connectivity.c
00001 /**
00002  * MOAB, a Mesh-Oriented datABase, is a software component for creating,
00003  * storing and accessing finite element mesh data.
00004  *
00005  * Copyright 2004 Sandia Corporation.  Under the terms of Contract
00006  * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government
00007  * retains certain rights in this software.
00008  *
00009  * This library is free software; you can redistribute it and/or
00010  * modify it under the terms of the GNU Lesser General Public
00011  * License as published by the Free Software Foundation; either
00012  * version 2.1 of the License, or (at your option) any later version.
00013  *
00014  */
00015
00016 #include <H5Tpublic.h>
00017 #include <H5Dpublic.h>
00018 #include <H5Gpublic.h>
00019 #include <H5Ppublic.h>
00020 #include "mhdf.h"
00021 #include "util.h"
00022 #include "file-handle.h"
00023 #include "status.h"
00024 #include "names-and-paths.h"
00025
00026 hid_t mhdf_createConnectivity( mhdf_FileHandle file_handle,
00027                                const char* elem_handle,
00028                                int nodes_per_elem,
00029                                long count,
00030                                long* first_id_out,
00031                                mhdf_Status* status )
00032 {
00033     FileHandle* file_ptr;
00034     hid_t elem_id, table_id;
00035     hsize_t dims[2];
00036     long first_id;
00037     API_BEGIN;
00038
00039     file_ptr = (FileHandle*)( file_handle );
00040     if( !mhdf_check_valid_file( file_ptr, status ) ) return -1;
00041
00042     if( nodes_per_elem <= 0 || count < 0 || !first_id_out )
00043     {
00044         mhdf_setFail( status, "Invalid argument." );
00045         return -1;
00046     }
00047
00048     elem_id = mhdf_elem_group_from_handle( file_ptr, elem_handle, status );
00049     if( elem_id < 0 ) return -1;
00050
00051     dims[0]  = (hsize_t)count;
00052     dims[1]  = (hsize_t)nodes_per_elem;
00053     table_id = mhdf_create_table( elem_id, CONNECTIVITY_NAME, file_ptr->id_type, 2, dims, status );
00054     H5Gclose( elem_id );
00055     if( table_id < 0 ) return -1;
00056
00057     first_id = file_ptr->max_id + 1;
00058     if( !mhdf_create_scalar_attrib( table_id, START_ID_ATTRIB, H5T_NATIVE_LONG, &first_id, status ) )
00059     {
00060         H5Dclose( table_id );
00061         return -1;
00062     }
00063
00064     *first_id_out = first_id;
00065     file_ptr->max_id += count;
00066     if( !mhdf_write_max_id( file_ptr, status ) )
00067     {
00068         H5Dclose( table_id );
00069         return -1;
00070     }
00071     file_ptr->open_handle_count++;
00072     mhdf_setOkay( status );
00073
00074     API_END_H( 1 );
00075     return table_id;
00076 }
00077
00078 hid_t mhdf_openConnectivity( mhdf_FileHandle file_handle,
00079                              const char* elem_handle,
00080                              int* num_nodes_per_elem_out,
00081                              long* num_elements_out,
00082                              long* first_elem_id_out,
00083                              mhdf_Status* status )
00084 {
00085     FileHandle* file_ptr;
00086     hid_t elem_id, table_id;
00087     hsize_t dims[2];
00088     API_BEGIN;
00089
00090     file_ptr = (FileHandle*)( file_handle );
00091     if( !mhdf_check_valid_file( file_ptr, status ) ) return -1;
00092
00093     if( !num_nodes_per_elem_out || !num_elements_out || !first_elem_id_out )
00094     {
00095         mhdf_setFail( status, "Invalid argument." );
00096         return -1;
00097     }
00098
00099     elem_id = mhdf_elem_group_from_handle( file_ptr, elem_handle, status );
00100     if( elem_id < 0 ) return -1;
00101
00102     table_id = mhdf_open_table2( elem_id, CONNECTIVITY_NAME, 2, dims, first_elem_id_out, status );
00103
00104     H5Gclose( elem_id );
00105     if( table_id < 0 ) return -1;
00106
00107     *num_elements_out       = dims[0];
00108     *num_nodes_per_elem_out = dims[1];
00109
00110     file_ptr->open_handle_count++;
00111     mhdf_setOkay( status );
00112     API_END_H( 1 );
00113     return table_id;
00114 }
00115
00116 hid_t mhdf_openConnectivitySimple( mhdf_FileHandle file_handle, const char* elem_handle, mhdf_Status* status )
00117 {
00118     FileHandle* file_ptr;
00119     hid_t elem_id, table_id;
00120     API_BEGIN;
00121
00122     file_ptr = (FileHandle*)( file_handle );
00123     if( !mhdf_check_valid_file( file_ptr, status ) ) return -1;
00124
00125     elem_id = mhdf_elem_group_from_handle( file_ptr, elem_handle, status );
00126     if( elem_id < 0 ) return -1;
00127
00128     table_id = mhdf_open_table_simple( elem_id, CONNECTIVITY_NAME, status );
00129
00130     H5Gclose( elem_id );
00131     if( table_id < 0 ) return -1;
00132
00133     file_ptr->open_handle_count++;
00134     mhdf_setOkay( status );
00135     API_END_H( 1 );
00136     return table_id;
00137 }
00138
00139 void mhdf_writeConnectivity( hid_t table_id,
00140                              long offset,
00141                              long count,
00142                              hid_t hdf_integer_type,
00143                              const void* nodes,
00144                              mhdf_Status* status )
00145 {
00146     API_BEGIN;
00147     mhdf_write_data( table_id, offset, count, hdf_integer_type, nodes, H5P_DEFAULT, status );
00148     API_END;
00149 }
00150 void mhdf_writeConnectivityWithOpt( hid_t table_id,
00151                                     long offset,
00152                                     long count,
00153                                     hid_t hdf_integer_type,
00154                                     const void* nodes,
00155                                     hid_t prop,
00156                                     mhdf_Status* status )
00157 {
00158     API_BEGIN;
00159     mhdf_write_data( table_id, offset, count, hdf_integer_type, nodes, prop, status );
00160     API_END;
00161 }
00162
00163 void mhdf_readConnectivity( hid_t table_id,
00164                             long offset,
00165                             long count,
00166                             hid_t hdf_integer_type,
00167                             void* nodes,
00168                             mhdf_Status* status )
00169 {
00170     API_BEGIN;
00171     mhdf_read_data( table_id, offset, count, hdf_integer_type, nodes, H5P_DEFAULT, status );
00172     API_END;
00173 }
00174 void mhdf_readConnectivityWithOpt( hid_t table_id,
00175                                    long offset,
00176                                    long count,
00177                                    hid_t hdf_integer_type,
00178                                    void* nodes,
00179                                    hid_t prop,
00180                                    mhdf_Status* status )
00181 {
00182     API_BEGIN;
00183     mhdf_read_data( table_id, offset, count, hdf_integer_type, nodes, prop, status );
00184     API_END;
00185 }
00186
00187 void mhdf_createPolyConnectivity( mhdf_FileHandle file_handle,
00188                                   const char* elem_type,
00189                                   long num_poly,
00190                                   long data_list_length,
00191                                   long* first_id_out,
00192                                   hid_t handles_out[2],
00193                                   mhdf_Status* status )
00194 {
00195     FileHandle* file_ptr;
00196     hid_t elem_id, index_id, conn_id;
00197     hsize_t dim;
00198     long first_id;
00199     API_BEGIN;
00200
00201     file_ptr = (FileHandle*)( file_handle );
00202     if( !mhdf_check_valid_file( file_ptr, status ) ) return;
00203
00204     if( num_poly <= 0 || data_list_length <= 0 || !first_id_out )
00205     {
00206         mhdf_setFail( status, "Invalid argument." );
00207         return;
00208     }
00209
00210     if( data_list_length < 3 * num_poly )
00211     {
00212         /* Could check agains 4*num_poly, but allow degenerate polys
00213            (1 for count plus 2 dim-1 defining entities, where > 2
00214             defining entities is a normal poly, 2 defining entities
00215             is a degenerate poly and 1 defning entity is not valid.)
00216         */
00217
00218         mhdf_setFail( status,
00219                       "Invalid polygon data:  data length of %ld is "
00220                       "insufficient for %ld poly(gons/hedra).\n",
00221                       data_list_length, num_poly );
00222         return;
00223     }
00224
00225     elem_id = mhdf_elem_group_from_handle( file_ptr, elem_type, status );
00226     if( elem_id < 0 ) return;
00227
00228     dim      = (hsize_t)num_poly;
00229     index_id = mhdf_create_table( elem_id, POLY_INDEX_NAME, MHDF_INDEX_TYPE, 1, &dim, status );
00230     if( index_id < 0 )
00231     {
00232         H5Gclose( elem_id );
00233         return;
00234     }
00235
00236     dim     = (hsize_t)data_list_length;
00237     conn_id = mhdf_create_table( elem_id, CONNECTIVITY_NAME, file_ptr->id_type, 1, &dim, status );
00238     H5Gclose( elem_id );
00239     if( conn_id < 0 )
00240     {
00241         H5Dclose( index_id );
00242         return;
00243     }
00244
00245     first_id = file_ptr->max_id + 1;
00246     if( !mhdf_create_scalar_attrib( conn_id, START_ID_ATTRIB, H5T_NATIVE_LONG, &first_id, status ) )
00247     {
00248         H5Dclose( index_id );
00249         H5Dclose( conn_id );
00250         return;
00251     }
00252
00253     *first_id_out = first_id;
00254     file_ptr->max_id += num_poly;
00255     if( !mhdf_write_max_id( file_ptr, status ) )
00256     {
00257         H5Dclose( index_id );
00258         H5Dclose( conn_id );
00259         return;
00260     }
00261     file_ptr->open_handle_count++;
00262     mhdf_setOkay( status );
00263     handles_out[0] = index_id;
00264     handles_out[1] = conn_id;
00265     API_END_H( 2 );
00266 }
00267
00268 void mhdf_openPolyConnectivity( mhdf_FileHandle file_handle,
00269                                 const char* element_handle,
00270                                 long* num_poly_out,
00271                                 long* data_list_length_out,
00272                                 long* first_poly_id_out,
00273                                 hid_t handles_out[2],
00274                                 mhdf_Status* status )
00275 {
00276     FileHandle* file_ptr;
00277     hid_t elem_id, table_id, index_id;
00278     hsize_t row_count;
00279     API_BEGIN;
00280
00281     file_ptr = (FileHandle*)( file_handle );
00282     if( !mhdf_check_valid_file( file_ptr, status ) ) return;
00283
00284     if( !num_poly_out || !data_list_length_out || !first_poly_id_out )
00285     {
00286         mhdf_setFail( status, "Invalid argument." );
00287         return;
00288     }
00289
00290     elem_id = mhdf_elem_group_from_handle( file_ptr, element_handle, status );
00291     if( elem_id < 0 ) return;
00292
00293     index_id = mhdf_open_table( elem_id, POLY_INDEX_NAME, 1, &row_count, status );
00294     if( index_id < 0 )
00295     {
00296         H5Gclose( elem_id );
00297         return;
00298     }
00299     *num_poly_out = (int)row_count;
00300
00301     table_id = mhdf_open_table( elem_id, CONNECTIVITY_NAME, 1, &row_count, status );
00302
00303     H5Gclose( elem_id );
00304     if( table_id < 0 )
00305     {
00306         H5Dclose( index_id );
00307         return;
00308     }
00309     *data_list_length_out = (long)row_count;
00310
00311     if( !mhdf_read_scalar_attrib( table_id, START_ID_ATTRIB, H5T_NATIVE_LONG, first_poly_id_out, status ) )
00312     {
00313         H5Dclose( table_id );
00314         H5Dclose( index_id );
00315         return;
00316     }
00317
00318     file_ptr->open_handle_count++;
00319     handles_out[0] = index_id;
00320     handles_out[1] = table_id;
00321     mhdf_setOkay( status );
00322     API_END_H( 2 );
00323 }
00324
00325 void mhdf_writePolyConnIndices( hid_t table_id,
00326                                 long offset,
00327                                 long count,
00328                                 hid_t hdf_integer_type,
00329                                 const void* index_list,
00330                                 mhdf_Status* status )
00331 {
00332     API_BEGIN;
00333     mhdf_write_data( table_id, offset, count, hdf_integer_type, index_list, H5P_DEFAULT, status );
00334     API_END;
00335 }
00336 void mhdf_writePolyConnIndicesWithOpt( hid_t table_id,
00337                                        long offset,
00338                                        long count,
00339                                        hid_t hdf_integer_type,
00340                                        const void* index_list,
00341                                        hid_t prop,
00342                                        mhdf_Status* status )
00343 {
00344     API_BEGIN;
00345     mhdf_write_data( table_id, offset, count, hdf_integer_type, index_list, prop, status );
00346     API_END;
00347 }
00348
00349 void mhdf_readPolyConnIndices( hid_t table_id,
00350                                long offset,
00351                                long count,
00352                                hid_t hdf_integer_type,
00353                                void* index_list,
00354                                mhdf_Status* status )
00355 {
00356     API_BEGIN;
00357     mhdf_read_data( table_id, offset, count, hdf_integer_type, index_list, H5P_DEFAULT, status );
00358     API_END;
00359 }
00360 void mhdf_readPolyConnIndicesWithOpt( hid_t table_id,
00361                                       long offset,
00362                                       long count,
00363                                       hid_t hdf_integer_type,
00364                                       void* index_list,
00365                                       hid_t prop,
00366                                       mhdf_Status* status )
00367 {
00368     API_BEGIN;
00369     mhdf_read_data( table_id, offset, count, hdf_integer_type, index_list, prop, status );
00370     API_END;
00371 }
00372
00373 void mhdf_writePolyConnIDs( hid_t table_id,
00374                             long offset,
00375                             long count,
00376                             hid_t hdf_integer_type,
00377                             const void* id_list,
00378                             mhdf_Status* status )
00379 {
00380     API_BEGIN;
00381     mhdf_write_data( table_id, offset, count, hdf_integer_type, id_list, H5P_DEFAULT, status );
00382     API_END;
00383 }
00384 void mhdf_writePolyConnIDsWithOpt( hid_t table_id,
00385                                    long offset,
00386                                    long count,
00387                                    hid_t hdf_integer_type,
00388                                    const void* id_list,
00389                                    hid_t prop,
00390                                    mhdf_Status* status )
00391 {
00392     API_BEGIN;
00393     mhdf_write_data( table_id, offset, count, hdf_integer_type, id_list, prop, status );
00394     API_END;
00395 }
00396
00397 void mhdf_readPolyConnIDs( hid_t table_id,
00398                            long offset,
00399                            long count,
00400                            hid_t hdf_integer_type,
00401                            void* id_list,
00402                            mhdf_Status* status )
00403 {
00404     API_BEGIN;
00405     mhdf_read_data( table_id, offset, count, hdf_integer_type, id_list, H5P_DEFAULT, status );
00406     API_END;
00407 }
00408 void mhdf_readPolyConnIDsWithOpt( hid_t table_id,
00409                                   long offset,
00410                                   long count,
00411                                   hid_t hdf_integer_type,
00412                                   void* id_list,
00413                                   hid_t prop,
00414                                   mhdf_Status* status )
00415 {
00416     API_BEGIN;
00417     mhdf_read_data( table_id, offset, count, hdf_integer_type, id_list, prop, status );
00418     API_END;
00419 }
