exodus_test.cpp File Reference
#include "TestUtil.hpp"
#include "moab/Core.hpp"
#include "MBTagConventions.hpp"
#include "moab/CN.hpp"
#include "moab/Range.hpp"
#include "ReadNCDF.hpp"
#include "moab/FileOptions.hpp"
#include "ExoIIUtil.hpp"
#include <cmath>
#include <algorithm>
+ Include dependency graph for exodus_test.cpp:
Classes
struct  TestType
Defines
#define IS_BUILDING_MB
Functions
void read_file (Interface &moab, const char *input_file)
void check_ho_element (Interface &moab, EntityHandle entity, int mid_nodes[4])
void test_read_side (int sideset_id, EntityType sideset_type, int sideset_nodes_per_elem, bool shell_side=false)
void test_ho_elements (EntityType type, int num_nodes)
void mb_vertex_coordinate_test ()
void mb_bar_connectivity_test ()
void mb_tri_connectivity_test ()
void mb_quad_connectivity_test ()
void mb_hex_connectivity_test ()
void mb_tet_connectivity_test ()
void mb_write_mesh_test ()
void test_types ()
void test_tri6 ()
void test_tri7 ()
void test_quad5 ()
void test_quad8 ()
void test_quad9 ()
void test_tet8 ()
void test_tet10 ()
void test_tet14 ()
void test_hex9 ()
void test_hex20 ()
void test_hex27 ()
void test_read_tri6_side ()
void test_read_shell_side ()
void test_read_shell_edge ()
void test_read_hex20_side ()
void test_read_block_ids ()
void test_read_sideset_ids ()
void test_read_nodeset_ids ()
void test_write_polygons ()
void test_write_polyhedra ()
void test_read_polygons ()
void test_read_polyhedra ()
void test_read_alternate_coord_format ()
int main ()
void load_file_one (Interface *iface)
void check_type (const TestType &type)
void write_and_read (Interface &write_mb, Interface &read_mb, EntityHandle block=0)
void check_ho_elements (Interface &moab, EntityHandle block, EntityType type, int mid_nodes[4])
EntityHandle find_block (Interface &mb, EntityType type, const int has_mid_nodes[4])
EntityHandle find_sideset (Interface &mb, int sideset_id, EntityType)
void test_read_ids_common (const char *file_name, const char *tag_name, const int *expected_vals, int num_expected)
Variables
static const char ho_file [] = "ho_test.g"
static const char file_one [] = "mbtest1.g"
static const char alt_file [] = "hex_2x2x2_ss.exo"
static const char polyg [] = "poly8-10.vtk"
static const char polyh [] = "polyhedra.vtk"
static const char rpolyg [] = "polyg.exo"
static const char rpolyh [] = "polyh.exo"
Define Documentation
Definition at line 8 of file exodus_test.cpp.
Function Documentation
void check_ho_element ( Interface moab,
int  mid_nodes[4]
void check_ho_elements ( Interface moab,
EntityHandle  block,
EntityType  type,
int  mid_nodes[4]
Definition at line 767 of file exodus_test.cpp.
References moab::Range::all_of_type(), moab::Range::begin(), CHECK, CHECK_ERR, check_ho_element(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_handle(), and MBENTITYSET.
Referenced by test_read_side().
    ErrorCode rval;
    Range elems;
    rval = moab.get_entities_by_handle( block, elems, ( type != MBENTITYSET ? true : false ) );CHECK_ERR( rval );
    CHECK( !elems.empty() );
    CHECK( elems.all_of_type( type ) );
    for( Range::const_iterator i = elems.begin(); i != elems.end(); ++i )
        check_ho_element( moab, *i, mid_nodes );
void check_type ( const TestType type)
Definition at line 678 of file exodus_test.cpp.
References CHECK_EQUAL, dim, moab::CN::Dimension(), moab::ExoIIUtil::element_name_to_type(), moab::ExoIIUtil::element_type_name(), moab::ExoIIUtil::ElementTypeNames, TestType::exo_type, moab::ExoIIUtil::ExoIIElementMBEntity, moab::ExoIIUtil::HasMidNodes, moab::CN::HasMidNodes(), TestType::moab_type, TestType::name, TestType::num_nodes, and moab::ExoIIUtil::VerticesPerElement.
Referenced by test_types().
    int has_mid_nodes[4];
    CN::HasMidNodes( type.moab_type, type.num_nodes, has_mid_nodes );
    CHECK_EQUAL( type.moab_type, ExoIIUtil::ExoIIElementMBEntity[type.exo_type] );
    CHECK_EQUAL( type.name, std::string( ExoIIUtil::ElementTypeNames[type.exo_type] ) );
    CHECK_EQUAL( type.num_nodes, ExoIIUtil::VerticesPerElement[type.exo_type] );
    auto dim = CN::Dimension( type.moab_type );
    if( 3 == dim ) CHECK_EQUAL( has_mid_nodes[3], ExoIIUtil::HasMidNodes[type.exo_type][3] );
    if( 2 <= dim ) CHECK_EQUAL( has_mid_nodes[2], ExoIIUtil::HasMidNodes[type.exo_type][2] );
    if( 1 <= dim ) CHECK_EQUAL( has_mid_nodes[1], ExoIIUtil::HasMidNodes[type.exo_type][1] );
    Core moab;
    ExoIIUtil tool( &moab );
    CHECK_EQUAL( type.exo_type, tool.element_name_to_type( type.name.c_str() ) );
    CHECK_EQUAL( type.name, std::string( tool.element_type_name( type.exo_type ) ) );
EntityHandle find_block ( Interface mb,
EntityType  type,
Definition at line 837 of file exodus_test.cpp.
References moab::Range::begin(), CHECK, CHECK_ERR, moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_type_and_tag(), moab::Interface::get_number_entities_by_type(), HAS_MID_NODES_TAG_NAME, MATERIAL_SET_TAG_NAME, MB_TYPE_INTEGER, MBENTITYSET, and moab::Interface::tag_get_handle().
    ErrorCode rval;
    Tag ho_tag, block_tag;
    const int negone = -1;
    rval             = mb.tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, block_tag, 0, &negone );CHECK_ERR( rval );
    const int mids[] = { -1, -1, -1, -1 };
    rval             = mb.tag_get_handle( HAS_MID_NODES_TAG_NAME, 4, MB_TYPE_INTEGER, ho_tag, 0, mids );CHECK_ERR( rval );
    // get material sets with expected higher-order nodes
    Range blocks;
    Tag tags[2]         = { ho_tag, block_tag };
    const void* vals[2] = { has_mid_nodes, NULL };
    rval                = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, tags, vals, 2, blocks );CHECK_ERR( rval );
    for( Range::iterator i = blocks.begin(); i != blocks.end(); ++i )
        int n;
        rval = mb.get_number_entities_by_type( *i, type, n );CHECK_ERR( rval );
        if( n > 0 ) return *i;
    CHECK( false );  // no block matching element type description
    return 0;
EntityHandle find_sideset ( Interface mb,
int  sideset_id,
EntityType
Definition at line 864 of file exodus_test.cpp.
References CHECK_EQUAL, CHECK_ERR, ErrorCode, moab::Range::front(), moab::Interface::get_entities_by_type_and_tag(), MB_TYPE_INTEGER, MBENTITYSET, NEUMANN_SET_TAG_NAME, moab::Range::size(), and moab::Interface::tag_get_handle().
    ErrorCode rval;
    Tag ss_tag;
    rval             = mb.tag_get_handle( NEUMANN_SET_TAG_NAME, 1, MB_TYPE_INTEGER, ss_tag, 0, &negone );CHECK_ERR( rval );
    const void* tag_vals[] = { &sideset_id };
    Range side_sets;
    rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &ss_tag, tag_vals, 1, side_sets );CHECK_ERR( rval );
    CHECK_EQUAL( 1, (int)side_sets.size() );
    return side_sets.front();
void load_file_one ( Interface iface)
Definition at line 186 of file exodus_test.cpp.
References CHECK_ERR, moab::error(), ErrorCode, file_one, moab::Interface::get_last_error(), moab::Interface::load_mesh(), and MB_SUCCESS.
Referenced by mb_bar_connectivity_test(), mb_hex_connectivity_test(), mb_quad_connectivity_test(), mb_tet_connectivity_test(), mb_tri_connectivity_test(), mb_vertex_coordinate_test(), and mb_write_mesh_test().
    ErrorCode error = iface->load_mesh( file_one );
    if( MB_SUCCESS != error )
        std::cout << "Failed to load input file: " << file_one << std::endl;
        std::string error_reason;
        iface->get_last_error( error_reason );
        std::cout << error_reason << std::endl;
    CHECK_ERR( error );
int main ( )
Definition at line 141 of file exodus_test.cpp.
References mb_bar_connectivity_test(), mb_hex_connectivity_test(), mb_quad_connectivity_test(), mb_tet_connectivity_test(), mb_tri_connectivity_test(), mb_vertex_coordinate_test(), mb_write_mesh_test(), RUN_TEST, test_hex20(), test_hex27(), test_hex9(), test_quad5(), test_quad8(), test_quad9(), test_read_alternate_coord_format(), test_read_block_ids(), test_read_hex20_side(), test_read_nodeset_ids(), test_read_polygons(), test_read_polyhedra(), test_read_shell_edge(), test_read_shell_side(), test_read_sideset_ids(), test_read_tri6_side(), test_tet10(), test_tet14(), test_tet8(), test_tri6(), test_tri7(), test_types(), test_write_polygons(), and test_write_polyhedra().
    int result = 0;
    result += RUN_TEST( mb_vertex_coordinate_test );
    result += RUN_TEST( mb_bar_connectivity_test );
    result += RUN_TEST( mb_tri_connectivity_test );
    result += RUN_TEST( mb_quad_connectivity_test );
    result += RUN_TEST( mb_hex_connectivity_test );
    result += RUN_TEST( mb_tet_connectivity_test );
    result += RUN_TEST( mb_write_mesh_test );
    result += RUN_TEST( test_types );
    result += RUN_TEST( test_tri6 );
    result += RUN_TEST( test_tri7 );
    result += RUN_TEST( test_quad5 );
    result += RUN_TEST( test_quad8 );
    result += RUN_TEST( test_quad9 );
    result += RUN_TEST( test_tet8 );
    result += RUN_TEST( test_tet10 );
    result += RUN_TEST( test_tet14 );
    result += RUN_TEST( test_hex9 );
    result += RUN_TEST( test_hex20 );
    result += RUN_TEST( test_hex27 );
    result += RUN_TEST( test_read_tri6_side );
    result += RUN_TEST( test_read_shell_side );
    result += RUN_TEST( test_read_shell_edge );
    result += RUN_TEST( test_read_hex20_side );
    result += RUN_TEST( test_read_block_ids );
    result += RUN_TEST( test_read_sideset_ids );
    result += RUN_TEST( test_read_nodeset_ids );
    result += RUN_TEST( test_read_alternate_coord_format );
    result += RUN_TEST( test_write_polygons );
    result += RUN_TEST( test_write_polyhedra );
    result += RUN_TEST( test_read_polygons );
    result += RUN_TEST( test_read_polyhedra );
    return result;
Test:
MB Bar Element Connectivity Test
  • Get coordinates for 2 node bar elements
Definition at line 248 of file exodus_test.cpp.
References moab::Range::begin(), CHECK_EQUAL, CHECK_ERR, moab::error(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_type(), load_file_one(), and MBEDGE.
Referenced by main().
    Core moab;
    Interface* MB = &moab;
    load_file_one( MB );
    std::vector< EntityHandle > conn;
    Range bars;
    ErrorCode error = MB->get_entities_by_type( 0, MBEDGE, bars );CHECK_ERR( error );
    // get the connectivity of the second bar
    EntityHandle handle = *( ++bars.begin() );
    error = MB->get_connectivity( &handle, 1, conn );CHECK_ERR( error );
    CHECK_EQUAL( (size_t)2, conn.size() );
    // from ncdump the connectivity of bar 2 (0 based) is
    //  14, 13
    CHECK_EQUAL( (EntityHandle)14, conn[0] );
    CHECK_EQUAL( (EntityHandle)13, conn[1] );
    // Now try getting the connectivity of one of the vertices for fun.
    // just return the vertex in the connectivity
    handle = conn[0];
    CHECK_EQUAL( MB_FAILURE, error );
Definition at line 330 of file exodus_test.cpp.
References moab::Range::begin(), CHECK_EQUAL, CHECK_ERR, moab::error(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_type(), load_file_one(), and MBHEX.
    Core moab;
    Range hexes;
    ErrorCode error = MB->get_entities_by_type( 0, MBHEX, hexes );CHECK_ERR( error );
    // get the connectivity of the second hex
    EntityHandle handle = *( ++hexes.begin() );
    CHECK_EQUAL( (size_t)8, conn.size() );
    // from ncdump the connectivity of hex 1 (0 based) is
    // 19, 13, 16, 23, 21, 14, 18, 27
    CHECK_EQUAL( (EntityHandle)19, conn[0] );
    CHECK_EQUAL( (EntityHandle)16, conn[2] );
    CHECK_EQUAL( (EntityHandle)23, conn[3] );
    CHECK_EQUAL( (EntityHandle)21, conn[4] );
    CHECK_EQUAL( (EntityHandle)14, conn[5] );
    CHECK_EQUAL( (EntityHandle)18, conn[6] );
    CHECK_EQUAL( (EntityHandle)27, conn[7] );
Definition at line 303 of file exodus_test.cpp.
References moab::Range::begin(), CHECK_EQUAL, CHECK_ERR, moab::error(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_type(), load_file_one(), and MBQUAD.
    Core moab;
    Range quads;
    ErrorCode error = MB->get_entities_by_type( 0, MBQUAD, quads );CHECK_ERR( error );
    // get the connectivity of the second quad
    EntityHandle handle = *( ++quads.begin() );
    CHECK_EQUAL( (size_t)4, conn.size() );
    // from ncdump the connectivity of quad 2 (0 based) is
    // 20, 11, 12, 26,
    CHECK_EQUAL( (EntityHandle)20, conn[0] );
    CHECK_EQUAL( (EntityHandle)11, conn[1] );
    CHECK_EQUAL( (EntityHandle)12, conn[2] );
    CHECK_EQUAL( (EntityHandle)26, conn[3] );
Definition at line 361 of file exodus_test.cpp.
References moab::Range::begin(), CHECK_EQUAL, CHECK_ERR, moab::error(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_type(), load_file_one(), and MBTET.
    Core moab;
    Range tets;
    ErrorCode error = MB->get_entities_by_type( 0, MBTET, tets );CHECK_ERR( error );
    // get the connectivity of the second tet
    EntityHandle handle = *( ++tets.begin() );
    // from ncdump the connectivity of tet 2 (0 based) is:
    // 35, 34, 32, 43
    CHECK_EQUAL( (EntityHandle)35, conn[0] );
    CHECK_EQUAL( (EntityHandle)34, conn[1] );
    CHECK_EQUAL( (EntityHandle)32, conn[2] );
    CHECK_EQUAL( (EntityHandle)43, conn[3] );
Definition at line 278 of file exodus_test.cpp.
References moab::Range::begin(), CHECK_EQUAL, CHECK_ERR, moab::error(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_type(), load_file_one(), and MBTRI.
    Core moab;
    Range tris;
    ErrorCode error = MB->get_entities_by_type( 0, MBTRI, tris );CHECK_ERR( error );
    // get the connectivity of the second tri
    EntityHandle handle = *( ++tris.begin() );
    CHECK_EQUAL( (size_t)3, conn.size() );
    // from ncdump the connectivity of tri 2 (0 based) is
    //  45, 37, 38
    CHECK_EQUAL( (EntityHandle)45, conn[0] );
    CHECK_EQUAL( (EntityHandle)37, conn[1] );
    CHECK_EQUAL( (EntityHandle)38, conn[2] );
Test:
Vertex Coordinates
  • Get coordinates of vertex 1 correctly
  • Get coordinates of vertex 8 correctly
  • Get coordinates of vertex 6 correctly
Definition at line 206 of file exodus_test.cpp.
References CHECK_ARRAYS_EQUAL, CHECK_EQUAL, CHECK_ERR, moab::CREATE_HANDLE(), moab::error(), ErrorCode, moab::Interface::get_coords(), moab::Interface::get_number_entities_by_type(), load_file_one(), and MBVERTEX.
    double coords[3];
    EntityHandle handle;
    ErrorCode error;
    int err;
    Core moab;
    // coordinate 2 should be {1.5, -1.5, 3.5}
    handle = CREATE_HANDLE( MBVERTEX, 2, err );
    error  = MB->get_coords( &handle, 1, coords );CHECK_ERR( error );
    const double exp2[] = { 1.5, -1.5, 3.5 };
    CHECK_ARRAYS_EQUAL( exp2, 3, coords, 3 );
    // coordinate 9 should be {1, -2, 3.5}
    handle = CREATE_HANDLE( MBVERTEX, 9, err );
    const double exp9[] = { 1, -2, 3.5 };
    CHECK_ARRAYS_EQUAL( exp9, 3, coords, 3 );
    // coordinate 7 should be {0.5, -2, 3.5}
    handle = CREATE_HANDLE( MBVERTEX, 7, err );
    const double exp7[] = { 0.5, -2, 3.5 };
    CHECK_ARRAYS_EQUAL( exp7, 3, coords, 3 );
    int node_count = 0;
    error          = MB->get_number_entities_by_type( 0, MBVERTEX, node_count );CHECK_ERR( error );
    // Number of vertices (node_count) should be 83 assuming no gaps in the handle space
    CHECK_EQUAL( 47, node_count );
Definition at line 387 of file exodus_test.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), CHECK_ERR, moab::Range::clear(), moab::Interface::create_meshset(), DIRICHLET_SET_TAG_NAME, moab::Range::end(), ErrorCode, GEOM_DIMENSION_TAG_NAME, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), moab::ID_FROM_HANDLE(), moab::Range::insert(), load_file_one(), MATERIAL_SET_TAG_NAME, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBHEX, MBQUAD, MESHSET_TRACK_OWNER, NEUMANN_SET_TAG_NAME, moab::Range::size(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), and moab::Interface::write_mesh().
    Core moab;
    ErrorCode result;
    std::string file_name = "mb_write.g";
    // no need to get lists, write out the whole mesh
    result = MB->write_mesh( file_name.c_str() );CHECK_ERR( result );
    //---------The following tests outputting meshsets that are in meshsets of blocks ---/
    // lets create a block meshset and put some entities and meshsets into it
    EntityHandle block_ms;
    result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, block_ms );CHECK_ERR( result );
    // make another meshset to put quads in, so SHELLs can be written out
    EntityHandle block_of_shells;
    result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, block_of_shells );CHECK_ERR( result );
    // tag the meshset so it's a block, with id 100
    int id = 100;
    Tag tag_handle;
    result           = MB->tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, tag_handle, 0, &negone );CHECK_ERR( result );
    result = MB->tag_set_data( tag_handle, &block_ms, 1, &id );CHECK_ERR( result );
    id     = 101;
    result = MB->tag_set_data( tag_handle, &block_of_shells, 1, &id );CHECK_ERR( result );
    // set dimension tag on this to ensure shells get output; reuse id variable
    result = MB->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, tag_handle, 0, &negone );CHECK_ERR( result );
    id     = 3;
    // get some entities (tets)
    Range temp_range;
    result = MB->get_entities_by_type( 0, MBHEX, temp_range );CHECK_ERR( result );
    Range::iterator iter, end_iter;
    iter     = temp_range.begin();
    end_iter = temp_range.end();
    // add evens to 'block_ms'
    std::vector< EntityHandle > temp_vec;
    for( ; iter != end_iter; ++iter )
        if( ID_FROM_HANDLE( *iter ) % 2 == 0 ) temp_vec.push_back( *iter );
    result = MB->add_entities( block_ms, &temp_vec[0], temp_vec.size() );CHECK_ERR( result );
    EntityHandle ms_of_block_ms;
    result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, ms_of_block_ms );CHECK_ERR( result );
    // add some entities to it
    temp_vec.clear();
        if( ID_FROM_HANDLE( *iter ) % 2 )  // add all odds
    result = MB->add_entities( ms_of_block_ms, &temp_vec[0], temp_vec.size() );CHECK_ERR( result );
    // add the other meshset to the block's meshset
    result = MB->add_entities( block_ms, &ms_of_block_ms, 1 );CHECK_ERR( result );
    //---------------testing sidesets----------------/
    // lets create a sideset meshset and put some entities and meshsets into it
    EntityHandle sideset_ms;
    result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, sideset_ms );CHECK_ERR( result );
    // tag the meshset so it's a sideset, with id 104
    id     = 104;
    result = MB->tag_get_handle( NEUMANN_SET_TAG_NAME, 1, MB_TYPE_INTEGER, tag_handle, 0, &negone );CHECK_ERR( result );
    result = MB->tag_set_data( tag_handle, &sideset_ms, 1, &id );CHECK_ERR( result );
    // get some entities (tris)
    temp_range.clear();
    result = MB->get_entities_by_type( 0, MBQUAD, temp_range );CHECK_ERR( result );
    // add evens to 'sideset_ms'
    temp_vec.clear();
    result = MB->add_entities( sideset_ms, &temp_vec[0], temp_vec.size() );CHECK_ERR( result );
    EntityHandle ms_of_sideset_ms;
    result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, ms_of_sideset_ms );CHECK_ERR( result );
    temp_vec.clear();
    result = MB->add_entities( ms_of_sideset_ms, &temp_vec[0], temp_vec.size() );CHECK_ERR( result );
    // add the other meshset to the sideset's meshset
    result = MB->add_entities( sideset_ms, &ms_of_sideset_ms, 1 );CHECK_ERR( result );
    //---------test sense on meshsets (reverse/foward)-------//
    // get all quads whose x-coord = 2.5 and put them into a meshset_a
    EntityHandle meshset_a;
    result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, meshset_a );CHECK_ERR( result );
    temp_range.clear();
    std::vector< EntityHandle > nodes1, entity_vec;
    std::copy( temp_range.begin(), temp_range.end(), std::back_inserter( entity_vec ) );
    result = MB->get_connectivity( &entity_vec[0], entity_vec.size(), nodes1 );CHECK_ERR( result );
    assert( nodes1.size() == 4 * temp_range.size() );
    temp_vec.clear();
    std::vector< double > coords( 3 * nodes1.size() );
    result = MB->get_coords( &nodes1[0], nodes1.size(), &coords[0] );CHECK_ERR( result );
    unsigned int k = 0;
    for( Range::iterator it = temp_range.begin(); it != temp_range.end(); ++it )
        if( coords[12 * k] == 2.5 && coords[12 * k + 3] == 2.5 && coords[12 * k + 6] == 2.5 &&
            coords[12 * k + 9] == 2.5 )
            temp_vec.push_back( *it );
        k++;
    result = MB->add_entities( meshset_a, ( temp_vec.empty() ) ? NULL : &temp_vec[0], temp_vec.size() );CHECK_ERR( result );
    result = MB->add_entities( block_of_shells, ( temp_vec.empty() ) ? NULL : &temp_vec[0], temp_vec.size() );CHECK_ERR( result );
    // put these quads into a different meshset_b and tag them with a reverse sense tag
    EntityHandle meshset_b;
    result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, meshset_b );CHECK_ERR( result );
    result = MB->add_entities( meshset_b, &meshset_a, 1 );CHECK_ERR( result );
    result = MB->tag_get_handle( "SENSE", 1, MB_TYPE_INTEGER, tag_handle, MB_TAG_SPARSE | MB_TAG_CREAT );CHECK_ERR( result );
    int reverse_value = -1;
    result            = MB->tag_set_data( tag_handle, &meshset_b, 1, &reverse_value );CHECK_ERR( result );
    // get some random quad, whose x-coord != 2.5, and put it into a different meshset_c
    // and tag it with a reverse sense tag
    temp_vec.clear();
        std::vector< EntityHandle > nodes;
        result = MB->get_connectivity( &( *iter ), 1, nodes );CHECK_ERR( result );
        bool not_equal_2_5 = true;
        for( unsigned int ku = 0; ku < nodes.size(); ku++ )
            double coords2[3] = { 0 };
            result = MB->get_coords( &( nodes[ku] ), 1, coords2 );CHECK_ERR( result );
            if( coords2[0] == 2.5 )
                not_equal_2_5 = false;
                break;
        if( not_equal_2_5 && nodes.size() > 0 )
            break;
    EntityHandle meshset_c;
    MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, meshset_c );
    result = MB->tag_get_handle( "SENSE", 1, MB_TYPE_INTEGER, tag_handle );CHECK_ERR( result );
    reverse_value = -1;
    result        = MB->tag_set_data( tag_handle, &meshset_c, 1, &reverse_value );CHECK_ERR( result );
    MB->add_entities( meshset_c, &temp_vec[0], temp_vec.size() );
    MB->add_entities( block_of_shells, &temp_vec[0], temp_vec.size() );
    // create another meshset_abc, adding meshset_a, meshset_b, meshset_c
    EntityHandle meshset_abc;
    MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, meshset_abc );
    temp_vec.clear();
    temp_vec.push_back( meshset_a );
    temp_vec.push_back( meshset_b );
    temp_vec.push_back( meshset_c );
    MB->add_entities( meshset_abc, &temp_vec[0], temp_vec.size() );
    // tag it so it's a sideset
    id     = 444;
    result = MB->tag_get_handle( "NEUMANN_SET", 1, MB_TYPE_INTEGER, tag_handle, 0, &negone );CHECK_ERR( result );
    result = MB->tag_set_data( tag_handle, &meshset_abc, 1, &id );CHECK_ERR( result );
    //---------------do nodesets now -----------------//
    // lets create a nodeset meshset and put some entities and meshsets into it
    EntityHandle nodeset_ms;
    MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, nodeset_ms );
    // tag the meshset so it's a nodeset, with id 119
    id     = 119;
    result = MB->tag_get_handle( DIRICHLET_SET_TAG_NAME, 1, MB_TYPE_INTEGER, tag_handle, 0, &negone );CHECK_ERR( result );
    result = MB->tag_set_data( tag_handle, &nodeset_ms, 1, &id );CHECK_ERR( result );
    // get all Quads
    temp_range.clear();
    // get all the nodes of the tris
    Range nodes_of_quads;
            nodes_of_quads.insert( nodes[ku] );
    iter     = nodes_of_quads.begin();
    end_iter = nodes_of_quads.end();
    // add evens to 'nodeset_ms'
    temp_vec.clear();
    MB->add_entities( nodeset_ms, &temp_vec[0], temp_vec.size() );
    EntityHandle ms_of_nodeset_ms;
    MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, ms_of_nodeset_ms );
    temp_vec.clear();
    MB->add_entities( ms_of_nodeset_ms, &temp_vec[0], temp_vec.size() );
    // add the other meshset to the nodeset's meshset
    MB->add_entities( nodeset_ms, &ms_of_nodeset_ms, 1 );
    file_name = "mb_write2.g";
    std::vector< EntityHandle > output_list;
    output_list.push_back( block_ms );
    output_list.push_back( sideset_ms );
    output_list.push_back( meshset_abc );
    output_list.push_back( nodeset_ms );
    output_list.push_back( block_of_shells );
    result = MB->write_mesh( file_name.c_str(), &output_list[0], output_list.size() );CHECK_ERR( result );
void read_file ( Interface moab,
const char *  input_file
Definition at line 748 of file exodus_test.cpp.
References CHECK_ERR, ErrorCode, and moab::Interface::load_file().
    ErrorCode rval = moab.load_file( input_file );CHECK_ERR( rval );
void test_hex20 ( )
Definition at line 105 of file exodus_test.cpp.
References MBHEX, and test_ho_elements().
    test_ho_elements( MBHEX, 20 );
void test_hex27 ( )
Definition at line 109 of file exodus_test.cpp.
    test_ho_elements( MBHEX, 27 );
void test_hex9 ( )
Definition at line 101 of file exodus_test.cpp.
void test_ho_elements ( EntityType  type,
int  num_nodes
void test_quad5 ( )
Definition at line 75 of file exodus_test.cpp.
References MBQUAD, and test_ho_elements().
void test_quad8 ( )
Definition at line 79 of file exodus_test.cpp.
void test_quad9 ( )
Definition at line 83 of file exodus_test.cpp.
Definition at line 967 of file exodus_test.cpp.
References alt_file, CHECK_ARRAYS_EQUAL, CHECK_EQUAL, CHECK_ERR, ErrorCode, moab::Range::front(), moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), moab::Interface::load_file(), mb, MBHEX, and moab::Range::size().
    Core moab;
    Interface& mb  = moab;
    ErrorCode rval = mb.load_file( alt_file );CHECK_ERR( rval );
    const double exp[] = { 0, 0, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0, 0, 0, 1, 1, 0, 1, 1, 1, 1, 0, 1, 1 };
    Range hexes;
    rval = mb.get_entities_by_type( 0, MBHEX, hexes );CHECK_ERR( rval );
    CHECK_EQUAL( (size_t)1, hexes.size() );
    EntityHandle hex = hexes.front();
    const EntityHandle* conn;
    int len;
    rval = mb.get_connectivity( hex, conn, len );CHECK_ERR( rval );
    CHECK_EQUAL( 8, len );
    double act[3 * 8];
    rval = mb.get_coords( conn, len, act );CHECK_ERR( rval );
    CHECK_ARRAYS_EQUAL( exp, 3 * 8, act, 3 * 8 );
Definition at line 950 of file exodus_test.cpp.
References ho_file, MATERIAL_SET_TAG_NAME, and test_read_ids_common().
    const int expected[] = { 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13 };
    test_read_ids_common( ho_file, MATERIAL_SET_TAG_NAME, expected, sizeof( expected ) / sizeof( expected[0] ) );
Definition at line 126 of file exodus_test.cpp.
References MBQUAD, and test_read_side().
    test_read_side( 2, MBQUAD, 8 );
}  // sideset 2
void test_read_ids_common ( const char *  file_name,
const char *  tag_name,
const int *  expected_vals,
int  num_expected
Definition at line 935 of file exodus_test.cpp.
References CHECK_EQUAL, CHECK_ERR, ErrorCode, mb, and moab::ReadNCDF::read_tag_values().
Referenced by test_read_block_ids(), test_read_nodeset_ids(), and test_read_sideset_ids().
    Core mb;
    ReadNCDF reader( &mb );
    FileOptions opts( "" );
    std::vector< int > values;
    ErrorCode rval = reader.read_tag_values( file_name, tag_name, opts, values );CHECK_ERR( rval );
    std::vector< int > expected( expected_vals, expected_vals + num_expected );
    std::sort( values.begin(), values.end() );
    std::sort( expected.begin(), expected.end() );
    CHECK_EQUAL( expected, values );
Definition at line 1002 of file exodus_test.cpp.
References CHECK_ERR, ErrorCode, moab::Interface::load_file(), mb, and rpolyg.
    Core moab;
    ErrorCode rval = mb.load_file( rpolyg );CHECK_ERR( rval );
Definition at line 1008 of file exodus_test.cpp.
References CHECK_ERR, ErrorCode, moab::Interface::load_file(), mb, and rpolyh.
    Core moab;
    ErrorCode rval = mb.load_file( rpolyh );CHECK_ERR( rval );
Definition at line 122 of file exodus_test.cpp.
References MBEDGE, and test_read_side().
    test_read_side( 4, MBEDGE, 3 );
}  // sideset 4
Definition at line 118 of file exodus_test.cpp.
    test_read_side( 3, MBQUAD, 9, true );
}  // sideset 3
void test_read_side ( int  sideset_id,
bool  shell_side = false
Definition at line 904 of file exodus_test.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, check_ho_elements(), dim, moab::CN::Dimension(), moab::Range::end(), ErrorCode, find_sideset(), moab::Core::get_adjacencies(), moab::Core::get_entities_by_handle(), moab::CN::HasMidNodes(), ho_file, read_file(), moab::Range::size(), and moab::Interface::UNION.
Referenced by test_read_hex20_side(), test_read_shell_edge(), test_read_shell_side(), and test_read_tri6_side().
    // read test file
    Core mb_impl;
    Interface& moab = mb_impl;
    read_file( moab, ho_file );
    // get side set
    EntityHandle set = find_sideset( moab, id, sideset_type );
    CHECK( set != 0 );
    // check expected element connectivity
    int ho_flags[4];
    CN::HasMidNodes( sideset_type, sideset_nodes_per_elem, ho_flags );
    check_ho_elements( moab, set, sideset_type, ho_flags );
    if( shell_side ) return;
    // check that each element is on the boundary of the mesh
    Range elems;
    ErrorCode rval = mb_impl.get_entities_by_handle( set, elems );CHECK_ERR( rval );
    int dim = CN::Dimension( sideset_type );
    for( Range::iterator i = elems.begin(); i != elems.end(); ++i )
        Range adj;
        rval = mb_impl.get_adjacencies( &*i, 1, dim + 1, false, adj, Interface::UNION );CHECK_ERR( rval );
        CHECK_EQUAL( 1, (int)adj.size() );
Definition at line 956 of file exodus_test.cpp.
References ho_file, NEUMANN_SET_TAG_NAME, and test_read_ids_common().
    const int expected[] = { 1, 2, 3, 4 };
    test_read_ids_common( ho_file, NEUMANN_SET_TAG_NAME, expected, sizeof( expected ) / sizeof( expected[0] ) );
Definition at line 114 of file exodus_test.cpp.
    test_read_side( 1, MBEDGE, 3 );
}  // sideset 1
void test_tet10 ( )
Definition at line 92 of file exodus_test.cpp.
References MBTET, and test_ho_elements().
    test_ho_elements( MBTET, 10 );
void test_tet14 ( )
Definition at line 96 of file exodus_test.cpp.
    test_ho_elements( MBTET, 14 );
void test_tet8 ( )
Definition at line 88 of file exodus_test.cpp.
void test_tri6 ( )
Definition at line 66 of file exodus_test.cpp.
References MBTRI, and test_ho_elements().
void test_tri7 ( )
Definition at line 70 of file exodus_test.cpp.
void test_types ( )
Definition at line 697 of file exodus_test.cpp.
References check_type(), moab::EXOII_BAR, moab::EXOII_BAR2, moab::EXOII_BAR3, moab::EXOII_BEAM, moab::EXOII_BEAM2, moab::EXOII_BEAM3, moab::EXOII_HEX, moab::EXOII_HEX20, moab::EXOII_HEX27, moab::EXOII_HEX8, moab::EXOII_HEX9, moab::EXOII_HEXSHELL, moab::EXOII_KNIFE, moab::EXOII_PYRAMID, moab::EXOII_PYRAMID10, moab::EXOII_PYRAMID13, moab::EXOII_PYRAMID18, moab::EXOII_PYRAMID5, moab::EXOII_QUAD, moab::EXOII_QUAD4, moab::EXOII_QUAD5, moab::EXOII_QUAD8, moab::EXOII_QUAD9, moab::EXOII_SHELL, moab::EXOII_SHELL4, moab::EXOII_SHELL5, moab::EXOII_SHELL8, moab::EXOII_SHELL9, moab::EXOII_SPHERE, moab::EXOII_SPRING, moab::EXOII_TET4, moab::EXOII_TETRA, moab::EXOII_TETRA10, moab::EXOII_TETRA14, moab::EXOII_TETRA4, moab::EXOII_TETRA8, moab::EXOII_TRI, moab::EXOII_TRI3, moab::EXOII_TRI6, moab::EXOII_TRI7, moab::EXOII_TRUSS, moab::EXOII_TRUSS2, moab::EXOII_TRUSS3, moab::EXOII_WEDGE, MBEDGE, MBHEX, MBKNIFE, MBPRISM, MBPYRAMID, MBQUAD, MBTET, MBTRI, and MBVERTEX.
    const TestType types[] = { { MBVERTEX, EXOII_SPHERE, 1, "SPHERE" },
                               { MBEDGE, EXOII_SPRING, 1, "SPRING" },
                               { MBEDGE, EXOII_BAR, 2, "BAR" },
                               { MBEDGE, EXOII_BAR2, 2, "BAR2" },
                               { MBEDGE, EXOII_BAR3, 3, "BAR3" },
                               { MBEDGE, EXOII_BEAM, 2, "BEAM" },
                               { MBEDGE, EXOII_BEAM2, 2, "BEAM2" },
                               { MBEDGE, EXOII_BEAM3, 3, "BEAM3" },
                               { MBEDGE, EXOII_TRUSS, 2, "TRUSS" },
                               { MBEDGE, EXOII_TRUSS2, 2, "TRUSS2" },
                               { MBEDGE, EXOII_TRUSS3, 3, "TRUSS3" },
                               { MBTRI, EXOII_TRI, 3, "TRI" },
                               { MBTRI, EXOII_TRI3, 3, "TRI3" },
                               { MBTRI, EXOII_TRI6, 6, "TRI6" },
                               { MBTRI, EXOII_TRI7, 7, "TRI7" },
                               { MBQUAD, EXOII_QUAD, 4, "QUAD" },
                               { MBQUAD, EXOII_QUAD4, 4, "QUAD4" },
                               { MBQUAD, EXOII_QUAD5, 5, "QUAD5" },
                               { MBQUAD, EXOII_QUAD8, 8, "QUAD8" },
                               { MBQUAD, EXOII_QUAD9, 9, "QUAD9" },
                               { MBQUAD, EXOII_SHELL, 4, "SHELL" },
                               { MBQUAD, EXOII_SHELL4, 4, "SHELL4" },
                               { MBQUAD, EXOII_SHELL5, 5, "SHELL5" },
                               { MBQUAD, EXOII_SHELL8, 8, "SHELL8" },
                               { MBQUAD, EXOII_SHELL9, 9, "SHELL9" },
                               { MBTET, EXOII_TETRA, 4, "TETRA" },
                               { MBTET, EXOII_TETRA4, 4, "TETRA4" },
                               { MBTET, EXOII_TET4, 4, "TET4" },
                               { MBTET, EXOII_TETRA8, 8, "TETRA8" },
                               { MBTET, EXOII_TETRA10, 10, "TETRA10" },
                               { MBTET, EXOII_TETRA14, 14, "TETRA14" },
                               { MBPYRAMID, EXOII_PYRAMID, 5, "PYRAMID" },
                               { MBPYRAMID, EXOII_PYRAMID5, 5, "PYRAMID5" },
                               { MBPYRAMID, EXOII_PYRAMID10, 10, "PYRAMID10" },
                               { MBPYRAMID, EXOII_PYRAMID13, 13, "PYRAMID13" },
                               { MBPYRAMID, EXOII_PYRAMID18, 18, "PYRAMID18" },
                               { MBPRISM, EXOII_WEDGE, 6, "WEDGE" },
                               { MBKNIFE, EXOII_KNIFE, 7, "KNIFE" },
                               { MBHEX, EXOII_HEX, 8, "HEX" },
                               { MBHEX, EXOII_HEX8, 8, "HEX8" },
                               { MBHEX, EXOII_HEX9, 9, "HEX9" },
                               { MBHEX, EXOII_HEX20, 20, "HEX20" },
                               { MBHEX, EXOII_HEX27, 27, "HEX27" },
                               { MBHEX, EXOII_HEXSHELL, 12, "HEXSHELL" } };
    const int num_types    = sizeof( types ) / sizeof( types[0] );
    for( int i = 0; i < num_types; ++i )
        check_type( types[i] );
Definition at line 987 of file exodus_test.cpp.
References CHECK_ERR, ErrorCode, moab::Interface::load_file(), mb, polyg, and moab::Interface::write_file().
    Core moab;
    ErrorCode rval = mb.load_file( polyg );CHECK_ERR( rval );
    rval = mb.write_file( "polyg.exo" );CHECK_ERR( rval );
Definition at line 995 of file exodus_test.cpp.
References CHECK_ERR, ErrorCode, moab::Interface::load_file(), mb, polyh, and moab::Interface::write_file().
    Core moab;
    ErrorCode rval = mb.load_file( polyh );CHECK_ERR( rval );
    rval = mb.write_file( "polyh.exo" );CHECK_ERR( rval );
void write_and_read ( Interface write_mb,
Interface read_mb,
EntityHandle  block = 0
Definition at line 753 of file exodus_test.cpp.
References CHECK_ERR, ErrorCode, moab::Interface::load_file(), MB_SUCCESS, tmp_file, and moab::Interface::write_file().
Referenced by check_tag_data(), and test_read_write_element().
    const char* tmp_file = "exodus_test_tmp.g";
    ErrorCode rval;
    EntityHandle* write_set_list = &block;
    int write_set_list_len       = 0;  //(block != 0);
    rval                         = write_mb.write_file( tmp_file, "EXODUS", 0, write_set_list, write_set_list_len );
    if( MB_SUCCESS != rval ) remove( tmp_file );CHECK_ERR( rval );
    rval = read_mb.load_file( tmp_file );
Variable Documentation
const char alt_file[] = "hex_2x2x2_ss.exo" [static]
Definition at line 33 of file exodus_test.cpp.
Referenced by test_read_alternate_coord_format().
const char file_one[] = "mbtest1.g" [static]
Definition at line 32 of file exodus_test.cpp.
Referenced by load_file_one().
const char ho_file[] = "ho_test.g" [static]
const char polyg[] = "poly8-10.vtk" [static]
const char polyh[] = "polyhedra.vtk" [static]
const char rpolyg[] = "polyg.exo" [static]
Definition at line 36 of file exodus_test.cpp.
Referenced by test_read_polygons().
const char rpolyh[] = "polyh.exo" [static]
Definition at line 37 of file exodus_test.cpp.
Referenced by test_read_polyhedra().
