smoab::detail::LinearCellConnectivity Class Reference
#include <LinearCellConnectivity.h>
Public Member Functions
 LinearCellConnectivity (smoab::Range const &cells, moab::Interface *moab)
void compactIds (vtkIdType &numCells, vtkIdType &connectivityLength)
void moabPoints (smoab::Range &range) const
void copyConnectivity (std::vector< EntityHandle > &output) const
void copyToVtkCellInfo (vtkIdType *cellArray) const
Private Types
typedef std::vector
< EntityHandle >
::const_iterator
EntityConstIterator
typedef std::vector
< internal::SubsetArray >
::const_iterator
ConnConstIterator
typedef std::vector
< detail::ContinousCellInfo >
::const_iterator
InfoConstIterator
Private Attributes
std::vector
Connectivity
std::vector< EntityHandleUniquePoints
std::vector
Info
Detailed Description
Definition at line 67 of file LinearCellConnectivity.h.
Member Typedef Documentation
typedef std::vector< internal::SubsetArray >::const_iterator smoab::detail::LinearCellConnectivity::ConnConstIterator [private]
Definition at line 203 of file LinearCellConnectivity.h.
typedef std::vector< EntityHandle >::const_iterator smoab::detail::LinearCellConnectivity::EntityConstIterator [private]
Definition at line 202 of file LinearCellConnectivity.h.
Definition at line 204 of file LinearCellConnectivity.h.
Definition at line 70 of file LinearCellConnectivity.h.
References moab::Range::begin(), moab::Interface::connect_iterate(), Connectivity, moab::Range::end(), Info, moab::Range::size(), moab::Interface::type_from_handle(), smoab::detail::vtkCellType(), and smoab::detail::vtkLinearCellType().
            : Connectivity(), UniquePoints(), Info()
            int count                  = 0;
            const std::size_t cellSize = cells.size();
            while( count != cellSize )
                EntityHandle* connectivity;
                int numVerts = 0, iterationCount = 0;
                //use the highly efficent calls, since we know that are of the same dimension
                moab->connect_iterate( cells.begin() + count, cells.end(), connectivity, numVerts, iterationCount );
                //if we didn't read anything, break!
                if( iterationCount == 0 )
                    break;
                //identify the cell type that we currently have,
                //store that along with the connectivity in a temp storage vector
                const moab::EntityType type = moab->type_from_handle( *cells.begin() + count );
                int vtkNumVerts;
                int vtkCellType = smoab::detail::vtkLinearCellType( type, vtkNumVerts );
                ContinousCellInfo info = { vtkCellType, vtkNumVerts, 0, iterationCount };
                this->Info.push_back( info );
                //we need to copy only a subset of the connectivity array
                internal::SubsetArray conn( connectivity, iterationCount, numVerts, vtkNumVerts );
                this->Connectivity.push_back( conn );
                count += iterationCount;
Member Function Documentation
void smoab::detail::LinearCellConnectivity::compactIds ( vtkIdType &  numCells,
vtkIdType &  connectivityLength
) [inline]
Definition at line 106 of file LinearCellConnectivity.h.
References copyConnectivity(), Info, and UniquePoints.
Referenced by smoab::detail::LoadPoly::fill().
            //converts all the ids to be ordered starting at zero, and also
            //keeping the orginal logical ordering. Stores the result of this
            //operation in the unstrucutred grid that is passed in
            //lets determine the total length of the connectivity
            connectivityLength = 0;
            numCells           = 0;
            for( InfoConstIterator i = this->Info.begin(); i != this->Info.end(); ++i )
                connectivityLength += ( *i ).numCells * ( *i ).numVerts;
                numCells += ( *i ).numCells;
            this->UniquePoints.reserve( connectivityLength );
            this->copyConnectivity( this->UniquePoints );
            std::sort( this->UniquePoints.begin(), this->UniquePoints.end() );
            typedef std::vector< EntityHandle >::iterator EntityIterator;
            EntityIterator newEnd = std::unique( this->UniquePoints.begin(), this->UniquePoints.end() );
            const std::size_t newSize = std::distance( this->UniquePoints.begin(), newEnd );
            this->UniquePoints.resize( newSize );
void smoab::detail::LinearCellConnectivity::copyConnectivity ( std::vector< EntityHandle > &  output) const [inline]
Definition at line 143 of file LinearCellConnectivity.h.
References Connectivity, and Info.
Referenced by compactIds().
            //walk the info to find the length of each sub connectivity array,
            //and insert them into the vector, ordering is implied by the order
            //the connecitivy sub array are added to this class
            ConnConstIterator c = this->Connectivity.begin();
            for( InfoConstIterator i = this->Info.begin(); i != this->Info.end(); ++i, ++c )
                //remember our Connectivity is a vector of pointers whose
                //length is held in the info vector.
                const int numUnusedPoints = ( *i ).numUnusedVerts;
                const int connLength      = ( *i ).numCells * ( *i ).numVerts;
                std::copy( c->begin(), c->end(), std::back_inserter( output ) );
void smoab::detail::LinearCellConnectivity::copyToVtkCellInfo ( vtkIdType *  cellArray) const [inline]
Definition at line 161 of file LinearCellConnectivity.h.
References Connectivity, Info, and UniquePoints.
Referenced by smoab::detail::LoadPoly::addGridsTopology().
                //for this group of the same cell type we need to fill the cellTypes
                const int numCells = ( *i ).numCells;
                const int numVerts = ( *i ).numVerts;
                //for each cell in this collection that have the same type
                //grab the raw array now, so we can properly increment for each vert in each cell
                internal::SubsetArray::const_iterator moabConnectivity = c->begin();
                for( int j = 0; j < numCells; ++j )
                    //cell arrays start and end are different, since we
                    //have to account for element that states the length of each cell
                    cellArray[0] = numVerts;
                    for( int k = 0; k < numVerts; ++k, ++moabConnectivity )
                        //this is going to be a root of some failures when we start
                        //reading really large datasets under 32bit.
                        //fyi, don't use a range ds for unique points, distance
                        //function is horribly slow they need to override it
                        EntityConstIterator result =
                            std::lower_bound( this->UniquePoints.begin(), this->UniquePoints.end(), *moabConnectivity );
                        std::size_t newId = std::distance( this->UniquePoints.begin(), result );
                        cellArray[k + 1]  = static_cast< vtkIdType >( newId );
                    cellArray += numVerts + 1;
Definition at line 134 of file LinearCellConnectivity.h.
References UniquePoints.
Referenced by smoab::detail::LoadPoly::addCoordinates().
            //from the documentation a reverse iterator is the fastest way
            //to insert into a range.
            std::copy( this->UniquePoints.rbegin(), this->UniquePoints.rend(), moab::range_inserter( range ) );
Member Data Documentation
List of all members.
