dagmc_rayfire_test.cpp
00001 #include <iostream>
00002 #include "moab/Interface.hpp"
00003 #ifndef IS_BUILDING_MB
00004 #define IS_BUILDING_MB
00005 #endif
00006 #include "TestUtil.hpp"
00007 #include "Internals.hpp"
00008 #include "moab/Core.hpp"
00009 #include "moab/GeomQueryTool.hpp"
00010
00011 #include "DagMC.hpp"
00012
00013 using namespace moab;
00014
00015 using moab::DagMC;
00016
00017 DagMC* DAG;
00018
00019 #define CHKERR( A )        \
00020     do        \
00021     {        \
00022         if( MB_SUCCESS != ( A ) )        \
00023         {        \
00024             std::cerr << "Failure (error code " << ( A ) << ") at " __FILE__ ":" << __LINE__ << std::endl; \
00025             return A;        \
00026         }        \
00027     } while( false )
00028
00029 std::string input_file = TestDir + "unittest/test_geom.h5m";
00030
00031 double eps = 1.0e-6;
00032
00033 void dagmc_setup_test()
00034 {
00035     ErrorCode rval = DAG->load_file( input_file.c_str() );  // open the Dag file
00036     CHECK_ERR( rval );
00037     rval = DAG->init_OBBTree();CHECK_ERR( rval );
00038
00039     /*
00040     int num_vols = DAG->num_entities(3);
00041     EntityHandle vol_h;
00042     for (int i = 0; i < num_vols; i++)
00043       vol_h = DAG->entity_by_index(3, i);
00044     */
00045     // EntityHandle volume = 12682136550675316765;
00046     // CHECK_EQUAL(volume, vol);
00047 }
00048
00049 void dagmc_origin_face_rayfire()
00050 {
00051     int vol_idx        = 1;
00052     EntityHandle vol_h = DAG->entity_by_index( 3, vol_idx );
00053     double dir[3]      = { -1.0, 0.0, 0.0 };
00054     double origin[3]   = { 0.0, 0.0, 0.0 };
00055     double next_surf_dist;
00056     EntityHandle next_surf;
00057     DAG->ray_fire( vol_h, origin, dir, next_surf, next_surf_dist );
00058     double expected_next_surf_dist = 5.0;
00059     CHECK_REAL_EQUAL( expected_next_surf_dist, next_surf_dist, eps );
00060 }
00061
00062 void dagmc_outside_face_rayfire()
00063 {
00064     int vol_idx        = 1;
00065     EntityHandle vol_h = DAG->entity_by_index( 3, vol_idx );
00066     double dir[3]      = { 1.0, 0.0, 0.0 };    // ray along x direction
00067     double origin[3]   = { -10.0, 0.0, 0.0 };  // origin at -10 0 0
00068     double next_surf_dist;
00069     EntityHandle next_surf;
00070     DAG->ray_fire( vol_h, origin, dir, next_surf, next_surf_dist );
00071     std::cout << next_surf_dist << std::endl;
00072     double expected_next_surf_dist = 15.0;
00073     CHECK_REAL_EQUAL( expected_next_surf_dist, next_surf_dist, eps );
00074 }
00075
00076 void dagmc_outside_face_rayfire_orient_exit()
00077 {
00078     DagMC::RayHistory history;
00079     int vol_idx        = 1;
00080     EntityHandle vol_h = DAG->entity_by_index( 3, vol_idx );
00081     double dir[3]      = { 1.0, 0.0, 0.0 };    // ray along x direction
00082     double origin[3]   = { -10.0, 0.0, 0.0 };  // origin at -10 0 0
00083     double next_surf_dist;
00084     EntityHandle next_surf;
00085     DAG->ray_fire( vol_h, origin, dir, next_surf, next_surf_dist, &history, 0, 1 );
00086     std::cout << next_surf_dist << std::endl;
00087     double expected_next_surf_dist = 15.0;
00088     CHECK_REAL_EQUAL( expected_next_surf_dist, next_surf_dist, eps );
00089 }
00090
00091 void dagmc_outside_face_rayfire_orient_entrance()
00092 {
00093     DagMC::RayHistory history;
00094     int vol_idx        = 1;
00095     EntityHandle vol_h = DAG->entity_by_index( 3, vol_idx );
00096     double dir[3]      = { 1.0, 0.0, 0.0 };    // ray along x direction
00097     double origin[3]   = { -10.0, 0.0, 0.0 };  // origin at -10 0 0
00098     double next_surf_dist;
00099     EntityHandle next_surf;
00100     DAG->ray_fire( vol_h, origin, dir, next_surf, next_surf_dist, &history, 0.0, -1 );
00101     std::cout << next_surf_dist << std::endl;
00102     double expected_next_surf_dist = 5.0;
00103     CHECK_REAL_EQUAL( expected_next_surf_dist, next_surf_dist, eps );
00104 }
00105
00106 void dagmc_outside_face_rayfire_history_fail()
00107 {
00108     DagMC::RayHistory history;
00109     int vol_idx        = 1;
00110     EntityHandle vol_h = DAG->entity_by_index( 3, vol_idx );
00111     double dir[3]      = { 1.0, 0.0, 0.0 };    // ray along x direction
00112     double origin[3]   = { -10.0, 0.0, 0.0 };  // origin at -10 0 0
00113     double xyz[3];
00114     double next_surf_dist;
00115     EntityHandle next_surf;
00116
00117     history.reset();
00118
00119     // ray fired exactly along boundary shared by 2 facets on a single surface,
00120     // needs two ray_fires to cross, this is expected and ok
00121
00122     // first ray fire with history
00123     DAG->ray_fire( vol_h, origin, dir, next_surf, next_surf_dist, &history, 0, 1 );
00124     // second ray fire with history
00125     DAG->ray_fire( vol_h, xyz, dir, next_surf, next_surf_dist, &history, 0, 1 );
00126     // this fire should hit graveyard, i.e. next_surf = 0
00127     DAG->ray_fire( vol_h, xyz, dir, next_surf, next_surf_dist, &history, 0, 1 );
00128
00129     // using history with this geom, there should be no next surface, i.e. 0
00130     EntityHandle ZERO = 0;
00131     CHECK_EQUAL( ZERO, next_surf );
00132 }
00133
00134 void dagmc_outside_face_rayfire_history()
00135 {
00136     DagMC::RayHistory history;
00137     int vol_idx        = 1;
00138     EntityHandle vol_h = DAG->entity_by_index( 3, vol_idx );
00139     double dir[3]      = { 1.0, 0.0, 0.0 };    // ray along x direction
00140     double origin[3]   = { -10.0, 0.0, 0.0 };  // origin at -10 0 0
00141     double xyz[3];
00142     double next_surf_dist;
00143     EntityHandle next_surf;
00144
00145     history.reset();
00146     // first ray fire with history
00147     DAG->ray_fire( vol_h, origin, dir, next_surf, next_surf_dist, &history, 0, 1 );
00148     std::cout << next_surf << " " << history.size() << std::endl;
00149     // second ray fire with history
00150
00151     xyz[0] = origin[0] + ( next_surf_dist * dir[0] );
00152     xyz[1] = origin[1] + ( next_surf_dist * dir[1] );
00153     xyz[2] = origin[2] + ( next_surf_dist * dir[2] );
00154
00155     // ray fired execacyl
00156
00157     DAG->ray_fire( vol_h, xyz, dir, next_surf, next_surf_dist, &history, 0, 1 );
00158
00159     DAG->ray_fire( vol_h, xyz, dir, next_surf, next_surf_dist, &history, 0, 1 );
00160
00161     // using history with this geom, there should be no next surface, i.e. 0
00162     EntityHandle ZERO = 0;
00163     CHECK_EQUAL( ZERO, next_surf );
00164 }
00165
00166 int main( int /* argc */, char** /* argv */ )
00167 {
00168     int result = 0;
00169
00170     DAG = new DagMC();
00171
00172     result += RUN_TEST( dagmc_setup_test );  // setup problem
00173     // rays fired along cardinal directions
00174     result += RUN_TEST( dagmc_origin_face_rayfire );  // point in centre
00175     result += RUN_TEST( dagmc_outside_face_rayfire );
00176     result += RUN_TEST( dagmc_outside_face_rayfire_orient_exit );      // fire ray from point outside volume
00177        // looking for exit intersections
00178     result += RUN_TEST( dagmc_outside_face_rayfire_orient_entrance );  // fire ray from point outside volume looking
00179        // for entrance intersection
00180     result += RUN_TEST( dagmc_outside_face_rayfire_history_fail );     // fire ray from point outside
00181        // geometry using ray history
00182     result += RUN_TEST( dagmc_outside_face_rayfire_history );          // fire ray from point outside
00183        // geometry using ray history
00184
00185     delete DAG;
00186
00187     return result;
00188 }
