smoab::detail::UsageTable Class Reference
#include <UsageTable.h>
Public Member Functions
void incrementUsage (const std::vector< smoab::EntityHandle > &entities, const std::vector< int > &usageId)
smoab::Range multipleUsage () const
smoab::Range singleUsage () const
Private Attributes
std::vector< smoab::EntityHandleMultipleUsageIds
std::set< internal::KeyTypeSingleUsageIds
Detailed Description
Definition at line 68 of file UsageTable.h.
Member Function Documentation
void smoab::detail::UsageTable::incrementUsage ( const std::vector< smoab::EntityHandle > &  entities,
const std::vector< int > &  usageId
Definition at line 82 of file UsageTable.h.
References MultipleUsageIds, SingleUsageIds, and usage.
Referenced by smoab::ExtractShell::findSkins().
        typedef std::vector< smoab::EntityHandle >::const_iterator iterator;
        typedef std::vector< int >::const_iterator uiterator;
        uiterator usage = usageId.begin();
        for( iterator i = entities.begin(); i != entities.end(); ++i, ++usage )
            internal::KeyType key( *i, *usage );
            if( this->SingleUsageIds.find( key ) != this->SingleUsageIds.end() )
                this->SingleUsageIds.erase( key );
                this->MultipleUsageIds.push_back( *i );
            else
                this->SingleUsageIds.insert( key );
Definition at line 105 of file UsageTable.h.
References MultipleUsageIds.
        smoab::Range multiples;
        std::copy( this->MultipleUsageIds.rbegin(), this->MultipleUsageIds.rend(), moab::range_inserter( multiples ) );
        return multiples;
Definition at line 113 of file UsageTable.h.
References SingleUsageIds.
        smoab::Range single;
        std::copy( this->SingleUsageIds.rbegin(), this->SingleUsageIds.rend(), internal::key_inserter( single ) );
        return single;
Member Data Documentation
Definition at line 77 of file UsageTable.h.
Referenced by incrementUsage(), and multipleUsage().
Definition at line 78 of file UsageTable.h.
Referenced by incrementUsage(), and singleUsage().
List of all members.
