gcrm_par.cpp File Reference
#include "TestUtil.hpp"
#include "moab/Core.hpp"
#include "moab/ParallelComm.hpp"
#include "moab/ProgOptions.hpp"
#include "MBParallelConventions.h"
#include "moab/ReadUtilIface.hpp"
#include "MBTagConventions.hpp"
#include <sstream>
+ Include dependency graph for gcrm_par.cpp:
Functions
void test_read_onevar_trivial ()
void test_read_mesh_parallel_trivial ()
void test_gather_onevar_on_rank0 ()
void test_gather_onevar_on_rank1 ()
void test_multiple_loads_of_same_file ()
void read_one_cell_var (bool rcbzoltan)
void read_mesh_parallel (bool rcbzoltan)
void gather_one_cell_var (int gather_set_rank)
void multiple_loads_of_same_file ()
int main (int argc, char *argv[])
void test_read_onevar_rcbzoltan ()
void test_read_mesh_parallel_rcbzoltan ()
Variables
std::string example = "unittest/io/gcrm_r3.nc"
std::string read_options
const double eps = 1e-6
const int layers = 3
Function Documentation
void gather_one_cell_var ( int  gather_set_rank)
Definition at line 470 of file gcrm_par.cpp.
References CHECK_EQUAL, CHECK_ERR, CHECK_REAL_EQUAL, moab::Interface::create_meshset(), eps, ErrorCode, example, moab::ParallelComm::filter_pstatus(), moab::ParallelComm::gather_data(), moab::Interface::get_entities_by_type(), moab::ReadUtilIface::get_gather_set(), moab::ParallelComm::get_pcomm(), moab::Interface::globalId_tag(), layers, moab::Interface::load_file(), mb, MB_TAG_DENSE, MB_TYPE_DOUBLE, MBPOLYGON, MESHSET_SET, moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), moab::Range::psize(), PSTATUS_NOT, PSTATUS_NOT_OWNED, moab::Interface::query_interface(), rank, read_options, moab::Range::size(), moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
Referenced by test_gather_onevar_on_rank0(), and test_gather_onevar_on_rank1().
    Core moab;
    Interface& mb = moab;
    EntityHandle file_set;
    ErrorCode rval = mb.create_meshset( MESHSET_SET, file_set );CHECK_ERR( rval );
    read_options = "PARALLEL=READ_PART;PARTITION_METHOD=TRIVIAL;PARALLEL_RESOLVE_SHARED_ENTS";
    std::ostringstream gather_set_option;
    gather_set_option << ";GATHER_SET=" << gather_set_rank;
    read_options += gather_set_option.str();
    rval = mb.load_file( example.c_str(), &file_set, read_options.c_str() );CHECK_ERR( rval );
    ParallelComm* pcomm = ParallelComm::get_pcomm( &mb, 0 );
    int procs           = pcomm->proc_config().proc_size();
    int rank            = pcomm->proc_config().proc_rank();
    // Make sure gather_set_rank is valid
    if( gather_set_rank < 0 || gather_set_rank >= procs ) return;
    Range cells, cells_owned;
    rval = mb.get_entities_by_type( file_set, MBPOLYGON, cells );CHECK_ERR( rval );
    // Get local owned cells
    rval = pcomm->filter_pstatus( cells, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &cells_owned );CHECK_ERR( rval );
    EntityHandle gather_set = 0;
    if( gather_set_rank == rank )
        // Get gather set
        ReadUtilIface* readUtilIface;
        mb.query_interface( readUtilIface );
        rval = readUtilIface->get_gather_set( gather_set );CHECK_ERR( rval );
        assert( gather_set != 0 );
    Tag vorticity_tag0, gid_tag;
    rval = mb.tag_get_handle( "vorticity0", layers, MB_TYPE_DOUBLE, vorticity_tag0, MB_TAG_DENSE );CHECK_ERR( rval );
    gid_tag = mb.globalId_tag();
    pcomm->gather_data( cells_owned, vorticity_tag0, gid_tag, gather_set, gather_set_rank );
        // Get gather set cells
        Range gather_set_cells;
        rval = mb.get_entities_by_type( gather_set, MBPOLYGON, gather_set_cells );CHECK_ERR( rval );
        CHECK_EQUAL( (size_t)642, gather_set_cells.size() );
        CHECK_EQUAL( (size_t)1, gather_set_cells.psize() );
        // Check vorticity0 tag values on 4 gather set cells: first cell, two median cells, and last
        // cell
        EntityHandle cell_ents[] = { gather_set_cells[0], gather_set_cells[320], gather_set_cells[321],
                                     gather_set_cells[641] };
        double vorticity0_val[4 * layers];
        rval = mb.tag_get_data( vorticity_tag0, &cell_ents[0], 4, vorticity0_val );CHECK_ERR( rval );
        // Only check first two layers
        // Layer 0
        CHECK_REAL_EQUAL( 3.629994, vorticity0_val[0 * layers], eps );
        CHECK_REAL_EQUAL( 0.131688, vorticity0_val[1 * layers], eps );
        CHECK_REAL_EQUAL( -0.554888, vorticity0_val[2 * layers], eps );
        CHECK_REAL_EQUAL( -0.554888, vorticity0_val[3 * layers], eps );
        // Layer 1
        CHECK_REAL_EQUAL( 3.629944, vorticity0_val[0 * layers + 1], eps );
        CHECK_REAL_EQUAL( 0.131686, vorticity0_val[1 * layers + 1], eps );
        CHECK_REAL_EQUAL( -0.554881, vorticity0_val[2 * layers + 1], eps );
        CHECK_REAL_EQUAL( -0.554881, vorticity0_val[3 * layers + 1], eps );
int main ( int  argc,
char *  argv[]
Definition at line 40 of file gcrm_par.cpp.
References RUN_TEST, test_gather_onevar_on_rank0(), test_gather_onevar_on_rank1(), test_multiple_loads_of_same_file(), test_read_mesh_parallel_rcbzoltan(), test_read_mesh_parallel_trivial(), test_read_onevar_rcbzoltan(), and test_read_onevar_trivial().
    MPI_Init( &argc, &argv );
    int result = 0;
    result += RUN_TEST( test_read_onevar_trivial );
#if defined( MOAB_HAVE_MPI ) && defined( MOAB_HAVE_ZOLTAN )
    result += RUN_TEST( test_read_onevar_rcbzoltan );
#endif
    result += RUN_TEST( test_read_mesh_parallel_trivial );
    result += RUN_TEST( test_read_mesh_parallel_rcbzoltan );
#endif
    result += RUN_TEST( test_gather_onevar_on_rank0 );
    result += RUN_TEST( test_gather_onevar_on_rank1 );
    result += RUN_TEST( test_multiple_loads_of_same_file );
    MPI_Finalize();
    return result;
Definition at line 544 of file gcrm_par.cpp.
References CHECK_EQUAL, CHECK_ERR, CHECK_REAL_EQUAL, moab::Interface::create_meshset(), eps, ErrorCode, example, moab::Interface::get_entities_by_type(), moab::ParallelComm::get_pcomm(), layers, moab::Interface::load_file(), mb, MB_TYPE_DOUBLE, MBEDGE, MBPOLYGON, MBVERTEX, MESHSET_SET, moab::Range::psize(), rank, read_options, moab::Range::size(), moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
Referenced by test_multiple_loads_of_same_file(), and test_multiple_loads_of_same_file_no_mixed_elements().
    Core moab;
    // Need a file set for nomesh to work right
    ErrorCode rval;
    // Read first only header information, no mesh, no variable
    read_options = "PARALLEL=READ_PART;PARTITION;NOMESH;VARIABLE=;PARTITION_METHOD=TRIVIAL";
    // Create mesh, no variable
    read_options = "PARALLEL=READ_PART;PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;PARTITION_METHOD="
                   "TRIVIAL;VARIABLE=";
    // Read variable vorticity at timestep 0, no mesh
    read_options = "PARALLEL=READ_PART;PARTITION;PARTITION_METHOD=TRIVIAL;NOMESH;VARIABLE="
                   "vorticity;TIMESTEP=0";
    Range local_verts;
    rval = mb.get_entities_by_type( file_set, MBVERTEX, local_verts );CHECK_ERR( rval );
    Range local_edges;
    rval = mb.get_entities_by_type( file_set, MBEDGE, local_edges );CHECK_ERR( rval );
    Range local_cells;
    rval = mb.get_entities_by_type( file_set, MBPOLYGON, local_cells );CHECK_ERR( rval );
    // No mixed elements
    CHECK_EQUAL( (size_t)1, local_cells.psize() );
    // Make check runs this test on two processors
    if( 2 == procs )
        CHECK_EQUAL( (size_t)321, local_cells.size() );
        // Check tag for cell variable vorticity at timestep 0
        Tag vorticity_tag0;
        rval = mb.tag_get_handle( "vorticity0", layers, MB_TYPE_DOUBLE, vorticity_tag0 );CHECK_ERR( rval );
        // Get vorticity0 tag values on 3 local cells
        double vorticity0_val[3 * layers];
        EntityHandle cell_ents[] = { local_cells[0], local_cells[160], local_cells[320] };
        rval                     = mb.tag_get_data( vorticity_tag0, cell_ents, 3, vorticity0_val );CHECK_ERR( rval );
        if( 0 == rank )
            CHECK_EQUAL( (size_t)687, local_verts.size() );
            CHECK_EQUAL( (size_t)1007, local_edges.size() );
            // Layer 0
            CHECK_REAL_EQUAL( -1.708188, vorticity0_val[1 * layers], eps );
            CHECK_REAL_EQUAL( 0.131688, vorticity0_val[2 * layers], eps );
            // Layer 1
            CHECK_REAL_EQUAL( -1.708164, vorticity0_val[1 * layers + 1], eps );
            CHECK_REAL_EQUAL( 0.131686, vorticity0_val[2 * layers + 1], eps );
        else if( 1 == rank )
            CHECK_EQUAL( (size_t)688, local_verts.size() );
            CHECK_EQUAL( (size_t)1008, local_edges.size() );
            // Layer 0
            CHECK_REAL_EQUAL( -0.554888, vorticity0_val[0 * layers], eps );
            CHECK_REAL_EQUAL( 2.434397, vorticity0_val[1 * layers], eps );
            // Layer 1
            CHECK_REAL_EQUAL( -0.554881, vorticity0_val[0 * layers + 1], eps );
            CHECK_REAL_EQUAL( 2.434363, vorticity0_val[1 * layers + 1], eps );
void read_mesh_parallel ( bool  rcbzoltan)
Definition at line 288 of file gcrm_par.cpp.
References moab::ParallelComm::check_all_shared_handles(), CHECK_EQUAL, CHECK_ERR, ErrorCode, example, moab::ParallelComm::filter_pstatus(), moab::Interface::get_entities_by_type(), moab::ParallelComm::get_pcomm(), moab::Interface::load_file(), mb, MBEDGE, MBPOLYGON, MBVERTEX, moab::ProcConfig::proc_comm(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), moab::Range::psize(), PSTATUS_NOT, PSTATUS_NOT_OWNED, rank, read_options, moab::Range::size(), and moab::Interface::write_file().
Referenced by test_read_mesh_parallel_rcbzoltan(), test_read_mesh_parallel_rcbzoltan_no_mixed_elements(), test_read_mesh_parallel_trivial(), and test_read_mesh_parallel_trivial_no_mixed_elements().
    Core moab;
    read_options = "PARALLEL=READ_PART;PARTITION_METHOD=TRIVIAL;PARALLEL_RESOLVE_SHARED_ENTS;VARIABLE=";
    if( rcbzoltan )
        read_options = "PARALLEL=READ_PART;PARTITION_METHOD=RCBZOLTAN;PARALLEL_RESOLVE_SHARED_ENTS;VARIABLE=";
    ErrorCode rval = mb.load_file( example.c_str(), NULL, read_options.c_str() );CHECK_ERR( rval );
    rval = pcomm->check_all_shared_handles();CHECK_ERR( rval );
    // Get local vertices
    Range local_verts;
    rval = mb.get_entities_by_type( 0, MBVERTEX, local_verts );CHECK_ERR( rval );
    int verts_num = local_verts.size();
    if( 2 == procs )
        if( rcbzoltan )
            if( 0 == rank )
                CHECK_EQUAL( 688, verts_num );
                CHECK_EQUAL( 687, verts_num );  // Not owned vertices included
        else
            if( 0 == rank )
                CHECK_EQUAL( 688, verts_num );  // Not owned vertices included
    rval = pcomm->filter_pstatus( local_verts, PSTATUS_NOT_OWNED, PSTATUS_NOT );CHECK_ERR( rval );
    if( 2 == procs )
        if( rcbzoltan )
            if( 0 == rank )
                CHECK_EQUAL( 592, verts_num );  // Not owned vertices excluded
        else
            if( 0 == rank )
                CHECK_EQUAL( 593, verts_num );  // Not owned vertices excluded
    // Get local edges
    Range local_edges;
    rval = mb.get_entities_by_type( 0, MBEDGE, local_edges );CHECK_ERR( rval );
    int edges_num = local_edges.size();
    if( 2 == procs )
        if( rcbzoltan )
            if( 0 == rank )
                CHECK_EQUAL( 1008, edges_num );
                CHECK_EQUAL( 1007, edges_num );  // Not owned edges included
        else
            if( 0 == rank )
                CHECK_EQUAL( 1008, edges_num );  // Not owned edges included
    rval = pcomm->filter_pstatus( local_edges, PSTATUS_NOT_OWNED, PSTATUS_NOT );CHECK_ERR( rval );
    if( 2 == procs )
        if( rcbzoltan )
            if( 0 == rank )
                CHECK_EQUAL( 912, edges_num );  // Not owned edges excluded
        else
            if( 0 == rank )
                CHECK_EQUAL( 913, edges_num );  // Not owned edges excluded
    // Get local cells
    Range local_cells;
    rval = mb.get_entities_by_type( 0, MBPOLYGON, local_cells );CHECK_ERR( rval );
    int cells_num = local_cells.size();
    if( 2 == procs )
        if( rcbzoltan )
            if( 0 == rank )
                CHECK_EQUAL( 321, cells_num );
            else
        else
    rval = pcomm->filter_pstatus( local_cells, PSTATUS_NOT_OWNED, PSTATUS_NOT );CHECK_ERR( rval );
    if( 2 == procs )
        if( rcbzoltan )
            if( 0 == rank )
            else
        else
    std::cout << "proc: " << rank << " verts:" << verts_num << "\n";
    int total_verts_num;
    MPI_Reduce( &verts_num, &total_verts_num, 1, MPI_INT, MPI_SUM, 0, pcomm->proc_config().proc_comm() );
    if( 0 == rank )
        std::cout << "total vertices: " << total_verts_num << "\n";
        CHECK_EQUAL( 1280, total_verts_num );
    std::cout << "proc: " << rank << " edges:" << edges_num << "\n";
    int total_edges_num;
    MPI_Reduce( &edges_num, &total_edges_num, 1, MPI_INT, MPI_SUM, 0, pcomm->proc_config().proc_comm() );
    if( 0 == rank )
        std::cout << "total edges: " << total_edges_num << "\n";
        CHECK_EQUAL( 1920, total_edges_num );
    std::cout << "proc: " << rank << " cells:" << cells_num << "\n";
    int total_cells_num;
    MPI_Reduce( &cells_num, &total_cells_num, 1, MPI_INT, MPI_SUM, 0, pcomm->proc_config().proc_comm() );
    if( 0 == rank )
        std::cout << "total cells: " << total_cells_num << "\n";
        CHECK_EQUAL( 642, total_cells_num );
#ifdef MOAB_HAVE_HDF5_PARALLEL
    std::string write_options( "PARALLEL=WRITE_PART;" );
    std::string output_file = "test_gcrm";
    if( rcbzoltan ) output_file += "_rcbzoltan";
    output_file += ".h5m";
    mb.write_file( output_file.c_str(), NULL, write_options.c_str() );
#endif
void read_one_cell_var ( bool  rcbzoltan)
Definition at line 100 of file gcrm_par.cpp.
References CHECK_EQUAL, CHECK_ERR, CHECK_REAL_EQUAL, eps, ErrorCode, example, moab::Interface::get_entities_by_type(), moab::ParallelComm::get_pcomm(), moab::Interface::globalId_tag(), layers, moab::Interface::load_file(), mb, MB_TYPE_DOUBLE, MBEDGE, MBPOLYGON, moab::Range::psize(), rank, read_options, moab::Range::size(), moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
Referenced by test_read_onevar_rcbzoltan(), test_read_onevar_rcbzoltan_no_mixed_elements(), test_read_onevar_trivial(), and test_read_onevar_trivial_no_mixed_elements().
    Core moab;
    read_options = "PARALLEL=READ_PART;PARTITION_METHOD=TRIVIAL;NO_EDGES;VARIABLE=vorticity";
    if( rcbzoltan )
        read_options = "PARALLEL=READ_PART;PARTITION_METHOD=RCBZOLTAN;NO_EDGES;VARIABLE=vorticity;DEBUG_IO=1";
    // Get local edges
    Range local_edges;
    CHECK_EQUAL( (size_t)0, local_edges.size() );
    // Get local cells
    Range local_cells;
    Tag gid_tag = mb.globalId_tag();
    std::vector< int > gids( local_cells.size() );
    rval = mb.tag_get_data( gid_tag, local_cells, &gids[0] );
    Range local_cell_gids;
    std::copy( gids.rbegin(), gids.rend(), range_inserter( local_cell_gids ) );
    if( 2 == procs )
        Tag vorticity_tag0;
        // Check tag for cell variable vorticity at timestep 1
        Tag vorticity_tag1;
        rval = mb.tag_get_handle( "vorticity1", layers, MB_TYPE_DOUBLE, vorticity_tag1 );CHECK_ERR( rval );
        // Get vorticity0 and vorticity1 tag values on 3 local cells
        double vorticity1_val[3 * layers];
        if( rcbzoltan )
            CHECK_EQUAL( (size_t)14, local_cell_gids.psize() );
            if( 0 == rank )
                CHECK_EQUAL( (size_t)321, local_cell_gids.size() );
                CHECK_EQUAL( 3, (int)local_cell_gids[0] );
                CHECK_EQUAL( 162, (int)local_cell_gids[159] );
                CHECK_EQUAL( 640, (int)local_cell_gids[318] );
                EntityHandle cell_ents[] = { local_cells[0], local_cells[159], local_cells[318] };
                // Timestep 0
                // Layer 0
                CHECK_REAL_EQUAL( -0.725999, vorticity0_val[0 * layers], eps );
                CHECK_REAL_EQUAL( -1.814997, vorticity0_val[1 * layers], eps );
                // Layer 1
                CHECK_REAL_EQUAL( -0.725989, vorticity0_val[0 * layers + 1], eps );
                CHECK_REAL_EQUAL( -1.814972, vorticity0_val[1 * layers + 1], eps );
                rval = mb.tag_get_data( vorticity_tag1, cell_ents, 3, vorticity1_val );CHECK_ERR( rval );
                // Timestep 1
                // Layer 0
                CHECK_REAL_EQUAL( -0.706871, vorticity1_val[0 * layers], eps );
                CHECK_REAL_EQUAL( -1.767178, vorticity1_val[1 * layers], eps );
                CHECK_REAL_EQUAL( 0.128218, vorticity1_val[2 * layers], eps );
                // Layer 1
                CHECK_REAL_EQUAL( -0.706861, vorticity1_val[0 * layers + 1], eps );
                CHECK_REAL_EQUAL( -1.767153, vorticity1_val[1 * layers + 1], eps );
                CHECK_REAL_EQUAL( 0.128216, vorticity1_val[2 * layers + 1], eps );
                CHECK_EQUAL( 1, (int)local_cell_gids[0] );
                CHECK_EQUAL( 366, (int)local_cell_gids[161] );
                CHECK_EQUAL( 1, (int)local_cell_gids[322] );
                EntityHandle cell_ents[] = { local_cells[0], local_cells[161], local_cells[322] };
                // Timestep 0
                // Layer 0
                CHECK_REAL_EQUAL( -1.512985, vorticity0_val[1 * layers], eps );
                CHECK_REAL_EQUAL( 3.629994, vorticity0_val[2 * layers], eps );
                // Layer 1
                CHECK_REAL_EQUAL( -1.512964, vorticity0_val[1 * layers + 1], eps );
                CHECK_REAL_EQUAL( 3.629944, vorticity0_val[2 * layers + 1], eps );
                // Timestep 1
                // Layer 0
                CHECK_REAL_EQUAL( 3.534355, vorticity1_val[0 * layers], eps );
                CHECK_REAL_EQUAL( -1.473122, vorticity1_val[1 * layers], eps );
                CHECK_REAL_EQUAL( 3.534355, vorticity1_val[2 * layers], eps );
                // Layer 1
                CHECK_REAL_EQUAL( 3.534306, vorticity1_val[0 * layers + 1], eps );
                CHECK_REAL_EQUAL( -1.473102, vorticity1_val[1 * layers + 1], eps );
                CHECK_REAL_EQUAL( 3.534306, vorticity1_val[2 * layers + 1], eps );
        else
            CHECK_EQUAL( (size_t)1, local_cell_gids.psize() );
            if( 0 == rank )
                CHECK_EQUAL( 161, (int)local_cell_gids[160] );
                CHECK_EQUAL( 321, (int)local_cell_gids[320] );
                // Timestep 0
                // Layer 0
                // Layer 1
                // Timestep 1
                // Layer 0
                CHECK_REAL_EQUAL( -1.663182, vorticity1_val[1 * layers], eps );
                // Layer 1
                CHECK_REAL_EQUAL( -1.663160, vorticity1_val[1 * layers + 1], eps );
                CHECK_EQUAL( 322, (int)local_cell_gids[0] );
                CHECK_EQUAL( 482, (int)local_cell_gids[160] );
                CHECK_EQUAL( 642, (int)local_cell_gids[320] );
                // Timestep 0
                // Layer 0
                // Layer 1
                // Timestep 1
                // Layer 0
                CHECK_REAL_EQUAL( -0.540269, vorticity1_val[0 * layers], eps );
                CHECK_REAL_EQUAL( 2.370258, vorticity1_val[1 * layers], eps );
                CHECK_REAL_EQUAL( -0.540269, vorticity1_val[2 * layers], eps );
                // Layer 1
                CHECK_REAL_EQUAL( -0.540262, vorticity1_val[0 * layers + 1], eps );
                CHECK_REAL_EQUAL( 2.370226, vorticity1_val[1 * layers + 1], eps );
                CHECK_REAL_EQUAL( -0.540262, vorticity1_val[2 * layers + 1], eps );
Definition at line 84 of file gcrm_par.cpp.
References gather_one_cell_var().
Referenced by main().
Definition at line 89 of file gcrm_par.cpp.
Definition at line 94 of file gcrm_par.cpp.
References multiple_loads_of_same_file().
Definition at line 79 of file gcrm_par.cpp.
References read_mesh_parallel().
    read_mesh_parallel( true );
Definition at line 74 of file gcrm_par.cpp.
    read_mesh_parallel( false );
Definition at line 69 of file gcrm_par.cpp.
References read_one_cell_var().
    read_one_cell_var( true );
Definition at line 64 of file gcrm_par.cpp.
    read_one_cell_var( false );
Variable Documentation
Definition at line 37 of file gcrm_par.cpp.
Definition at line 13 of file gcrm_par.cpp.
Definition at line 38 of file gcrm_par.cpp.
