dagmc_pointinvol_test.cpp
00001 #include <iostream>
00002 #include "moab/Interface.hpp"
00003 #ifndef IS_BUILDING_MB
00004 #define IS_BUILDING_MB
00005 #endif
00006 #include "TestUtil.hpp"
00007 #include "Internals.hpp"
00008 #include "moab/Core.hpp"
00009
00010 #include "DagMC.hpp"
00011
00012 using namespace moab;
00013
00014 using moab::DagMC;
00015
00016 DagMC* DAG;
00017
00018 #define CHKERR( A )        \
00019     do        \
00020     {        \
00021         if( MB_SUCCESS != ( A ) )        \
00022         {        \
00023             std::cerr << "Failure (error code " << ( A ) << ") at " __FILE__ ":" << __LINE__ << std::endl; \
00024             return A;        \
00025         }        \
00026     } while( false )
00027
00028 std::string input_file = TestDir + "unittest/test_geom.h5m";
00029
00030 void dagmc_setup_test()
00031 {
00032     ErrorCode rval = DAG->load_file( input_file.c_str() );  // open the Dag file
00033     CHECK_ERR( rval );
00034     rval = DAG->init_OBBTree();CHECK_ERR( rval );
00035
00036     /*
00037     int num_vols = DAG->num_entities(3);
00038     EntityHandle vol;
00039     for (int i = 0; i < num_vols; i++)
00040       vol = DAG->entity_by_index(3, i);
00041     */
00042     // EntityHandle volume = 12682136550675316765;
00043     // CHECK_EQUAL(volume, vol);
00044 }
00045
00046 void dagmc_point_in()
00047 {
00048     int result          = 0;
00049     int expected_result = 1;
00050     double xyz[3]       = { 0.0, 0.0, 0.0 };
00051     int vol_idx         = 1;
00052     EntityHandle vol_h  = DAG->entity_by_index( 3, vol_idx );
00053     ErrorCode rval      = DAG->point_in_volume( vol_h, xyz, result );CHECK_ERR( rval );
00054     CHECK_EQUAL( expected_result, result );
00055 }
00056
00057 int dagmc_point_in_vol_dir( double origin[3], double dir[3], int vol_idx )
00058 {
00059     int result         = 0;
00060     EntityHandle vol_h = DAG->entity_by_index( 3, vol_idx );
00061     double xyz[3];
00062     double next_surf_dist;
00063     EntityHandle next_surf;
00064
00065     // normalise the vector
00066     double dir_norm = ( dir[0] * dir[0] ) + ( dir[1] * dir[1] ) + ( dir[2] * dir[2] );
00067
00068     dir[0] = dir[0] / sqrt( dir_norm );
00069     dir[1] = dir[1] / sqrt( dir_norm );
00070     dir[2] = dir[2] / sqrt( dir_norm );
00071
00072     ErrorCode rval = DAG->ray_fire( vol_h, origin, dir, next_surf, next_surf_dist );CHECK_ERR( rval );
00073
00074     xyz[0] = origin[0] + ( next_surf_dist * dir[0] );
00075     xyz[1] = origin[1] + ( next_surf_dist * dir[1] );
00076     xyz[2] = origin[2] + ( next_surf_dist * dir[2] );
00077
00078     std::cout << xyz[0] << " " << xyz[1] << " " << xyz[2] << std::endl;
00079
00080     rval = DAG->point_in_volume( vol_h, xyz, result, dir );CHECK_ERR( rval );
00081     return result;
00082 }
00083
00084 void dagmc_point_in_vol_1()
00085 {
00086     double dir[3]       = { -1.0, 0.0, 0.0 };
00087     double origin[3]    = { 0.0, 0.0, 0.0 };
00088     int vol_idx         = 1;
00089     int expected_result = 1;
00090
00091     int result = dagmc_point_in_vol_dir( origin, dir, vol_idx );
00092     CHECK_EQUAL( expected_result, result );
00093 }
00094
00095 void dagmc_point_in_vol_2()
00096 {
00097     int expected_result = 1;
00098     int vol_idx         = 1;
00099     double dir[3]       = { 1.0, 0.0, 0.0 };
00100     double origin[3]    = { 0.0, 0.0, 0.0 };
00101
00102     int result = dagmc_point_in_vol_dir( origin, dir, vol_idx );
00103
00104     CHECK_EQUAL( expected_result, result );
00105 }
00106
00107 void dagmc_point_in_vol_3()
00108 {
00109     int expected_result = 1;
00110     int vol_idx         = 1;
00111     double dir[3]       = { 0.0, -1.0, 0.0 };
00112     double origin[3]    = { 0.0, 0.0, 0.0 };
00113
00114     int result = dagmc_point_in_vol_dir( origin, dir, vol_idx );
00115
00116     CHECK_EQUAL( expected_result, result );
00117 }
00118
00119 void dagmc_point_in_vol_4()
00120 {
00121     int expected_result = 1;
00122     int vol_idx         = 1;
00123     double dir[3]       = { 0.0, 1.0, 0.0 };
00124     double origin[3]    = { 0.0, 0.0, 0.0 };
00125
00126     int result = dagmc_point_in_vol_dir( origin, dir, vol_idx );
00127
00128     CHECK_EQUAL( expected_result, result );
00129 }
00130
00131 void dagmc_point_in_vol_5()
00132 {
00133     int expected_result = 1;
00134     int vol_idx         = 1;
00135     double dir[3]       = { 0.0, 0.0, -1.0 };
00136     double origin[3]    = { 0.0, 0.0, 0.0 };
00137
00138     int result = dagmc_point_in_vol_dir( origin, dir, vol_idx );
00139
00140     CHECK_EQUAL( expected_result, result );
00141 }
00142
00143 void dagmc_point_in_vol_6()
00144 {
00145     int expected_result = 1;
00146     int vol_idx         = 1;
00147     double dir[3]       = { 0.0, 0.0, 1.0 };
00148     double origin[3]    = { 0.0, 0.0, 0.0 };
00149
00150     int result = dagmc_point_in_vol_dir( origin, dir, vol_idx );
00151
00152     CHECK_EQUAL( expected_result, result );
00153 }
00154
00155 void dagmc_point_on_corner_1()
00156 {
00157     int expected_result = 1;
00158     int vol_idx         = 1;
00159     double dir[3]       = { 1.0, 1.0, 1.0 };
00160     double origin[3]    = { 0.0, 0.0, 0.0 };
00161
00162     int result = dagmc_point_in_vol_dir( origin, dir, vol_idx );
00163
00164     CHECK_EQUAL( expected_result, result );
00165 }
00166
00167 void dagmc_point_on_corner_2()
00168 {
00169     int expected_result = 1;
00170     int vol_idx         = 1;
00171     double dir[3]       = { -1.0, 1.0, 1.0 };
00172     double origin[3]    = { 0.0, 0.0, 0.0 };
00173
00174     int result = dagmc_point_in_vol_dir( origin, dir, vol_idx );
00175
00176     CHECK_EQUAL( expected_result, result );
00177 }
00178
00179 void dagmc_point_on_corner_3()
00180 {
00181     int expected_result = 1;
00182     int vol_idx         = 1;
00183     double dir[3]       = { 1.0, 1.0, -1.0 };
00184     double origin[3]    = { 0.0, 0.0, 0.0 };
00185
00186     int result = dagmc_point_in_vol_dir( origin, dir, vol_idx );
00187
00188     CHECK_EQUAL( expected_result, result );
00189 }
00190
00191 void dagmc_point_on_corner_4()
00192 {
00193     int expected_result = 1;
00194     int vol_idx         = 1;
00195     double dir[3]       = { -1.0, 1.0, -1.0 };
00196     double origin[3]    = { 0.0, 0.0, 0.0 };
00197
00198     int result = dagmc_point_in_vol_dir( origin, dir, vol_idx );
00199
00200     CHECK_EQUAL( expected_result, result );
00201 }
00202
00203 void dagmc_point_on_corner_5()
00204 {
00205     int expected_result = 1;
00206     int vol_idx         = 1;
00207     double dir[3]       = { 1.0, -1.0, 1.0 };
00208     double origin[3]    = { 0.0, 0.0, 0.0 };
00209
00210     int result = dagmc_point_in_vol_dir( origin, dir, vol_idx );
00211
00212     CHECK_EQUAL( expected_result, result );
00213 }
00214
00215 void dagmc_point_on_corner_6()
00216 {
00217     int expected_result = 1;
00218     int vol_idx         = 1;
00219     double dir[3]       = { -1.0, -1.0, 1.0 };
00220     double origin[3]    = { 0.0, 0.0, 0.0 };
00221
00222     int result = dagmc_point_in_vol_dir( origin, dir, vol_idx );
00223
00224     CHECK_EQUAL( expected_result, result );
00225 }
00226
00227 void dagmc_point_on_corner_7()
00228 {
00229     int expected_result = 1;
00230     int vol_idx         = 1;
00231     double dir[3]       = { 1.0, -1.0, -1.0 };
00232     double origin[3]    = { 0.0, 0.0, 0.0 };
00233
00234     int result = dagmc_point_in_vol_dir( origin, dir, vol_idx );
00235
00236     CHECK_EQUAL( expected_result, result );
00237 }
00238
00239 void dagmc_point_on_corner_8()
00240 {
00241     int expected_result = 1;
00242     int vol_idx         = 1;
00243     double dir[3]       = { -1.0, -1.0, -1.0 };
00244     double origin[3]    = { 0.0, 0.0, 0.0 };
00245
00246     int result = dagmc_point_in_vol_dir( origin, dir, vol_idx );
00247
00248     CHECK_EQUAL( expected_result, result );
00249 }
00250
00251 int main( int /* argc */, char** /* argv */ )
00252 {
00253     int result = 0;
00254
00255     DAG = new DagMC();
00256
00257     result += RUN_TEST( dagmc_setup_test );  // setup problem
00258     result += RUN_TEST( dagmc_point_in );    // point in centre
00259     // rays fired along cardinal directions
00260     result += RUN_TEST( dagmc_point_in_vol_1 );  // point in centre
00261     result += RUN_TEST( dagmc_point_in_vol_2 );  // point in centre
00262     result += RUN_TEST( dagmc_point_in_vol_3 );  // point in centre
00263     result += RUN_TEST( dagmc_point_in_vol_4 );  // point in centre
00264     result += RUN_TEST( dagmc_point_in_vol_5 );  // point in centre
00265     result += RUN_TEST( dagmc_point_in_vol_6 );  // point in centre
00266     // rays fired at nodes
00267     result += RUN_TEST( dagmc_point_on_corner_1 );
00268     result += RUN_TEST( dagmc_point_on_corner_2 );
00269     result += RUN_TEST( dagmc_point_on_corner_3 );
00270     result += RUN_TEST( dagmc_point_on_corner_4 );
00271
00272     // result += RUN_TEST(dagmc_point_in({0.0, 0.0, 5.0}); // point in centre
00273     // result += RUN_TEST(dagmc_point_in({0.0, 0.0, -5.0}); // point in centre
00274     // result += RUN_TEST(dagmc_point_in({0.0, 5.0, 0.0}); // point in centre
00275     // result += RUN_TEST(dagmc_point_in({0.0, -5.0, 0.0}); // point in centre
00276     // result += RUN_TEST(dagmc_point_in({5.0, 0.0, 0.0}); // point in centre
00277     // result += RUN_TEST(dagmc_point_in({-5.0, 0.0, 0.0}); // point in centre
00278
00279     delete DAG;
00280
00281     return result;
00282 }
