_vec ( realType u,
uint  n,
int  op
Definition at line 760 of file gs.cpp.
References moab::fail(), local_cm, moab::local_condense_vec(), and moab::local_uncondense_vec().
#endif
    local_condense_vec( u, n, op, local_cm );
    this->nlinfo->nonlocal_vec( u, n, op, _comm );
#endif
    local_uncondense_vec( u, n, local_cm );
ErrorCode moab::gs_data::initialize ( uint  n,
const long *  label,
const Ulong ulabel,
uint  maxv,
Sets up the moab_gs_data; see constructor for parameter documentation
Definition at line 802 of file gs.cpp.
References moab::TupleList::enableWriteAccess(), ErrorCode, moab::TupleList::get_max(), moab::TupleList::get_n(), moab::TupleList::inc_n(), moab::TupleList::initialize(), local_cm, MB_SUCCESS, moab::TupleList::buffer::reset(), moab::TupleList::reset(), moab::TupleList::resize(), moab::TupleList::sort(), VALGRIND_CHECK_MEM_IS_DEFINED, moab::TupleList::vi_wr, moab::TupleList::vl_wr, and moab::TupleList::vul_wr.
Referenced by gs_data(), moab::ParallelComm::resolve_shared_ents(), and moab::ParallelComm::resolve_shared_sets().
    nlinfo = NULL;
    unsigned int j;
    TupleList nonzero, primary;
    ErrorCode rval;
    TupleList shared;
#else
    moab::TupleList::buffer buf;
#endif
    (void)VALGRIND_CHECK_MEM_IS_DEFINED( label, nlabels * sizeof( long ) );
    (void)VALGRIND_CHECK_MEM_IS_DEFINED( ulabel, nlabels * sizeof( Ulong ) );
    MPI_Comm_dup( crystal->_comm, &this->_comm );
#else
    buf.buffer_init( 1024 );
#endif
    /* construct list of nonzeros: (index ^, label) */
    nonzero.initialize( 1, nlabels, nulabels, 0, n );
    nonzero.enableWriteAccess();
        uint i;
        sint* nzi;
        long* nzl;
        Ulong* nzul;
        nzi  = nonzero.vi_wr;
        nzl  = nonzero.vl_wr;
        nzul = nonzero.vul_wr;
            if( label[nlabels * i] != 0 )
                nzi[0] = i;
                for( j = 0; j < nlabels; j++ )
                    nzl[j] = label[nlabels * i + j];
                for( j = 0; j < nulabels; j++ )
                    nzul[j] = ulabel[nulabels * i + j];
                nzi++;
                nzl += nlabels;
                nzul += nulabels;
                nonzero.inc_n();
    /* sort nonzeros by label: (index ^2, label ^1) */
#ifndef MOAB_HAVE_MPI
    nonzero.sort( 1, &buf );
#else
    nonzero.sort( 1, &crystal->all->buf );
#endif
    /* build list of unique labels w/ lowest associated index:
     (index in nonzero ^, primary (lowest) index in label, count, label(s),
     ulabel(s)) */
    primary.initialize( 3, nlabels, nulabels, 0, nonzero.get_n() );
    primary.enableWriteAccess();
        uint i;
        sint *nzi = nonzero.vi_wr, *pi = primary.vi_wr;
        slong *nzl = nonzero.vl_wr, *pl = primary.vl_wr;
        Ulong *nzul = nonzero.vul_wr, *pul = primary.vul_wr;
        slong last = -1;
        for( i = 0; i < nonzero.get_n(); ++i, nzi += 1, nzl += nlabels, nzul += nulabels )
            if( nzl[0] == last )
                ++pi[-1];
                continue;
            last  = nzl[0];
            pi[0] = i;
            pi[1] = nzi[0];
                pl[j] = nzl[j];
                pul[j] = nzul[j];
            pi[2] = 1;
            pi += 3, pl += nlabels;
            pul += nulabels;
            primary.inc_n();
    /* calculate size of local condense map */
        uint i, count = 1;
        sint* pi = primary.vi_wr;
        for( i = primary.get_n(); i; --i, pi += 3 )
            if( pi[2] > 1 ) count += pi[2] + 1;
        this->local_cm = (sint*)malloc( count * sizeof( sint ) );
    /* sort unique labels by primary index:
     (nonzero index ^2, primary index ^1, count, label ^2) */
    primary.sort( 0, &buf );
    buf.reset();
    // buffer_free(&buf);
#else
    primary.sort( 0, &crystal->all->buf );
#endif
    /* construct local condense map */
        uint i, ln;
        sint* cm = this->local_cm;
        for( i = primary.get_n(); i > 0; --i, pi += 3 )
            if( ( ln = pi[2] ) > 1 )
                sint* nzi = nonzero.vi_wr + 1 * pi[0];
                for( j = ln; j > 0; --j, nzi += 1 )
                    *cm++ = nzi[0];
                *cm++ = -1;
        *cm++ = -1;
    nonzero.reset();
    primary.reset();
#else
    /* assign work proc by label modulo np */
        uint i;
        slong* pl = primary.vl_wr;
        for( i = primary.get_n(); i; --i, pi += 3, pl += nlabels )
            pi[0] = pl[0] % crystal->_num;
    rval = crystal->gs_transfer( 1, primary, 0 ); /* transfer to work procs */
    if( rval != MB_SUCCESS ) return rval;
    /* primary: (source proc, index on src, useless, label) */
    /* sort by label */
    primary.sort( 3, &crystal->all->buf );
    /* add sentinel to primary list */
    if( primary.get_n() == primary.get_max() )
        primary.resize( ( primary.get_max() ? primary.get_max() + ( primary.get_max() + 1 ) / 2 + 1 : 2 ) );
    primary.vl_wr[nlabels * primary.get_n()] = -1;
    /* construct shared list: (proc1, proc2, index1, label) */
    shared.initialize( 3, nlabels, nulabels, 0, primary.get_n() );
    shared.enableWriteAccess();
#endif
        sint *pi1 = primary.vi_wr, *si = shared.vi_wr;
        slong lbl, *pl1 = primary.vl_wr, *sl = shared.vl_wr;
        Ulong *pul1 = primary.vul_wr, *sul = shared.vul_wr;
        for( ; ( lbl = pl1[0] ) != -1; pi1 += 3, pl1 += nlabels, pul1 += nulabels )
            sint* pi2   = pi1 + 3;
            slong* pl2  = pl1 + nlabels;
            Ulong* pul2 = pul1 + nulabels;
            for( ; pl2[0] == lbl; pi2 += 3, pl2 += nlabels, pul2 += nulabels )
                if( shared.get_n() + 2 > shared.get_max() )
                    shared.resize( ( shared.get_max() ? shared.get_max() + ( shared.get_max() + 1 ) / 2 + 1 : 2 ) ),
                        si = shared.vi_wr + shared.get_n() * 3;
                sl    = shared.vl_wr + shared.get_n() * nlabels;
                sul   = shared.vul_wr + shared.get_n() * nulabels;
                si[0] = pi1[0];
                si[1] = pi2[0];
                si[2] = pi1[1];
                    sl[j] = pl2[j];
                    sul[j] = pul2[j];
                si += 3;
                sl += nlabels;
                sul += nulabels;
                shared.inc_n();
                si[0] = pi2[0];
                si[1] = pi1[0];
                si[2] = pi2[1];
                    sl[j] = pl1[j];
                    sul[j] = pul1[j];
                si += 3;
                sl += nlabels;
                sul += nulabels;
                shared.inc_n();
    primary.reset();
    rval = crystal->gs_transfer( 1, shared, 0 ); /* segfaulting transfer to dest procs */
    /* shared list: (useless, proc2, index, label) */
    /* sort by label */
    shared.sort( 3, &crystal->all->buf );
    /* sort by partner proc */
    shared.sort( 1, &crystal->all->buf );
    /* count partner procs */
        uint i, count = 0;
        sint proc = -1, *si = shared.vi_wr;
        for( i = shared.get_n(); i; --i, si += 3 )
            if( si[1] != proc )
                ++count;
                proc = si[1];
        // this->nlinfo = new nonlocal_info();
        // this->nlinfo->initialize(count,shared.get_n(),
        //                          nlabels, nulabels, maxv);
        this->nlinfo = new nonlocal_info( count, shared.get_n(), nlabels, nulabels, maxv );
    /* construct non-local info */
        uint i;
        slong* sl      = shared.vl_wr;
        Ulong* ul      = shared.vul_wr;
        uint* target   = this->nlinfo->_target;
        uint* nshared  = this->nlinfo->_nshared;
        uint* sh_ind   = this->nlinfo->_sh_ind;
        slong* slabels = this->nlinfo->_slabels;
        Ulong* ulabels = this->nlinfo->_ulabels;
            if( si[1] != proc )
                proc       = si[1];
                *target++  = proc;
                *nshared++ = 0;
            ++nshared[-1];
            *sh_ind++ = si[2];
            // don't store 1st slabel
            sl++;
            for( j = 0; j < nlabels - 1; j++ )
                slabels[j] = sl[j];
                ulabels[j] = ul[j];
            slabels += nlabels - 1;
            ulabels += nulabels;
            sl += nlabels - 1;
            ul += nulabels;
    shared.reset();
#endif
    return MB_SUCCESS;
Definition at line 1054 of file gs.cpp.
References local_cm.
Referenced by moab::ParallelComm::resolve_shared_ents(), moab::ParallelComm::resolve_shared_sets(), and ~gs_data().
    free( local_cm );
    local_cm = NULL;
    if( nlinfo != NULL )
        nlinfo->nlinfo_free();
        delete this->nlinfo;
        MPI_Comm_free( &_comm );
        nlinfo = NULL;
#endif
Member Data Documentation
List of all members.
