dual_test.cpp File Reference
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "moab/MeshTopoUtil.hpp"
#include "moab/DualTool.hpp"
#include "../TestUtil.hpp"
#include <iostream>
#include <string>
+ Include dependency graph for dual_test.cpp:
Functions
int main (int argc, char *argv[])
Variables
std::string default_input = "unittest/hex01.vtk"
const char default_output [] = "dual.vtk"
InterfacegMB
Function Documentation
int main ( int  argc,
char *  argv[]
Definition at line 18 of file dual_test.cpp.
References moab::Range::clear(), moab::MeshTopoUtil::construct_aentities(), moab::DualTool::construct_dual(), moab::DualTool::construct_hex_dual(), default_input, default_output, moab::DualTool::DUAL_CURVE_TAG_NAME, moab::DualTool::DUAL_SURFACE_TAG_NAME, moab::Range::empty(), ErrorCode, moab::DualTool::get_dual_entities(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_type_and_tag(), moab::Interface::get_number_entities_by_dimension(), moab::Interface::get_number_entities_by_type(), gMB, moab::Interface::load_mesh(), MB_SUCCESS, MB_TYPE_HANDLE, MBENTITYSET, MBHEX, MBQUAD, moab::Range::size(), moab::Interface::tag_get_handle(), and moab::Interface::write_file().
    const char* f1 = default_input.c_str();
    const char* f2 = default_output;
    if( argc <= 2 )
        std::cout << "Usage: dual_test <mesh_file_name> <out file>" << std::endl;
        std::cout << "using default input : " << default_input << " and output " << default_output << "\n";
    else
        f1 = argv[1];
        f2 = argv[2];
    gMB = new Core();
    // read the mesh file
    ErrorCode result = gMB->load_mesh( f1 );
    if( MB_SUCCESS != result )
        std::cout << "Problems reading file " << argv[1] << "." << std::endl;
        delete gMB;
        return 1;
    // make sure aentities are created
    Range all_verts;
    result = gMB->get_entities_by_dimension( 0, 0, all_verts );
    if( MB_SUCCESS != result ) std::cout << "Problem getting vertices." << std::endl;
    MeshTopoUtil( gMB ).construct_aentities( all_verts );
    // get counts before constructing dual
    int num_edges;
    result = gMB->get_number_entities_by_dimension( 0, 1, num_edges );
    if( MB_SUCCESS != result ) std::cout << "Problem getting number of edges." << std::endl;
    // see if it's all-hex or all-quad, and construct hex/quad dual if so
    int num_hex, num_quad, num_3d, num_2d;
    result = gMB->get_number_entities_by_dimension( 0, 2, num_2d );
    if( MB_SUCCESS != result ) return 0;
    result = gMB->get_number_entities_by_dimension( 0, 3, num_3d );
    result = gMB->get_number_entities_by_type( 0, MBQUAD, num_quad );
    result = gMB->get_number_entities_by_type( 0, MBHEX, num_hex );
    // construct the dual for this mesh
    DualTool dt( gMB );
    if( num_quad == num_2d && num_hex == num_3d )
        result = dt.construct_hex_dual( 0, 0 );
    else
        result = dt.construct_dual( 0, 0 );
        std::cout << "Problems constructing dual." << std::endl;
        return 0;
    // print information about the dual
    Range dual_cells, dual_faces;
    result = dt.get_dual_entities( 0, 0, 2, dual_faces );
        std::cout << "Problem getting dual faces." << std::endl;
    else
        std::cout << "Found " << dual_faces.size() << "/" << num_edges << " dual faces." << std::endl;
    result = dt.get_dual_entities( 0, 0, 3, dual_cells );
        std::cout << "Problem getting dual cells." << std::endl;
    else
        std::cout << "Found " << dual_cells.size() << "/" << all_verts.size() << " dual cells." << std::endl;
    // print information about dual hyperplanes, if any
    Tag hp_tag;
    Range hp_sets;
    if( num_2d == num_quad )
        // get sets with the right tag
        result = gMB->tag_get_handle( DualTool::DUAL_CURVE_TAG_NAME, 1, MB_TYPE_HANDLE, hp_tag );
        if( MB_SUCCESS == result )
            result = gMB->get_entities_by_type_and_tag( 0, MBENTITYSET, &hp_tag, NULL, 1, hp_sets );
            if( MB_SUCCESS == result && !hp_sets.empty() )
                std::cout << "Found " << hp_sets.size() << " 1d dual hyperplanes (chords)." << std::endl;
    if( num_3d == num_hex )
        result = gMB->tag_get_handle( DualTool::DUAL_SURFACE_TAG_NAME, 1, MB_TYPE_HANDLE, hp_tag );
            hp_sets.clear();
                std::cout << "Found " << hp_sets.size() << " 2d dual hyperplanes (sheets)." << std::endl;
    // write GMV file
    gMB->write_file( f2 );
    delete gMB;
    return 0;
Variable Documentation
Definition at line 13 of file dual_test.cpp.
Referenced by main().
const char default_output[] = "dual.vtk"
Definition at line 14 of file dual_test.cpp.
Definition at line 16 of file dual_test.cpp.
