convert.cpp File Reference
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "MBTagConventions.hpp"
#include "moab/ReaderWriterSet.hpp"
#include "moab/ReorderTool.hpp"
#include <iostream>
#include <fstream>
#include <sstream>
#include <iomanip>
#include <set>
#include <list>
#include <cstdlib>
#include <algorithm>
#include <ctime>
#include <cstdio>
+ Include dependency graph for convert.cpp:
Defines
#define WIN32
#define USAGE_ERROR   1
#define READ_ERROR   2
#define WRITE_ERROR   3
#define OTHER_ERROR   4
#define ENT_NOT_FOUND   5
Functions
static void print_usage (const char *name, std::ostream &stream)
static void print_help (const char *name)
static void usage_error (const char *name)
static void list_formats (Interface *)
static bool parse_id_list (const char *string, std::set< int > &)
static void print_id_list (const char *, std::ostream &stream, const std::set< int > &list)
static void reset_times ()
static void write_times (std::ostream &stream)
static void remove_entities_from_sets (Interface *gMB, Range &dead_entities, Range &empty_sets)
static void remove_from_vector (std::vector< EntityHandle > &vect, const Range &ents_to_remove)
static bool make_opts_string (std::vector< std::string > options, std::string &result)
static std::string percent_subst (const std::string &s, int val)
static int process_partition_file (Interface *gMB, std::string &metis_partition_file)
int main (int argc, char *argv[])
static void print_time (int clk_per_sec, const char *prefix, clock_t ticks, std::ostream &stream)
Variables
clock_t usr_time
clock_t sys_time
clock_t abs_time
Define Documentation
Definition at line 55 of file convert.cpp.
Referenced by main().
Definition at line 54 of file convert.cpp.
Referenced by list_formats().
Definition at line 52 of file convert.cpp.
Definition at line 51 of file convert.cpp.
Referenced by main(), and usage_error().
#define WIN32
MOAB, a Mesh-Oriented datABase, is a software component for creating, storing and accessing finite element mesh data.
Copyright 2004 Sandia Corporation. Under the terms of Contract DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government retains certain rights in this software.
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version.
Definition at line 18 of file convert.cpp.
Definition at line 53 of file convert.cpp.
Function Documentation
void list_formats ( Interface gMB) [static]
Definition at line 1137 of file convert.cpp.
References ErrorCode, MB_SUCCESS, OTHER_ERROR, moab::Interface::query_interface(), and moab::Interface::release_interface().
    const char iface_name[] = "ReaderWriterSet";
    ErrorCode err;
    ReaderWriterSet* set = 0;
    ReaderWriterSet::iterator i;
    std::ostream& str = std::cout;
    // get ReaderWriterSet
    err = gMB->query_interface( set );
    if( err != MB_SUCCESS || !set )
        std::cerr << "Internal error:  Interface \"" << iface_name << "\" not available.\n";
        exit( OTHER_ERROR );
    // get field width for format description
    size_t w = 0;
    for( i = set->begin(); i != set->end(); ++i )
        if( i->description().length() > w ) w = i->description().length();
    // write table header
    str << "Format  " << std::setw( w ) << std::left << "Description"
        << "  Read  Write  File Name Suffixes\n"
        << "------  " << std::setw( w ) << std::setfill( '-' ) << "" << std::setfill( ' ' )
        << "  ----  -----  ------------------\n";
    // write table data
        std::vector< std::string > ext;
        i->get_extensions( ext );
        str << std::setw( 6 ) << i->name() << "  " << std::setw( w ) << std::left << i->description() << "  "
            << ( i->have_reader() ? " yes" : "  no" ) << "  " << ( i->have_writer() ? "  yes" : "   no" ) << " ";
        for( std::vector< std::string >::iterator j = ext.begin(); j != ext.end(); ++j )
            str << " " << *j;
        str << std::endl;
    str << std::endl;
    gMB->release_interface( set );
    exit( 0 );
int main ( int  argc,
char *  argv[]
Definition at line 157 of file convert.cpp.
References moab::Interface::add_entities(), moab::Range::all_of_type(), moab::ParallelComm::assign_global_ids(), moab::TempestRemapper::assign_vertex_element_IDs(), moab::Range::begin(), moab::Range::clear(), moab::ParallelComm::comm(), moab::TempestRemapper::ConvertMeshToTempest(), moab::TempestRemapper::ConvertTempestMesh(), moab::TempestRemapper::CS, moab::TempestRemapper::DEFAULT, moab::Interface::delete_entities(), dim, dim_tag, DIRICHLET_SET_TAG_NAME, moab::Range::empty(), moab::Range::end(), ENT_NOT_FOUND, ErrorCode, moab::TempestRemapper::GenerateMeshMetadata(), geom, GEOM_DIMENSION_TAG_NAME, moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_type_and_tag(), moab::Interface::get_error_string(), moab::Interface::get_last_error(), moab::TempestRemapper::GetMesh(), moab::TempestRemapper::GetMeshEntities(), moab::TempestRemapper::GetMeshSet(), moab::TempestRemapper::GetMeshVertices(), moab::Interface::globalId_tag(), gMB, moab::ReorderTool::handle_order_from_int_tag(), moab::TempestRemapper::ICO, moab::TempestRemapper::ICOD, id_tag, ierr, moab::TempestRemapper::initialize(), list_formats(), moab::Interface::load_file(), moab::TempestRemapper::LoadMesh(), moab::Remapper::LoadNativeMesh(), make_opts_string(), MATERIAL_SET_TAG_NAME, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBENTITYSET, MBQUAD, MBTRI, moab::Range::merge(), mesh, moab::TempestRemapper::meshValidate, MPI_COMM_WORLD, NEUMANN_SET_TAG_NAME, moab::Remapper::OverlapMesh, PARALLEL_PARTITION_TAG_NAME, parse_id_list(), percent_subst(), print_help(), print_id_list(), process_partition_file(), READ_ERROR, read_options, remove_entities_from_sets(), moab::remove_from_vector(), moab::ReorderTool::reorder_entities(), reset_times(), moab::TempestRemapper::RLL, moab::Range::size(), moab::Remapper::SourceMesh, moab::subtract(), moab::Interface::tag_delete(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), moab::Interface::UNION, USAGE_ERROR, usage_error(), verbose, WRITE_ERROR, moab::Interface::write_file(), and write_times().
    int proc_id = 0;
#ifdef MOAB_HAVE_MPI
    MPI_Init( &argc, &argv );
    MPI_Comm_rank( MPI_COMM_WORLD, &proc_id );
#endif
#ifdef MOAB_HAVE_TEMPESTREMAP
    bool tempestin = false, tempestout = false;
#endif
    Core core;
    Interface* gMB = &core;
    ErrorCode result;
    Range range;
#if( defined( MOAB_HAVE_MPI ) && defined( MOAB_HAVE_TEMPESTREMAP ) )
    moab::ParallelComm* pcomm = new moab::ParallelComm( gMB, MPI_COMM_WORLD, 0 );
#endif
    bool append_rank        = false;
    bool percent_rank_subst = false;
    bool file_written       = false;
    int i, dim;
    std::list< std::string >::iterator j;
    bool dims[4]       = { false, false, false, false };
    const char* format = NULL;    // output file format
    std::list< std::string > in;  // input file name list
    std::string out;              // output file name
    bool verbose = false;
    std::set< int > geom[4], mesh[4];      // user-specified IDs
    std::vector< EntityHandle > set_list;  // list of user-specified sets to write
    std::vector< std::string > write_opts, read_opts;
    std::string metis_partition_file;
    std::string globalid_tag_name;
    int spectral_order = 1;
#endif
    const char* const mesh_tag_names[] = { DIRICHLET_SET_TAG_NAME, NEUMANN_SET_TAG_NAME, MATERIAL_SET_TAG_NAME,
                                           PARALLEL_PARTITION_TAG_NAME };
    const char* const geom_names[]     = { "VERTEX", "CURVE", "SURFACE", "VOLUME" };
    // scan arguments
    bool do_flag     = true;
    bool print_times = false;
    bool generate[]  = { false, false, false };
    bool pval;
    bool parallel = false, resolve_shared = false, exchange_ghosts = false;
    for( i = 1; i < argc; i++ )
        if( !argv[i][0] ) usage_error( argv[0] );
        if( do_flag && argv[i][0] == '-' )
            if( !argv[i][1] || ( argv[i][1] != 'M' && argv[i][2] ) ) usage_error( argv[0] );
            switch( argv[i][1] )
                    // do flag arguments:
                case '-':
                    do_flag = false;
                    break;
                case 'g':
                    verbose = true;
                    break;
                case 't':
                    print_times = true;
                    break;
                case 'A':
                    break;
                case 'h':
                case 'H':
                    print_help( argv[0] );
                    break;
                case 'l':
                    list_formats( gMB );
                    break;
                case 'P':
                    append_rank = true;
                    break;
                case 'p':
                    percent_rank_subst = true;
                    break;
                case 'M':
                    parallel = true;
                    if( argv[i][2] == '1' || argv[i][2] == '2' ) resolve_shared = true;
                    if( argv[i][2] == '2' ) exchange_ghosts = true;
                    break;
#endif
                case 'B':
                    tempestin = true;
                    break;
                case 'b':
                    tempestout = true;
                    break;
#endif
                case '1':
                case '2':
                case '3':
                    dims[argv[i][1] - '0'] = true;
                    break;
                    // do options that require additional args:
                default:
                    ++i;
                    if( i == argc || argv[i][0] == '-' )
                        std::cerr << "Expected argument following " << argv[i - 1] << std::endl;
                    if( argv[i - 1][1] == 'I' )
                        dim = atoi( argv[i] );
                        if( dim < 1 || dim > 2 )
                            std::cerr << "Invalid dimension value following -I" << std::endl;
                        generate[dim] = true;
                        continue;
                    pval = false;
                    switch( argv[i - 1][1] )
                        case 'a':
                            read_opts.push_back( std::string( "SAT_FILE=" ) + argv[i] );
                            pval = true;
                            break;
                        case 'f':
                            format = argv[i];
                            pval   = true;
                            break;
                        case 'o':
                            write_opts.push_back( argv[i] );
                            pval = true;
                            break;
                        case 'O':
                            read_opts.push_back( argv[i] );
                            pval = true;
                            break;
                        case 'i':
                            globalid_tag_name = std::string( argv[i] );
                            pval              = true;
                            break;
                        case 'r':
                            spectral_order = atoi( argv[i] );
                            pval           = true;
                            break;
#endif
                        case 'v':
                            pval = parse_id_list( argv[i], geom[3] );
                            break;
                        case 's':
                            pval = parse_id_list( argv[i], geom[2] );
                            break;
                        case 'c':
                            pval = parse_id_list( argv[i], geom[1] );
                            break;
                        case 'V':
                            pval = parse_id_list( argv[i], geom[0] );
                            break;
                        case 'D':
                            pval = parse_id_list( argv[i], mesh[3] );
                            break;
                        case 'm':
                            pval = parse_id_list( argv[i], mesh[2] );
                            break;
                        case 'n':
                            pval = parse_id_list( argv[i], mesh[1] );
                            break;
                        case 'd':
                            pval = parse_id_list( argv[i], mesh[0] );
                            break;
                        case 'z':
                            metis_partition_file = argv[i];
                            pval                 = true;
                            break;
                        default:
                            std::cerr << "Invalid option: " << argv[i] << std::endl;
                    if( !pval )
                        std::cerr << "Invalid flag or flag value: " << argv[i - 1] << " " << argv[i] << std::endl;
        // do file names
        else
            in.push_back( argv[i] );
    if( in.size() < 2 )
        std::cerr << "No output file name specified." << std::endl;
    // output file name is the last one specified
    out = in.back();
    in.pop_back();
    if( append_rank )
        std::ostringstream mod;
        mod << out << "." << proc_id;
        out = mod.str();
    if( percent_rank_subst )
        for( j = in.begin(); j != in.end(); ++j )
            *j = percent_subst( *j, proc_id );
        out = percent_subst( out, proc_id );
    // construct options string from individual options
    std::string read_options, write_options;
    if( parallel )
        read_opts.push_back( "PARALLEL=READ_PART" );
        read_opts.push_back( "PARTITION=PARALLEL_PARTITION" );
        if( !append_rank && !percent_rank_subst ) write_opts.push_back( "PARALLEL=WRITE_PART" );
    if( resolve_shared ) read_opts.push_back( "PARALLEL_RESOLVE_SHARED_ENTS" );
    if( exchange_ghosts ) read_opts.push_back( "PARALLEL_GHOSTS=3.0.1" );
    if( !make_opts_string( read_opts, read_options ) || !make_opts_string( write_opts, write_options ) )
        MPI_Finalize();
#endif
        return USAGE_ERROR;
    if( !metis_partition_file.empty() )
        if( ( in.size() != 1 ) || ( proc_id != 0 ) )
            std::cerr << " mpas partition allows only one input file, in serial conversion\n";
            MPI_Finalize();
#endif
            return USAGE_ERROR;
    Tag id_tag = gMB->globalId_tag();
    // Read the input file.
    if( tempestin && in.size() > 1 )
        std::cerr << " we can read only one tempest files at a time\n";
        MPI_Finalize();
#endif
        return USAGE_ERROR;
    TempestRemapper* remapper = NULL;
    if( tempestin or tempestout )
        remapper = new moab::TempestRemapper( gMB, pcomm );
#else
        remapper      = new moab::TempestRemapper( gMB );
#endif
    bool use_overlap_context = false;
    Tag srcParentTag, tgtParentTag;
#endif
        std::string inFileName = *j;
        reset_times();
        if( remapper )
            remapper->meshValidate = false;
            // remapper->constructEdgeMap = true;
            remapper->initialize();
            if( tempestin )
                // convert
                result = remapper->LoadMesh( moab::Remapper::SourceMesh, inFileName, moab::TempestRemapper::DEFAULT );MB_CHK_ERR( result );
                Mesh* tempestMesh = remapper->GetMesh( moab::Remapper::SourceMesh );
                tempestMesh->RemoveZeroEdges();
                tempestMesh->RemoveCoincidentNodes();
                // Load the meshes and validate
                result = remapper->ConvertTempestMesh( moab::Remapper::SourceMesh );
                // Check if we are converting a RLL grid
                NcFile ncInput( inFileName.c_str(), NcFile::ReadOnly );
                NcError error_temp( NcError::silent_nonfatal );
                // get the attribute
                NcAtt* attRectilinear = ncInput.get_att( "rectilinear" );
                // If rectilinear attribute present, mark it
                std::vector< int > vecDimSizes( 3, 0 );
                Tag rectilinearTag;
                // Tag data contains: guessed mesh type,     mesh size1,     mesh size 2
                //          Example:  CS(0)/ICO(1)/ICOD(2),  num_elements,   num_nodes
                //                 :       RLL(3),           num_lat,        num_lon
                result = gMB->tag_get_handle( "ClimateMetadata", 3, MB_TYPE_INTEGER, rectilinearTag,
                                              MB_TAG_SPARSE | MB_TAG_CREAT, vecDimSizes.data() );MB_CHK_SET_ERR( result, "can't create rectilinear sizes tag" );
                if( attRectilinear != nullptr )
                    // Obtain rectilinear attributes (dimension sizes)
                    NcAtt* attRectilinearDim0Size = ncInput.get_att( "rectilinear_dim0_size" );
                    NcAtt* attRectilinearDim1Size = ncInput.get_att( "rectilinear_dim1_size" );
                    if( attRectilinearDim0Size == nullptr )
                        _EXCEPTIONT( "Missing attribute \"rectilinear_dim0_size\"" );
                    if( attRectilinearDim1Size == nullptr )
                        _EXCEPTIONT( "Missing attribute \"rectilinear_dim1_size\"" );
                    int nDim0Size = attRectilinearDim0Size->as_int( 0 );
                    int nDim1Size = attRectilinearDim1Size->as_int( 0 );
                    // Obtain rectilinear attributes (dimension names)
                    NcAtt* attRectilinearDim0Name = ncInput.get_att( "rectilinear_dim0_name" );
                    NcAtt* attRectilinearDim1Name = ncInput.get_att( "rectilinear_dim1_name" );
                    if( attRectilinearDim0Name == nullptr )
                        _EXCEPTIONT( "Missing attribute \"rectilinear_dim0_name\"" );
                    if( attRectilinearDim1Name == nullptr )
                        _EXCEPTIONT( "Missing attribute \"rectilinear_dim1_name\"" );
                    std::string strDim0Name = attRectilinearDim0Name->as_string( 0 );
                    std::string strDim1Name = attRectilinearDim1Name->as_string( 0 );
                    std::map< std::string, int > vecDimNameSizes;
                    // Push rectilinear attributes into array
                    vecDimNameSizes[strDim0Name] = nDim0Size;
                    vecDimNameSizes[strDim1Name] = nDim1Size;
                    vecDimSizes[0]               = static_cast< int >( moab::TempestRemapper::RLL );
                    vecDimSizes[1]               = vecDimNameSizes["lat"];
                    vecDimSizes[2]               = vecDimNameSizes["lon"];
                    printf( "Rectilinear RLL mesh size: (lat) %d X (lon) %d\n", vecDimSizes[1], vecDimSizes[2] );
                    moab::EntityHandle mSet = 0;
                    // mSet   = remapper->GetMeshSet( moab::Remapper::SourceMesh );
                    result = gMB->tag_set_data( rectilinearTag, &mSet, 1, vecDimSizes.data() );MB_CHK_ERR( result );
                else
                    const Range& elems = remapper->GetMeshEntities( moab::Remapper::SourceMesh );
                    bool isQuads       = elems.all_of_type( moab::MBQUAD );
                    bool isTris        = elems.all_of_type( moab::MBTRI );
                    // vecDimSizes[0] = static_cast< int >( remapper->GetMeshType( moab::Remapper::SourceMesh );
                    vecDimSizes[0] = ( isQuads ? static_cast< int >( moab::TempestRemapper::CS )
                                               : ( isTris ? static_cast< int >( moab::TempestRemapper::ICO )
                                                          : static_cast< int >( moab::TempestRemapper::ICOD ) ) );
                    vecDimSizes[1] = elems.size();
                    vecDimSizes[2] = remapper->GetMeshVertices( moab::Remapper::SourceMesh ).size();
                    switch( vecDimSizes[0] )
                        case 0:
                            printf( "Cubed-Sphere mesh: %d (elems), %d (nodes)\n", vecDimSizes[1], vecDimSizes[2] );
                            break;
                        case 2:
                            printf( "Icosahedral (triangular) mesh: %d (elems), %d (nodes)\n", vecDimSizes[1],
                                    vecDimSizes[2] );
                            break;
                        case 3:
                        default:
                            printf( "Polygonal mesh: %d (elems), %d (nodes)\n", vecDimSizes[1], vecDimSizes[2] );
                            break;
                ncInput.close();
                const size_t nOverlapFaces = tempestMesh->faces.size();
                if( tempestMesh->vecSourceFaceIx.size() == nOverlapFaces &&
                    tempestMesh->vecSourceFaceIx.size() == nOverlapFaces )
                    int defaultInt      = -1;
                    use_overlap_context = true;
                    // Check if our MOAB mesh has RED and BLUE tags; this would indicate we are
                    // converting an overlap grid
                    result = gMB->tag_get_handle( "TargetParent", 1, MB_TYPE_INTEGER, tgtParentTag,
                                                  MB_TAG_DENSE | MB_TAG_CREAT, &defaultInt );MB_CHK_SET_ERR( result, "can't create target parent tag" );
                    result = gMB->tag_get_handle( "SourceParent", 1, MB_TYPE_INTEGER, srcParentTag,
                                                  MB_TAG_DENSE | MB_TAG_CREAT, &defaultInt );MB_CHK_SET_ERR( result, "can't create source parent tag" );
                    const Range& faces = remapper->GetMeshEntities( moab::Remapper::SourceMesh );
                    std::vector< int > gids( faces.size() ), srcpar( faces.size() ), tgtpar( faces.size() );
                    result = gMB->tag_get_data( id_tag, faces, &gids[0] );MB_CHK_ERR( result );
                    for( unsigned ii = 0; ii < faces.size(); ++ii )
                        srcpar[ii] = tempestMesh->vecSourceFaceIx[gids[ii] - 1];
                        tgtpar[ii] = tempestMesh->vecTargetFaceIx[gids[ii] - 1];
                    result = gMB->tag_set_data( srcParentTag, faces, &srcpar[0] );MB_CHK_ERR( result );
                    result = gMB->tag_set_data( tgtParentTag, faces, &tgtpar[0] );MB_CHK_ERR( result );
                    srcpar.clear();
                    tgtpar.clear();
                    gids.clear();
            else if( tempestout )
                moab::EntityHandle& srcmesh = remapper->GetMeshSet( moab::Remapper::SourceMesh );
                moab::EntityHandle& ovmesh  = remapper->GetMeshSet( moab::Remapper::OverlapMesh );
                // load the mesh in MOAB format
                std::vector< int > metadata(2);
                result = remapper->LoadNativeMesh( *j, srcmesh, metadata );MB_CHK_ERR( result );
                // Check if our MOAB mesh has RED and BLUE tags; this would indicate we are converting
                // an overlap grid
                ErrorCode rval1 = gMB->tag_get_handle( "SourceParent", srcParentTag );
                ErrorCode rval2 = gMB->tag_get_handle( "TargetParent", tgtParentTag );
                if( rval1 == MB_SUCCESS && rval2 == MB_SUCCESS )
                    ovmesh              = srcmesh;
                    Tag countTag;
                    result = gMB->tag_get_handle( "Counting", countTag );MB_CHK_ERR( result );
                    Tag order;
                    ReorderTool reorder_tool( &core );
                    result = reorder_tool.handle_order_from_int_tag( srcParentTag, -1, order );MB_CHK_ERR( result );
                    result = reorder_tool.reorder_entities( order );MB_CHK_ERR( result );
                    result = gMB->tag_delete( order );MB_CHK_ERR( result );
                    result = remapper->ConvertMeshToTempest( moab::Remapper::OverlapMesh );MB_CHK_ERR( result );
                else
                    if( metadata[0] == static_cast< int >( moab::TempestRemapper::RLL ) )
                        assert( metadata.size() );
                        std::cout << "Converting a RLL mesh with rectilinear dimension: " << metadata[0] << " X "
                                  << metadata[1] << std::endl;
                    // Convert the mesh and validate
                    result = remapper->ConvertMeshToTempest( moab::Remapper::SourceMesh );MB_CHK_ERR( result );
        else
            result = gMB->load_file( j->c_str(), 0, read_options.c_str() );
#else
#endif
        if( MB_SUCCESS != result )
            std::cerr << "Failed to load \"" << *j << "\"." << std::endl;
            std::cerr << "Error code: " << gMB->get_error_string( result ) << " (" << result << ")" << std::endl;
            std::string message;
            if( MB_SUCCESS == gMB->get_last_error( message ) && !message.empty() )
                std::cerr << "Error message: " << message << std::endl;
            MPI_Finalize();
#endif
            return READ_ERROR;
        if( !proc_id ) std::cerr << "Read \"" << *j << "\"" << std::endl;
        if( print_times && !proc_id ) write_times( std::cout );
    // Determine if the user has specified any geometry sets to write
    bool have_geom = false;
    for( dim = 0; dim <= 3; ++dim )
        if( !geom[dim].empty() ) have_geom = true;
        if( verbose ) print_id_list( geom_names[dim], std::cout, geom[dim] );
    // True if the user has specified any sets to write
    bool have_sets = have_geom;
    // Get geometry tags
    Tag dim_tag;
    if( have_geom )
        if( id_tag == 0 )
            std::cerr << "No ID tag defined." << std::endl;
            have_geom = false;
        result = gMB->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, dim_tag );
            std::cerr << "No geometry tag defined." << std::endl;
            have_geom = false;
    // Get geometry sets
    if( have_geom )
        int id_val;
        Tag tags[]         = { id_tag, dim_tag };
        const void* vals[] = { &id_val, &dim };
            int init_count = set_list.size();
            for( std::set< int >::iterator iter = geom[dim].begin(); iter != geom[dim].end(); ++iter )
                id_val = *iter;
                range.clear();
                result = gMB->get_entities_by_type_and_tag( 0, MBENTITYSET, tags, vals, 2, range );
                if( MB_SUCCESS != result || range.empty() )
                    range.clear();
                    std::cerr << geom_names[dim] << " " << id_val << " not found.\n";
                std::copy( range.begin(), range.end(), std::back_inserter( set_list ) );
            if( verbose )
                std::cout << "Found " << ( set_list.size() - init_count ) << ' ' << geom_names[dim] << " sets"
                          << std::endl;
    // Get mesh groupings
    for( i = 0; i < 4; ++i )
        if( verbose ) print_id_list( mesh_tag_names[i], std::cout, mesh[i] );
        if( mesh[i].empty() ) continue;
        have_sets = true;
        // Get tag
        Tag tag;
        result = gMB->tag_get_handle( mesh_tag_names[i], 1, MB_TYPE_INTEGER, tag );
            std::cerr << "Tag not found: " << mesh_tag_names[i] << std::endl;
            continue;
        // get entity sets
        for( std::set< int >::iterator iter = mesh[i].begin(); iter != mesh[i].end(); ++iter )
            range.clear();
            const void* vals[] = { &*iter };
            result             = gMB->get_entities_by_type_and_tag( 0, MBENTITYSET, &tag, vals, 1, range );
                range.clear();
                std::cerr << mesh_tag_names[i] << " " << *iter << " not found.\n";
        if( verbose )
            std::cout << "Found " << ( set_list.size() - init_count ) << ' ' << mesh_tag_names[i] << " sets"
                      << std::endl;
    // Check if output is limited to certain dimensions of elements
    bool bydim = false;
    for( dim = 1; dim < 4; ++dim )
        if( dims[dim] ) bydim = true;
    // Check conflicting input
    if( bydim )
        if( generate[1] && !dims[1] )
            std::cerr << "Warning: Request to generate 1D internal entities but not export them." << std::endl;
            generate[1] = false;
        if( generate[2] && !dims[2] )
            std::cerr << "Warning: Request to generate 2D internal entities but not export them." << std::endl;
            generate[2] = false;
    // Generate any internal entities
    if( generate[1] || generate[2] )
        EntityHandle all_mesh    = 0;
        const EntityHandle* sets = &all_mesh;
        int num_sets             = 1;
        if( have_sets )
            num_sets = set_list.size();
            sets     = &set_list[0];
        for( i = 0; i < num_sets; ++i )
            Range dim3, dim2, adj;
            gMB->get_entities_by_dimension( sets[i], 3, dim3, true );
            if( generate[1] )
                gMB->get_entities_by_dimension( sets[i], 2, dim2, true );
                gMB->get_adjacencies( dim3, 1, true, adj, Interface::UNION );
                gMB->get_adjacencies( dim2, 1, true, adj, Interface::UNION );
            if( generate[2] )
                gMB->get_adjacencies( dim3, 2, true, adj, Interface::UNION );
            if( sets[i] ) gMB->add_entities( sets[i], adj );
    // Delete any entities not of the dimensions to be exported
    if( bydim )
        // Get list of dead elements
        Range dead_entities, tmp_range;
        for( dim = 1; dim <= 3; ++dim )
            if( dims[dim] ) continue;
            gMB->get_entities_by_dimension( 0, dim, tmp_range );
            dead_entities.merge( tmp_range );
        // Remove dead entities from all sets, and add all
        // empty sets to list of dead entities.
        Range empty_sets;
        remove_entities_from_sets( gMB, dead_entities, empty_sets );
        while( !empty_sets.empty() )
            if( !set_list.empty() ) remove_from_vector( set_list, empty_sets );
            dead_entities.merge( empty_sets );
            tmp_range.clear();
            remove_entities_from_sets( gMB, empty_sets, tmp_range );
            empty_sets = subtract( tmp_range, dead_entities );
        // Destroy dead entities
        gMB->delete_entities( dead_entities );
    // If user specified sets to write, but none were found, exit.
    if( have_sets && set_list.empty() )
        std::cerr << "Nothing to write." << std::endl;
        MPI_Finalize();
#endif
        return ENT_NOT_FOUND;
    // interpret the mpas partition file created by gpmetis
        int err = process_partition_file( gMB, metis_partition_file );
        if( err )
            std::cerr << "Failed to process partition file \"" << metis_partition_file << "\"." << std::endl;
            MPI_Finalize();
#endif
            return WRITE_ERROR;
    if( verbose )
        if( have_sets )
            std::cout << "Found " << set_list.size() << " specified sets to write (total)." << std::endl;
        else
            std::cout << "No sets specifed.  Writing entire mesh." << std::endl;
    // Write the output file
    reset_times();
    if( remapper )
        Range faces;
        Mesh* tempestMesh =
            remapper->GetMesh( ( use_overlap_context ? moab::Remapper::OverlapMesh : moab::Remapper::SourceMesh ) );
            remapper->GetMeshSet( ( use_overlap_context ? moab::Remapper::OverlapMesh : moab::Remapper::SourceMesh ) );
        result = gMB->get_entities_by_dimension( srcmesh, 2, faces );MB_CHK_ERR( result );
        int ntot_elements = 0, nelements = faces.size();
        int ierr = MPI_Allreduce( &nelements, &ntot_elements, 1, MPI_INT, MPI_SUM, pcomm->comm() );
        if( ierr != 0 ) MB_CHK_SET_ERR( MB_FAILURE, "MPI_Allreduce failed to get total source elements" );
#else
        ntot_elements = nelements;
#endif
        Tag gidTag = gMB->globalId_tag();
        std::vector< int > gids( faces.size() );
        result = gMB->tag_get_data( gidTag, faces, &gids[0] );MB_CHK_ERR( result );
        if( faces.size() > 1 && gids[0] == gids[1] && !use_overlap_context )
            result = pcomm->assign_global_ids( srcmesh, 2, 1, false );MB_CHK_ERR( result );
#else
            result = remapper->assign_vertex_element_IDs( gidTag, srcmesh, 2, 1 );MB_CHK_ERR( result );
            result = remapper->assign_vertex_element_IDs( gidTag, srcmesh, 0, 1 );MB_CHK_ERR( result );
#endif
        // VSM: If user requested explicitly for some metadata, we need to generate the DoF ID tag
        // and set the appropriate numbering based on specified discretization order
        // Useful only for SE meshes with GLL DoFs
        if( spectral_order > 1 && globalid_tag_name.size() > 1 )
            result = remapper->GenerateMeshMetadata( *tempestMesh, ntot_elements, faces, NULL, globalid_tag_name,
                                                     spectral_order );MB_CHK_ERR( result );
        if( tempestout )
            // Check if our MOAB mesh has RED and BLUE tags; this would indicate we are converting an
            // overlap grid
            if( use_overlap_context && false )
                const int nOverlapFaces = faces.size();
                // Overlap mesh: resize the source and target connection arrays
                tempestMesh->vecSourceFaceIx.resize( nOverlapFaces );  // 0-based indices corresponding to source mesh
                tempestMesh->vecTargetFaceIx.resize( nOverlapFaces );  // 0-based indices corresponding to target mesh
                result = gMB->tag_get_data( srcParentTag, faces, &tempestMesh->vecSourceFaceIx[0] );MB_CHK_ERR( result );
                result = gMB->tag_get_data( tgtParentTag, faces, &tempestMesh->vecTargetFaceIx[0] );MB_CHK_ERR( result );
            // Write out the mesh using TempestRemap
            tempestMesh->Write( out, NcFile::Netcdf4 );
            file_written = true;
        delete remapper; // cleanup
#endif
    if( !file_written )
        if( have_sets )
            result = gMB->write_file( out.c_str(), format, write_options.c_str(), &set_list[0], set_list.size() );
        else
            result = gMB->write_file( out.c_str(), format, write_options.c_str() );
            std::cerr << "Failed to write \"" << out << "\"." << std::endl;
            MPI_Finalize();
#endif
            return WRITE_ERROR;
    if( !proc_id ) std::cerr << "Wrote \"" << out << "\"" << std::endl;
    MPI_Finalize();
#endif
    return 0;
bool make_opts_string ( std::vector< std::string >  options,
std::string &  result
) [static]
Definition at line 1090 of file convert.cpp.
    opts.clear();
    if( options.empty() ) return true;
    // choose a separator character
    std::vector< std::string >::const_iterator i;
    char separator             = '\0';
    const char* alt_separators = ";+,:\t\n";
    for( const char* sep_ptr = alt_separators; *sep_ptr; ++sep_ptr )
        bool seen = false;
        for( i = options.begin(); i != options.end(); ++i )
            if( i->find( *sep_ptr, 0 ) != std::string::npos )
                seen = true;
                break;
        if( !seen )
            separator = *sep_ptr;
            break;
    if( !separator )
        std::cerr << "Error: cannot find separator character for options string" << std::endl;
        return false;
    if( separator != ';' )
        opts = ";";
        opts += separator;
    // concatenate options
    opts += *i;
    for( ++i; i != options.end(); ++i )
        opts += separator;
        opts += *i;
    return true;
bool parse_id_list ( const char *  string,
std::set< int > &  results
) [static]
Definition at line 947 of file convert.cpp.
    bool okay   = true;
    char* mystr = strdup( string );
    for( const char* ptr = strtok( mystr, "," ); ptr; ptr = strtok( 0, "," ) )
        char* endptr;
        long val = strtol( ptr, &endptr, 0 );
        if( endptr == ptr || val <= 0 )
            std::cerr << "Not a valid id: " << ptr << std::endl;
            okay = false;
            break;
        long val2 = val;
        if( *endptr == '-' )
            const char* sptr = endptr + 1;
            val2             = strtol( sptr, &endptr, 0 );
            if( endptr == sptr || val2 <= 0 )
                std::cerr << "Not a valid id: " << sptr << std::endl;
                okay = false;
                break;
            if( val2 < val )
                std::cerr << "Invalid id range: " << ptr << std::endl;
                okay = false;
                break;
        if( *endptr )
            std::cerr << "Unexpected character: " << *endptr << std::endl;
            okay = false;
            break;
        for( ; val <= val2; ++val )
            if( !results.insert( (int)val ).second ) std::cerr << "Warning: duplicate Id: " << val << std::endl;
    free( mystr );
    return okay;
std::string percent_subst ( const std::string &  s,
int  val
) [static]
Definition at line 1209 of file convert.cpp.
    if( s.empty() ) return s;
    size_t j = s.find( '%' );
    if( j == std::string::npos ) return s;
    std::ostringstream st;
    st << s.substr( 0, j );
    st << val;
    size_t i;
    while( ( i = s.find( '%', j + 1 ) ) != std::string::npos )
        st << s.substr( j, i - j );
        st << val;
        j = i;
    st << s.substr( j + 1 );
    return st.str();
static void print_help ( const char *  name) [static]
Definition at line 117 of file convert.cpp.
References print_usage().
    std::cout << " This program can be used to convert between mesh file\n"
                 " formats, extract a subset of a mesh file to a separate\n"
                 " file, or both.  The type of file to write is determined\n"
                 " from the file extension (e.g. \".vtk\") portion of the\n"
                 " output file name.\n"
                 " \n"
                 " While MOAB strives to export and import all data from\n"
                 " each supported file format, most file formats do\n"
                 " not support MOAB's entire data model.  Thus MOAB cannot\n"
                 " guarantee lossless conversion for any file formats\n"
                 " other than the native HDF5 representation.\n"
                 "\n";
    print_usage( name, std::cout );
    exit( 0 );
void print_id_list ( const char *  head,
std::ostream &  stream,
const std::set< int > &  list
) [static]
Definition at line 996 of file convert.cpp.
    stream << head << ": ";
    if( list.empty() )
        stream << "(none)" << std::endl;
        return;
    int start, prev;
    std::set< int >::const_iterator iter = list.begin();
    start = prev = *( iter++ );
    for( ;; )
        if( iter == list.end() || *iter != 1 + prev )
            stream << start;
            if( prev != start ) stream << '-' << prev;
            if( iter == list.end() ) break;
            stream << ", ";
            start = *iter;
        prev = *( iter++ );
    stream << std::endl;
static void print_time ( int  clk_per_sec,
const char *  prefix,
clock_t  ticks,
) [static]
Definition at line 1025 of file convert.cpp.
Referenced by build_coords(), main(), testA(), testB(), testC(), testD(), testE(), and write_times().
    ticks *= clk_per_sec / 100;
    clock_t centi   = ticks % 100;
    clock_t seconds = ticks / 100;
    stream << prefix;
    if( seconds < 120 )
        stream << ( ticks / 100 ) << "." << centi << "s" << std::endl;
    else
        clock_t minutes = ( seconds / 60 ) % 60;
        clock_t hours   = ( seconds / 3600 );
        seconds %= 60;
        if( hours ) stream << hours << "h";
        if( minutes ) stream << minutes << "m";
        if( seconds || centi ) stream << seconds << "." << centi << "s";
        stream << " (" << ( ticks / 100 ) << "." << centi << "s)" << std::endl;
static void print_usage ( const char *  name,
) [static]
Definition at line 59 of file convert.cpp.
Referenced by main(), print_help(), and usage_error().
    stream << "Usage: " << name
           << " [-a <sat_file>|-A] [-t] [subset options] [-f format] <input_file> [<input_file2> "
              "...] <output_file>"
           << std::endl
           << "\t-f <format>    - Specify output file format" << std::endl
           << "\t-a <acis_file> - ACIS SAT file dumped by .cub reader (same as \"-o "
              "SAT_FILE=acis_file\""
           << std::endl
           << "\t-A             - .cub file reader should not dump a SAT file (depricated default)" << std::endl
           << "\t-o option      - Specify write option." << std::endl
           << "\t-O option      - Specify read option." << std::endl
           << "\t-t             - Time read and write of files." << std::endl
           << "\t-g             - Enable verbose/debug output." << std::endl
           << "\t-h             - Print this help text and exit." << std::endl
           << "\t-l             - List available file formats and exit." << std::endl
           << "\t-I <dim>       - Generate internal entities of specified dimension." << std::endl
           << "\t-P             - Append processor ID to output file name" << std::endl
           << "\t-p             - Replace '%' with processor ID in input and output file name" << std::endl
           << "\t-M[0|1|2]      - Read/write in parallel, optionally also doing "
              "resolve_shared_ents (1) and exchange_ghosts (2)"
           << std::endl
           << "\t-z <file>      - Read metis partition information corresponding to an MPAS grid "
              "file and create h5m partition file"
           << std::endl
#endif
           << "\t-B             - Use TempestRemap exodus file reader and convert to MOAB format" << std::endl
           << "\t-b             - Convert MOAB mesh to TempestRemap exodus file writer" << std::endl
           << "\t-i             - Name of the global DoF tag to use with mbtempest" << std::endl
           << "\t-r             - Order of field DoF (discretization) data; FV=1,SE=[1,N]" << std::endl
#endif
           << "\t--             - treat all subsequent options as file names" << std::endl
           << "\t                 (allows file names beginning with '-')" << std::endl
           << "  subset options: " << std::endl
           << "\tEach of the following options should be followed by " << std::endl
           << "\ta list of ids.  IDs may be separated with commas.  " << std::endl
           << "\tRanges of IDs may be specified with a '-' between " << std::endl
           << "\ttwo values.  The list may not contain spaces." << std::endl
           << "\t-v  - Volume" << std::endl
           << "\t-s  - Surface" << std::endl
           << "\t-c  - Curve" << std::endl
           << "\t-V  - Vertex" << std::endl
           << "\t-m  - Material set (block)" << std::endl
           << "\t-d  - Dirichlet set (nodeset)" << std::endl
           << "\t-n  - Neumann set (sideset)" << std::endl
           << "\t-D  - Parallel partitioning set (PARALLEL_PARTITION)" << std::endl
           << "\tThe presence of one or more of the following flags limits " << std::endl
           << "\tthe exported mesh to only elements of the corresponding " << std::endl
           << "\tdimension.  Vertices are always exported." << std::endl
           << "\t-1  - Edges " << std::endl
           << "\t-2  - Tri, Quad, Polygon " << std::endl
           << "\t-3  - Tet, Hex, Prism, etc. " << std::endl;
int process_partition_file ( Interface gMB,
std::string &  metis_partition_file
) [static]
Definition at line 1231 of file convert.cpp.
References moab::Interface::add_entities(), moab::Interface::clear_meshset(), moab::Interface::create_meshset(), moab::Range::empty(), ErrorCode, moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_type_and_tag(), moab::Range::insert(), MB_CHK_ERR, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBENTITYSET, MESHSET_SET, moab::Range::size(), moab::Interface::tag_delete_data(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), and moab::Interface::UNION.
    // how many faces in the file ? how do we make sure it is an mpas file?
    // mpas atmosphere files can be downloaded from here
    // https://mpas-dev.github.io/atmosphere/atmosphere_meshes.html
    Range faces;
    ErrorCode rval = mb->get_entities_by_dimension( 0, 2, faces );MB_CHK_ERR( rval );
    std::cout << " MPAS model has " << faces.size() << " polygons\n";
    // read the partition file
    std::ifstream partfile;
    partfile.open( metis_partition_file.c_str() );
    std::string line;
    std::vector< int > parts;
    parts.resize( faces.size(), -1 );
    int i = 0;
    if( partfile.is_open() )
        while( getline( partfile, line ) )
            // cout << line << '\n';
            parts[i++] = atoi( line.c_str() );
            if( i > (int)faces.size() )
                std::cerr << " too many lines in partition file \n. bail out \n";
                return 1;
        partfile.close();
    std::vector< int >::iterator pmax = max_element( parts.begin(), parts.end() );
    std::vector< int >::iterator pmin = min_element( parts.begin(), parts.end() );
    if( *pmin <= -1 )
        std::cerr << " partition file is incomplete, *pmin is -1 !! \n";
        return 1;
    std::cout << " partitions range: " << *pmin << " " << *pmax << "\n";
    Tag part_set_tag;
    int dum_id = -1;
    rval = mb->tag_get_handle( "PARALLEL_PARTITION", 1, MB_TYPE_INTEGER, part_set_tag, MB_TAG_SPARSE | MB_TAG_CREAT,
                               &dum_id );MB_CHK_ERR( rval );
    // get any sets already with this tag, and clear them
    // remove the parallel partition sets if they exist
    Range tagged_sets;
    rval = mb->get_entities_by_type_and_tag( 0, MBENTITYSET, &part_set_tag, NULL, 1, tagged_sets, Interface::UNION );MB_CHK_ERR( rval );
    if( !tagged_sets.empty() )
        rval = mb->clear_meshset( tagged_sets );MB_CHK_ERR( rval );
        rval = mb->tag_delete_data( part_set_tag, tagged_sets );MB_CHK_ERR( rval );
    Tag gid;
    rval = mb->tag_get_handle( "GLOBAL_ID", gid );MB_CHK_ERR( rval );
    int num_sets = *pmax + 1;
    if( *pmin != 0 )
        std::cout << " problem reading parts; min is not 0 \n";
        return 1;
    for( i = 0; i < num_sets; i++ )
        EntityHandle new_set;
        rval = mb->create_meshset( MESHSET_SET, new_set );MB_CHK_ERR( rval );
        tagged_sets.insert( new_set );
    int* dum_ids = new int[num_sets];
        dum_ids[i] = i;
    rval = mb->tag_set_data( part_set_tag, tagged_sets, dum_ids );MB_CHK_ERR( rval );
    delete[] dum_ids;
    std::vector< int > gids;
    int num_faces = (int)faces.size();
    gids.resize( num_faces );
    rval = mb->tag_get_data( gid, faces, &gids[0] );MB_CHK_ERR( rval );
    for( int j = 0; j < num_faces; j++ )
        int eid         = gids[j];
        EntityHandle eh = faces[j];
        int partition   = parts[eid - 1];
        if( partition < 0 || partition >= num_sets )
            std::cout << " wrong partition number \n";
            return 1;
        rval = mb->add_entities( tagged_sets[partition], &eh, 1 );MB_CHK_ERR( rval );
    return 0;
void remove_entities_from_sets ( Interface gMB,
Range empty_sets
) [static]
Definition at line 1181 of file convert.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::Range::empty(), moab::Range::end(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type(), moab::Range::insert(), moab::intersect(), MBENTITYSET, and moab::Interface::remove_entities().
    empty_sets.clear();
    Range sets;
    gMB->get_entities_by_type( 0, MBENTITYSET, sets );
    for( Range::iterator i = sets.begin(); i != sets.end(); ++i )
        Range set_contents;
        gMB->get_entities_by_handle( *i, set_contents, false );
        set_contents = intersect( set_contents, dead_entities );
        gMB->remove_entities( *i, set_contents );
        set_contents.clear();
        if( set_contents.empty() ) empty_sets.insert( *i );
void remove_from_vector ( std::vector< EntityHandle > &  vect,
const Range ents_to_remove
) [static]
Definition at line 1198 of file convert.cpp.
References moab::Range::begin(), and moab::Range::end().
    Range::const_iterator i;
    std::vector< EntityHandle >::iterator j;
    for( i = ents_to_remove.begin(); i != ents_to_remove.end(); ++i )
        j = std::find( vect.begin(), vect.end(), *i );
        if( j != vect.end() ) vect.erase( j );
void reset_times ( ) [static]
Definition at line 1051 of file convert.cpp.
References abs_time.
    abs_time = clock();
static void usage_error ( const char *  name) [static]
Definition at line 136 of file convert.cpp.
References print_usage(), and USAGE_ERROR.
    print_usage( name, std::cerr );
    MPI_Finalize();
#endif
    exit( USAGE_ERROR );
void write_times ( std::ostream &  stream) [static]
Definition at line 1056 of file convert.cpp.
References abs_time, and print_time().
    clock_t abs_tm = clock();
    print_time( CLOCKS_PER_SEC, "  ", abs_tm - abs_time, stream );
    abs_time = abs_tm;
Variable Documentation
clock_t abs_time
Definition at line 1047 of file convert.cpp.
Referenced by reset_times(), and write_times().
clock_t sys_time
clock_t usr_time
