dagmc_simple_test.cpp
00001 #include <iostream>
00002 #include "moab/Interface.hpp"
00003 #ifndef IS_BUILDING_MB
00004 #define IS_BUILDING_MB
00005 #endif
00006 #include "TestUtil.hpp"
00007 #include "Internals.hpp"
00008 #include "moab/Core.hpp"
00009
00010 #include "DagMC.hpp"
00011
00012 using namespace moab;
00013
00014 using moab::DagMC;
00015
00016 DagMC* DAG;
00017
00018 #define CHKERR( A )        \
00019     do        \
00020     {        \
00021         if( MB_SUCCESS != ( A ) )        \
00022         {        \
00023             std::cerr << "Failure (error code " << ( A ) << ") at " __FILE__ ":" << __LINE__ << std::endl; \
00024             return A;        \
00025         }        \
00026     } while( false )
00027
00028 const std::string input_file = TestDir + "unittest/test_geom.h5m";
00029
00030 void dagmc_load_file()
00031 {
00032     ErrorCode rval = DAG->load_file( input_file.c_str() );  // open the Dag file
00033     CHECK_ERR( rval );
00034 }
00035
00036 void dagmc_load_file_dagmc()
00037 {
00038     /* 1 - Test with external moab, load file in DAGMC*/
00039     // make new moab core
00040     Core* mbi = new moab::Core();
00041     // make new dagmc into that moab
00042     DagMC* dagmc = new moab::DagMC( mbi );
00043
00044     ErrorCode rval;
00045     // load a file
00046     rval = dagmc->load_file( input_file.c_str() );CHECK_ERR( rval );
00047
00048     // delete dagmc
00049     delete dagmc;
00050     delete mbi;
00051 }
00052
00053 void dagmc_load_file_dagmc_via_moab()
00054 {
00055     /* 2 - Test with external moab, load file in MOAB*/
00056     // load the file into moab rather than dagmc
00057     ErrorCode rval;
00058
00059     moab::Core* mbi = new moab::Core();
00060     rval            = mbi->load_file( input_file.c_str() );CHECK_ERR( rval );
00061     moab::DagMC* dagmc = new moab::DagMC( mbi );
00062     rval               = dagmc->load_existing_contents();CHECK_ERR( rval );
00063
00064     // delete dagmc;
00065     delete dagmc;
00066     delete mbi;
00067 }
00068
00069 void dagmc_load_file_dagmc_internal()
00070 {
00071     /* 3 - Test with internal moab, load file in DAG*/
00072     // make new dagmc into that moab
00073     ErrorCode rval;
00074
00075     moab::DagMC* dagmc = new moab::DagMC();
00076     // load a file
00077     rval = dagmc->load_file( input_file.c_str() );CHECK_ERR( rval );
00078     delete dagmc;
00079 }
00080
00081 void dagmc_load_file_dagmc_build_obb()
00082 {
00083     /* 1 - Test with external moab, load file in DAGMC*/
00084     // make new moab core
00085     ErrorCode rval;
00086
00087     moab::Core* mbi = new moab::Core();
00088     // make new dagmc into that moab
00089     DagMC* dagmc = new moab::DagMC( mbi );
00090
00091     // load a file
00092     rval = dagmc->load_file( input_file.c_str() );CHECK_ERR( rval );
00093     rval = dagmc->init_OBBTree();CHECK_ERR( rval );
00094     // delete dagmc
00095     delete dagmc;
00096     delete mbi;
00097 }
00098
00099 void dagmc_load_file_dagmc_via_moab_build_obb()
00100 {
00101     /* 2 - Test with external moab, load file in MOAB*/
00102     // load the file into moab rather than dagmc
00103     ErrorCode rval;
00104
00105     moab::Core* mbi = new moab::Core();
00106     rval            = mbi->load_file( input_file.c_str() );CHECK_ERR( rval );
00107     moab::DagMC* dagmc = new moab::DagMC( mbi );
00108     rval               = dagmc->load_existing_contents();CHECK_ERR( rval );
00109     rval = dagmc->init_OBBTree();CHECK_ERR( rval );
00110
00111     // delete dagmc;
00112     delete dagmc;
00113     delete mbi;
00114 }
00115
00116 void dagmc_load_file_dagmc_internal_build_obb()
00117 {
00118     /* 3 - Test with internal moab, load file in DAG*/
00119     // make new dagmc into that moab
00120     ErrorCode rval;
00121
00122     moab::DagMC* dagmc = new moab::DagMC();
00123     // load a file
00124     rval = dagmc->load_file( input_file.c_str() );CHECK_ERR( rval );
00125     rval = dagmc->init_OBBTree();CHECK_ERR( rval );
00126     delete dagmc;
00127 }
00128
00129 void dagmc_test_obb_retreval()
00130 {
00131     // make new dagmc
00132     std::cout << "test_obb_retreval" << std::endl;
00133
00134     DagMC* dagmc = new moab::DagMC();
00135
00136     ErrorCode rval;
00137     // load a file
00138     rval = dagmc->load_file( input_file.c_str() );CHECK_ERR( rval );
00139     rval = dagmc->init_OBBTree();CHECK_ERR( rval );
00140
00141     // write the file
00142     rval = dagmc->write_mesh( "fcad", 4 );
00143
00144     // now remove the dagmc instance a
00145     delete dagmc;
00146
00147     dagmc = new moab::DagMC();
00148     rval  = dagmc->load_file( "fcad" );CHECK_ERR( rval );
00149     rval = dagmc->init_OBBTree();CHECK_ERR( rval );
00150
00151     // delete the fcad file
00152     remove( "fcad" );
00153     delete dagmc;
00154 }
00155
00156 void dagmc_build_obb()
00157 {
00158     ErrorCode rval = DAG->init_OBBTree();CHECK_ERR( rval );
00159 }
00160
00161 void dagmc_num_vols()
00162 {
00163     int expect_num_vols = 2;
00164     int num_vols        = DAG->num_entities( 3 );
00165     CHECK_EQUAL( expect_num_vols, num_vols );
00166 }
00167
00168 void dagmc_entity_handle()
00169 {
00170     /*
00171     int num_vols = DAG->num_entities(3);
00172     EntityHandle vol_h;
00173     for (int i = 0; i < num_vols; i++)
00174       vol_h = DAG->entity_by_index(3, i);
00175     */
00176     // EntityHandle expect_vol_h = 12682136550675316765;
00177     // CHECK_EQUAL(expect_vol_h, vol_h);
00178 }
00179
00180 void dagmc_point_in()
00181 {
00182     int result         = 0;
00183     int expect_result  = 1;
00184     int vol_idx        = 1;
00185     double xyz[3]      = { 0.0, 0.0, 0.0 };
00186     EntityHandle vol_h = DAG->entity_by_index( 3, vol_idx );
00187     ErrorCode rval     = DAG->point_in_volume( vol_h, xyz, result );CHECK_ERR( rval );
00188     CHECK_EQUAL( expect_result, result );
00189 }
00190
00191 void dagmc_test_obb_retreval_rayfire()
00192 {
00193     // make new dagmc
00194     std::cout << "test_obb_retreval and ray_fire" << std::endl;
00195
00196     DagMC* dagmc = new moab::DagMC();
00197
00198     ErrorCode rval;
00199     // load a file
00200     rval = dagmc->load_file( input_file.c_str() );CHECK_ERR( rval );
00201     rval = dagmc->init_OBBTree();CHECK_ERR( rval );
00202
00203     // write the file
00204     rval = dagmc->write_mesh( "fcad", 4 );
00205
00206     // now remove the dagmc instance a
00207     delete dagmc;
00208
00209     // now create new DAGMC
00210     dagmc = new moab::DagMC();
00211     rval  = dagmc->load_file( "fcad" );CHECK_ERR( rval );
00212     rval = dagmc->init_OBBTree();CHECK_ERR( rval );
00213
00214     // delete the fcad file
00215     remove( "fcad" );
00216
00217     // now perform full ray fire
00218     double eps  = 1.e-6;
00219     int vol_idx = 1;
00220     // note model is cube of side 10, centred at 0,0,0, so ray fire along
00221     // any unit direction should be exactly 5.0
00222     double xyz[3] = { 0.0, 0.0, 0.0 };
00223     double dir[3] = { 0.0, 0.0, 1.0 };
00224     EntityHandle next_surf;
00225     double next_surf_dist;
00226     double expect_next_surf_dist = 5.0;
00227     EntityHandle vol_h           = DAG->entity_by_index( 3, vol_idx );
00228
00229     rval = DAG->ray_fire( vol_h, xyz, dir, next_surf, next_surf_dist );CHECK_ERR( rval );
00230     CHECK_REAL_EQUAL( expect_next_surf_dist, next_surf_dist, eps );
00231     delete dagmc;
00232 }
00233
00234 void dagmc_rayfire()
00235 {
00236     const double eps = 1e-6;  // epsilon for test, faceting tol?
00237
00238     int vol_idx = 1;
00239     // note model is cube of side 10, centred at 0,0,0, so ray fire along
00240     // any unit direction should be exactly 5.0
00241     double xyz[3] = { 0.0, 0.0, 0.0 };
00242     double dir[3] = { 0.0, 0.0, 1.0 };
00243     EntityHandle next_surf;
00244     double next_surf_dist;
00245     double expect_next_surf_dist = 5.0;
00246     EntityHandle vol_h           = DAG->entity_by_index( 3, vol_idx );
00247
00248     ErrorCode rval = DAG->ray_fire( vol_h, xyz, dir, next_surf, next_surf_dist );CHECK_ERR( rval );
00249     CHECK_REAL_EQUAL( expect_next_surf_dist, next_surf_dist, eps );
00250 }
00251
00252 void dagmc_closest_to()
00253 {
00254     const double eps = 1e-6;  // epsilon for test, faceting tol?
00255
00256     int vol_idx = 1;
00257     // note model is cube of side 10, centred at 0,0,0, so ray fire along
00258     // any unit direction should be exactly 5.0
00259     double xyz[3] = { -6.0, 0.0, 0.0 };
00260     double distance;  // distance from point to nearest surface
00261     double expect_distance = 1.0;
00262     EntityHandle vol_h     = DAG->entity_by_index( 3, vol_idx );
00263
00264     ErrorCode rval = DAG->closest_to_location( vol_h, xyz, distance );CHECK_ERR( rval );
00265     // distance should be 1.0 cm
00266     CHECK_REAL_EQUAL( expect_distance, distance, eps );
00267 }
00268
00269 void dagmc_test_boundary()
00270 {
00271     int vol_idx         = 1;
00272     EntityHandle vol_h  = DAG->entity_by_index( 3, vol_idx );
00273     int surf_idx        = 1;
00274     EntityHandle surf_h = DAG->entity_by_index( 2, surf_idx );
00275
00276     double xyz[3] = { 0.0, 0.0, 5.0 };
00277     double dir[3] = { 0.0, 0.0, 1.0 };
00278     int result;
00279     int expect_result = 0;
00280
00281     ErrorCode rval = DAG->test_volume_boundary( vol_h, surf_h, xyz, dir, result );CHECK_ERR( rval );
00282     // check ray leaving volume
00283     CHECK_EQUAL( expect_result, result );
00284 }
00285
00286 int main( int /* argc */, char** /* argv */ )
00287 {
00288     int result = 0;
00289
00290     DAG = new moab::DagMC();
00291
00292     result += RUN_TEST( dagmc_load_file );                           // test ray fire
00293     result += RUN_TEST( dagmc_build_obb );                           // build the obb
00294     result += RUN_TEST( dagmc_num_vols );                            // make sure the num of vols correct
00295     result += RUN_TEST( dagmc_load_file_dagmc );                     //
00296     result += RUN_TEST( dagmc_load_file_dagmc_via_moab );            //
00297     result += RUN_TEST( dagmc_load_file_dagmc_internal );            //
00298     result += RUN_TEST( dagmc_load_file_dagmc_build_obb );           //
00299     result += RUN_TEST( dagmc_load_file_dagmc_via_moab_build_obb );  //
00300     result += RUN_TEST( dagmc_load_file_dagmc_internal_build_obb );  //
00301     result += RUN_TEST( dagmc_test_obb_retreval );                   // check that we are retreving loaded obbs
00302     result += RUN_TEST( dagmc_test_obb_retreval_rayfire );           // check that we can ray fire on loaded obbs
00303     result += RUN_TEST( dagmc_point_in );                            // check entity by point
00304     result += RUN_TEST( dagmc_rayfire );                             // ensure ray fire distance is correct
00305     result += RUN_TEST( dagmc_closest_to );                          // check the distance to surface nearest point
00306     result += RUN_TEST( dagmc_test_boundary );                       // check particle entering leaving
00307
00308     delete DAG;
00309
00310     return result;
00311 }
