deforming.cpp File Reference
#include "TestUtil.hpp"
#include "Mesquite.hpp"
#include "DeformingDomainWrapper.hpp"
#include "MeshImpl.hpp"
#include "MsqError.hpp"
#include "MeshDomain1D.hpp"
#include "PlanarDomain.hpp"
#include "QualityAssessor.hpp"
#include "MsqVertex.hpp"
#include <iostream>
#include <cstdlib>
#include <algorithm>
+ Include dependency graph for deforming.cpp:
Defines
#define CHKMESH(COND, ERR)
Functions
void usage (const char *argv0)
void classify_boundary (Mesh *mesh, Mesh::VertexHandle corners_out[4], std::vector< Mesh::VertexHandle > curves_out[4], MsqError &err)
void cond_write_file (MeshImpl &mesh, const char *filename)
int main (int argc, char *argv[])
Variables
std::string INPUT_FILE = "/sph-10-zsquare.vtk"
const double Z = 7.0
const double HD = 4.5
Define Documentation
#define CHKMESH (   COND,
  ERR
Value:
do        \
        if( !( COND ) )                                                              \
            MSQ_SETERR( err )( "Unexpected mesh topology", MsqError::INVALID_MESH ); \
            return;        \
    } while( false )
Definition at line 179 of file deforming.cpp.
Function Documentation
void classify_boundary ( Mesh mesh,
std::vector< Mesh::VertexHandle curves_out[4],
MsqError err
void cond_write_file ( MeshImpl mesh,
const char *  filename
Definition at line 69 of file deforming.cpp.
References MSQ_CHKERR, and MBMesquite::MeshImpl::write_vtk().
Referenced by main().
    if( filename )
        MsqPrintError err( std::cerr );
        mesh.write_vtk( filename, err );
        if( MSQ_CHKERR( err ) )
            std::cerr << filename << ": failed to write file" << std::endl;
            exit( 1 );
        std::cout << "Wrote file: " << filename << std::endl;
int main ( int  argc,
char *  argv[]
Definition at line 84 of file deforming.cpp.
References classify_boundary(), cond_write_file(), corners, fixed, HD, INPUT_FILE, MBMesquite::QualityAssessor::invalid_elements(), mesh, MSQ_CHKERR, MBMesquite::DeformingCurveSmoother::PROPORTIONAL, MBMesquite::Wrapper::quality_assessor(), MBMesquite::MeshImpl::read_vtk(), MBMesquite::IQInterface::run_instructions(), size, MBMesquite::DeformingCurveSmoother::smooth_curve(), MBMesquite::DeformingDomainWrapper::store_initial_mesh(), MBMesquite::DeformingCurveSmoother::store_initial_mesh(), usage, MBMesquite::MeshImpl::vertex_set_coordinates(), MBMesquite::MeshImpl::vertices_set_fixed_flag(), MBMesquite::PlanarDomain::XY, and MBMesquite::MeshWriter::Z.
    const char* deformed_file = 0;
    const char* smoothed_file = 0;
    const char* tag_file      = 0;
    struct
        const char* flag;
        const char** name_ptr;
    } flags[] = { { "-d", &deformed_file }, { "-t", &tag_file }, { "-f", &smoothed_file }, { 0, 0 } };
    for( int i = 1; i < argc; ++i )
        int j;
        for( j = 0; flags[j].flag && strcmp( flags[j].flag, argv[i] ); ++j )
        if( !flags[j].flag )
            std::cerr << "Invalid argument: \"" << argv[i] << '"' << std::endl;
            usage( argv[0] );
        else if( ++i == argc )
            std::cerr << "Expected argument following \"" << argv[i - 1] << '"' << std::endl;
            usage( argv[0] );
        *( flags[j].name_ptr ) = argv[i];
    // load mesh
    MeshImpl mesh;
    mesh.read_vtk( INPUT_FILE.c_str(), err );
    if( MSQ_CHKERR( err ) ) return 1;
    // find boundary vertices
    std::vector< Mesh::VertexHandle > curves[4];
    Mesh::VertexHandle corners[4];
    classify_boundary( &mesh, corners, curves, err );
    // new, "deformed" domain will be an 2HDx2HD planar square
    const double corner_coords[][3] = { { -HD, -HD, Z }, { HD, -HD, Z }, { HD, HD, Z }, { -HD, HD, Z } };
    LineDomain lines[4]             = { LineDomain( Vector3D( corner_coords[0] ), Vector3D( 1, 0, 0 ) ),
                            LineDomain( Vector3D( corner_coords[1] ), Vector3D( 0, 1, 0 ) ),
                            LineDomain( Vector3D( corner_coords[2] ), Vector3D( -1, 0, 0 ) ),
                            LineDomain( Vector3D( corner_coords[3] ), Vector3D( 0, -1, 0 ) ) };
    PlanarDomain surface( PlanarDomain::XY, Z );
    // save initial mesh state
    DeformingCurveSmoother curve_tool;
    for( int i = 0; i < 4; ++i )
        curve_tool.store_initial_mesh( &mesh, &curves[i][0], curves[i].size(), &lines[i], err );
    DeformingDomainWrapper wrapper;
    wrapper.store_initial_mesh( &mesh, err );
    cond_write_file( mesh, tag_file );
    // move corner vertices to new location
        Vector3D vect( corner_coords[i] );
        mesh.vertex_set_coordinates( corners[i], vect, err );
    std::vector< bool > fixed( 4, true );
    mesh.vertices_set_fixed_flag( corners, fixed, 4, err );
    // smooth curves
        curve_tool.smooth_curve( &mesh, &curves[i][0], curves[i].size(), &lines[i],
                                 DeformingCurveSmoother::PROPORTIONAL, err );
        fixed.resize( curves[i].size(), true );
        mesh.vertices_set_fixed_flag( &curves[i][0], fixed, curves[i].size(), err );
    cond_write_file( mesh, deformed_file );
    // smooth surface mesh
    MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &surface );
    wrapper.run_instructions( &mesh_and_domain, err );
    cond_write_file( mesh, smoothed_file );
    return wrapper.quality_assessor().invalid_elements();
void usage ( const char *  argv0)
Definition at line 54 of file deforming.cpp.
    std::cerr << "Usage: " << argv0 << " [-t <file>] [-d <file>] [-f <file>]" << std::endl
              << "\t-t : write initial mesh with tags containing reference mesh" << std::endl
              << "\t-d : write file containing deformed mesh with smoothed curves " << std::endl
              << "\t-f : write file containing final mesh" << std::endl
              << std::endl;
    std::exit( 1 );
Variable Documentation
Definition at line 52 of file deforming.cpp.
Definition at line 48 of file deforming.cpp.
Definition at line 50 of file deforming.cpp.
