dagmc_simple_test.cpp File Reference
#include <iostream>
#include "moab/Interface.hpp"
#include "TestUtil.hpp"
#include "Internals.hpp"
#include "moab/Core.hpp"
#include "DagMC.hpp"
+ Include dependency graph for dagmc_simple_test.cpp:
Defines
#define IS_BUILDING_MB
#define CHKERR(A)
Functions
void dagmc_load_file ()
void dagmc_load_file_dagmc ()
void dagmc_load_file_dagmc_via_moab ()
void dagmc_load_file_dagmc_internal ()
void dagmc_load_file_dagmc_build_obb ()
void dagmc_load_file_dagmc_via_moab_build_obb ()
void dagmc_load_file_dagmc_internal_build_obb ()
void dagmc_test_obb_retreval ()
void dagmc_build_obb ()
void dagmc_num_vols ()
void dagmc_entity_handle ()
void dagmc_point_in ()
void dagmc_test_obb_retreval_rayfire ()
void dagmc_rayfire ()
void dagmc_closest_to ()
void dagmc_test_boundary ()
int main (int, char **)
Variables
DagMC * DAG
const std::string input_file = "unittest/test_geom.h5m"
Define Documentation
#define CHKERR (   A)
Value:
do        \
        if( MB_SUCCESS != ( A ) )        \
            std::cerr << "Failure (error code " << ( A ) << ") at " __FILE__ ":" << __LINE__ << std::endl; \
            return A;        \
    } while( false )
Definition at line 18 of file dagmc_simple_test.cpp.
Definition at line 4 of file dagmc_simple_test.cpp.
Function Documentation
void dagmc_build_obb ( )
Definition at line 156 of file dagmc_simple_test.cpp.
References CHECK_ERR, DAG, and ErrorCode.
Referenced by main().
    ErrorCode rval = DAG->init_OBBTree();CHECK_ERR( rval );
void dagmc_closest_to ( )
Definition at line 252 of file dagmc_simple_test.cpp.
References CHECK_ERR, CHECK_REAL_EQUAL, DAG, eps, and ErrorCode.
    const double eps = 1e-6;  // epsilon for test, faceting tol?
    int vol_idx = 1;
    // note model is cube of side 10, centred at 0,0,0, so ray fire along
    // any unit direction should be exactly 5.0
    double xyz[3] = { -6.0, 0.0, 0.0 };
    double distance;  // distance from point to nearest surface
    double expect_distance = 1.0;
    EntityHandle vol_h     = DAG->entity_by_index( 3, vol_idx );
    ErrorCode rval = DAG->closest_to_location( vol_h, xyz, distance );CHECK_ERR( rval );
    // distance should be 1.0 cm
    CHECK_REAL_EQUAL( expect_distance, distance, eps );
Definition at line 168 of file dagmc_simple_test.cpp.
    int num_vols = DAG->num_entities(3);
    EntityHandle vol_h;
    for (int i = 0; i < num_vols; i++)
      vol_h = DAG->entity_by_index(3, i);
    // EntityHandle expect_vol_h = 12682136550675316765;
    // CHECK_EQUAL(expect_vol_h, vol_h);
void dagmc_load_file ( )
Definition at line 30 of file dagmc_simple_test.cpp.
References CHECK_ERR, DAG, ErrorCode, and input_file.
    ErrorCode rval = DAG->load_file( input_file.c_str() );  // open the Dag file
    CHECK_ERR( rval );
Definition at line 36 of file dagmc_simple_test.cpp.
References CHECK_ERR, ErrorCode, and input_file.
    /* 1 - Test with external moab, load file in DAGMC*/
    // make new moab core
    Core* mbi = new moab::Core();
    // make new dagmc into that moab
    DagMC* dagmc = new moab::DagMC( mbi );
    ErrorCode rval;
    // load a file
    rval = dagmc->load_file( input_file.c_str() );CHECK_ERR( rval );
    // delete dagmc
    delete dagmc;
    delete mbi;
Definition at line 81 of file dagmc_simple_test.cpp.
    ErrorCode rval;
    moab::Core* mbi = new moab::Core();
    // load a file
    rval = dagmc->init_OBBTree();CHECK_ERR( rval );
    // delete dagmc
    delete dagmc;
    delete mbi;
Definition at line 69 of file dagmc_simple_test.cpp.
    /* 3 - Test with internal moab, load file in DAG*/
    ErrorCode rval;
    moab::DagMC* dagmc = new moab::DagMC();
    // load a file
    delete dagmc;
Definition at line 116 of file dagmc_simple_test.cpp.
    ErrorCode rval;
    // load a file
    delete dagmc;
Definition at line 53 of file dagmc_simple_test.cpp.
References CHECK_ERR, ErrorCode, input_file, and moab::Core::load_file().
    /* 2 - Test with external moab, load file in MOAB*/
    // load the file into moab rather than dagmc
    ErrorCode rval;
    rval            = mbi->load_file( input_file.c_str() );CHECK_ERR( rval );
    moab::DagMC* dagmc = new moab::DagMC( mbi );
    rval               = dagmc->load_existing_contents();CHECK_ERR( rval );
    // delete dagmc;
    delete dagmc;
    delete mbi;
Definition at line 99 of file dagmc_simple_test.cpp.
    ErrorCode rval;
    // delete dagmc;
    delete dagmc;
    delete mbi;
void dagmc_num_vols ( )
Definition at line 161 of file dagmc_simple_test.cpp.
References CHECK_EQUAL, and DAG.
    int expect_num_vols = 2;
    int num_vols        = DAG->num_entities( 3 );
    CHECK_EQUAL( expect_num_vols, num_vols );
void dagmc_point_in ( )
Definition at line 180 of file dagmc_simple_test.cpp.
References CHECK_EQUAL, CHECK_ERR, DAG, and ErrorCode.
    int result         = 0;
    int expect_result  = 1;
    int vol_idx        = 1;
    double xyz[3]      = { 0.0, 0.0, 0.0 };
    ErrorCode rval     = DAG->point_in_volume( vol_h, xyz, result );CHECK_ERR( rval );
    CHECK_EQUAL( expect_result, result );
void dagmc_rayfire ( )
Definition at line 234 of file dagmc_simple_test.cpp.
    int vol_idx = 1;
    double dir[3] = { 0.0, 0.0, 1.0 };
    EntityHandle next_surf;
    double next_surf_dist;
    double expect_next_surf_dist = 5.0;
    ErrorCode rval = DAG->ray_fire( vol_h, xyz, dir, next_surf, next_surf_dist );CHECK_ERR( rval );
    CHECK_REAL_EQUAL( expect_next_surf_dist, next_surf_dist, eps );
Definition at line 269 of file dagmc_simple_test.cpp.
    int vol_idx         = 1;
    int surf_idx        = 1;
    EntityHandle surf_h = DAG->entity_by_index( 2, surf_idx );
    double xyz[3] = { 0.0, 0.0, 5.0 };
    int result;
    int expect_result = 0;
    ErrorCode rval = DAG->test_volume_boundary( vol_h, surf_h, xyz, dir, result );CHECK_ERR( rval );
    // check ray leaving volume
Definition at line 129 of file dagmc_simple_test.cpp.
    // make new dagmc
    std::cout << "test_obb_retreval" << std::endl;
    ErrorCode rval;
    // load a file
    // write the file
    rval = dagmc->write_mesh( "fcad", 4 );
    // now remove the dagmc instance a
    delete dagmc;
    rval  = dagmc->load_file( "fcad" );CHECK_ERR( rval );
    // delete the fcad file
    remove( "fcad" );
    delete dagmc;
Definition at line 191 of file dagmc_simple_test.cpp.
References CHECK_ERR, CHECK_REAL_EQUAL, DAG, eps, ErrorCode, and input_file.
    // make new dagmc
    std::cout << "test_obb_retreval and ray_fire" << std::endl;
    ErrorCode rval;
    // load a file
    // write the file
    delete dagmc;
    // now create new DAGMC
    remove( "fcad" );
    // now perform full ray fire
    double eps  = 1.e-6;
    int vol_idx = 1;
    delete dagmc;
int main ( int  ,
char **
Definition at line 286 of file dagmc_simple_test.cpp.
References DAG, dagmc_build_obb(), dagmc_closest_to(), dagmc_load_file(), dagmc_load_file_dagmc(), dagmc_load_file_dagmc_build_obb(), dagmc_load_file_dagmc_internal(), dagmc_load_file_dagmc_internal_build_obb(), dagmc_load_file_dagmc_via_moab(), dagmc_load_file_dagmc_via_moab_build_obb(), dagmc_num_vols(), dagmc_point_in(), dagmc_rayfire(), dagmc_test_boundary(), dagmc_test_obb_retreval(), dagmc_test_obb_retreval_rayfire(), and RUN_TEST.
    int result = 0;
    DAG = new moab::DagMC();
    result += RUN_TEST( dagmc_load_file );                           // test ray fire
    result += RUN_TEST( dagmc_build_obb );                           // build the obb
    result += RUN_TEST( dagmc_num_vols );                            // make sure the num of vols correct
    result += RUN_TEST( dagmc_load_file_dagmc );                     //
    result += RUN_TEST( dagmc_load_file_dagmc_via_moab );            //
    result += RUN_TEST( dagmc_load_file_dagmc_internal );            //
    result += RUN_TEST( dagmc_load_file_dagmc_build_obb );           //
    result += RUN_TEST( dagmc_load_file_dagmc_via_moab_build_obb );  //
    result += RUN_TEST( dagmc_load_file_dagmc_internal_build_obb );  //
    result += RUN_TEST( dagmc_test_obb_retreval );                   // check that we are retreving loaded obbs
    result += RUN_TEST( dagmc_test_obb_retreval_rayfire );           // check that we can ray fire on loaded obbs
    result += RUN_TEST( dagmc_point_in );                            // check entity by point
    result += RUN_TEST( dagmc_rayfire );                             // ensure ray fire distance is correct
    result += RUN_TEST( dagmc_closest_to );                          // check the distance to surface nearest point
    result += RUN_TEST( dagmc_test_boundary );                       // check particle entering leaving
    delete DAG;
    return result;
Variable Documentation
DagMC* DAG
Definition at line 16 of file dagmc_simple_test.cpp.
Definition at line 28 of file dagmc_simple_test.cpp.
